[PATCH 1/1] efi_loader: require CONFIG_BLK
The move to driver model should by now be completed. To be able to remove pre-driver model code from our block IO code require CONFIG_BLK=y for UEFI support.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index dacc3b5881..692cf5ced0 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -10,6 +10,7 @@ config EFI_LOADER depends on !EFI_STUB || !X86_64 || EFI_STUB_64BIT # We need EFI_STUB_32BIT to be set on x86_32 with EFI_STUB depends on !EFI_STUB || !X86 || X86_64 || EFI_STUB_32BIT + depends on BLK default y if !ARM || SYS_CPU = armv7 || SYS_CPU = armv8 select LIB_UUID select PARTITION_UUIDS -- 2.30.2
If so, we can safely remove !CONFIG_BLK-related code from efi_disk.c and efi_device_path.c.
-Takahiro Akashi
- depends on BLK default y if !ARM || SYS_CPU = armv7 || SYS_CPU = armv8 select LIB_UUID select PARTITION_UUIDS
-- 2.30.2
Yes, that was my intent. As we want to improve the integration with the driver model we should get rid of the outdated non-BLK code. Let's merge that into the next branch.
Best regards
Heinrich
-Takahiro Akashi
-- 2.30.2
Hi Heinrich,
I have a patch locally for that. I hope to send the series out soon.
Best regards
Heinrich
-Takahiro Akashi
-- 2.30.2
AKASHI Takahiro
