[U-Boot] [PATCH v2 1/5] x86: coreboot: Fix cosmetic issues
Clean up arch/x86/cpu/coreboot.c to fix several cosmetic issues.
Signed-off-by: Bin Meng bmeng.cn@gmail.com Acked-by: Simon Glass sjg@chromium.org
Changes in v2: - Drop v1 patches already applied - Add <asm/io.h> inclusion back
arch/x86/cpu/coreboot/coreboot.c | 27 +++------------------------ arch/x86/include/asm/u-boot-x86.h | 1 - 2 files changed, 3 insertions(+), 25 deletions(-)
diff --git a/arch/x86/cpu/coreboot/coreboot.c b/arch/x86/cpu/coreboot/coreboot.c index 4cdd0d4..c3dfd28 100644 --- a/arch/x86/cpu/coreboot/coreboot.c +++ b/arch/x86/cpu/coreboot/coreboot.c @@ -7,16 +7,10 @@ */
#include <common.h> -#include <asm/u-boot-x86.h> -#include <flash.h> #include <netdev.h> -#include <ns16550.h> -#include <asm/msr.h> -#include <asm/cache.h> -#include <asm/cpu.h> #include <asm/io.h> +#include <asm/msr.h> #include <asm/mtrr.h> -#include <asm/arch/tables.h> #include <asm/arch/sysinfo.h> #include <asm/arch/timestamp.h>
@@ -53,13 +47,6 @@ int last_stage_init(void) return 0; }
-#ifndef CONFIG_SYS_NO_FLASH -ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) -{ - return 0; -} -#endif - int board_eth_init(bd_t *bis) { return pci_eth_init(bis); @@ -67,7 +54,8 @@ int board_eth_init(bd_t *bis)
void board_final_cleanup(void) { - /* Un-cache the ROM so the kernel has one + /* + * Un-cache the ROM so the kernel has one * more MTRR available. * * Coreboot should have assigned this to the @@ -91,15 +79,6 @@ void board_final_cleanup(void) outb(0xcb, 0xb2); }
-void panic_puts(const char *str) -{ - NS16550_t port = (NS16550_t)0x3f8; - - NS16550_init(port, 1); - while (*str) - NS16550_putc(port, *str++); -} - int misc_init_r(void) { return 0; diff --git a/arch/x86/include/asm/u-boot-x86.h b/arch/x86/include/asm/u-boot-x86.h index be103c0..d1d21ed 100644 --- a/arch/x86/include/asm/u-boot-x86.h +++ b/arch/x86/include/asm/u-boot-x86.h @@ -16,7 +16,6 @@ void init_gd(gd_t *id, u64 *gdt_addr); void setup_gdt(gd_t *id, u64 *gdt_addr); int init_cache(void); int cleanup_before_linux(void); -void panic_puts(const char *str);
/* cpu/.../timer.c */ void timer_isr(void *);
Changes in v2:
Applied to u-boot-x86, thanks!
Bin Meng
