Please pull u-boot-watchdog/master
Hi Tom,
please pull the following watchdog related fix:
---------------------------------------------------------------- - Correct watchdog timeout print message (Chanho Park) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=327&view=resu...
Thanks, Stefan
The following changes since commit 5c4e9d0c74a8c2f8d0f4e0ab9cf44959298c2bad:
Merge branch 'master-rpc-off' of https://source.denx.de/u-boot/custodians/u-boot-sh (2023-12-03 16:30:32 -0500)
git@source.denx.de:u-boot/custodians/u-boot-watchdog.git
for you to fetch changes up to a341a0e01f8087904eccbf3fe7baba63a62f9674:
watchdog: Correct watchdog timeout print message (2023-12-04 08:09:09 +0100)
---------------------------------------------------------------- Chanho Park (1): watchdog: Correct watchdog timeout print message
drivers/watchdog/wdt-uclass.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
Stefan Roese
