[PATCH] tools: ftdgrep: correct the find regions loop in do_fdtgrep
Update the loop executed in do_fdtgrep to find all the regions and add a test for count > max_region only when the second passes is executed.
This patch solve an issue if the number of region found (count) is greater then the default value (max_region = count = 100): the second pass is never executed, because the loop stops after the first pass (i = 0, count > 100, max_regions = 100) with error -1 and the error message "Internal error with fdtgrep_find_region".
I also update the error message.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
tools/fdtgrep.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/tools/fdtgrep.c b/tools/fdtgrep.c index 8f44f599c1..bcf06b871d 100644 --- a/tools/fdtgrep.c +++ b/tools/fdtgrep.c @@ -823,8 +823,10 @@ static int do_fdtgrep(struct display_info *disp, const char *filename) } if (count <= max_regions) break; + } + if (count > max_regions) { free(region); - fprintf(stderr, "Internal error with fdtgrep_find_region)(\n"); + fprintf(stderr, "Internal error with fdtgrep_find_region()\n"); return -1; }
Hi Patrick,
On Fri, 10 Jan 2020 08:50:31 +0100 Patrick Delaunay patrick.delaunay@st.com wrote: ...
- if (count > max_regions) { free(region);
This change moved free(region) out of the loop. If you do so, then please also change malloc() in the loop to realloc():
region = realloc(region, count * sizeof(struct fdt_region));
-- Anatolij
From: Anatolij Gustschin agust@denx.de Sent: dimanche 12 janvier 2020 20:51
Hi Patrick,
char *filename)
Yes, I will push V2 with realloc to avoid the memory leak that I introduced..
Thanks for review
-- Anatolij
Patrick
Anatolij Gustschin
Patrick DELAUNAY
Patrick Delaunay
