[U-Boot] imx6: [PATCH] Add support for new board "eval1a"
This patch adds support for the latest evalboard Eval 1A from databyte
Signed-off-by: Claudio Hediger claudio@databyte.ch Cc: Stefano Babic sbabic@denx.de ---
From ecfc11f5507e2a1db2c8981b193017e1fd74f7eb Mon Sep 17 00:00:00 2001
From: Claudio Hediger claudio@databyte.ch Date: Sun, 9 Jun 2019 15:56:29 +0200 Subject: [PATCH 1/3] Added new file. Not finished yet. Commit before eclipse
--- arch/arm/dts/eval1a.dts | 204 +++++++++++++++++++++++++ arch/arm/mach-imx/mx6/Kconfig | 6 + board/databyte.ch/eval1a/Kconfig | 12 ++ board/databyte.ch/eval1a/MAINTAINERS | 7 + board/databyte.ch/eval1a/Makefile | 4 + board/databyte.ch/eval1a/eval1a.c | 211 ++++++++++++++++++++++++++ board/databyte.ch/eval1a/imximage.cfg | 133 ++++++++++++++++ board/databyte.ch/eval1a/plugin.S | 173 +++++++++++++++++++++ configs/eval1a_defconfig | 36 +++++ include/configs/eval1a.h | 54 +++++++ 10 files changed, 840 insertions(+) create mode 100644 arch/arm/dts/eval1a.dts create mode 100644 board/databyte.ch/eval1a/Kconfig create mode 100644 board/databyte.ch/eval1a/MAINTAINERS create mode 100644 board/databyte.ch/eval1a/Makefile create mode 100644 board/databyte.ch/eval1a/eval1a.c create mode 100644 board/databyte.ch/eval1a/imximage.cfg create mode 100644 board/databyte.ch/eval1a/plugin.S create mode 100644 configs/eval1a_defconfig create mode 100644 include/configs/eval1a.h
diff --git a/arch/arm/dts/eval1a.dts b/arch/arm/dts/eval1a.dts new file mode 100644 index 0000000000..1869abab6a --- /dev/null +++ b/arch/arm/dts/eval1a.dts @@ -0,0 +1,204 @@ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +/dts-v1/; + +#include "imx6ull.dtsi" + +/ { + model = "Databyte imx6 Evalboard 1A"; + compatible = "dtb,eval1a", "fsl,imx6ull"; + + chosen { + stdout-path = &uart1; + }; + + memory { + reg = <0x80000000 0x20000000>; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + reg_can_3v3: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "can-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpios = <&gpio_spi 3 GPIO_ACTIVE_LOW>; + }; + + reg_sd1_vmmc: regulator@1 { + compatible = "regulator-fixed"; + regulator-name = "VSD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio1 9 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + }; + +}; + +&cpu0 { + arm-supply = <®_arm>; + soc-supply = <®_soc>; + /*dc-supply = <®_gpio_dvfs>;*/ +}; + +&clks { + assigned-clocks = <&clks IMX6UL_CLK_PLL4_AUDIO_DIV>; + assigned-clock-rates = <786432000>; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet1>; + phy-mode = "rmii"; + phy-handle = <ðphy0>; + status = "okay"; +}; + +&fec2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet2>; + phy-mode = "rmii"; + phy-handle = <ðphy1>; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@2 { + compatible = "micrel,ksz8081"; + reg = <2>; + }; + + ethphy1: ethernet-phy@1 { + compatible = "micrel,ksz8081"; + reg = <1>; + }; + }; +}; + + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog_1>; + eval1a { + + pinctrl_enet1: enet1grp { + fsl,pins = < + MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN 0x1b0b0 + MX6UL_PAD_ENET1_RX_ER__ENET1_RX_ER 0x1b0b0 + MX6UL_PAD_ENET1_RX_DATA0__ENET1_RDATA00 0x1b0b0 + MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01 0x1b0b0 + MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN 0x1b0b0 + MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00 0x1b0b0 + MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01 0x1b0b0 + MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 0x4001b031 + >; + }; + + pinctrl_enet2: enet2grp { + fsl,pins = < + MX6UL_PAD_GPIO1_IO07__ENET2_MDC 0x1b0b0 + MX6UL_PAD_GPIO1_IO06__ENET2_MDIO 0x1b0b0 + MX6UL_PAD_ENET2_RX_EN__ENET2_RX_EN 0x1b0b0 + MX6UL_PAD_ENET2_RX_ER__ENET2_RX_ER 0x1b0b0 + MX6UL_PAD_ENET2_RX_DATA0__ENET2_RDATA00 0x1b0b0 + MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01 0x1b0b0 + MX6UL_PAD_ENET2_TX_EN__ENET2_TX_EN 0x1b0b0 + MX6UL_PAD_ENET2_TX_DATA0__ENET2_TDATA00 0x1b0b0 + MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01 0x1b0b0 + MX6UL_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 0x4001b031 + >; + }; + + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6UL_PAD_UART1_TX_DATA__UART1_DCE_TX 0x1b0b1 + MX6UL_PAD_UART1_RX_DATA__UART1_DCE_RX 0x1b0b1 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX6UL_PAD_UART2_TX_DATA__UART2_DCE_TX 0x1b0b1 + MX6UL_PAD_UART2_RX_DATA__UART2_DCE_RX 0x1b0b1 + MX6UL_PAD_UART3_RX_DATA__UART2_DCE_RTS 0x1b0b1 + MX6UL_PAD_UART3_TX_DATA__UART2_DCE_CTS 0x1b0b1 + >; + }; + + pinctrl_uart2dte: uart2dtegrp { + fsl,pins = < + MX6UL_PAD_UART2_TX_DATA__UART2_DTE_RX 0x1b0b1 + MX6UL_PAD_UART2_RX_DATA__UART2_DTE_TX 0x1b0b1 + MX6UL_PAD_UART3_RX_DATA__UART2_DTE_CTS 0x1b0b1 + MX6UL_PAD_UART3_TX_DATA__UART2_DTE_RTS 0x1b0b1 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x17059 + MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x10071 + MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x17059 + MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x17059 + MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x17059 + MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x17059 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX6UL_PAD_LCD_RESET__WDOG1_WDOG_ANY 0x30b0 + >; + }; + }; +}; + + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + fsl,uart-has-rtscts; + /* for DTE mode, add below change */ + /* fsl,dte-mode; */ + /* pinctrl-0 = <&pinctrl_uart2dte>; */ + status = "okay"; +}; + +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1>; + cd-gpios = <&gpio1 19 GPIO_ACTIVE_LOW>; + keep-power-in-suspend; + enable-sdio-wakeup; + vmmc-supply = <®_sd1_vmmc>; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,wdog_b; +}; diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index f513c4c06f..c101be4f18 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -196,6 +196,11 @@ config TARGET_EMBESTMX6BOARDS select BOARD_LATE_INIT select SUPPORT_SPL
+config TARGET_EVAL1A + bool "Databyte eval1a" + select BOARD_LATE_INIT + select MX6ULL + config TARGET_GE_BX50V3 bool "General Electric Bx50v3" select BOARD_LATE_INIT @@ -559,6 +564,7 @@ source "board/bticino/mamoj/Kconfig" source "board/ccv/xpress/Kconfig" source "board/compulab/cm_fx6/Kconfig" source "board/congatec/cgtqmx6eval/Kconfig" +source "board/databyte.ch/eval1a/Kconfig" source "board/dhelectronics/dh_imx6/Kconfig" source "board/el/el6x/Kconfig" source "board/embest/mx6boards/Kconfig" diff --git a/board/databyte.ch/eval1a/Kconfig b/board/databyte.ch/eval1a/Kconfig new file mode 100644 index 0000000000..b9b12c4b21 --- /dev/null +++ b/board/databyte.ch/eval1a/Kconfig @@ -0,0 +1,12 @@ +if TARGET_EVAL1A + +config SYS_BOARD + default "eval1a" + +config SYS_VENDOR + default "databyte.ch" + +config SYS_CONFIG_NAME + default "eval1a" + +endif diff --git a/board/databyte.ch/eval1a/MAINTAINERS b/board/databyte.ch/eval1a/MAINTAINERS new file mode 100644 index 0000000000..101cbe5660 --- /dev/null +++ b/board/databyte.ch/eval1a/MAINTAINERS @@ -0,0 +1,7 @@ +EVAL1A BOARD +M: C. Hediger info@databyte.ch +S: Maintained +F: board/databyte.ch/eval1a/ +F: include/configs/mx6ullevk.h +F: configs/mx6ull_14x14_evk_defconfig +F: configs/mx6ull_14x14_evk_plugin_defconfig diff --git a/board/databyte.ch/eval1a/Makefile b/board/databyte.ch/eval1a/Makefile new file mode 100644 index 0000000000..4575eb00b7 --- /dev/null +++ b/board/databyte.ch/eval1a/Makefile @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0+ +# (C) Copyright 2016 Freescale Semiconductor, Inc. + +obj-y := eval1a.o diff --git a/board/databyte.ch/eval1a/eval1a.c b/board/databyte.ch/eval1a/eval1a.c new file mode 100644 index 0000000000..6cb76dce7a --- /dev/null +++ b/board/databyte.ch/eval1a/eval1a.c @@ -0,0 +1,211 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + */ + +#include <asm/arch/clock.h> +#include <asm/arch/iomux.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/io.h> +#include <common.h> +#include <fsl_esdhc.h> +#include <linux/sizes.h> +#include <mmc.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PUS_22K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define ENET_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define ETH_PHY_POWER IMX_GPIO_NR(4, 10) + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + + return 0; +} + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc1_pads[] = { + /* 4 bit SD */ + MX6_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + + +static iomux_v3_cfg_t const fec_pads[] = { + MX6_PAD_ENET1_RX_EN__ENET1_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_RX_ER__ENET1_RX_ER | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_RX_DATA0__ENET1_RDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_RX_DATA1__ENET1_RDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_EN__ENET1_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_DATA0__ENET1_TDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_DATA1__ENET1_TDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + +static void setup_iomux_fec(void) +{ + imx_iomux_v3_setup_multiple_pads(fec_pads, ARRAY_SIZE(fec_pads)); + + /* Reset KSZ8041 PHY */ + gpio_request(ETH_PHY_POWER, "eth_pwr"); + gpio_direction_output(ETH_PHY_POWER , 1); + udelay(15000); +} + +/* + * Initializes on-chip ethernet controllers. + * to override, implement board_eth_init() + */ +#if defined(CONFIG_FEC_MXC) +//extern int fecmxc_initialize(bd_t *bis); +#endif + +/* +int fecmxc_initialize(bd_t *bis) +{ + return 0; +} */ + +int board_mmc_get_env_dev(int devno) +{ + return devno; +} + +int mmc_map_to_kernel_blk(int devno) +{ + return devno; +} + +int board_early_init_f(void) +{ + setup_iomux_uart(); + + return 0; +} + +#ifdef CONFIG_FEC_MXC +int board_eth_init(bd_t *bis) +{ + setup_iomux_fec(); + + return 0; //cpu_eth_init(bis); +} + +static int setup_fec(void) +{ + struct iomuxc *iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; + + /* clear gpr1[14], gpr1[18:17] to select anatop clock */ + clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC_MASK, 0); + + return enable_fec_anatop_clock(0, ENET_50MHZ); +} +#endif + +int board_init(void) +{ + /* Address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + +#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + + return 0; +} + +#ifdef CONFIG_CMD_BMODE +static const struct boot_mode board_boot_modes[] = { + /* 4 bit bus width */ + {"sd1", MAKE_CFGVAL(0x42, 0x20, 0x00, 0x00)}, + {"sd2", MAKE_CFGVAL(0x40, 0x28, 0x00, 0x00)}, + {"qspi1", MAKE_CFGVAL(0x10, 0x00, 0x00, 0x00)}, + {NULL, 0}, +}; +#endif + +int board_late_init(void) +{ +#ifdef CONFIG_CMD_BMODE + add_board_boot_modes(board_boot_modes); +#endif + +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + env_set("board_name", "EVAL"); + env_set("board_rev", "1A"); +#endif + + return 0; +} + +int board_mmc_getcd(struct mmc *mmc) +{ + //Since we cant detect the insertion of an SD-Card, we always assume that there is one inserted! + return 1; +} + +static struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC1_BASE_ADDR} +}; + +int board_mmc_init(bd_t *bis) +{ + //struct src *src_regs = (struct src *)SRC_BASE_ADDR; + //u32 val; + //u32 port; + + //val = readl(&src_regs->sbmr1); + + /* Boot from USDHC */ + //port = (val >> 11) & 0x3; + + imx_iomux_v3_setup_multiple_pads(usdhc1_pads, + ARRAY_SIZE(usdhc1_pads)); + //gpio_direction_input(USDHC1_CD_GPIO); + usdhc_cfg[0].esdhc_base = USDHC1_BASE_ADDR; + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + + gd->arch.sdhc_clk = usdhc_cfg[0].sdhc_clk; + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); +} + + + +int checkboard(void) +{ + puts("Board: DTB iMX6 eval 1a\n"); + + return 0; +} diff --git a/board/databyte.ch/eval1a/imximage.cfg b/board/databyte.ch/eval1a/imximage.cfg new file mode 100644 index 0000000000..21c5026e1f --- /dev/null +++ b/board/databyte.ch/eval1a/imximage.cfg @@ -0,0 +1,133 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * + * Refer doc/README.imximage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +#define __ASSEMBLY__ +#include <config.h> + +/* image version */ + +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi/sd/nand/onenand, qspi/nor + */ + +#ifdef CONFIG_QSPI_BOOT +BOOT_FROM qspi +#elif defined(CONFIG_NOR_BOOT) +BOOT_FROM nor +#else +BOOT_FROM sd +#endif + +#ifdef CONFIG_USE_IMXIMG_PLUGIN +/*PLUGIN plugin-binary-file IRAM_FREE_START_ADDR*/ +PLUGIN board/databyte.ch/eval1a/plugin.bin 0x00907000 +#else + +#ifdef CONFIG_SECURE_BOOT +CSF CONFIG_CSF_SIZE +#endif + +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* Enable all clocks */ +DATA 4 0x020c4068 0xffffffff +DATA 4 0x020c406c 0xffffffff +DATA 4 0x020c4070 0xffffffff +DATA 4 0x020c4074 0xffffffff +DATA 4 0x020c4078 0xffffffff +DATA 4 0x020c407c 0xffffffff +DATA 4 0x020c4080 0xffffffff +DATA 4 0x020e04b4 0x000C0000 +DATA 4 0x020e04ac 0x00000000 +DATA 4 0x020e027c 0x00000008 + +DATA 4 0x020e0250 0x00000008 +DATA 4 0x020e024c 0x00000008 +DATA 4 0x020e0490 0x00000008 +DATA 4 0x020e0288 0x000C0008 + +DATA 4 0x020e0270 0x00000000 + +DATA 4 0x020e0260 0x00000008 +DATA 4 0x020e0264 0x00000008 +DATA 4 0x020e04a0 0x00000008 + +DATA 4 0x020e0494 0x00020000 +DATA 4 0x020e0280 0x00000008 +DATA 4 0x020e0284 0x00000008 + +DATA 4 0x020e04b0 0x00020000 +DATA 4 0x020e0498 0x00000008 +DATA 4 0x020e04a4 0x00000008 +DATA 4 0x020e0244 0x00000008 +DATA 4 0x020e0248 0x00000008 + +DATA 4 0x021b001c 0x00008000 +DATA 4 0x021b0800 0xA1390003 +DATA 4 0x021b080c 0x000A0025 + +DATA 4 0x021b0810 0x000B000B +DATA 4 0x021b083c 0x014C014C +DATA 4 0x021b0848 0x40403236 +DATA 4 0x021b0850 0x4040322C +DATA 4 0x021b081c 0x33333333 +DATA 4 0x021b0820 0x33333333 + +DATA 4 0x021b082c 0xF3333333 +DATA 4 0x021b0830 0xF3333333 + +DATA 4 0x021b08c0 0x00944009 +DATA 4 0x021b08b8 0x00000800 +DATA 4 0x021b0004 0x0002002D +DATA 4 0x021b0008 0x1B333030 +DATA 4 0x021b000c 0x3F4352F3 +DATA 4 0x021b0010 0xB66D0B63 +DATA 4 0x021b0014 0x01FF00DB +DATA 4 0x021b0018 0x00211740 + +DATA 4 0x021b001c 0x00008000 +DATA 4 0x021b002c 0x000026D2 +DATA 4 0x021b0030 0x00431023 + +DATA 4 0x021b0040 0x00000047 +DATA 4 0x021b0000 0x83180000 +DATA 4 0x021b0890 0x00400000 +DATA 4 0x021b001c 0x02008032 +DATA 4 0x021b001c 0x00008033 + +DATA 4 0x021b001c 0x00408031 +DATA 4 0x021b001c 0x15208030 +DATA 4 0x021b001c 0x04008040 +DATA 4 0x021b001c 0x0200803A +DATA 4 0x021b001c 0x0000803B +DATA 4 0x021b001c 0x00408039 +DATA 4 0x021b001c 0x15208038 +DATA 4 0x021b001c 0x04008048 +DATA 4 0x021b0020 0x00007800 +DATA 4 0x021b0818 0x00000117 +DATA 4 0x021b0004 0x0002552D +DATA 4 0x021b0404 0x00011006 +DATA 4 0x021b001c 0x00000000 + + +#endif diff --git a/board/databyte.ch/eval1a/plugin.S b/board/databyte.ch/eval1a/plugin.S new file mode 100644 index 0000000000..1955c1b3be --- /dev/null +++ b/board/databyte.ch/eval1a/plugin.S @@ -0,0 +1,173 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * C Copyright (C) 2016 Freescale Semiconductor, Inc. + */ + +#include <config.h> + +/* DDR script */ +.macro eval1a_ddr3_setting + ldr r0, =IOMUXC_BASE_ADDR + ldr r1, =0x000C0000 + str r1, [r0, #0x4B4] + + ldr r1, =0x00000000 + str r1, [r0, #0x4AC] + + ldr r1, =0x00000008 + str r1, [r0, #0x27C] + str r1, [r0, #0x250] + str r1, [r0, #0x24C] + str r1, [r0, #0x490] + str r1, [r0, #0x288] + + ldr r1, =0x00000000 + str r1, [r0, #0x270] + + ldr r1, =0x00000008 + str r1, [r0, #0x260] + str r1, [r0, #0x264] + str r1, [r0, #0x4A0] + + ldr r1, =0x00020000 + str r1, [r0, #0x494] + + ldr r1, =0x00000008 + str r1, [r0, #0x280] + str r1, [r0, #0x284] + + ldr r1, =0x00020000 + str r1, [r0, #0x4B0] + + ldr r1, =0x00000008 + str r1, [r0, #0x498] + str r1, [r0, #0x4A4] + str r1, [r0, #0x244] + str r1, [r0, #0x248] + + ldr r0, =MMDC_P0_BASE_ADDR + ldr r1, =0x00008000 + str r1, [r0, #0x1C] + + ldr r1, =0xA1390003 + str r1, [r0, #0x800] + + ldr r1, =0x000A0025 + str r1, [r0, #0x80C] + + ldr r1, =0x000B000B + str r1, [r0, #0x810] + + ldr r1, =0x014C014C + str r1, [r0, #0x83C] + + ldr r1, =0x40403236 + str r1, [r0, #0x848] + + ldr r1, =0x4040322C + str r1, [r0, #0x850] + ldr r1, =0x33333333 + str r1, [r0, #0x81C] + str r1, [r0, #0x820] + ldr r1, =0xF3333333 + str r1, [r0, #0x82C] + str r1, [r0, #0x830] + ldr r1, =0x00944009 + str r1, [r0, #0x8C0] + + ldr r1, =0x00000800 + str r1, [r0, #0x8B8] + ldr r1, =0x0002002D + str r1, [r0, #0x004] + ldr r1, =0x1B333030 + str r1, [r0, #0x008] + + ldr r1, =0x3F4352F3 + str r1, [r0, #0x00C] + + ldr r1, =0xB66D0B63 + str r1, [r0, #0x010] + + ldr r1, =0x01FF00DB + str r1, [r0, #0x014] + + ldr r1, =0x00211740 + str r1, [r0, #0x018] + + ldr r1, =0x00008000 + str r1, [r0, #0x01C] + + ldr r1, =0x000026D2 + str r1, [r0, #0x02C] + + ldr r1, =0x00431023 + str r1, [r0, #0x030] + + ldr r1, =0x00000047 + str r1, [r0, #0x040] + + ldr r1, =0x83180000 + str r1, [r0, #0x000] + + ldr r1, =0x00400000 + str r1, [r0, #0x890] + ldr r1, =0x02008032 + str r1, [r0, #0x01C] + ldr r1, =0x00008033 + str r1, [r0, #0x01C] + ldr r1, =0x00408031 + str r1, [r0, #0x01C] + ldr r1, =0x15208030 + str r1, [r0, #0x01C] + ldr r1, =0x04008040 + str r1, [r0, #0x01C] + + ldr r1, =0x0200803A + str r1, [r0, #0x01C] + + ldr r1, =0x0000803B + str r1, [r0, #0x01C] + + ldr r1, =0x00408039 + str r1, [r0, #0x01C] + + ldr r1, =0x15208038 + str r1, [r0, #0x01C] + + ldr r1, =0x04008048 + str r1, [r0, #0x01C] + + + ldr r1, =0x00007800 + str r1, [r0, #0x020] + ldr r1, =0x00000117 + str r1, [r0, #0x818] + ldr r1, =0x0002552D + str r1, [r0, #0x004] + ldr r1, =0x00011006 + str r1, [r0, #0x404] + ldr r1, =0x00000000 + str r1, [r0, #0x01C] +.endm + +.macro imx6_clock_gating + ldr r0, =CCM_BASE_ADDR + ldr r1, =0xFFFFFFFF + str r1, [r0, #0x68] + str r1, [r0, #0x6C] + str r1, [r0, #0x70] + str r1, [r0, #0x74] + str r1, [r0, #0x78] + str r1, [r0, #0x7C] + str r1, [r0, #0x80] +.endm + +.macro imx6_qos_setting +.endm + +.macro imx6_ddr_setting + eval1a_ddr3_setting +.endm + +/* include the common plugin code here */ +#include <asm/arch/mx6_plugin.S> diff --git a/configs/eval1a_defconfig b/configs/eval1a_defconfig new file mode 100644 index 0000000000..64e54b207d --- /dev/null +++ b/configs/eval1a_defconfig @@ -0,0 +1,36 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_TARGET_EVAL1A=y +CONFIG_MXC_UART=y +CONFIG_DM_MMC=y +CONFIG_CMD_FAT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MMC=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_FSL_ESDHC=y +CONFIG_CMD_BMODE=y +CONFIG_CMD_BOOTZ=y + +CONFIG_SPL_IMAGE="spl/u-boot-spl.bin" + +CONFIG_FEC_MXC=y +CONFIG_CMD_MII=y +CONFIG_PHYLIB=y +CONFIG_MII=y +CONFIG_DM_ETH=y +CONFIG_ETH=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y +CONFIG_RGMII=y +CONFIG_NET_RANDOM_ETHADDR=y + +CONFIG_DEFAULT_DEVICE_TREE="eval1a" + +CONFIG_NR_DRAM_BANKS=1 + +CONFIG_SYS_TEXT_BASE=0x87800000 diff --git a/include/configs/eval1a.h b/include/configs/eval1a.h new file mode 100644 index 0000000000..8b75af99e4 --- /dev/null +++ b/include/configs/eval1a.h @@ -0,0 +1,54 @@ +#ifndef __EVAL1A_CONFIG_H +#define __EVAL1A_CONFIG_H + +#include "mx6_common.h" + +#ifndef CONFIG_MXC_UART +#define CONFIG_MXC_UART +#endif + +/* +#define CONFIG_SPL +#define CONFIG_SPL_BUILD +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SYS_ONENAND_BASE 0x4E000000 +#define CONFIG_SPL_TEXT_BASE 0x0 +#define CONFIG_SPL_SKIP_RELOCATE +#define CONFIG_SPL_SERIAL_SUPPORT +*/ + +#define CONFIG_ENV_SIZE SZ_8K +#define CONFIG_ENV_OFFSET (12 * SZ_64K) + +#define CONFIG_MXC_UART_BASE UART1_BASE + +//#define CONFIG_FEC_MXC +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_FEC_MXC_PHYADDR 0 + + +/* MMC Configs */ +#ifdef CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR USDHC1_BASE_ADDR +#endif + +#define PHYS_SDRAM_SIZE SZ_256M + +#define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M) + +/* Physical Memory Map */ +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + + +#endif
Hi Claudio,
Please be aware that this board uses the "old" approach, which is not using driver model and device tree description.
The SPL is not (yet) required to be converted to DM/DTS. The U-Boot proper (u-boot.img) shall use DM/DTS.
From ecfc11f5507e2a1db2c8981b193017e1fd74f7eb Mon Sep 17 00:00:00 2001 From: Claudio Hediger claudio@databyte.ch Date: Sun, 9 Jun 2019 15:56:29 +0200 Subject: [PATCH 1/3] Added new file. Not finished yet. Commit before eclipse
- Copyright (C) 2016 Freescale Semiconductor, Inc.
modify
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation.
+/dts-v1/;
If you port code from linux kernel, then please provide SHA1 ID of the exact commit of copied file.
- model = "Databyte imx6 Evalboard 1A";
- compatible = "dtb,eval1a", "fsl,imx6ull";
- chosen {
- memory {
- regulators {
#size-cells = <0>;
reg = <0>;
enable-active-high;
+&cpu0 {
- arm-supply = <®_arm>;
- soc-supply = <®_soc>;
- /*dc-supply = <®_gpio_dvfs>;*/
+&clks {
- assigned-clocks = <&clks IMX6UL_CLK_PLL4_AUDIO_DIV>;
- assigned-clock-rates = <786432000>;
+&fec1 {
- pinctrl-names = "default";
- pinctrl-0 = <&pinctrl_enet1>;
- phy-mode = "rmii";
- phy-handle = <ðphy0>;
- status = "okay";
+&fec2 {
- pinctrl-0 = <&pinctrl_enet2>;
- phy-handle = <ðphy1>;
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <2>;
reg = <1>;
+&iomuxc {
- pinctrl-0 = <&pinctrl_hog_1>;
- eval1a {
fsl,pins = <
0x1b0b0
0x1b0b0
0x1b0b0
fsl,pins = <
0x1b0b0
0x1b0b0
0x1b0b0
0x1b0b0
0x1b0b0
fsl,pins = <
0x1b0b1
0x1b0b1
fsl,pins = <
0x1b0b1
0x1b0b1
fsl,pins = <
0x1b0b1
0x1b0b1
fsl,pins = <
0x17059
0x10071
0x17059
0x17059
0x17059
0x17059
fsl,pins = <
0x30b0
+&uart1 {
- pinctrl-0 = <&pinctrl_uart1>;
- status = "okay";
+&uart2 {
- pinctrl-0 = <&pinctrl_uart2>;
- fsl,uart-has-rtscts;
- /* for DTE mode, add below change */
- /* fsl,dte-mode; */
- /* pinctrl-0 = <&pinctrl_uart2dte>; */
- status = "okay";
+&usdhc1 {
- pinctrl-0 = <&pinctrl_usdhc1>;
- cd-gpios = <&gpio1 19 GPIO_ACTIVE_LOW>;
- keep-power-in-suspend;
- enable-sdio-wakeup;
- vmmc-supply = <®_sd1_vmmc>;
- status = "okay";
+&wdog1 {
- pinctrl-0 = <&pinctrl_wdog>;
- fsl,wdog_b;
- bool "Databyte eval1a"
- select BOARD_LATE_INIT
- select MX6ULL
+config SYS_BOARD
- default "eval1a"
+config SYS_VENDOR
- default "databyte.ch"
- default "eval1a"
- PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \
- PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
- PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm
- PAD_CTL_SRE_FAST | PAD_CTL_HYS)
- PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
This is not needed if you use pinctrl and dts.
- gd->ram_size = imx_ddr_size();
- MX6_PAD_UART1_TX_DATA__UART1_DCE_TX |
- MX6_PAD_UART1_RX_DATA__UART1_DCE_RX |
- /* 4 bit SD */
- MX6_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD1_DATA0__USDHC1_DATA0 |
- MX6_PAD_SD1_DATA1__USDHC1_DATA1 |
- MX6_PAD_SD1_DATA2__USDHC1_DATA2 |
- MX6_PAD_SD1_DATA3__USDHC1_DATA3 |
- MX6_PAD_ENET1_RX_EN__ENET1_RX_EN |
- MX6_PAD_ENET1_RX_ER__ENET1_RX_ER |
- MX6_PAD_ENET1_RX_DATA0__ENET1_RDATA00 |
- MX6_PAD_ENET1_RX_DATA1__ENET1_RDATA01 |
- MX6_PAD_ENET1_TX_EN__ENET1_TX_EN |
- MX6_PAD_ENET1_TX_DATA0__ENET1_TDATA00 |
- MX6_PAD_ENET1_TX_DATA1__ENET1_TDATA01 |
- MX6_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 |
The same here.
- imx_iomux_v3_setup_multiple_pads(uart1_pads,
- imx_iomux_v3_setup_multiple_pads(fec_pads,
- /* Reset KSZ8041 PHY */
- gpio_request(ETH_PHY_POWER, "eth_pwr");
- gpio_direction_output(ETH_PHY_POWER , 1);
- udelay(15000);
- Initializes on-chip ethernet controllers.
- to override, implement board_eth_init()
- return devno;
- return devno;
- setup_iomux_uart();
- setup_iomux_fec();
fec driver is also converted to DM/DTS.
- return 0; //cpu_eth_init(bis);
- struct iomuxc *iomuxc_regs = (struct iomuxc
- /* clear gpr1[14], gpr1[18:17] to select anatop clock */
- clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC_MASK,
0); +
- return enable_fec_anatop_clock(0, ENET_50MHZ);
+} +#endif
- /* Address of boot parameters */
- gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- setup_fec();
- /* 4 bit bus width */
- {"sd1", MAKE_CFGVAL(0x42, 0x20, 0x00, 0x00)},
- {"sd2", MAKE_CFGVAL(0x40, 0x28, 0x00, 0x00)},
- {"qspi1", MAKE_CFGVAL(0x10, 0x00, 0x00, 0x00)},
- {NULL, 0},
+}; +#endif
- add_board_boot_modes(board_boot_modes);
- env_set("board_name", "EVAL");
- env_set("board_rev", "1A");
- //Since we cant detect the insertion of an SD-Card, we
- return 1;
- {USDHC1_BASE_ADDR}
This base address it get from dts.
- //struct src *src_regs = (struct src *)SRC_BASE_ADDR;
- //u32 val;
- //u32 port;
- //val = readl(&src_regs->sbmr1);
- /* Boot from USDHC */
- //port = (val >> 11) & 0x3;
Please correct me if I'm wrong, but such commented code doesn't look like a production one.
- imx_iomux_v3_setup_multiple_pads(usdhc1_pads,
- //gpio_direction_input(USDHC1_CD_GPIO);
- usdhc_cfg[0].esdhc_base = USDHC1_BASE_ADDR;
- usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK);
- gd->arch.sdhc_clk = usdhc_cfg[0].sdhc_clk;
- return fsl_esdhc_initialize(bis, &usdhc_cfg[0]);
- puts("Board: DTB iMX6 eval 1a\n");
- Refer doc/README.imximage for more details about how-to configure
- and create imximage boot image
- The syntax is taken as close as possible with the kwbimage
+IMAGE_VERSION 2
- Boot Device : one of
- spi/sd/nand/onenand, qspi/nor
- Device Configuration Data (DCD)
- Each entry must have the format:
- Addr-type Address Value
- where:
- Addr-type register length (1,2 or 4 bytes)
- Address absolute address of the register
- value value to be stored in the register
What is the purpose of this BCB ? Initial setup shall be done in SPL part of U-Boot.
- C Copyright (C) 2016 Freescale Semiconductor, Inc.
- ldr r0, =IOMUXC_BASE_ADDR
- ldr r1, =0x000C0000
- str r1, [r0, #0x4B4]
- ldr r1, =0x00000000
- str r1, [r0, #0x4AC]
- ldr r1, =0x00000008
- str r1, [r0, #0x27C]
- str r1, [r0, #0x250]
- str r1, [r0, #0x24C]
- str r1, [r0, #0x490]
- str r1, [r0, #0x288]
- str r1, [r0, #0x270]
- str r1, [r0, #0x260]
- str r1, [r0, #0x264]
- str r1, [r0, #0x4A0]
- ldr r1, =0x00020000
- str r1, [r0, #0x494]
- str r1, [r0, #0x280]
- str r1, [r0, #0x284]
- str r1, [r0, #0x4B0]
- str r1, [r0, #0x498]
- str r1, [r0, #0x4A4]
- str r1, [r0, #0x244]
- str r1, [r0, #0x248]
- ldr r0, =MMDC_P0_BASE_ADDR
- ldr r1, =0x00008000
- str r1, [r0, #0x1C]
- ldr r1, =0xA1390003
- str r1, [r0, #0x800]
- ldr r1, =0x000A0025
- str r1, [r0, #0x80C]
- ldr r1, =0x000B000B
- str r1, [r0, #0x810]
- ldr r1, =0x014C014C
- str r1, [r0, #0x83C]
- ldr r1, =0x40403236
- str r1, [r0, #0x848]
- ldr r1, =0x4040322C
- str r1, [r0, #0x850]
- ldr r1, =0x33333333
- str r1, [r0, #0x81C]
- str r1, [r0, #0x820]
- ldr r1, =0xF3333333
- str r1, [r0, #0x82C]
- str r1, [r0, #0x830]
- ldr r1, =0x00944009
- str r1, [r0, #0x8C0]
- ldr r1, =0x00000800
- str r1, [r0, #0x8B8]
- ldr r1, =0x0002002D
- str r1, [r0, #0x004]
- ldr r1, =0x1B333030
- str r1, [r0, #0x008]
- ldr r1, =0x3F4352F3
- str r1, [r0, #0x00C]
- ldr r1, =0xB66D0B63
- str r1, [r0, #0x010]
- ldr r1, =0x01FF00DB
- str r1, [r0, #0x014]
- ldr r1, =0x00211740
- str r1, [r0, #0x018]
- str r1, [r0, #0x01C]
- ldr r1, =0x000026D2
- str r1, [r0, #0x02C]
- ldr r1, =0x00431023
- str r1, [r0, #0x030]
- ldr r1, =0x00000047
- str r1, [r0, #0x040]
- ldr r1, =0x83180000
- str r1, [r0, #0x000]
- ldr r1, =0x00400000
- str r1, [r0, #0x890]
- ldr r1, =0x02008032
- ldr r1, =0x00008033
- ldr r1, =0x00408031
- ldr r1, =0x15208030
- ldr r1, =0x04008040
- ldr r1, =0x0200803A
- ldr r1, =0x0000803B
- ldr r1, =0x00408039
- ldr r1, =0x15208038
- ldr r1, =0x04008048
- ldr r1, =0x00007800
- str r1, [r0, #0x020]
- ldr r1, =0x00000117
- str r1, [r0, #0x818]
- ldr r1, =0x0002552D
- ldr r1, =0x00011006
- str r1, [r0, #0x404]
+.endm
- ldr r0, =CCM_BASE_ADDR
- ldr r1, =0xFFFFFFFF
- str r1, [r0, #0x68]
- str r1, [r0, #0x6C]
- str r1, [r0, #0x70]
- str r1, [r0, #0x74]
- str r1, [r0, #0x78]
- str r1, [r0, #0x7C]
- str r1, [r0, #0x80]
+.endm
- eval1a_ddr3_setting
+.endm
i.MX6 now has the code to train and setup ddr automatically.
- (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Hi Lukasz
Thank you for your answer. You are right. I will update my code and send a new patch to the mailing list.
Sorry for the inconvenience. This is my first patch to such a big project.
Regards Claudio
-----Ursprüngliche Nachricht----- Von: Lukasz Majewski lukma@denx.de Gesendet: Montag, 17. Juni 2019 11:00 An: claudio@databyte.ch Cc: u-boot@lists.denx.de Betreff: Re: [U-Boot] imx6: [PATCH] Add support for new board "eval1a"
Hi Claudio,
modify
+/dts-v1/;
- chosen {
- memory {
- regulators {
#size-cells = <0>;
reg = <0>;
enable-active-high;
+&cpu0 {
+&clks {
+&fec1 {
- status = "okay";
+&fec2 {
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <2>;
reg = <1>;
+&iomuxc {
- eval1a {
fsl,pins = <
0x1b0b0
0x1b0b0
0x1b0b0
fsl,pins = <
0x1b0b0
0x1b0b0
0x1b0b0
0x1b0b0
0x1b0b0
fsl,pins = <
0x1b0b1
0x1b0b1
fsl,pins = <
0x1b0b1
0x1b0b1
fsl,pins = <
0x1b0b1
0x1b0b1
fsl,pins = <
0x17059
0x10071
0x17059
0x17059
0x17059
0x17059
fsl,pins = <
0x30b0
+&uart1 {
- status = "okay";
+&uart2 {
- status = "okay";
+&usdhc1 {
- status = "okay";
+&wdog1 {
- fsl,wdog_b;
- select MX6ULL
+config SYS_BOARD
- default "eval1a"
+config SYS_VENDOR
- default "eval1a"
- /* 4 bit SD */
The same here.
- udelay(15000);
- to override, implement board_eth_init() */ #if
+defined(CONFIG_FEC_MXC) //extern int fecmxc_initialize(bd_t *bis); +#endif
- return devno;
- return devno;
0); +
- return enable_fec_anatop_clock(0, ENET_50MHZ); } #endif
- setup_fec();
- {NULL, 0},
+}; +#endif
- return 1;
- //u32 val;
- //u32 port;
- return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); }
- The syntax is taken as close as possible with the kwbimage */
+IMAGE_VERSION 2
- where:
+.endm
+.endm
+.endm
+/* include the common plugin code here */ #include +<asm/arch/mx6_plugin.S> diff --git a/configs/eval1a_defconfig b/configs/eval1a_defconfig new file mode 100644 index 0000000000..64e54b207d --- /dev/null +++ b/configs/eval1a_defconfig @@ -0,0 +1,36 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_TARGET_EVAL1A=y +CONFIG_MXC_UART=y +CONFIG_DM_MMC=y +CONFIG_CMD_FAT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MMC=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_FSL_ESDHC=y +CONFIG_CMD_BMODE=y +CONFIG_CMD_BOOTZ=y
+/* +#define CONFIG_SPL +#define CONFIG_SPL_BUILD +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SYS_ONENAND_BASE 0x4E000000 #define +CONFIG_SPL_TEXT_BASE 0x0 #define CONFIG_SPL_SKIP_RELOCATE #define +CONFIG_SPL_SERIAL_SUPPORT */
Lukasz Majewski
Hi Claudio,
Hi Lukasz
In U-Boot now the update to driver model and device tree is now ongoing.
You may want look for some already converted i.MX6 boards as a reference (they are not yet in the mainline, but shall be):
http://patchwork.ozlabs.org/cover/1112747/ http://patchwork.ozlabs.org/cover/1102875/
or this series: https://patchwork.ozlabs.org/patch/1095619/
No, You shouldn't be sorry or feel any inconvenience. This is the role of the community to help you to get your board into the mainline.
Please do not afraid to ask. :-)
Regards Claudio
Hi Claudio,
modify
as
+/dts-v1/;
- chosen {
- memory {
- regulators {
#size-cells = <0>;
reg = <0>;
enable-active-high;
+&cpu0 {
+&clks {
+&fec1 {
- status = "okay";
+&fec2 {
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <2>;
reg = <1>;
+&iomuxc {
- eval1a {
fsl,pins = <
0x1b0b0
0x1b0b0
0x1b0b0
fsl,pins = <
0x1b0b0
0x1b0b0
0x1b0b0
0x1b0b0
0x1b0b0
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
0x17059
0x10071
0x17059
0x17059
0x17059
0x17059
fsl,pins = <
0x30b0
+&uart1 {
- status = "okay";
+&uart2 {
- status = "okay";
+&usdhc1 {
- status = "okay";
+&wdog1 {
- fsl,wdog_b;
- select MX6ULL
+config SYS_BOARD
- default "eval1a"
+config SYS_VENDOR
- default "eval1a"
- /* 4 bit SD */
The same here.
- udelay(15000);
- return devno;
- return devno;
0); +
- setup_fec();
- {NULL, 0},
+}; +#endif
- return 1;
- //u32 val;
- //u32 port;
configure
+IMAGE_VERSION 2
- where:
+.endm
+.endm
+.endm
Lukasz Majewski
Lukasz Majewski
Hi Lukasz
Thank you for your answer and your warm welcome.
Actually I have tried to enable dm_mmc by including
select DM select DM_MMC select OF_CONTROL imply CMD_DM
into kconfig.
Unfortunately, this breaks everything. I don’t even get any output on my console. u-boot breaks at in bootstage_error (id=BOOTSTAGE_ID_NEED_RESET) at include/bootstage.h:381
Do you have any links, where I can find further information about how to implement device model? I have looked into your provided links. Unfortunately i don't see big differences at the moment.
I would really like to get the code up to date and in line with the latest requirements 😊
Thanks for your support. Regards Claudio -----Ursprüngliche Nachricht----- Von: Lukasz Majewski lukma@denx.de Gesendet: Mittwoch, 19. Juni 2019 10:00 An: claudio@databyte.ch Cc: u-boot@lists.denx.de Betreff: Re: [U-Boot] imx6: [PATCH] Add support for new board "eval1a"
Hi Claudio,
Hi Lukasz
Regards Claudio
Hi Claudio,
modify
as
+/dts-v1/;
- chosen {
- memory {
- regulators {
#size-cells = <0>;
reg = <0>;
enable-active-high;
+&cpu0 {
+&clks {
- assigned-clock-rates = <786432000>; };
+&fec1 {
- status = "okay";
+&fec2 {
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <2>;
reg = <1>;
+&iomuxc {
- eval1a {
fsl,pins = <
0x1b0b0
0x1b0b0
0x1b0b0
fsl,pins = <
0x1b0b0
0x1b0b0
0x1b0b0
0x1b0b0
0x1b0b0
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
0x17059
0x10071
0x17059
0x17059
0x17059
0x17059
fsl,pins = <
0x30b0
+&uart1 {
- status = "okay";
+&uart2 {
- status = "okay";
+&usdhc1 {
- status = "okay";
+&wdog1 {
- fsl,wdog_b;
- select MX6ULL
+config SYS_BOARD
- default "eval1a"
+config SYS_VENDOR
- default "eval1a"
+endif diff --git a/board/databyte.ch/eval1a/MAINTAINERS b/board/databyte.ch/eval1a/MAINTAINERS new file mode 100644 index 0000000000..101cbe5660 --- /dev/null +++ b/board/databyte.ch/eval1a/MAINTAINERS @@ -0,0 +1,7 @@ +EVAL1A BOARD +M: C. Hediger info@databyte.ch +S: Maintained +F: board/databyte.ch/eval1a/ +F: include/configs/mx6ullevk.h +F: configs/mx6ull_14x14_evk_defconfig +F: configs/mx6ull_14x14_evk_plugin_defconfig diff --git a/board/databyte.ch/eval1a/Makefile b/board/databyte.ch/eval1a/Makefile new file mode 100644 index 0000000000..4575eb00b7 --- /dev/null +++ b/board/databyte.ch/eval1a/Makefile @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0+ # (C) Copyright 2016 Freescale +Semiconductor, Inc.
+#include <asm/arch/clock.h> +#include <asm/arch/iomux.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/boot_mode.h> #include <asm/io.h> #include +<common.h> #include <fsl_esdhc.h> #include <linux/sizes.h> #include +<mmc.h>
- /* 4 bit SD */
The same here.
- udelay(15000);
+int board_mmc_get_env_dev(int devno) {
- return devno;
+int mmc_map_to_kernel_blk(int devno) {
- return devno;
0); +
- setup_fec();
- {NULL, 0},
+}; +#endif
+int board_mmc_getcd(struct mmc *mmc) {
- return 1;
- //u32 val;
- //u32 port;
configure
+IMAGE_VERSION 2
- where:
+.endm
+.endm
+.endm
Lukasz Majewski
Lukasz Majewski
Hi Claudio,
Hi Lukasz
With DM_MMC you also need to enable CONFIG_BLK
Moreover, I don't know how experienced are you with the DM/DTS (the dm tree command from u-boot prompt), but I would recommend starting with converting subsystem, which is not used to boot the device (for example PMIC, I2C, REGULATOR, etc).
In that way you would have a grasp of how things are going and avoid frustration with bricking the board.
into kconfig.
Hi Claudio,
Hi Lukasz
Regards Claudio
Hi Claudio,
modify
as
+/dts-v1/;
- chosen {
- memory {
- regulators {
#size-cells = <0>;
reg = <0>;
enable-active-high;
+&cpu0 {
+&clks {
+&fec1 {
- status = "okay";
+&fec2 {
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <2>;
reg = <1>;
+&iomuxc {
- eval1a {
fsl,pins = <
fsl,pins = <
0x1b0b0
0x1b0b0
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
0x17059
0x10071
0x17059
0x17059
0x17059
0x17059
fsl,pins = <
+&uart1 {
- status = "okay";
+&uart2 {
- status = "okay";
+&usdhc1 {
- status = "okay";
+&wdog1 {
- fsl,wdog_b;
- select MX6ULL
+config SYS_BOARD
- default "eval1a"
+config SYS_VENDOR
- default "eval1a"
- /* 4 bit SD */
The same here.
- udelay(15000);
- return devno;
- return devno;
- setup_fec();
- {NULL, 0},
+}; +#endif
- return 1;
- //u32 val;
- //u32 port;
configure
+IMAGE_VERSION 2
- where:
+.endm
+.endm
+.endm
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
claudio@databyte.ch
Lukasz Majewski
