[U-Boot] [PATCH] arm: socfpga: stratix10: Add generic FPGA reconfig mailbox API for S10
Add a generic mailbox API for FPGA reconfig status which can be called by others. This new function accepts 2 different mailbox commands: CONFIG_STATUS or RECONFIG_STATUS.
Signed-off-by: Ang, Chee Hong chee.hong.ang@intel.com --- arch/arm/mach-socfpga/include/mach/mailbox_s10.h | 3 +- arch/arm/mach-socfpga/mailbox_s10.c | 48 ++++++++++++++++++++++++ 2 files changed, 50 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h index 81a609d..660df35 100644 --- a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h +++ b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h @@ -140,5 +140,6 @@ int mbox_qspi_open(void); #endif
int mbox_reset_cold(void); - +int mbox_get_fpga_config_status(u32 cmd); +int mbox_get_fpga_config_status_psci(u32 cmd); #endif /* _MAILBOX_S10_H_ */ diff --git a/arch/arm/mach-socfpga/mailbox_s10.c b/arch/arm/mach-socfpga/mailbox_s10.c index 0d906c3..345485c 100644 --- a/arch/arm/mach-socfpga/mailbox_s10.c +++ b/arch/arm/mach-socfpga/mailbox_s10.c @@ -342,6 +342,54 @@ int mbox_reset_cold(void) return 0; }
+/* Accepted commands: CONFIG_STATUS or RECONFIG_STATUS */ +static __always_inline int mbox_get_fpga_config_status_common(u32 cmd) +{ + u32 reconfig_status_resp_len; + u32 reconfig_status_resp[RECONFIG_STATUS_RESPONSE_LEN]; + int ret; + + reconfig_status_resp_len = RECONFIG_STATUS_RESPONSE_LEN; + ret = mbox_send_cmd_common(MBOX_ID_UBOOT, cmd, + MBOX_CMD_DIRECT, 0, NULL, 0, + &reconfig_status_resp_len, + reconfig_status_resp); + if (!ret) { + /* Check for any error */ + ret = reconfig_status_resp[RECONFIG_STATUS_STATE]; + if (ret && ret != MBOX_CFGSTAT_STATE_CONFIG) + return ret; + + /* Make sure nStatus is not 0 */ + ret = reconfig_status_resp[RECONFIG_STATUS_PIN_STATUS]; + if (!(ret & RCF_PIN_STATUS_NSTATUS)) + return MBOX_CFGSTAT_STATE_ERROR_HARDWARE; + + ret = reconfig_status_resp[RECONFIG_STATUS_SOFTFUNC_STATUS]; + if (ret & RCF_SOFTFUNC_STATUS_SEU_ERROR) + return MBOX_CFGSTAT_STATE_ERROR_HARDWARE; + + if ((ret & RCF_SOFTFUNC_STATUS_CONF_DONE) && + (ret & RCF_SOFTFUNC_STATUS_INIT_DONE) && + !reconfig_status_resp[RECONFIG_STATUS_STATE]) + return 0; /* configuration success */ + else + return MBOX_CFGSTAT_STATE_CONFIG; + } + + return ret; +} + +int mbox_get_fpga_config_status(u32 cmd) +{ + return mbox_get_fpga_config_status_common(cmd); +} + +int __secure mbox_get_fpga_config_status_psci(u32 cmd) +{ + return mbox_get_fpga_config_status_common(cmd); +} + int mbox_send_cmd(u8 id, u32 cmd, u8 is_indirect, u32 len, u32 *arg, u8 urgent, u32 *resp_buf_len, u32 *resp_buf) {
What "others" can call this ?
Why __always_inline ?
- u32 reconfig_status_resp_len;
- u32 reconfig_status_resp[RECONFIG_STATUS_RESPONSE_LEN];
- int ret;
- reconfig_status_resp_len = RECONFIG_STATUS_RESPONSE_LEN;
- ret = mbox_send_cmd_common(MBOX_ID_UBOOT, cmd,
- if (!ret) {
if (ret) return ret;
return ret;
else
- return ret;
- return mbox_get_fpga_config_status_common(cmd);
This is a common function used to check the readiness of the FPGA. FPGA configuration drivers will need to call this to make sure the FPGA configuration is successfully completed and running. These FPGA configuration drivers will be submitted soon after this patch.
diff --git a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h index 81a609d..660df35 100644 --- a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h +++ b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h @@ -140,5 +140,6 @@ int mbox_qspi_open(void); #endif int mbox_reset_cold(void);
+int mbox_get_fpga_config_status(u32 cmd); +int mbox_get_fpga_config_status_psci(u32 cmd); #endif /* _MAILBOX_S10_H_ */ diff --git a/arch/arm/mach-socfpga/mailbox_s10.c b/arch/arm/mach- socfpga/mailbox_s10.c index 0d906c3..345485c 100644 --- a/arch/arm/mach-socfpga/mailbox_s10.c +++ b/arch/arm/mach-socfpga/mailbox_s10.c @@ -342,6 +342,54 @@ int mbox_reset_cold(void) return 0; } +/* Accepted commands: CONFIG_STATUS or RECONFIG_STATUS */ +static __always_inline int mbox_get_fpga_config_status_common(u32 cmd)
This function is needed in 2 sections. Our u-boot run in normal code section and '__secure' section which mainly used for PSCI services. Refer to the 'mbox_get_fpga_config_status()' and 'mbox_get_fpga_config_status_psci()' below. These 2 functions run in 2 different sections and they need to call this function.
- int ret;
- if (!ret) {
Will be addressed in v2 patch.
return ret;
ret =
ret =
else
- return ret;
So this should be in drivers/fpga/ ?
Also, don't add dead code, just submit this alongside the user of this code.
But why does this need to be __always_inline ? The compiler can decide what's best.
- int ret;
- if (!ret) {
return ret;
ret =
ret =
else
- return ret;
Yes. There is a FPGA configuration driver under this folder. Will submit soon.
The reason I try to get this common function upstream is because my colleague is trying to upstream socfpga dwmac driver which also need to call this function to check whether the soft Ip running on FPGA for the dwmac driver is up and running. If I bundle this code alongside with my FPGA configuration driver, it might take longer time to get into the mainline. So this common function is blocking other to upstream his/her code.
This is dangerous. Let me explain in more details why we need this, '__secure' section and normal '.code' section exist in different time. '.code' section no longer valid once u-boot boot to OS, but '__secure' section still exist after booting to OS because OS need to call PSCI services to achieve certain things. We need to make sure both sections contain the full code, therefore we need to enforce the compiler to duplicate this piece of code to both sections as well.
- u32
- int ret;
0,
- if (!ret) {
ret =
return ret;
ret =
return
ret =
return
E])
success */
else
- return ret;
SoCFPGA dwmac support is already upstream. Can you explain why it needs to query the FPGA at all ? Is the whole dwmac in the FPGA ? Or is the dwmac just routed through FPGA ?
I'm not really fond of accepting dead code, on which code I didn't even see and design that's unclear depends.
How does the __always_inline help with that ? [...]
dwmac driver need to call this function to access PCS (MAC PHY) which is routed through FPGA.
I understand. Can I submit another FPGA driver patchsets and refer this patch as the dependency ? The FPGA driver patchsets is the user of the common function.
diff --git a/arch/arm/mach- socfpga/include/mach/mailbox_s10.h b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h index 81a609d..660df35 100644 --- a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h +++ b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h @@ -140,5 +140,6 @@ int mbox_qspi_open(void); #endif int mbox_reset_cold(void);
mbox_get_fpga_config_status() (in .code section) mbox_get_fpga_config_status_psci() (in __secure section) Both functions need to implement mbox_get_fpga_config_status_common(). So we clone this mbox_get_fpga_config_status_common() into mbox_get_fpga_config_status() & mbox_get_fpga_config_status_psci() without duplicating the same code in those 2 functions. mbox_get_fpga_config_status() exist when u-boot is active. So this function is callable by u-boot itself. mbox_get_fpga_config_status_psci() exist after u-boot boot the OS. U- boot will actually copy this function to another region of memory which mostly consist of PSCI/SMC handlers. These services are called by OS to do certain stuffs like reboot, access secure hardware and etc. So is actually same piece of code that need to exist at 2 different stage. arch/arm/mach-socfpga/mailbox_s10.c already has a couple of other functions which also use this method to make the same piece of code exist in 2 different regions.
On 09/26/2018 11:03 AM, chee.hong.ang@intel.com wrote: > > > > From: "Ang, Chee Hong" chee.hong.ang@intel.com > > Add a generic mailbox API for FPGA reconfig status which > can be > called by others. This new function accepts 2 different > mailbox > commands: CONFIG_STATUS or RECONFIG_STATUS. What "others" can call this ?
Then shouldn't this be modeled in the DT ? And if it is properly modeled in the DT, the FPGA driver code should do any such checking, not the EMAC code.
Yes please
> Signed-off-by: Ang, Chee Hong chee.hong.ang@intel.com > --- > arch/arm/mach-socfpga/include/mach/mailbox_s10.h | 3 +- > arch/arm/mach-socfpga/mailbox_s10.c | 48 > ++++++++++++++++++++++++ > 2 files changed, 50 insertions(+), 1 deletion(-) > > diff --git a/arch/arm/mach- > socfpga/include/mach/mailbox_s10.h > b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h > index 81a609d..660df35 100644 > --- a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h > +++ b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h > @@ -140,5 +140,6 @@ int mbox_qspi_open(void); > #endif > > int mbox_reset_cold(void); > - > +int mbox_get_fpga_config_status(u32 cmd); > +int mbox_get_fpga_config_status_psci(u32 cmd); > #endif /* _MAILBOX_S10_H_ */ > diff --git a/arch/arm/mach-socfpga/mailbox_s10.c > b/arch/arm/mach- > socfpga/mailbox_s10.c > index 0d906c3..345485c 100644 > --- a/arch/arm/mach-socfpga/mailbox_s10.c > +++ b/arch/arm/mach-socfpga/mailbox_s10.c > @@ -342,6 +342,54 @@ int mbox_reset_cold(void) > return 0; > } > > +/* Accepted commands: CONFIG_STATUS or RECONFIG_STATUS */ > +static __always_inline int > mbox_get_fpga_config_status_common(u32 > cmd) Why __always_inline ?
This seems like a really hacky way to do it. Wouldn't it make more sense to use some linker script trick for this ?
OK
Ang, Chee Hong
