[PATCH 1/1] api: add missing cookie checks for network access
dev_write_net() and dev_read_net() should validate the provided cookie.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- api/api_net.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/api/api_net.c b/api/api_net.c index 7515c26e8b4..0b931a80787 100644 --- a/api/api_net.c +++ b/api/api_net.c @@ -72,14 +72,16 @@ int dev_enum_net(struct device_info *di)
int dev_write_net(void *cookie, void *buf, int len) { - /* XXX verify that cookie points to a valid net device??? */ + if (!dev_valid_net(cookie)) + return API_ENODEV;
return eth_send(buf, len); }
int dev_read_net(void *cookie, void *buf, int len) { - /* XXX verify that cookie points to a valid net device??? */ + if (!dev_valid_net(cookie)) + return API_ENODEV;
return eth_receive(buf, len); }
return API_ENODEV;
return API_ENODEV;
Is this right? Probably. But what triggered looking in to this to start with? I don't think anything is enabling the API support these days even.
return API_ENODEV;
return API_ENODEV;
We should either properly test the API in our CI or or remove it.
What once was done via the API could be done via an EFI payload in a more portable way today.
Best regards
Heinrich
diff --git a/api/api_net.c b/api/api_net.c index 7515c26e8b4..0b931a80787 100644 --- a/api/api_net.c +++ b/api/api_net.c @@ -72,14 +72,16 @@ int dev_enum_net(struct device_info *di) int dev_write_net(void *cookie, void *buf, int len) {
- if (!dev_valid_net(cookie))
return eth_send(buf, len); } int dev_read_net(void *cookie, void *buf, int len) {return API_ENODEV;
return eth_receive(buf, len); }return API_ENODEV;
Yes, we should indeed likely remove it.
