Two jobs at once on denx-vulcan?
Is there something screwy with this? It seems that denx-vulcan does two builds at once?
https://source.denx.de/u-boot/custodians/u-boot-dm/-/jobs/323540
Regards, SImon
Hm, I did some changes to the vulcan runner which might have caused this... But still, even if it is running multiple jobs in parallel, they should still be isolated, so how does this lead to a build failure?
Hi Harald,
I'm not sure that it does, but I do see this at the above link:
Error: Unable to create '/builds/u-boot/custodians/u-boot-dm/.git/logs/HEAD.lock': File exists.
Re doing multiple builds, have you set it up so it doesn't take on the very large builds? I would love to enable multiple builds for the qemu steps since they mostly use a single CPU, but am not sure how to do it.
Hi Simon,
On Mon, 2021-09-20 at 08:06 -0600, Simon Glass wrote:
Hi Harald,
This is super strange... Each build should be running in its own container so there should never be a way for such a race to occur. No clue what is going on here...
Actually, this was more a mistake than an intentional change. I updated the runner on vulcan to also take jobs for some other repos and wanted those jobs to run in parallel. It looks like I just forgot setting the `limit = 1` option for the U-Boot runner.
Now, I think doing what you suggest is possible. We need to tag build and "test" jobs differently and then define multiple runners with different limits. E.g. in `.gitlab-ci.yml`:
build all 32bit ARM platforms: stage: world build tags: - build
cppcheck: stage: testsuites tags: - test
And then define two runners in `/etc/gitlab-runner/config.toml`:
concurrent = 4
[[runners]] name = "u-boot builder on vulcan" limit = 1 ...
[[runners]] name = "u-boot tester on vulcan" limit = 4 ...
and during registration they get the `build` and `test` tags respectively. This would allow running (in this example) up to 4 test jobs concurrently, but only ever one large build job at once.
On Fri, Sep 24, 2021 at 04:01:21PM +0200, Harald Seiler wrote:
Hi Simon,
Hi Harald,
I know this from having to track down a different oddball failure with konsulko-bootbake. It comes down to something along the lines of volumes being re-used. Good in that it means that every job every time isn't doing a whole clone of the u-boot tree. Bad in that just in case the job gets wedged/killed in a crazy spot you end up with problems like this. If you run a 'find' on vulcan you'll figure out which overlay has a problem. Or you can stop the runner for a moment and tell docker to purge unused volumes and it'll clear it up.
concurrent = 4
Yes, but this would also make it harder for people to use the CI as-is with their own runners. For example, the only thing stopping people from using the free gitlab CI runners on their own is that squashfs test being broken.
Hi Tom,
Hi Simon,
Hi Harald,
build all 32bit ARM platforms: stage: world build tags: - build cppcheck: stage: testsuites tags: - test
concurrent = 4 [[runners]] name = "u-boot builder on vulcan" limit = 1 ... [[runners]] name = "u-boot tester on vulcan" limit = 4 ...
Thanks for the info Harald.
Would it just mean that they would need to add both 'build' and 'test' tags to their running? If so that does not sound onerous.
I believe it would speed up CI quite a bit.
On Fri, Sep 24, 2021 at 08:38:49AM -0600, Simon Glass wrote:
Hi Tom,
Hi Simon,
Hi Harald,
Along with not being able to use the gitlab free runners.
I'm not sure? First, did you upgrade your runners recently? I started by looking at https://source.denx.de/u-boot/u-boot/-/pipelines/9238/builds and all of the last stage jobs went super quick. But second, assuming the time there includes spinning up the runner, sandbox+clang took 2x as long to run as regular sandbox, to run less tests: https://source.denx.de/u-boot/u-boot/-/jobs/326772 https://source.denx.de/u-boot/u-boot/-/jobs/326773
But we might save a minute, or two, if all of the other much quicker tests ran to completion sooner, but we'd still be stuck waiting on the longest running test.
So while I think splitting the job in to stages, such that if something fails early we call it all off, a time test where we just have a single stage would mean more stuff in parallel and maybe would be quicker, especially when we have more free runners. And to me, sadly, that's our biggest gating factor and the one that can be solved with money rather than technical wizardry.
Hi Tom,
Hi Tom,
Hi Simon,
Hi Harald,
On Sat, 2021-09-18 at 10:37 -0600, Simon Glass wrote: > Hi, > > Is there something screwy with this? It seems that denx-vulcan does > two builds at once? > > https://source.denx.de/u-boot/custodians/u-boot-dm/-/jobs/323540
They are the same as ever: tui did about 1 build per second on average and kaki did 0.5 builds per second, but this has slowed by about 15% recently. They are both have quite a few cores. It could just be that the other two runners were busy so kaki and tui did everything.
Yes but tui is 2x as fast as kaki (both in terms of number of CPUs and single-threaded performance) so that might explain it.
Yes, which can be many minutes. But each qemu run takes a good minute and we have about 30 of them now. Even if all four runners are running on them, then that is 7 minutes. In parallel it might only take a minute or two.
Make sense. The other problem is that, to run the tests in parallel, we might need to clean some of them up (the series I sent is a start on that). But I think tui could probably run all the qemu jobs in parallel at once, for example.
So perhaps we can come back to this when we get parallel tests running. It definitely is not efficient at present, in the second (qemu) stage.
On Fri, Sep 24, 2021 at 05:36:31PM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Simon,
Hi Harald,
On Mon, 20 Sept 2021 at 02:12, Harald Seiler hws@denx.de wrote: > > Hi, > > On Sat, 2021-09-18 at 10:37 -0600, Simon Glass wrote: > > Hi, > > > > Is there something screwy with this? It seems that denx-vulcan does > > two builds at once? > > > > https://source.denx.de/u-boot/custodians/u-boot-dm/-/jobs/323540 > > Hm, I did some changes to the vulcan runner which might have caused > this... But still, even if it is running multiple jobs in parallel, they > should still be isolated, so how does this lead to a build failure?
OK. And I guess the other part of this would be that you could take tui/kaki/etc out of general rotation for a bit and run some pipelines to see what the time change is with your ideas in place.
Harald Seiler
