[PATCH v2] test/py: mii: Add tests for mii command
Add below test cases for mii commands: mii_info -To display MII PHY info mii_list - To list MII devices mii_set_device - To set MII device mii_read - To reads register from MII PHY address mii_dump - To display data from MII PHY address
Signed-off-by: Love Kumar love.kumar@amd.com --- Changes in v2: - Get MII device list from env instead of auto-detecting it - Set the MII device to its current device after testing so that it won't impact next cases --- test/py/tests/test_mii.py | 92 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 92 insertions(+) create mode 100644 test/py/tests/test_mii.py
diff --git a/test/py/tests/test_mii.py b/test/py/tests/test_mii.py new file mode 100644 index 000000000000..e9bdbadffc8e --- /dev/null +++ b/test/py/tests/test_mii.py @@ -0,0 +1,92 @@ +# SPDX-License-Identifier: GPL-2.0 +# (C) Copyright 2023, Advanced Micro Devices, Inc. + +import pytest +import re + +""" +Note: This test doesn't rely on boardenv_* configuration value but they can +change test behavior. + +For example: + +# Setup env__mii_deive_test_skip to True if tests with ethernet PHY devices +# should be skipped. For example: Missing PHY device +env__mii_device_test_skip = True + +# Setup env__mii_device_test to set the MII device names. Test will be skipped +# if env_mii_device_test is not set +env__mii_device_test = { + "device_list": ["eth0", "eth1"], +} +""" + +@pytest.mark.buildconfigspec("cmd_mii") +def test_mii_info(u_boot_console): + if u_boot_console.config.env.get("env__mii_device_test_skip", False): + pytest.skip("MII device test is not enabled!") + expected_output = "PHY" + output = u_boot_console.run_command("mii info") + if not re.search(r"PHY (.+?):", output): + pytest.skip("PHY device does not exist!") + assert expected_output in output + +@pytest.mark.buildconfigspec("cmd_mii") +def test_mii_list(u_boot_console): + if u_boot_console.config.env.get("env__mii_device_test_skip", False): + pytest.skip("MII device test is not enabled!") + + f = u_boot_console.config.env.get("env__mii_device_test", None) + if not f: + pytest.skip("No MII device to test!") + + dev_list = f.get("device_list") + if len(dev_list) == 0: + pytest.fail("No MII device list provided via env__mii_device_test!") + + expected_output = "Current device" + output = u_boot_console.run_command("mii device") + mii_devices = ( + re.search(r"MII devices: '(.+)'", output).groups()[0].replace("'", "").split() + ) + + assert len([x for x in dev_list if x in mii_devices]) == len(dev_list) + assert expected_output in output + +@pytest.mark.buildconfigspec("cmd_mii") +def test_mii_set_device(u_boot_console): + test_mii_list(u_boot_console) + f = u_boot_console.config.env.get("env__mii_device_test", None) + dev_list = f.get("device_list") + output = u_boot_console.run_command("mii device") + current_dev = re.search(r"Current device: '(.+?)'", output).groups()[0] + + for dev in dev_list: + u_boot_console.run_command(f"mii device {dev}") + output = u_boot_console.run_command("echo $?") + assert output.endswith("0") + + u_boot_console.run_command(f"mii device {current_dev}") + output = u_boot_console.run_command("mii device") + dev = re.search(r"Current device: '(.+?)'", output).groups()[0] + assert current_dev == dev + +@pytest.mark.buildconfigspec("cmd_mii") +def test_mii_read(u_boot_console): + test_mii_list(u_boot_console) + output = u_boot_console.run_command("mii info") + eth_addr = hex(int(re.search(r"PHY (.+?):", output).groups()[0], 16)) + u_boot_console.run_command(f"mii read {eth_addr} 0") + output = u_boot_console.run_command("echo $?") + assert output.endswith("0") + +@pytest.mark.buildconfigspec("cmd_mii") +def test_mii_dump(u_boot_console): + test_mii_list(u_boot_console) + expected_response = "PHY control register" + output = u_boot_console.run_command("mii info") + eth_addr = hex(int(re.search(r"PHY (.+?):", output).groups()[0], 16)) + response = u_boot_console.run_command(f"mii dump {eth_addr} 0") + assert expected_response in response + output = u_boot_console.run_command("echo $?") + assert output.endswith("0")
Hi Love,
Changes in v2:
I'll just note that we can write tests in C now, even if they need Python setup. See [1].
Some nits below, with which:
+For example:
- "device_list": ["eth0", "eth1"],
Please be sure to use single quotes throughout, for consistency.
- if u_boot_console.config.env.get("env__mii_device_test_skip", False):
- expected_output = "PHY"
- output = u_boot_console.run_command("mii info")
- if not re.search(r"PHY (.+?):", output):
- assert expected_output in output
- f = u_boot_console.config.env.get("env__mii_device_test", None)
- if not f:
- dev_list = f.get("device_list")
- if len(dev_list) == 0:
if not dev_list:
- expected_output = "Current device"
- output = u_boot_console.run_command("mii device")
- mii_devices = (
- assert len([x for x in dev_list if x in mii_devices]) == len(dev_list)
- test_mii_list(u_boot_console)
- current_dev = re.search(r"Current device: '(.+?)'", output).groups()[0]
- for dev in dev_list:
- u_boot_console.run_command(f"mii device {current_dev}")
- dev = re.search(r"Current device: '(.+?)'", output).groups()[0]
- assert current_dev == dev
- eth_addr = hex(int(re.search(r"PHY (.+?):", output).groups()[0], 16))
- u_boot_console.run_command(f"mii read {eth_addr} 0")
- output = u_boot_console.run_command("echo $?")
- assert output.endswith("0")
- expected_response = "PHY control register"
- response = u_boot_console.run_command(f"mii dump {eth_addr} 0")
- assert expected_response in response
-- 2.25.1
[1] https://docs.u-boot.org/en/latest/develop/tests_writing.html#mixing-python-a...
Love Kumar
