[U-Boot] [PATCH 0/2] Add initial support for AQUILA-CYGNUS
IGEP COM AQUILA and CYGNUS are two computer-on-module based on AM3354 and AM3352 processors. Both use SODIMM from factor and are designed for industrial range purpose.
Enric Balletbo i Serra (2): Add DDR3 support for IGEP COM AQUILA/CYGNUS. ARM: Add support for IGEP COM AQUILA/CYGNUS
MAINTAINERS | 1 + arch/arm/include/asm/arch-am33xx/ddr_defs.h | 17 ++ board/isee/igep0033/Makefile | 46 ++++ board/isee/igep0033/board.c | 232 +++++++++++++++++++++ board/isee/igep0033/board.h | 27 +++ board/isee/igep0033/mux.c | 89 ++++++++ boards.cfg | 1 + include/configs/igep0033.h | 300 +++++++++++++++++++++++++++ 8 files changed, 713 insertions(+) create mode 100644 board/isee/igep0033/Makefile create mode 100644 board/isee/igep0033/board.c create mode 100644 board/isee/igep0033/board.h create mode 100644 board/isee/igep0033/mux.c create mode 100644 include/configs/igep0033.h
These boards uses Samsung K4B2G1646E-BIH9 a 2Gb E-die DDR3 SDRAM.
Signed-off-by: Enric Balletbo i Serra eballetbo@iseebcn.com --- arch/arm/include/asm/arch-am33xx/ddr_defs.h | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/arch/arm/include/asm/arch-am33xx/ddr_defs.h b/arch/arm/include/asm/arch-am33xx/ddr_defs.h index 260cc34..4ebc557 100644 --- a/arch/arm/include/asm/arch-am33xx/ddr_defs.h +++ b/arch/arm/include/asm/arch-am33xx/ddr_defs.h @@ -117,6 +117,23 @@ #define MT41J512M8RH125_PHY_WR_DATA 0x74 #define MT41J512M8RH125_IOCTRL_VALUE 0x18B
+/* Samsung K4B2G1646E-BIH9 */ +#define K4B2G1646EBIH9_EMIF_READ_LATENCY 0x06 +#define K4B2G1646EBIH9_EMIF_TIM1 0x0888A39B +#define K4B2G1646EBIH9_EMIF_TIM2 0x2A04011A +#define K4B2G1646EBIH9_EMIF_TIM3 0x501F820F +#define K4B2G1646EBIH9_EMIF_SDCFG 0x61C24AB2 +#define K4B2G1646EBIH9_EMIF_SDREF 0x0000093B +#define K4B2G1646EBIH9_ZQ_CFG 0x50074BE4 +#define K4B2G1646EBIH9_DLL_LOCK_DIFF 0x1 +#define K4B2G1646EBIH9_RATIO 0x40 +#define K4B2G1646EBIH9_INVERT_CLKOUT 0x1 +#define K4B2G1646EBIH9_RD_DQS 0x3B +#define K4B2G1646EBIH9_WR_DQS 0x85 +#define K4B2G1646EBIH9_PHY_FIFO_WE 0x100 +#define K4B2G1646EBIH9_PHY_WR_DATA 0xC1 +#define K4B2G1646EBIH9_IOCTRL_VALUE 0x18B + /** * Configure DMM */
The IGEP COM AQUILA and CYGNUS are industrial processors modules with following highlights:
o AM3352/AM3354 Texas Instruments processor o Cortex-A8 ARM CPU o 3.3 volts Inputs / Outputs use industrial o 256 MB DDR3 SDRAM / 128 Megabytes FLASH o MicroSD card reader on-board o Ethernet controller on-board o JTAG debug connector available o Designed for industrial range purposes
Signed-off-by: Enric Balletbo i Serra eballetbo@iseebcn.com --- MAINTAINERS | 1 + board/isee/igep0033/Makefile | 46 +++++++ board/isee/igep0033/board.c | 232 ++++++++++++++++++++++++++++++++ board/isee/igep0033/board.h | 27 ++++ board/isee/igep0033/mux.c | 89 +++++++++++++ boards.cfg | 1 + include/configs/igep0033.h | 300 ++++++++++++++++++++++++++++++++++++++++++ 7 files changed, 696 insertions(+) create mode 100644 board/isee/igep0033/Makefile create mode 100644 board/isee/igep0033/board.c create mode 100644 board/isee/igep0033/board.h create mode 100644 board/isee/igep0033/mux.c create mode 100644 include/configs/igep0033.h
diff --git a/MAINTAINERS b/MAINTAINERS index 1614b91..6cfcf83 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -607,6 +607,7 @@ Enric Balletbo i Serra eballetbo@iseebcn.com igep0020 ARM ARMV7 (OMAP3xx SoC) igep0030 ARM ARMV7 (OMAP3xx SoC) igep0032 ARM ARMV7 (OMAP3xx SoC) + igep0033 ARM ARMV7 (AM33xx Soc)
Eric Benard eric@eukrea.com
diff --git a/board/isee/igep0033/Makefile b/board/isee/igep0033/Makefile new file mode 100644 index 0000000..54a4b75 --- /dev/null +++ b/board/isee/igep0033/Makefile @@ -0,0 +1,46 @@ +# +# Makefile +# +# Copyright (C) 2013, ISEE 2007 SL - http://www.isee.biz/ +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed "as is" WITHOUT ANY WARRANTY of any +# kind, whether express or implied; without even the implied warranty +# of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +ifdef CONFIG_SPL_BUILD +COBJS := mux.o +endif + +COBJS += board.o +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/isee/igep0033/board.c b/board/isee/igep0033/board.c new file mode 100644 index 0000000..d315516 --- /dev/null +++ b/board/isee/igep0033/board.c @@ -0,0 +1,232 @@ +/* + * Board functions for IGEP COM AQUILA/CYGNUS based boards + * + * Copyright (C) 2013, ISEE 2007 SL - http://www.isee.biz/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <errno.h> +#include <spl.h> +#include <asm/arch/cpu.h> +#include <asm/arch/hardware.h> +#include <asm/arch/omap.h> +#include <asm/arch/ddr_defs.h> +#include <asm/arch/clock.h> +#include <asm/arch/gpio.h> +#include <asm/arch/mmc_host_def.h> +#include <asm/arch/sys_proto.h> +#include <asm/io.h> +#include <asm/emif.h> +#include <asm/gpio.h> +#include <i2c.h> +#include <miiphy.h> +#include <cpsw.h> +#include "board.h" + +DECLARE_GLOBAL_DATA_PTR; + +static struct wd_timer *wdtimer = (struct wd_timer *)WDT_BASE; +#ifdef CONFIG_SPL_BUILD +static struct uart_sys *uart_base = (struct uart_sys *)DEFAULT_UART_BASE; +#endif + +/* MII mode defines */ +#define RMII_MODE_ENABLE 0x4D + +static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE; + +/* UART Defines */ +#ifdef CONFIG_SPL_BUILD +#define UART_RESET (0x1 << 1) +#define UART_CLK_RUNNING_MASK 0x1 +#define UART_SMART_IDLE_EN (0x1 << 0x3) + +static void rtc32k_enable(void) +{ + struct rtc_regs *rtc = (struct rtc_regs *)RTC_BASE; + + /* + * Unlock the RTC's registers. For more details please see the + * RTC_SS section of the TRM. In order to unlock we need to + * write these specific values (keys) in this order. + */ + writel(0x83e70b13, &rtc->kick0r); + writel(0x95a4f1e0, &rtc->kick1r); + + /* Enable the RTC 32K OSC by setting bits 3 and 6. */ + writel((1 << 3) | (1 << 6), &rtc->osc); +} + +static const struct ddr_data ddr3_data = { + .datardsratio0 = K4B2G1646EBIH9_RD_DQS, + .datawdsratio0 = K4B2G1646EBIH9_WR_DQS, + .datafwsratio0 = K4B2G1646EBIH9_PHY_FIFO_WE, + .datawrsratio0 = K4B2G1646EBIH9_PHY_WR_DATA, + .datadldiff0 = PHY_DLL_LOCK_DIFF, +}; + +static const struct cmd_control ddr3_cmd_ctrl_data = { + .cmd0csratio = K4B2G1646EBIH9_RATIO, + .cmd0dldiff = K4B2G1646EBIH9_DLL_LOCK_DIFF, + .cmd0iclkout = K4B2G1646EBIH9_INVERT_CLKOUT, + + .cmd1csratio = K4B2G1646EBIH9_RATIO, + .cmd1dldiff = K4B2G1646EBIH9_DLL_LOCK_DIFF, + .cmd1iclkout = K4B2G1646EBIH9_INVERT_CLKOUT, + + .cmd2csratio = K4B2G1646EBIH9_RATIO, + .cmd2dldiff = K4B2G1646EBIH9_DLL_LOCK_DIFF, + .cmd2iclkout = K4B2G1646EBIH9_INVERT_CLKOUT, +}; + +static struct emif_regs ddr3_emif_reg_data = { + .sdram_config = K4B2G1646EBIH9_EMIF_SDCFG, + .ref_ctrl = K4B2G1646EBIH9_EMIF_SDREF, + .sdram_tim1 = K4B2G1646EBIH9_EMIF_TIM1, + .sdram_tim2 = K4B2G1646EBIH9_EMIF_TIM2, + .sdram_tim3 = K4B2G1646EBIH9_EMIF_TIM3, + .zq_config = K4B2G1646EBIH9_ZQ_CFG, + .emif_ddr_phy_ctlr_1 = K4B2G1646EBIH9_EMIF_READ_LATENCY, +}; +#endif + +/* + * Early system init of muxing and clocks. + */ +void s_init(void) +{ + /* WDT1 is already running when the bootloader gets control + * Disable it to avoid "random" resets + */ + writel(0xAAAA, &wdtimer->wdtwspr); + while (readl(&wdtimer->wdtwwps) != 0x0) + ; + writel(0x5555, &wdtimer->wdtwspr); + while (readl(&wdtimer->wdtwwps) != 0x0) + ; + +#ifdef CONFIG_SPL_BUILD + /* Setup the PLLs and the clocks for the peripherals */ + pll_init(); + + /* Enable RTC32K clock */ + rtc32k_enable(); + + /* UART softreset */ + u32 regval; + + enable_uart0_pin_mux(); + + regval = readl(&uart_base->uartsyscfg); + regval |= UART_RESET; + writel(regval, &uart_base->uartsyscfg); + while ((readl(&uart_base->uartsyssts) & + UART_CLK_RUNNING_MASK) != UART_CLK_RUNNING_MASK) + ; + + /* Disable smart idle */ + regval = readl(&uart_base->uartsyscfg); + regval |= UART_SMART_IDLE_EN; + writel(regval, &uart_base->uartsyscfg); + + gd = &gdata; + + preloader_console_init(); + + /* Configure board pin mux */ + enable_board_pin_mux(); + + config_ddr(303, K4B2G1646EBIH9_IOCTRL_VALUE, &ddr3_data, + &ddr3_cmd_ctrl_data, &ddr3_emif_reg_data, 0); +#endif +} + +/* + * Basic board specific setup. Pinmux has been handled already. + */ +int board_init(void) +{ + gd->bd->bi_boot_params = PHYS_DRAM_1 + 0x100; + + gpmc_init(); + + return 0; +} + +#if defined(CONFIG_DRIVER_TI_CPSW) +static void cpsw_control(int enabled) +{ + /* VTP can be added here */ + + return; +} + +static struct cpsw_slave_data cpsw_slaves[] = { + { + .slave_reg_ofs = 0x208, + .sliver_reg_ofs = 0xd80, + .phy_id = 0, + .phy_if = PHY_INTERFACE_MODE_RMII, + }, +}; + +static struct cpsw_platform_data cpsw_data = { + .mdio_base = CPSW_MDIO_BASE, + .cpsw_base = CPSW_BASE, + .mdio_div = 0xff, + .channels = 8, + .cpdma_reg_ofs = 0x800, + .slaves = 1, + .slave_data = cpsw_slaves, + .ale_reg_ofs = 0xd00, + .ale_entries = 1024, + .host_port_reg_ofs = 0x108, + .hw_stats_reg_ofs = 0x900, + .mac_control = (1 << 5), + .control = cpsw_control, + .host_port_num = 0, + .version = CPSW_CTRL_VERSION_2, +}; + +int board_eth_init(bd_t *bis) +{ + int rv, ret = 0; + uint8_t mac_addr[6]; + uint32_t mac_hi, mac_lo; + + if (!eth_getenv_enetaddr("ethaddr", mac_addr)) { + /* try reading mac address from efuse */ + mac_lo = readl(&cdev->macid0l); + mac_hi = readl(&cdev->macid0h); + mac_addr[0] = mac_hi & 0xFF; + mac_addr[1] = (mac_hi & 0xFF00) >> 8; + mac_addr[2] = (mac_hi & 0xFF0000) >> 16; + mac_addr[3] = (mac_hi & 0xFF000000) >> 24; + mac_addr[4] = mac_lo & 0xFF; + mac_addr[5] = (mac_lo & 0xFF00) >> 8; + if (is_valid_ether_addr(mac_addr)) + eth_setenv_enetaddr("ethaddr", mac_addr); + } + + writel(RMII_MODE_ENABLE, &cdev->miisel); + + rv = cpsw_register(&cpsw_data); + if (rv < 0) + printf("Error %d registering CPSW switch\n", rv); + else + ret += rv; + + return ret; +} +#endif + diff --git a/board/isee/igep0033/board.h b/board/isee/igep0033/board.h new file mode 100644 index 0000000..37988e0 --- /dev/null +++ b/board/isee/igep0033/board.h @@ -0,0 +1,27 @@ +/* + * IGEP COM AQUILA/CYGNUS boards information header + * + * Copyright (C) 2013, ISEE 2007 SL - http://www.isee.biz/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _BOARD_H_ +#define _BOARD_H_ + +/* + * We must be able to enable uart0, for initial output. We then have a + * main pinmux function that can be overridden to enable all other pinmux that + * is required on the board. + */ +void enable_uart0_pin_mux(void); +void enable_board_pin_mux(void); +#endif diff --git a/board/isee/igep0033/mux.c b/board/isee/igep0033/mux.c new file mode 100644 index 0000000..16f4add --- /dev/null +++ b/board/isee/igep0033/mux.c @@ -0,0 +1,89 @@ +/* + * Copyright (C) 2013, ISEE 2007 SL - http://www.isee.biz/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/hardware.h> +#include <asm/arch/mux.h> +#include <asm/io.h> +#include <i2c.h> +#include "board.h" + +static struct module_pin_mux uart0_pin_mux[] = { + {OFFSET(uart0_rxd), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART0_RXD */ + {OFFSET(uart0_txd), (MODE(0) | PULLUDEN)}, /* UART0_TXD */ + {-1}, +}; + +static struct module_pin_mux mmc0_pin_mux[] = { + {OFFSET(mmc0_dat3), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT3 */ + {OFFSET(mmc0_dat2), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT2 */ + {OFFSET(mmc0_dat1), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT1 */ + {OFFSET(mmc0_dat0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT0 */ + {OFFSET(mmc0_clk), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CLK */ + {OFFSET(mmc0_cmd), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CMD */ + {OFFSET(mcasp0_aclkx), (MODE(4) | RXACTIVE)}, /* MMC0_CD */ + {-1}, +}; + +static struct module_pin_mux nand_pin_mux[] = { + {OFFSET(gpmc_ad0), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD0 */ + {OFFSET(gpmc_ad1), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD1 */ + {OFFSET(gpmc_ad2), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD2 */ + {OFFSET(gpmc_ad3), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD3 */ + {OFFSET(gpmc_ad4), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD4 */ + {OFFSET(gpmc_ad5), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD5 */ + {OFFSET(gpmc_ad6), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD6 */ + {OFFSET(gpmc_ad7), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD7 */ + {OFFSET(gpmc_wait0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* NAND WAIT */ + {OFFSET(gpmc_wpn), (MODE(7) | PULLUP_EN | RXACTIVE)}, /* NAND_WPN */ + {OFFSET(gpmc_csn0), (MODE(0) | PULLUDEN)}, /* NAND_CS0 */ + {OFFSET(gpmc_advn_ale), (MODE(0) | PULLUDEN)}, /* NAND_ADV_ALE */ + {OFFSET(gpmc_oen_ren), (MODE(0) | PULLUDEN)}, /* NAND_OE */ + {OFFSET(gpmc_wen), (MODE(0) | PULLUDEN)}, /* NAND_WEN */ + {OFFSET(gpmc_be0n_cle), (MODE(0) | PULLUDEN)}, /* NAND_BE_CLE */ + {-1}, +}; + +static struct module_pin_mux rmii1_pin_mux[] = { + {OFFSET(mii1_txen), MODE(1)}, /* RMII1_TXEN */ + {OFFSET(mii1_rxerr), MODE(1) | RXACTIVE}, /* RMII1_RXERR */ + {OFFSET(mii1_crs), MODE(1) | RXACTIVE}, /* RMII1_CRS_DV */ + {OFFSET(mii1_rxd0), MODE(1) | RXACTIVE}, /* RMII1_RXD0 */ + {OFFSET(mii1_rxd1), MODE(1) | RXACTIVE}, /* RMII1_RXD1 */ + {OFFSET(mii1_txd0), MODE(1)}, /* RMII1_TXD0 */ + {OFFSET(mii1_txd1), MODE(1)}, /* RMII1_TXD1 */ + {OFFSET(rmii1_refclk), MODE(0) | RXACTIVE}, /* RMII1_REF_CLK */ + {OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* MDIO_DATA */ + {OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* MDIO_CLK */ + {-1}, +}; + +void enable_uart0_pin_mux(void) +{ + configure_module_pin_mux(uart0_pin_mux); +} + +/* + * Do board-specific muxes. + */ +void enable_board_pin_mux(void) +{ + /* NAND Flash */ + configure_module_pin_mux(nand_pin_mux); + /* SD Card */ + configure_module_pin_mux(mmc0_pin_mux); + /* Ethernet pinmux. */ + configure_module_pin_mux(rmii1_pin_mux); +} + diff --git a/boards.cfg b/boards.cfg index 5fc70be..faf5614 100644 --- a/boards.cfg +++ b/boards.cfg @@ -273,6 +273,7 @@ igep0020_nand arm armv7 igep00x0 isee igep0030 arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_ONENAND igep0030_nand arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_NAND igep0032 arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0032,BOOT_ONENAND +igep0033 arm armv7 igep0033 isee am33xx am3517_evm arm armv7 am3517evm logicpd omap3 mt_ventoux arm armv7 mt_ventoux teejet omap3 omap3_zoom1 arm armv7 zoom1 logicpd omap3 diff --git a/include/configs/igep0033.h b/include/configs/igep0033.h new file mode 100644 index 0000000..0962c34 --- /dev/null +++ b/include/configs/igep0033.h @@ -0,0 +1,300 @@ +/* + * Copyright (C) 2013, ISEE 2007 SL - http://www.isee.biz/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef __CONFIG_IGEP0033_H +#define __CONFIG_IGEP0033_H + +#define CONFIG_AM33XX + +#include <asm/arch/omap.h> + +/* Mach type */ +#define MACH_TYPE_IGEP0033 4521 /* Until the next sync */ +#define CONFIG_MACH_TYPE MACH_TYPE_IGEP0033 + +/* Clock defines */ +#define V_OSCK 24000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK) + +/* DMA defines */ +#define CONFIG_DMA_COHERENT +#define CONFIG_DMA_COHERENT_SIZE (1 << 20) + +#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_SYS_MALLOC_LEN (1024 << 10) +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT "U-Boot# " +#define CONFIG_SYS_NO_FLASH + +/* Display cpuinfo */ +#define CONFIG_DISPLAY_CPUINFO +/* Add libfdt-based support */ +#define CONFIG_OF_LIBFDT +/* Enable passing of ATAGs */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG + +/* Commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ECHO +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_FS_GENERIC +#define CONFIG_CMD_MMC +#define CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS + +#define CONFIG_BOOTDELAY 1 /* negative for no autoboot */ +#define CONFIG_ENV_VARS_UBOOT_CONFIG +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x80200000\0" \ + "fdtaddr=0x80F80000\0" \ + "fdt_high=0xffffffff\0" \ + "rdaddr=0x81000000\0" \ + "bootfile=/boot/uImage\0" \ + "fdtfile=\0" \ + "console=ttyO0,115200n8\0" \ + "optargs=\0" \ + "mmcdev=0\0" \ + "mmcroot=/dev/mmcblk0p2 rw\0" \ + "mmcrootfstype=ext4 rootwait\0" \ + "ramroot=/dev/ram0 rw ramdisk_size=65536 initrd=${rdaddr},64M\0" \ + "ramrootfstype=ext2\0" \ + "mmcargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ + "bootenv=uEnv.txt\0" \ + "loadbootenv=load mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ + "importbootenv=echo Importing environment from mmc ...; " \ + "env import -t $loadaddr $filesize\0" \ + "ramargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${ramroot} " \ + "rootfstype=${ramrootfstype}\0" \ + "loadramdisk=load mmc ${mmcdev} ${rdaddr} ramdisk.gz\0" \ + "loaduimagefat=load mmc ${mmcdev} ${loadaddr} ${bootfile}\0" \ + "loaduimage=load mmc ${mmcdev}:2 ${loadaddr} ${bootfile}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "ramboot=echo Booting from ramdisk ...; " \ + "run ramargs; " \ + "bootm ${loadaddr}\0" \ + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "echo SD/MMC found on device ${mmcdev};" \ + "if run loadbootenv; then " \ + "echo Loaded environment from ${bootenv};" \ + "run importbootenv;" \ + "fi;" \ + "if test -n $uenvcmd; then " \ + "echo Running uenvcmd ...;" \ + "run uenvcmd;" \ + "fi;" \ + "if run loaduimage; then " \ + "run mmcboot;" \ + "fi;" \ + "fi;" \ + + + +/* Max number of command args */ +#define CONFIG_SYS_MAXARGS 16 + +/* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 512 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ + + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* + * memtest works on 8 MB in DRAM after skipping 32MB from + * start addr of ram disk + */ +#define CONFIG_SYS_MEMTEST_START (PHYS_DRAM_1 + (64 * 1024 * 1024)) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START \ + + (8 * 1024 * 1024)) + +#define CONFIG_SYS_LOAD_ADDR 0x81000000 /* Default load address */ +#define CONFIG_SYS_HZ 1000 /* 1ms clock */ + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_DRAM_1 0x80000000 /* DRAM Bank #1 */ +#define CONFIG_MAX_RAM_BANK_SIZE (1024 << 20) /* 1GB */ + +#define CONFIG_SYS_SDRAM_BASE PHYS_DRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (NON_SECURE_SRAM_END - \ + GENERATED_GBL_DATA_SIZE) +/* Platform/Board specific defs */ +#define CONFIG_SYS_TIMERBASE 0x48040000 /* Use Timer2 */ +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +/* NS16550 Configuration */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK (48000000) +#define CONFIG_SYS_NS16550_COM1 0x44e09000 /* UART0 */ + +#define CONFIG_SERIAL_MULTI +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_SYS_CONSOLE_INFO_QUIET + +/* MMC support */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_OMAP_HSMMC +#define CONFIG_DOS_PARTITION + +/* GPIO support */ +#define CONFIG_OMAP_GPIO + +/* Ethernet support */ +#define CONFIG_DRIVER_TI_CPSW +#define CONFIG_MII +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_SUBNETMASK +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI +#define CONFIG_PHYLIB +#define CONFIG_PHY_ADDR 0 +#define CONFIG_PHY_SMSC + +/* NAND support */ +#define CONFIG_NAND +#define CONFIG_NAND_OMAP_GPMC +#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 +#define CONFIG_SYS_NAND_BASE (0x08000000) /* phys address CS0 */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_ONFI_DETECTION 1 +#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ + +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#define CONFIG_RBTREE +#define CONFIG_LZO + +#define MTDIDS_DEFAULT "nand0=nand" +#define MTDPARTS_DEFAULT "mtdparts=nand:512k(SPL),"\ + "1920k(U-Boot),128k(U-Boot Env),"\ + "5m(Kernel),-(File System)" + +/* Unsupported features */ +#undef CONFIG_USE_IRQ + +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x402F0400 +#define CONFIG_SPL_MAX_SIZE (101 * 1024) +#define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR + +#define CONFIG_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SPL_YMODEM_SUPPORT +#define CONFIG_SPL_NET_SUPPORT +#define CONFIG_SPL_NET_VCI_STRING "AM335x U-Boot SPL" +#define CONFIG_SPL_ETH_SUPPORT +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/am33xx/u-boot-spl.lds" + +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SPL_NAND_AM33XX_BCH +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_ECC +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12, 13, 14, 15, 16, 17, \ + 18, 19, 20, 21, 22, 23, 24, 25, \ + 26, 27, 28, 29, 30, 31, 32, 33, \ + 34, 35, 36, 37, 38, 39, 40, 41, \ + 42, 43, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56, 57, } + +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 14 + +#define CONFIG_SYS_NAND_ECCSTEPS 4 +#define CONFIG_SYS_NAND_ECCTOTAL (CONFIG_SYS_NAND_ECCBYTES * \ + CONFIG_SYS_NAND_ECCSTEPS) + +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 + +/* + * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM + * 64 bytes before this address should be set aside for u-boot.img's + * header. That is 0x800FFFC0--0x80100000 should not be used for any + * other needs. + */ +#define CONFIG_SYS_TEXT_BASE 0x80800000 +#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 + +/* Since SPL did pll and ddr initialization for us, + * we don't need to do it twice. + */ +#ifndef CONFIG_SPL_BUILD +#define CONFIG_SKIP_LOWLEVEL_INIT +#endif + +#endif /* ! __CONFIG_IGEP0033_H */
In general, yay. But some specific comments that I know you inherited:
[snip]
Do you really have to support ATAGS and FDT? Just confirming.
With CONFIG_CMD_FS_GENERIC and CMD_EXT4 do you really need CMD_EXT2 set?
[snip]
- "loadaddr=0x80200000\0" \
- "fdtaddr=0x80F80000\0" \
- "fdt_high=0xffffffff\0" \
- "rdaddr=0x81000000\0" \
- "bootfile=/boot/uImage\0" \
- "fdtfile=\0" \
You're setting the config options to get an easy run-time way to set fdtfile but not providing a script command to set it nor a C function. If you don't need run-time detection, just set fdtfile :)
- memtest works on 8 MB in DRAM after skipping 32MB from
- start addr of ram disk
The comment is wrong, and you can do any of: - Opt-out of mtest (and see Wolfgang's readme on why that's probably a good idea) - Correct this to be all of RAM, minus a bit for a reasonably-sized U-Boot to be running in.
[snip]
Setting aside such a large space for U-Boot is something else you inherited, do you want to re-evaluate this or too late?
Keeping in mind the errata involved, does your board support CPSW SPL without needed the erratad-out mode?
Hi Tom,
Thanks for your comments.
2013/4/4 Tom Rini trini@ti.com
[snip]
No, I'll remove.
You have reason, has no sense, I'll remove too.
[snip]
"fdtfile=\0" \
I'll remove ftd related variables until fdt support is not tested.
Readed and convinced. Thanks for this point.
[snip]
Is not too late, I'll reduce the U-Boot space, do you think 512k is sufficient ?
We'll change the default bootmode in production boards so has no sense define this. I'll remove.
I'll send version 2, thanks again.
Cheers, Enric
-- Tom
Tom,
One more question...
2013/4/4 Enric Balletbo Serra eballetbo@gmail.com
Hi Tom,
[snip]
No, I'll remove.
[snip]
"fdtfile=\0" \
As explained in Wolfgang's readme shouldn't remove CONFIG_CMD_MEMTEST from config_cmd_default.h ?
[snip]
Cheers, Enric
-- Tom
On Thu, Apr 04, 2013 at 09:51:05AM +0200, Enric Balletbo Serra wrote:
[snip]
When the time comes, as stated in doc/feature-removal-schedule.txt :) For now, #undef it.
[snip]
[snip]
Well, what redudancy are you doing? A single image within 512KiB is fine, sure. Two images wouldn't be, most likely :)
