[U-Boot] [PATCH v2] cmd_boot: Add a poweroff command
From: Michael van Slingerland michael@deviousops.nl
Add a 'poweroff' command to boot commands, this only gets enabled if the board Kconfig does a "select CMD_POWEROFF".
Signed-off-by: Michael van Slingerland michael@deviousops.nl [hdegoede@redhat.com: Make the cmd conditional on a CMD_POWEROFF Kconfig] Signed-off-by: Hans de Goede hdegoede@redhat.com --- Changes in v2: -Improve poweroff help text -Remove unnecessary #ifdef from command.h --- common/Kconfig | 3 +++ common/cmd_boot.c | 8 ++++++++ include/command.h | 1 + 3 files changed, 12 insertions(+)
diff --git a/common/Kconfig b/common/Kconfig index ccf5475..9d446bf 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -184,6 +184,9 @@ config CMD_XIMG help Extract a part of a multi-image.
+config CMD_POWEROFF + bool + endmenu
menu "Environment commands" diff --git a/common/cmd_boot.c b/common/cmd_boot.c index 8f2e070..72f2cf3 100644 --- a/common/cmd_boot.c +++ b/common/cmd_boot.c @@ -61,3 +61,11 @@ U_BOOT_CMD( "Perform RESET of the CPU", "" ); + +#ifdef CONFIG_CMD_POWEROFF +U_BOOT_CMD( + poweroff, 1, 0, do_poweroff, + "Perform POWEROFF of the device", + "" +); +#endif diff --git a/include/command.h b/include/command.h index 2ae9b6c..0524c0b 100644 --- a/include/command.h +++ b/include/command.h @@ -110,6 +110,7 @@ extern int common_diskboot(cmd_tbl_t *cmdtp, const char *intf, int argc, char *const argv[]);
extern int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); +extern int do_poweroff(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]);
/* * Error codes that commands return to cmd_process(). We use the standard 0
Dear Hans de Goede,
Do you plan to submit any code that will actually implement and use this feature?
As is, this is just dead code, and anybody who enables the option just runs into build errors.
As is:
NAK.
On 23-12-15 07:33, Wolfgang Denk wrote:
Dear Hans de Goede,
As is:
NAK.
<sigh> as you may have noticed this is a v2 of this patch, v1 was part of a set which did actually implement support for this and came with a coverletter explaining why this is a desirable feature.
Regards,
Hans
Hans de Goede
