[U-Boot] [PATCH v5] Add imls utility command
Changelog from v4:
- Added flash_bad_block() function. - Added a README file. - Replaced <sys/user.h> with <asm/page.h>
Signed-off-by: Marco Stornelli marco.stornelli@gmail.com ---
diff --git a/tools/imls/Makefile b/tools/imls/Makefile new file mode 100644 index 0000000..d654658 --- /dev/null +++ b/tools/imls/Makefile @@ -0,0 +1,106 @@ +# +# (C) Copyright 2009 Marco Stornelli marco.stornelli@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +HOST_CFLAGS = -Wall -pedantic + +# Generated executable files +BIN_FILES-y += imls + +# Source files which exist outside the tools directory +EXT_OBJ_FILES-y += lib_generic/crc32.o +EXT_OBJ_FILES-y += lib_generic/md5.o +EXT_OBJ_FILES-y += lib_generic/sha1.o +EXT_OBJ_FILES-y += common/image.o + +# Source files located in the tools directory +OBJ_FILES-y += imls.o + +# Flattened device tree objects +LIBFDT_OBJ_FILES-y += fdt.o +LIBFDT_OBJ_FILES-y += fdt_ro.o +LIBFDT_OBJ_FILES-y += fdt_rw.o +LIBFDT_OBJ_FILES-y += fdt_strerror.o +LIBFDT_OBJ_FILES-y += fdt_wip.o + +# now $(obj) is defined +SRCS += $(addprefix $(SRCTREE)/,$(EXT_OBJ_FILES-y:.o=.c)) +SRCS += $(addprefix $(SRCTREE)/tools/,$(OBJ_FILES-y:.o=.c)) +SRCS += $(addprefix $(SRCTREE)/libfdt/,$(LIBFDT_OBJ_FILES-y:.o=.c)) +BINS := $(addprefix $(obj),$(sort $(BIN_FILES-y))) +LIBFDT_OBJS := $(addprefix $(obj),$(LIBFDT_OBJ_FILES-y)) + +# +# Use native tools and options +# Define __KERNEL_STRICT_NAMES to prevent typedef overlaps +# +CPPFLAGS = -idirafter $(SRCTREE)/include \ + -idirafter $(OBJTREE)/include2 \ + -idirafter $(OBJTREE)/include \ + -I $(SRCTREE)/libfdt \ + -I $(SRCTREE)/tools \ + -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES +CFLAGS = $(HOST_CFLAGS) $(CPPFLAGS) -O + +# No -pedantic switch to avoid libfdt compilation warnings +FIT_CFLAGS = -Wall $(CPPFLAGS) -O + +CC = $(CROSS_COMPILER)gcc +STRIP = $(CROSS_COMPILER)strip + +ifeq ($(MTD_VERSION),old) +CPPFLAGS += -DMTD_OLD +endif + +all: $(BINS) + +$(obj)imls: $(obj)imls.o $(obj)crc32.o $(obj)image.o $(obj)md5.o \ + $(obj)sha1.o $(LIBFDT_OBJS) + $(CC) $(CFLAGS) -o $@ $^ + $(STRIP) $@ + +# Some files complain if compiled with -pedantic, use FIT_CFLAGS +$(obj)image.o: $(SRCTREE)/common/image.c + $(CC) -g $(FIT_CFLAGS) -c -o $@ $< + +$(obj)imls.o: imls.c + $(CC) -g $(FIT_CFLAGS) -c -o $@ $< + +# Some of the tool objects need to be accessed from outside the tools directory +$(obj)%.o: $(SRCTREE)/common/%.c + $(CC) -g $(FIT_CFLAGS) -c -o $@ $< + +$(obj)%.o: $(SRCTREE)/lib_generic/%.c + $(CC) -g $(CFLAGS) -c -o $@ $< + +$(obj)%.o: $(SRCTREE)/libfdt/%.c + $(CC) -g $(FIT_CFLAGS) -c -o $@ $< + +clean: + rm -rf *.o imls + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/tools/imls/README b/tools/imls/README new file mode 100644 index 0000000..63d639d --- /dev/null +++ b/tools/imls/README @@ -0,0 +1,57 @@ +# +# (C) Copyright 2009 Marco Stornelli marco.stornelli@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# The files in this directory are free software; you can redistribute +# them and/or modify them under the terms of the GNU General Public +# License as published by the Free Software Foundation; either +# version 2 of the License, or (at your option) any later version. +# +# These files are distributed in the hope that they will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +IMLS +------------- + +imls is an implementation of a Linux command line tool to access +to raw flash partitions and list images made with mkimage command. + +For building against older versions of the MTD headers (meaning before +v2.6.8-rc1) it is required to pass the argument "MTD_VERSION=old" to +make. + +Usage examples +-------------- + +1) Flash with sectors of 128KiB and 32 sectors: + +> imls -s 32 -c 131072 /dev/mtd0 +Searching... +Image Name: foo +Created: Fri Apr 10 18:11:30 2009 +Image Type: Intel x86 Linux Standalone Program (uncompressed) +Data Size: 10716 Bytes = 10.46 kB = 0.01 MB +Load Address: 00000000 +Entry Point: 00000000 + +2) Flash with sectors of 64KiB and 128 sectors and with a search offset of one +sector: + +> imls -o 1 -s 128 -c 65536 /dev/mtd0 +Searching... +Image Name: foo +Created: Fri Apr 10 18:11:30 2009 +Image Type: Intel x86 Linux Standalone Program (uncompressed) +Data Size: 10716 Bytes = 10.46 kB = 0.01 MB +Load Address: 00000000 +Entry Point: 00000000 diff --git a/tools/imls/imls.c b/tools/imls/imls.c new file mode 100644 index 0000000..583272a --- /dev/null +++ b/tools/imls/imls.c @@ -0,0 +1,270 @@ +/* + * (C) Copyright 2009 Marco Stornelli marco.stornelli@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <errno.h> +#include <fcntl.h> +#include <stdio.h> +#include <stdlib.h> +#include <stddef.h> +#include <string.h> +#include <sys/types.h> +#include <sys/ioctl.h> +#include <sys/stat.h> +#include <unistd.h> +#include <asm/page.h> + +#ifdef MTD_OLD +#include <stdint.h> +#include <linux/mtd/mtd.h> +#else +#define __user /* nothing */ +#include <mtd/mtd-user.h> +#endif + +#include <sha1.h> +#include <fdt.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <image.h> + +#define MIN(a, b) (((a) < (b)) ? (a) : (b)) + +extern unsigned long crc32(unsigned long crc, const char *buf, unsigned int len); +static void usage(void); +static int image_verify_header(char *ptr, int fd); +static int flash_bad_block(int fd, uint8_t mtd_type, loff_t start); + +char *cmdname; +char *devicefile; + +unsigned int sectorcount = 0; +int sflag = 0; +unsigned int sectoroffset = 0; +unsigned int sectorsize = 0; +int cflag = 0; + +int main (int argc, char **argv) +{ + int fd = -1, err = 0, readbyte = 0, j; + struct mtd_info_user mtdinfo; + char buf[sizeof(image_header_t)]; + int found = 0; + + cmdname = *argv; + + while (--argc > 0 && **++argv == '-') { + while (*++*argv) { + switch (**argv) { + case 's': + if (--argc <= 0) + usage (); + sectorcount = (unsigned int)atoi(*++argv); + sflag = 1; + goto NXTARG; + case 'o': + if (--argc <= 0) + usage (); + sectoroffset = (unsigned int)atoi(*++argv); + goto NXTARG; + + case 'c': + if (--argc <= 0) + usage (); + sectorsize = (unsigned int)atoi(*++argv); + cflag = 1; + goto NXTARG; + default: + usage (); + } + } +NXTARG: ; + } + + if (argc != 1 || cflag == 0 || sflag == 0) + usage(); + + devicefile = *argv; + + fd = open(devicefile, O_RDONLY); + if (fd < 0) { + fprintf (stderr, "%s: Can't open %s: %s\n", + cmdname, devicefile, strerror(errno)); + exit(EXIT_FAILURE); + } + + err = ioctl(fd, MEMGETINFO, &mtdinfo); + if (err < 0) { + fprintf(stderr, "%s: Cannot get MTD information: %s\n",cmdname, + strerror(errno)); + exit(EXIT_FAILURE); + } + + if (mtdinfo.type != MTD_NORFLASH && mtdinfo.type != MTD_NANDFLASH) { + fprintf(stderr, "%s: Unsupported flash type %u\n", + cmdname, mtdinfo.type); + exit(EXIT_FAILURE); + } + + if (sectorsize * sectorcount != mtdinfo.size) { + fprintf(stderr, "%s: Partition size (%d) incompatible with " + "sector size and count\n", cmdname, mtdinfo.size); + exit(EXIT_FAILURE); + } + + if (sectorsize * sectoroffset >= mtdinfo.size) { + fprintf(stderr, "%s: Partition size (%d) incompatible with " + "sector offset given\n", cmdname, mtdinfo.size); + exit(EXIT_FAILURE); + } + + if (sectoroffset > sectorcount - 1) { + fprintf(stderr, "%s: Sector offset cannot be grater than " + "sector count minus one\n", cmdname); + exit(EXIT_FAILURE); + } + + printf("Searching....\n"); + + for (j = sectoroffset; j < sectorcount; ++j) { + + if (lseek(fd, j*sectorsize, SEEK_SET) != j*sectorsize) { + fprintf(stderr, "%s: lseek failure: %s\n", + cmdname, strerror(errno)); + exit(EXIT_FAILURE); + } + + err = flash_bad_block(fd, mtdinfo.type, j*sectorsize); + if (err < 0) + exit(EXIT_FAILURE); + if (err) + continue; /* Skip and jump to next */ + + readbyte = read(fd, buf, sizeof(image_header_t)); + if (readbyte != sizeof(image_header_t)) { + fprintf(stderr, "%s: Can't read from device: %s\n", + cmdname, strerror(errno)); + exit(EXIT_FAILURE); + } + + if (fdt_check_header(buf)) { + /* old-style image */ + if (image_verify_header(buf, fd)) { + found = 1; + image_print_contents((image_header_t *)buf); + } + } else { + /* FIT image */ + fit_print_contents(buf); + } + + } + + close(fd); + + if(!found) + printf("No images found\n"); + + exit(EXIT_SUCCESS); +} + +void usage() +{ + fprintf (stderr, "Usage:\n" + " %s [-o offset] -c size -s count device\n" + " -o ==> number of sectors to use as offset\n" + " -s ==> number of sectors\n" + " -c ==> size of sectors (byte)\n", + cmdname); + + exit(EXIT_FAILURE); +} + +static int image_verify_header(char *ptr, int fd) +{ + int len, nread; + char *data; + uint32_t checksum; + image_header_t *hdr = (image_header_t *)ptr; + char buf[PAGE_SIZE]; + + if (image_get_magic(hdr) != IH_MAGIC) + return 0; + + data = (char *)hdr; + len = image_get_header_size(); + + checksum = image_get_hcrc(hdr); + hdr->ih_hcrc = htonl(0); /* clear for re-calculation */ + + if (crc32(0, data, len) != checksum) { + fprintf(stderr, + "%s: Maybe image found but it has bad header checksum!\n", + cmdname); + return 0; + } + + len = image_get_size(hdr); + checksum = 0; + + while (len > 0) { + nread = read(fd, buf, MIN(len,PAGE_SIZE)); + if (nread != MIN(len,PAGE_SIZE)) { + fprintf(stderr, + "%s: Error while reading: %s\n", + cmdname, strerror(errno)); + exit(EXIT_FAILURE); + } + checksum = crc32(checksum, buf, nread); + len -= nread; + } + + if (checksum != image_get_dcrc(hdr)) { + fprintf (stderr, + "%s: Maybe image found but it has corrupted data!\n", + cmdname); + return 0; + } + + return 1; +} + +/* + * Test for bad block on NAND, just returns 0 on NOR, on NAND: + * 0 - block is good + * > 0 - block is bad + * < 0 - failed to test + */ +static int flash_bad_block(int fd, uint8_t mtd_type, loff_t start) +{ + if (mtd_type == MTD_NANDFLASH) { + int badblock = ioctl(fd, MEMGETBADBLOCK, &start); + + if (badblock < 0) { + fprintf(stderr,"%s: Cannot read bad block mark: %s\n", + cmdname, strerror(errno)); + return badblock; + } + + if (badblock) { + return badblock; + } + } + + return 0; +}
Dear Marco,
In message 49E05B72.602@gmail.com you wrote:
Changelog from v4:
You get your patches wrong.
The commit message (i. e. a description of the patch that explains wht it is good for, goes above your Signed-off-by: line message. What you have there is unusable.
The text you added there must go as a comment, i. e. below the "---" line following your Signed-off-by: line.
Marco
