[U-Boot] [PATCH] Link the correct libgcc.a on ARMv4T architecture
If we use $(CC -print-libgcc-file-name) without option -march=armv4t, we will link the wrong version libgcc.a(for ARMv5). That causes cpu core raising excptions when u-boot running on the board.
Signed-off-by:Paul Hsu pochun.hsu@gmail.com --- Makefile | 15 +++++++++++++++ 1 files changed, 15 insertions(+), 0 deletions(-)
diff --git a/Makefile b/Makefile index 4f1cb1b..978c9cd 100644 --- a/Makefile +++ b/Makefile @@ -259,6 +259,17 @@ LIBS := $(addprefix $(obj),$(LIBS)) LIBBOARD = board/$(BOARDDIR)/lib$(BOARD).a LIBBOARD := $(addprefix $(obj),$(LIBBOARD))
+#check ARMV4T +ifdef CPU +ifeq ("$(CPU)","arm920t") +ARMV4T := yes +endif +ifeq ("$(CPU)","arm720t") +ARMV4T := yes +endif +endif + + # Add GCC lib ifdef USE_PRIVATE_LIBGCC ifeq ("$(USE_PRIVATE_LIBGCC)", "yes") @@ -267,8 +278,12 @@ else PLATFORM_LIBGCC = -L $(USE_PRIVATE_LIBGCC) -lgcc endif else +ifeq ("$(ARMV4T)","yes") +PLATFORM_LIBGCC = -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name -march=armv4t`) -lgcc +else PLATFORM_LIBGCC = -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc endif +endif PLATFORM_LIBS += $(PLATFORM_LIBGCC) export PLATFORM_LIBS
Dear Paul Hsu,
On which tool chain is this causing problems?
And how does this problem manifest?
NAK. If really needed, this needs to be fixed in ARM specific config files / Makefiles, not in the top level Makefile.
On Wed, Sep 8, 2010 at 4:16 PM, Wolfgang Denk wd@denx.de wrote:
Dear Paul Hsu,
I use toolchain released by code sourcery(Sourcery G++ Lite 2010q1-202 for ARM GNU/Linux).
$ /opt/arm-2010q1/bin/arm-none-linux-gnueabi-gcc -print-libgcc-file-name -march=armv4t /opt/arm-2010q1/bin/../lib/gcc/arm-none-linux-gnueabi/4.4.1/armv4t/libgcc.a This libgcc.a is a correct one we need on ARMv4T.
If you use the same command wihtout -march=armv4t $ /opt/arm-2010q1/bin/arm-none-linux-gnueabi-gcc -print-libgcc-file-name /opt/arm-2010q1/bin/../lib/gcc/arm-none-linux-gnueabi/4.4.1/libgcc.a This is not the one we need.
I agree that we should find a better place to put ARM specific config in. But currently, top level Makefile is the one I found. Any suggestion?
BR, Paul
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de core error - bus dumped
Dear Paul Hsu,
In message AANLkTin=dbkiHNGHO2W+knxaC3mk9TFJacQD9d8BwTHf@mail.gmail.com you wrote:
Thanks for the information.
You did not answer this question. Do you bet build errors? Or does the build complete, but U-Boot does not work correctly?
arch/arm/config.mk ?
On Wed, Sep 8, 2010 at 5:05 PM, Wolfgang Denk wd@denx.de wrote:
Dear Paul Hsu,
Build process is complete, but U-Boot does not work correctly. Because of linking the wrong version libgcc.a, which contains armv5 instruction such that arm core raises a undefined instruction exception then code hanged.
I found another way to solve this issue.
In arch/arm/cpu/arm920t/config.mk, change this line from PLATFORM_CPPFLAGS += -march=armv4 to PLATFORM_CPPFLAGS += -march=armv4t
Then everything goes well. This solution won't make any modification on top level Makefile.
But I don't know exactly that the solution will incur other side effect or not?
BTW, If this solution is the right thing to do, shall I issue another patch?
BR, Paul
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de If some day we are defeated, well, war has its fortunes, good and bad. -- Commander Kor, "Errand of Mercy", stardate 3201.7
Paul Hsu
