U-Boot Bootmenu is broken on Nokia N900
Bootmenu on Nokia N900 is broken (on both HW and in qemu emulator). Bootmenu just prints garbage on the screen. I run git bisect and the result is:
72a0dd8bed010bef78028ae528763f9807758e6b is the first bad commit commit 72a0dd8bed010bef78028ae528763f9807758e6b Author: Simon Glass sjg@chromium.org Date: Fri Jan 6 08:52:29 2023 -0600
video: Enable VIDEO_ANSI by default only with EFI
This is not generally needed unless EFI_LOADER is used. Adjust the default setting to reduce the size of the U-Boot build.
Signed-off-by: Simon Glass sjg@chromium.org
:040000 040000 7da10731b9f552cd7ff26dabe3e4787bf2b80caa 18fa5c5d7f1f14aebaa1365b8f60217bbeffabb8 M drivers
Change was relatively simple:
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index f539977d9b73..440b161b8423 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -112,10 +112,13 @@ config VIDEO_BPP32
config VIDEO_ANSI bool "Support ANSI escape sequences in video console" - default y + default y if EFI_LOADER help Enable ANSI escape sequence decoding for a more fully functional - console. + console. Functionality includes changing the text colour and moving + the cursor. These date from the 1970s and are still widely used today + to control a text terminal. U-Boot implements these by decoding the + sequences and performing the appropriate operation.
config VIDEO_MIPI_DSI bool "Support MIPI DSI interface"
On master branch with CONFIG_VIDEO_ANSI=y is bootmenu rendering again.
CONFIG_VIDEO_ANSI needs to be by default enabled also when CONFIG_CMD_BOOTMENU is enabled (not only for EFI).
Simon, would you fix it?
Pali Rohár
