[U-Boot] [PATCH] vexpress64: use DM for all vexpress64 boards
Commit d8bafe1310487ba0e0785997726b4792072178d3 "ARMv8: enable DM in vexpress64 board" only enabled DM for the simulated vexpress64 board (FVP) with the hardcoded clock value for the simulated board, causing a console regression on the Juno board which was using a different clock setting.
Fix this by enabling DM for all vexpress64 boards, defining the clock frequency per-board, deleting the static array of PL01x ports from the config file and relying solely on the port defined in the boardfile using platform data.
Cc: David Feng fenghua@phytium.com.cn Signed-off-by: Linus Walleij linus.walleij@linaro.org --- board/armltd/vexpress64/vexpress64.c | 2 +- include/configs/vexpress_aemv8a.h | 20 ++++---------------- 2 files changed, 5 insertions(+), 17 deletions(-)
diff --git a/board/armltd/vexpress64/vexpress64.c b/board/armltd/vexpress64/vexpress64.c index 13dd6674363c..7cb4e0021f66 100644 --- a/board/armltd/vexpress64/vexpress64.c +++ b/board/armltd/vexpress64/vexpress64.c @@ -19,7 +19,7 @@ DECLARE_GLOBAL_DATA_PTR; static const struct pl01x_serial_platdata serial_platdata = { .base = V2M_UART0, .type = TYPE_PL011, - .clock = 2400 * 1000, + .clock = CONFIG_PL011_CLOCK, };
U_BOOT_DEVICE(vexpress_serials) = { diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index 3fda20a8f6c8..032010bb9e02 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -8,10 +8,9 @@ #ifndef __VEXPRESS_AEMV8A_H #define __VEXPRESS_AEMV8A_H
-#define CONFIG_DM - -/* We use generic board for v8 Versatile Express */ +/* We use generic board and device manager for v8 Versatile Express */ #define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_DM
#ifdef CONFIG_TARGET_VEXPRESS64_BASE_FVP #ifndef CONFIG_SEMIHOSTING @@ -134,27 +133,16 @@ #endif
/* PL011 Serial Configuration */ -#define CONFIG_BAUDRATE 115200 -#ifdef CONFIG_DM #define CONFIG_DM_SERIAL -#define CONFIG_PL01X_SERIAL -#else -#define CONFIG_SYS_SERIAL0 V2M_UART0 -#define CONFIG_SYS_SERIAL1 V2M_UART1 +#define CONFIG_BAUDRATE 115200 #define CONFIG_CONS_INDEX 0 +#define CONFIG_PL01X_SERIAL #define CONFIG_PL011_SERIAL #ifdef CONFIG_TARGET_VEXPRESS64_JUNO #define CONFIG_PL011_CLOCK 7273800 #else #define CONFIG_PL011_CLOCK 24000000 #endif -#define CONFIG_PL01x_PORTS {(void *)CONFIG_SYS_SERIAL0, \ - (void *)CONFIG_SYS_SERIAL1} -#endif - -#define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_SERIAL0 V2M_UART0 -#define CONFIG_SYS_SERIAL1 V2M_UART1
/* Command line configuration */ #define CONFIG_MENU
Linus Walleij
