[U-Boot] Please pull u-boot-sunxi master
Hi Tom,
Here is another sunxi pull-req for v2015.10, highlights:
-Bug fixes and cleanups to the spl nand support which was merged at the beginning of the v2015.10 cycle -Add support for a few new boards -Misc fixes
The following changes since commit f875bbb49111c308b90b9ca74d1b79f69498b278:
ARM: dts: uniphier: add ProXstream2 and PH1-LD6b SoC/board support (2015-08-31 00:29:23 +0900)
http://git.denx.de/u-boot-sunxi.git master
for you to fetch changes up to fa5e102019e28a5936e52d6aa9f5624cf1744a35:
sunxi: increase SYS_MONITOR_LEN (2015-08-31 16:03:05 +0200)
---------------------------------------------------------------- Boris Brezillon (2): sunxi_nand_spl: clear status flags in SPL implementation sunxi: increase SYS_MONITOR_LEN
Chen-Yu Tsai (1): sunxi: Enable non-secure access to RTC on sun6i (A31s)
Hans de Goede (26): sunxi: axp221: Allow specifying dcdc2 voltage via Kconfig sunxi: Add support for gt90h-v4 tablets sunxi: musb: Drop no longer accurate comment in Kconfig help text sunxi: Drop LCD_MODE from A13-OLinuxIno defconfigs sunxi: Add CONFIG_MMC0_CD_PIN to various boards sunxi_nand_spl: Fix CONFIG_SPL_NAND_SUNXI handling sunxi_nand_spl: Drop unnecessary temp buf sunxi_nand_spl: We only need to reset the nand chip once sunxi_nand_spl: Do not bother writing the spare-area reg in syndrome mode sunxi_nand_spl: Use SYS_NAND_SELF_INIT and only do nand init when necessary sunxi_nand_spl: Make sure the DMA controller is enabled sunxi_nand_spl: Turn off clocks when we're done with the nand sunxi_nand_spl: Add proper cache flusing sunxi_nand_spl: Use kernel driver algorithm for determining ecc_mode / _off sunxi_nand_spl: Add support for sun4i and sun5i SoCs sunxi_nand_spl: Properly config page-size in the nand ctl register sunxi_nand_spl: Parametrize lowlevel read functions sunxi_nand_spl: Auto detect nand configuration parameters sunxi_nand_spl: Add support for backup boot partitions sunxi_nand_spl: Rename SPL_NAND_SUNXI to NAND_SUNXI sunxi_nand_spl: Remove NAND_SUNXI_SPL_SYNDROME_PARTITIONS_END mtd: nand: Make CONFIG_SYS_NAND_U_BOOT_OFFS configurable through Kconfig sunxi: Ampe_A76_defconfig: Add otg id pin configuration sunxi: Add inet97fv2_defconfig sunxi: Add inet98v_rev2 defconfig and dts file sunxi: Fix MAINTAINERS board sorting
Marcus Cooper (1): sunxi: Add support for the Olimex A20 EVB
Yousong Zhou (1): sunxi: mmc: set transfer timeout according to byte_cnt.
arch/arm/cpu/armv7/sunxi/Makefile | 1 + arch/arm/cpu/armv7/sunxi/board.c | 5 + arch/arm/cpu/armv7/sunxi/tzpc.c | 18 ++ arch/arm/dts/Makefile | 3 + arch/arm/dts/sun5i-a13-inet-98v-rev2.dts | 236 ++++++++++++++++++++++++++ arch/arm/dts/sun7i-a20-olimex-som-evb.dts | 244 +++++++++++++++++++++++++++ arch/arm/dts/sun8i-a23-gt90h-v4.dts | 145 ++++++++++++++++ arch/arm/include/asm/arch-sunxi/tzpc.h | 23 +++ board/sunxi/Kconfig | 1 + board/sunxi/MAINTAINERS | 10 +- board/sunxi/board.c | 34 ++-- configs/A10-OLinuXino-Lime_defconfig | 1 + configs/A13-OLinuXinoM_defconfig | 2 +- configs/A13-OLinuXino_defconfig | 2 +- configs/A20-OLinuXino-Lime_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 16 ++ configs/Ampe_A76_defconfig | 1 + configs/Cubieboard_defconfig | 1 + configs/Cubietruck_defconfig | 1 + configs/gt90h_v4_defconfig | 26 +++ configs/inet97fv2_defconfig | 20 +++ configs/inet98v_rev2_defconfig | 22 +++ drivers/mmc/sunxi_mmc.c | 6 +- drivers/mtd/nand/Kconfig | 57 ++----- drivers/mtd/nand/Makefile | 2 +- drivers/mtd/nand/sunxi_nand_spl.c | 268 +++++++++++++++++------------- drivers/power/Kconfig | 9 + drivers/usb/musb-new/Kconfig | 4 +- include/configs/sunxi-common.h | 12 +- 29 files changed, 990 insertions(+), 181 deletions(-) create mode 100644 arch/arm/cpu/armv7/sunxi/tzpc.c create mode 100644 arch/arm/dts/sun5i-a13-inet-98v-rev2.dts create mode 100644 arch/arm/dts/sun7i-a20-olimex-som-evb.dts create mode 100644 arch/arm/dts/sun8i-a23-gt90h-v4.dts create mode 100644 arch/arm/include/asm/arch-sunxi/tzpc.h create mode 100644 configs/A20-Olimex-SOM-EVB_defconfig create mode 100644 configs/gt90h_v4_defconfig create mode 100644 configs/inet97fv2_defconfig create mode 100644 configs/inet98v_rev2_defconfig
Regards,
Hans
On Mon, Aug 31, 2015 at 06:05:49PM +0200, Hans de Goede wrote:
Hi Tom,
Hans de Goede
