[U-Boot] [PATCH v3 00/16] rk3188 uboot support
this is meant as a status update and possible discussion for the core parts if needed.
After talking with Simon and Tom the order is now also correct with tpl -> spl -> uboot.
Status right now is: - the full uboot still works - the tpl/spl does start and is able to configure the ddr into a working state - The jump spl -> bootrom -> uboot doesn't work though
On the other hand, Kever was able to make this work, booting from nand when building the image with a very ancient tool.
All newer tools (including boot_merger.c from Rockchip's uboot) do not produce working images. But it is possible to produce a working sd-boot image using the proprietary 1st-stage loader.
See the temporary mkuboot script in the last patch, which can create both types of images now (especially wrt. the needed rc4 encryption of everything).
Combining this (it does work using some special tool), it looks like there is still some minor glitch in the way we build the spl image somewhere.
Heiko Stuebner (16): dm: allow limiting pre-reloc markings to spl or tpl rockchip: move bootrom helper compilation to a hidden option rockchip: mkimage: Allow encoding of loader code in spl images rockchip: mkimage: Add support rk3188 serial rockchip: serial: Adapt rockchip of-platdata driver for rk3188 rockchip: rk3188: Add header files for PMU and GRF rockchip: rk3188: Add pinctrl driver rockchip: rk3188: Add sysreset driver rockchip: rk3188: Add rk3066/rk3188 clock bindings rockchip: rk3188: Add clock driver rockchip: rk3188: Add core devicetree files rockchip: rk3188: Add core support rockchip: rk3188: Add sdram driver rockchip: rk3188: Add main, spl and tpl boards rockchip: rk3188: Add Radxa Rock board Add a temporary script that can create a bootimage for rk3188
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3188-radxarock.dts | 382 +++++++++ arch/arm/dts/rk3188.dtsi | 601 +++++++++++++++ arch/arm/dts/rk3xxx.dtsi | 417 ++++++++++ arch/arm/include/asm/arch-rockchip/cru_rk3188.h | 191 +++++ arch/arm/include/asm/arch-rockchip/ddr_rk3188.h | 22 + arch/arm/include/asm/arch-rockchip/grf_rk3188.h | 589 ++++++++++++++ arch/arm/include/asm/arch-rockchip/pmu_rk3188.h | 36 + arch/arm/mach-rockchip/Kconfig | 20 + arch/arm/mach-rockchip/Makefile | 14 +- arch/arm/mach-rockchip/rk3188-board-spl.c | 220 ++++++ arch/arm/mach-rockchip/rk3188-board-tpl.c | 87 +++ arch/arm/mach-rockchip/rk3188-board.c | 71 ++ arch/arm/mach-rockchip/rk3188/Kconfig | 35 + arch/arm/mach-rockchip/rk3188/Makefile | 11 + arch/arm/mach-rockchip/rk3188/clk_rk3188.c | 33 + arch/arm/mach-rockchip/rk3188/sdram_rk3188.c | 985 ++++++++++++++++++++++++ arch/arm/mach-rockchip/rk3188/syscon_rk3188.c | 55 ++ board/radxa/rock/Kconfig | 15 + board/radxa/rock/MAINTAINERS | 6 + board/radxa/rock/Makefile | 7 + board/radxa/rock/rock.c | 7 + configs/rock_defconfig | 56 ++ doc/driver-model/README.txt | 4 + drivers/clk/at91/pmc.c | 3 +- drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_rk3188.c | 523 +++++++++++++ drivers/core/root.c | 2 +- drivers/core/util.c | 29 + drivers/pinctrl/Kconfig | 9 + drivers/pinctrl/pinctrl-uclass.c | 3 +- drivers/pinctrl/rockchip/Makefile | 1 + drivers/pinctrl/rockchip/pinctrl_rk3188.c | 611 +++++++++++++++ drivers/serial/serial_rockchip.c | 19 +- drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_rk3188.c | 47 ++ include/configs/rk3188_common.h | 125 +++ include/configs/rock.h | 30 + include/dm/util.h | 2 + include/dt-bindings/clock/rk3066a-cru.h | 32 + include/dt-bindings/clock/rk3188-cru-common.h | 256 ++++++ include/dt-bindings/clock/rk3188-cru.h | 48 ++ mkuboot | 35 + scripts/Makefile.spl | 7 +- tools/dtoc/dtoc.py | 2 + tools/rkcommon.c | 34 +- tools/rkcommon.h | 22 + tools/rkimage.c | 3 + tools/rksd.c | 4 + tools/rkspi.c | 4 + 50 files changed, 5707 insertions(+), 11 deletions(-) create mode 100644 arch/arm/dts/rk3188-radxarock.dts create mode 100644 arch/arm/dts/rk3188.dtsi create mode 100644 arch/arm/dts/rk3xxx.dtsi create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rk3188.h create mode 100644 arch/arm/include/asm/arch-rockchip/ddr_rk3188.h create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rk3188.h create mode 100644 arch/arm/include/asm/arch-rockchip/pmu_rk3188.h create mode 100644 arch/arm/mach-rockchip/rk3188-board-spl.c create mode 100644 arch/arm/mach-rockchip/rk3188-board-tpl.c create mode 100644 arch/arm/mach-rockchip/rk3188-board.c create mode 100644 arch/arm/mach-rockchip/rk3188/Kconfig create mode 100644 arch/arm/mach-rockchip/rk3188/Makefile create mode 100644 arch/arm/mach-rockchip/rk3188/clk_rk3188.c create mode 100644 arch/arm/mach-rockchip/rk3188/sdram_rk3188.c create mode 100644 arch/arm/mach-rockchip/rk3188/syscon_rk3188.c create mode 100644 board/radxa/rock/Kconfig create mode 100644 board/radxa/rock/MAINTAINERS create mode 100644 board/radxa/rock/Makefile create mode 100644 board/radxa/rock/rock.c create mode 100644 configs/rock_defconfig create mode 100644 drivers/clk/rockchip/clk_rk3188.c create mode 100644 drivers/pinctrl/rockchip/pinctrl_rk3188.c create mode 100644 drivers/sysreset/sysreset_rk3188.c create mode 100644 include/configs/rk3188_common.h create mode 100644 include/configs/rock.h create mode 100644 include/dt-bindings/clock/rk3066a-cru.h create mode 100644 include/dt-bindings/clock/rk3188-cru-common.h create mode 100644 include/dt-bindings/clock/rk3188-cru.h create mode 100755 mkuboot
Right now the u-boot,dm-pre-reloc flag will make each marked node always appear in both spl and tpl. But systems needing an additional tpl might have special constraints for each, like the spl needing to be very tiny.
So introduce two additional flags to mark nodes for only spl or tpl environments and introduce a function dm_fdt_pre_reloc to automate the necessary checks in code instances checking for pre-relocation flags.
The behaviour of the original flag stays untouched and still marks a node for both spl and tpl.
Signed-off-by: Heiko Stuebner heiko@sntech.de --- doc/driver-model/README.txt | 4 ++++ drivers/clk/at91/pmc.c | 3 ++- drivers/core/root.c | 2 +- drivers/core/util.c | 29 +++++++++++++++++++++++++++++ drivers/pinctrl/pinctrl-uclass.c | 3 ++- include/dm/util.h | 2 ++ scripts/Makefile.spl | 7 ++++++- tools/dtoc/dtoc.py | 2 ++ 8 files changed, 48 insertions(+), 4 deletions(-)
diff --git a/doc/driver-model/README.txt b/doc/driver-model/README.txt index 1b5ccec4b2..af28b43c7b 100644 --- a/doc/driver-model/README.txt +++ b/doc/driver-model/README.txt @@ -825,6 +825,10 @@ drivers marked with DM_FLAG_PRE_RELOC or the device tree 'u-boot,dm-pre-reloc' flag are initialised prior to relocation. This helps to reduce the driver model overhead.
+It is possible to limit this to specific relocation steps, by using +the more specialized 'u-boot,dm-spl' and 'u-boot,dm-tpl' flags +in the devicetree. + Then post relocation we throw that away and re-init driver model again. For drivers which require some sort of continuity between pre- and post-relocation devices, we can provide access to the pre-relocation diff --git a/drivers/clk/at91/pmc.c b/drivers/clk/at91/pmc.c index 76ba91af81..c098efc9f7 100644 --- a/drivers/clk/at91/pmc.c +++ b/drivers/clk/at91/pmc.c @@ -10,6 +10,7 @@ #include <dm/device.h> #include <dm/lists.h> #include <dm/root.h> +#include <dm/util.h> #include "pmc.h"
DECLARE_GLOBAL_DATA_PTR; @@ -56,7 +57,7 @@ int at91_clk_sub_device_bind(struct udevice *dev, const char *drv_name) offset > 0; offset = fdt_next_subnode(fdt, offset)) { if (pre_reloc_only && - !fdt_getprop(fdt, offset, "u-boot,dm-pre-reloc", NULL)) + !dm_fdt_pre_reloc(fdt, offset)) continue; /* * If this node has "compatible" property, this is not diff --git a/drivers/core/root.c b/drivers/core/root.c index 9edfc1efb6..45f990ba9e 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -205,7 +205,7 @@ int dm_scan_fdt_node(struct udevice *parent, const void *blob, int offset, offset > 0; offset = fdt_next_subnode(blob, offset)) { if (pre_reloc_only && - !fdt_getprop(blob, offset, "u-boot,dm-pre-reloc", NULL)) + !dm_fdt_pre_reloc(blob, offset)) continue; if (!fdtdec_get_is_enabled(blob, offset)) { dm_dbg(" - ignoring disabled device\n"); diff --git a/drivers/core/util.c b/drivers/core/util.c index e01dd06d28..a67434b80d 100644 --- a/drivers/core/util.c +++ b/drivers/core/util.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <libfdt.h> #include <vsprintf.h>
void dm_warn(const char *fmt, ...) @@ -35,3 +36,31 @@ int list_count_items(struct list_head *head)
return count; } + +int dm_fdt_pre_reloc(const void *blob, int offset) +{ + bool dm_spl, dm_tpl; + + if (fdt_getprop(blob, offset, "u-boot,dm-pre-reloc", NULL)) + return 1; + + dm_spl = fdt_getprop(blob, offset, "u-boot,dm-spl", NULL); + dm_tpl = fdt_getprop(blob, offset, "u-boot,dm-tpl", NULL); + +#ifdef CONFIG_TPL_BUILD + if (dm_tpl) + return 1; +#elif defined(CONFIG_SPL_BUILD) + if (dm_spl) + return 1; +#else + /* + * In regular builds individual spl and tpl handling both + * count as handled pre-relocation for later second init. + */ + if (dm_spl || dm_tpl) + return 1; +#endif + + return 0; +} diff --git a/drivers/pinctrl/pinctrl-uclass.c b/drivers/pinctrl/pinctrl-uclass.c index 02ab9b4afd..9e0122906c 100644 --- a/drivers/pinctrl/pinctrl-uclass.c +++ b/drivers/pinctrl/pinctrl-uclass.c @@ -12,6 +12,7 @@ #include <dm/lists.h> #include <dm/pinctrl.h> #include <dm/uclass.h> +#include <dm/util.h>
@@ -131,7 +132,7 @@ static int pinconfig_post_bind(struct udevice *dev) offset > 0; offset = fdt_next_subnode(fdt, offset)) { if (pre_reloc_only && - !fdt_getprop(fdt, offset, "u-boot,dm-pre-reloc", NULL)) + !dm_fdt_pre_reloc(fdt, offset)) continue; /* * If this node has "compatible" property, this is not diff --git a/include/dm/util.h b/include/dm/util.h index 15daa3d19f..38c023ce66 100644 --- a/include/dm/util.h +++ b/include/dm/util.h @@ -48,4 +48,6 @@ static inline void dm_dump_devres(void) } #endif
+int dm_fdt_pre_reloc(const void *blob, int offset); + #endif diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index c962bbca2c..60bd844e48 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -206,8 +206,13 @@ $(obj)/$(SPL_BIN)-pad.bin: $(obj)/$(SPL_BIN) # 'u-boot,dm-pre-reloc' property and thus are not needed by SPL. The second # pass removes various unused properties from the remaining nodes. # The output is typically a much smaller device tree file. +ifeq ($(CONFIG_TPL_BUILD),y) +fdtgrep_props := -b u-boot,dm-pre-reloc -b u-boot,dm-tpl +else +fdtgrep_props := -b u-boot,dm-pre-reloc -b u-boot,dm-spl +endif quiet_cmd_fdtgrep = FDTGREP $@ - cmd_fdtgrep = $(objtree)/tools/fdtgrep -b u-boot,dm-pre-reloc -RT $< \ + cmd_fdtgrep = $(objtree)/tools/fdtgrep $(fdtgrep_props) -RT $< \ -n /chosen -O dtb | \ $(objtree)/tools/fdtgrep -r -O dtb - -o $@ \ $(addprefix -P ,$(subst $",,$(CONFIG_OF_SPL_REMOVE_PROPS))) diff --git a/tools/dtoc/dtoc.py b/tools/dtoc/dtoc.py index 11050b66f7..232f8ff739 100755 --- a/tools/dtoc/dtoc.py +++ b/tools/dtoc/dtoc.py @@ -30,6 +30,8 @@ PROP_IGNORE_LIST = [ "status", 'phandle', 'u-boot,dm-pre-reloc', + 'u-boot,dm-tpl', + 'u-boot,dm-spl', ]
# C type declarations for the tyues we support
s/u-boot/U-Boot
Please add a comment for dm_fdt_pre_reloc() in the header file.
Two things to consider:
- Should we drop the use of u-boot,dm-pre-reloc in Makefile.spl, and convert all users to your version? This would mean having both u-boot,dm-pre-reloc and u-boot,dm-spl in some cases, I suspect.
- Can you use #ifdef in SPL/TPL to reduce code size fractionally in dm_fdt_pre_reloc()?
Hi Simon,
Am Montag, 6. Februar 2017, 07:34:54 CET schrieb Simon Glass:
s/u-boot/U-Boot
^^ u-boot,dm-spl and u-boot,dm-tpl I guess
Dropping u-boot,dm-pre-reloc is for you to decide, as you wrote the original implementation ;-) . It will save one fdt-query but might need several iterations as I guess new boards will add new ones after we remove the old ones.
dm_fdt_pre_reloc()?
Do you mean moving the + dm_spl = fdt_getprop(blob, offset, "u-boot,dm-spl", NULL); + dm_tpl = fdt_getprop(blob, offset, "u-boot,dm-tpl", NULL);
into the existing #ifdef CONFIG_TPL_BUILD / SPL_BUILD blocks or something else?
Thanks Heiko
Hi Heiko,
On 16 February 2017 at 17:36, Heiko Stübner heiko@sntech.de wrote:
Hi Simon,
s/u-boot/U-Boot
Let's do it. It is more efficient and I don't expect it to cause many problems if we get it in at the start of the merge window.
dm_fdt_pre_reloc()?
Well I don't think it matters, but the idea is that there would then be no point in checking u-boot,dm-tpl except when CONFIG_TPL_BUILD is defined.
Right now the ROCKCHIP_SPL_BACK_TO_BROM option both triggers compilation of the bootrom hook-code as well as enabling the behaviour of loading the full uboot via the boot.
New added socs may always need the bootrom code, while still being able to decide between loading uboot regularly or via the bootrom separately.
So move the compilation of the bootrom code to a hidden option that gets selected by ROCKCHIP_SPL_BACK_TO_BROM, but can also be selected by other parts.
Signed-off-by: Heiko Stuebner heiko@sntech.de --- arch/arm/mach-rockchip/Kconfig | 4 ++++ arch/arm/mach-rockchip/Makefile | 2 +- 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 5c4a4c2291..a776df35f4 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -37,11 +37,15 @@ config ROCKCHIP_RK3399 config ROCKCHIP_SPL_BACK_TO_BROM bool "SPL returns to bootrom" default y if ROCKCHIP_RK3036 + select ROCKCHIP_BROM_HELPER help Rockchip SoCs have ability to load SPL & U-Boot binary. If enabled, SPL will return to the boot rom, which will then load the U-Boot binary to keep going on.
+config ROCKCHIP_BROM_HELPER + bool + config SPL_MMC_SUPPORT default y if !ROCKCHIP_SPL_BACK_TO_BROM
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 6e79fed485..f9ccc9bb2c 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -7,7 +7,7 @@ ifdef CONFIG_SPL_BUILD obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board-spl.o -obj-$(CONFIG_ROCKCHIP_SPL_BACK_TO_BROM) += save_boot_param.o +obj-$(CONFIG_ROCKCHIP_BROM_HELPER) += save_boot_param.o else obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board.o obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board.o
s/uboot/U-Boot/
Rockchip SoCs allow the spl code to be rc4-encoded, not only the image header, but only newer SoCs allow this encoding to be disabled.
The rk3188 is not part of those and requires its boot code to be rc4-encoded with the regular key. So add the ability to do this encoding via a setting on a per-soc basis when building spl images.
Signed-off-by: Heiko Stuebner heiko@sntech.de --- tools/rkcommon.c | 33 +++++++++++++++++++++++++++++---- tools/rkcommon.h | 22 ++++++++++++++++++++++ tools/rkimage.c | 3 +++ tools/rksd.c | 4 ++++ tools/rkspi.c | 4 ++++ 5 files changed, 62 insertions(+), 4 deletions(-)
diff --git a/tools/rkcommon.c b/tools/rkcommon.c index 0a072aa83c..ed9b24137a 100644 --- a/tools/rkcommon.c +++ b/tools/rkcommon.c @@ -46,17 +46,19 @@ struct header0_info { * @imagename: Image name(passed by "mkimage -n") * @spl_hdr: Boot ROM requires a 4-bytes spl header * @spl_size: Spl size(include extra 4-bytes spl header) + * @spl_rc4: RC4 encode the SPL binary (same key as header) */ struct spl_info { const char *imagename; const char *spl_hdr; const uint32_t spl_size; + const bool spl_rc4; };
static struct spl_info spl_infos[] = { - { "rk3036", "RK30", 0x1000 }, - { "rk3288", "RK32", 0x8000 }, - { "rk3399", "RK33", 0x20000 }, + { "rk3036", "RK30", 0x1000, false }, + { "rk3288", "RK32", 0x8000, false }, + { "rk3399", "RK33", 0x20000, false }, };
static unsigned char rc4_key[16] = { @@ -113,6 +115,16 @@ int rkcommon_get_spl_size(struct image_tool_params *params) return info->spl_size; }
+bool rkcommon_need_rc4_spl(struct image_tool_params *params) +{ + struct spl_info *info = rkcommon_get_spl_info(params->imagename); + + /* + * info would not be NULL, because of we checked params before. + */ + return info->spl_rc4; +} + int rkcommon_set_header(void *buf, uint file_size, struct image_tool_params *params) { @@ -124,7 +136,7 @@ int rkcommon_set_header(void *buf, uint file_size, memset(buf, '\0', RK_INIT_OFFSET * RK_BLK_SIZE); hdr = (struct header0_info *)buf; hdr->signature = RK_SIGNATURE; - hdr->disable_rc4 = 1; + hdr->disable_rc4 = !rkcommon_need_rc4_spl(params); hdr->init_offset = RK_INIT_OFFSET;
hdr->init_size = (file_size + RK_BLK_SIZE - 1) / RK_BLK_SIZE; @@ -135,3 +147,16 @@ int rkcommon_set_header(void *buf, uint file_size,
return 0; } + +void rkcommon_rc4_encode_spl(void *buf, unsigned int offset, unsigned int size) +{ + unsigned int remaining = size; + + while (remaining > 0) { + int step = (remaining > RK_BLK_SIZE) ? RK_BLK_SIZE : remaining; + + rc4_encode(buf + offset, step, rc4_key); + offset += RK_BLK_SIZE; + remaining -= step; + } +} diff --git a/tools/rkcommon.h b/tools/rkcommon.h index c69540f5f3..b4f6f327dc 100644 --- a/tools/rkcommon.h +++ b/tools/rkcommon.h @@ -55,4 +55,26 @@ int rkcommon_get_spl_size(struct image_tool_params *params); int rkcommon_set_header(void *buf, uint file_size, struct image_tool_params *params);
+/** + * rkcommon_need_rc4_spl() - check if rc4 encoded spl is required + * + * Some socs cannot disable the rc4-encryption of the spl binary. + * rc4 encryption is disabled normally except on socs that cannot + * handle unencrypted binaries. + * @return true or false depending on rc4 being required. + */ +bool rkcommon_need_rc4_spl(struct image_tool_params *params); + +/** + * rkcommon_rc4_encode_spl() - encode the spl binary + * + * Encrypts the SPL binary using the generic rc4 key as required + * by some socs. + * + * @buf: Pointer to the SPL data (header and SPL binary) + * @offset: offset inside buf to start at + * @size: number of bytes to encode + */ +void rkcommon_rc4_encode_spl(void *buf, unsigned int offset, unsigned int size); + #endif diff --git a/tools/rkimage.c b/tools/rkimage.c index ef31cb6944..44d098c775 100644 --- a/tools/rkimage.c +++ b/tools/rkimage.c @@ -28,6 +28,9 @@ static void rkimage_set_header(void *buf, struct stat *sbuf, int ifd, { memcpy(buf + RK_SPL_HDR_START, rkcommon_get_spl_hdr(params), RK_SPL_HDR_SIZE); + + if (rkcommon_need_rc4_spl(params)) + rkcommon_rc4_encode_spl(buf, 4, params->file_size); }
static int rkimage_extract_subimage(void *buf, struct image_tool_params *params) diff --git a/tools/rksd.c b/tools/rksd.c index a2baa74d31..ff2233ff2d 100644 --- a/tools/rksd.c +++ b/tools/rksd.c @@ -41,6 +41,10 @@ static void rksd_set_header(void *buf, struct stat *sbuf, int ifd,
memcpy(buf + RK_SPL_HDR_START, rkcommon_get_spl_hdr(params), RK_SPL_HDR_SIZE); + + if (rkcommon_need_rc4_spl(params)) + rkcommon_rc4_encode_spl(buf, RK_SPL_START - 4, + params->file_size - RK_SPL_START + 4); }
static int rksd_extract_subimage(void *buf, struct image_tool_params *params) diff --git a/tools/rkspi.c b/tools/rkspi.c index a0b0051d38..0271d2e817 100644 --- a/tools/rkspi.c +++ b/tools/rkspi.c @@ -48,6 +48,10 @@ static void rkspi_set_header(void *buf, struct stat *sbuf, int ifd, memcpy(buf + RK_SPL_HDR_START, rkcommon_get_spl_hdr(params), RK_SPL_HDR_SIZE);
+ if (rkcommon_need_rc4_spl(params)) + rkcommon_rc4_encode_spl(buf, RK_SPL_START - 4, + params->file_size - RK_SPL_START + 4); + /* * Spread the image out so we only use the first 2KB of each 4KB * region. This is a feature of the SPI format required by the Rockchip
Hi Heiko,
- @imagename: Image name(passed by "mkimage -n")
- @spl_hdr: Boot ROM requires a 4-bytes spl header
- @spl_size: Spl size(include extra 4-bytes spl header)
- @spl_rc4: RC4 encode the SPL binary (same key as header)
- struct spl_info *info = rkcommon_get_spl_info(params->imagename);
- return info->spl_rc4;
- int rkcommon_set_header(void *buf, uint file_size, struct image_tool_params *params) {
return 0; }
- unsigned int remaining = size;
- while (remaining > 0) {
remaining -= step;
- rkcommon_need_rc4_spl() - check if rc4 encoded spl is required
- Some socs cannot disable the rc4-encryption of the spl binary.
- rc4 encryption is disabled normally except on socs that cannot
- handle unencrypted binaries.
- @return true or false depending on rc4 being required.
- rkcommon_rc4_encode_spl() - encode the spl binary
- Encrypts the SPL binary using the generic rc4 key as required
- by some socs.
- @buf: Pointer to the SPL data (header and SPL binary)
- @offset: offset inside buf to start at
- @size: number of bytes to encode
- #endif
- if (rkcommon_need_rc4_spl(params))
- Spread the image out so we only use the first 2KB of each 4KB
- region. This is a feature of the SPI format required by the Rockchip
Reviewed-by: Kever Yang kever.yang@rock-chips.com Tested-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Add the entry for the rk3188 requiring rc4-encryption of the SPL.
Signed-off-by: Heiko Stuebner heiko@sntech.de --- tools/rkcommon.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/rkcommon.c b/tools/rkcommon.c index ed9b24137a..6595e02c1c 100644 --- a/tools/rkcommon.c +++ b/tools/rkcommon.c @@ -57,6 +57,7 @@ struct spl_info {
static struct spl_info spl_infos[] = { { "rk3036", "RK30", 0x1000, false }, + { "rk3188", "RK31", 0x8000 - 0x800, true }, { "rk3288", "RK32", 0x8000, false }, { "rk3399", "RK33", 0x20000, false }, };
Hi Heiko,
- { "rk3188", "RK31", 0x8000 - 0x800, true }, { "rk3288", "RK32", 0x8000, false }, { "rk3399", "RK33", 0x20000, false }, };
Thanks, - Kever
Add necessary structs to have the driver also work for the serial on the rk3188.
Signed-off-by: Heiko Stuebner heiko@sntech.de --- drivers/serial/serial_rockchip.c | 19 ++++++++++++++++++- 1 file changed, 18 insertions(+), 1 deletion(-)
diff --git a/drivers/serial/serial_rockchip.c b/drivers/serial/serial_rockchip.c index 6bac95a414..7e030a6aed 100644 --- a/drivers/serial/serial_rockchip.c +++ b/drivers/serial/serial_rockchip.c @@ -12,12 +12,19 @@ #include <serial.h> #include <asm/arch/clock.h>
+#if defined(CONFIG_ROCKCHIP_RK3188) +struct rockchip_uart_platdata { + struct dtd_rockchip_rk3188_uart dtplat; + struct ns16550_platdata plat; +}; +struct dtd_rockchip_rk3188_uart *dtplat, s_dtplat; +#elif defined(CONFIG_ROCKCHIP_RK3288) struct rockchip_uart_platdata { struct dtd_rockchip_rk3288_uart dtplat; struct ns16550_platdata plat; }; - struct dtd_rockchip_rk3288_uart *dtplat, s_dtplat; +#endif
static int rockchip_serial_probe(struct udevice *dev) { @@ -32,6 +39,16 @@ static int rockchip_serial_probe(struct udevice *dev) return ns16550_serial_probe(dev); }
+U_BOOT_DRIVER(rockchip_rk3188_uart) = { + .name = "rockchip_rk3188_uart", + .id = UCLASS_SERIAL, + .priv_auto_alloc_size = sizeof(struct NS16550), + .platdata_auto_alloc_size = sizeof(struct rockchip_uart_platdata), + .probe = rockchip_serial_probe, + .ops = &ns16550_serial_ops, + .flags = DM_FLAG_PRE_RELOC, +}; + U_BOOT_DRIVER(rockchip_rk3288_uart) = { .name = "rockchip_rk3288_uart", .id = UCLASS_SERIAL,
PMU is the power management unit and GRF is the general register file. Both are heavily used in U-Boot. Add header files with register definitions.
Signed-off-by: Heiko Stuebner heiko@sntech.de Acked-by: Simon Glass sjg@chromium.org --- arch/arm/include/asm/arch-rockchip/grf_rk3188.h | 589 ++++++++++++++++++++++++ arch/arm/include/asm/arch-rockchip/pmu_rk3188.h | 36 ++ 2 files changed, 625 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rk3188.h create mode 100644 arch/arm/include/asm/arch-rockchip/pmu_rk3188.h
diff --git a/arch/arm/include/asm/arch-rockchip/grf_rk3188.h b/arch/arm/include/asm/arch-rockchip/grf_rk3188.h new file mode 100644 index 0000000000..ce7bac5338 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/grf_rk3188.h @@ -0,0 +1,589 @@ +/* + * Copyright (c) 2016 Heiko Stuebner heiko@sntech.de + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _ASM_ARCH_GRF_RK3188_H +#define _ASM_ARCH_GRF_RK3188_H + +struct rk3188_grf_gpio_lh { + u32 l; + u32 h; +}; + +struct rk3188_grf { + struct rk3188_grf_gpio_lh gpio_dir[4]; + struct rk3188_grf_gpio_lh gpio_do[4]; + struct rk3188_grf_gpio_lh gpio_en[4]; + + u32 reserved[2]; + u32 gpio0c_iomux; + u32 gpio0d_iomux; + + u32 gpio1a_iomux; + u32 gpio1b_iomux; + u32 gpio1c_iomux; + u32 gpio1d_iomux; + + u32 gpio2a_iomux; + u32 gpio2b_iomux; + u32 gpio2c_iomux; + u32 gpio2d_iomux; + + u32 gpio3a_iomux; + u32 gpio3b_iomux; + u32 gpio3c_iomux; + u32 gpio3d_iomux; + + u32 soc_con0; + u32 soc_con1; + u32 soc_con2; + u32 soc_status0; + + u32 busdmac_con[3]; + u32 peridmac_con[4]; + + u32 cpu_con[6]; + u32 reserved0[2]; + + u32 ddrc_con0; + u32 ddrc_stat; + + u32 io_con[5]; + u32 soc_status1; + + u32 uoc0_con[4]; + u32 uoc1_con[4]; + u32 uoc2_con[2]; + u32 reserved1; + u32 uoc3_con[2]; + u32 hsic_stat; + u32 os_reg[8]; + + u32 gpio0_p[3]; + u32 gpio1_p[3][4]; + + u32 flash_data_p; + u32 flash_cmd_p; +}; +check_member(rk3188_grf, flash_cmd_p, 0x01a4); + +/* GRF_GPIO0D_IOMUX */ +enum { + GPIO0D7_SHIFT = 14, + GPIO0D7_MASK = 1, + GPIO0D7_GPIO = 0, + GPIO0D7_SPI1_CSN0, + + GPIO0D6_SHIFT = 12, + GPIO0D6_MASK = 1, + GPIO0D6_GPIO = 0, + GPIO0D6_SPI1_CLK, + + GPIO0D5_SHIFT = 10, + GPIO0D5_MASK = 1, + GPIO0D5_GPIO = 0, + GPIO0D5_SPI1_TXD, + + GPIO0D4_SHIFT = 8, + GPIO0D4_MASK = 1, + GPIO0D4_GPIO = 0, + GPIO0D4_SPI0_RXD, + + GPIO0D3_SHIFT = 6, + GPIO0D3_MASK = 3, + GPIO0D3_GPIO = 0, + GPIO0D3_FLASH_CSN3, + GPIO0D3_EMMC_RSTN_OUT, + + GPIO0D2_SHIFT = 4, + GPIO0D2_MASK = 3, + GPIO0D2_GPIO = 0, + GPIO0D2_FLASH_CSN2, + GPIO0D2_EMMC_CMD, + + GPIO0D1_SHIFT = 2, + GPIO0D1_MASK = 1, + GPIO0D1_GPIO = 0, + GPIO0D1_FLASH_CSN1, + + GPIO0D0_SHIFT = 0, + GPIO0D0_MASK = 3, + GPIO0D0_GPIO = 0, + GPIO0D0_FLASH_DQS, + GPIO0D0_EMMC_CLKOUT +}; + +/* GRF_GPIO1A_IOMUX */ +enum { + GPIO1A7_SHIFT = 14, + GPIO1A7_MASK = 3, + GPIO1A7_GPIO = 0, + GPIO1A7_UART1_RTS_N, + GPIO1A7_SPI0_CSN0, + + GPIO1A6_SHIFT = 12, + GPIO1A6_MASK = 3, + GPIO1A6_GPIO = 0, + GPIO1A6_UART1_CTS_N, + GPIO1A6_SPI0_CLK, + + GPIO1A5_SHIFT = 10, + GPIO1A5_MASK = 3, + GPIO1A5_GPIO = 0, + GPIO1A5_UART1_SOUT, + GPIO1A5_SPI0_TXD, + + GPIO1A4_SHIFT = 8, + GPIO1A4_MASK = 3, + GPIO1A4_GPIO = 0, + GPIO1A4_UART1_SIN, + GPIO1A4_SPI0_RXD, + + GPIO1A3_SHIFT = 6, + GPIO1A3_MASK = 1, + GPIO1A3_GPIO = 0, + GPIO1A3_UART0_RTS_N, + + GPIO1A2_SHIFT = 4, + GPIO1A2_MASK = 1, + GPIO1A2_GPIO = 0, + GPIO1A2_UART0_CTS_N, + + GPIO1A1_SHIFT = 2, + GPIO1A1_MASK = 1, + GPIO1A1_GPIO = 0, + GPIO1A1_UART0_SOUT, + + GPIO1A0_SHIFT = 0, + GPIO1A0_MASK = 1, + GPIO1A0_GPIO = 0, + GPIO1A0_UART0_SIN, +}; + +/* GRF_GPIO1B_IOMUX */ +enum { + GPIO1B7_SHIFT = 14, + GPIO1B7_MASK = 1, + GPIO1B7_GPIO = 0, + GPIO1B7_SPI0_CSN1, + + GPIO1B6_SHIFT = 12, + GPIO1B6_MASK = 3, + GPIO1B6_GPIO = 0, + GPIO1B6_SPDIF_TX, + GPIO1B6_SPI1_CSN1, + + GPIO1B5_SHIFT = 10, + GPIO1B5_MASK = 3, + GPIO1B5_GPIO = 0, + GPIO1B5_UART3_RTS_N, + GPIO1B5_RESERVED, + + GPIO1B4_SHIFT = 8, + GPIO1B4_MASK = 3, + GPIO1B4_GPIO = 0, + GPIO1B4_UART3_CTS_N, + GPIO1B4_GPS_RFCLK, + + GPIO1B3_SHIFT = 6, + GPIO1B3_MASK = 3, + GPIO1B3_GPIO = 0, + GPIO1B3_UART3_SOUT, + GPIO1B3_GPS_SIG, + + GPIO1B2_SHIFT = 4, + GPIO1B2_MASK = 3, + GPIO1B2_GPIO = 0, + GPIO1B2_UART3_SIN, + GPIO1B2_GPS_MAG, + + GPIO1B1_SHIFT = 2, + GPIO1B1_MASK = 3, + GPIO1B1_GPIO = 0, + GPIO1B1_UART2_SOUT, + GPIO1B1_JTAG_TDO, + + GPIO1B0_SHIFT = 0, + GPIO1B0_MASK = 3, + GPIO1B0_GPIO = 0, + GPIO1B0_UART2_SIN, + GPIO1B0_JTAG_TDI, +}; + +/* GRF_GPIO1D_IOMUX */ +enum { + GPIO1D7_SHIFT = 14, + GPIO1D7_MASK = 1, + GPIO1D7_GPIO = 0, + GPIO1D7_I2C4_SCL, + + GPIO1D6_SHIFT = 12, + GPIO1D6_MASK = 1, + GPIO1D6_GPIO = 0, + GPIO1D6_I2C4_SDA, + + GPIO1D5_SHIFT = 10, + GPIO1D5_MASK = 1, + GPIO1D5_GPIO = 0, + GPIO1D5_I2C2_SCL, + + GPIO1D4_SHIFT = 8, + GPIO1D4_MASK = 1, + GPIO1D4_GPIO = 0, + GPIO1D4_I2C2_SDA, + + GPIO1D3_SHIFT = 6, + GPIO1D3_MASK = 1, + GPIO1D3_GPIO = 0, + GPIO1D3_I2C1_SCL, + + GPIO1D2_SHIFT = 4, + GPIO1D2_MASK = 1, + GPIO1D2_GPIO = 0, + GPIO1D2_I2C1_SDA, + + GPIO1D1_SHIFT = 2, + GPIO1D1_MASK = 1, + GPIO1D1_GPIO = 0, + GPIO1D1_I2C0_SCL, + + GPIO1D0_SHIFT = 0, + GPIO1D0_MASK = 1, + GPIO1D0_GPIO = 0, + GPIO1D0_I2C0_SDA, +}; + +/* GRF_GPIO3A_IOMUX */ +enum { + GPIO3A7_SHIFT = 14, + GPIO3A7_MASK = 1, + GPIO3A7_GPIO = 0, + GPIO3A7_SDMMC0_DATA3, + + GPIO3A6_SHIFT = 12, + GPIO3A6_MASK = 1, + GPIO3A6_GPIO = 0, + GPIO3A6_SDMMC0_DATA2, + + GPIO3A5_SHIFT = 10, + GPIO3A5_MASK = 1, + GPIO3A5_GPIO = 0, + GPIO3A5_SDMMC0_DATA1, + + GPIO3A4_SHIFT = 8, + GPIO3A4_MASK = 1, + GPIO3A4_GPIO = 0, + GPIO3A4_SDMMC0_DATA0, + + GPIO3A3_SHIFT = 6, + GPIO3A3_MASK = 1, + GPIO3A3_GPIO = 0, + GPIO3A3_SDMMC0_CMD, + + GPIO3A2_SHIFT = 4, + GPIO3A2_MASK = 1, + GPIO3A2_GPIO = 0, + GPIO3A2_SDMMC0_CLKOUT, + + GPIO3A1_SHIFT = 2, + GPIO3A1_MASK = 1, + GPIO3A1_GPIO = 0, + GPIO3A1_SDMMC0_PWREN, + + GPIO3A0_SHIFT = 0, + GPIO3A0_MASK = 1, + GPIO3A0_GPIO = 0, + GPIO3A0_SDMMC0_RSTN, +}; + +/* GRF_GPIO3B_IOMUX */ +enum { + GPIO3B7_SHIFT = 14, + GPIO3B7_MASK = 3, + GPIO3B7_GPIO = 0, + GPIO3B7_CIF_DATA11, + GPIO3B7_I2C3_SCL, + + GPIO3B6_SHIFT = 12, + GPIO3B6_MASK = 3, + GPIO3B6_GPIO = 0, + GPIO3B6_CIF_DATA10, + GPIO3B6_I2C3_SDA, + + GPIO3B5_SHIFT = 10, + GPIO3B5_MASK = 3, + GPIO3B5_GPIO = 0, + GPIO3B5_CIF_DATA1, + GPIO3B5_HSADC_DATA9, + + GPIO3B4_SHIFT = 8, + GPIO3B4_MASK = 3, + GPIO3B4_GPIO = 0, + GPIO3B4_CIF_DATA0, + GPIO3B4_HSADC_DATA8, + + GPIO3B3_SHIFT = 6, + GPIO3B3_MASK = 1, + GPIO3B3_GPIO = 0, + GPIO3B3_CIF_CLKOUT, + + GPIO3B2_SHIFT = 4, + GPIO3B2_MASK = 1, + GPIO3B2_GPIO = 0, + /* no muxes */ + + GPIO3B1_SHIFT = 2, + GPIO3B1_MASK = 1, + GPIO3B1_GPIO = 0, + GPIO3B1_SDMMC0_WRITE_PRT, + + GPIO3B0_SHIFT = 0, + GPIO3B0_MASK = 1, + GPIO3B0_GPIO = 0, + GPIO3B0_SDMMC_DETECT_N, +}; + +/* GRF_GPIO3C_IOMUX */ +enum { + GPIO3C7_SHIFT = 14, + GPIO3C7_MASK = 3, + GPIO3C7_GPIO = 0, + GPIO3C7_SDMMC1_WRITE_PRT, + GPIO3C7_RMII_CRS_DVALID, + GPIO3C7_RESERVED, + + GPIO3C6_SHIFT = 12, + GPIO3C6_MASK = 3, + GPIO3C6_GPIO = 0, + GPIO3C6_SDMMC1_DECTN, + GPIO3C6_RMII_RX_ERR, + GPIO3C6_RESERVED, + + GPIO3C5_SHIFT = 10, + GPIO3C5_MASK = 3, + GPIO3C5_GPIO = 0, + GPIO3C5_SDMMC1_CLKOUT, + GPIO3C5_RMII_CLKOUT, + GPIO3C5_RMII_CLKIN, + + GPIO3C4_SHIFT = 8, + GPIO3C4_MASK = 3, + GPIO3C4_GPIO = 0, + GPIO3C4_SDMMC1_DATA3, + GPIO3C4_RMII_RXD1, + GPIO3C4_RESERVED, + + GPIO3C3_SHIFT = 6, + GPIO3C3_MASK = 3, + GPIO3C3_GPIO = 0, + GPIO3C3_SDMMC1_DATA2, + GPIO3C3_RMII_RXD0, + GPIO3C3_RESERVED, + + GPIO3C2_SHIFT = 4, + GPIO3C2_MASK = 3, + GPIO3C2_GPIO = 0, + GPIO3C2_SDMMC1_DATA1, + GPIO3C2_RMII_TXD0, + GPIO3C2_RESERVED, + + GPIO3C1_SHIFT = 2, + GPIO3C1_MASK = 3, + GPIO3C1_GPIO = 0, + GPIO3C1_SDMMC1_DATA0, + GPIO3C1_RMII_TXD1, + GPIO3C1_RESERVED, + + GPIO3C0_SHIFT = 0, + GPIO3C0_MASK = 3, + GPIO3C0_GPIO = 0, + GPIO3C0_SDMMC1_CMD, + GPIO3C0_RMII_TX_EN, + GPIO3C0_RESERVED, +}; + +/* GRF_GPIO3D_IOMUX */ +enum { + GPIO3D6_SHIFT = 12, + GPIO3D6_MASK = 3, + GPIO3D6_GPIO = 0, + GPIO3D6_PWM_3, + GPIO3D6_JTAG_TMS, + GPIO3D6_HOST_DRV_VBUS, + + GPIO3D5_SHIFT = 10, + GPIO3D5_MASK = 3, + GPIO3D5_GPIO = 0, + GPIO3D5_PWM_2, + GPIO3D5_JTAG_TCK, + GPIO3D5_OTG_DRV_VBUS, + + GPIO3D4_SHIFT = 8, + GPIO3D4_MASK = 3, + GPIO3D4_GPIO = 0, + GPIO3D4_PWM_1, + GPIO3D4_JTAG_TRSTN, + + GPIO3D3_SHIFT = 6, + GPIO3D3_MASK = 3, + GPIO3D3_GPIO = 0, + GPIO3D3_PWM_0, + + GPIO3D2_SHIFT = 4, + GPIO3D2_MASK = 3, + GPIO3D2_GPIO = 0, + GPIO3D2_SDMMC1_INT_N, + + GPIO3D1_SHIFT = 2, + GPIO3D1_MASK = 3, + GPIO3D1_GPIO = 0, + GPIO3D1_SDMMC1_BACKEND_PWR, + GPIO3D1_MII_MDCLK, + + GPIO3D0_SHIFT = 0, + GPIO3D0_MASK = 3, + GPIO3D0_GPIO = 0, + GPIO3D0_SDMMC1_PWR_EN, + GPIO3D0_MII_MD, +}; + +/* GRF_SOC_CON0 */ +enum { + HSADC_CLK_DIR_SHIFT = 15, + HSADC_CLK_DIR_MASK = 1, + + HSADC_SEL_SHIFT = 14, + HSADC_SEL_MASK = 1, + + NOC_REMAP_SHIFT = 12, + NOC_REMAP_MASK = 1, + + EMMC_FLASH_SEL_SHIFT = 11, + EMMC_FLASH_SEL_MASK = 1, + + TZPC_REVISION_SHIFT = 7, + TZPC_REVISION_MASK = 0xf, + + L2CACHE_ACC_SHIFT = 5, + L2CACHE_ACC_MASK = 3, + + L2RD_WAIT_SHIFT = 3, + L2RD_WAIT_MASK = 3, + + IMEMRD_WAIT_SHIFT = 1, + IMEMRD_WAIT_MASK = 3, +}; + +/* GRF_SOC_CON1 */ +enum { + RKI2C4_SEL_SHIFT = 15, + RKI2C4_SEL_MASK = 1, + + RKI2C3_SEL_SHIFT = 14, + RKI2C3_SEL_MASK = 1, + + RKI2C2_SEL_SHIFT = 13, + RKI2C2_SEL_MASK = 1, + + RKI2C1_SEL_SHIFT = 12, + RKI2C1_SEL_MASK = 1, + + RKI2C0_SEL_SHIFT = 11, + RKI2C0_SEL_MASK = 1, + + VCODEC_SEL_SHIFT = 10, + VCODEC_SEL_MASK = 1, + + PERI_EMEM_PAUSE_SHIFT = 9, + PERI_EMEM_PAUSE_MASK = 1, + + PERI_USB_PAUSE_SHIFT = 8, + PERI_USB_PAUSE_MASK = 1, + + SMC_MUX_MODE_0_SHIFT = 6, + SMC_MUX_MODE_0_MASK = 1, + + SMC_SRAM_MW_0_SHIFT = 4, + SMC_SRAM_MW_0_MASK = 3, + + SMC_REMAP_0_SHIFT = 3, + SMC_REMAP_0_MASK = 1, + + SMC_A_GT_M0_SYNC_SHIFT = 2, + SMC_A_GT_M0_SYNC_MASK = 1, + + EMAC_SPEED_SHIFT = 1, + EMAC_SPEEC_MASK = 1, + + EMAC_MODE_SHIFT = 0, + EMAC_MODE_MASK = 1, +}; + +/* GRF_SOC_CON2 */ +enum { + SDIO_CLK_OUT_SR_SHIFT = 15, + SDIO_CLK_OUT_SR_MASK = 1, + + MEM_EMA_L2C_SHIFT = 11, + MEM_EMA_L2C_MASK = 7, + + MEM_EMA_A9_SHIFT = 8, + MEM_EMA_A9_MASK = 7, + + MSCH4_MAINDDR3_SHIFT = 7, + MSCH4_MAINDDR3_MASK = 1, + MSCH4_MAINDDR3_DDR3 = 1, + + EMAC_NEWRCV_EN_SHIFT = 6, + EMAC_NEWRCV_EN_MASK = 1, + + SW_ADDR15_EN_SHIFT = 5, + SW_ADDR15_EN_MASK = 1, + + SW_ADDR16_EN_SHIFT = 4, + SW_ADDR16_EN_MASK = 1, + + SW_ADDR17_EN_SHIFT = 3, + SW_ADDR17_EN_MASK = 1, + + BANK2_TO_RANK_EN_SHIFT = 2, + BANK2_TO_RANK_EN_MASK = 1, + + RANK_TO_ROW15_EN_SHIFT = 1, + RANK_TO_ROW15_EN_MASK = 1, + + UPCTL_C_ACTIVE_IN_SHIFT = 0, + UPCTL_C_ACTIVE_IN_MASK = 1, + UPCTL_C_ACTIVE_IN_MAY = 0, + UPCTL_C_ACTIVE_IN_WILL, +}; + +/* GRF_DDRC_CON0 */ +enum { + DDR_16BIT_EN_SHIFT = 15, + DDR_16BIT_EN_MASK = 1, + + DTO_LB_SHIFT = 11, + DTO_LB_MASK = 3, + + DTO_TE_SHIFT = 9, + DTO_TE_MASK = 3, + + DTO_PDR_SHIFT = 7, + DTO_PDR_MASK = 3, + + DTO_PDD_SHIFT = 5, + DTO_PDD_MASK = 3, + + DTO_IOM_SHIFT = 3, + DTO_IOM_MASK = 3, + + DTO_OE_SHIFT = 1, + DTO_OE_MASK = 3, + + ATO_AE_SHIFT = 0, + ATO_AE_MASK = 1, +}; +#endif diff --git a/arch/arm/include/asm/arch-rockchip/pmu_rk3188.h b/arch/arm/include/asm/arch-rockchip/pmu_rk3188.h new file mode 100644 index 0000000000..d3feac3832 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/pmu_rk3188.h @@ -0,0 +1,36 @@ +/* + * Copyright (c) 2016 Heiko Stuebner heiko@sntech.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARCH_PMU_RK3188_H +#define _ASM_ARCH_PMU_RK3188_H + +struct rk3188_pmu { + u32 wakeup_cfg[2]; + u32 pwrdn_con; + u32 pwrdn_st; + + u32 int_con; + u32 int_st; + u32 misc_con; + + u32 osc_cnt; + u32 pll_cnt; + u32 pmu_cnt; + u32 ddrio_pwron_cnt; + u32 wakeup_rst_clr_cnt; + u32 scu_pwrdwn_cnt; + u32 scu_pwrup_cnt; + u32 misc_con1; + u32 gpio0_con; + + u32 sys_reg[4]; + u32 reserved0[4]; + u32 stop_int_dly; + u32 gpio0_p[2]; +}; +check_member(rk3188_pmu, gpio0_p[1], 0x0068); + +#endif
Add a driver which supports pin multiplexing setup for the most commonly used peripherals.
Signed-off-by: Heiko Stuebner heiko@sntech.de Acked-by: Simon Glass sjg@chromium.org --- drivers/pinctrl/Kconfig | 9 + drivers/pinctrl/rockchip/Makefile | 1 + drivers/pinctrl/rockchip/pinctrl_rk3188.c | 611 ++++++++++++++++++++++++++++++ 3 files changed, 621 insertions(+) create mode 100644 drivers/pinctrl/rockchip/pinctrl_rk3188.c
diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index efcb4c0003..c68860c092 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -132,6 +132,15 @@ config ROCKCHIP_RK3036_PINCTRL definitions and pin control functions for each available multiplex function.
+config ROCKCHIP_RK3188_PINCTRL + bool "Rockchip pin control driver" + depends on DM + help + Support pin multiplexing control on Rockchip rk3188 SoCs. The driver + is controlled by a device tree node which contains both the GPIO + definitions and pin control functions for each available multiplex + function. + config ROCKCHIP_RK3288_PINCTRL bool "Rockchip pin control driver" depends on DM diff --git a/drivers/pinctrl/rockchip/Makefile b/drivers/pinctrl/rockchip/Makefile index 805c833ec9..cc99aeebb5 100644 --- a/drivers/pinctrl/rockchip/Makefile +++ b/drivers/pinctrl/rockchip/Makefile @@ -6,5 +6,6 @@ #
obj-$(CONFIG_ROCKCHIP_RK3036_PINCTRL) += pinctrl_rk3036.o +obj-$(CONFIG_ROCKCHIP_RK3188_PINCTRL) += pinctrl_rk3188.o obj-$(CONFIG_ROCKCHIP_RK3288_PINCTRL) += pinctrl_rk3288.o obj-$(CONFIG_ROCKCHIP_RK3399_PINCTRL) += pinctrl_rk3399.o diff --git a/drivers/pinctrl/rockchip/pinctrl_rk3188.c b/drivers/pinctrl/rockchip/pinctrl_rk3188.c new file mode 100644 index 0000000000..ef94dab210 --- /dev/null +++ b/drivers/pinctrl/rockchip/pinctrl_rk3188.c @@ -0,0 +1,611 @@ +/* + * Pinctrl driver for Rockchip RK3188 SoCs + * Copyright (c) 2016 Heiko Stuebner heiko@sntech.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/grf_rk3188.h> +#include <asm/arch/hardware.h> +#include <asm/arch/periph.h> +#include <asm/arch/pmu_rk3188.h> +#include <dm/pinctrl.h> +#include <dm/root.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct rk3188_pinctrl_priv { + struct rk3188_grf *grf; + struct rk3188_pmu *pmu; + int num_banks; +}; + +/** + * Encode variants of iomux registers into a type variable + */ +#define IOMUX_GPIO_ONLY BIT(0) + +/** + * @type: iomux variant using IOMUX_* constants + * @offset: if initialized to -1 it will be autocalculated, by specifying + * an initial offset value the relevant source offset can be reset + * to a new value for autocalculating the following iomux registers. + */ +struct rockchip_iomux { + u8 type; + s16 offset; +}; + +/** + * @reg: register offset of the gpio bank + * @nr_pins: number of pins in this bank + * @bank_num: number of the bank, to account for holes + * @name: name of the bank + * @iomux: array describing the 4 iomux sources of the bank + */ +struct rockchip_pin_bank { + u16 reg; + u8 nr_pins; + u8 bank_num; + char *name; + struct rockchip_iomux iomux[4]; +}; + +#define PIN_BANK(id, pins, label) \ + { \ + .bank_num = id, \ + .nr_pins = pins, \ + .name = label, \ + .iomux = { \ + { .offset = -1 }, \ + { .offset = -1 }, \ + { .offset = -1 }, \ + { .offset = -1 }, \ + }, \ + } + +#define PIN_BANK_IOMUX_FLAGS(id, pins, label, iom0, iom1, iom2, iom3) \ + { \ + .bank_num = id, \ + .nr_pins = pins, \ + .name = label, \ + .iomux = { \ + { .type = iom0, .offset = -1 }, \ + { .type = iom1, .offset = -1 }, \ + { .type = iom2, .offset = -1 }, \ + { .type = iom3, .offset = -1 }, \ + }, \ + } + +#ifndef CONFIG_SPL_BUILD +static struct rockchip_pin_bank rk3188_pin_banks[] = { + PIN_BANK_IOMUX_FLAGS(0, 32, "gpio0", IOMUX_GPIO_ONLY, 0, 0, 0), + PIN_BANK(1, 32, "gpio1"), + PIN_BANK(2, 32, "gpio2"), + PIN_BANK(3, 32, "gpio3"), +}; +#endif + +static void pinctrl_rk3188_pwm_config(struct rk3188_grf *grf, int pwm_id) +{ + switch (pwm_id) { + case PERIPH_ID_PWM0: + rk_clrsetreg(&grf->gpio3d_iomux, GPIO3D3_MASK << GPIO3D3_SHIFT, + GPIO3D3_PWM_0 << GPIO3D3_SHIFT); + break; + case PERIPH_ID_PWM1: + rk_clrsetreg(&grf->gpio3d_iomux, GPIO3D4_MASK << GPIO3D4_SHIFT, + GPIO3D4_PWM_1 << GPIO3D4_SHIFT); + break; + case PERIPH_ID_PWM2: + rk_clrsetreg(&grf->gpio3d_iomux, GPIO3D5_MASK << GPIO3D5_SHIFT, + GPIO3D5_PWM_2 << GPIO3D5_SHIFT); + break; + case PERIPH_ID_PWM3: + rk_clrsetreg(&grf->gpio3d_iomux, GPIO3D6_MASK << GPIO3D6_SHIFT, + GPIO3D6_PWM_3 << GPIO3D6_SHIFT); + break; + default: + debug("pwm id = %d iomux error!\n", pwm_id); + break; + } +} + +static void pinctrl_rk3188_i2c_config(struct rk3188_grf *grf, + struct rk3188_pmu *pmu, int i2c_id) +{ + switch (i2c_id) { + case PERIPH_ID_I2C0: + rk_clrsetreg(&grf->gpio1d_iomux, + GPIO1D1_MASK << GPIO1D1_SHIFT | + GPIO1D0_MASK << GPIO1D0_SHIFT, + GPIO1D1_I2C0_SCL << GPIO1D1_SHIFT | + GPIO1D0_I2C0_SDA << GPIO1D0_SHIFT); + /* enable new i2c controller */ + rk_clrsetreg(&grf->soc_con1, 1 << RKI2C0_SEL_SHIFT, + 1 << RKI2C0_SEL_SHIFT); + break; + case PERIPH_ID_I2C1: + rk_clrsetreg(&grf->gpio1d_iomux, + GPIO1D3_MASK << GPIO1D3_SHIFT | + GPIO1D2_MASK << GPIO1D2_SHIFT, + GPIO1D3_I2C1_SCL << GPIO1D2_SHIFT | + GPIO1D2_I2C1_SDA << GPIO1D2_SHIFT); + rk_clrsetreg(&grf->soc_con1, 1 << RKI2C1_SEL_SHIFT, + 1 << RKI2C1_SEL_SHIFT); + break; + case PERIPH_ID_I2C2: + rk_clrsetreg(&grf->gpio1d_iomux, + GPIO1D5_MASK << GPIO1D5_SHIFT | + GPIO1D4_MASK << GPIO1D4_SHIFT, + GPIO1D5_I2C2_SCL << GPIO1D5_SHIFT | + GPIO1D4_I2C2_SDA << GPIO1D4_SHIFT); + rk_clrsetreg(&grf->soc_con1, 1 << RKI2C2_SEL_SHIFT, + 1 << RKI2C2_SEL_SHIFT); + break; + case PERIPH_ID_I2C3: + rk_clrsetreg(&grf->gpio3b_iomux, + GPIO3B7_MASK << GPIO3B7_SHIFT | + GPIO3B6_MASK << GPIO3B6_SHIFT, + GPIO3B7_I2C3_SCL << GPIO3B7_SHIFT | + GPIO3B6_I2C3_SDA << GPIO3B6_SHIFT); + rk_clrsetreg(&grf->soc_con1, 1 << RKI2C3_SEL_SHIFT, + 1 << RKI2C3_SEL_SHIFT); + break; + case PERIPH_ID_I2C4: + rk_clrsetreg(&grf->gpio1d_iomux, + GPIO1D7_MASK << GPIO1D7_SHIFT | + GPIO1D6_MASK << GPIO1D6_SHIFT, + GPIO1D7_I2C4_SCL << GPIO1D7_SHIFT | + GPIO1D6_I2C4_SDA << GPIO1D6_SHIFT); + rk_clrsetreg(&grf->soc_con1, 1 << RKI2C4_SEL_SHIFT, + 1 << RKI2C4_SEL_SHIFT); + break; + default: + debug("i2c id = %d iomux error!\n", i2c_id); + break; + } +} + +static int pinctrl_rk3188_spi_config(struct rk3188_grf *grf, + enum periph_id spi_id, int cs) +{ + switch (spi_id) { + case PERIPH_ID_SPI0: + switch (cs) { + case 0: + rk_clrsetreg(&grf->gpio1a_iomux, + GPIO1A7_MASK << GPIO1A7_SHIFT, + GPIO1A7_SPI0_CSN0 << GPIO1A7_SHIFT); + break; + case 1: + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B7_MASK << GPIO1B7_SHIFT, + GPIO1B7_SPI0_CSN1 << GPIO1B7_SHIFT); + break; + default: + goto err; + } + rk_clrsetreg(&grf->gpio1a_iomux, + GPIO1A4_MASK << GPIO1A4_SHIFT | + GPIO1A5_MASK << GPIO1A5_SHIFT | + GPIO1A6_MASK << GPIO1A6_SHIFT, + GPIO1A4_SPI0_RXD << GPIO1A4_SHIFT | + GPIO1A5_SPI0_TXD << GPIO1A5_SHIFT | + GPIO1A6_SPI0_CLK << GPIO1A6_SHIFT); + break; + case PERIPH_ID_SPI1: + switch (cs) { + case 0: + rk_clrsetreg(&grf->gpio0d_iomux, + GPIO0D7_MASK << GPIO0D7_SHIFT, + GPIO0D7_SPI1_CSN0 << GPIO0D7_SHIFT); + break; + case 1: + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B6_MASK << GPIO1B6_SHIFT, + GPIO1B6_SPI1_CSN1 << GPIO1B6_SHIFT); + break; + default: + goto err; + } + rk_clrsetreg(&grf->gpio0d_iomux, + GPIO0D4_MASK << GPIO0D4_SHIFT | + GPIO0D5_MASK << GPIO0D5_SHIFT | + GPIO0D6_MASK << GPIO0D6_SHIFT, + GPIO0D4_SPI0_RXD << GPIO0D4_SHIFT | + GPIO0D5_SPI1_TXD << GPIO0D5_SHIFT | + GPIO0D6_SPI1_CLK << GPIO0D6_SHIFT); + break; + default: + goto err; + } + + return 0; +err: + debug("rkspi: periph%d cs=%d not supported", spi_id, cs); + return -ENOENT; +} + +static void pinctrl_rk3188_uart_config(struct rk3188_grf *grf, int uart_id) +{ + switch (uart_id) { + case PERIPH_ID_UART0: + rk_clrsetreg(&grf->gpio1a_iomux, + GPIO1A3_MASK << GPIO1A3_SHIFT | + GPIO1A2_MASK << GPIO1A2_SHIFT | + GPIO1A1_MASK << GPIO1A1_SHIFT | + GPIO1A0_MASK << GPIO1A0_SHIFT, + GPIO1A3_UART0_RTS_N << GPIO1A3_SHIFT | + GPIO1A2_UART0_CTS_N << GPIO1A2_SHIFT | + GPIO1A1_UART0_SOUT << GPIO1A1_SHIFT | + GPIO1A0_UART0_SIN << GPIO1A0_SHIFT); + break; + case PERIPH_ID_UART1: + rk_clrsetreg(&grf->gpio1a_iomux, + GPIO1A7_MASK << GPIO1A7_SHIFT | + GPIO1A6_MASK << GPIO1A6_SHIFT | + GPIO1A5_MASK << GPIO1A5_SHIFT | + GPIO1A4_MASK << GPIO1A4_SHIFT, + GPIO1A7_UART1_RTS_N << GPIO1A7_SHIFT | + GPIO1A6_UART1_CTS_N << GPIO1A6_SHIFT | + GPIO1A5_UART1_SOUT << GPIO1A5_SHIFT | + GPIO1A4_UART1_SIN << GPIO1A4_SHIFT); + break; + case PERIPH_ID_UART2: + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B1_MASK << GPIO1B1_SHIFT | + GPIO1B0_MASK << GPIO1B0_SHIFT, + GPIO1B1_UART2_SOUT << GPIO1B1_SHIFT | + GPIO1B0_UART2_SIN << GPIO1B0_SHIFT); + break; + case PERIPH_ID_UART3: + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B5_MASK << GPIO1B5_SHIFT | + GPIO1B4_MASK << GPIO1B4_SHIFT | + GPIO1B3_MASK << GPIO1B3_SHIFT | + GPIO1B2_MASK << GPIO1B2_SHIFT, + GPIO1B5_UART3_RTS_N << GPIO1B5_SHIFT | + GPIO1B4_UART3_CTS_N << GPIO1B4_SHIFT | + GPIO1B3_UART3_SOUT << GPIO1B3_SHIFT | + GPIO1B2_UART3_SIN << GPIO1B2_SHIFT); + break; + default: + debug("uart id = %d iomux error!\n", uart_id); + break; + } +} + +static void pinctrl_rk3188_sdmmc_config(struct rk3188_grf *grf, int mmc_id) +{ + switch (mmc_id) { + case PERIPH_ID_EMMC: + rk_clrsetreg(&grf->soc_con0, 1 << EMMC_FLASH_SEL_SHIFT, + 1 << EMMC_FLASH_SEL_SHIFT); + rk_clrsetreg(&grf->gpio0d_iomux, + GPIO0D2_MASK << GPIO0D2_SHIFT | + GPIO0D0_MASK << GPIO0D0_SHIFT, + GPIO0D2_EMMC_CMD << GPIO0D2_SHIFT | + GPIO0D0_EMMC_CLKOUT << GPIO0D0_SHIFT); + break; + case PERIPH_ID_SDCARD: + rk_clrsetreg(&grf->gpio3b_iomux, + GPIO3B0_MASK << GPIO3B0_SHIFT, + GPIO3B0_SDMMC_DETECT_N << GPIO3B0_SHIFT); + rk_clrsetreg(&grf->gpio3a_iomux, + GPIO3A7_MASK << GPIO3A7_SHIFT | + GPIO3A6_MASK << GPIO3A6_SHIFT | + GPIO3A5_MASK << GPIO3A5_SHIFT | + GPIO3A4_MASK << GPIO3A4_SHIFT | + GPIO3A3_MASK << GPIO3A3_SHIFT | + GPIO3A3_MASK << GPIO3A2_SHIFT, + GPIO3A7_SDMMC0_DATA3 << GPIO3A7_SHIFT | + GPIO3A6_SDMMC0_DATA2 << GPIO3A6_SHIFT | + GPIO3A5_SDMMC0_DATA1 << GPIO3A5_SHIFT | + GPIO3A4_SDMMC0_DATA0 << GPIO3A4_SHIFT | + GPIO3A3_SDMMC0_CMD << GPIO3A3_SHIFT | + GPIO3A2_SDMMC0_CLKOUT << GPIO3A2_SHIFT); + break; + default: + debug("mmc id = %d iomux error!\n", mmc_id); + break; + } +} + +static int rk3188_pinctrl_request(struct udevice *dev, int func, int flags) +{ + struct rk3188_pinctrl_priv *priv = dev_get_priv(dev); + + debug("%s: func=%x, flags=%x\n", __func__, func, flags); + switch (func) { + case PERIPH_ID_PWM0: + case PERIPH_ID_PWM1: + case PERIPH_ID_PWM2: + case PERIPH_ID_PWM3: + case PERIPH_ID_PWM4: + pinctrl_rk3188_pwm_config(priv->grf, func); + break; + case PERIPH_ID_I2C0: + case PERIPH_ID_I2C1: + case PERIPH_ID_I2C2: + case PERIPH_ID_I2C3: + case PERIPH_ID_I2C4: + case PERIPH_ID_I2C5: + pinctrl_rk3188_i2c_config(priv->grf, priv->pmu, func); + break; + case PERIPH_ID_SPI0: + case PERIPH_ID_SPI1: + case PERIPH_ID_SPI2: + pinctrl_rk3188_spi_config(priv->grf, func, flags); + break; + case PERIPH_ID_UART0: + case PERIPH_ID_UART1: + case PERIPH_ID_UART2: + case PERIPH_ID_UART3: + case PERIPH_ID_UART4: + pinctrl_rk3188_uart_config(priv->grf, func); + break; + break; + case PERIPH_ID_SDMMC0: + case PERIPH_ID_SDMMC1: + pinctrl_rk3188_sdmmc_config(priv->grf, func); + break; + default: + return -EINVAL; + } + + return 0; +} + +static int rk3188_pinctrl_get_periph_id(struct udevice *dev, + struct udevice *periph) +{ +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + u32 cell[3]; + int ret; + + ret = fdtdec_get_int_array(gd->fdt_blob, periph->of_offset, + "interrupts", cell, ARRAY_SIZE(cell)); + if (ret < 0) + return -EINVAL; + + switch (cell[1]) { + case 44: + return PERIPH_ID_SPI0; + case 45: + return PERIPH_ID_SPI1; + case 46: + return PERIPH_ID_SPI2; + case 60: + return PERIPH_ID_I2C0; + case 62: /* Note strange order */ + return PERIPH_ID_I2C1; + case 61: + return PERIPH_ID_I2C2; + case 63: + return PERIPH_ID_I2C3; + case 64: + return PERIPH_ID_I2C4; + case 65: + return PERIPH_ID_I2C5; + } +#endif + + return -ENOENT; +} + +static int rk3188_pinctrl_set_state_simple(struct udevice *dev, + struct udevice *periph) +{ + int func; + + func = rk3188_pinctrl_get_periph_id(dev, periph); + if (func < 0) + return func; + return rk3188_pinctrl_request(dev, func, 0); +} + +#ifndef CONFIG_SPL_BUILD +int rk3188_pinctrl_get_pin_info(struct rk3188_pinctrl_priv *priv, + int banknum, int ind, u32 **addrp, uint *shiftp, + uint *maskp) +{ + struct rockchip_pin_bank *bank = &rk3188_pin_banks[banknum]; + uint muxnum; + u32 *addr; + + for (muxnum = 0; muxnum < 4; muxnum++) { + struct rockchip_iomux *mux = &bank->iomux[muxnum]; + + if (ind >= 8) { + ind -= 8; + continue; + } + + addr = &priv->grf->gpio0c_iomux - 2; + addr += mux->offset; + *shiftp = ind & 7; + *maskp = 3; + *shiftp *= 2; + + debug("%s: addr=%p, mask=%x, shift=%x\n", __func__, addr, + *maskp, *shiftp); + *addrp = addr; + return 0; + } + + return -EINVAL; +} + +static int rk3188_pinctrl_get_gpio_mux(struct udevice *dev, int banknum, + int index) +{ + struct rk3188_pinctrl_priv *priv = dev_get_priv(dev); + uint shift; + uint mask; + u32 *addr; + int ret; + + ret = rk3188_pinctrl_get_pin_info(priv, banknum, index, &addr, &shift, + &mask); + if (ret) + return ret; + return (readl(addr) & mask) >> shift; +} + +static int rk3188_pinctrl_set_pins(struct udevice *dev, int banknum, int index, + int muxval, int flags) +{ + struct rk3188_pinctrl_priv *priv = dev_get_priv(dev); + uint shift, ind = index; + uint mask; + u32 *addr; + int ret; + + debug("%s: %x %x %x %x\n", __func__, banknum, index, muxval, flags); + ret = rk3188_pinctrl_get_pin_info(priv, banknum, index, &addr, &shift, + &mask); + if (ret) + return ret; + rk_clrsetreg(addr, mask << shift, muxval << shift); + + /* Handle pullup/pulldown */ + if (flags) { + uint val = 0; + + if (flags & (1 << PIN_CONFIG_BIAS_PULL_UP)) + val = 1; + else if (flags & (1 << PIN_CONFIG_BIAS_PULL_DOWN)) + val = 2; + + ind = index >> 3; + + if (banknum == 0 && index < 12) { + addr = &priv->pmu->gpio0_p[ind]; + shift = (index & 7) * 2; + } else if (banknum == 0 && index >= 12) { + addr = &priv->grf->gpio0_p[ind - 1]; + /* + * The bits in the grf-registers have an inverse + * ordering with the lowest pin being in bits 15:14 + * and the highest pin in bits 1:0 . + */ + shift = (7 - (index & 7)) * 2; + } else { + addr = &priv->grf->gpio1_p[banknum - 1][ind]; + shift = (7 - (index & 7)) * 2; + } + debug("%s: addr=%p, val=%x, shift=%x\n", __func__, addr, val, + shift); + rk_clrsetreg(addr, 3 << shift, val << shift); + } + + return 0; +} + +static int rk3188_pinctrl_set_state(struct udevice *dev, struct udevice *config) +{ + const void *blob = gd->fdt_blob; + int pcfg_node, ret, flags, count, i; + u32 cell[60], *ptr; + + debug("%s: %s %s\n", __func__, dev->name, config->name); + ret = fdtdec_get_int_array_count(blob, config->of_offset, + "rockchip,pins", cell, + ARRAY_SIZE(cell)); + if (ret < 0) { + debug("%s: bad array %d\n", __func__, ret); + return -EINVAL; + } + count = ret; + for (i = 0, ptr = cell; i < count; i += 4, ptr += 4) { + pcfg_node = fdt_node_offset_by_phandle(blob, ptr[3]); + if (pcfg_node < 0) + return -EINVAL; + flags = pinctrl_decode_pin_config(blob, pcfg_node); + if (flags < 0) + return flags; + + ret = rk3188_pinctrl_set_pins(dev, ptr[0], ptr[1], ptr[2], + flags); + if (ret) + return ret; + } + + return 0; +} +#endif + +static struct pinctrl_ops rk3188_pinctrl_ops = { +#ifndef CONFIG_SPL_BUILD + .set_state = rk3188_pinctrl_set_state, + .get_gpio_mux = rk3188_pinctrl_get_gpio_mux, +#endif + .set_state_simple = rk3188_pinctrl_set_state_simple, + .request = rk3188_pinctrl_request, + .get_periph_id = rk3188_pinctrl_get_periph_id, +}; + +#ifndef CONFIG_SPL_BUILD +static int rk3188_pinctrl_parse_tables(struct rk3188_pinctrl_priv *priv, + struct rockchip_pin_bank *banks, + int count) +{ + struct rockchip_pin_bank *bank; + uint reg, muxnum, banknum; + + reg = 0; + for (banknum = 0; banknum < count; banknum++) { + bank = &banks[banknum]; + bank->reg = reg; + debug("%s: bank %d, reg %x\n", __func__, banknum, reg * 4); + for (muxnum = 0; muxnum < 4; muxnum++) { + struct rockchip_iomux *mux = &bank->iomux[muxnum]; + + mux->offset = reg; + reg += 1; + } + } + + return 0; +} +#endif + +static int rk3188_pinctrl_probe(struct udevice *dev) +{ + struct rk3188_pinctrl_priv *priv = dev_get_priv(dev); + int ret = 0; + + priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + priv->pmu = syscon_get_first_range(ROCKCHIP_SYSCON_PMU); + debug("%s: grf=%p, pmu=%p\n", __func__, priv->grf, priv->pmu); +#ifndef CONFIG_SPL_BUILD + ret = rk3188_pinctrl_parse_tables(priv, rk3188_pin_banks, + ARRAY_SIZE(rk3188_pin_banks)); +#endif + + return ret; +} + +static const struct udevice_id rk3188_pinctrl_ids[] = { + { .compatible = "rockchip,rk3188-pinctrl" }, + { } +}; + +U_BOOT_DRIVER(pinctrl_rk3188) = { + .name = "rockchip_rk3188_pinctrl", + .id = UCLASS_PINCTRL, + .of_match = rk3188_pinctrl_ids, + .priv_auto_alloc_size = sizeof(struct rk3188_pinctrl_priv), + .ops = &rk3188_pinctrl_ops, +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + .bind = dm_scan_fdt_dev, +#endif + .probe = rk3188_pinctrl_probe, +};
Driver for the sysreset of Rockchip rk3188 socs.
Signed-off-by: Heiko Stuebner heiko@sntech.de --- drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_rk3188.c | 47 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 48 insertions(+) create mode 100644 drivers/sysreset/sysreset_rk3188.c
diff --git a/drivers/sysreset/Makefile b/drivers/sysreset/Makefile index fa75cc52de..30f1bce390 100644 --- a/drivers/sysreset/Makefile +++ b/drivers/sysreset/Makefile @@ -9,6 +9,7 @@ obj-$(CONFIG_SYSRESET) += sysreset-uclass.o ifndef CONFIG_SPL_BUILD obj-$(CONFIG_ROCKCHIP_RK3036) += sysreset_rk3036.o endif +obj-$(CONFIG_ROCKCHIP_RK3188) += sysreset_rk3188.o obj-$(CONFIG_ROCKCHIP_RK3288) += sysreset_rk3288.o obj-$(CONFIG_ROCKCHIP_RK3399) += sysreset_rk3399.o obj-$(CONFIG_SANDBOX) += sysreset_sandbox.o diff --git a/drivers/sysreset/sysreset_rk3188.c b/drivers/sysreset/sysreset_rk3188.c new file mode 100644 index 0000000000..36ae47600a --- /dev/null +++ b/drivers/sysreset/sysreset_rk3188.c @@ -0,0 +1,47 @@ +/* + * (C) Copyright 2015 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <sysreset.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/cru_rk3188.h> +#include <asm/arch/hardware.h> +#include <linux/err.h> + +int rk3188_sysreset_request(struct udevice *dev, enum sysreset_t type) +{ + struct rk3188_cru *cru = rockchip_get_cru(); + + if (IS_ERR(cru)) + return PTR_ERR(cru); + switch (type) { + case SYSRESET_WARM: + rk_clrreg(&cru->cru_mode_con, 0xffff); + writel(0xeca8, &cru->cru_glb_srst_snd_value); + break; + case SYSRESET_COLD: + rk_clrreg(&cru->cru_mode_con, 0xffff); + writel(0xfdb9, &cru->cru_glb_srst_fst_value); + break; + default: + return -EPROTONOSUPPORT; + } + + return -EINPROGRESS; +} + +static struct sysreset_ops rk3188_sysreset = { + .request = rk3188_sysreset_request, +}; + +U_BOOT_DRIVER(sysreset_rk3188) = { + .name = "rk3188_sysreset", + .id = UCLASS_SYSRESET, + .ops = &rk3188_sysreset, +};
Bring in required device clock binding files from Linux. The clock trees for rk3066 and rk3188 are largely similar, which makes them share the common parts in a shared header. While we focus on rk3188 for now, bring in both headers already for completeness sake.
Signed-off-by: Heiko Stuebner heiko@sntech.de Acked-by: Simon Glass sjg@chromium.org --- include/dt-bindings/clock/rk3066a-cru.h | 32 ++++ include/dt-bindings/clock/rk3188-cru-common.h | 256 ++++++++++++++++++++++++++ include/dt-bindings/clock/rk3188-cru.h | 48 +++++ 3 files changed, 336 insertions(+) create mode 100644 include/dt-bindings/clock/rk3066a-cru.h create mode 100644 include/dt-bindings/clock/rk3188-cru-common.h create mode 100644 include/dt-bindings/clock/rk3188-cru.h
diff --git a/include/dt-bindings/clock/rk3066a-cru.h b/include/dt-bindings/clock/rk3066a-cru.h new file mode 100644 index 0000000000..549ae6a3f3 --- /dev/null +++ b/include/dt-bindings/clock/rk3066a-cru.h @@ -0,0 +1,32 @@ +/* + * Copyright (c) 2014 MundoReader S.L. + * Author: Heiko Stuebner heiko@sntech.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3066A_H +#define _DT_BINDINGS_CLK_ROCKCHIP_RK3066A_H + +#include <dt-bindings/clock/rk3188-cru-common.h> + +/* soft-reset indices */ +#define SRST_SRST1 0 +#define SRST_SRST2 1 + +#define SRST_L2MEM 18 +#define SRST_I2S0 23 +#define SRST_I2S1 24 +#define SRST_I2S2 25 +#define SRST_TIMER2 29 + +#define SRST_GPIO4 36 +#define SRST_GPIO6 38 + +#define SRST_TSADC 92 + +#define SRST_HDMI 96 +#define SRST_HDMI_APB 97 +#define SRST_CIF1 111 + +#endif diff --git a/include/dt-bindings/clock/rk3188-cru-common.h b/include/dt-bindings/clock/rk3188-cru-common.h new file mode 100644 index 0000000000..8fc818b1d9 --- /dev/null +++ b/include/dt-bindings/clock/rk3188-cru-common.h @@ -0,0 +1,256 @@ +/* + * Copyright (c) 2014 MundoReader S.L. + * Author: Heiko Stuebner heiko@sntech.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3188_COMMON_H +#define _DT_BINDINGS_CLK_ROCKCHIP_RK3188_COMMON_H + +/* core clocks from */ +#define PLL_APLL 1 +#define PLL_DPLL 2 +#define PLL_CPLL 3 +#define PLL_GPLL 4 +#define CORE_PERI 5 +#define CORE_L2C 6 +#define ARMCLK 7 + +/* sclk gates (special clocks) */ +#define SCLK_UART0 64 +#define SCLK_UART1 65 +#define SCLK_UART2 66 +#define SCLK_UART3 67 +#define SCLK_MAC 68 +#define SCLK_SPI0 69 +#define SCLK_SPI1 70 +#define SCLK_SARADC 71 +#define SCLK_SDMMC 72 +#define SCLK_SDIO 73 +#define SCLK_EMMC 74 +#define SCLK_I2S0 75 +#define SCLK_I2S1 76 +#define SCLK_I2S2 77 +#define SCLK_SPDIF 78 +#define SCLK_CIF0 79 +#define SCLK_CIF1 80 +#define SCLK_OTGPHY0 81 +#define SCLK_OTGPHY1 82 +#define SCLK_HSADC 83 +#define SCLK_TIMER0 84 +#define SCLK_TIMER1 85 +#define SCLK_TIMER2 86 +#define SCLK_TIMER3 87 +#define SCLK_TIMER4 88 +#define SCLK_TIMER5 89 +#define SCLK_TIMER6 90 +#define SCLK_JTAG 91 +#define SCLK_SMC 92 +#define SCLK_TSADC 93 + +#define DCLK_LCDC0 190 +#define DCLK_LCDC1 191 + +/* aclk gates */ +#define ACLK_DMA1 192 +#define ACLK_DMA2 193 +#define ACLK_GPS 194 +#define ACLK_LCDC0 195 +#define ACLK_LCDC1 196 +#define ACLK_GPU 197 +#define ACLK_SMC 198 +#define ACLK_CIF 199 +#define ACLK_IPP 200 +#define ACLK_RGA 201 +#define ACLK_CIF0 202 +#define ACLK_CPU 203 +#define ACLK_PERI 204 + +/* pclk gates */ +#define PCLK_GRF 320 +#define PCLK_PMU 321 +#define PCLK_TIMER0 322 +#define PCLK_TIMER1 323 +#define PCLK_TIMER2 324 +#define PCLK_TIMER3 325 +#define PCLK_PWM01 326 +#define PCLK_PWM23 327 +#define PCLK_SPI0 328 +#define PCLK_SPI1 329 +#define PCLK_SARADC 330 +#define PCLK_WDT 331 +#define PCLK_UART0 332 +#define PCLK_UART1 333 +#define PCLK_UART2 334 +#define PCLK_UART3 335 +#define PCLK_I2C0 336 +#define PCLK_I2C1 337 +#define PCLK_I2C2 338 +#define PCLK_I2C3 339 +#define PCLK_I2C4 340 +#define PCLK_GPIO0 341 +#define PCLK_GPIO1 342 +#define PCLK_GPIO2 343 +#define PCLK_GPIO3 344 +#define PCLK_GPIO4 345 +#define PCLK_GPIO6 346 +#define PCLK_EFUSE 347 +#define PCLK_TZPC 348 +#define PCLK_TSADC 349 +#define PCLK_CPU 350 +#define PCLK_PERI 351 +#define PCLK_DDRUPCTL 352 +#define PCLK_PUBL 353 + +/* hclk gates */ +#define HCLK_SDMMC 448 +#define HCLK_SDIO 449 +#define HCLK_EMMC 450 +#define HCLK_OTG0 451 +#define HCLK_EMAC 452 +#define HCLK_SPDIF 453 +#define HCLK_I2S0 454 +#define HCLK_I2S1 455 +#define HCLK_I2S2 456 +#define HCLK_OTG1 457 +#define HCLK_HSIC 458 +#define HCLK_HSADC 459 +#define HCLK_PIDF 460 +#define HCLK_LCDC0 461 +#define HCLK_LCDC1 462 +#define HCLK_ROM 463 +#define HCLK_CIF0 464 +#define HCLK_IPP 465 +#define HCLK_RGA 466 +#define HCLK_NANDC0 467 +#define HCLK_CPU 468 +#define HCLK_PERI 469 + +#define CLK_NR_CLKS (HCLK_PERI + 1) + +/* soft-reset indices */ +#define SRST_MCORE 2 +#define SRST_CORE0 3 +#define SRST_CORE1 4 +#define SRST_MCORE_DBG 7 +#define SRST_CORE0_DBG 8 +#define SRST_CORE1_DBG 9 +#define SRST_CORE0_WDT 12 +#define SRST_CORE1_WDT 13 +#define SRST_STRC_SYS 14 +#define SRST_L2C 15 + +#define SRST_CPU_AHB 17 +#define SRST_AHB2APB 19 +#define SRST_DMA1 20 +#define SRST_INTMEM 21 +#define SRST_ROM 22 +#define SRST_SPDIF 26 +#define SRST_TIMER0 27 +#define SRST_TIMER1 28 +#define SRST_EFUSE 30 + +#define SRST_GPIO0 32 +#define SRST_GPIO1 33 +#define SRST_GPIO2 34 +#define SRST_GPIO3 35 + +#define SRST_UART0 39 +#define SRST_UART1 40 +#define SRST_UART2 41 +#define SRST_UART3 42 +#define SRST_I2C0 43 +#define SRST_I2C1 44 +#define SRST_I2C2 45 +#define SRST_I2C3 46 +#define SRST_I2C4 47 + +#define SRST_PWM0 48 +#define SRST_PWM1 49 +#define SRST_DAP_PO 50 +#define SRST_DAP 51 +#define SRST_DAP_SYS 52 +#define SRST_TPIU_ATB 53 +#define SRST_PMU_APB 54 +#define SRST_GRF 55 +#define SRST_PMU 56 +#define SRST_PERI_AXI 57 +#define SRST_PERI_AHB 58 +#define SRST_PERI_APB 59 +#define SRST_PERI_NIU 60 +#define SRST_CPU_PERI 61 +#define SRST_EMEM_PERI 62 +#define SRST_USB_PERI 63 + +#define SRST_DMA2 64 +#define SRST_SMC 65 +#define SRST_MAC 66 +#define SRST_NANC0 68 +#define SRST_USBOTG0 69 +#define SRST_USBPHY0 70 +#define SRST_OTGC0 71 +#define SRST_USBOTG1 72 +#define SRST_USBPHY1 73 +#define SRST_OTGC1 74 +#define SRST_HSADC 76 +#define SRST_PIDFILTER 77 +#define SRST_DDR_MSCH 79 + +#define SRST_TZPC 80 +#define SRST_SDMMC 81 +#define SRST_SDIO 82 +#define SRST_EMMC 83 +#define SRST_SPI0 84 +#define SRST_SPI1 85 +#define SRST_WDT 86 +#define SRST_SARADC 87 +#define SRST_DDRPHY 88 +#define SRST_DDRPHY_APB 89 +#define SRST_DDRCTL 90 +#define SRST_DDRCTL_APB 91 +#define SRST_DDRPUB 93 + +#define SRST_VIO0_AXI 98 +#define SRST_VIO0_AHB 99 +#define SRST_LCDC0_AXI 100 +#define SRST_LCDC0_AHB 101 +#define SRST_LCDC0_DCLK 102 +#define SRST_LCDC1_AXI 103 +#define SRST_LCDC1_AHB 104 +#define SRST_LCDC1_DCLK 105 +#define SRST_IPP_AXI 106 +#define SRST_IPP_AHB 107 +#define SRST_RGA_AXI 108 +#define SRST_RGA_AHB 109 +#define SRST_CIF0 110 + +#define SRST_VCODEC_AXI 112 +#define SRST_VCODEC_AHB 113 +#define SRST_VIO1_AXI 114 +#define SRST_VCODEC_CPU 115 +#define SRST_VCODEC_NIU 116 +#define SRST_GPU 120 +#define SRST_GPU_NIU 122 +#define SRST_TFUN_ATB 125 +#define SRST_TFUN_APB 126 +#define SRST_CTI4_APB 127 + +#define SRST_TPIU_APB 128 +#define SRST_TRACE 129 +#define SRST_CORE_DBG 130 +#define SRST_DBG_APB 131 +#define SRST_CTI0 132 +#define SRST_CTI0_APB 133 +#define SRST_CTI1 134 +#define SRST_CTI1_APB 135 +#define SRST_PTM_CORE0 136 +#define SRST_PTM_CORE1 137 +#define SRST_PTM0 138 +#define SRST_PTM0_ATB 139 +#define SRST_PTM1 140 +#define SRST_PTM1_ATB 141 +#define SRST_CTM 142 +#define SRST_TS 143 + +#endif diff --git a/include/dt-bindings/clock/rk3188-cru.h b/include/dt-bindings/clock/rk3188-cru.h new file mode 100644 index 0000000000..b6960b07bc --- /dev/null +++ b/include/dt-bindings/clock/rk3188-cru.h @@ -0,0 +1,48 @@ +/* + * Copyright (c) 2014 MundoReader S.L. + * Author: Heiko Stuebner heiko@sntech.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3188_H +#define _DT_BINDINGS_CLK_ROCKCHIP_RK3188_H + +#include <dt-bindings/clock/rk3188-cru-common.h> + +/* soft-reset indices */ +#define SRST_PTM_CORE2 0 +#define SRST_PTM_CORE3 1 +#define SRST_CORE2 5 +#define SRST_CORE3 6 +#define SRST_CORE2_DBG 10 +#define SRST_CORE3_DBG 11 + +#define SRST_TIMER2 16 +#define SRST_TIMER4 23 +#define SRST_I2S0 24 +#define SRST_TIMER5 25 +#define SRST_TIMER3 29 +#define SRST_TIMER6 31 + +#define SRST_PTM3 36 +#define SRST_PTM3_ATB 37 + +#define SRST_GPS 67 +#define SRST_HSICPHY 75 +#define SRST_TIMER 78 + +#define SRST_PTM2 92 +#define SRST_CORE2_WDT 94 +#define SRST_CORE3_WDT 95 + +#define SRST_PTM2_ATB 111 + +#define SRST_HSIC 117 +#define SRST_CTI2 118 +#define SRST_CTI2_APB 119 +#define SRST_GPU_BRIDGE 121 +#define SRST_CTI3 123 +#define SRST_CTI3_APB 124 + +#endif
Add a driver for setting up and modifying the various PLLs and peripheral clocks on the RK3188.
Signed-off-by: Heiko Stuebner heiko@sntech.de --- arch/arm/include/asm/arch-rockchip/cru_rk3188.h | 191 +++++++++ drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_rk3188.c | 523 ++++++++++++++++++++++++ 3 files changed, 715 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rk3188.h create mode 100644 drivers/clk/rockchip/clk_rk3188.c
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3188.h b/arch/arm/include/asm/arch-rockchip/cru_rk3188.h new file mode 100644 index 0000000000..74f0fedcc6 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3188.h @@ -0,0 +1,191 @@ +/* + * (C) Copyright 2016 Heiko Stuebner heiko@sntech.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef _ASM_ARCH_CRU_RK3188_H +#define _ASM_ARCH_CRU_RK3188_H + +#define OSC_HZ (24 * 1000 * 1000) + +#define APLL_HZ (1608 * 1000000) +#define GPLL_HZ (594 * 1000000) +#define CPLL_HZ (384 * 1000000) + +/* The SRAM is clocked off aclk_cpu, so we want to max it out for boot speed */ +#define CPU_ACLK_HZ 297000000 +#define CPU_HCLK_HZ 148500000 +#define CPU_PCLK_HZ 74250000 +#define CPU_H2P_HZ 74250000 + +#define PERI_ACLK_HZ 148500000 +#define PERI_HCLK_HZ 148500000 +#define PERI_PCLK_HZ 74250000 + +/* Private data for the clock driver - used by rockchip_get_cru() */ +struct rk3188_clk_priv { + struct rk3188_grf *grf; + struct rk3188_cru *cru; + ulong rate; + bool has_bwadj; +}; + +struct rk3188_cru { + struct rk3188_pll { + u32 con0; + u32 con1; + u32 con2; + u32 con3; + } pll[4]; + u32 cru_mode_con; + u32 cru_clksel_con[35]; + u32 cru_clkgate_con[10]; + u32 reserved1[2]; + u32 cru_glb_srst_fst_value; + u32 cru_glb_srst_snd_value; + u32 reserved2[2]; + u32 cru_softrst_con[9]; + u32 cru_misc_con; + u32 reserved3[2]; + u32 cru_glb_cnt_th; +}; +check_member(rk3188_cru, cru_glb_cnt_th, 0x0140); + +/* CRU_CLKSEL0_CON */ +enum { + /* a9_core_div: core = core_src / (a9_core_div + 1) */ + A9_CORE_DIV_SHIFT = 9, + A9_CORE_DIV_MASK = 0x1f, + CORE_PLL_SHIFT = 8, + CORE_PLL_MASK = 1, + CORE_PLL_SELECT_APLL = 0, + CORE_PLL_SELECT_GPLL, + + /* core peri div: core:core_peri = 2:1, 4:1, 8:1 or 16:1 */ + CORE_PERI_DIV_SHIFT = 6, + CORE_PERI_DIV_MASK = 3, + + /* aclk_cpu pll selection */ + CPU_ACLK_PLL_SHIFT = 5, + CPU_ACLK_PLL_MASK = 1, + CPU_ACLK_PLL_SELECT_APLL = 0, + CPU_ACLK_PLL_SELECT_GPLL, + + /* a9_cpu_div: aclk_cpu = cpu_src / (a9_cpu_div + 1) */ + A9_CPU_DIV_SHIFT = 0, + A9_CPU_DIV_MASK = 0x1f, +}; + +/* CRU_CLKSEL1_CON */ +enum { + /* ahb2apb_pclk_div: hclk_cpu:pclk_cpu = 1:1, 2:1 or 4:1 */ + AHB2APB_DIV_SHIFT = 14, + AHB2APB_DIV_MASK = 3, + + /* cpu_pclk_div: aclk_cpu:pclk_cpu = 1:1, 2:1, 4:1 or 8:1 */ + CPU_PCLK_DIV_SHIFT = 12, + CPU_PCLK_DIV_MASK = 3, + + /* cpu_hclk_div: aclk_cpu:hclk_cpu = 1:1, 2:1 or 4:1 */ + CPU_HCLK_DIV_SHIFT = 8, + CPU_HCLK_DIV_MASK = 3, + + /* core_aclk_div: cire:aclk_core = 1:1, 2:1, 3:1, 4:1 or 8:1 */ + CORE_ACLK_DIV_SHIFT = 3, + CORE_ACLK_DIV_MASK = 7, +}; + +/* CRU_CLKSEL10_CON */ +enum { + PERI_SEL_PLL_MASK = 1, + PERI_SEL_PLL_SHIFT = 15, + PERI_SEL_CPLL = 0, + PERI_SEL_GPLL, + + /* peri pclk div: aclk_bus:pclk_bus = 1:1, 2:1, 4:1 or 8:1 */ + PERI_PCLK_DIV_SHIFT = 12, + PERI_PCLK_DIV_MASK = 3, + + /* peripheral bus hclk div:aclk_bus: hclk_bus = 1:1, 2:1 or 4:1 */ + PERI_HCLK_DIV_SHIFT = 8, + PERI_HCLK_DIV_MASK = 3, + + /* peri aclk div: aclk_peri = periph_src / (peri_aclk_div + 1) */ + PERI_ACLK_DIV_SHIFT = 0, + PERI_ACLK_DIV_MASK = 0x1f, +}; +/* CRU_CLKSEL11_CON */ +enum { + HSICPHY_DIV_SHIFT = 8, + HSICPHY_DIV_MASK = 0x3f, + + MMC0_DIV_SHIFT = 0, + MMC0_DIV_MASK = 0x3f, +}; + +/* CRU_CLKSEL12_CON */ +enum { + UART_PLL_SHIFT = 15, + UART_PLL_MASK = 1, + UART_PLL_SELECT_GENERAL = 0, + UART_PLL_SELECT_CODEC, + + EMMC_DIV_SHIFT = 8, + EMMC_DIV_MASK = 0x3f, + + SDIO_DIV_SHIFT = 0, + SDIO_DIV_MASK = 0x3f, +}; + +/* CRU_CLKSEL25_CON */ +enum { + SPI1_DIV_SHIFT = 8, + SPI1_DIV_MASK = 0x7f, + + SPI0_DIV_SHIFT = 0, + SPI0_DIV_MASK = 0x7f, +}; + +/* CRU_MODE_CON */ +enum { + GPLL_MODE_SHIFT = 12, + GPLL_MODE_MASK = 3, + GPLL_MODE_SLOW = 0, + GPLL_MODE_NORMAL, + GPLL_MODE_DEEP, + + CPLL_MODE_SHIFT = 8, + CPLL_MODE_MASK = 3, + CPLL_MODE_SLOW = 0, + CPLL_MODE_NORMAL, + CPLL_MODE_DEEP, + + DPLL_MODE_SHIFT = 4, + DPLL_MODE_MASK = 3, + DPLL_MODE_SLOW = 0, + DPLL_MODE_NORMAL, + DPLL_MODE_DEEP, + + APLL_MODE_SHIFT = 0, + APLL_MODE_MASK = 3, + APLL_MODE_SLOW = 0, + APLL_MODE_NORMAL, + APLL_MODE_DEEP, +}; + +/* CRU_APLL_CON0 */ +enum { + CLKR_SHIFT = 8, + CLKR_MASK = 0x3f, + + CLKOD_SHIFT = 0, + CLKOD_MASK = 0x3f, +}; + +/* CRU_APLL_CON1 */ +enum { + CLKF_SHIFT = 0, + CLKF_MASK = 0x1fff, +}; + +#endif diff --git a/drivers/clk/rockchip/Makefile b/drivers/clk/rockchip/Makefile index 1f8e41739d..b66e81e810 100644 --- a/drivers/clk/rockchip/Makefile +++ b/drivers/clk/rockchip/Makefile @@ -5,5 +5,6 @@ #
obj-$(CONFIG_ROCKCHIP_RK3036) += clk_rk3036.o +obj-$(CONFIG_ROCKCHIP_RK3188) += clk_rk3188.o obj-$(CONFIG_ROCKCHIP_RK3288) += clk_rk3288.o obj-$(CONFIG_ROCKCHIP_RK3399) += clk_rk3399.o diff --git a/drivers/clk/rockchip/clk_rk3188.c b/drivers/clk/rockchip/clk_rk3188.c new file mode 100644 index 0000000000..c276772136 --- /dev/null +++ b/drivers/clk/rockchip/clk_rk3188.c @@ -0,0 +1,523 @@ +/* + * (C) Copyright 2015 Google, Inc + * (C) Copyright 2016 Heiko Stuebner heiko@sntech.de + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <dt-structs.h> +#include <errno.h> +#include <mapmem.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/cru_rk3188.h> +#include <asm/arch/grf_rk3188.h> +#include <asm/arch/hardware.h> +#include <dt-bindings/clock/rk3188-cru.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <dm/uclass-internal.h> +#include <linux/log2.h> + +DECLARE_GLOBAL_DATA_PTR; + +enum rk3188_clk_type { + RK3188_CRU, + RK3188A_CRU, +}; + +struct rk3188_clk_plat { +#if CONFIG_IS_ENABLED(OF_PLATDATA) + struct dtd_rockchip_rk3188_cru dtd; +#endif +}; + +struct pll_div { + u32 nr; + u32 nf; + u32 no; +}; + +enum { + VCO_MAX_HZ = 2200U * 1000000, + VCO_MIN_HZ = 440 * 1000000, + OUTPUT_MAX_HZ = 2200U * 1000000, + OUTPUT_MIN_HZ = 30 * 1000000, + FREF_MAX_HZ = 2200U * 1000000, + FREF_MIN_HZ = 30 * 1000, +}; + +enum { + /* PLL CON0 */ + PLL_OD_MASK = 0x0f, + + /* PLL CON1 */ + PLL_NF_MASK = 0x1fff, + + /* PLL CON2 */ + PLL_BWADJ_MASK = 0x0fff, + + /* PLL CON3 */ + PLL_RESET_SHIFT = 5, + + /* GRF_SOC_STATUS0 */ + SOCSTS_DPLL_LOCK = 1 << 5, + SOCSTS_APLL_LOCK = 1 << 6, + SOCSTS_CPLL_LOCK = 1 << 7, + SOCSTS_GPLL_LOCK = 1 << 8, +}; + +#define RATE_TO_DIV(input_rate, output_rate) \ + ((input_rate) / (output_rate) - 1); + +#define DIV_TO_RATE(input_rate, div) ((input_rate) / ((div) + 1)) + +#define PLL_DIVISORS(hz, _nr, _no) {\ + .nr = _nr, .nf = (u32)((u64)hz * _nr * _no / OSC_HZ), .no = _no};\ + _Static_assert(((u64)hz * _nr * _no / OSC_HZ) * OSC_HZ /\ + (_nr * _no) == hz, #hz "Hz cannot be hit with PLL "\ + "divisors on line " __stringify(__LINE__)); + +/* Keep divisors as low as possible to reduce jitter and power usage */ +static const struct pll_div gpll_init_cfg = PLL_DIVISORS(GPLL_HZ, 2, 2); +static const struct pll_div cpll_init_cfg = PLL_DIVISORS(CPLL_HZ, 1, 2); + +static int rkclk_set_pll(struct rk3188_cru *cru, enum rk_clk_id clk_id, + const struct pll_div *div, bool has_bwadj) +{ + int pll_id = rk_pll_id(clk_id); + struct rk3188_pll *pll = &cru->pll[pll_id]; + /* All PLLs have same VCO and output frequency range restrictions. */ + uint vco_hz = OSC_HZ / 1000 * div->nf / div->nr * 1000; + uint output_hz = vco_hz / div->no; + + debug("PLL at %x: nf=%d, nr=%d, no=%d, vco=%u Hz, output=%u Hz\n", + (uint)pll, div->nf, div->nr, div->no, vco_hz, output_hz); + assert(vco_hz >= VCO_MIN_HZ && vco_hz <= VCO_MAX_HZ && + output_hz >= OUTPUT_MIN_HZ && output_hz <= OUTPUT_MAX_HZ && + (div->no == 1 || !(div->no % 2))); + + /* enter reset */ + rk_setreg(&pll->con3, 1 << PLL_RESET_SHIFT); + + rk_clrsetreg(&pll->con0, + CLKR_MASK << CLKR_SHIFT | PLL_OD_MASK, + ((div->nr - 1) << CLKR_SHIFT) | (div->no - 1)); + rk_clrsetreg(&pll->con1, CLKF_MASK, div->nf - 1); + + if (has_bwadj) + rk_clrsetreg(&pll->con2, PLL_BWADJ_MASK, (div->nf >> 1) - 1); + + udelay(10); + + /* return from reset */ + rk_clrreg(&pll->con3, 1 << PLL_RESET_SHIFT); + + return 0; +} + +static int rkclk_configure_ddr(struct rk3188_cru *cru, struct rk3188_grf *grf, + unsigned int hz, bool has_bwadj) +{ + static const struct pll_div dpll_cfg[] = { + {.nf = 25, .nr = 2, .no = 1}, + {.nf = 400, .nr = 9, .no = 2}, + {.nf = 500, .nr = 9, .no = 2}, + {.nf = 100, .nr = 3, .no = 1}, + }; + int cfg; + + switch (hz) { + case 300000000: + cfg = 0; + break; + case 533000000: /* actually 533.3P MHz */ + cfg = 1; + break; + case 666000000: /* actually 666.6P MHz */ + cfg = 2; + break; + case 800000000: + cfg = 3; + break; + default: + debug("Unsupported SDRAM frequency"); + return -EINVAL; + } + + /* pll enter slow-mode */ + rk_clrsetreg(&cru->cru_mode_con, DPLL_MODE_MASK << DPLL_MODE_SHIFT, + DPLL_MODE_SLOW << DPLL_MODE_SHIFT); + + rkclk_set_pll(cru, CLK_DDR, &dpll_cfg[cfg], has_bwadj); + + /* wait for pll lock */ + while (!(readl(&grf->soc_status0) & SOCSTS_DPLL_LOCK)) + udelay(1); + + /* PLL enter normal-mode */ + rk_clrsetreg(&cru->cru_mode_con, DPLL_MODE_MASK << DPLL_MODE_SHIFT, + DPLL_MODE_NORMAL << DPLL_MODE_SHIFT); + + return 0; +} + +#ifdef CONFIG_SPL_BUILD +static void rkclk_init(struct rk3188_cru *cru, struct rk3188_grf *grf, + bool has_bwadj) +{ + u32 aclk_div, hclk_div, pclk_div, h2p_div; + + /* pll enter slow-mode */ + rk_clrsetreg(&cru->cru_mode_con, + GPLL_MODE_MASK << GPLL_MODE_SHIFT | + CPLL_MODE_MASK << CPLL_MODE_SHIFT, + GPLL_MODE_SLOW << GPLL_MODE_SHIFT | + CPLL_MODE_SLOW << CPLL_MODE_SHIFT); + + /* init pll */ + rkclk_set_pll(cru, CLK_GENERAL, &gpll_init_cfg, has_bwadj); + rkclk_set_pll(cru, CLK_CODEC, &cpll_init_cfg, has_bwadj); + + /* waiting for pll lock */ + while ((readl(&grf->soc_status0) & + (SOCSTS_CPLL_LOCK | SOCSTS_GPLL_LOCK)) != + (SOCSTS_CPLL_LOCK | SOCSTS_GPLL_LOCK)) + udelay(1); + + /* + * cpu clock pll source selection and + * reparent aclk_cpu_pre from apll to gpll + * set up dependent divisors for PCLK/HCLK and ACLK clocks. + */ + aclk_div = RATE_TO_DIV(GPLL_HZ, CPU_ACLK_HZ); + assert((aclk_div + 1) * CPU_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f); + + rk_clrsetreg(&cru->cru_clksel_con[0], + CPU_ACLK_PLL_MASK << CPU_ACLK_PLL_SHIFT | + A9_CPU_DIV_MASK << A9_CPU_DIV_SHIFT, + CPU_ACLK_PLL_SELECT_GPLL << CPU_ACLK_PLL_SHIFT | + aclk_div << A9_CPU_DIV_SHIFT); + + hclk_div = ilog2(CPU_ACLK_HZ / CPU_HCLK_HZ); + assert((1 << hclk_div) * CPU_HCLK_HZ == CPU_ACLK_HZ && hclk_div < 0x3); + pclk_div = ilog2(CPU_ACLK_HZ / CPU_PCLK_HZ); + assert((1 << pclk_div) * CPU_PCLK_HZ == CPU_ACLK_HZ && pclk_div < 0x4); + h2p_div = ilog2(CPU_HCLK_HZ / CPU_H2P_HZ); + assert((1 << h2p_div) * CPU_H2P_HZ == CPU_HCLK_HZ && pclk_div < 0x3); + + rk_clrsetreg(&cru->cru_clksel_con[1], + AHB2APB_DIV_MASK << AHB2APB_DIV_SHIFT | + CPU_PCLK_DIV_MASK << CPU_PCLK_DIV_SHIFT | + CPU_HCLK_DIV_MASK << CPU_HCLK_DIV_SHIFT, + h2p_div << AHB2APB_DIV_SHIFT | + pclk_div << CPU_PCLK_DIV_SHIFT | + hclk_div << CPU_HCLK_DIV_SHIFT); + + /* + * peri clock pll source selection and + * set up dependent divisors for PCLK/HCLK and ACLK clocks. + */ + aclk_div = GPLL_HZ / PERI_ACLK_HZ - 1; + assert((aclk_div + 1) * PERI_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f); + + hclk_div = ilog2(PERI_ACLK_HZ / PERI_HCLK_HZ); + assert((1 << hclk_div) * PERI_HCLK_HZ == + PERI_ACLK_HZ && (hclk_div < 0x4)); + + pclk_div = ilog2(PERI_ACLK_HZ / PERI_PCLK_HZ); + assert((1 << pclk_div) * PERI_PCLK_HZ == + PERI_ACLK_HZ && (pclk_div < 0x4)); + + rk_clrsetreg(&cru->cru_clksel_con[10], + PERI_PCLK_DIV_MASK << PERI_PCLK_DIV_SHIFT | + PERI_HCLK_DIV_MASK << PERI_HCLK_DIV_SHIFT | + PERI_ACLK_DIV_MASK << PERI_ACLK_DIV_SHIFT, + PERI_SEL_GPLL << PERI_SEL_PLL_SHIFT | + pclk_div << PERI_PCLK_DIV_SHIFT | + hclk_div << PERI_HCLK_DIV_SHIFT | + aclk_div << PERI_ACLK_DIV_SHIFT); + + /* PLL enter normal-mode */ + rk_clrsetreg(&cru->cru_mode_con, + GPLL_MODE_MASK << GPLL_MODE_SHIFT | + CPLL_MODE_MASK << CPLL_MODE_SHIFT, + GPLL_MODE_NORMAL << GPLL_MODE_SHIFT | + CPLL_MODE_NORMAL << CPLL_MODE_SHIFT); +} +#endif + +/* Get pll rate by id */ +static uint32_t rkclk_pll_get_rate(struct rk3188_cru *cru, + enum rk_clk_id clk_id) +{ + uint32_t nr, no, nf; + uint32_t con; + int pll_id = rk_pll_id(clk_id); + struct rk3188_pll *pll = &cru->pll[pll_id]; + static u8 clk_shift[CLK_COUNT] = { + 0xff, APLL_MODE_SHIFT, DPLL_MODE_SHIFT, CPLL_MODE_SHIFT, + GPLL_MODE_SHIFT + }; + uint shift; + + con = readl(&cru->cru_mode_con); + shift = clk_shift[clk_id]; + switch ((con >> shift) & APLL_MODE_MASK) { + case APLL_MODE_SLOW: + return OSC_HZ; + case APLL_MODE_NORMAL: + /* normal mode */ + con = readl(&pll->con0); + no = ((con >> CLKOD_SHIFT) & CLKOD_MASK) + 1; + nr = ((con >> CLKR_SHIFT) & CLKR_MASK) + 1; + con = readl(&pll->con1); + nf = ((con >> CLKF_SHIFT) & CLKF_MASK) + 1; + + return (24 * nf / (nr * no)) * 1000000; + case APLL_MODE_DEEP: + default: + return 32768; + } +} + +static ulong rockchip_mmc_get_clk(struct rk3188_cru *cru, uint gclk_rate, + int periph) +{ + uint div; + u32 con; + + switch (periph) { + case HCLK_EMMC: + con = readl(&cru->cru_clksel_con[12]); + div = (con >> EMMC_DIV_SHIFT) & EMMC_DIV_MASK; + break; + case HCLK_SDMMC: + con = readl(&cru->cru_clksel_con[11]); + div = (con >> MMC0_DIV_SHIFT) & MMC0_DIV_MASK; + break; + case HCLK_SDIO: + con = readl(&cru->cru_clksel_con[12]); + div = (con >> SDIO_DIV_SHIFT) & SDIO_DIV_MASK; + break; + default: + return -EINVAL; + } + + return DIV_TO_RATE(gclk_rate, div); +} + +static ulong rockchip_mmc_set_clk(struct rk3188_cru *cru, uint gclk_rate, + int periph, uint freq) +{ + int src_clk_div; + + debug("%s: gclk_rate=%u\n", __func__, gclk_rate); + src_clk_div = RATE_TO_DIV(gclk_rate, freq); + assert(src_clk_div <= 0x3f); + + switch (periph) { + case HCLK_EMMC: + rk_clrsetreg(&cru->cru_clksel_con[12], + EMMC_DIV_MASK << EMMC_DIV_SHIFT, + src_clk_div << EMMC_DIV_SHIFT); + break; + case HCLK_SDMMC: + rk_clrsetreg(&cru->cru_clksel_con[11], + MMC0_DIV_MASK << MMC0_DIV_SHIFT, + src_clk_div << MMC0_DIV_SHIFT); + break; + case HCLK_SDIO: + rk_clrsetreg(&cru->cru_clksel_con[12], + SDIO_DIV_MASK << SDIO_DIV_SHIFT, + src_clk_div << SDIO_DIV_SHIFT); + break; + default: + return -EINVAL; + } + + return rockchip_mmc_get_clk(cru, gclk_rate, periph); +} + +static ulong rockchip_spi_get_clk(struct rk3188_cru *cru, uint gclk_rate, + int periph) +{ + uint div; + u32 con; + + switch (periph) { + case SCLK_SPI0: + con = readl(&cru->cru_clksel_con[25]); + div = (con >> SPI0_DIV_SHIFT) & SPI0_DIV_MASK; + break; + case SCLK_SPI1: + con = readl(&cru->cru_clksel_con[25]); + div = (con >> SPI1_DIV_SHIFT) & SPI1_DIV_MASK; + break; + default: + return -EINVAL; + } + + return DIV_TO_RATE(gclk_rate, div); +} + +static ulong rockchip_spi_set_clk(struct rk3188_cru *cru, uint gclk_rate, + int periph, uint freq) +{ + int src_clk_div = RATE_TO_DIV(gclk_rate, freq); + + switch (periph) { + case SCLK_SPI0: + assert(src_clk_div <= SPI0_DIV_MASK); + rk_clrsetreg(&cru->cru_clksel_con[25], + SPI0_DIV_MASK << SPI0_DIV_SHIFT, + src_clk_div << SPI0_DIV_SHIFT); + break; + case SCLK_SPI1: + assert(src_clk_div <= SPI1_DIV_MASK); + rk_clrsetreg(&cru->cru_clksel_con[25], + SPI1_DIV_MASK << SPI1_DIV_SHIFT, + src_clk_div << SPI1_DIV_SHIFT); + break; + default: + return -EINVAL; + } + + return rockchip_spi_get_clk(cru, gclk_rate, periph); +} + +static ulong rk3188_clk_get_rate(struct clk *clk) +{ + struct rk3188_clk_priv *priv = dev_get_priv(clk->dev); + ulong new_rate, gclk_rate; + + gclk_rate = rkclk_pll_get_rate(priv->cru, CLK_GENERAL); + switch (clk->id) { + case 1 ... 4: + new_rate = rkclk_pll_get_rate(priv->cru, clk->id); + break; + case HCLK_EMMC: + case HCLK_SDMMC: + case HCLK_SDIO: + new_rate = rockchip_mmc_get_clk(priv->cru, PERI_HCLK_HZ, + clk->id); + break; + case SCLK_SPI0: + case SCLK_SPI1: + new_rate = rockchip_spi_get_clk(priv->cru, PERI_PCLK_HZ, + clk->id); + break; + case PCLK_I2C0: + case PCLK_I2C1: + case PCLK_I2C2: + case PCLK_I2C3: + case PCLK_I2C4: + return gclk_rate; + default: + return -ENOENT; + } + + return new_rate; +} + +static ulong rk3188_clk_set_rate(struct clk *clk, ulong rate) +{ + struct rk3188_clk_priv *priv = dev_get_priv(clk->dev); + struct rk3188_cru *cru = priv->cru; + ulong new_rate; + + switch (clk->id) { + case CLK_DDR: + new_rate = rkclk_configure_ddr(priv->cru, priv->grf, rate, + priv->has_bwadj); + break; + case HCLK_EMMC: + case HCLK_SDMMC: + case HCLK_SDIO: + new_rate = rockchip_mmc_set_clk(cru, PERI_HCLK_HZ, + clk->id, rate); + break; + case SCLK_SPI0: + case SCLK_SPI1: + new_rate = rockchip_spi_set_clk(cru, PERI_PCLK_HZ, + clk->id, rate); + break; + default: + return -ENOENT; + } + + return new_rate; +} + +static struct clk_ops rk3188_clk_ops = { + .get_rate = rk3188_clk_get_rate, + .set_rate = rk3188_clk_set_rate, +}; + +static int rk3188_clk_ofdata_to_platdata(struct udevice *dev) +{ +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + struct rk3188_clk_priv *priv = dev_get_priv(dev); + + priv->cru = (struct rk3188_cru *)dev_get_addr(dev); +#endif + + return 0; +} + +static int rk3188_clk_probe(struct udevice *dev) +{ + struct rk3188_clk_priv *priv = dev_get_priv(dev); + enum rk3188_clk_type type = dev_get_driver_data(dev); + + priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + if (IS_ERR(priv->grf)) + return PTR_ERR(priv->grf); + priv->has_bwadj = (type == RK3188A_CRU) ? 1 : 0; + +#ifdef CONFIG_SPL_BUILD +#if CONFIG_IS_ENABLED(OF_PLATDATA) + struct rk3188_clk_plat *plat = dev_get_platdata(dev); + + priv->cru = map_sysmem(plat->dtd.reg[0], plat->dtd.reg[1]); +#endif + + rkclk_init(priv->cru, priv->grf, priv->has_bwadj); +#endif + + return 0; +} + +static int rk3188_clk_bind(struct udevice *dev) +{ + int ret; + + /* The reset driver does not have a device node, so bind it here */ + ret = device_bind_driver(gd->dm_root, "rk3188_sysreset", "reset", &dev); + if (ret) + debug("Warning: No rk3188 reset driver: ret=%d\n", ret); + + return 0; +} + +static const struct udevice_id rk3188_clk_ids[] = { + { .compatible = "rockchip,rk3188-cru", .data = RK3188_CRU }, + { .compatible = "rockchip,rk3188a-cru", .data = RK3188A_CRU }, + { } +}; + +U_BOOT_DRIVER(rockchip_rk3188_cru) = { + .name = "rockchip_rk3188_cru", + .id = UCLASS_CLK, + .of_match = rk3188_clk_ids, + .priv_auto_alloc_size = sizeof(struct rk3188_clk_priv), + .platdata_auto_alloc_size = sizeof(struct rk3188_clk_plat), + .ops = &rk3188_clk_ops, + .bind = rk3188_clk_bind, + .ofdata_to_platdata = rk3188_clk_ofdata_to_platdata, + .probe = rk3188_clk_probe, +};
Hi Heiko.
With one comment below.
- (C) Copyright 2016 Heiko Stuebner heiko@sntech.de
ulong rate;
bool has_bwadj;
struct rk3188_pll {
u32 con0;
u32 con1;
u32 con2;
u32 con3;
} pll[4];
u32 cru_mode_con;
u32 reserved1[2];
u32 reserved2[2];
u32 cru_misc_con;
u32 reserved3[2];
u32 cru_glb_cnt_th;
Can you define
A9_CORE_DIV_MASK = 0x1f << A9_CORE_DIV_SHIFT
and similarly for other masks. I got this wrong with rk3288, and I think shifting the mask makes the code easier in places.
Hi Simon,
Am Montag, 6. Februar 2017, 07:35:12 CET schrieb Simon Glass:
ulong rate;
bool has_bwadj;
struct rk3188_pll {
u32 con0;
u32 con1;
u32 con2;
u32 con3;
} pll[4];
u32 cru_mode_con;
u32 reserved1[2];
u32 reserved2[2];
u32 cru_misc_con;
u32 reserved3[2];
u32 cru_glb_cnt_th;
Can you define
I'd disagree here. We're using this scheme everywhere on Rockchip platforms. For example please look at all the pinmux defines GPIO3C1_SHIFT = 2, GPIO3C1_MASK = 3, GPIO3C1_GPIO = 0, GPIO3C1_SDMMC1_DATA0, GPIO3C1_RMII_TXD1, GPIO3C1_RESERVED,
and numerous other places and I'd think mixing paradigms in one soc and between all Rockchip socs would be somewhat unwise.
Heiko
Hi Heiko,
On 18 February 2017 at 07:19, Heiko Stuebner heiko@sntech.de wrote:
Hi Simon,
ulong rate;
bool has_bwadj;
struct rk3188_pll {
u32 con0;
u32 con1;
u32 con2;
u32 con3;
} pll[4];
u32 cru_mode_con;
u32 reserved1[2];
u32 reserved2[2];
u32 cru_misc_con;
u32 reserved3[2];
u32 cru_glb_cnt_th;
Can you define
The new ones are going to use this approach and I will get around to converting them at some point. I do think I did it wrong in the first place.
Anyway let's not hold this up for this as we have the same issue with rk3399.
On 21 February 2017 at 11:07, Simon Glass sjg@chromium.org wrote:
Hi Heiko,
Hi Simon,
ulong rate;
bool has_bwadj;
struct rk3188_pll {
u32 con0;
u32 con1;
u32 con2;
u32 con3;
} pll[4];
u32 cru_mode_con;
u32 reserved1[2];
u32 reserved2[2];
u32 cru_misc_con;
u32 reserved3[2];
u32 cru_glb_cnt_th;
Can you define
Applied to u-boot-rockchip, thanks!
The rk3188 shares a lot of peripherals with the rk3066 and thus has a common include called rk3xxx.dtsi. Add both this one and the specialized rk3188 on top of it.
Signed-off-by: Heiko Stuebner heiko@sntech.de --- arch/arm/dts/rk3188.dtsi | 601 +++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/rk3xxx.dtsi | 417 ++++++++++++++++++++++++++++++++ 2 files changed, 1018 insertions(+) create mode 100644 arch/arm/dts/rk3188.dtsi create mode 100644 arch/arm/dts/rk3xxx.dtsi
diff --git a/arch/arm/dts/rk3188.dtsi b/arch/arm/dts/rk3188.dtsi new file mode 100644 index 0000000000..f4d438eb66 --- /dev/null +++ b/arch/arm/dts/rk3188.dtsi @@ -0,0 +1,601 @@ +/* + * Copyright (c) 2013 MundoReader S.L. + * Author: Heiko Stuebner heiko@sntech.de + * + * SPDX-License-Identifier: GPL-2.0+ or X11 + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/clock/rk3188-cru.h> +#include "rk3xxx.dtsi" + +/ { + compatible = "rockchip,rk3188"; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + enable-method = "rockchip,rk3066-smp"; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + next-level-cache = <&L2>; + reg = <0x0>; + operating-points = < + /* kHz uV */ + 1608000 1350000 + 1416000 1250000 + 1200000 1150000 + 1008000 1075000 + 816000 975000 + 600000 950000 + 504000 925000 + 312000 875000 + >; + clock-latency = <40000>; + clocks = <&cru ARMCLK>; + }; + cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + next-level-cache = <&L2>; + reg = <0x1>; + }; + cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + next-level-cache = <&L2>; + reg = <0x2>; + }; + cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + next-level-cache = <&L2>; + reg = <0x3>; + }; + }; + + sram: sram@10080000 { + compatible = "mmio-sram"; + reg = <0x10080000 0x8000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x10080000 0x8000>; + + smp-sram@0 { + compatible = "rockchip,rk3066-smp-sram"; + reg = <0x0 0x50>; + }; + }; + + i2s0: i2s@1011a000 { + compatible = "rockchip,rk3188-i2s", "rockchip,rk3066-i2s"; + reg = <0x1011a000 0x2000>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2s0_bus>; + dmas = <&dmac1_s 6>, <&dmac1_s 7>; + dma-names = "tx", "rx"; + clock-names = "i2s_hclk", "i2s_clk"; + clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>; + rockchip,playback-channels = <2>; + rockchip,capture-channels = <2>; + status = "disabled"; + }; + + spdif: sound@1011e000 { + compatible = "rockchip,rk3188-spdif", "rockchip,rk3066-spdif"; + reg = <0x1011e000 0x2000>; + #sound-dai-cells = <0>; + clock-names = "hclk", "mclk"; + clocks = <&cru HCLK_SPDIF>, <&cru SCLK_SPDIF>; + dmas = <&dmac1_s 8>; + dma-names = "tx"; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&spdif_tx>; + status = "disabled"; + }; + + cru: clock-controller@20000000 { + compatible = "rockchip,rk3188-cru"; + reg = <0x20000000 0x1000>; + rockchip,grf = <&grf>; + u-boot,dm-spl; + + #clock-cells = <1>; + #reset-cells = <1>; + }; + + efuse: efuse@20010000 { + compatible = "rockchip,rockchip-efuse"; + reg = <0x20010000 0x4000>; + #address-cells = <1>; + #size-cells = <1>; + clocks = <&cru PCLK_EFUSE>; + clock-names = "pclk_efuse"; + + cpu_leakage: cpu_leakage@17 { + reg = <0x17 0x1>; + }; + }; + + usbphy: phy { + compatible = "rockchip,rk3188-usb-phy", "rockchip,rk3288-usb-phy"; + rockchip,grf = <&grf>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + + usbphy0: usb-phy@10c { + #phy-cells = <0>; + reg = <0x10c>; + clocks = <&cru SCLK_OTGPHY0>; + clock-names = "phyclk"; + #clock-cells = <0>; + }; + + usbphy1: usb-phy@11c { + #phy-cells = <0>; + reg = <0x11c>; + clocks = <&cru SCLK_OTGPHY1>; + clock-names = "phyclk"; + #clock-cells = <0>; + }; + }; + + pinctrl: pinctrl { + compatible = "rockchip,rk3188-pinctrl"; + rockchip,grf = <&grf>; + rockchip,pmu = <&pmu>; + + #address-cells = <1>; + #size-cells = <1>; + ranges; + u-boot,dm-spl; + + gpio0: gpio0@2000a000 { + compatible = "rockchip,gpio-bank"; + reg = <0x2000a000 0x100>; + interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_GPIO0>; + + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio1: gpio1@2003c000 { + compatible = "rockchip,gpio-bank"; + reg = <0x2003c000 0x100>; + interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_GPIO1>; + + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio2@2003e000 { + compatible = "rockchip,gpio-bank"; + reg = <0x2003e000 0x100>; + interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_GPIO2>; + + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio3@20080000 { + compatible = "rockchip,gpio-bank"; + reg = <0x20080000 0x100>; + interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_GPIO3>; + + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + pcfg_pull_up: pcfg_pull_up { + bias-pull-up; + }; + + pcfg_pull_down: pcfg_pull_down { + bias-pull-down; + }; + + pcfg_pull_none: pcfg_pull_none { + bias-disable; + }; + + emmc { + emmc_clk: emmc-clk { + rockchip,pins = <RK_GPIO0 24 RK_FUNC_2 &pcfg_pull_none>; + }; + + emmc_cmd: emmc-cmd { + rockchip,pins = <RK_GPIO0 26 RK_FUNC_2 &pcfg_pull_up>; + }; + + emmc_rst: emmc-rst { + rockchip,pins = <RK_GPIO0 27 RK_FUNC_2 &pcfg_pull_none>; + }; + + /* + * The data pins are shared between nandc and emmc and + * not accessible through pinctrl. Also they should've + * been already set correctly by firmware, as + * flash/emmc is the boot-device. + */ + }; + + emac { + emac_xfer: emac-xfer { + rockchip,pins = <RK_GPIO3 16 RK_FUNC_2 &pcfg_pull_none>, /* tx_en */ + <RK_GPIO3 17 RK_FUNC_2 &pcfg_pull_none>, /* txd1 */ + <RK_GPIO3 18 RK_FUNC_2 &pcfg_pull_none>, /* txd0 */ + <RK_GPIO3 19 RK_FUNC_2 &pcfg_pull_none>, /* rxd0 */ + <RK_GPIO3 20 RK_FUNC_2 &pcfg_pull_none>, /* rxd1 */ + <RK_GPIO3 21 RK_FUNC_2 &pcfg_pull_none>, /* mac_clk */ + <RK_GPIO3 22 RK_FUNC_2 &pcfg_pull_none>, /* rx_err */ + <RK_GPIO3 23 RK_FUNC_2 &pcfg_pull_none>; /* crs_dvalid */ + }; + + emac_mdio: emac-mdio { + rockchip,pins = <RK_GPIO3 24 RK_FUNC_2 &pcfg_pull_none>, + <RK_GPIO3 25 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + i2c0 { + i2c0_xfer: i2c0-xfer { + rockchip,pins = <RK_GPIO1 24 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO1 25 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2c1 { + i2c1_xfer: i2c1-xfer { + rockchip,pins = <RK_GPIO1 26 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO1 27 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2c2 { + i2c2_xfer: i2c2-xfer { + rockchip,pins = <RK_GPIO1 28 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO1 29 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2c3 { + i2c3_xfer: i2c3-xfer { + rockchip,pins = <RK_GPIO3 14 RK_FUNC_2 &pcfg_pull_none>, + <RK_GPIO3 15 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + i2c4 { + i2c4_xfer: i2c4-xfer { + rockchip,pins = <RK_GPIO1 30 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO1 31 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + pwm0 { + pwm0_out: pwm0-out { + rockchip,pins = <RK_GPIO3 27 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + pwm1 { + pwm1_out: pwm1-out { + rockchip,pins = <RK_GPIO3 28 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + pwm2 { + pwm2_out: pwm2-out { + rockchip,pins = <RK_GPIO3 29 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + pwm3 { + pwm3_out: pwm3-out { + rockchip,pins = <RK_GPIO3 30 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + spi0 { + spi0_clk: spi0-clk { + rockchip,pins = <RK_GPIO1 6 RK_FUNC_2 &pcfg_pull_up>; + }; + spi0_cs0: spi0-cs0 { + rockchip,pins = <RK_GPIO1 7 RK_FUNC_2 &pcfg_pull_up>; + }; + spi0_tx: spi0-tx { + rockchip,pins = <RK_GPIO1 5 RK_FUNC_2 &pcfg_pull_up>; + }; + spi0_rx: spi0-rx { + rockchip,pins = <RK_GPIO1 4 RK_FUNC_2 &pcfg_pull_up>; + }; + spi0_cs1: spi0-cs1 { + rockchip,pins = <RK_GPIO1 15 RK_FUNC_1 &pcfg_pull_up>; + }; + }; + + spi1 { + spi1_clk: spi1-clk { + rockchip,pins = <RK_GPIO0 30 RK_FUNC_1 &pcfg_pull_up>; + }; + spi1_cs0: spi1-cs0 { + rockchip,pins = <RK_GPIO0 31 RK_FUNC_1 &pcfg_pull_up>; + }; + spi1_rx: spi1-rx { + rockchip,pins = <RK_GPIO0 28 RK_FUNC_1 &pcfg_pull_up>; + }; + spi1_tx: spi1-tx { + rockchip,pins = <RK_GPIO0 29 RK_FUNC_1 &pcfg_pull_up>; + }; + spi1_cs1: spi1-cs1 { + rockchip,pins = <RK_GPIO1 14 RK_FUNC_2 &pcfg_pull_up>; + }; + }; + + uart0 { + uart0_xfer: uart0-xfer { + rockchip,pins = <RK_GPIO1 0 RK_FUNC_1 &pcfg_pull_up>, + <RK_GPIO1 1 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart0_cts: uart0-cts { + rockchip,pins = <RK_GPIO1 2 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart0_rts: uart0-rts { + rockchip,pins = <RK_GPIO1 3 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + uart1 { + uart1_xfer: uart1-xfer { + rockchip,pins = <RK_GPIO1 4 RK_FUNC_1 &pcfg_pull_up>, + <RK_GPIO1 5 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart1_cts: uart1-cts { + rockchip,pins = <RK_GPIO1 6 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart1_rts: uart1-rts { + rockchip,pins = <RK_GPIO1 7 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + uart2 { + uart2_xfer: uart2-xfer { + rockchip,pins = <RK_GPIO1 8 RK_FUNC_1 &pcfg_pull_up>, + <RK_GPIO1 9 RK_FUNC_1 &pcfg_pull_none>; + }; + /* no rts / cts for uart2 */ + }; + + uart3 { + uart3_xfer: uart3-xfer { + rockchip,pins = <RK_GPIO1 10 RK_FUNC_1 &pcfg_pull_up>, + <RK_GPIO1 11 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart3_cts: uart3-cts { + rockchip,pins = <RK_GPIO1 12 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart3_rts: uart3-rts { + rockchip,pins = <RK_GPIO1 13 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + sd0 { + sd0_clk: sd0-clk { + rockchip,pins = <RK_GPIO3 2 RK_FUNC_1 &pcfg_pull_none>; + }; + + sd0_cmd: sd0-cmd { + rockchip,pins = <RK_GPIO3 3 RK_FUNC_1 &pcfg_pull_none>; + }; + + sd0_cd: sd0-cd { + rockchip,pins = <RK_GPIO3 8 RK_FUNC_1 &pcfg_pull_none>; + }; + + sd0_wp: sd0-wp { + rockchip,pins = <RK_GPIO3 9 RK_FUNC_1 &pcfg_pull_none>; + }; + + sd0_pwr: sd0-pwr { + rockchip,pins = <RK_GPIO3 1 RK_FUNC_1 &pcfg_pull_none>; + }; + + sd0_bus1: sd0-bus-width1 { + rockchip,pins = <RK_GPIO3 4 RK_FUNC_1 &pcfg_pull_none>; + }; + + sd0_bus4: sd0-bus-width4 { + rockchip,pins = <RK_GPIO3 4 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO3 5 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO3 6 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO3 7 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + sd1 { + sd1_clk: sd1-clk { + rockchip,pins = <RK_GPIO3 21 RK_FUNC_1 &pcfg_pull_none>; + }; + + sd1_cmd: sd1-cmd { + rockchip,pins = <RK_GPIO3 16 RK_FUNC_1 &pcfg_pull_none>; + }; + + sd1_cd: sd1-cd { + rockchip,pins = <RK_GPIO3 22 RK_FUNC_1 &pcfg_pull_none>; + }; + + sd1_wp: sd1-wp { + rockchip,pins = <RK_GPIO3 23 RK_FUNC_1 &pcfg_pull_none>; + }; + + sd1_bus1: sd1-bus-width1 { + rockchip,pins = <RK_GPIO3 17 RK_FUNC_1 &pcfg_pull_none>; + }; + + sd1_bus4: sd1-bus-width4 { + rockchip,pins = <RK_GPIO3 17 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO3 18 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO3 19 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO3 20 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2s0 { + i2s0_bus: i2s0-bus { + rockchip,pins = <RK_GPIO1 16 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO1 17 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO1 18 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO1 19 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO1 20 RK_FUNC_1 &pcfg_pull_none>, + <RK_GPIO1 21 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + spdif { + spdif_tx: spdif-tx { + rockchip,pins = <RK_GPIO1 14 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + }; +}; + +&emac { + compatible = "rockchip,rk3188-emac"; +}; + +&global_timer { + interrupts = <GIC_PPI 11 0xf04>; +}; + +&grf { + compatible = "rockchip,rk3188-grf", "syscon"; +}; + +&local_timer { + interrupts = <GIC_PPI 13 0xf04>; +}; + +&i2c0 { + compatible = "rockchip,rk3188-i2c"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_xfer>; +}; + +&i2c1 { + compatible = "rockchip,rk3188-i2c"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_xfer>; +}; + +&i2c2 { + compatible = "rockchip,rk3188-i2c"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_xfer>; +}; + +&i2c3 { + compatible = "rockchip,rk3188-i2c"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c3_xfer>; +}; + +&i2c4 { + compatible = "rockchip,rk3188-i2c"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c4_xfer>; +}; + +&pmu { + compatible = "rockchip,rk3188-pmu", "syscon"; +}; + +&pwm0 { + pinctrl-names = "default"; + pinctrl-0 = <&pwm0_out>; +}; + +&pwm1 { + pinctrl-names = "default"; + pinctrl-0 = <&pwm1_out>; +}; + +&pwm2 { + pinctrl-names = "default"; + pinctrl-0 = <&pwm2_out>; +}; + +&pwm3 { + pinctrl-names = "default"; + pinctrl-0 = <&pwm3_out>; +}; + +&spi0 { + compatible = "rockchip,rk3188-spi", "rockchip,rk3066-spi"; + pinctrl-names = "default"; + pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0>; +}; + +&spi1 { + compatible = "rockchip,rk3188-spi", "rockchip,rk3066-spi"; + pinctrl-names = "default"; + pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0>; +}; + +&uart0 { + compatible = "rockchip,rk3188-uart", "snps,dw-apb-uart"; + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer>; +}; + +&uart1 { + compatible = "rockchip,rk3188-uart", "snps,dw-apb-uart"; + pinctrl-names = "default"; + pinctrl-0 = <&uart1_xfer>; +}; + +&uart2 { + compatible = "rockchip,rk3188-uart", "snps,dw-apb-uart"; + pinctrl-names = "default"; + pinctrl-0 = <&uart2_xfer>; +}; + +&uart3 { + compatible = "rockchip,rk3188-uart", "snps,dw-apb-uart"; + pinctrl-names = "default"; + pinctrl-0 = <&uart3_xfer>; +}; + +&wdt { + compatible = "rockchip,rk3188-wdt", "snps,dw-wdt"; +}; diff --git a/arch/arm/dts/rk3xxx.dtsi b/arch/arm/dts/rk3xxx.dtsi new file mode 100644 index 0000000000..6d9e36d235 --- /dev/null +++ b/arch/arm/dts/rk3xxx.dtsi @@ -0,0 +1,417 @@ +/* + * Copyright (c) 2013 MundoReader S.L. + * Author: Heiko Stuebner heiko@sntech.de + * + * SPDX-License-Identifier: GPL-2.0+ or X11 + */ + +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include "skeleton.dtsi" + +/ { + interrupt-parent = <&gic>; + + aliases { + ethernet0 = &emac; + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + i2c3 = &i2c3; + i2c4 = &i2c4; + mshc0 = &emmc; + mshc1 = &mmc0; + mshc2 = &mmc1; + serial0 = &uart0; + serial1 = &uart1; + serial2 = &uart2; + serial3 = &uart3; + spi0 = &spi0; + spi1 = &spi1; + }; + + amba { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + dmac1_s: dma-controller@20018000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x20018000 0x4000>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-broken-no-flushp; + clocks = <&cru ACLK_DMA1>; + clock-names = "apb_pclk"; + }; + + dmac1_ns: dma-controller@2001c000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x2001c000 0x4000>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-broken-no-flushp; + clocks = <&cru ACLK_DMA1>; + clock-names = "apb_pclk"; + status = "disabled"; + }; + + dmac2: dma-controller@20078000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x20078000 0x4000>; + interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-broken-no-flushp; + clocks = <&cru ACLK_DMA2>; + clock-names = "apb_pclk"; + }; + }; + + xin24m: oscillator { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + #clock-cells = <0>; + clock-output-names = "xin24m"; + }; + + L2: l2-cache-controller@10138000 { + compatible = "arm,pl310-cache"; + reg = <0x10138000 0x1000>; + cache-unified; + cache-level = <2>; + }; + + scu@1013c000 { + compatible = "arm,cortex-a9-scu"; + reg = <0x1013c000 0x100>; + }; + + global_timer: global-timer@1013c200 { + compatible = "arm,cortex-a9-global-timer"; + reg = <0x1013c200 0x20>; + interrupts = <GIC_PPI 11 0x304>; + clocks = <&cru CORE_PERI>; + }; + + local_timer: local-timer@1013c600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0x1013c600 0x20>; + interrupts = <GIC_PPI 13 0x304>; + clocks = <&cru CORE_PERI>; + }; + + gic: interrupt-controller@1013d000 { + compatible = "arm,cortex-a9-gic"; + interrupt-controller; + #interrupt-cells = <3>; + reg = <0x1013d000 0x1000>, + <0x1013c100 0x0100>; + }; + + uart0: serial@10124000 { + compatible = "snps,dw-apb-uart"; + reg = <0x10124000 0x400>; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <1>; + clock-names = "baudclk", "apb_pclk"; + clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; + status = "disabled"; + }; + + uart1: serial@10126000 { + compatible = "snps,dw-apb-uart"; + reg = <0x10126000 0x400>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <1>; + clock-names = "baudclk", "apb_pclk"; + clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; + status = "disabled"; + }; + + noc: syscon@10128000 { + u-boot,dm-spl; + compatible = "rockchip,rk3188-noc", "syscon"; + reg = <0x10128000 0x2000>; + }; + + usb_otg: usb@10180000 { + compatible = "rockchip,rk3066-usb", "snps,dwc2"; + reg = <0x10180000 0x40000>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_OTG0>; + clock-names = "otg"; + dr_mode = "otg"; + g-np-tx-fifo-size = <16>; + g-rx-fifo-size = <275>; + g-tx-fifo-size = <256 128 128 64 64 32>; + g-use-dma; + phys = <&usbphy0>; + phy-names = "usb2-phy"; + status = "disabled"; + }; + + usb_host: usb@101c0000 { + compatible = "snps,dwc2"; + reg = <0x101c0000 0x40000>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_OTG1>; + clock-names = "otg"; + dr_mode = "host"; + phys = <&usbphy1>; + phy-names = "usb2-phy"; + status = "disabled"; + }; + + emac: ethernet@10204000 { + compatible = "snps,arc-emac"; + reg = <0x10204000 0x3c>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + + rockchip,grf = <&grf>; + + clocks = <&cru HCLK_EMAC>, <&cru SCLK_MAC>; + clock-names = "hclk", "macref"; + max-speed = <100>; + phy-mode = "rmii"; + + status = "disabled"; + }; + + mmc0: dwmmc@10214000 { + compatible = "rockchip,rk2928-dw-mshc"; + reg = <0x10214000 0x1000>; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>; + clock-names = "biu", "ciu"; + fifo-depth = <256>; + status = "disabled"; + }; + + mmc1: dwmmc@10218000 { + compatible = "rockchip,rk2928-dw-mshc"; + reg = <0x10218000 0x1000>; + interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>; + clock-names = "biu", "ciu"; + fifo-depth = <256>; + status = "disabled"; + }; + + emmc: dwmmc@1021c000 { + compatible = "rockchip,rk2928-dw-mshc"; + reg = <0x1021c000 0x1000>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>; + clock-names = "biu", "ciu"; + fifo-depth = <256>; + status = "disabled"; + }; + + pmu: pmu@20004000 { + compatible = "rockchip,rk3066-pmu", "syscon"; + reg = <0x20004000 0x100>; + u-boot,dm-spl; + }; + + grf: grf@20008000 { + compatible = "syscon"; + reg = <0x20008000 0x200>; + u-boot,dm-spl; + }; + + dmc: dmc@20020000 { + /* unreviewed u-boot-specific binding */ + compatible = "rockchip,rk3188-dmc", "syscon"; + rockchip,cru = <&cru>; + rockchip,grf = <&grf>; + rockchip,pmu = <&pmu>; + rockchip,noc = <&noc>; + reg = <0x20020000 0x3fc + 0x20040000 0x294>; + clocks = <&cru PCLK_DDRUPCTL>, <&cru PCLK_PUBL>; + clock-names = "pclk_ddrupctl", "pclk_publ"; + u-boot,dm-spl; + }; + + i2c0: i2c@2002d000 { + compatible = "rockchip,rk3066-i2c"; + reg = <0x2002d000 0x1000>; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + + rockchip,grf = <&grf>; + + clock-names = "i2c"; + clocks = <&cru PCLK_I2C0>; + + status = "disabled"; + }; + + i2c1: i2c@2002f000 { + compatible = "rockchip,rk3066-i2c"; + reg = <0x2002f000 0x1000>; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + + rockchip,grf = <&grf>; + + clocks = <&cru PCLK_I2C1>; + clock-names = "i2c"; + + status = "disabled"; + }; + + pwm0: pwm@20030000 { + compatible = "rockchip,rk2928-pwm"; + reg = <0x20030000 0x10>; + #pwm-cells = <2>; + clocks = <&cru PCLK_PWM01>; + status = "disabled"; + }; + + pwm1: pwm@20030010 { + compatible = "rockchip,rk2928-pwm"; + reg = <0x20030010 0x10>; + #pwm-cells = <2>; + clocks = <&cru PCLK_PWM01>; + status = "disabled"; + }; + + wdt: watchdog@2004c000 { + compatible = "snps,dw-wdt"; + reg = <0x2004c000 0x100>; + clocks = <&cru PCLK_WDT>; + interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + pwm2: pwm@20050020 { + compatible = "rockchip,rk2928-pwm"; + reg = <0x20050020 0x10>; + #pwm-cells = <2>; + clocks = <&cru PCLK_PWM23>; + status = "disabled"; + }; + + pwm3: pwm@20050030 { + compatible = "rockchip,rk2928-pwm"; + reg = <0x20050030 0x10>; + #pwm-cells = <2>; + clocks = <&cru PCLK_PWM23>; + status = "disabled"; + }; + + i2c2: i2c@20056000 { + compatible = "rockchip,rk3066-i2c"; + reg = <0x20056000 0x1000>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + + rockchip,grf = <&grf>; + + clocks = <&cru PCLK_I2C2>; + clock-names = "i2c"; + + status = "disabled"; + }; + + i2c3: i2c@2005a000 { + compatible = "rockchip,rk3066-i2c"; + reg = <0x2005a000 0x1000>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + + rockchip,grf = <&grf>; + + clocks = <&cru PCLK_I2C3>; + clock-names = "i2c"; + + status = "disabled"; + }; + + i2c4: i2c@2005e000 { + compatible = "rockchip,rk3066-i2c"; + reg = <0x2005e000 0x1000>; + interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + + rockchip,grf = <&grf>; + + clocks = <&cru PCLK_I2C4>; + clock-names = "i2c"; + + status = "disabled"; + }; + + uart2: serial@20064000 { + compatible = "snps,dw-apb-uart"; + reg = <0x20064000 0x400>; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <1>; + clock-frequency = <24000000>; + clock-names = "baudclk", "apb_pclk"; + clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; + status = "disabled"; + }; + + uart3: serial@20068000 { + compatible = "snps,dw-apb-uart"; + reg = <0x20068000 0x400>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <1>; + clock-names = "baudclk", "apb_pclk"; + clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; + status = "disabled"; + }; + + saradc: saradc@2006c000 { + compatible = "rockchip,saradc"; + reg = <0x2006c000 0x100>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + #io-channel-cells = <1>; + clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; + clock-names = "saradc", "apb_pclk"; + status = "disabled"; + }; + + spi0: spi@20070000 { + compatible = "rockchip,rk3066-spi"; + clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; + clock-names = "spiclk", "apb_pclk"; + interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x20070000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + dmas = <&dmac2 10>, <&dmac2 11>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi1: spi@20074000 { + compatible = "rockchip,rk3066-spi"; + clocks = <&cru SCLK_SPI1>, <&cru PCLK_SPI1>; + clock-names = "spiclk", "apb_pclk"; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x20074000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + dmas = <&dmac2 12>, <&dmac2 13>; + dma-names = "tx", "rx"; + status = "disabled"; + }; +};
Does this mirror the Linux kernel setup?
Am Montag, 6. Februar 2017, 07:35:16 CET schrieb Simon Glass:
yep, the split on the file level is the same in kernel. rk3066 and rk3188 share nearly every core component. The only change compared to the kernel are the added u-boot,* properties.
Heiko
Add the core architecture code for the rk3188. It doesn't support the SPL yet, as because of some unknown error it doesn't start yet.
Signed-off-by: Heiko Stuebner heiko@sntech.de --- arch/arm/mach-rockchip/Kconfig | 16 ++++ arch/arm/mach-rockchip/Makefile | 5 ++ arch/arm/mach-rockchip/rk3188/Kconfig | 24 +++++ arch/arm/mach-rockchip/rk3188/Makefile | 10 +++ arch/arm/mach-rockchip/rk3188/clk_rk3188.c | 33 +++++++ arch/arm/mach-rockchip/rk3188/syscon_rk3188.c | 55 ++++++++++++ include/configs/rk3188_common.h | 125 ++++++++++++++++++++++++++ 7 files changed, 268 insertions(+) create mode 100644 arch/arm/mach-rockchip/rk3188/Kconfig create mode 100644 arch/arm/mach-rockchip/rk3188/Makefile create mode 100644 arch/arm/mach-rockchip/rk3188/clk_rk3188.c create mode 100644 arch/arm/mach-rockchip/rk3188/syscon_rk3188.c create mode 100644 include/configs/rk3188_common.h
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index a776df35f4..ba9fbbbd33 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -11,6 +11,21 @@ config ROCKCHIP_RK3036 and video codec support. Peripherals include Gigabit Ethernet, USB2 host and OTG, SDIO, I2S, UART, SPI, I2C and PWMs.
+config ROCKCHIP_RK3188 + bool "Support Rockchip RK3188" + select CPU_V7 + select SUPPORT_SPL + select SUPPORT_TPL + select SPL + select TPL + select ROCKCHIP_BROM_HELPER + help + The Rockchip RK3188 is a ARM-based SoC with a quad-core Cortex-A9 + including NEON and GPU, 512KB L2 cache, Mali-400 graphics, two + video interfaces, several memory options and video codec support. + Peripherals include Fast Ethernet, USB2 host and OTG, SDIO, I2S, + UART, SPI, I2C and PWMs. + config ROCKCHIP_RK3288 bool "Support Rockchip RK3288" select CPU_V7 @@ -50,6 +65,7 @@ config SPL_MMC_SUPPORT default y if !ROCKCHIP_SPL_BACK_TO_BROM
source "arch/arm/mach-rockchip/rk3036/Kconfig" +source "arch/arm/mach-rockchip/rk3188/Kconfig" source "arch/arm/mach-rockchip/rk3288/Kconfig" source "arch/arm/mach-rockchip/rk3399/Kconfig" endif diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index f9ccc9bb2c..2be7e14e3e 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -16,5 +16,10 @@ ifndef CONFIG_ARM64 obj-y += rk_timer.o endif obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036/ + +ifndef CONFIG_TPL_BUILD +obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188/ +endif + obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288/ obj-$(CONFIG_ROCKCHIP_RK3399) += rk3399/ diff --git a/arch/arm/mach-rockchip/rk3188/Kconfig b/arch/arm/mach-rockchip/rk3188/Kconfig new file mode 100644 index 0000000000..f8e1d0316b --- /dev/null +++ b/arch/arm/mach-rockchip/rk3188/Kconfig @@ -0,0 +1,24 @@ +if ROCKCHIP_RK3188 + +config SYS_SOC + default "rockchip" + +config SYS_MALLOC_F_LEN + default 0x0800 + +config SPL_LIBCOMMON_SUPPORT + default y + +config SPL_LIBGENERIC_SUPPORT + default y + +config SPL_SERIAL_SUPPORT + default y + +config TPL_LIBCOMMON_SUPPORT + default y + +config TPL_SERIAL_SUPPORT + default y + +endif diff --git a/arch/arm/mach-rockchip/rk3188/Makefile b/arch/arm/mach-rockchip/rk3188/Makefile new file mode 100644 index 0000000000..7fa010405b --- /dev/null +++ b/arch/arm/mach-rockchip/rk3188/Makefile @@ -0,0 +1,10 @@ +# +# Copyright (c) 2015 Google, Inc +# +# SPDX-License-Identifier: GPL-2.0+ +# + +ifndef CONFIG_TPL_BUILD +obj-y += clk_rk3188.o +obj-y += syscon_rk3188.o +endif diff --git a/arch/arm/mach-rockchip/rk3188/clk_rk3188.c b/arch/arm/mach-rockchip/rk3188/clk_rk3188.c new file mode 100644 index 0000000000..1ec9e1cb75 --- /dev/null +++ b/arch/arm/mach-rockchip/rk3188/clk_rk3188.c @@ -0,0 +1,33 @@ +/* + * Copyright (C) 2015 Google, Inc + * Written by Simon Glass sjg@chromium.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <syscon.h> +#include <asm/arch/clock.h> +#include <asm/arch/cru_rk3188.h> + +int rockchip_get_clk(struct udevice **devp) +{ + return uclass_get_device_by_driver(UCLASS_CLK, + DM_GET_DRIVER(rockchip_rk3188_cru), devp); +} + +void *rockchip_get_cru(void) +{ + struct rk3188_clk_priv *priv; + struct udevice *dev; + int ret; + + ret = rockchip_get_clk(&dev); + if (ret) + return ERR_PTR(ret); + + priv = dev_get_priv(dev); + + return priv->cru; +} diff --git a/arch/arm/mach-rockchip/rk3188/syscon_rk3188.c b/arch/arm/mach-rockchip/rk3188/syscon_rk3188.c new file mode 100644 index 0000000000..aeee6bfcad --- /dev/null +++ b/arch/arm/mach-rockchip/rk3188/syscon_rk3188.c @@ -0,0 +1,55 @@ +/* + * Copyright (C) 2015 Google, Inc + * Written by Simon Glass sjg@chromium.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <syscon.h> +#include <asm/arch/clock.h> + +static const struct udevice_id rk3188_syscon_ids[] = { + { .compatible = "rockchip,rk3188-noc", .data = ROCKCHIP_SYSCON_NOC }, + { .compatible = "rockchip,rk3188-grf", .data = ROCKCHIP_SYSCON_GRF }, + { .compatible = "rockchip,rk3188-pmu", .data = ROCKCHIP_SYSCON_PMU }, + { } +}; + +U_BOOT_DRIVER(syscon_rk3188) = { + .name = "rk3188_syscon", + .id = UCLASS_SYSCON, + .of_match = rk3188_syscon_ids, +}; + +#if CONFIG_IS_ENABLED(OF_PLATDATA) +static int rk3188_syscon_bind_of_platdata(struct udevice *dev) +{ + dev->driver_data = dev->driver->of_match->data; + debug("syscon: %s %d\n", dev->name, (uint)dev->driver_data); + + return 0; +} + +U_BOOT_DRIVER(rockchip_rk3188_noc) = { + .name = "rockchip_rk3188_noc", + .id = UCLASS_SYSCON, + .of_match = rk3188_syscon_ids, + .bind = rk3188_syscon_bind_of_platdata, +}; + +U_BOOT_DRIVER(rockchip_rk3188_grf) = { + .name = "rockchip_rk3188_grf", + .id = UCLASS_SYSCON, + .of_match = rk3188_syscon_ids + 1, + .bind = rk3188_syscon_bind_of_platdata, +}; + +U_BOOT_DRIVER(rockchip_rk3188_pmu) = { + .name = "rockchip_rk3188_pmu", + .id = UCLASS_SYSCON, + .of_match = rk3188_syscon_ids + 2, + .bind = rk3188_syscon_bind_of_platdata, +}; +#endif diff --git a/include/configs/rk3188_common.h b/include/configs/rk3188_common.h new file mode 100644 index 0000000000..3bd04214ec --- /dev/null +++ b/include/configs/rk3188_common.h @@ -0,0 +1,125 @@ +/* + * (C) Copyright 2015 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_RK3188_COMMON_H +#define __CONFIG_RK3188_COMMON_H + +#define CONFIG_SYS_CACHELINE_SIZE 64 + +#include <asm/arch/hardware.h> +#include "rockchip-common.h" + +#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY +#define CONFIG_SYS_NO_FLASH +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_MALLOC_LEN (32 << 20) +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_THUMB_BUILD + +#define CONFIG_SYS_TIMER_RATE (24 * 1000 * 1000) +#define CONFIG_SYS_TIMER_BASE 0x2000e000 /* TIMER3 */ +#define CONFIG_SYS_TIMER_COUNTER (CONFIG_SYS_TIMER_BASE + 8) +#define CONFIG_SYS_TIMER_COUNTS_DOWN + +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SPL_BOARD_INIT + +#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +/* Bootrom will load u-boot binary to 0x60000000 once return from SPL */ +#define CONFIG_SYS_TEXT_BASE 0x60000000 +#else +#define CONFIG_SYS_TEXT_BASE 0x60100000 +#endif +#define CONFIG_SYS_INIT_SP_ADDR 0x60100000 +#define CONFIG_SYS_LOAD_ADDR 0x60800800 + +#define CONFIG_ROCKCHIP_MAX_INIT_SIZE (0x8000 - 0x800) +#define CONFIG_ROCKCHIP_CHIP_TAG "RK31" + +#ifdef CONFIG_TPL_BUILD +#define CONFIG_SPL_TEXT_BASE 0x10080804 +/* tpl size 1kb - 4byte RK31 header */ +#define CONFIG_SPL_MAX_SIZE (0x400 - 0x4) +#elif defined(CONFIG_SPL_BUILD) +/* spl size 32kb sram - 2kb bootrom - 1kb spl */ +#define CONFIG_SPL_MAX_SIZE (0x8000 - 0xC00) +#define CONFIG_SPL_TEXT_BASE 0x10080C00 +#define CONFIG_SPL_FRAMEWORK 1 +#define CONFIG_SPL_CLK 1 +#define CONFIG_SPL_PINCTRL 1 +#define CONFIG_SPL_REGMAP 1 +#define CONFIG_SPL_SYSCON 1 +#define CONFIG_SPL_RAM 1 +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT 1 +#define CONFIG_ROCKCHIP_SERIAL 1 +#endif + +#define CONFIG_SPL_STACK 0x10087fff + +/* MMC/SD IP block */ +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER + +#define CONFIG_DOS_PARTITION +#define CONFIG_FAT_WRITE +#define CONFIG_PARTITION_UUIDS +#define CONFIG_CMD_PART + +#define CONFIG_SYS_SDRAM_BASE 0x60000000 +#define CONFIG_NR_DRAM_BANKS 1 +#define SDRAM_BANK_SIZE (2UL << 30) + +#define CONFIG_SPI_FLASH +#define CONFIG_SPI +#define CONFIG_SF_DEFAULT_SPEED 20000000 + +#ifndef CONFIG_SPL_BUILD +/* usb otg */ +#define CONFIG_USB_GADGET +#define CONFIG_USB_GADGET_DUALSPEED +#define CONFIG_USB_GADGET_DWC2_OTG +#define CONFIG_ROCKCHIP_USB2_PHY +#define CONFIG_USB_GADGET_VBUS_DRAW 0 + +#define CONFIG_USB_GADGET_DOWNLOAD +#define CONFIG_G_DNL_MANUFACTURER "Rockchip" +#define CONFIG_G_DNL_VENDOR_NUM 0x2207 +#define CONFIG_G_DNL_PRODUCT_NUM 0x310a + +/* usb host support */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_DWC2 +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_SMSC95XX +#define CONFIG_USB_ETHER_ASIX +#endif +#define ENV_MEM_LAYOUT_SETTINGS \ + "scriptaddr=0x60000000\0" \ + "pxefile_addr_r=0x60100000\0" \ + "fdt_addr_r=0x61f00000\0" \ + "kernel_addr_r=0x62000000\0" \ + "ramdisk_addr_r=0x64000000\0" + +#include <config_distro_bootcmd.h> + +/* Linux fails to load the fdt if it's loaded above 256M on a Rock board, + * so limit the fdt reallocation to that */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0x6fffffff\0" \ + "initrd_high=0x6fffffff\0" \ + "partitions=" PARTS_DEFAULT \ + ENV_MEM_LAYOUT_SETTINGS \ + ROCKCHIP_DEVICE_SETTINGS \ + BOOTENV + +#endif /* CONFIG_SPL_BUILD */ + +#define CONFIG_PREBOOT + +#endif
The sdram controller blocks are very similar to the rk3288 in utilizing memory scheduler, Designware uPCTL and Designware PUBL blocks, only limited to one bank instead of two.
There are some minimal differences when setting up the ram, so it gets a separate driver for the rk3188 but reuses the driver structs, as there is no need to define the same again.
More optimization can happen when the modelling of the controller parts in the dts actually follow the hardware layout hopefully at some point in the future.
Signed-off-by: Heiko Stuebner heiko@sntech.de --- arch/arm/include/asm/arch-rockchip/ddr_rk3188.h | 22 + arch/arm/mach-rockchip/rk3188/Makefile | 1 + arch/arm/mach-rockchip/rk3188/sdram_rk3188.c | 985 ++++++++++++++++++++++++ 3 files changed, 1008 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/ddr_rk3188.h create mode 100644 arch/arm/mach-rockchip/rk3188/sdram_rk3188.c
diff --git a/arch/arm/include/asm/arch-rockchip/ddr_rk3188.h b/arch/arm/include/asm/arch-rockchip/ddr_rk3188.h new file mode 100644 index 0000000000..993c58d1a8 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/ddr_rk3188.h @@ -0,0 +1,22 @@ +/* + * (C) Copyright 2015 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _ASM_ARCH_DDR_RK3188_H +#define _ASM_ARCH_DDR_RK3188_H + +#include <asm/arch/ddr_rk3288.h> + +struct rk3188_msch { + u32 coreid; + u32 revisionid; + u32 ddrconf; + u32 ddrtiming; + u32 ddrmode; + u32 readlatency; +}; +check_member(rk3188_msch, readlatency, 0x0014); + +#endif diff --git a/arch/arm/mach-rockchip/rk3188/Makefile b/arch/arm/mach-rockchip/rk3188/Makefile index 7fa010405b..2dc9511de7 100644 --- a/arch/arm/mach-rockchip/rk3188/Makefile +++ b/arch/arm/mach-rockchip/rk3188/Makefile @@ -6,5 +6,6 @@
ifndef CONFIG_TPL_BUILD obj-y += clk_rk3188.o +obj-y += sdram_rk3188.o obj-y += syscon_rk3188.o endif diff --git a/arch/arm/mach-rockchip/rk3188/sdram_rk3188.c b/arch/arm/mach-rockchip/rk3188/sdram_rk3188.c new file mode 100644 index 0000000000..9e41723c9f --- /dev/null +++ b/arch/arm/mach-rockchip/rk3188/sdram_rk3188.c @@ -0,0 +1,985 @@ +/* + * (C) Copyright 2015 Google, Inc + * Copyright 2014 Rockchip Inc. + * + * SPDX-License-Identifier: GPL-2.0 + * + * Adapted from coreboot. + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dt-structs.h> +#include <errno.h> +#include <ram.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/cru_rk3188.h> +#include <asm/arch/ddr_rk3188.h> +#include <asm/arch/grf_rk3188.h> +#include <asm/arch/pmu_rk3188.h> +#include <asm/arch/sdram.h> +#include <linux/err.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct chan_info { + struct rk3288_ddr_pctl *pctl; + struct rk3288_ddr_publ *publ; + struct rk3188_msch *msch; +}; + +struct dram_info { + struct chan_info chan[1]; + struct ram_info info; + struct clk ddr_clk; + struct rk3188_cru *cru; + struct rk3188_grf *grf; + struct rk3188_sgrf *sgrf; + struct rk3188_pmu *pmu; +}; + +struct rk3188_sdram_params { +#if CONFIG_IS_ENABLED(OF_PLATDATA) + struct dtd_rockchip_rk3188_dmc of_plat; +#endif + struct rk3288_sdram_channel ch[2]; + struct rk3288_sdram_pctl_timing pctl_timing; + struct rk3288_sdram_phy_timing phy_timing; + struct rk3288_base_params base; + int num_channels; + struct regmap *map; +}; + +#define TEST_PATTEN 0x5aa5f00f +#define DQS_GATE_TRAINING_ERROR_RANK0 (1 << 4) +#define DQS_GATE_TRAINING_ERROR_RANK1 (2 << 4) + +#ifdef CONFIG_SPL_BUILD +static void copy_to_reg(u32 *dest, const u32 *src, u32 n) +{ + int i; + + for (i = 0; i < n / sizeof(u32); i++) { + writel(*src, dest); + src++; + dest++; + } +} + +static void ddr_reset(struct rk3188_cru *cru, u32 ch, u32 ctl, u32 phy) +{ + u32 phy_ctl_srstn_shift = 5 + 8 * ch; + u32 ctl_psrstn_shift = 3 + 8 * ch; + u32 ctl_srstn_shift = 2 + 8 * ch; + u32 phy_psrstn_shift = 1 + 8 * ch; + u32 phy_srstn_shift = 8 * ch; + + rk_clrsetreg(&cru->cru_softrst_con[5], + 1 << phy_ctl_srstn_shift | 1 << ctl_psrstn_shift | + 1 << ctl_srstn_shift | 1 << phy_psrstn_shift | + 1 << phy_srstn_shift, + phy << phy_ctl_srstn_shift | ctl << ctl_psrstn_shift | + ctl << ctl_srstn_shift | phy << phy_psrstn_shift | + phy << phy_srstn_shift); +} + +static void ddr_phy_ctl_reset(struct rk3188_cru *cru, u32 ch, u32 n) +{ + u32 phy_ctl_srstn_shift = 5 + 8 * ch; + + rk_clrsetreg(&cru->cru_softrst_con[5], + 1 << phy_ctl_srstn_shift, n << phy_ctl_srstn_shift); +} + +static void phy_pctrl_reset(struct rk3188_cru *cru, + struct rk3288_ddr_publ *publ, + u32 channel) +{ + int i; + + ddr_reset(cru, channel, 1, 1); + udelay(1); + clrbits_le32(&publ->acdllcr, ACDLLCR_DLLSRST); + for (i = 0; i < 4; i++) + clrbits_le32(&publ->datx8[i].dxdllcr, DXDLLCR_DLLSRST); + + udelay(10); + setbits_le32(&publ->acdllcr, ACDLLCR_DLLSRST); + for (i = 0; i < 4; i++) + setbits_le32(&publ->datx8[i].dxdllcr, DXDLLCR_DLLSRST); + + udelay(10); + ddr_reset(cru, channel, 1, 0); + udelay(10); + ddr_reset(cru, channel, 0, 0); + udelay(10); +} + +static void phy_dll_bypass_set(struct rk3288_ddr_publ *publ, + u32 freq) +{ + int i; + if (freq <= 250000000) { + if (freq <= 150000000) + clrbits_le32(&publ->dllgcr, SBIAS_BYPASS); + else + setbits_le32(&publ->dllgcr, SBIAS_BYPASS); + setbits_le32(&publ->acdllcr, ACDLLCR_DLLDIS); + for (i = 0; i < 4; i++) + setbits_le32(&publ->datx8[i].dxdllcr, + DXDLLCR_DLLDIS); + + setbits_le32(&publ->pir, PIR_DLLBYP); + } else { + clrbits_le32(&publ->dllgcr, SBIAS_BYPASS); + clrbits_le32(&publ->acdllcr, ACDLLCR_DLLDIS); + for (i = 0; i < 4; i++) { + clrbits_le32(&publ->datx8[i].dxdllcr, + DXDLLCR_DLLDIS); + } + + clrbits_le32(&publ->pir, PIR_DLLBYP); + } +} + +static void dfi_cfg(struct rk3288_ddr_pctl *pctl, u32 dramtype) +{ + writel(DFI_INIT_START, &pctl->dfistcfg0); + writel(DFI_DRAM_CLK_SR_EN | DFI_DRAM_CLK_DPD_EN, + &pctl->dfistcfg1); + writel(DFI_PARITY_INTR_EN | DFI_PARITY_EN, &pctl->dfistcfg2); + writel(7 << TLP_RESP_TIME_SHIFT | LP_SR_EN | LP_PD_EN, + &pctl->dfilpcfg0); + + writel(2 << TCTRL_DELAY_TIME_SHIFT, &pctl->dfitctrldelay); + writel(1 << TPHY_WRDATA_TIME_SHIFT, &pctl->dfitphywrdata); + writel(0xf << TPHY_RDLAT_TIME_SHIFT, &pctl->dfitphyrdlat); + writel(2 << TDRAM_CLK_DIS_TIME_SHIFT, &pctl->dfitdramclkdis); + writel(2 << TDRAM_CLK_EN_TIME_SHIFT, &pctl->dfitdramclken); + writel(1, &pctl->dfitphyupdtype0); + + /* cs0 and cs1 write odt enable */ + writel((RANK0_ODT_WRITE_SEL | RANK1_ODT_WRITE_SEL), + &pctl->dfiodtcfg); + /* odt write length */ + writel(7 << ODT_LEN_BL8_W_SHIFT, &pctl->dfiodtcfg1); + /* phyupd and ctrlupd disabled */ + writel(0, &pctl->dfiupdcfg); +} + +static void ddr_set_enable(struct rk3188_grf *grf, uint channel, bool enable) +{ + uint val = 0; + + if (enable) + val = 1 << DDR_16BIT_EN_SHIFT; + + rk_clrsetreg(&grf->ddrc_con0, 1 << DDR_16BIT_EN_SHIFT, val); +} + +static void ddr_set_ddr3_mode(struct rk3188_grf *grf, uint channel, + bool ddr3_mode) +{ + uint mask, val; + + mask = 1 << MSCH4_MAINDDR3_SHIFT; + val = ddr3_mode << MSCH4_MAINDDR3_SHIFT; + rk_clrsetreg(&grf->soc_con2, mask, val); +} + +#define RANK_2_ROW15_EN 1 +static void ddr_rank_2_row15en(struct rk3188_grf *grf, bool enable) +{ + uint mask, val; + + mask = 1 << RANK_2_ROW15_EN; + val = enable << RANK_2_ROW15_EN; + rk_clrsetreg(&grf->soc_con2, mask, val); +} + +static void pctl_cfg(u32 channel, struct rk3288_ddr_pctl *pctl, + struct rk3188_sdram_params *sdram_params, + struct rk3188_grf *grf) +{ + copy_to_reg(&pctl->togcnt1u, &sdram_params->pctl_timing.togcnt1u, + sizeof(sdram_params->pctl_timing)); + switch (sdram_params->base.dramtype) { + case DDR3: + if (sdram_params->phy_timing.mr[1] & DDR3_DLL_DISABLE) { + writel(sdram_params->pctl_timing.tcl - 3, + &pctl->dfitrddataen); + } else { + writel(sdram_params->pctl_timing.tcl - 2, + &pctl->dfitrddataen); + } + writel(sdram_params->pctl_timing.tcwl - 1, + &pctl->dfitphywrlat); + writel(0 << MDDR_LPDDR2_CLK_STOP_IDLE_SHIFT | DDR3_EN | + DDR2_DDR3_BL_8 | (6 - 4) << TFAW_SHIFT | PD_EXIT_SLOW | + 1 << PD_TYPE_SHIFT | 0 << PD_IDLE_SHIFT, + &pctl->mcfg); + ddr_set_ddr3_mode(grf, channel, true); + ddr_set_enable(grf, channel, true); + break; + } + + setbits_le32(&pctl->scfg, 1); +} + +static void phy_cfg(const struct chan_info *chan, u32 channel, + struct rk3188_sdram_params *sdram_params) +{ + struct rk3288_ddr_publ *publ = chan->publ; + struct rk3188_msch *msch = chan->msch; + uint ddr_freq_mhz = sdram_params->base.ddr_freq / 1000000; + u32 dinit2; + int i; + + dinit2 = DIV_ROUND_UP(ddr_freq_mhz * 200000, 1000); + /* DDR PHY Timing */ + copy_to_reg(&publ->dtpr[0], &sdram_params->phy_timing.dtpr0, + sizeof(sdram_params->phy_timing)); + writel(sdram_params->base.noc_timing, &msch->ddrtiming); + writel(0x3f, &msch->readlatency); + writel(DIV_ROUND_UP(ddr_freq_mhz * 5120, 1000) << PRT_DLLLOCK_SHIFT | + DIV_ROUND_UP(ddr_freq_mhz * 50, 1000) << PRT_DLLSRST_SHIFT | + 8 << PRT_ITMSRST_SHIFT, &publ->ptr[0]); + writel(DIV_ROUND_UP(ddr_freq_mhz * 500000, 1000) << PRT_DINIT0_SHIFT | + DIV_ROUND_UP(ddr_freq_mhz * 400, 1000) << PRT_DINIT1_SHIFT, + &publ->ptr[1]); + writel(min(dinit2, 0x1ffffU) << PRT_DINIT2_SHIFT | + DIV_ROUND_UP(ddr_freq_mhz * 1000, 1000) << PRT_DINIT3_SHIFT, + &publ->ptr[2]); + + switch (sdram_params->base.dramtype) { + case DDR3: + clrbits_le32(&publ->pgcr, 0x1f); + clrsetbits_le32(&publ->dcr, DDRMD_MASK << DDRMD_SHIFT, + DDRMD_DDR3 << DDRMD_SHIFT); + break; + } + if (sdram_params->base.odt) { + /*dynamic RTT enable */ + for (i = 0; i < 4; i++) + setbits_le32(&publ->datx8[i].dxgcr, DQSRTT | DQRTT); + } else { + /*dynamic RTT disable */ + for (i = 0; i < 4; i++) + clrbits_le32(&publ->datx8[i].dxgcr, DQSRTT | DQRTT); + } +} + +static void phy_init(struct rk3288_ddr_publ *publ) +{ + setbits_le32(&publ->pir, PIR_INIT | PIR_DLLSRST + | PIR_DLLLOCK | PIR_ZCAL | PIR_ITMSRST | PIR_CLRSR); + udelay(1); + while ((readl(&publ->pgsr) & + (PGSR_IDONE | PGSR_DLDONE | PGSR_ZCDONE)) != + (PGSR_IDONE | PGSR_DLDONE | PGSR_ZCDONE)) + ; +} + +static void send_command(struct rk3288_ddr_pctl *pctl, u32 rank, + u32 cmd, u32 arg) +{ + writel((START_CMD | (rank << 20) | arg | cmd), &pctl->mcmd); + udelay(1); + while (readl(&pctl->mcmd) & START_CMD) + ; +} + +static inline void send_command_op(struct rk3288_ddr_pctl *pctl, + u32 rank, u32 cmd, u32 ma, u32 op) +{ + send_command(pctl, rank, cmd, (ma & LPDDR2_MA_MASK) << LPDDR2_MA_SHIFT | + (op & LPDDR2_OP_MASK) << LPDDR2_OP_SHIFT); +} + +static void memory_init(struct rk3288_ddr_publ *publ, + u32 dramtype) +{ + setbits_le32(&publ->pir, + (PIR_INIT | PIR_DRAMINIT | PIR_LOCKBYP + | PIR_ZCALBYP | PIR_CLRSR | PIR_ICPC + | (dramtype == DDR3 ? PIR_DRAMRST : 0))); + udelay(1); + while ((readl(&publ->pgsr) & (PGSR_IDONE | PGSR_DLDONE)) + != (PGSR_IDONE | PGSR_DLDONE)) + ; +} + +static void move_to_config_state(struct rk3288_ddr_publ *publ, + struct rk3288_ddr_pctl *pctl) +{ + unsigned int state; + + while (1) { + state = readl(&pctl->stat) & PCTL_STAT_MSK; + + switch (state) { + case LOW_POWER: + writel(WAKEUP_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MSK) + != ACCESS) + ; + /* wait DLL lock */ + while ((readl(&publ->pgsr) & PGSR_DLDONE) + != PGSR_DLDONE) + ; + /* if at low power state,need wakeup first, + * and then enter the config, so + * fallthrough + */ + case ACCESS: + /* fallthrough */ + case INIT_MEM: + writel(CFG_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MSK) != CONFIG) + ; + break; + case CONFIG: + return; + default: + break; + } + } +} + +static void set_bandwidth_ratio(const struct chan_info *chan, u32 channel, + u32 n, struct rk3188_grf *grf) +{ + struct rk3288_ddr_pctl *pctl = chan->pctl; + struct rk3288_ddr_publ *publ = chan->publ; + struct rk3188_msch *msch = chan->msch; + + if (n == 1) { + setbits_le32(&pctl->ppcfg, 1); + ddr_set_enable(grf, channel, 1); + setbits_le32(&msch->ddrtiming, 1 << 31); + /* Data Byte disable*/ + clrbits_le32(&publ->datx8[2].dxgcr, 1); + clrbits_le32(&publ->datx8[3].dxgcr, 1); + /* disable DLL */ + setbits_le32(&publ->datx8[2].dxdllcr, DXDLLCR_DLLDIS); + setbits_le32(&publ->datx8[3].dxdllcr, DXDLLCR_DLLDIS); + } else { + clrbits_le32(&pctl->ppcfg, 1); + ddr_set_enable(grf, channel, 0); + clrbits_le32(&msch->ddrtiming, 1 << 31); + /* Data Byte enable*/ + setbits_le32(&publ->datx8[2].dxgcr, 1); + setbits_le32(&publ->datx8[3].dxgcr, 1); + + /* enable DLL */ + clrbits_le32(&publ->datx8[2].dxdllcr, DXDLLCR_DLLDIS); + clrbits_le32(&publ->datx8[3].dxdllcr, DXDLLCR_DLLDIS); + /* reset DLL */ + clrbits_le32(&publ->datx8[2].dxdllcr, DXDLLCR_DLLSRST); + clrbits_le32(&publ->datx8[3].dxdllcr, DXDLLCR_DLLSRST); + udelay(10); + setbits_le32(&publ->datx8[2].dxdllcr, DXDLLCR_DLLSRST); + setbits_le32(&publ->datx8[3].dxdllcr, DXDLLCR_DLLSRST); + } + setbits_le32(&pctl->dfistcfg0, 1 << 2); +} + +static int data_training(const struct chan_info *chan, u32 channel, + struct rk3188_sdram_params *sdram_params) +{ + unsigned int j; + int ret = 0; + u32 rank; + int i; + u32 step[2] = { PIR_QSTRN, PIR_RVTRN }; + struct rk3288_ddr_publ *publ = chan->publ; + struct rk3288_ddr_pctl *pctl = chan->pctl; + + /* disable auto refresh */ + writel(0, &pctl->trefi); + + if (sdram_params->base.dramtype != LPDDR3) + setbits_le32(&publ->pgcr, 1 << PGCR_DQSCFG_SHIFT); + rank = sdram_params->ch[channel].rank | 1; + for (j = 0; j < ARRAY_SIZE(step); j++) { + /* + * trigger QSTRN and RVTRN + * clear DTDONE status + */ + setbits_le32(&publ->pir, PIR_CLRSR); + + /* trigger DTT */ + setbits_le32(&publ->pir, + PIR_INIT | step[j] | PIR_LOCKBYP | PIR_ZCALBYP | + PIR_CLRSR); + udelay(1); + /* wait echo byte DTDONE */ + while ((readl(&publ->datx8[0].dxgsr[0]) & rank) + != rank) + ; + while ((readl(&publ->datx8[1].dxgsr[0]) & rank) + != rank) + ; + if (!(readl(&pctl->ppcfg) & 1)) { + while ((readl(&publ->datx8[2].dxgsr[0]) + & rank) != rank) + ; + while ((readl(&publ->datx8[3].dxgsr[0]) + & rank) != rank) + ; + } + if (readl(&publ->pgsr) & + (PGSR_DTERR | PGSR_RVERR | PGSR_RVEIRR)) { + ret = -1; + break; + } + } + /* send some auto refresh to complement the lost while DTT */ + for (i = 0; i < (rank > 1 ? 8 : 4); i++) + send_command(pctl, rank, REF_CMD, 0); + + if (sdram_params->base.dramtype != LPDDR3) + clrbits_le32(&publ->pgcr, 1 << PGCR_DQSCFG_SHIFT); + + /* resume auto refresh */ + writel(sdram_params->pctl_timing.trefi, &pctl->trefi); + + return ret; +} + +static void move_to_access_state(const struct chan_info *chan) +{ + struct rk3288_ddr_publ *publ = chan->publ; + struct rk3288_ddr_pctl *pctl = chan->pctl; + unsigned int state; + + while (1) { + state = readl(&pctl->stat) & PCTL_STAT_MSK; + + switch (state) { + case LOW_POWER: + if (((readl(&pctl->stat) >> LP_TRIG_SHIFT) & + LP_TRIG_MASK) == 1) + return; + + writel(WAKEUP_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MSK) != ACCESS) + ; + /* wait DLL lock */ + while ((readl(&publ->pgsr) & PGSR_DLDONE) + != PGSR_DLDONE) + ; + break; + case INIT_MEM: + writel(CFG_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MSK) != CONFIG) + ; + /* fallthrough */ + case CONFIG: + writel(GO_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MSK) == CONFIG) + ; + break; + case ACCESS: + return; + default: + break; + } + } +} + +static void dram_cfg_rbc(const struct chan_info *chan, u32 chnum, + struct rk3188_sdram_params *sdram_params) +{ + struct rk3288_ddr_publ *publ = chan->publ; + + if (sdram_params->ch[chnum].bk == 3) + clrsetbits_le32(&publ->dcr, PDQ_MASK << PDQ_SHIFT, + 1 << PDQ_SHIFT); + else + clrbits_le32(&publ->dcr, PDQ_MASK << PDQ_SHIFT); + + writel(sdram_params->base.ddrconfig, &chan->msch->ddrconf); +} + +static void dram_all_config(const struct dram_info *dram, + struct rk3188_sdram_params *sdram_params) +{ + unsigned int chan; + u32 sys_reg = 0; + + sys_reg |= sdram_params->base.dramtype << SYS_REG_DDRTYPE_SHIFT; + sys_reg |= (sdram_params->num_channels - 1) << SYS_REG_NUM_CH_SHIFT; + for (chan = 0; chan < sdram_params->num_channels; chan++) { + const struct rk3288_sdram_channel *info = + &sdram_params->ch[chan]; + + sys_reg |= info->row_3_4 << SYS_REG_ROW_3_4_SHIFT(chan); + sys_reg |= 1 << SYS_REG_CHINFO_SHIFT(chan); + sys_reg |= (info->rank - 1) << SYS_REG_RANK_SHIFT(chan); + sys_reg |= (info->col - 9) << SYS_REG_COL_SHIFT(chan); + sys_reg |= info->bk == 3 ? 0 : 1 << SYS_REG_BK_SHIFT(chan); + sys_reg |= (info->cs0_row - 13) << SYS_REG_CS0_ROW_SHIFT(chan); + sys_reg |= (info->cs1_row - 13) << SYS_REG_CS1_ROW_SHIFT(chan); + sys_reg |= (2 >> info->bw) << SYS_REG_BW_SHIFT(chan); + sys_reg |= (2 >> info->dbw) << SYS_REG_DBW_SHIFT(chan); + + dram_cfg_rbc(&dram->chan[chan], chan, sdram_params); + } + if (sdram_params->ch[0].rank == 2) + ddr_rank_2_row15en(dram->grf, 0); + else + ddr_rank_2_row15en(dram->grf, 1); + writel(sys_reg, &dram->pmu->sys_reg[2]); +} +const int ddrconf_table[] = { + /* + * [5:4] row(13+n) + * [1:0] col(9+n), assume bw=2 + * row col,bw */ + 0, + ((2 << 4) | 1), + ((1 << 4) | 1), + ((0 << 4) | 1), + ((2 << 4) | 2), + ((1 << 4) | 2), + ((0 << 4) | 2), + ((1 << 4) | 0), + ((0 << 4) | 0), + 0, + 0, + 0, + 0, + 0, + 0, + 0, +}; + +static int sdram_rank_bw_detect(struct dram_info *dram, int channel, + struct rk3188_sdram_params *sdram_params) +{ + int reg; + int need_trainig = 0; + const struct chan_info *chan = &dram->chan[channel]; + struct rk3288_ddr_publ *publ = chan->publ; + + ddr_rank_2_row15en(dram->grf, 0); + + if (-1 == data_training(chan, channel, sdram_params)) { + printf("first data training fail!\n"); + reg = readl(&publ->datx8[0].dxgsr[0]); + /* Check the result for rank 0 */ + if ((channel == 0) && (reg & DQS_GATE_TRAINING_ERROR_RANK0)) { + printf("data training fail!\n"); + return -EIO; + } + + /* Check the result for rank 1 */ + if (reg & DQS_GATE_TRAINING_ERROR_RANK1) { + sdram_params->ch[channel].rank = 1; + clrsetbits_le32(&publ->pgcr, 0xF << 18, + sdram_params->ch[channel].rank << 18); + need_trainig = 1; + } + reg = readl(&publ->datx8[2].dxgsr[0]); + if (reg & (1 << 4)) { + sdram_params->ch[channel].bw = 1; + set_bandwidth_ratio(chan, channel, + sdram_params->ch[channel].bw, + dram->grf); + need_trainig = 1; + } + } + /* Assume the Die bit width are the same with the chip bit width */ + sdram_params->ch[channel].dbw = sdram_params->ch[channel].bw; + + if (need_trainig && + (-1 == data_training(chan, channel, sdram_params))) { + if (sdram_params->base.dramtype == LPDDR3) { + ddr_phy_ctl_reset(dram->cru, channel, 1); + udelay(10); + ddr_phy_ctl_reset(dram->cru, channel, 0); + udelay(10); + } + printf("2nd data training failed!"); + return -EIO; + } + + return 0; +} + +static int sdram_col_row_detect(struct dram_info *dram, int channel, + struct rk3188_sdram_params *sdram_params) +{ + int row, col; + unsigned int addr; + const struct chan_info *chan = &dram->chan[channel]; + struct rk3288_ddr_pctl *pctl = chan->pctl; + struct rk3288_ddr_publ *publ = chan->publ; + int ret = 0; + + /* Detect col */ + for (col = 11; col >= 9; col--) { + writel(0, CONFIG_SYS_SDRAM_BASE); + addr = CONFIG_SYS_SDRAM_BASE + + (1 << (col + sdram_params->ch[channel].bw - 1)); + writel(TEST_PATTEN, addr); + if ((readl(addr) == TEST_PATTEN) && + (readl(CONFIG_SYS_SDRAM_BASE) == 0)) + break; + } + if (col == 8) { + printf("Col detect error\n"); + ret = -EINVAL; + goto out; + } else { + sdram_params->ch[channel].col = col; + } + + ddr_rank_2_row15en(dram->grf, 1); + move_to_config_state(publ, pctl); + writel(1, &chan->msch->ddrconf); + move_to_access_state(chan); + /* Detect row, max 15,min13 in rk3188*/ + for (row = 16; row >= 13; row--) { + writel(0, CONFIG_SYS_SDRAM_BASE); + addr = CONFIG_SYS_SDRAM_BASE + (1 << (row + 15 - 1)); + writel(TEST_PATTEN, addr); + if ((readl(addr) == TEST_PATTEN) && + (readl(CONFIG_SYS_SDRAM_BASE) == 0)) + break; + } + if (row == 12) { + printf("Row detect error\n"); + ret = -EINVAL; + } else { + sdram_params->ch[channel].cs1_row = row; + sdram_params->ch[channel].row_3_4 = 0; + printf("chn %d col %d, row %d\n", channel, col, row); + sdram_params->ch[channel].cs0_row = row; + } + +out: + return ret; +} + +static int sdram_get_niu_config(struct rk3188_sdram_params *sdram_params) +{ + int i, tmp, size, ret = 0; + + tmp = sdram_params->ch[0].col - 9; + tmp -= (sdram_params->ch[0].bw == 2) ? 0 : 1; + tmp |= ((sdram_params->ch[0].cs0_row - 13) << 4); + size = sizeof(ddrconf_table)/sizeof(ddrconf_table[0]); + for (i = 0; i < size; i++) + if (tmp == ddrconf_table[i]) + break; + if (i >= size) { + printf("niu config not found\n"); + ret = -EINVAL; + } else { + printf("niu config %d\n", i); + sdram_params->base.ddrconfig = i; + } + + return ret; +} + +static int sdram_init(struct dram_info *dram, + struct rk3188_sdram_params *sdram_params) +{ + int channel; + int zqcr; + int ret; + + printf("%s start 001\n", __func__); + if ((sdram_params->base.dramtype == DDR3 && + sdram_params->base.ddr_freq > 800000000)) { + printf("SDRAM frequency is too high!"); + return -E2BIG; + } + + ret = clk_set_rate(&dram->ddr_clk, sdram_params->base.ddr_freq); + printf("ret=%d\n", ret); + if (ret) { + printf("Could not set DDR clock\n"); + return ret; + } + + for (channel = 0; channel < 1; channel++) { + const struct chan_info *chan = &dram->chan[channel]; + struct rk3288_ddr_pctl *pctl = chan->pctl; + struct rk3288_ddr_publ *publ = chan->publ; + + phy_pctrl_reset(dram->cru, publ, channel); + phy_dll_bypass_set(publ, sdram_params->base.ddr_freq); + + dfi_cfg(pctl, sdram_params->base.dramtype); + + pctl_cfg(channel, pctl, sdram_params, dram->grf); + + phy_cfg(chan, channel, sdram_params); + + phy_init(publ); + + writel(POWER_UP_START, &pctl->powctl); + while (!(readl(&pctl->powstat) & POWER_UP_DONE)) + ; + + memory_init(publ, sdram_params->base.dramtype); + move_to_config_state(publ, pctl); + + /* Using 32bit bus width for detect */ + sdram_params->ch[channel].bw = 2; + set_bandwidth_ratio(chan, channel, + sdram_params->ch[channel].bw, dram->grf); + /* + * set cs, using n=3 for detect + * CS0, n=1 + * CS1, n=2 + * CS0 & CS1, n = 3 + */ + sdram_params->ch[channel].rank = 2, + clrsetbits_le32(&publ->pgcr, 0xF << 18, + (sdram_params->ch[channel].rank | 1) << 18); + + /* DS=40ohm,ODT=155ohm */ + zqcr = 1 << ZDEN_SHIFT | 2 << PU_ONDIE_SHIFT | + 2 << PD_ONDIE_SHIFT | 0x19 << PU_OUTPUT_SHIFT | + 0x19 << PD_OUTPUT_SHIFT; + writel(zqcr, &publ->zq1cr[0]); + writel(zqcr, &publ->zq0cr[0]); + + /* Detect the rank and bit-width with data-training */ + writel(1, &chan->msch->ddrconf); + sdram_rank_bw_detect(dram, channel, sdram_params); + + if (sdram_params->base.dramtype == LPDDR3) { + u32 i; + writel(0, &pctl->mrrcfg0); + for (i = 0; i < 17; i++) + send_command_op(pctl, 1, MRR_CMD, i, 0); + } + writel(4, &chan->msch->ddrconf); + move_to_access_state(chan); + /* DDR3 and LPDDR3 are always 8 bank, no need detect */ + sdram_params->ch[channel].bk = 3; + /* Detect Col and Row number*/ + ret = sdram_col_row_detect(dram, channel, sdram_params); + if (ret) + goto error; + } + /* Find NIU DDR configuration */ + ret = sdram_get_niu_config(sdram_params); + if (ret) + goto error; + + dram_all_config(dram, sdram_params); + printf("%s done\n", __func__); + + return 0; +error: + printf("DRAM init failed!\n"); + hang(); +} +#endif /* CONFIG_SPL_BUILD */ + +size_t sdram_size_mb(struct rk3188_pmu *pmu) +{ + u32 rank, col, bk, cs0_row, cs1_row, bw, row_3_4; + size_t chipsize_mb = 0; + size_t size_mb = 0; + u32 ch; + u32 sys_reg = readl(&pmu->sys_reg[2]); + u32 chans; + + chans = 1 + ((sys_reg >> SYS_REG_NUM_CH_SHIFT) & SYS_REG_NUM_CH_MASK); + + for (ch = 0; ch < chans; ch++) { + rank = 1 + (sys_reg >> SYS_REG_RANK_SHIFT(ch) & + SYS_REG_RANK_MASK); + col = 9 + (sys_reg >> SYS_REG_COL_SHIFT(ch) & SYS_REG_COL_MASK); + bk = 3 - ((sys_reg >> SYS_REG_BK_SHIFT(ch)) & SYS_REG_BK_MASK); + cs0_row = 13 + (sys_reg >> SYS_REG_CS0_ROW_SHIFT(ch) & + SYS_REG_CS0_ROW_MASK); + cs1_row = 13 + (sys_reg >> SYS_REG_CS1_ROW_SHIFT(ch) & + SYS_REG_CS1_ROW_MASK); + bw = (2 >> ((sys_reg >> SYS_REG_BW_SHIFT(ch)) & + SYS_REG_BW_MASK)); + row_3_4 = sys_reg >> SYS_REG_ROW_3_4_SHIFT(ch) & + SYS_REG_ROW_3_4_MASK; + chipsize_mb = (1 << (cs0_row + col + bk + bw - 20)); + + if (rank > 1) + chipsize_mb += chipsize_mb >> + (cs0_row - cs1_row); + if (row_3_4) + chipsize_mb = chipsize_mb * 3 / 4; + size_mb += chipsize_mb; + } + + /* there can be no more than 2gb of memory */ + size_mb = min(size_mb, 0x80000000 >> 20); + + return size_mb; +} + +#ifdef CONFIG_SPL_BUILD +static int setup_sdram(struct udevice *dev) +{ + struct dram_info *priv = dev_get_priv(dev); + struct rk3188_sdram_params *params = dev_get_platdata(dev); + + return sdram_init(priv, params); +} + +static int rk3188_dmc_ofdata_to_platdata(struct udevice *dev) +{ +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + struct rk3188_sdram_params *params = dev_get_platdata(dev); + const void *blob = gd->fdt_blob; + int node = dev->of_offset; + int ret; + + /* rk3188 supports only one-channel */ + params->num_channels = 1; + ret = fdtdec_get_int_array(blob, node, "rockchip,pctl-timing", + (u32 *)¶ms->pctl_timing, + sizeof(params->pctl_timing) / sizeof(u32)); + if (ret) { + printf("%s: Cannot read rockchip,pctl-timing\n", __func__); + return -EINVAL; + } + ret = fdtdec_get_int_array(blob, node, "rockchip,phy-timing", + (u32 *)¶ms->phy_timing, + sizeof(params->phy_timing) / sizeof(u32)); + if (ret) { + printf("%s: Cannot read rockchip,phy-timing\n", __func__); + return -EINVAL; + } + ret = fdtdec_get_int_array(blob, node, "rockchip,sdram-params", + (u32 *)¶ms->base, + sizeof(params->base) / sizeof(u32)); + if (ret) { + printf("%s: Cannot read rockchip,sdram-params\n", __func__); + return -EINVAL; + } + ret = regmap_init_mem(dev, ¶ms->map); + if (ret) + return ret; +#endif + + return 0; +} +#endif /* CONFIG_SPL_BUILD */ + +#if CONFIG_IS_ENABLED(OF_PLATDATA) +static int conv_of_platdata(struct udevice *dev) +{ + struct rk3188_sdram_params *plat = dev_get_platdata(dev); + struct dtd_rockchip_rk3188_dmc *of_plat = &plat->of_plat; + int ret; + + memcpy(&plat->pctl_timing, of_plat->rockchip_pctl_timing, + sizeof(plat->pctl_timing)); + memcpy(&plat->phy_timing, of_plat->rockchip_phy_timing, + sizeof(plat->phy_timing)); + memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base)); + /* rk3188 supports dual-channel, set default channel num to 2 */ + plat->num_channels = 1; + ret = regmap_init_mem_platdata(dev, of_plat->reg, + ARRAY_SIZE(of_plat->reg) / 2, + &plat->map); + if (ret) + return ret; + + return 0; +} +#endif + +static int rk3188_dmc_probe(struct udevice *dev) +{ +#ifdef CONFIG_SPL_BUILD + struct rk3188_sdram_params *plat = dev_get_platdata(dev); +#endif + struct dram_info *priv = dev_get_priv(dev); + struct regmap *map; + int ret; + struct udevice *dev_clk; + +#if CONFIG_IS_ENABLED(OF_PLATDATA) + ret = conv_of_platdata(dev); + if (ret) + return ret; +#endif + map = syscon_get_regmap_by_driver_data(ROCKCHIP_SYSCON_NOC); + if (IS_ERR(map)) + return PTR_ERR(map); + priv->chan[0].msch = regmap_get_range(map, 0); + + priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + priv->pmu = syscon_get_first_range(ROCKCHIP_SYSCON_PMU); + +#ifdef CONFIG_SPL_BUILD + priv->chan[0].pctl = regmap_get_range(plat->map, 0); + priv->chan[0].publ = regmap_get_range(plat->map, 1); +#endif + + ret = rockchip_get_clk(&dev_clk); + if (ret) + return ret; + priv->ddr_clk.id = CLK_DDR; + ret = clk_request(dev_clk, &priv->ddr_clk); + if (ret) + return ret; + + priv->cru = rockchip_get_cru(); + if (IS_ERR(priv->cru)) + return PTR_ERR(priv->cru); +#ifdef CONFIG_SPL_BUILD + ret = setup_sdram(dev); + if (ret) + return ret; +#endif + priv->info.base = 0; + priv->info.size = sdram_size_mb(priv->pmu) << 20; + + return 0; +} + +static int rk3188_dmc_get_info(struct udevice *dev, struct ram_info *info) +{ + struct dram_info *priv = dev_get_priv(dev); + + *info = priv->info; + + return 0; +} + +static struct ram_ops rk3188_dmc_ops = { + .get_info = rk3188_dmc_get_info, +}; + +static const struct udevice_id rk3188_dmc_ids[] = { + { .compatible = "rockchip,rk3188-dmc" }, + { } +}; + +U_BOOT_DRIVER(dmc_rk3188) = { + .name = "rockchip_rk3188_dmc", + .id = UCLASS_RAM, + .of_match = rk3188_dmc_ids, + .ops = &rk3188_dmc_ops, +#ifdef CONFIG_SPL_BUILD + .ofdata_to_platdata = rk3188_dmc_ofdata_to_platdata, +#endif + .probe = rk3188_dmc_probe, + .priv_auto_alloc_size = sizeof(struct dram_info), +#ifdef CONFIG_SPL_BUILD + .platdata_auto_alloc_size = sizeof(struct rk3188_sdram_params), +#endif +};
Hi Heiko,
Nits below.
- (C) Copyright 2015 Google, Inc
- SPDX-License-Identifier: GPL-2.0
u32 coreid;
u32 revisionid;
u32 ddrconf;
u32 ddrtiming;
u32 ddrmode;
u32 readlatency;
Can you comment this struct? What is it for?
- Copyright 2014 Rockchip Inc.
- Adapted from coreboot.
Does coreboot support the rk3188?
+struct chan_info {
+struct dram_info {
struct clk ddr_clk;
int num_channels;
struct regmap *map;
Seems like this should go in a common file as there are several users - rk_copy_to_reg() ?
int i;
writel(*src, dest);
src++;
dest++;
u32 channel)
int i;
udelay(1);
udelay(10);
udelay(10);
udelay(10);
udelay(10);
u32 freq)
int i;
blank line here
Do you have a comment for this logic, and why it is how it is?
else
DXDLLCR_DLLDIS);
} else {
DXDLLCR_DLLDIS);
&pctl->dfistcfg1);
&pctl->dfilpcfg0);
&pctl->dfiodtcfg);
uint val = 0;
if (enable)
bool ddr3_mode)
uint mask, val;
Can this go at the top of the file?
uint mask, val;
case DDR3:
} else {
&pctl->mcfg);
break;
u32 dinit2;
int i;
&publ->ptr[1]);
&publ->ptr[2]);
case DDR3:
break;
} else {
udelay(1);
u32 cmd, u32 arg)
udelay(1);
u32 dramtype)
udelay(1);
unsigned int state;
while (1) {
switch (state) {
case LOW_POWER:
!= ACCESS)
/* wait DLL lock */
!= PGSR_DLDONE)
Check multi-line comment style:
/* * If at low-power state ... * ... */
* fallthrough
case ACCESS:
/* fallthrough */
case INIT_MEM:
break;
case CONFIG:
return;
default:
break;
if (n == 1) {
/* disable DLL */
} else {
/* enable DLL */
/* reset DLL */
udelay(10);
Function comment? What does it return? channel could just be int, right?
unsigned int j;
int ret = 0;
u32 rank;
int i;
/* trigger DTT */
PIR_CLRSR);
udelay(1);
!= rank)
!= rank)
& rank) != rank)
& rank) != rank)
ret = -1;
break;
return ret;
unsigned int state;
while (1) {
switch (state) {
case LOW_POWER:
LP_TRIG_MASK) == 1)
return;
/* wait DLL lock */
!= PGSR_DLDONE)
break;
case INIT_MEM:
/* fallthrough */
case CONFIG:
break;
case ACCESS:
return;
default:
break;
1 << PDQ_SHIFT);
else
unsigned int chan;
u32 sys_reg = 0;
else
blank line
* [5:4] row(13+n)
* row col,bw */
0,
((2 << 4) | 1),
((1 << 4) | 1),
((0 << 4) | 1),
((2 << 4) | 2),
((1 << 4) | 2),
((0 << 4) | 2),
((1 << 4) | 0),
((0 << 4) | 0),
0,
0,
0,
0,
0,
0,
0,
Can this go at the top of the file? What are the <<4 for ? Can we have a #define?
int reg;
Can you check for <0 rather than == -1? That is the normal error check.
return -EIO;
funny indent here
need_trainig = 1;
dram->grf);
need_trainig = 1;
if (need_trainig &&
same as above
udelay(10);
udelay(10);
return -EIO;
Function comment
int row, col;
unsigned int addr;
int ret = 0;
/* Detect col */
break;
if (col == 8) {
ret = -EINVAL;
goto out;
} else {
break;
if (row == 12) {
ret = -EINVAL;
} else {
+out:
return ret;
break;
if (i >= size) {
ret = -EINVAL;
} else {
return ret;
int channel;
int zqcr;
int ret;
debug()
return -E2BIG;
debug()
if (ret) {
return ret;
phy_init(publ);
* CS0, n=1
* CS1, n=2
* CS0 & CS1, n = 3
u32 i;
if (ret)
goto error;
if (ret)
goto error;
+error:
hang();
size_t size_mb = 0;
u32 ch;
u32 chans;
SYS_REG_RANK_MASK);
SYS_REG_BW_MASK));
if (rank > 1)
if (row_3_4)
return size_mb;
int ret;
if (ret) {
return -EINVAL;
if (ret) {
return -EINVAL;
(u32 *)¶ms->base,
if (ret) {
return -EINVAL;
if (ret)
return ret;
int ret;
&plat->map);
if (ret)
return ret;
+} +#endif
struct regmap *map;
int ret;
if (ret)
return ret;
if (IS_ERR(map))
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
*info = priv->info;
.id = UCLASS_RAM,
2.11.0
Hi Simon,
Am Montag, 6. Februar 2017, 07:35:23 CET schrieb Simon Glass:
Nits below.
u32 coreid;
u32 revisionid;
u32 ddrconf;
u32 ddrtiming;
u32 ddrmode;
u32 readlatency;
Added a comment that this the memory scheduler register map, but that is all I can say for it, as it is sparsely documented in the chip manuals.
Right now we don't have a common file with shared code and as that function is specific to the SPL build I'm not sure if it wouldn't cause issues if we have a big bunch of common code that gets included in all SPLs.
Looking at my compilation result, it looks like the compiler inlined the function anyway, so maybe just define it as inline in the hardware.h ?
int i;
writel(*src, dest);
src++;
dest++;
u32 freq)
int i;
blank line here
Not really ... the memory controllers of the rk3066,rk3188 are very much similar to the rk3288, so this simply mirrors your own sdram code from rk3288 ;-) .
Speaking of duplicate code, you might already realize that this sdram driver is very much similar to the rk3288. My current plan is to submit the rk3188 separately at first and after everything lands try to make the common code shared.
rk3066, rk3188 and rk3288 all use a dw-upctl + dw-publ + phy, with some minimal differences, while the rk3036 uses a dw-upctl with a different phy block, so it might get a bit tricky on where to share and how to name stuff.
Also another developer seems to be working on rk3066 uboot support already, so it might be interesting to see if this will also require additional adaptations.
else
DXDLLCR_DLLDIS);
} else {
DXDLLCR_DLLDIS);
bool ddr3_mode)
uint mask, val;
actually already contained in the grf header, so can be simply used from there
uint mask, val;
I'm not particular insighted on what this code actually does, except what the function name implies ;-) ... but I did swap the channel to int.
unsigned int j;
int ret = 0;
u32 rank;
int i;
/* trigger DTT */
udelay(1);
!= rank)
!= rank)
& rank) != rank)
& rank) != rank)
ret = -1;
break;
return ret;
* [5:4] row(13+n)
* row col,bw */
0,
((2 << 4) | 1),
((1 << 4) | 1),
((0 << 4) | 1),
((2 << 4) | 2),
((1 << 4) | 2),
((0 << 4) | 2),
((1 << 4) | 0),
((0 << 4) | 0),
0,
0,
0,
0,
0,
0,
0,
Having that shift as define might get difficult. As you can see this is the value that gets written into the ddrconf register of the memory scheduler and the contents of this registers aren't documented in any TRM (rk3288, rk3188, rk3066).
So I'd like to refrain from introducting possible wrong defines right now :-) .
Heiko
Hi Heiko,
On 17 February 2017 at 13:39, Heiko Stuebner heiko@sntech.de wrote:
Hi Simon,
Nits below.
u32 coreid;
u32 revisionid;
u32 ddrconf;
u32 ddrtiming;
u32 ddrmode;
u32 readlatency;
I'd rather not do that - how about cleaning it up in a separate patch later.
int i;
writel(*src, dest);
src++;
dest++;
u32 freq)
int i;
blank line here
OK
else
DXDLLCR_DLLDIS);
} else {
DXDLLCR_DLLDIS);
bool ddr3_mode)
uint mask, val;
uint mask, val;
unsigned int j;
int ret = 0;
u32 rank;
int i;
/* trigger DTT */
udelay(1);
!= rank)
!= rank)
& rank) != rank)
& rank) != rank)
ret = -1;
break;
return ret;
* [5:4] row(13+n)
* row col,bw */
0,
((2 << 4) | 1),
((1 << 4) | 1),
((0 << 4) | 1),
((2 << 4) | 2),
((1 << 4) | 2),
((0 << 4) | 2),
((1 << 4) | 0),
((0 << 4) | 0),
0,
0,
0,
0,
0,
0,
0,
OK. The memory init code is a pain point for many SoCs, let's just do our best and hopefully docs and meaning can improve with time.
The rk3188 needs 3 uboot stages: a tpl living in 1KB of sram, a spl the resides in the rest of the sram and loads the regular uboot living in regular ram.
Signed-off-by: Heiko Stuebner heiko@sntech.de --- arch/arm/mach-rockchip/Makefile | 7 +- arch/arm/mach-rockchip/rk3188-board-spl.c | 220 ++++++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk3188-board-tpl.c | 87 ++++++++++++ arch/arm/mach-rockchip/rk3188-board.c | 71 ++++++++++ 4 files changed, 384 insertions(+), 1 deletion(-) create mode 100644 arch/arm/mach-rockchip/rk3188-board-spl.c create mode 100644 arch/arm/mach-rockchip/rk3188-board-tpl.c create mode 100644 arch/arm/mach-rockchip/rk3188-board.c
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 2be7e14e3e..7b8abc2266 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -4,11 +4,16 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_TPL_BUILD +obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board-tpl.o +obj-$(CONFIG_ROCKCHIP_BROM_HELPER) += save_boot_param.o +else ifdef CONFIG_SPL_BUILD obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o +obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board-spl.o obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board-spl.o obj-$(CONFIG_ROCKCHIP_BROM_HELPER) += save_boot_param.o else +obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board.o obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board.o obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board.o endif diff --git a/arch/arm/mach-rockchip/rk3188-board-spl.c b/arch/arm/mach-rockchip/rk3188-board-spl.c new file mode 100644 index 0000000000..b528a2f73d --- /dev/null +++ b/arch/arm/mach-rockchip/rk3188-board-spl.c @@ -0,0 +1,220 @@ +/* + * (C) Copyright 2015 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <fdtdec.h> +#include <led.h> +#include <malloc.h> +#include <ram.h> +#include <spl.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/hardware.h> +#include <asm/arch/periph.h> +#include <asm/arch/pmu_rk3188.h> +#include <asm/arch/sdram.h> +#include <asm/arch/timer.h> +#include <dm/pinctrl.h> +#include <dm/root.h> +#include <dm/test.h> +#include <dm/util.h> +#include <power/regulator.h> +#include <syscon.h> + +DECLARE_GLOBAL_DATA_PTR; + +u32 spl_boot_device(void) +{ +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + const void *blob = gd->fdt_blob; + struct udevice *dev; + const char *bootdev; + int node; + int ret; + + bootdev = fdtdec_get_config_string(blob, "u-boot,boot0"); + debug("Boot device %s\n", bootdev); + if (!bootdev) + goto fallback; + + node = fdt_path_offset(blob, bootdev); + if (node < 0) { + debug("node=%d\n", node); + goto fallback; + } + ret = device_get_global_by_of_offset(node, &dev); + if (ret) { + debug("device at node %s/%d not found: %d\n", bootdev, node, + ret); + goto fallback; + } + debug("Found device %s\n", dev->name); + switch (device_get_uclass_id(dev)) { + case UCLASS_SPI_FLASH: + return BOOT_DEVICE_SPI; + case UCLASS_MMC: + return BOOT_DEVICE_MMC1; + default: + debug("Booting from device uclass '%s' not supported\n", + dev_get_uclass_name(dev)); + } + +fallback: +#endif + return BOOT_DEVICE_MMC1; +} + +u32 spl_boot_mode(const u32 boot_device) +{ + return MMCSD_MODE_RAW; +} + +extern u32 SAVE_SP_ADDR; +extern void back_to_bootrom(void); +void board_init_f(ulong dummy) +{ + struct udevice *pinctrl, *dev; + struct rk3188_pmu *pmu; + int ret; + +#define EARLY_UART + /* Example code showing how to enable the debug UART on RK3188 */ +#ifdef EARLY_UART +#include <asm/arch/grf_rk3188.h> + /* Enable early UART on the RK3188 */ +#define GRF_BASE 0x20008000 + struct rk3188_grf * const grf = (void *)GRF_BASE; + + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B1_MASK << GPIO1B1_SHIFT | + GPIO1B0_MASK << GPIO1B0_SHIFT, + GPIO1B1_UART2_SOUT << GPIO1B1_SHIFT | + GPIO1B0_UART2_SIN << GPIO1B0_SHIFT); + /* + * Debug UART can be used from here if required: + * + * debug_uart_init(); + * printch('a'); + * printhex8(0x1234); + * printascii("string"); + */ + debug_uart_init(); + printch('s'); + printch('p'); + printch('l'); + printch('\n'); +#endif + + ret = spl_init(); + if (ret) { + debug("spl_init() failed: %d\n", ret); + hang(); + } + + rockchip_timer_init(); + + ret = rockchip_get_clk(&dev); + if (ret) { + debug("CLK init failed: %d\n", ret); + return; + } + + /* + * Recover the bootrom's stackpointer. + * For whatever reason needs to run after rockchip_get_clk. + */ + pmu = syscon_get_first_range(ROCKCHIP_SYSCON_PMU); + if (IS_ERR(pmu)) + error("pmu syscon returned %ld\n", PTR_ERR(pmu)); + SAVE_SP_ADDR = readl(&pmu->sys_reg[2]); + + ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); + if (ret) { + debug("Pinctrl init failed: %d\n", ret); + return; + } + + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + debug("DRAM init failed: %d\n", ret); + return; + } + +#if defined(CONFIG_ROCKCHIP_SPL_BACK_TO_BROM) && !defined(CONFIG_SPL_BOARD_INIT) + back_to_bootrom(); +#endif +} + +static int setup_led(void) +{ +#ifdef CONFIG_SPL_LED + struct udevice *dev; + char *led_name; + int ret; + + led_name = fdtdec_get_config_string(gd->fdt_blob, "u-boot,boot-led"); + if (!led_name) + return 0; + ret = led_get_by_label(led_name, &dev); + if (ret) { + debug("%s: get=%d\n", __func__, ret); + return ret; + } + ret = led_set_on(dev, 1); + if (ret) + return ret; +#endif + + return 0; +} + +void spl_board_init(void) +{ + struct udevice *pinctrl; + int ret; + + ret = setup_led(); + if (ret) { + debug("LED ret=%d\n", ret); + hang(); + } + + ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); + if (ret) { + debug("%s: Cannot find pinctrl device\n", __func__); + goto err; + } + +#ifdef CONFIG_SPL_MMC_SUPPORT + ret = pinctrl_request_noflags(pinctrl, PERIPH_ID_SDCARD); + if (ret) { + debug("%s: Failed to set up SD card\n", __func__); + goto err; + } +#endif + + /* Enable debug UART */ + ret = pinctrl_request_noflags(pinctrl, PERIPH_ID_UART_DBG); + if (ret) { + debug("%s: Failed to set up console UART\n", __func__); + goto err; + } + + preloader_console_init(); +#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM + back_to_bootrom(); +#endif + return; + +err: + printf("spl_board_init: Error %d\n", ret); + + /* No way to report error here */ + hang(); +} diff --git a/arch/arm/mach-rockchip/rk3188-board-tpl.c b/arch/arm/mach-rockchip/rk3188-board-tpl.c new file mode 100644 index 0000000000..62cdb8976a --- /dev/null +++ b/arch/arm/mach-rockchip/rk3188-board-tpl.c @@ -0,0 +1,87 @@ +/* + * (C) Copyright 2015 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <debug_uart.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/arch/pmu_rk3188.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* track how often we were entered */ +static int rk3188_num_entries; +extern void back_to_bootrom(void); + +#define PMU_BASE 0x20004000 +#define TPL_ENTRY 0x10080C00 +extern u32 SAVE_SP_ADDR; +static void jump_to_tpl(void) +{ + typedef void __noreturn (*image_entry_noargs_t)(void); + + struct rk3188_pmu * const pmu = (void *)PMU_BASE; + image_entry_noargs_t tpl_entry = + (image_entry_noargs_t)(unsigned long)TPL_ENTRY; + + /* Store the SAVE_SP_ADDR in a location shared with TPL. */ + writel(SAVE_SP_ADDR, &pmu->sys_reg[2]); + tpl_entry(); +} + +void board_init_f(ulong dummy) +{ +#define EARLY_UART + /* Example code showing how to enable the debug UART on RK3188 */ +#ifdef EARLY_UART +#include <asm/arch/grf_rk3188.h> + /* Enable early UART on the RK3188 */ +#define GRF_BASE 0x20008000 + struct rk3188_grf * const grf = (void *)GRF_BASE; + + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B1_MASK << GPIO1B1_SHIFT | + GPIO1B0_MASK << GPIO1B0_SHIFT, + GPIO1B1_UART2_SOUT << GPIO1B1_SHIFT | + GPIO1B0_UART2_SIN << GPIO1B0_SHIFT); + /* + * Debug UART can be used from here if required: + * + * debug_uart_init(); + * printch('a'); + * printhex8(0x1234); + * printascii("string"); + */ + debug_uart_init(); + + printch('t'); + printch('p'); + printch('l'); + printch('-'); + printch(rk3188_num_entries + 1 + '0'); + printch('\n'); +#endif + + rk3188_num_entries++; + + if (rk3188_num_entries == 1) { + /* + * The original loader did some very basic integrity + * checking at this point, but the remaining few bytes + * could be used for any improvement making sense + * really early on. + */ + + back_to_bootrom(); + } else { + /* + * TPL part of the loader should now wait for us + * at offset 0xC00 in the sram. Should never return + * from there. + */ + jump_to_tpl(); + } +} diff --git a/arch/arm/mach-rockchip/rk3188-board.c b/arch/arm/mach-rockchip/rk3188-board.c new file mode 100644 index 0000000000..16f38559af --- /dev/null +++ b/arch/arm/mach-rockchip/rk3188-board.c @@ -0,0 +1,71 @@ +/* + * (C) Copyright 2015 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <ram.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/periph.h> +#include <asm/arch/pmu_rk3288.h> +#include <asm/arch/boot_mode.h> +#include <asm/gpio.h> +#include <dm/pinctrl.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ +#if defined(CONFIG_ROCKCHIP_SPL_BACK_TO_BROM) + struct udevice *pinctrl; + int ret; + + /* + * We need to implement sdcard iomux here for the further + * initialization, otherwise, it'll hit sdcard command sending + * timeout exception. + */ + ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); + if (ret) { + debug("%s: Cannot find pinctrl device\n", __func__); + goto err; + } + ret = pinctrl_request_noflags(pinctrl, PERIPH_ID_SDCARD); + if (ret) { + debug("%s: Failed to set up SD card\n", __func__); + goto err; + } + + return 0; +err: + printf("board_init: Error %d\n", ret); + + /* No way to report error here */ + hang(); + + return -1; +#else + return 0; +#endif +} + +int dram_init(void) +{ + /* FIXME: read back ram size from sys_reg2 */ + gd->ram_size = 0x40000000; + + return 0; +} + +#ifndef CONFIG_SYS_DCACHE_OFF +void enable_caches(void) +{ + /* Enable D-cache. I-cache is already enabled in start.S */ + dcache_enable(); +} +#endif
Hi Heiko,
s/uboot/U-Boot/
There is a lot of common code here with rk3288 - can we unify it a bit, or is that not feasible?
int node;
int ret;
if (!bootdev)
goto fallback;
if (node < 0) {
goto fallback;
if (ret) {
ret);
goto fallback;
case UCLASS_MMC:
default:
+fallback: +#endif
int ret;
+#define EARLY_UART
* printch('a');
debug_uart_init();
printch('s');
printch('p');
printch('l');
printch('\n');
printascii("spl\n");
ret = spl_init();
if (ret) {
hang();
if (ret) {
return;
if (IS_ERR(pmu))
if (ret) {
return;
if (ret) {
return;
back_to_bootrom();
+#endif +}
char *led_name;
int ret;
if (!led_name)
if (ret) {
return ret;
if (ret)
return ret;
int ret;
ret = setup_led();
if (ret) {
hang();
if (ret) {
goto err;
if (ret) {
goto err;
if (ret) {
goto err;
back_to_bootrom();
return;
+err:
hang();
Is this in BSS? I suspect it might cause problems. Perhaps put it in the data section?
Should be in a header file somewhere
Blank line
tpl_entry();
* printch('a');
debug_uart_init();
printch('t');
printch('p');
printch('l');
printch('-');
printascii()
printch('\n');
* really early on.
back_to_bootrom();
} else {
* from there.
jump_to_tpl();
int ret;
if (ret) {
goto err;
if (ret) {
goto err;
+err:
hang();
return -1;
+#else
+#endif +}
TODO(email):
dcache_enable();
2.11.0
Am Montag, 6. Februar 2017, 07:35:25 CET schrieb Simon Glass:
Hi Heiko,
s/uboot/U-Boot/
not sure about that. In the end the amount of code is not that much - essentially the setup_led() and spl_board_init() could be unified a bit, but then spl_board_init() would probably require empty functions for not implemented stuff - configure_emmc on rk3188 for example.
So I'm not sure if this would help or just makes everything more complicated.
int node;
int ret;
if (!bootdev)
goto fallback;
if (node < 0) {
goto fallback;
if (ret) {
node, + ret);
goto fallback;
case UCLASS_MMC:
default:
+fallback: +#endif
int ret;
+#define EARLY_UART
* printch('a');
debug_uart_init();
printch('s');
printch('p');
printch('l');
printch('\n');
actually using printascii at this point make the board hang in the past. So far I haven't figured out why printch works but printascii does not.
I'll try again, maybe it magically fixed itself
ret = spl_init();
if (ret) {
hang();
if (ret) {
return;
if (IS_ERR(pmu))
if (ret) {
return;
if (ret) {
return;
char *led_name;
int ret;
if (ret) {
return ret;
if (ret)
return ret;
int ret;
ret = setup_led();
if (ret) {
hang();
if (ret) {
goto err;
if (ret) {
goto err;
if (ret) {
goto err;
back_to_bootrom();
return;
+err:
hang();
ok, I'll give that a try. So far I've never reached linker stuff, but judging from other uboot code a " __attribute__ ((section(".data")))" should be sufficient?
So far each board has declared this itself, but I've moved it to a header now for all of them.
I've also moved this to my new bootrom.h
Blank line
ok
tpl_entry();
* printch('a');
debug_uart_init();
printch('t');
printch('p');
printch('l');
printch('-');
printascii()
see spl printascii comment :-)
printch('\n');
* really early on.
back_to_bootrom();
} else {
* from there.
jump_to_tpl();
int ret;
if (ret) {
goto err;
if (ret) {
goto err;
+err:
hang();
return -1;
+#else
+#endif +}
TODO(email):
yep, I plan on doing this once the jump from spl to uboot actually works :-)
dcache_enable();
2.11.0
The Rock is a RK3188 based single board computer by Radxa. Currently it still relies on the proprietary DDR init and cannot use the generic SPL, but at least is able to boot a linux kernel and system up to a regular login prompt.
Signed-off-by: Heiko Stuebner heiko@sntech.de --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3188-radxarock.dts | 382 ++++++++++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk3188/Kconfig | 11 + board/radxa/rock/Kconfig | 15 ++ board/radxa/rock/MAINTAINERS | 6 + board/radxa/rock/Makefile | 7 + board/radxa/rock/rock.c | 7 + configs/rock_defconfig | 56 +++++ include/configs/rock.h | 30 +++ 9 files changed, 515 insertions(+) create mode 100644 arch/arm/dts/rk3188-radxarock.dts create mode 100644 board/radxa/rock/Kconfig create mode 100644 board/radxa/rock/MAINTAINERS create mode 100644 board/radxa/rock/Makefile create mode 100644 board/radxa/rock/rock.c create mode 100644 configs/rock_defconfig create mode 100644 include/configs/rock.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 3ee608b5b4..647285253e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -29,6 +29,7 @@ dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ dtb-$(CONFIG_EXYNOS7420) += exynos7420-espresso7420.dtb dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3036-sdk.dtb \ + rk3188-radxarock.dtb \ rk3288-firefly.dtb \ rk3288-veyron-jerry.dtb \ rk3288-veyron-mickey.dtb \ diff --git a/arch/arm/dts/rk3188-radxarock.dts b/arch/arm/dts/rk3188-radxarock.dts new file mode 100644 index 0000000000..5f5b5e9a1f --- /dev/null +++ b/arch/arm/dts/rk3188-radxarock.dts @@ -0,0 +1,382 @@ +/* + * Copyright (c) 2013 Heiko Stuebner heiko@sntech.de + * + * SPDX-License-Identifier: GPL-2.0+ or X11 + */ + +/dts-v1/; +#include <dt-bindings/input/input.h> +#include "rk3188.dtsi" + +/ { + model = "Radxa Rock"; + compatible = "radxa,rock", "rockchip,rk3188"; + + chosen { +/* stdout-path = &uart2; */ + stdout-path = "serial2:115200n8"; + }; + + config { + u-boot,dm-pre-reloc; + u-boot,boot-led = "rock:red:power"; + }; + + memory { + device_type = "memory"; + reg = <0x60000000 0x80000000>; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + + power { + gpios = <&gpio0 4 GPIO_ACTIVE_LOW>; + linux,code = <KEY_POWER>; + label = "GPIO Key Power"; + linux,input-type = <1>; + wakeup-source; + debounce-interval = <100>; + }; + }; + + gpio-leds { + compatible = "gpio-leds"; + + green { + label = "rock:green:user1"; + gpios = <&gpio0 12 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + blue { + label = "rock:blue:user2"; + gpios = <&gpio0 14 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + sleep { + label = "rock:red:power"; + gpios = <&gpio0 15 0>; + default-state = "off"; + }; + }; + + sound { + compatible = "simple-audio-card"; + simple-audio-card,name = "SPDIF"; + + simple-audio-card,dai-link@1 { /* S/PDIF - S/PDIF */ + cpu { sound-dai = <&spdif>; }; + codec { sound-dai = <&spdif_out>; }; + }; + }; + + spdif_out: spdif-out { + compatible = "linux,spdif-dit"; + #sound-dai-cells = <0>; + }; + + ir_recv: gpio-ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio0 10 1>; + pinctrl-names = "default"; + pinctrl-0 = <&ir_recv_pin>; + }; + + vcc_otg: usb-otg-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio2 31 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&otg_vbus_drv>; + regulator-name = "otg-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + vcc_sd0: sdmmc-regulator { + compatible = "regulator-fixed"; + regulator-name = "sdmmc-supply"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio3 1 GPIO_ACTIVE_LOW>; + startup-delay-us = <100000>; + vin-supply = <&vcc_io>; + }; + + vcc_host: usb-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&host_vbus_drv>; + regulator-name = "host-pwr"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + vsys: vsys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vsys"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + }; +}; + +&dmc { + rockchip,pctl-timing = <0x12c 0xc8 0x1f4 0x1e 0x4e 0x4 0x69 0x6 + 0x3 0x0 0x6 0x5 0xc 0x10 0x6 0x4 + 0x4 0x5 0x4 0x200 0x3 0xa 0x40 0x0 + 0x1 0x5 0x5 0x3 0xc 0x1e 0x100 0x0 + 0x4 0x0>; + rockchip,phy-timing = <0x208c6690 0x690878 0x10022a00 + 0x220 0x40 0x0 0x0>; + rockchip,sdram-params = <0x24716310 0 2 300000000 3 9 0>; +}; + +&emac { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&emac_xfer>, <&emac_mdio>, <&phy_int>; + + phy = <&phy0>; + phy-supply = <&vcc_rmii>; + + phy0: ethernet-phy@0 { + reg = <0>; + interrupt-parent = <&gpio3>; + interrupts = <26 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +&cpu0 { + cpu0-supply = <&vdd_arm>; +}; + +&i2c1 { + status = "okay"; + clock-frequency = <400000>; + + rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + interrupt-parent = <&gpio0>; + interrupts = <13 IRQ_TYPE_EDGE_FALLING>; + pinctrl-names = "default"; + pinctrl-0 = <&rtc_int>; + #clock-cells = <0>; + clock-output-names = "xin32k"; + }; + + act8846: act8846@5a { + compatible = "active-semi,act8846"; + reg = <0x5a>; + status = "okay"; + system-power-controller; + + pinctrl-names = "default"; + pinctrl-0 = <&act8846_dvs0_ctl>; + + vp1-supply = <&vsys>; + vp2-supply = <&vsys>; + vp3-supply = <&vsys>; + vp4-supply = <&vsys>; + inl1-supply = <&vcc_io>; + inl2-supply = <&vsys>; + inl3-supply = <&vsys>; + + regulators { + vcc_ddr: REG1 { + regulator-name = "VCC_DDR"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + }; + + vdd_log: REG2 { + regulator-name = "VDD_LOG"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + }; + + vdd_arm: REG3 { + regulator-name = "VDD_ARM"; + regulator-min-microvolt = <875000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + }; + + vcc_io: REG4 { + regulator-name = "VCC_IO"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vdd_10: REG5 { + regulator-name = "VDD_10"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + }; + + vdd_hdmi: REG6 { + regulator-name = "VDD_HDMI"; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-always-on; + }; + + vcc18: REG7 { + regulator-name = "VCC_18"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + vcca_33: REG8 { + regulator-name = "VCCA_33"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vcc_rmii: REG9 { + regulator-name = "VCC_RMII"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vccio_wl: REG10 { + regulator-name = "VCCIO_WL"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vcc_18: REG11 { + regulator-name = "VCC18_IO"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + vcc28: REG12 { + regulator-name = "VCC_28"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + }; + }; + }; +}; + +&mmc0 { + num-slots = <1>; + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&sd0_clk>, <&sd0_cmd>, <&sd0_cd>, <&sd0_bus4>; + vmmc-supply = <&vcc_sd0>; + + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + disable-wp; +}; + +&pwm1 { + status = "okay"; +}; + +&pwm2 { + status = "okay"; +}; + +&pwm3 { + status = "okay"; +}; + +&pinctrl { + pcfg_output_low: pcfg-output-low { + output-low; + }; + + act8846 { + act8846_dvs0_ctl: act8846-dvs0-ctl { + rockchip,pins = <RK_GPIO3 27 RK_FUNC_GPIO &pcfg_output_low>; + }; + }; + + hym8563 { + rtc_int: rtc-int { + rockchip,pins = <RK_GPIO0 0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + lan8720a { + phy_int: phy-int { + rockchip,pins = <RK_GPIO3 26 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + ir-receiver { + ir_recv_pin: ir-recv-pin { + rockchip,pins = <RK_GPIO0 10 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb { + host_vbus_drv: host-vbus-drv { + rockchip,pins = <0 3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + otg_vbus_drv: otg-vbus-drv { + rockchip,pins = <2 31 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&spdif { + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; + +&uart2 { + status = "okay"; + u-boot,dm-spl; +}; + +&uart3 { + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; + +&usb_host { + status = "okay"; +}; + +&usb_otg { + status = "okay"; +}; + +&wdt { + status = "okay"; +}; diff --git a/arch/arm/mach-rockchip/rk3188/Kconfig b/arch/arm/mach-rockchip/rk3188/Kconfig index f8e1d0316b..5afc23ad2f 100644 --- a/arch/arm/mach-rockchip/rk3188/Kconfig +++ b/arch/arm/mach-rockchip/rk3188/Kconfig @@ -1,5 +1,14 @@ if ROCKCHIP_RK3188
+config TARGET_ROCK + bool "Radxa Rock" + help + Rock is a RK3188-based development board with 2 USB and 1 otg + ports, HDMI, TV-out, micro-SD card, audio, WiFi and 100MBit + Ethernet, It also includes on-board nand and 1GB of SDRAM. + Expansion connectors provide access to display pins, I2C, SPI, + UART and GPIOs. + config SYS_SOC default "rockchip"
@@ -21,4 +30,6 @@ config TPL_LIBCOMMON_SUPPORT config TPL_SERIAL_SUPPORT default y
+source "board/radxa/rock/Kconfig" + endif diff --git a/board/radxa/rock/Kconfig b/board/radxa/rock/Kconfig new file mode 100644 index 0000000000..855b9b6954 --- /dev/null +++ b/board/radxa/rock/Kconfig @@ -0,0 +1,15 @@ +if TARGET_ROCK + +config SYS_BOARD + default "rock" + +config SYS_VENDOR + default "radxa" + +config SYS_CONFIG_NAME + default "rock" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/radxa/rock/MAINTAINERS b/board/radxa/rock/MAINTAINERS new file mode 100644 index 0000000000..c5f59c0a6f --- /dev/null +++ b/board/radxa/rock/MAINTAINERS @@ -0,0 +1,6 @@ +RADXA_ROCK +M: Heiko Stuebner heiko@sntech.de +S: Maintained +F: board/radxa/rock +F: include/configs/rock.h +F: configs/rock_defconfig diff --git a/board/radxa/rock/Makefile b/board/radxa/rock/Makefile new file mode 100644 index 0000000000..fe94b60c35 --- /dev/null +++ b/board/radxa/rock/Makefile @@ -0,0 +1,7 @@ +# +# (C) Copyright 2015 Heiko Stuebner +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += rock.o diff --git a/board/radxa/rock/rock.c b/board/radxa/rock/rock.c new file mode 100644 index 0000000000..5119e95455 --- /dev/null +++ b/board/radxa/rock/rock.c @@ -0,0 +1,7 @@ +/* + * (C) Copyright 2015 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> diff --git a/configs/rock_defconfig b/configs/rock_defconfig new file mode 100644 index 0000000000..2705909e6c --- /dev/null +++ b/configs/rock_defconfig @@ -0,0 +1,56 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ROCKCHIP_RK3188=y +CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y +CONFIG_TARGET_ROCK=y +CONFIG_SPL_STACK_R_ADDR=0x60080000 +CONFIG_DEFAULT_DEVICE_TREE="rk3188-radxarock" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_OF_PLATDATA=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +# CONFIG_SPL_SIMPLE_BUS is not set +# CONFIG_SPL_MMC_SUPPORT is not set +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_LED=y +CONFIG_SYSRESET=y +CONFIG_PINCTRL=y +# CONFIG_SPL_PINCTRL_FULL is not set +CONFIG_ROCKCHIP_RK3188_PINCTRL=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_RAM=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0x20064000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_NS16550=y +CONFIG_SYS_NS16550=y +CONFIG_CMD_DHRYSTONE=y +CONFIG_ERRNO_STR=y diff --git a/include/configs/rock.h b/include/configs/rock.h new file mode 100644 index 0000000000..de5291cd05 --- /dev/null +++ b/include/configs/rock.h @@ -0,0 +1,30 @@ +/* + * (C) Copyright 2015 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define ROCKCHIP_DEVICE_SETTINGS +#include <configs/rk3188_common.h> + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +/* SPL @ 32k for 34k + * u-boot directly after @ 68k for 400k or so + * ENV @ 992k + */ +#define CONFIG_ENV_OFFSET ((1024-32) * 1024) +#else +/* SPL @ 32k for ~36k + * ENV @ 96k + * u-boot @ 128K + */ +#define CONFIG_ENV_OFFSET (96 * 1024) +#endif + +#endif
Combines tpl, spl and uboot image in one flashable image. --- mkuboot | 35 +++++++++++++++++++++++++++++++++++ 1 file changed, 35 insertions(+) create mode 100755 mkuboot
diff --git a/mkuboot b/mkuboot new file mode 100755 index 0000000000..42109b2b87 --- /dev/null +++ b/mkuboot @@ -0,0 +1,35 @@ +#!/bin/bash + +LOCALPATH=$(pwd) +ROOTDIR=$(dirname $(dirname $(readlink -f $0))) +OUT=${ROOTDIR}/out +IMAGE=${ROOTDIR}/image +BOARD=$1 +DEFCONFIG="" + +if [ $# != 1 ] ; then +BOARD=rock +fi +OUTBIN=${BOARD}-uboot.bin + + +# copy tpl and pad to 1020 byte +cat tpl/u-boot-tpl.bin > tpl/u-boot-tplspl.bin +truncate -s 1020 tpl/u-boot-tplspl.bin + +#append spl and encode the result using mkimage +truncate -s %2048 spl/u-boot-spl.bin +cat spl/u-boot-spl.bin >> tpl/u-boot-tplspl.bin +tools/mkimage -n rk3188 -T rksd -d tpl/u-boot-tplspl.bin ${OUTBIN} + +######## +# Need to remove the RK31 from the FlashBoot binary to create FlashSpl +# This can be used instead of the open spl as first stage +#tools/mkimage -n rk3188 -T rksd -d FlashSpl ${OUTBIN} + +# bootrom reads and decodes 2kb blocks, so bring u-boot.bin in line +truncate -s %2048 u-boot.bin + +# rk3188 needs an rc4-encoded uboot as well +cat u-boot.bin | split -b 512 --filter='openssl rc4 -K 7C4E0304550509072D2C7B38170D1711' >> ${OUTBIN} +echo U-boot image:${OUTBIN}
Could use binman?
Hi Heiko,
On 3 February 2017 at 09:09, Heiko Stuebner heiko@sntech.de wrote:
this is meant as a status update and possible discussion for the core parts if needed.
After talking with Simon and Tom the order is now also correct with tpl -> spl -> uboot.
Status right now is:
- the full uboot still works
- the tpl/spl does start and is able to configure the ddr into a working state
- The jump spl -> bootrom -> uboot doesn't work though
On the other hand, Kever was able to make this work, booting from nand when building the image with a very ancient tool.
All newer tools (including boot_merger.c from Rockchip's uboot) do not produce working images. But it is possible to produce a working sd-boot image using the proprietary 1st-stage loader.
See the temporary mkuboot script in the last patch, which can create both types of images now (especially wrt. the needed rc4 encryption of everything).
Combining this (it does work using some special tool), it looks like there is still some minor glitch in the way we build the spl image somewhere.
What should we do with this series? There are a few minor things to resolve but other than that, do you think it is ready to apply?
The above problem could perhaps be resolved later if there is a suitable README describing it?
Hi Simon,
Am Donnerstag, 16. Februar 2017, 13:43:45 CET schrieb Simon Glass:
It's somehow always on the backburner, but I already started fixing the things you pointed out. Though I'll be in Portland, Mountain View and San Francisco for the next two weeks, so will only be able to resend the fixes after that.
Kever already found out, that the sd read the bootrom does fails when trying to load the uboot from the spl. I'm still trying to investigate this [same Portland remark applies], but if you're ok with stuff going in in this state, that is definitly fine by me, as it spares me from sending the full series all the time ;-)
Heiko
Am Freitag, 17. Februar 2017, 01:41:27 CET schrieb Heiko Stübner:
Hi Simon,
schedule update :-)
Kever is the hero of the day, as he found out what was causing the load failure (reset in sdram driver did actually reset the sdmmc controller). So now the real uboot does load finally from spl.
So with the technical issues solved, I'm hoping to just get the review commens finalized tomorrow on my flight over the atlantic and plane-wifi permitting may even resend from there ;-) .
Heiko
Hi Heiko,
For this patch series, I have test and works on my NAND based rodxa board.
For the sd-card, you will need one patch to fix the problem which I have send to you offline.
Tested-by: Kever Yang kever.yang@rock-chips.com
Heiko Stuebner (16): dm: allow limiting pre-reloc markings to spl or tpl rockchip: move bootrom helper compilation to a hidden option rockchip: mkimage: Allow encoding of loader code in spl images rockchip: mkimage: Add support rk3188 serial rockchip: serial: Adapt rockchip of-platdata driver for rk3188 rockchip: rk3188: Add header files for PMU and GRF rockchip: rk3188: Add pinctrl driver rockchip: rk3188: Add sysreset driver rockchip: rk3188: Add rk3066/rk3188 clock bindings rockchip: rk3188: Add clock driver rockchip: rk3188: Add core devicetree files rockchip: rk3188: Add core support rockchip: rk3188: Add sdram driver rockchip: rk3188: Add main, spl and tpl boards rockchip: rk3188: Add Radxa Rock board Add a temporary script that can create a bootimage for rk3188
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3188-radxarock.dts | 382 +++++++++ arch/arm/dts/rk3188.dtsi | 601 +++++++++++++++ arch/arm/dts/rk3xxx.dtsi | 417 ++++++++++ arch/arm/include/asm/arch-rockchip/cru_rk3188.h | 191 +++++ arch/arm/include/asm/arch-rockchip/ddr_rk3188.h | 22 + arch/arm/include/asm/arch-rockchip/grf_rk3188.h | 589 ++++++++++++++ arch/arm/include/asm/arch-rockchip/pmu_rk3188.h | 36 + arch/arm/mach-rockchip/Kconfig | 20 + arch/arm/mach-rockchip/Makefile | 14 +- arch/arm/mach-rockchip/rk3188-board-spl.c | 220 ++++++ arch/arm/mach-rockchip/rk3188-board-tpl.c | 87 +++ arch/arm/mach-rockchip/rk3188-board.c | 71 ++ arch/arm/mach-rockchip/rk3188/Kconfig | 35 + arch/arm/mach-rockchip/rk3188/Makefile | 11 + arch/arm/mach-rockchip/rk3188/clk_rk3188.c | 33 + arch/arm/mach-rockchip/rk3188/sdram_rk3188.c | 985 ++++++++++++++++++++++++ arch/arm/mach-rockchip/rk3188/syscon_rk3188.c | 55 ++ board/radxa/rock/Kconfig | 15 + board/radxa/rock/MAINTAINERS | 6 + board/radxa/rock/Makefile | 7 + board/radxa/rock/rock.c | 7 + configs/rock_defconfig | 56 ++ doc/driver-model/README.txt | 4 + drivers/clk/at91/pmc.c | 3 +- drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_rk3188.c | 523 +++++++++++++ drivers/core/root.c | 2 +- drivers/core/util.c | 29 + drivers/pinctrl/Kconfig | 9 + drivers/pinctrl/pinctrl-uclass.c | 3 +- drivers/pinctrl/rockchip/Makefile | 1 + drivers/pinctrl/rockchip/pinctrl_rk3188.c | 611 +++++++++++++++ drivers/serial/serial_rockchip.c | 19 +- drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_rk3188.c | 47 ++ include/configs/rk3188_common.h | 125 +++ include/configs/rock.h | 30 + include/dm/util.h | 2 + include/dt-bindings/clock/rk3066a-cru.h | 32 + include/dt-bindings/clock/rk3188-cru-common.h | 256 ++++++ include/dt-bindings/clock/rk3188-cru.h | 48 ++ mkuboot | 35 + scripts/Makefile.spl | 7 +- tools/dtoc/dtoc.py | 2 + tools/rkcommon.c | 34 +- tools/rkcommon.h | 22 + tools/rkimage.c | 3 + tools/rksd.c | 4 + tools/rkspi.c | 4 + 50 files changed, 5707 insertions(+), 11 deletions(-) create mode 100644 arch/arm/dts/rk3188-radxarock.dts create mode 100644 arch/arm/dts/rk3188.dtsi create mode 100644 arch/arm/dts/rk3xxx.dtsi create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rk3188.h create mode 100644 arch/arm/include/asm/arch-rockchip/ddr_rk3188.h create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rk3188.h create mode 100644 arch/arm/include/asm/arch-rockchip/pmu_rk3188.h create mode 100644 arch/arm/mach-rockchip/rk3188-board-spl.c create mode 100644 arch/arm/mach-rockchip/rk3188-board-tpl.c create mode 100644 arch/arm/mach-rockchip/rk3188-board.c create mode 100644 arch/arm/mach-rockchip/rk3188/Kconfig create mode 100644 arch/arm/mach-rockchip/rk3188/Makefile create mode 100644 arch/arm/mach-rockchip/rk3188/clk_rk3188.c create mode 100644 arch/arm/mach-rockchip/rk3188/sdram_rk3188.c create mode 100644 arch/arm/mach-rockchip/rk3188/syscon_rk3188.c create mode 100644 board/radxa/rock/Kconfig create mode 100644 board/radxa/rock/MAINTAINERS create mode 100644 board/radxa/rock/Makefile create mode 100644 board/radxa/rock/rock.c create mode 100644 configs/rock_defconfig create mode 100644 drivers/clk/rockchip/clk_rk3188.c create mode 100644 drivers/pinctrl/rockchip/pinctrl_rk3188.c create mode 100644 drivers/sysreset/sysreset_rk3188.c create mode 100644 include/configs/rk3188_common.h create mode 100644 include/configs/rock.h create mode 100644 include/dt-bindings/clock/rk3066a-cru.h create mode 100644 include/dt-bindings/clock/rk3188-cru-common.h create mode 100644 include/dt-bindings/clock/rk3188-cru.h create mode 100755 mkuboot
Heiko Stuebner
Heiko Stübner
Kever Yang
