Re: [U-Boot] multi-image uImage with fitImage
+U-Boot again
Hi Andre,
On 30 March 2015 at 22:41, Andre Wolokita andre.wolokita@analog.com wrote:
On 31/03/15 13:42, Stephen Warren wrote:
On 03/30/2015 05:42 PM, Andre Wolokita wrote: ...
I am able to boot a uImage produced by buildroot successfully, although I still haven't tried a zImage. One point of clarification: the uImage (and presumably zImage) produced by buildroot has the initrd linked in to the image. Could you think of any reason that this would affect a fitImage from loading?
Presumably this combined kernel+initrd is very large, so the amount of space taken by the decompressed kernel (roughly located at the start of RAM) is much larger than typical. Perhaps the decompression is over-writing the DTB or something like that? Is the entire kernel_initrd located within the first 256MB of RAM, if you're uses AUTO_ZRELADDR in the kernel config?
Well, I figured it out. It turns out that using objcopy to create a binary of vmlinux and using the vmlinux.bin as the "kernel" as well as creating a cpio of the rootfs for the "ramdisk" allows Linux to boot perfectly.
Thanks for your help, Simon and Stephen. :)
OK good! I wonder if the Linux build process still creates a file called 'Image' which does the objcopy for you?
