[PATCH V2] nvmem: add driver handling U-Boot environment variables
U-Boot stores its setup as environment variables. It's a list of key-value pairs stored on flash device with a custom header.
This commit adds an NVMEM driver that: 1. Provides NVMEM access to environment vars binary data 2. Extracts variables as NVMEM cells
It can be used for: 1. Accessing env variables from user-space 2. Reading NVMEM cells by Linux drivers
Signed-off-by: Rafał Miłecki rafal@milecki.pl --- V2: Drop ARCH_BCM4908 dependency as there are plenty architectures using U-Boot bootloader. Thanks Srinivas. --- MAINTAINERS | 1 + drivers/nvmem/Kconfig | 11 ++ drivers/nvmem/Makefile | 2 + drivers/nvmem/u-boot-env.c | 236 +++++++++++++++++++++++++++++++++++++ 4 files changed, 250 insertions(+) create mode 100644 drivers/nvmem/u-boot-env.c
diff --git a/MAINTAINERS b/MAINTAINERS index 2869a958f5e4..368e532444d0 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -20193,6 +20193,7 @@ U-BOOT ENVIRONMENT VARIABLES M: Rafał Miłecki rafal@milecki.pl S: Maintained F: Documentation/devicetree/bindings/nvmem/u-boot,env.yaml +F: drivers/nvmem/u-boot-env.c
UACCE ACCELERATOR FRAMEWORK M: Zhangfei Gao zhangfei.gao@linaro.org diff --git a/drivers/nvmem/Kconfig b/drivers/nvmem/Kconfig index 967d0084800e..eee3ff668629 100644 --- a/drivers/nvmem/Kconfig +++ b/drivers/nvmem/Kconfig @@ -337,4 +337,15 @@ config NVMEM_APPLE_EFUSES This driver can also be built as a module. If so, the module will be called nvmem-apple-efuses.
+config NVMEM_U_BOOT_ENV + tristate "U-Boot environment variables support" + depends on OF && MTD + select CRC32 + help + U-Boot stores its setup as environment variables. This driver adds + support for verifying & exporting such data. It also exposes variables + as NVMEM cells so they can be referenced by other drivers. + + If compiled as module it will be called nvmem_u-boot-env. + endif diff --git a/drivers/nvmem/Makefile b/drivers/nvmem/Makefile index 00e136a0a123..d201a02a09ec 100644 --- a/drivers/nvmem/Makefile +++ b/drivers/nvmem/Makefile @@ -67,3 +67,5 @@ obj-$(CONFIG_NVMEM_SUNPLUS_OCOTP) += nvmem_sunplus_ocotp.o nvmem_sunplus_ocotp-y := sunplus-ocotp.o obj-$(CONFIG_NVMEM_APPLE_EFUSES) += nvmem-apple-efuses.o nvmem-apple-efuses-y := apple-efuses.o +obj-$(CONFIG_NVMEM_U_BOOT_ENV) += nvmem_u-boot-env.o +nvmem_u-boot-env-y := u-boot-env.o diff --git a/drivers/nvmem/u-boot-env.c b/drivers/nvmem/u-boot-env.c new file mode 100644 index 000000000000..c7945d7d5750 --- /dev/null +++ b/drivers/nvmem/u-boot-env.c @@ -0,0 +1,236 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2022 Rafał Miłecki rafal@milecki.pl + */ + +#include <linux/crc32.h> +#include <linux/mod_devicetable.h> +#include <linux/module.h> +#include <linux/mtd/mtd.h> +#include <linux/nvmem-consumer.h> +#include <linux/nvmem-provider.h> +#include <linux/of_device.h> +#include <linux/platform_device.h> +#include <linux/slab.h> + +enum u_boot_env_format { + U_BOOT_FORMAT_SINGLE, + U_BOOT_FORMAT_REDUNDANT, +}; + +struct u_boot_env { + struct device *dev; + enum u_boot_env_format format; + + /* Parent device */ + struct mtd_info *mtd; + size_t offset; + size_t size; + + /* Cells */ + struct nvmem_cell_info *cells; + int ncells; +}; + +struct u_boot_env_image_single { + __le32 crc32; + uint8_t data[0]; +} __packed; + +struct u_boot_env_image_redundant { + __le32 crc32; + u8 mark; + uint8_t data[0]; +} __packed; + +static int u_boot_env_read(void *context, unsigned int offset, void *val, + size_t bytes) +{ + struct u_boot_env *priv = context; + struct device *dev = priv->dev; + size_t bytes_read; + int err; + + err = mtd_read(priv->mtd, priv->offset + offset, bytes, &bytes_read, val); + if (err && !mtd_is_bitflip(err)) { + dev_err(dev, "Failed to read from mtd: %d\n", err); + return err; + } + + if (bytes_read != bytes) { + dev_err(dev, "Failed to read %zd bytes\n", bytes); + return -EIO; + } + + return 0; +} + +static int u_boot_env_add_cells(struct u_boot_env *priv, uint8_t *buf, + size_t data_offset, size_t data_len) +{ + struct device *dev = priv->dev; + char *data = buf + data_offset; + char *var, *value, *eq; + int idx; + + priv->ncells = 0; + for (var = data; var < data + data_len && *var; var += strlen(var) + 1) + priv->ncells++; + + priv->cells = devm_kcalloc(dev, priv->ncells, sizeof(*priv->cells), GFP_KERNEL); + if (!priv->cells) + return -ENOMEM; + + for (var = data, idx = 0; + var < data + data_len && *var; + var = value + strlen(value) + 1, idx++) { + eq = strchr(var, '='); + if (!eq) + break; + *eq = '\0'; + value = eq + 1; + + priv->cells[idx].name = devm_kstrdup(dev, var, GFP_KERNEL); + if (!priv->cells[idx].name) + return -ENOMEM; + priv->cells[idx].offset = data_offset + value - data; + priv->cells[idx].bytes = strlen(value); + } + + if (WARN_ON(idx != priv->ncells)) + priv->ncells = idx; + + return 0; +} + +static int u_boot_env_parse(struct u_boot_env *priv) +{ + struct device *dev = priv->dev; + size_t crc32_data_offset; + size_t crc32_data_len; + size_t crc32_offset; + size_t data_offset; + size_t data_len; + uint32_t crc32; + uint32_t calc; + size_t bytes; + uint8_t *buf; + int err; + + buf = kcalloc(1, priv->size, GFP_KERNEL); + if (!buf) { + err = -ENOMEM; + goto err_out; + } + + err = mtd_read(priv->mtd, priv->offset, priv->size, &bytes, buf); + if ((err && !mtd_is_bitflip(err)) || bytes != priv->size) { + dev_err(dev, "Failed to read from mtd: %d\n", err); + goto err_kfree; + } + + switch (priv->format) { + case U_BOOT_FORMAT_SINGLE: + crc32_offset = offsetof(struct u_boot_env_image_single, crc32); + crc32_data_offset = offsetof(struct u_boot_env_image_single, data); + data_offset = offsetof(struct u_boot_env_image_single, data); + break; + case U_BOOT_FORMAT_REDUNDANT: + crc32_offset = offsetof(struct u_boot_env_image_redundant, crc32); + crc32_data_offset = offsetof(struct u_boot_env_image_redundant, mark); + data_offset = offsetof(struct u_boot_env_image_redundant, data); + break; + } + crc32 = le32_to_cpu(*(uint32_t *)(buf + crc32_offset)); + crc32_data_len = priv->size - crc32_data_offset; + data_len = priv->size - data_offset; + + calc = crc32(~0, buf + crc32_data_offset, crc32_data_len) ^ ~0L; + if (calc != crc32) { + dev_err(dev, "Invalid calculated CRC32: 0x%08x (expected: 0x%08x)\n", calc, crc32); + err = -EINVAL; + goto err_kfree; + } + + buf[priv->size - 1] = '\0'; + err = u_boot_env_add_cells(priv, buf, data_offset, data_len); + if (err) + dev_err(dev, "Failed to add cells: %d\n", err); + +err_kfree: + kfree(buf); +err_out: + return err; +} + +static const struct of_device_id u_boot_env_of_match_table[] = { + { .compatible = "u-boot,env", .data = (void *)U_BOOT_FORMAT_SINGLE, }, + { .compatible = "u-boot,env-redundant-bool", .data = (void *)U_BOOT_FORMAT_REDUNDANT, }, + { .compatible = "u-boot,env-redundant-count", .data = (void *)U_BOOT_FORMAT_REDUNDANT, }, + {}, +}; + +static int u_boot_env_probe(struct platform_device *pdev) +{ + struct nvmem_config config = { + .name = "u-boot-env", + .reg_read = u_boot_env_read, + }; + struct device *dev = &pdev->dev; + struct device_node *np = dev->of_node; + const struct of_device_id *of_id; + struct u_boot_env *priv; + const char *label; + int err; + + priv = devm_kzalloc(dev, sizeof(*priv), GFP_KERNEL); + if (!priv) + return -ENOMEM; + priv->dev = dev; + + of_id = of_match_device(u_boot_env_of_match_table, dev); + if (!of_id) + return -EINVAL; + priv->format = (uintptr_t)of_id->data; + + if (of_property_read_u32(np, "reg", (u32 *)&priv->offset) || + of_property_read_u32_index(np, "reg", 1, (u32 *)&priv->size)) { + dev_err(dev, "Failed to read "reg" property\n"); + return -EINVAL; + } + + label = of_get_property(np->parent, "label", NULL); + if (!label) + label = np->parent->name; + + priv->mtd = get_mtd_device_nm(label); + if (IS_ERR(priv->mtd)) { + dev_err(dev, "Failed to find "%s" MTD device: %ld\n", label, PTR_ERR(priv->mtd)); + return PTR_ERR(priv->mtd); + } + + err = u_boot_env_parse(priv); + if (err) + return err; + + config.dev = dev; + config.cells = priv->cells; + config.ncells = priv->ncells; + config.priv = priv; + config.size = priv->size; + + return PTR_ERR_OR_ZERO(devm_nvmem_register(dev, &config)); +} + +static struct platform_driver u_boot_env_driver = { + .probe = u_boot_env_probe, + .driver = { + .name = "u_boot_env", + .of_match_table = u_boot_env_of_match_table, + }, +}; +module_platform_driver(u_boot_env_driver); + +MODULE_AUTHOR("Rafał Miłecki"); +MODULE_LICENSE("GPL"); +MODULE_DEVICE_TABLE(of, u_boot_env_of_match_table);
Hello Rafał,
- Provides NVMEM access to environment vars binary data
- Extracts variables as NVMEM cells
It can be used for:
- Accessing env variables from user-space
Is this already possible? The only interface I know of is the /nvmem file in sysfs, but that one is not per cell, but per device.
- label = of_get_property(np->parent, "label", NULL);
- if (!label)
- priv->mtd = get_mtd_device_nm(label);
- if (IS_ERR(priv->mtd)) {
dev_err(dev, "Failed to find \"%s\" MTD device: %ld\n", label, PTR_ERR(priv->mtd));
I am trying to make sense of this using the binding, but I can't. Do you have an example device tree fragment?
Cheers, Ahmad
On 4.05.2022 11:23, Ahmad Fatoum wrote:
Hello Rafał,
It can be used for:
Maybe that wasn't precise enough, I should probably write: 1. Parsing binary data from user-space
In future I'd like to extend U-Boot's "printenv" tool to support reading env variables blob using Linux's sysfs as documented in the Documentation/ABI/stable/sysfs-bus-nvmem
- if (!label)
This comes from unreleased yet board I'm working on.
It stores U-Boot env variables in the middle of U-Boot binary.
partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>;
partition@0 { label = "loader"; reg = <0x0 0x100000>;
partition@40000 { compatible = "u-boot,env"; label = "u-boot-env"; reg = <0x40000 0x4000>; }; };
partition@100000 { label = "image"; reg = <0x100000 0x1fe00000>; }; };
Hello Rafał,
Hello Rafał,
It can be used for:
- Parsing binary data from user-space
So, would you use this interface just to save fw_printenv the hassle of finding the environment (but redoing parsing) or do you intend to preprocess the data too? (e.g. only show the active environment)
For your use case, it sound like teaching NVMEM core to export cells as binary sysfs files would be very useful.
Huh, that's an odd layout. I am not sure whether of_get_property to arrive at the parent is such a good idea though. Doesn't it enforce a limitation that there must not exist two partitions with the same label?
Some systems can have a second recovery bootloader for example. Given that these are device tree nodes, wouldn't it be possible to find the MTD by device tree parent instead of via its label?
Thanks, Ahmad
Ahmad Fatoum
Rafał Miłecki
