[PATCH] net: Fix error if some network features are disabled
If 'CONFIG_CMD_TFTPBOOT' or 'CONFIG_CMD_BOOTP' are disabled, the usage must be disabled, too!
Signed-off-by: Olaf Krebs olaf.krebs@emh-metering.com CC: Joe Hershberger joe.hershberger@ni.com --- cmd/net.c | 6 ++++++ net/net.c | 6 ++++-- 2 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/cmd/net.c b/cmd/net.c index 1b724cc570..f4f57d9e56 100644 --- a/cmd/net.c +++ b/cmd/net.c @@ -129,11 +129,15 @@ static void netboot_update_env(void) env_set("netmask", tmp); }
+#ifdef CONFIG_CMD_BOOTP if (net_hostname[0]) env_set("hostname", net_hostname); +#endif
+#ifdef CONFIG_CMD_BOOTP if (net_root_path[0]) env_set("rootpath", net_root_path); +#endif
if (net_ip.s_addr) { ip_to_string(net_ip, tmp); @@ -159,8 +163,10 @@ static void netboot_update_env(void) env_set("dnsip2", tmp); } #endif +#ifdef CONFIG_CMD_BOOTP if (net_nis_domain[0]) env_set("domain", net_nis_domain); +#endif
#if defined(CONFIG_CMD_SNTP) && defined(CONFIG_BOOTP_TIMEOFFSET) if (net_ntp_time_offset) { diff --git a/net/net.c b/net/net.c index 087d399a24..21f6e60e6e 100644 --- a/net/net.c +++ b/net/net.c @@ -454,6 +454,7 @@ restart: net_dev_exists = 1; net_boot_file_size = 0; switch (protocol) { +#ifdef CONFIG_CMD_TFTPBOOT case TFTPGET: #ifdef CONFIG_CMD_TFTPPUT case TFTPPUT: @@ -461,6 +462,7 @@ restart: /* always use ARP to get server ethernet address */ tftp_start(protocol); break; +#endif #ifdef CONFIG_CMD_TFTPSRV case TFTPSRV: tftp_start_server(); @@ -478,13 +480,13 @@ restart: dhcp_request(); /* Basically same as BOOTP */ break; #endif - +#if defined(CONFIG_CMD_BOOTP) case BOOTP: bootp_reset(); net_ip.s_addr = 0; bootp_request(); break; - +#endif #if defined(CONFIG_CMD_RARP) case RARP: rarp_try = 0;
Krebs, Olaf
