[PATCH 1/9] P1010RDB: Remove CONFIG_SPL_NAND_MINIMAL
This symbol is not used anywhere, remove it.
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/P1010RDB.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 0c19b92940e3..0c4a2f01ad4a 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -75,7 +75,6 @@ #define CONFIG_SYS_NAND_U_BOOT_START (0x11000000) #elif defined(CONFIG_SPL_BUILD) #define CONFIG_SPL_INIT_MINIMAL -#define CONFIG_SPL_NAND_MINIMAL #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_MAX_SIZE 8192 #define CONFIG_SYS_NAND_U_BOOT_SIZE (128 << 10)
This option is not referenced in code, remove it.
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/ls1043a_common.h | 1 - include/configs/ls1046a_common.h | 2 -- 2 files changed, 3 deletions(-)
diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 7457dad86682..0b54c52b4f2e 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -78,7 +78,6 @@
/* NAND SPL */ #ifdef CONFIG_NAND_BOOT -#define CONFIG_SPL_PBL_PAD #define CONFIG_SPL_MAX_SIZE 0x1a000 #define CONFIG_SPL_STACK 0x1001d000 #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 000f19a73e27..21830c0bda9e 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -89,8 +89,6 @@
/* NAND SPL */ #ifdef CONFIG_NAND_BOOT -#define CONFIG_SPL_PBL_PAD - #define CONFIG_SPL_MAX_SIZE 0x17000 /* 90 KiB */ #define CONFIG_SPL_STACK 0x1001f000 #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE
This is only referenced in non-SPL_DM cases, of which there are currently none. Remove this option and slightly re-organize the code is there is now never an if/else at the start of spl_sata_load_image()
Signed-off-by: Tom Rini trini@konsulko.com --- common/spl/spl_sata.c | 20 +++++--------------- include/configs/imx6_spl.h | 1 - 2 files changed, 5 insertions(+), 16 deletions(-)
diff --git a/common/spl/spl_sata.c b/common/spl/spl_sata.c index 1f3a144cdfbf..d03f86344e05 100644 --- a/common/spl/spl_sata.c +++ b/common/spl/spl_sata.c @@ -73,21 +73,11 @@ static int spl_sata_load_image(struct spl_image_info *spl_image, int err = 0; struct blk_desc *stor_dev;
-#if !defined(CONFIG_DM_SCSI) && !defined(CONFIG_AHCI) - err = init_sata(CONFIG_SPL_SATA_BOOT_DEVICE); -#endif - if (err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - printf("spl: sata init failed: err - %d\n", err); -#endif - return err; - } else { - /* try to recognize storage devices immediately */ - scsi_scan(false); - stor_dev = blk_get_devnum_by_type(IF_TYPE_SCSI, 0); - if (!stor_dev) - return -ENODEV; - } + /* try to recognize storage devices immediately */ + scsi_scan(false); + stor_dev = blk_get_devnum_by_type(IF_TYPE_SCSI, 0); + if (!stor_dev) + return -ENODEV;
#if CONFIG_IS_ENABLED(OS_BOOT) if (spl_start_uboot() || diff --git a/include/configs/imx6_spl.h b/include/configs/imx6_spl.h index 234aacb3b914..7215bda973ff 100644 --- a/include/configs/imx6_spl.h +++ b/include/configs/imx6_spl.h @@ -60,7 +60,6 @@
/* SATA support */ #if defined(CONFIG_SPL_SATA) -#define CONFIG_SPL_SATA_BOOT_DEVICE 0 #define CONFIG_SYS_SATA_FAT_BOOT_PARTITION 1 #endif
This converts the following to Kconfig: CONFIG_SYS_FLASH_CFI_WIDTH
Signed-off-by: Tom Rini trini@konsulko.com --- configs/M5208EVBE_defconfig | 1 + configs/M5235EVB_Flash32_defconfig | 1 + configs/M5235EVB_defconfig | 1 + configs/M5249EVB_defconfig | 1 + configs/M5272C3_defconfig | 1 + configs/M5282EVB_defconfig | 1 + configs/M53017EVB_defconfig | 1 + configs/M5329AFEE_defconfig | 1 + configs/M5329BFEE_defconfig | 1 + configs/M5373EVB_defconfig | 1 + configs/ae350_rv32_defconfig | 1 + configs/ae350_rv32_spl_defconfig | 1 + configs/ae350_rv32_spl_xip_defconfig | 1 + configs/ae350_rv32_xip_defconfig | 1 + configs/ae350_rv64_defconfig | 1 + configs/ae350_rv64_spl_defconfig | 1 + configs/ae350_rv64_spl_xip_defconfig | 1 + configs/ae350_rv64_xip_defconfig | 1 + configs/blanche_defconfig | 1 + configs/eb_cpu5282_defconfig | 1 + configs/eb_cpu5282_internal_defconfig | 1 + configs/kzm9g_defconfig | 1 + configs/mccmon6_nor_defconfig | 1 + configs/mccmon6_sd_defconfig | 1 + configs/omap35_logic_somlv_defconfig | 1 + configs/omap3_logic_somlv_defconfig | 1 + configs/r8a77990_ebisu_defconfig | 1 + configs/r8a77995_draak_defconfig | 1 + configs/rcar3_salvator-x_defconfig | 1 + configs/rcar3_ulcb_defconfig | 1 + configs/total_compute_defconfig | 1 + configs/vexpress_aemv8a_juno_defconfig | 1 + configs/vexpress_aemv8a_semi_defconfig | 1 + configs/xtfpga_defconfig | 1 + drivers/mtd/Kconfig | 29 ++++++++++++++++++++++++++ drivers/mtd/cfi_flash.c | 7 ------- include/configs/M5208EVBE.h | 1 - include/configs/M5235EVB.h | 5 ----- include/configs/M5249EVB.h | 1 - include/configs/M5253DEMO.h | 1 - include/configs/M5272C3.h | 1 - include/configs/M5282EVB.h | 1 - include/configs/M53017EVB.h | 1 - include/configs/M5329EVB.h | 1 - include/configs/M5373EVB.h | 1 - include/configs/am335x_evm.h | 1 - include/configs/armadillo-800eva.h | 1 - include/configs/ax25-ae350.h | 1 - include/configs/blanche.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/draak.h | 1 - include/configs/eb_cpu5282.h | 1 - include/configs/ebisu.h | 1 - include/configs/ids8313.h | 1 - include/configs/kzm9g.h | 1 - include/configs/mccmon6.h | 1 - include/configs/mx6sabreauto.h | 1 - include/configs/octeon_ebb7304.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/salvator-x.h | 1 - include/configs/total_compute.h | 2 -- include/configs/ulcb.h | 1 - include/configs/vexpress_aemv8.h | 2 -- include/configs/xtfpga.h | 1 - scripts/config_whitelist.txt | 1 - 65 files changed, 63 insertions(+), 42 deletions(-)
diff --git a/configs/M5208EVBE_defconfig b/configs/M5208EVBE_defconfig index 757792f9b0f4..4ab888f59ed5 100644 --- a/configs/M5208EVBE_defconfig +++ b/configs/M5208EVBE_defconfig @@ -34,6 +34,7 @@ CONFIG_SYS_I2C_SLAVE=0x7F CONFIG_SYS_I2C_SPEED=80000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y diff --git a/configs/M5235EVB_Flash32_defconfig b/configs/M5235EVB_Flash32_defconfig index 1ed127ca3c27..2a7996278418 100644 --- a/configs/M5235EVB_Flash32_defconfig +++ b/configs/M5235EVB_Flash32_defconfig @@ -41,6 +41,7 @@ CONFIG_SYS_I2C_SLAVE=0x7F CONFIG_SYS_I2C_SPEED=80000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_32BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y diff --git a/configs/M5235EVB_defconfig b/configs/M5235EVB_defconfig index fed386c164ad..5eeed2d2f313 100644 --- a/configs/M5235EVB_defconfig +++ b/configs/M5235EVB_defconfig @@ -41,6 +41,7 @@ CONFIG_SYS_I2C_SLAVE=0x7F CONFIG_SYS_I2C_SPEED=80000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y diff --git a/configs/M5249EVB_defconfig b/configs/M5249EVB_defconfig index 171df12564ff..f99375b535ed 100644 --- a/configs/M5249EVB_defconfig +++ b/configs/M5249EVB_defconfig @@ -25,6 +25,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_NET is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_MCFUART=y diff --git a/configs/M5272C3_defconfig b/configs/M5272C3_defconfig index 376fb4253060..e3f736bf6308 100644 --- a/configs/M5272C3_defconfig +++ b/configs/M5272C3_defconfig @@ -54,6 +54,7 @@ CONFIG_SYS_BR7_PRELIM=0x701 CONFIG_SYS_OR7_PRELIM=0xFFC0007C CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y diff --git a/configs/M5282EVB_defconfig b/configs/M5282EVB_defconfig index 8f38710b0742..42940e1000a4 100644 --- a/configs/M5282EVB_defconfig +++ b/configs/M5282EVB_defconfig @@ -30,6 +30,7 @@ CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y CONFIG_SYS_RX_ETH_BUFFER=8 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y diff --git a/configs/M53017EVB_defconfig b/configs/M53017EVB_defconfig index 246bc8a3bed7..901a15d5061a 100644 --- a/configs/M53017EVB_defconfig +++ b/configs/M53017EVB_defconfig @@ -36,6 +36,7 @@ CONFIG_SYS_I2C_SLAVE=0x7F CONFIG_SYS_I2C_SPEED=80000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/M5329AFEE_defconfig b/configs/M5329AFEE_defconfig index 3536b4432de4..0bce9d8f4229 100644 --- a/configs/M5329AFEE_defconfig +++ b/configs/M5329AFEE_defconfig @@ -36,6 +36,7 @@ CONFIG_SYS_I2C_SPEED=80000 CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y diff --git a/configs/M5329BFEE_defconfig b/configs/M5329BFEE_defconfig index a020775c87d0..efc7733b44c2 100644 --- a/configs/M5329BFEE_defconfig +++ b/configs/M5329BFEE_defconfig @@ -37,6 +37,7 @@ CONFIG_SYS_I2C_SPEED=80000 CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/M5373EVB_defconfig b/configs/M5373EVB_defconfig index b008b91fdd54..920a86fa9aa7 100644 --- a/configs/M5373EVB_defconfig +++ b/configs/M5373EVB_defconfig @@ -37,6 +37,7 @@ CONFIG_SYS_I2C_SPEED=80000 CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/ae350_rv32_defconfig b/configs/ae350_rv32_defconfig index 9c1fe5689644..340ec49c461e 100644 --- a/configs/ae350_rv32_defconfig +++ b/configs/ae350_rv32_defconfig @@ -29,6 +29,7 @@ CONFIG_FTSDC010=y CONFIG_FTSDC010_SDIO=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ae350_rv32_spl_defconfig b/configs/ae350_rv32_spl_defconfig index c79297169905..7a7fd416b04b 100644 --- a/configs/ae350_rv32_spl_defconfig +++ b/configs/ae350_rv32_spl_defconfig @@ -32,6 +32,7 @@ CONFIG_FTSDC010=y CONFIG_FTSDC010_SDIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/ae350_rv32_spl_xip_defconfig b/configs/ae350_rv32_spl_xip_defconfig index e1400767d57d..9ba010a168c7 100644 --- a/configs/ae350_rv32_spl_xip_defconfig +++ b/configs/ae350_rv32_spl_xip_defconfig @@ -34,6 +34,7 @@ CONFIG_FTSDC010=y CONFIG_FTSDC010_SDIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/ae350_rv32_xip_defconfig b/configs/ae350_rv32_xip_defconfig index 62fb51baad4c..16ff634d15a9 100644 --- a/configs/ae350_rv32_xip_defconfig +++ b/configs/ae350_rv32_xip_defconfig @@ -30,6 +30,7 @@ CONFIG_FTSDC010=y CONFIG_FTSDC010_SDIO=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ae350_rv64_defconfig b/configs/ae350_rv64_defconfig index 681c40fd770e..ba525c98c2ae 100644 --- a/configs/ae350_rv64_defconfig +++ b/configs/ae350_rv64_defconfig @@ -30,6 +30,7 @@ CONFIG_FTSDC010=y CONFIG_FTSDC010_SDIO=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ae350_rv64_spl_defconfig b/configs/ae350_rv64_spl_defconfig index 210bf22a0485..9e9f85a18699 100644 --- a/configs/ae350_rv64_spl_defconfig +++ b/configs/ae350_rv64_spl_defconfig @@ -33,6 +33,7 @@ CONFIG_FTSDC010=y CONFIG_FTSDC010_SDIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/ae350_rv64_spl_xip_defconfig b/configs/ae350_rv64_spl_xip_defconfig index c6a6c79e394e..c1a6d89ae7ca 100644 --- a/configs/ae350_rv64_spl_xip_defconfig +++ b/configs/ae350_rv64_spl_xip_defconfig @@ -35,6 +35,7 @@ CONFIG_FTSDC010=y CONFIG_FTSDC010_SDIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/ae350_rv64_xip_defconfig b/configs/ae350_rv64_xip_defconfig index b5bdf94dafb7..49511ab15493 100644 --- a/configs/ae350_rv64_xip_defconfig +++ b/configs/ae350_rv64_xip_defconfig @@ -31,6 +31,7 @@ CONFIG_FTSDC010=y CONFIG_FTSDC010_SDIO=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/blanche_defconfig b/configs/blanche_defconfig index 01e9ea372225..f4bb406be3cc 100644 --- a/configs/blanche_defconfig +++ b/configs/blanche_defconfig @@ -55,6 +55,7 @@ CONFIG_RENESAS_SDHI=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/eb_cpu5282_defconfig b/configs/eb_cpu5282_defconfig index d634280de5d3..4cf03abc61e4 100644 --- a/configs/eb_cpu5282_defconfig +++ b/configs/eb_cpu5282_defconfig @@ -45,6 +45,7 @@ CONFIG_LED_STATUS_BOOT=0 CONFIG_LED_STATUS_CMD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y diff --git a/configs/eb_cpu5282_internal_defconfig b/configs/eb_cpu5282_internal_defconfig index a726fdb56e37..117851584693 100644 --- a/configs/eb_cpu5282_internal_defconfig +++ b/configs/eb_cpu5282_internal_defconfig @@ -43,6 +43,7 @@ CONFIG_LED_STATUS_BOOT=0 CONFIG_LED_STATUS_CMD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y diff --git a/configs/kzm9g_defconfig b/configs/kzm9g_defconfig index 779f0d9ed89b..9a944cad39c2 100644 --- a/configs/kzm9g_defconfig +++ b/configs/kzm9g_defconfig @@ -36,6 +36,7 @@ CONFIG_SYS_I2C_SH=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_CFI=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x10000000 diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index e837b391ebc1..3718d08b6700 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -60,6 +60,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index 0f17ccdc85de..3228050dd206 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -58,6 +58,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 5db671d694ea..ffb0e28569ae 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -62,6 +62,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 2c5d60d164ae..b49734666d77 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -63,6 +63,7 @@ CONFIG_MMC_OMAP36XX_PINS=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y diff --git a/configs/r8a77990_ebisu_defconfig b/configs/r8a77990_ebisu_defconfig index 7ba55737d841..3fd65e97c44b 100644 --- a/configs/r8a77990_ebisu_defconfig +++ b/configs/r8a77990_ebisu_defconfig @@ -72,6 +72,7 @@ CONFIG_RENESAS_SDHI=y CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index e2a7e5f636dd..ee0f61513175 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -66,6 +66,7 @@ CONFIG_RENESAS_SDHI=y CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/rcar3_salvator-x_defconfig b/configs/rcar3_salvator-x_defconfig index 7bcbb3a13394..7263b32101d0 100644 --- a/configs/rcar3_salvator-x_defconfig +++ b/configs/rcar3_salvator-x_defconfig @@ -75,6 +75,7 @@ CONFIG_RENESAS_SDHI=y CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/rcar3_ulcb_defconfig b/configs/rcar3_ulcb_defconfig index c953299c0d0f..052465c8d7a9 100644 --- a/configs/rcar3_ulcb_defconfig +++ b/configs/rcar3_ulcb_defconfig @@ -74,6 +74,7 @@ CONFIG_RENESAS_SDHI=y CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_FLASH_CFI_MTD=y diff --git a/configs/total_compute_defconfig b/configs/total_compute_defconfig index 1a674de8157c..e0f76b711b3c 100644 --- a/configs/total_compute_defconfig +++ b/configs/total_compute_defconfig @@ -49,6 +49,7 @@ CONFIG_ARM_PL180_MMCI=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_32BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index 688cecb7632c..fdfcf3b49606 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_UBI=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_SYS_FLASH_CFI_WIDTH_32BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index 95412d24eea3..0ae8ae10a310 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_UBI=y # CONFIG_MMC is not set CONFIG_MTD=y +CONFIG_SYS_FLASH_CFI_WIDTH_32BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/xtfpga_defconfig b/configs/xtfpga_defconfig index e98af5ec7e63..eab40fc0d133 100644 --- a/configs/xtfpga_defconfig +++ b/configs/xtfpga_defconfig @@ -38,6 +38,7 @@ CONFIG_DM=y # CONFIG_DM_SEQ_ALIAS is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHYLIB=y diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index 4088267dd111..c3f5455347ed 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -48,6 +48,35 @@ config FLASH_CFI_DRIVER option. Visit http://www.amd.com/products/nvd/overview/cfi.html for more information on CFI.
+choice + prompt "Data-width of the flash device" + depends on FLASH_CFI_DRIVER + default SYS_FLASH_CFI_WIDTH_8BIT + +config SYS_FLASH_CFI_WIDTH_8BIT + bool "Data-width of the device is 8-bit" + +config SYS_FLASH_CFI_WIDTH_16BIT + bool "Data-width of the device is 16-bit" + +config SYS_FLASH_CFI_WIDTH_32BIT + bool "Data-width of the device is 32-bit" + +config SYS_FLASH_CFI_WIDTH_64BIT + bool "Data-width of the device is 64-bit" + +endchoice + +config SYS_FLASH_CFI_WIDTH + hex + depends on FLASH_CFI_DRIVER + default 0x1 if SYS_FLASH_CFI_WIDTH_8BIT + default 0x2 if SYS_FLASH_CFI_WIDTH_16BIT + default 0x4 if SYS_FLASH_CFI_WIDTH_32BIT + default 0x8 if SYS_FLASH_CFI_WIDTH_64BIT + help + This must be kept in sync with the table in include/flash.h + config CFI_FLASH bool "Enable Driver Model for CFI Flash driver" depends on DM_MTD diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index aae3ea0d1b45..495041070650 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -68,13 +68,6 @@ static uint flash_verbose = 1;
flash_info_t flash_info[CFI_MAX_FLASH_BANKS]; /* FLASH chips info */
-/* - * Check if chip width is defined. If not, start detecting with 8bit. - */ -#ifndef CONFIG_SYS_FLASH_CFI_WIDTH -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_8BIT -#endif - #ifdef CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS #define __maybe_weak __weak #else diff --git a/include/configs/M5208EVBE.h b/include/configs/M5208EVBE.h index 135dec0ebb4d..4ca71ad41ba2 100644 --- a/include/configs/M5208EVBE.h +++ b/include/configs/M5208EVBE.h @@ -94,7 +94,6 @@ /* FLASH organization */ #ifdef CONFIG_SYS_FLASH_CFI # define CONFIG_SYS_FLASH_SIZE 0x800000 /* Max size that the board might have */ -# define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT # define CONFIG_SYS_MAX_FLASH_SECT 254 /* max number of sectors on one chip */ #endif
diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index 88f5f155633c..68b695c6fbbd 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -102,11 +102,6 @@ */ #ifdef CONFIG_SYS_FLASH_CFI # define CONFIG_SYS_FLASH_SIZE 0x800000 /* Max size that the board might have */ -#ifdef CONFIG_NORFLASH_PS32BIT -# define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_32BIT -#else -# define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT -#endif # define CONFIG_SYS_MAX_FLASH_SECT 137 /* max number of sectors on one chip */ #endif
diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index 1a604f5c81ea..64eae702160f 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -79,7 +79,6 @@ #ifdef CONFIG_SYS_FLASH_CFI
# define CONFIG_SYS_FLASH_SIZE 0x1000000 /* Max size that the board might have */ -# define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT # define CONFIG_SYS_MAX_FLASH_SECT 137 /* max number of sectors on one chip */ # define CONFIG_SYS_FLASH_CHECKSUM # define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index 0a416dc12266..e81768441ec4 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -115,7 +115,6 @@ * 0x30 is block erase in SST */ # define CONFIG_SYS_FLASH_SIZE 0x800000 -# define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT # define CONFIG_FLASH_CFI_LEGACY #else # define CONFIG_SYS_SST_SECT 2048 diff --git a/include/configs/M5272C3.h b/include/configs/M5272C3.h index 6b4028c17ca2..bd4c531751e2 100644 --- a/include/configs/M5272C3.h +++ b/include/configs/M5272C3.h @@ -102,7 +102,6 @@ */ #ifdef CONFIG_SYS_FLASH_CFI # define CONFIG_SYS_FLASH_SIZE 0x800000 /* Max size that the board might have */ -# define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT # define CONFIG_SYS_MAX_FLASH_SECT 137 /* max number of sectors on one chip */ #endif
diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index fe04a70b61e9..c0358ccc5269 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -106,7 +106,6 @@ #ifdef CONFIG_SYS_FLASH_CFI
# define CONFIG_SYS_FLASH_SIZE 0x1000000 /* Max size that the board might have */ -# define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT # define CONFIG_SYS_MAX_FLASH_SECT 137 /* max number of sectors on one chip */ # define CONFIG_SYS_FLASH_CHECKSUM # define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } diff --git a/include/configs/M53017EVB.h b/include/configs/M53017EVB.h index 9b84d3693a31..15173d49b000 100644 --- a/include/configs/M53017EVB.h +++ b/include/configs/M53017EVB.h @@ -111,7 +111,6 @@ #ifdef CONFIG_SYS_FLASH_CFI # define CONFIG_FLASH_SPANSION_S29WS_N 1 # define CONFIG_SYS_FLASH_SIZE 0x1000000 /* Max size that the board might have */ -# define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT # define CONFIG_SYS_MAX_FLASH_SECT 137 /* max number of sectors on one chip */ #endif
diff --git a/include/configs/M5329EVB.h b/include/configs/M5329EVB.h index 7e65f9914f4d..06c023b3ad6a 100644 --- a/include/configs/M5329EVB.h +++ b/include/configs/M5329EVB.h @@ -106,7 +106,6 @@ */ #ifdef CONFIG_SYS_FLASH_CFI # define CONFIG_SYS_FLASH_SIZE 0x800000 /* Max size that the board might have */ -# define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT # define CONFIG_SYS_MAX_FLASH_SECT 137 /* max number of sectors on one chip */ #endif
diff --git a/include/configs/M5373EVB.h b/include/configs/M5373EVB.h index b131aefd6dd1..6b2d60fac846 100644 --- a/include/configs/M5373EVB.h +++ b/include/configs/M5373EVB.h @@ -108,7 +108,6 @@ */ #ifdef CONFIG_SYS_FLASH_CFI # define CONFIG_SYS_FLASH_SIZE 0x800000 /* Max size that the board might have */ -# define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT # define CONFIG_SYS_MAX_FLASH_SECT 137 /* max number of sectors on one chip */ #endif
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index fd5b209a52db..78b359dcea93 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -241,7 +241,6 @@ #if defined(CONFIG_NOR) #define CONFIG_SYS_MAX_FLASH_SECT 128 #define CONFIG_SYS_FLASH_BASE (0x08000000) -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_FLASH_SIZE 0x01000000 #endif /* NOR support */
diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index 44af5b44badf..e7d685a657e3 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -47,7 +47,6 @@ #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* FLASH */ -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_FLASH_BASE 0x00000000 #define CONFIG_SYS_MAX_FLASH_SECT 512 #define CONFIG_SYS_FLASH_BANKS_LIST { (CONFIG_SYS_FLASH_BASE) } diff --git a/include/configs/ax25-ae350.h b/include/configs/ax25-ae350.h index 633be8f61414..03fe9469bf1a 100644 --- a/include/configs/ax25-ae350.h +++ b/include/configs/ax25-ae350.h @@ -58,7 +58,6 @@
/* use CFI framework */
-#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_CFI_FLASH_STATUS_POLL
/* support JEDEC */ diff --git a/include/configs/blanche.h b/include/configs/blanche.h index 4f8da5940431..d0f37b6cc20c 100644 --- a/include/configs/blanche.h +++ b/include/configs/blanche.h @@ -28,7 +28,6 @@ #if !defined(CONFIG_MTD_NOR_FLASH) #define CONFIG_SH_QSPI_BASE 0xE6B10000 #else -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_FLASH_SHOW_PROGRESS 45 #define CONFIG_SYS_FLASH_BASE 0x00000000 #define CONFIG_SYS_FLASH_SIZE 0x04000000 /* 64 MB */ diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index e16af8824b40..9f685b198791 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -95,7 +95,6 @@ #if defined(CONFIG_NOR) /* NOR: device related configs */ #define CONFIG_SYS_MAX_FLASH_SECT 512 -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_FLASH_SIZE (64 * 1024 * 1024) /* 64 MB */ #define CONFIG_SYS_FLASH_BASE (0x08000000) /* Reduce SPL size by removing unlikey targets */ diff --git a/include/configs/draak.h b/include/configs/draak.h index 476b4c3710a2..a38e48634835 100644 --- a/include/configs/draak.h +++ b/include/configs/draak.h @@ -15,7 +15,6 @@
#define CONFIG_FLASH_SHOW_PROGRESS 45 #define CONFIG_SYS_FLASH_BANKS_LIST { 0x08000000 } -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_WRITE_SWAPPED_DATA
diff --git a/include/configs/eb_cpu5282.h b/include/configs/eb_cpu5282.h index 70ee288aa72e..cbc29ddb5180 100644 --- a/include/configs/eb_cpu5282.h +++ b/include/configs/eb_cpu5282.h @@ -102,7 +102,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 10000000
#define CONFIG_SYS_FLASH_SIZE 16*1024*1024 -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT
#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE }
diff --git a/include/configs/ebisu.h b/include/configs/ebisu.h index 3adc4180efd9..3dc111f5248d 100644 --- a/include/configs/ebisu.h +++ b/include/configs/ebisu.h @@ -18,7 +18,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_SYS_FLASH_BANKS_LIST { 0x08000000 } -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_WRITE_SWAPPED_DATA
diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index 3fd441e30ba0..d5c9489bce6e 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -108,7 +108,6 @@ /* * NOR FLASH setup */ -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_8BIT #define CONFIG_FLASH_SHOW_PROGRESS 50
#define CONFIG_SYS_FLASH_BASE 0xFF800000 diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 2ea8b82dd092..442505adaa14 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -19,7 +19,6 @@ /* NOR Flash */ #define KZM_FLASH_BASE (0x00000000) #define CONFIG_SYS_FLASH_BASE (KZM_FLASH_BASE) -#define CONFIG_SYS_FLASH_CFI_WIDTH (FLASH_CFI_16BIT) #define CONFIG_SYS_MAX_FLASH_SECT (512)
/* prompt */ diff --git a/include/configs/mccmon6.h b/include/configs/mccmon6.h index dcce52eb7d37..f24a00724173 100644 --- a/include/configs/mccmon6.h +++ b/include/configs/mccmon6.h @@ -31,7 +31,6 @@
/* NOR 16-bit mode */ #define CONFIG_SYS_FLASH_BASE WEIM_ARB_BASE_ADDR -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_FLASH_VERIFY
diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index a212652fd7f0..4537fce19deb 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -42,7 +42,6 @@ #define CONFIG_SYS_FLASH_SECT_SIZE (128 * 1024) #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ #define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #endif
#define CONFIG_SYS_FSL_USDHC_NUM 2 diff --git a/include/configs/octeon_ebb7304.h b/include/configs/octeon_ebb7304.h index 8c6c57bd546a..7035e6313420 100644 --- a/include/configs/octeon_ebb7304.h +++ b/include/configs/octeon_ebb7304.h @@ -13,7 +13,6 @@ * CFI flash */ #define CONFIG_SYS_MAX_FLASH_SECT 256 -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_8BIT #define CONFIG_SYS_FLASH_EMPTY_INFO /* flinfo indicates empty blocks */
#define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */ diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index d3839eb12293..4112e5570f6a 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -154,7 +154,6 @@ #endif
#define CONFIG_SYS_MAX_FLASH_SECT 256 -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_FLASH_SIZE 0x4000000
#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ diff --git a/include/configs/salvator-x.h b/include/configs/salvator-x.h index eb00e2b004bc..4b0f20e89b7c 100644 --- a/include/configs/salvator-x.h +++ b/include/configs/salvator-x.h @@ -16,7 +16,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_SYS_FLASH_BANKS_LIST { 0x08000000 } -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_WRITE_SWAPPED_DATA
diff --git a/include/configs/total_compute.h b/include/configs/total_compute.h index 7ab792613612..c0495b7e153a 100644 --- a/include/configs/total_compute.h +++ b/include/configs/total_compute.h @@ -50,8 +50,6 @@ /* 256 x 256KiB sectors */ #define CONFIG_SYS_MAX_FLASH_SECT 256
-#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_32BIT - #define CONFIG_SYS_FLASH_EMPTY_INFO /* flinfo indicates empty blocks */ #define FLASH_MAX_SECTOR_SIZE 0x00040000
diff --git a/include/configs/ulcb.h b/include/configs/ulcb.h index 14ea40bee3ed..578873295fb9 100644 --- a/include/configs/ulcb.h +++ b/include/configs/ulcb.h @@ -16,7 +16,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_SYS_FLASH_BANKS_LIST { 0x08000000 } -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_WRITE_SWAPPED_DATA
diff --git a/include/configs/vexpress_aemv8.h b/include/configs/vexpress_aemv8.h index df76b9a5612f..904ed8df0be8 100644 --- a/include/configs/vexpress_aemv8.h +++ b/include/configs/vexpress_aemv8.h @@ -276,8 +276,6 @@ /* Store environment at top of flash */ #endif
-#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_32BIT - #ifdef CONFIG_USB_EHCI_HCD #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1 diff --git a/include/configs/xtfpga.h b/include/configs/xtfpga.h index 215b7592d2ae..7392582b5e46 100644 --- a/include/configs/xtfpga.h +++ b/include/configs/xtfpga.h @@ -170,7 +170,6 @@ /* Flash & Environment */ /*=====================*/
-#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #ifdef CONFIG_XTFPGA_LX60 # define CONFIG_SYS_FLASH_SIZE 0x0040000 /* 4MB */ # define CONFIG_SYS_FLASH_SECT_SZ 0x10000 /* block size 64KB */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 06a76b6398ce..0cfb3ba4482c 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -887,7 +887,6 @@ CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE_PHYS_EARLY CONFIG_SYS_FLASH_BR_PRELIM CONFIG_SYS_FLASH_CFI_NONBLOCK -CONFIG_SYS_FLASH_CFI_WIDTH CONFIG_SYS_FLASH_CHECKSUM CONFIG_SYS_FLASH_EMPTY_INFO CONFIG_SYS_FLASH_ERASE_TOUT
This converts the following to Kconfig: CONFIG_SYS_CFI_FLASH_STATUS_POLL
Signed-off-by: Tom Rini trini@konsulko.com --- configs/3c120_defconfig | 1 + configs/ae350_rv32_defconfig | 1 + configs/ae350_rv32_spl_defconfig | 1 + configs/ae350_rv32_spl_xip_defconfig | 1 + configs/ae350_rv32_xip_defconfig | 1 + configs/ae350_rv64_defconfig | 1 + configs/ae350_rv64_spl_defconfig | 1 + configs/ae350_rv64_spl_xip_defconfig | 1 + configs/ae350_rv64_xip_defconfig | 1 + drivers/mtd/Kconfig | 4 ++++ include/configs/3c120_devboard.h | 1 - include/configs/ax25-ae350.h | 4 ---- scripts/config_whitelist.txt | 1 - 13 files changed, 13 insertions(+), 6 deletions(-)
diff --git a/configs/3c120_defconfig b/configs/3c120_defconfig index 617b25a375b5..f266c0e5e41d 100644 --- a/configs/3c120_defconfig +++ b/configs/3c120_defconfig @@ -39,6 +39,7 @@ CONFIG_ALTERA_SYSID=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y +CONFIG_SYS_CFI_FLASH_STATUS_POLL=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ae350_rv32_defconfig b/configs/ae350_rv32_defconfig index 340ec49c461e..714a70759138 100644 --- a/configs/ae350_rv32_defconfig +++ b/configs/ae350_rv32_defconfig @@ -31,6 +31,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH=y +CONFIG_SYS_CFI_FLASH_STATUS_POLL=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/ae350_rv32_spl_defconfig b/configs/ae350_rv32_spl_defconfig index 7a7fd416b04b..cd9cc613cb50 100644 --- a/configs/ae350_rv32_spl_defconfig +++ b/configs/ae350_rv32_spl_defconfig @@ -33,6 +33,7 @@ CONFIG_FTSDC010_SDIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y +CONFIG_SYS_CFI_FLASH_STATUS_POLL=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/ae350_rv32_spl_xip_defconfig b/configs/ae350_rv32_spl_xip_defconfig index 9ba010a168c7..8f47e178636d 100644 --- a/configs/ae350_rv32_spl_xip_defconfig +++ b/configs/ae350_rv32_spl_xip_defconfig @@ -35,6 +35,7 @@ CONFIG_FTSDC010_SDIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y +CONFIG_SYS_CFI_FLASH_STATUS_POLL=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/ae350_rv32_xip_defconfig b/configs/ae350_rv32_xip_defconfig index 16ff634d15a9..f0b842f35edf 100644 --- a/configs/ae350_rv32_xip_defconfig +++ b/configs/ae350_rv32_xip_defconfig @@ -32,6 +32,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH=y +CONFIG_SYS_CFI_FLASH_STATUS_POLL=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/ae350_rv64_defconfig b/configs/ae350_rv64_defconfig index ba525c98c2ae..5425255a700f 100644 --- a/configs/ae350_rv64_defconfig +++ b/configs/ae350_rv64_defconfig @@ -32,6 +32,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH=y +CONFIG_SYS_CFI_FLASH_STATUS_POLL=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/ae350_rv64_spl_defconfig b/configs/ae350_rv64_spl_defconfig index 9e9f85a18699..33476f3fb1d2 100644 --- a/configs/ae350_rv64_spl_defconfig +++ b/configs/ae350_rv64_spl_defconfig @@ -34,6 +34,7 @@ CONFIG_FTSDC010_SDIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y +CONFIG_SYS_CFI_FLASH_STATUS_POLL=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/ae350_rv64_spl_xip_defconfig b/configs/ae350_rv64_spl_xip_defconfig index c1a6d89ae7ca..e6ed0efa5535 100644 --- a/configs/ae350_rv64_spl_xip_defconfig +++ b/configs/ae350_rv64_spl_xip_defconfig @@ -36,6 +36,7 @@ CONFIG_FTSDC010_SDIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y +CONFIG_SYS_CFI_FLASH_STATUS_POLL=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/ae350_rv64_xip_defconfig b/configs/ae350_rv64_xip_defconfig index 49511ab15493..d4b2e638b296 100644 --- a/configs/ae350_rv64_xip_defconfig +++ b/configs/ae350_rv64_xip_defconfig @@ -33,6 +33,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH=y +CONFIG_SYS_CFI_FLASH_STATUS_POLL=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index c3f5455347ed..d0ab7c18c649 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -96,6 +96,10 @@ config CFI_FLASH_USE_WEAK_ACCESSORS Enable this option to allow for the flash_{read,write}{8,16,32,64} functions to be overridden by the platform.
+config SYS_CFI_FLASH_STATUS_POLL + bool "Poll status on AMD flash chips" + depends on FLASH_CFI_DRIVER + config SYS_FLASH_USE_BUFFER_WRITE bool "Enable buffered writes to flash" depends on FLASH_CFI_DRIVER diff --git a/include/configs/3c120_devboard.h b/include/configs/3c120_devboard.h index 9db0f0efb150..2d52dc6f6608 100644 --- a/include/configs/3c120_devboard.h +++ b/include/configs/3c120_devboard.h @@ -19,7 +19,6 @@ /* * CFI Flash */ -#define CONFIG_SYS_CFI_FLASH_STATUS_POLL /* fix amd flash issue */ #define CONFIG_SYS_MAX_FLASH_SECT 512
/* diff --git a/include/configs/ax25-ae350.h b/include/configs/ax25-ae350.h index 03fe9469bf1a..264d708fa9f3 100644 --- a/include/configs/ax25-ae350.h +++ b/include/configs/ax25-ae350.h @@ -56,10 +56,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000000 - \ GENERATED_GBL_DATA_SIZE)
-/* use CFI framework */ - -#define CONFIG_SYS_CFI_FLASH_STATUS_POLL - /* support JEDEC */ #define PHYS_FLASH_1 0x88000000 /* BANK 0 */ #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 0cfb3ba4482c..a5e36698b1ff 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -666,7 +666,6 @@ CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR_PHYS_HIGH CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSR_DO_NOT_RELOCATE -CONFIG_SYS_CFI_FLASH_STATUS_POLL CONFIG_SYS_CLK CONFIG_SYS_CLKTL_CBCDR CONFIG_SYS_CORE_SRAM
This converts the following to Kconfig: CONFIG_SPL_INIT_MINIMAL CONFIG_SPL_FLUSH_IMAGE CONFIG_SPL_SKIP_RELOCATE
Signed-off-by: Tom Rini trini@konsulko.com --- README | 6 ------ arch/powerpc/cpu/mpc83xx/Makefile | 2 ++ arch/powerpc/cpu/mpc83xx/start.S | 2 +- arch/powerpc/cpu/mpc85xx/Makefile | 2 ++ arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 2 +- arch/powerpc/cpu/mpc85xx/start.S | 2 +- arch/powerpc/cpu/mpc85xx/tlb.c | 2 +- arch/powerpc/cpu/mpc8xxx/Makefile | 2 ++ arch/powerpc/cpu/mpc8xxx/law.c | 4 ++-- arch/powerpc/lib/Makefile | 2 ++ board/congatec/common/Makefile | 2 ++ board/freescale/common/Makefile | 2 ++ board/freescale/p1010rdb/Makefile | 2 ++ board/freescale/p1_p2_rdb_pc/Makefile | 2 ++ common/spl/Kconfig | 14 ++++++++++++++ configs/P1010RDB-PA_36BIT_NAND_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 2 ++ configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 2 ++ configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 2 ++ configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 2 ++ configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 2 ++ configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 2 ++ configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 2 ++ configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 2 ++ configs/T1024RDB_SDCARD_defconfig | 2 ++ configs/T1024RDB_SPIFLASH_defconfig | 2 ++ configs/T1042D4RDB_NAND_defconfig | 2 ++ configs/T1042D4RDB_SDCARD_defconfig | 2 ++ configs/T1042D4RDB_SPIFLASH_defconfig | 2 ++ configs/T2080QDS_NAND_defconfig | 2 ++ configs/T2080QDS_SDCARD_defconfig | 2 ++ configs/T2080QDS_SPIFLASH_defconfig | 2 ++ configs/T2080RDB_NAND_defconfig | 2 ++ configs/T2080RDB_SDCARD_defconfig | 2 ++ configs/T2080RDB_SPIFLASH_defconfig | 2 ++ configs/T2080RDB_revD_NAND_defconfig | 2 ++ configs/T2080RDB_revD_SDCARD_defconfig | 2 ++ configs/T2080RDB_revD_SPIFLASH_defconfig | 2 ++ configs/T4240RDB_SDCARD_defconfig | 2 ++ include/configs/P1010RDB.h | 9 +-------- include/configs/T102xRDB.h | 2 -- include/configs/T104xRDB.h | 2 -- include/configs/T208xQDS.h | 2 -- include/configs/T208xRDB.h | 2 -- include/configs/T4240RDB.h | 2 -- include/configs/p1_p2_rdb_pc.h | 7 +------ scripts/config_whitelist.txt | 3 --- 75 files changed, 115 insertions(+), 39 deletions(-)
diff --git a/README b/README index e686839637f7..484a2c500ccf 100644 --- a/README +++ b/README @@ -1716,9 +1716,6 @@ The following options need to be configured: For ARM, enable an optional function to print more information about the running system.
- CONFIG_SPL_INIT_MINIMAL - Arch init code should be built for a very small image - CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR, CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS Sector and number of sectors to load kernel argument @@ -1742,9 +1739,6 @@ The following options need to be configured: continuing (the hardware starts execution after just loading the first page rather than the full 4K).
- CONFIG_SPL_SKIP_RELOCATE - Avoid SPL relocation - CONFIG_SPL_UBI Support for a lightweight UBI (fastmap) scanner and loader diff --git a/arch/powerpc/cpu/mpc83xx/Makefile b/arch/powerpc/cpu/mpc83xx/Makefile index 7c4ef7657e5b..1255f533e343 100644 --- a/arch/powerpc/cpu/mpc83xx/Makefile +++ b/arch/powerpc/cpu/mpc83xx/Makefile @@ -8,10 +8,12 @@ MINIMAL=
ifdef CONFIG_SPL_BUILD +ifndef CONFIG_TPL_BUILD ifdef CONFIG_SPL_INIT_MINIMAL MINIMAL=y endif endif +endif
extra-y = start.o
diff --git a/arch/powerpc/cpu/mpc83xx/start.S b/arch/powerpc/cpu/mpc83xx/start.S index 0944d1910573..7a01b16b75eb 100644 --- a/arch/powerpc/cpu/mpc83xx/start.S +++ b/arch/powerpc/cpu/mpc83xx/start.S @@ -39,7 +39,7 @@ #endif
#if defined(CONFIG_NAND_SPL) || \ - (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_INIT_MINIMAL)) + (defined(CONFIG_SPL_BUILD) && CONFIG_IS_ENABLED(INIT_MINIMAL)) #define MINIMAL_SPL #endif
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index c32cde04e16a..f3ee7d34949c 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -9,10 +9,12 @@ MINIMAL=
extra-y = start.o resetvec.o
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c index 5a0d33b1b3dd..584454e01fee 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c @@ -177,7 +177,7 @@ void cpu_init_early_f(void *fdt) invalidate_tlb(1);
#if defined(CONFIG_SYS_PPC_E500_DEBUG_TLB) && \ - !(defined(CONFIG_SPL_INIT_MINIMAL) && defined(CONFIG_SPL_BUILD)) && \ + !(CONFIG_IS_ENABLED(INIT_MINIMAL) && defined(CONFIG_SPL_BUILD)) && \ !defined(CONFIG_NAND_SPL) disable_tlb(CONFIG_SYS_PPC_E500_DEBUG_TLB); #endif diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 2b2ad9735995..7a079edb691e 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -27,7 +27,7 @@ #define LAW_EN 0x80000000
diff --git a/arch/powerpc/cpu/mpc85xx/tlb.c b/arch/powerpc/cpu/mpc85xx/tlb.c index 550d45da0efa..4f6778c720db 100644 --- a/arch/powerpc/cpu/mpc85xx/tlb.c +++ b/arch/powerpc/cpu/mpc85xx/tlb.c @@ -44,7 +44,7 @@ __weak void init_tlbs(void) }
#if !defined(CONFIG_NAND_SPL) && \ - (!defined(CONFIG_SPL_BUILD) || !defined(CONFIG_SPL_INIT_MINIMAL)) + (!defined(CONFIG_SPL_BUILD) || !CONFIG_IS_ENABLED(INIT_MINIMAL)) void read_tlbcam_entry(int idx, u32 *valid, u32 *tsize, unsigned long *epn, phys_addr_t *rpn) { diff --git a/arch/powerpc/cpu/mpc8xxx/Makefile b/arch/powerpc/cpu/mpc8xxx/Makefile index bec891d5401c..e3a536d4f8c7 100644 --- a/arch/powerpc/cpu/mpc8xxx/Makefile +++ b/arch/powerpc/cpu/mpc8xxx/Makefile @@ -5,10 +5,12 @@ MINIMAL=
ifdef MINIMAL
diff --git a/arch/powerpc/cpu/mpc8xxx/law.c b/arch/powerpc/cpu/mpc8xxx/law.c index cf03f4101906..713ff172bcee 100644 --- a/arch/powerpc/cpu/mpc8xxx/law.c +++ b/arch/powerpc/cpu/mpc8xxx/law.c @@ -79,7 +79,7 @@ void disable_law(u8 idx) }
#if !defined(CONFIG_NAND_SPL) && \ - (!defined(CONFIG_SPL_BUILD) || !defined(CONFIG_SPL_INIT_MINIMAL)) + (!defined(CONFIG_SPL_BUILD) || !CONFIG_IS_ENABLED(INIT_MINIMAL)) static int get_law_entry(u8 i, struct law_entry *e) { u32 lawar; @@ -110,7 +110,7 @@ int set_next_law(phys_addr_t addr, enum law_size sz, enum law_trgt_if id) }
#if !defined(CONFIG_NAND_SPL) && \ - (!defined(CONFIG_SPL_BUILD) || !defined(CONFIG_SPL_INIT_MINIMAL)) + (!defined(CONFIG_SPL_BUILD) || !CONFIG_IS_ENABLED(INIT_MINIMAL)) int set_last_law(phys_addr_t addr, enum law_size sz, enum law_trgt_if id) { u32 idx; diff --git a/arch/powerpc/lib/Makefile b/arch/powerpc/lib/Makefile index 2782740bf5b3..066d7f408e08 100644 --- a/arch/powerpc/lib/Makefile +++ b/arch/powerpc/lib/Makefile @@ -10,10 +10,12 @@ lib-$(CONFIG_USE_PRIVATE_LIBGCC) += _ashldi3.o _ashrdi3.o _lshrdi3.o MINIMAL=
obj-y += bdinfo.o
diff --git a/board/congatec/common/Makefile b/board/congatec/common/Makefile index d4ddfbf97162..2db0fc1ae5c3 100644 --- a/board/congatec/common/Makefile +++ b/board/congatec/common/Makefile @@ -8,10 +8,12 @@ MINIMAL=
ifdef MINIMAL # necessary to create built-in.o diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 4df484935f4c..4214c6e46e48 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -6,10 +6,12 @@ MINIMAL=
ifdef MINIMAL # necessary to create built-in.o diff --git a/board/freescale/p1010rdb/Makefile b/board/freescale/p1010rdb/Makefile index 36b34c70aa87..a00806e6aaed 100644 --- a/board/freescale/p1010rdb/Makefile +++ b/board/freescale/p1010rdb/Makefile @@ -5,10 +5,12 @@ MINIMAL=
ifdef MINIMAL obj-y += spl_minimal.o diff --git a/board/freescale/p1_p2_rdb_pc/Makefile b/board/freescale/p1_p2_rdb_pc/Makefile index a7736d8332d4..cbdb2507e838 100644 --- a/board/freescale/p1_p2_rdb_pc/Makefile +++ b/board/freescale/p1_p2_rdb_pc/Makefile @@ -5,10 +5,12 @@ MINIMAL=
ifdef MINIMAL obj-y += spl_minimal.o diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 50ff113cab21..42681211d0df 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -140,6 +140,20 @@ config SPL_FSL_PBL
endmenu
+menu "PowerPC SPL specific options" + depends on PPC && (SUPPORT_SPL && !SPL_FRAMEWORK) + +config SPL_INIT_MINIMAL + bool "Arch init code will be built for a very small image" + +config SPL_FLUSH_IMAGE + bool "Clean dcache and invalidate icache after loading the image" + +config SPL_SKIP_RELOCATE + bool "Skip relocating SPL" + +endmenu + config HANDOFF bool "Pass hand-off information from SPL to U-Boot proper" depends on SPL && BLOBLIST diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index dc4d1c8bb9b6..79de9b41dcc0 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -29,6 +29,8 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_BOOT=y +CONFIG_SPL_INIT_MINIMAL=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 6ded15625c5c..0c1cd2f19692 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -20,6 +20,7 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudra CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 CONFIG_CMD_IMLS=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index da9690688c4b..6f6d6445dd74 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index 84ebcd53b35d..bef258411633 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index d103ed599b6d..a3e6120b948e 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -28,6 +28,8 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_BOOT=y +CONFIG_SPL_INIT_MINIMAL=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 8a416bc4d93f..349c6477a40c 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudra CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 CONFIG_CMD_IMLS=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index e0a9c2df2ec7..bb34c0499ed2 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -26,6 +26,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index 215671b4e7f1..f42ba10be9ae 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -29,6 +29,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 4bda8f2068f4..b807eb1ee358 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -30,6 +30,8 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_BOOT=y +CONFIG_SPL_INIT_MINIMAL=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index dc2e40d530d0..9186e6fafe8a 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 CONFIG_CMD_IMLS=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index f7cf815433a3..3b1912d282fb 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index ab378da0aad6..8ec1e93426e5 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -31,6 +31,7 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 9f839f55fbe4..eb0e48289d79 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -29,6 +29,8 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_BOOT=y +CONFIG_SPL_INIT_MINIMAL=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index 4824169b4811..b2a3587171d6 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 CONFIG_CMD_IMLS=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index f40cc9fcbec9..0b547456a1a7 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index f371661e5538..c92036e9d952 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index fd68dc70bab4..f5892e98bf72 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -30,6 +30,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_BOOT=y +CONFIG_SPL_INIT_MINIMAL=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index fb0855527597..deaeb0a4e1b9 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -29,6 +29,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 62ea0fe32897..4dffe7e5b34c 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -32,6 +32,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 80108f3d210a..f127d8c92dce 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -22,6 +22,7 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$con CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276 diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 87d12d8fb004..ff27fd2a7bfb 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -29,6 +29,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_BOOT=y +CONFIG_SPL_INIT_MINIMAL=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 7b03e9a30065..a2d16e31a7a5 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 600691517c20..7cd087e01ce5 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -31,6 +31,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 2cde204313fb..069a35f3df81 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -21,6 +21,7 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$con CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276 diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 3898e20d188c..9b8793298edd 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -29,6 +29,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_BOOT=y +CONFIG_SPL_INIT_MINIMAL=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index 345a85521cd4..f7acd3996ce0 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index ac7ee81d6d5d..daed834c0fc0 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -31,6 +31,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index f1c8c7179cc3..ccb1e30b4ec1 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -21,6 +21,7 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$con CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276 diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index a2e0e9f7de8b..d6f3fb242223 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -30,6 +30,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_BOOT=y +CONFIG_SPL_INIT_MINIMAL=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 092681c1d83c..50bf852203c1 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -29,6 +29,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index f505a7a50872..a99f46a88011 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -32,6 +32,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index bf998dacf99a..cbae767fceb6 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -22,6 +22,7 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$con CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276 diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index b45e23f32c17..1031ebe4628f 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -29,6 +29,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_BOOT=y +CONFIG_SPL_INIT_MINIMAL=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 5e152d6b36b2..6c757c2a69e4 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 75f16593fb7c..91ca330b119f 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -31,6 +31,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index b68777dfa4cd..f33b69d97d7e 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -21,6 +21,7 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$con CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276 diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index dc2b7b3f61bb..218985606d1d 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -34,6 +34,8 @@ CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 9a3e19a98f89..d0b7f7174e02 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -35,6 +35,8 @@ CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 2381a0d30e95..fce2aac36b2c 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -38,6 +38,8 @@ CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index e221dd059222..7c0e35b67b49 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -30,6 +30,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 7a6c96c4ffd7..bd9d1aefc607 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -31,6 +31,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index d39b9e07e201..21a7c18a29bf 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -34,6 +34,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index ec54a71b016d..5b17526766aa 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -35,6 +35,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 0d57dade82d6..a3ec6bc5bc90 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -36,6 +36,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 3838e28f415d..956835167bd4 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -39,6 +39,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index c6df1fc65732..8a6e6899c80f 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -33,6 +33,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 7fc6ec429ccc..beb714a7027d 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -34,6 +34,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index ebc948c18a07..14fa9f6efde0 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -37,6 +37,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T2080RDB_revD_NAND_defconfig b/configs/T2080RDB_revD_NAND_defconfig index 03529ff0d8b2..3ba54841f2af 100644 --- a/configs/T2080RDB_revD_NAND_defconfig +++ b/configs/T2080RDB_revD_NAND_defconfig @@ -34,6 +34,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T2080RDB_revD_SDCARD_defconfig b/configs/T2080RDB_revD_SDCARD_defconfig index 35ce1edd6896..9afa79b0f714 100644 --- a/configs/T2080RDB_revD_SDCARD_defconfig +++ b/configs/T2080RDB_revD_SDCARD_defconfig @@ -35,6 +35,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T2080RDB_revD_SPIFLASH_defconfig b/configs/T2080RDB_revD_SPIFLASH_defconfig index 14ae4f0e961b..f86de3a6852c 100644 --- a/configs/T2080RDB_revD_SPIFLASH_defconfig +++ b/configs/T2080RDB_revD_SPIFLASH_defconfig @@ -38,6 +38,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index 6d2708135851..fe5481ec7fc0 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -32,6 +32,8 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y +CONFIG_SPL_FLUSH_IMAGE=y +CONFIG_SPL_SKIP_RELOCATE=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 0c4a2f01ad4a..8667941a0ab3 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -16,7 +16,6 @@ #include <asm/config_mpc85xx.h>
#ifdef CONFIG_SDCARD -#define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_PAD_TO 0x18000 #define CONFIG_SPL_MAX_SIZE (96 * 1024) @@ -36,7 +35,6 @@ #define CONFIG_RESET_VECTOR_ADDRESS 0x110bfffc #else #define CONFIG_SPL_SPI_FLASH_MINIMAL -#define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_PAD_TO 0x18000 #define CONFIG_SPL_MAX_SIZE (96 * 1024) @@ -53,8 +51,6 @@
#ifdef CONFIG_MTD_RAW_NAND #ifdef CONFIG_NXP_ESBC -#define CONFIG_SPL_INIT_MINIMAL -#define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin"
#define CONFIG_SPL_MAX_SIZE 8192 @@ -65,7 +61,6 @@ #define CONFIG_SYS_NAND_U_BOOT_START 0x00200000 #else #ifdef CONFIG_TPL_BUILD -#define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_NAND_INIT #define CONFIG_SPL_COMMON_INIT_DDR #define CONFIG_SPL_MAX_SIZE (128 << 10) @@ -74,8 +69,6 @@ #define CONFIG_SYS_NAND_U_BOOT_DST (0x11000000) #define CONFIG_SYS_NAND_U_BOOT_START (0x11000000) #elif defined(CONFIG_SPL_BUILD) -#define CONFIG_SPL_INIT_MINIMAL -#define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_MAX_SIZE 8192 #define CONFIG_SYS_NAND_U_BOOT_SIZE (128 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0xD0000000 @@ -455,7 +448,7 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_INIT_MINIMAL) +#if defined(CONFIG_SPL_BUILD) && CONFIG_IS_ENABLED(INIT_MINIMAL) #define CONFIG_NS16550_MIN_FUNCTIONS #endif
diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index e7cc39e78a92..30570ad51198 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -21,13 +21,11 @@ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS
#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_PAD_TO 0x40000 #define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC #define BOOT_PAGE_OFFSET 0x27000 #ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_SKIP_RELOCATE #define CONFIG_SPL_COMMON_INIT_DDR #define CONFIG_SYS_CCSR_DO_NOT_RELOCATE #endif diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index de31f695c601..2d9c8fcd175e 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -15,11 +15,9 @@ #include <asm/config_mpc85xx.h>
#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_PAD_TO 0x40000 #define CONFIG_SPL_MAX_SIZE 0x28000 #ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_SKIP_RELOCATE #define CONFIG_SPL_COMMON_INIT_DDR #define CONFIG_SYS_CCSR_DO_NOT_RELOCATE #endif diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 82e0fc46c7b6..1f546f4407c8 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -29,13 +29,11 @@ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS
#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_PAD_TO 0x40000 #define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC #define BOOT_PAGE_OFFSET 0x27000 #ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_SKIP_RELOCATE #define CONFIG_SPL_COMMON_INIT_DDR #define CONFIG_SYS_CCSR_DO_NOT_RELOCATE #endif diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 943854432535..1bd4b36eb8bf 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -24,13 +24,11 @@ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS
#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_PAD_TO 0x40000 #define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC #define BOOT_PAGE_OFFSET 0x27000 #ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_SKIP_RELOCATE #define CONFIG_SPL_COMMON_INIT_DDR #define CONFIG_SYS_CCSR_DO_NOT_RELOCATE #endif diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 834855c336c9..934f98ca3730 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -22,7 +22,6 @@ #define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #else -#define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_PAD_TO 0x40000 #define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC @@ -40,7 +39,6 @@ #endif
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_SKIP_RELOCATE #define CONFIG_SPL_COMMON_INIT_DDR #define CONFIG_SYS_CCSR_DO_NOT_RELOCATE #endif diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index f6ecf2a7a8b8..d2c8d23c31c0 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -77,7 +77,6 @@ #endif
#ifdef CONFIG_SDCARD -#define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SPL_MAX_SIZE (128 * 1024) @@ -91,7 +90,6 @@ #endif #elif defined(CONFIG_SPIFLASH) #define CONFIG_SPL_SPI_FLASH_MINIMAL -#define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SPL_MAX_SIZE (128 * 1024) @@ -105,7 +103,6 @@ #endif #elif defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_TPL_BUILD -#define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_NAND_INIT #define CONFIG_SPL_COMMON_INIT_DDR #define CONFIG_SPL_MAX_SIZE (128 << 10) @@ -114,8 +111,6 @@ #define CONFIG_SYS_NAND_U_BOOT_DST (0x11000000) #define CONFIG_SYS_NAND_U_BOOT_START (0x11000000) #elif defined(CONFIG_SPL_BUILD) -#define CONFIG_SPL_INIT_MINIMAL -#define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_MAX_SIZE 4096 #define CONFIG_SYS_NAND_U_BOOT_SIZE (128 << 10) @@ -402,7 +397,7 @@ #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_INIT_MINIMAL) +#if defined(CONFIG_SPL_BUILD) && CONFIG_IS_ENABLED(INIT_MINIMAL) #define CONFIG_NS16550_MIN_FUNCTIONS #endif
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index a5e36698b1ff..e40f9fc06c02 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -571,12 +571,10 @@ CONFIG_SPL_BSS_START_ADDR CONFIG_SPL_CMT CONFIG_SPL_CMT_DEBUG CONFIG_SPL_COMMON_INIT_DDR -CONFIG_SPL_FLUSH_IMAGE CONFIG_SPL_FS_LOAD_ARGS_NAME CONFIG_SPL_FS_LOAD_KERNEL_NAME CONFIG_SPL_FS_LOAD_PAYLOAD_NAME CONFIG_SPL_GD_ADDR -CONFIG_SPL_INIT_MINIMAL CONFIG_SPL_MAX_FOOTPRINT CONFIG_SPL_MAX_SIZE CONFIG_SPL_NAND_INIT @@ -591,7 +589,6 @@ CONFIG_SPL_RELOC_STACK CONFIG_SPL_RELOC_TEXT_BASE CONFIG_SPL_SATA_BOOT_DEVICE CONFIG_SPL_SIZE -CONFIG_SPL_SKIP_RELOCATE CONFIG_SPL_SPI_FLASH_MINIMAL CONFIG_SPL_STACK CONFIG_SPL_STACK_ADDR
This converts the following to Kconfig: CONFIG_SPL_NAND_RAW_ONLY CONFIG_SPL_NAND_SOFTECC
Signed-off-by: Tom Rini trini@konsulko.com --- README | 4 ---- common/spl/Kconfig | 12 +++++++++++- configs/axm_defconfig | 2 ++ configs/corvus_defconfig | 2 ++ configs/devkit3250_defconfig | 2 ++ configs/gardena-smart-gateway-at91sam_defconfig | 1 + configs/smartweb_defconfig | 2 ++ configs/taurus_defconfig | 2 ++ include/configs/at91sam9m10g45ek.h | 1 - include/configs/corvus.h | 2 -- include/configs/devkit3250.h | 5 ----- include/configs/gardena-smart-gateway-at91sam.h | 1 - include/configs/pm9g45.h | 1 - include/configs/smartweb.h | 2 -- include/configs/taurus.h | 2 -- scripts/config_whitelist.txt | 2 -- 16 files changed, 22 insertions(+), 21 deletions(-)
diff --git a/README b/README index 484a2c500ccf..0fd92cfaebc5 100644 --- a/README +++ b/README @@ -1743,10 +1743,6 @@ The following options need to be configured: Support for a lightweight UBI (fastmap) scanner and loader
- CONFIG_SPL_NAND_RAW_ONLY - Support to boot only raw u-boot.bin images. Use this only - if you need to save space. - CONFIG_SPL_COMMON_INIT_DDR Set for common ddr init with serial presence detect in SPL binary. diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 42681211d0df..b45607b3f758 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -763,13 +763,23 @@ config SPL_NAND_SUPPORT This enables the drivers in drivers/mtd/nand/raw as part of an SPL build.
+config SPL_NAND_RAW_ONLY + bool "Support to boot only raw u-boot.bin images" + depends on SPL_NAND_SUPPORT + help + Use this only if you need to save space. + config SPL_NAND_DRIVERS bool "Use standard NAND driver" help SPL uses normal NAND drivers, not minimal drivers.
config SPL_NAND_ECC - bool "Include standard software ECC in the SPL" + bool "Include standard ECC in SPL" + +config SPL_NAND_SOFTECC + bool "Use software ECC in SPL" + depends on SPL_NAND_ECC
config SPL_NAND_SIMPLE bool "Support simple NAND drivers in SPL" diff --git a/configs/axm_defconfig b/configs/axm_defconfig index d17cdd29c562..ebda5a49fe99 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -39,8 +39,10 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_CRC32=y CONFIG_SPL_NAND_SUPPORT=y +CONFIG_SPL_NAND_RAW_ONLY=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y +CONFIG_SPL_NAND_SOFTECC=y CONFIG_SPL_NAND_BASE=y CONFIG_SPL_DM_SPI_FLASH=y CONFIG_HUSH_PARSER=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 443f15e71d38..9b55d9e87db0 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -32,8 +32,10 @@ CONFIG_BOOTCOMMAND="nand read 0x70000000 0x200000 0x300000;bootm 0x70000000" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NAND_SUPPORT=y +CONFIG_SPL_NAND_RAW_ONLY=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y +CONFIG_SPL_NAND_SOFTECC=y CONFIG_SPL_NAND_BASE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index 71e80e804853..5b25463df969 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -26,8 +26,10 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NAND_SUPPORT=y +CONFIG_SPL_NAND_RAW_ONLY=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y +CONFIG_SPL_NAND_SOFTECC=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_CMD_IMLS=y CONFIG_CMD_GPIO=y diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index 0dbd0849581a..2ee716365341 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -35,6 +35,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_NAND_SUPPORT=y +CONFIG_SPL_NAND_RAW_ONLY=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_BASE=y CONFIG_HUSH_PARSER=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index a9f90e907538..b3c6d23e717b 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -33,8 +33,10 @@ CONFIG_BOOTCOMMAND="run flashboot" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_NAND_SUPPORT=y +CONFIG_SPL_NAND_RAW_ONLY=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y +CONFIG_SPL_NAND_SOFTECC=y CONFIG_SPL_NAND_BASE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 90f9133cb62d..8bc5afdc2e51 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -43,8 +43,10 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_CRC32=y CONFIG_SPL_NAND_SUPPORT=y +CONFIG_SPL_NAND_RAW_ONLY=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y +CONFIG_SPL_NAND_SOFTECC=y CONFIG_SPL_NAND_BASE=y CONFIG_SPL_DM_SPI_FLASH=y CONFIG_HUSH_PARSER=y diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 38b9061080ab..2930d7a1499f 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -56,7 +56,6 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
#elif CONFIG_NAND_BOOT -#define CONFIG_SPL_NAND_SOFTECC #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000
#define CONFIG_SYS_NAND_ECCSIZE 256 diff --git a/include/configs/corvus.h b/include/configs/corvus.h index 4809b59ecc39..b4fef73121af 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -63,8 +63,6 @@ #define CONFIG_SPL_BSS_START_ADDR CONFIG_SPL_MAX_SIZE #define CONFIG_SPL_BSS_MAX_SIZE (SZ_2K)
-#define CONFIG_SPL_NAND_RAW_ONLY -#define CONFIG_SPL_NAND_SOFTECC #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index 93a704cc31d6..d2a760e9b1f6 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -97,11 +97,6 @@
/* SPL will use serial */
-/* SPL loads an image from NAND */ -#define CONFIG_SPL_NAND_RAW_ONLY - -#define CONFIG_SPL_NAND_SOFTECC - #define CONFIG_SPL_MAX_SIZE 0x20000 #define CONFIG_SPL_PAD_TO CONFIG_SPL_MAX_SIZE
diff --git a/include/configs/gardena-smart-gateway-at91sam.h b/include/configs/gardena-smart-gateway-at91sam.h index 5e6a8ee770e0..3e99d2cfb04d 100644 --- a/include/configs/gardena-smart-gateway-at91sam.h +++ b/include/configs/gardena-smart-gateway-at91sam.h @@ -51,7 +51,6 @@ #define CONFIG_SYS_MCKR 0x1301 #define CONFIG_SYS_MCKR_CSS 0x1302
-#define CONFIG_SPL_NAND_RAW_ONLY #define CONFIG_SYS_NAND_U_BOOT_SIZE 0xa0000 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index b858aaa1ccd9..658b8a7f15ff 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -61,7 +61,6 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
#define CONFIG_SYS_NAND_ECCSIZE 256 diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index b51a5203547d..d58d76d10914 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -126,8 +126,6 @@ #define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN
#define CONFIG_SYS_NAND_ENABLE_PIN_SPL (2*32 + 14) -#define CONFIG_SPL_NAND_RAW_ONLY -#define CONFIG_SPL_NAND_SOFTECC #define CONFIG_SYS_NAND_U_BOOT_SIZE SZ_512K #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 77d80bfc9813..768bfc6cc6c3 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -152,8 +152,6 @@ #define CONFIG_SPL_BSS_MAX_SIZE (3 * SZ_512)
#define CONFIG_SYS_NAND_ENABLE_PIN_SPL (2*32 + 14) -#define CONFIG_SPL_NAND_RAW_ONLY -#define CONFIG_SPL_NAND_SOFTECC #define CONFIG_SYS_NAND_U_BOOT_SIZE SZ_512K #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e40f9fc06c02..d777c0ffa838 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -579,8 +579,6 @@ CONFIG_SPL_MAX_FOOTPRINT CONFIG_SPL_MAX_SIZE CONFIG_SPL_NAND_INIT CONFIG_SPL_NAND_MINIMAL -CONFIG_SPL_NAND_RAW_ONLY -CONFIG_SPL_NAND_SOFTECC CONFIG_SPL_PAD_TO CONFIG_SPL_PBL_PAD CONFIG_SPL_RELOC_MALLOC_ADDR
This converts the following to Kconfig: CONFIG_SPL_FS_LOAD_ARGS_NAME CONFIG_SPL_FS_LOAD_KERNEL_NAME CONFIG_SPL_FS_LOAD_PAYLOAD_NAME
Signed-off-by: Tom Rini trini@konsulko.com --- README | 11 -------- common/spl/Kconfig | 25 +++++++++++++++++++ common/spl/spl_sata.c | 4 --- configs/am335x_evm_defconfig | 1 + configs/am335x_evm_spiboot_defconfig | 1 + configs/am335x_hs_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_rtconly_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/am57xx_hs_evm_usb_defconfig | 1 + configs/am64x_evm_a53_defconfig | 1 + configs/am65x_evm_a53_defconfig | 1 + configs/am65x_hs_evm_a53_defconfig | 1 + ...edev_cc_v1_0_ultrazedev_som_v1_0_defconfig | 2 ++ configs/dra7xx_evm_defconfig | 1 + configs/dra7xx_hs_evm_defconfig | 1 + configs/dra7xx_hs_evm_usb_defconfig | 1 + configs/imx6q_logic_defconfig | 1 + configs/j7200_evm_a72_defconfig | 1 + configs/j721e_evm_a72_defconfig | 1 + configs/j721e_hs_evm_a72_defconfig | 1 + configs/j721s2_evm_a72_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6sabreauto_defconfig | 1 + configs/mx6slevk_spl_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/novena_defconfig | 1 + configs/openpiton_riscv64_spl_defconfig | 1 + configs/pcm058_defconfig | 1 + configs/pico-imx6_defconfig | 1 + configs/riotboard_defconfig | 2 ++ configs/syzygy_hub_defconfig | 1 + configs/udoo_defconfig | 1 + configs/udoo_neo_defconfig | 1 + configs/vining_2000_defconfig | 1 + configs/wandboard_defconfig | 1 + configs/xilinx_zynq_virt_defconfig | 2 ++ configs/xilinx_zynqmp_virt_defconfig | 2 ++ include/configs/am3517_evm.h | 4 --- include/configs/am64x_evm.h | 4 --- include/configs/am65x_evm.h | 4 --- include/configs/at91sam9m10g45ek.h | 2 -- include/configs/at91sam9n12ek.h | 4 --- include/configs/at91sam9x5ek.h | 4 --- include/configs/ax25-ae350.h | 4 --- include/configs/embestmx6boards.h | 2 -- include/configs/imx6-engicam.h | 2 -- include/configs/imx6_logic.h | 2 -- include/configs/imx6_spl.h | 9 ------- include/configs/imx6dl-mamoj.h | 2 -- include/configs/imx7_spl.h | 9 ------- include/configs/j721e_evm.h | 4 --- include/configs/j721s2_evm.h | 4 --- include/configs/ls1046ardb.h | 2 -- include/configs/mccmon6.h | 1 - include/configs/mx6sabreauto.h | 2 -- include/configs/mx6sabresd.h | 2 -- include/configs/openpiton-riscv64.h | 1 - include/configs/pico-imx6.h | 2 -- include/configs/pico-imx6ul.h | 2 -- include/configs/pico-imx7d.h | 2 -- include/configs/pm9g45.h | 2 -- include/configs/rk3288_common.h | 3 --- include/configs/sama5d27_som1_ek.h | 4 --- include/configs/sama5d27_wlsom1_ek.h | 4 --- include/configs/sama5d2_icp.h | 4 --- include/configs/sama5d2_xplained.h | 4 --- include/configs/sama5d3_xplained.h | 6 ----- include/configs/sama5d3xek.h | 4 --- include/configs/sama5d4_xplained.h | 4 --- include/configs/sama5d4ek.h | 4 --- include/configs/siemens-am33x-common.h | 2 -- include/configs/sniper.h | 2 -- include/configs/socfpga_common.h | 7 ------ include/configs/socfpga_soc64_common.h | 7 ------ include/configs/ti814x_evm.h | 2 -- include/configs/ti_armv7_common.h | 8 ------ include/configs/topic_miami.h | 1 - include/configs/vyasa-rk3288.h | 2 -- include/configs/xilinx_zynqmp.h | 7 ------ include/configs/zynq-common.h | 8 ------ scripts/config_whitelist.txt | 1 - 86 files changed, 68 insertions(+), 175 deletions(-)
diff --git a/README b/README index 0fd92cfaebc5..f39b215d019f 100644 --- a/README +++ b/README @@ -1722,17 +1722,6 @@ The following options need to be configured: parameters from when MMC is being used in raw mode (for falcon mode)
- CONFIG_SPL_FS_LOAD_PAYLOAD_NAME - Filename to read to load U-Boot when reading from filesystem - - CONFIG_SPL_FS_LOAD_KERNEL_NAME - Filename to read to load kernel uImage when reading - from filesystem (for Falcon mode) - - CONFIG_SPL_FS_LOAD_ARGS_NAME - Filename to read to load kernel argument parameters - when reading from filesystem (for Falcon mode) - CONFIG_SPL_MPC83XX_WAIT_FOR_NAND Set this for NAND SPL on PPC mpc83xx targets, so that start.S waits for the rest of the SPL to load before diff --git a/common/spl/Kconfig b/common/spl/Kconfig index b45607b3f758..df2075c7cf28 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -605,6 +605,31 @@ config SPL_FS_FAT filesystem from within SPL. Support for the underlying block device (e.g. MMC or USB) must be enabled separately.
+config SPL_FS_LOAD_PAYLOAD_NAME + string "File to load for U-Boot from the filesystem" + depends on SPL_FS_EXT4 || SPL_FS_FAT || SPL_FS_SQUASHFS + default "tispl.bin" if SYS_K3_SPL_ATF + default "u-boot.itb" if SPL_LOAD_FIT + default "u-boot.img" + help + Filename to read to load U-Boot when reading from filesystem. + +config SPL_FS_LOAD_KERNEL_NAME + string "File to load for the OS kernel from the filesystem" + depends on (SPL_FS_EXT4 || SPL_FS_FAT || SPL_FS_SQUASHFS) && SPL_OS_BOOT + default "uImage" + help + Filename to read to load for the OS kernel when reading from the + filesystem. + +config SPL_FS_LOAD_ARGS_NAME + string "File to load for the OS kernel argument parameters from the filesystem" + depends on (SPL_FS_EXT4 || SPL_FS_FAT || SPL_FS_SQUASHFS) && SPL_OS_BOOT + default "args" + help + Filename to read to load for the OS kernel argument parameters from + the filesystem. + config SPL_FAT_WRITE bool "Support write for FAT filesystems" help diff --git a/common/spl/spl_sata.c b/common/spl/spl_sata.c index d03f86344e05..1351d78612a5 100644 --- a/common/spl/spl_sata.c +++ b/common/spl/spl_sata.c @@ -21,10 +21,6 @@ #define CONFIG_SYS_SATA_FAT_BOOT_PARTITION 1 #endif
-#ifndef CONFIG_SPL_FS_LOAD_PAYLOAD_NAME -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif - #ifndef CONFIG_SPL_SATA_RAW_U_BOOT_SECTOR /* Dummy value to make the compiler happy */ #define CONFIG_SPL_SATA_RAW_U_BOOT_SECTOR 0x100 diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 17c67108b692..c7d19315016f 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -21,6 +21,7 @@ CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_ETH=y # CONFIG_SPL_FS_EXT4 is not set +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_MUSB_NEW=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 3f3a81a1d98b..bdb0ef0b976e 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_FIT_IMAGE_TINY=y # CONFIG_SPL_FS_EXT4 is not set +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_DM_SPI_FLASH=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index 074a654b55a2..7123a167eb3f 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -20,6 +20,7 @@ CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_FIT_IMAGE_TINY=y # CONFIG_SPL_ENV_SUPPORT is not set # CONFIG_SPL_FS_EXT4 is not set +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 6e37c2ca2d78..24ecf1fbe026 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_ETH=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 6b24aac067a7..6c9a62c40df4 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index a3de93d9bf9c..2bd98cf4f7e2 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index cc75fe9eb3d4..33b008f5a902 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -23,6 +23,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_ETH=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index c19ec97a8320..2769d3518c68 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -28,6 +28,7 @@ CONFIG_AVB_VERIFY=y CONFIG_ANDROID_AB=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_DMA=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index ca78622eb2b8..2d23db26c6ba 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -31,6 +31,7 @@ CONFIG_AVB_VERIFY=y CONFIG_ANDROID_AB=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_DMA=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index 40c628a4988f..b218b1b50d02 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -34,6 +34,7 @@ CONFIG_AVB_VERIFY=y CONFIG_ANDROID_AB=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_DMA=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index 489a750230b3..ed603a19f5b7 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -38,6 +38,7 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_ETH=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_I2C=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_DM_SPI_FLASH=y diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index 3c654391b13d..236e32f21a37 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -39,6 +39,7 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_I2C=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am65x_hs_evm_a53_defconfig b/configs/am65x_hs_evm_a53_defconfig index ccfd0dbe5f75..99c78d3b425c 100644 --- a/configs/am65x_hs_evm_a53_defconfig +++ b/configs/am65x_hs_evm_a53_defconfig @@ -38,6 +38,7 @@ CONFIG_SPL_STACK_R=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_I2C=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig index a98aa8caf584..90ca33b8244b 100644 --- a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig +++ b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig @@ -26,6 +26,8 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x10000000 CONFIG_BOOTDELAY=0 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_CLOCKS=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_OS_BOOT=y CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=2073 diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index dcb7b3f78f7f..f04a2fbca6fa 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -28,6 +28,7 @@ CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_DMA=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y CONFIG_SPL_NAND_BASE=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 340d4f99f87d..6bb5c3c2ad00 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -31,6 +31,7 @@ CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_DMA=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index 12b92f3bc4ae..652d9924bb88 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -33,6 +33,7 @@ CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_DMA=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index e804f75247c0..c5ad6dcdd1f2 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL_RAW_IMAGE_SUPPORT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_DMA=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index f90a184c63fc..ac5152a164ce 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -39,6 +39,7 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_I2C=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index 90805e43a91b..b507f23e8df3 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -36,6 +36,7 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_I2C=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_DM_SPI_FLASH=y diff --git a/configs/j721e_hs_evm_a72_defconfig b/configs/j721e_hs_evm_a72_defconfig index ae2865b30330..a07204dd98ed 100644 --- a/configs/j721e_hs_evm_a72_defconfig +++ b/configs/j721e_hs_evm_a72_defconfig @@ -34,6 +34,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_I2C=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_DM_SPI_FLASH=y diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index 6bb2e6a31870..90b941157beb 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -39,6 +39,7 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_I2C=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index b5bff664878e..41122ade90e1 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -27,6 +27,7 @@ CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="if hdmidet; then usb start; setenv stdin serial,usbkbd; setenv stdout serial,vidconsole; setenv stderr serial,vidconsole; else setenv stdin serial; setenv stdout serial; setenv stderr serial; fi;" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y CONFIG_SPL_WATCHDOG=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index f96bbcd07c30..3d2e906f934b 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -35,6 +35,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y CONFIG_SPL_USB_HOST=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index ebc3f2272a2c..ed7808d798e7 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -26,6 +26,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 51dfe8ce03a2..065ead0a7ad2 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -28,6 +28,7 @@ CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc resc CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y CONFIG_SPL_USB_HOST=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index d2ef51e00423..2f46b68cbe97 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -28,6 +28,7 @@ CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc resc CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index a75ce588c516..215aaa605b52 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -32,6 +32,7 @@ CONFIG_BOOTCOMMAND="run distro_bootcmd ; run net_nfs" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_MISC_INIT_R=y CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y CONFIG_SPL_WATCHDOG=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/openpiton_riscv64_spl_defconfig b/configs/openpiton_riscv64_spl_defconfig index a5c01d365cc8..6e4e4549419d 100644 --- a/configs/openpiton_riscv64_spl_defconfig +++ b/configs/openpiton_riscv64_spl_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_BANNER_PRINT is not set CONFIG_SPL_CPU=y CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="boot/fw_payload.bin" CONFIG_SPL_RTC=y CONFIG_SYS_PROMPT="openpiton$ " CONFIG_SYS_CBSIZE=256 diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index 47e2199b47ba..54bef4e062e3 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -33,6 +33,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x18a CONFIG_SPL_DMA=y CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x31400 diff --git a/configs/pico-imx6_defconfig b/configs/pico-imx6_defconfig index 6887ee98ce1b..09809542606d 100644 --- a/configs/pico-imx6_defconfig +++ b/configs/pico-imx6_defconfig @@ -29,6 +29,7 @@ CONFIG_DEFAULT_FDT_FILE="ask" CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_USB_HOST=y CONFIG_SPL_USB_GADGET=y CONFIG_SPL_USB_SDP_SUPPORT=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index 15c1c5a3c442..8e74a1f087f9 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -29,6 +29,8 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" +CONFIG_SPL_FS_LOAD_ARGS_NAME="imx6dl-riotboard.dtb" CONFIG_SPL_OS_BOOT=y CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x0 diff --git a/configs/syzygy_hub_defconfig b/configs/syzygy_hub_defconfig index 4b4f692fe4f5..b1990841987e 100644 --- a/configs/syzygy_hub_defconfig +++ b/configs/syzygy_hub_defconfig @@ -26,6 +26,7 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_USE_PREBOOT=y CONFIG_CLOCKS=y CONFIG_SPL_STACK_R=y +CONFIG_SPL_FS_LOAD_ARGS_NAME="system.dtb" CONFIG_SPL_OS_BOOT=y CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x0 diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index d3b49bffeb75..e21945116c03 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -23,6 +23,7 @@ CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y CONFIG_SPL_WATCHDOG=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index 699e68986faa..fff11bb10e97 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -24,6 +24,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_WATCHDOG=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 diff --git a/configs/vining_2000_defconfig b/configs/vining_2000_defconfig index 4ee03411e9e9..a8c3d907d1d4 100644 --- a/configs/vining_2000_defconfig +++ b/configs/vining_2000_defconfig @@ -32,6 +32,7 @@ CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y CONFIG_SPL_USB_HOST=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 82fb14f1bb9c..fadc8af36eb5 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -35,6 +35,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y CONFIG_SPL_WATCHDOG=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index 61a748b4882b..5e724f063f9d 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -29,6 +29,8 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_USE_PREBOOT=y CONFIG_CLOCKS=y CONFIG_SPL_STACK_R=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" +CONFIG_SPL_FS_LOAD_ARGS_NAME="system.dtb" CONFIG_SPL_FPGA=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 698149711ca7..35625a4c1fa4 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -32,6 +32,8 @@ CONFIG_PREBOOT="run scsi_init;usb start" CONFIG_BOARD_EARLY_INIT_R=y CONFIG_CLOCKS=y CONFIG_SPL_STACK_R=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" +CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_FPGA=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index db3298781d1c..1848aecb3901 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -104,8 +104,4 @@
#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */
-/* Defines for SPL */ - -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - #endif /* __CONFIG_H */ diff --git a/include/configs/am64x_evm.h b/include/configs/am64x_evm.h index d84a8db97ede..0abaddcae6d2 100644 --- a/include/configs/am64x_evm.h +++ b/include/configs/am64x_evm.h @@ -18,10 +18,6 @@ /* DDR Configuration */ #define CONFIG_SYS_SDRAM_BASE1 0x880000000
-#ifdef CONFIG_SYS_K3_SPL_ATF -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "tispl.bin" -#endif - #define CONFIG_SPL_MAX_SIZE CONFIG_SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE #if defined(CONFIG_TARGET_AM642_A53_EVM) #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SPL_TEXT_BASE + SZ_4M) diff --git a/include/configs/am65x_evm.h b/include/configs/am65x_evm.h index b1f9050f3f5b..ba50c759c00f 100644 --- a/include/configs/am65x_evm.h +++ b/include/configs/am65x_evm.h @@ -44,10 +44,6 @@ #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_16M #endif
#define CONFIG_SYS_BOOTM_LEN SZ_64M diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 2930d7a1499f..20753e00de74 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -53,8 +53,6 @@ #define CONFIG_SYS_SPL_MALLOC_START 0x70080000 #define CONFIG_SYS_SPL_MALLOC_SIZE 0x00080000
-#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - #elif CONFIG_NAND_BOOT #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000
diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 7d378177b043..7bc8a36481db 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -75,8 +75,4 @@ #define CONFIG_SYS_MCKR 0x1301 #define CONFIG_SYS_MCKR_CSS 0x1302
-#ifdef CONFIG_SD_BOOT -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif - #endif diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 013c7cfc59ce..cab44d2645a2 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -70,8 +70,4 @@ #define CONFIG_SYS_MCKR 0x1301 #define CONFIG_SYS_MCKR_CSS 0x1302
-#ifdef CONFIG_SD_BOOT -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif - #endif diff --git a/include/configs/ax25-ae350.h b/include/configs/ax25-ae350.h index 264d708fa9f3..242b73f8f2f0 100644 --- a/include/configs/ax25-ae350.h +++ b/include/configs/ax25-ae350.h @@ -11,10 +11,6 @@ #define CONFIG_SPL_MAX_SIZE 0x00100000 #define CONFIG_SPL_BSS_START_ADDR 0x04000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 - -#ifdef CONFIG_SPL_MMC -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.itb" -#endif #endif
#define RISCV_MMODE_TIMERBASE 0xe6000000 diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 1bf564c36065..119d59951f26 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -59,8 +59,6 @@ #include "imx6_spl.h" /* RiOTboard */ #define CONFIG_SYS_SPL_ARGS_ADDR 0x13000000 -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "imx6dl-riotboard.dtb"
#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0 /* offset 69KB */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0 /* offset 69KB */ diff --git a/include/configs/imx6-engicam.h b/include/configs/imx6-engicam.h index 26d7a88ebde8..24b70bf82f83 100644 --- a/include/configs/imx6-engicam.h +++ b/include/configs/imx6-engicam.h @@ -140,8 +140,6 @@
/* Falcon Mode */ #ifdef CONFIG_SPL_OS_BOOT -# define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -# define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" # define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000
/* MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/imx6_logic.h b/include/configs/imx6_logic.h index 65f8944ccaf6..b77c335f9040 100644 --- a/include/configs/imx6_logic.h +++ b/include/configs/imx6_logic.h @@ -135,8 +135,6 @@ #endif
/* Falcon Mode */ -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" #define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/imx6_spl.h b/include/configs/imx6_spl.h index 7215bda973ff..38aec9436e46 100644 --- a/include/configs/imx6_spl.h +++ b/include/configs/imx6_spl.h @@ -63,15 +63,6 @@ #define CONFIG_SYS_SATA_FAT_BOOT_PARTITION 1 #endif
-/* Define the payload for FAT/EXT support */ -#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) -# ifdef CONFIG_OF_CONTROL -# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" -# else -# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -# endif -#endif - #if defined(CONFIG_MX6SX) || defined(CONFIG_MX6SL) || \ defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) #define CONFIG_SPL_BSS_START_ADDR 0x88200000 diff --git a/include/configs/imx6dl-mamoj.h b/include/configs/imx6dl-mamoj.h index ba79e1bccfa8..85ca89790c0c 100644 --- a/include/configs/imx6dl-mamoj.h +++ b/include/configs/imx6dl-mamoj.h @@ -51,8 +51,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
/* Falcon */ -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" #define CONFIG_SYS_SPL_ARGS_ADDR 0x13000000
/* MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/imx7_spl.h b/include/configs/imx7_spl.h index 128f612392fa..39136ea49a8e 100644 --- a/include/configs/imx7_spl.h +++ b/include/configs/imx7_spl.h @@ -43,15 +43,6 @@ #define CONFIG_SYS_MONITOR_LEN 409600 /* 400 KB */ #endif
-/* Define the payload for FAT/EXT support */ -#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) -# ifdef CONFIG_OF_CONTROL -# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" -# else -# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -# endif -#endif - #define CONFIG_SPL_BSS_START_ADDR 0x88200000 #define CONFIG_SPL_BSS_MAX_SIZE 0x100000 /* 1 MB */ #define CONFIG_SYS_SPL_MALLOC_START 0x88300000 diff --git a/include/configs/j721e_evm.h b/include/configs/j721e_evm.h index 2590ee6b0140..5538fee9460f 100644 --- a/include/configs/j721e_evm.h +++ b/include/configs/j721e_evm.h @@ -49,10 +49,6 @@ /* Image load address in RAM for DFU boot*/ #endif
#define CONFIG_SYS_BOOTM_LEN SZ_64M diff --git a/include/configs/j721s2_evm.h b/include/configs/j721s2_evm.h index a5505f079b43..d0a78fd7cc89 100644 --- a/include/configs/j721s2_evm.h +++ b/include/configs/j721s2_evm.h @@ -50,10 +50,6 @@ /* Image load address in RAM for DFU boot*/ #endif
#define CONFIG_SYS_BOOTM_LEN SZ_64M diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 3dfbae268e4e..ff76e6945673 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -139,8 +139,6 @@ #endif #endif
-#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - #include <asm/fsl_secure_boot.h>
#endif /* __LS1046ARDB_H__ */ diff --git a/include/configs/mccmon6.h b/include/configs/mccmon6.h index f24a00724173..df6c5094bef1 100644 --- a/include/configs/mccmon6.h +++ b/include/configs/mccmon6.h @@ -21,7 +21,6 @@ */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR (0x800) #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS (0x80) -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "fitImage"
#define CONFIG_MXC_UART_BASE UART1_BASE
diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index 4537fce19deb..00ca50a4e647 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -28,8 +28,6 @@
/* Falcon Mode */ #ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" #define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 5a854b9d1946..c78ddc42568c 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -18,8 +18,6 @@ #include "mx6sabre_common.h"
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/openpiton-riscv64.h b/include/configs/openpiton-riscv64.h index 75b48f880aff..f909aa862fdb 100644 --- a/include/configs/openpiton-riscv64.h +++ b/include/configs/openpiton-riscv64.h @@ -28,7 +28,6 @@ #define CONFIG_SPL_STACK (0x80000000 + 0x04000000 - \ GENERATED_GBL_DATA_SIZE)
-#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "boot/fw_payload.bin" #define CONFIG_SPL_GD_ADDR 0x85000000 #endif
diff --git a/include/configs/pico-imx6.h b/include/configs/pico-imx6.h index c288908046ac..b4b556f3bc0e 100644 --- a/include/configs/pico-imx6.h +++ b/include/configs/pico-imx6.h @@ -14,8 +14,6 @@
#ifdef CONFIG_SPL_OS_BOOT /* Falcon Mode */ -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" #define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index 1f111ea3064f..aadf6861ca1f 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -16,8 +16,6 @@
#ifdef CONFIG_SPL_OS_BOOT /* Falcon Mode */ -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" #define CONFIG_SYS_SPL_ARGS_ADDR 0x88000000
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index 06fd78f9da60..d196662dc3ee 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -14,8 +14,6 @@
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 658b8a7f15ff..0bcc2f35f5c3 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -58,8 +58,6 @@ #define CONFIG_SYS_SPL_MALLOC_START 0x70080000 #define CONFIG_SYS_SPL_MALLOC_SIZE 0x00080000
diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 77ab7cea2db1..ae57353ce352 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -23,9 +23,6 @@
/* RAW SD card / eMMC locations. */
-/* FAT sd card locations. */ -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - #define CONFIG_SYS_SDRAM_BASE 0 #define SDRAM_BANK_SIZE (2UL << 30) #define SDRAM_MAX_SIZE 0xfe000000 diff --git a/include/configs/sama5d27_som1_ek.h b/include/configs/sama5d27_som1_ek.h index b9144584e3ed..1ac4f66a91c4 100644 --- a/include/configs/sama5d27_som1_ek.h +++ b/include/configs/sama5d27_som1_ek.h @@ -30,8 +30,4 @@
#define CONFIG_SYS_MONITOR_LEN (512 << 10)
-#ifdef CONFIG_SD_BOOT -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif - #endif diff --git a/include/configs/sama5d27_wlsom1_ek.h b/include/configs/sama5d27_wlsom1_ek.h index e611e7b51047..a1c0e6a1eb63 100644 --- a/include/configs/sama5d27_wlsom1_ek.h +++ b/include/configs/sama5d27_wlsom1_ek.h @@ -35,8 +35,4 @@
-#ifdef CONFIG_SD_BOOT -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif - #endif diff --git a/include/configs/sama5d2_icp.h b/include/configs/sama5d2_icp.h index c3a5c2ae323b..8cb80efe8e5b 100644 --- a/include/configs/sama5d2_icp.h +++ b/include/configs/sama5d2_icp.h @@ -42,8 +42,4 @@
-#ifdef CONFIG_SD_BOOT -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif - #endif diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index cab6ae506984..c2fe118b5bcd 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -27,8 +27,4 @@
-#ifdef CONFIG_SD_BOOT -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif - #endif diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index 68bbe8f29c84..1617ebc643da 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -65,10 +65,6 @@ /* size of u-boot.bin to load */ #define CONFIG_SYS_MONITOR_LEN (2 * SZ_512K)
-#ifdef CONFIG_SD_BOOT -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif - /* Falcon boot support on raw MMC */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x100 /* 128 KiB */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS (CONFIG_CMD_SPL_WRITE_SIZE / 512) @@ -76,8 +72,6 @@ #define CONFIG_SYS_SPL_ARGS_ADDR 0x22000000
/* Falcon boot support on FAT on MMC */ -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage"
/* Falcon boot support on raw NAND */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x1a0000 diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 3be2c83fce0f..94f4ae6a1f05 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -76,8 +76,4 @@
-#ifdef CONFIG_SD_BOOT -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif - #endif diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index e0e0bc6beb7c..42a7ac402d22 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -41,8 +41,4 @@
-#ifdef CONFIG_SD_BOOT -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif - #endif diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index 2549d4c1a19a..6519956e09cf 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -41,8 +41,4 @@
-#ifdef CONFIG_SD_BOOT -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif - #endif diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 2b4d05b7165b..22c6015e28a9 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -59,8 +59,6 @@ #define CONFIG_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */
-#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/sniper.h b/include/configs/sniper.h index 2daaadd3146e..e8a57faac528 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -58,8 +58,6 @@ #define CONFIG_SYS_SPL_MALLOC_SIZE (1024 * 1024) #define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK
-#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - /* * Serial */ diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index e8ee53969c49..23467773ce34 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -162,13 +162,6 @@ #define CONFIG_SPL_MAX_SIZE CONFIG_SYS_INIT_RAM_SIZE #endif
-/* SPL SDMMC boot support */ -#ifdef CONFIG_SPL_MMC -#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif -#endif - /* SPL QSPI boot support */
/* SPL NAND boot support */ diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index 045e66492e48..750cc00f849f 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -162,11 +162,4 @@ unsigned int cm_get_l4_sys_free_clk_hz(void); #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR \ - CONFIG_SYS_SPL_MALLOC_SIZE)
-/* SPL SDMMC boot support */ -#ifdef CONFIG_SPL_LOAD_FIT -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.itb" -#else -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif - #endif /* __CONFIG_SOCFPGA_SOC64_COMMON_H__ */ diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index ff5bbad90e79..299eec75bdfe 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -93,8 +93,6 @@ #define CONFIG_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */
-#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - #define CONFIG_SYS_SPI_U_BOOT_SIZE 0x40000
/* diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index cd136f696a47..a4fdc2de8b21 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -132,16 +132,8 @@ CONFIG_SPL_TEXT_BASE) #endif
- -/* FAT sd card locations. */ -#ifndef CONFIG_SPL_FS_LOAD_PAYLOAD_NAME -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif - #ifdef CONFIG_SPL_OS_BOOT /* FAT */ -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args"
/* RAW SD card / eMMC */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x1500 /* address 0x2A0000 */ diff --git a/include/configs/topic_miami.h b/include/configs/topic_miami.h index f859656b396c..f8c782123acd 100644 --- a/include/configs/topic_miami.h +++ b/include/configs/topic_miami.h @@ -19,7 +19,6 @@ /* SPL settings */ #undef CONFIG_SPL_MAX_FOOTPRINT #define CONFIG_SPL_MAX_FOOTPRINT CONFIG_SYS_SPI_U_BOOT_OFFS -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
/* Setup proper boot sequences for Miami boards */
diff --git a/include/configs/vyasa-rk3288.h b/include/configs/vyasa-rk3288.h index a51b169c618b..fb76e5544ac3 100644 --- a/include/configs/vyasa-rk3288.h +++ b/include/configs/vyasa-rk3288.h @@ -22,8 +22,6 @@
#ifndef CONFIG_TPL_BUILD /* Falcon Mode */ -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" #define CONFIG_SYS_SPL_ARGS_ADDR 0x0ffe5000
/* Falcon Mode - MMC support: args@16MB kernel@17MB */ diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 6c28be1ac530..9fc7c44dbaad 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -215,21 +215,14 @@ #endif
/* u-boot is like dtb */ -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "u-boot.bin" #define CONFIG_SYS_SPL_ARGS_ADDR 0x8000000
/* ATF is my kernel image */ -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "atf-uboot.ub"
/* MMC support */ #ifdef CONFIG_MMC_SDHCI_ZYNQ # define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0 /* unused */ # define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0 /* unused */ -# if defined(CONFIG_SPL_LOAD_FIT) -# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.itb" -# else -# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -# endif #endif
#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_DFU) diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 40ca3cedbb8e..a93dbfb10295 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -212,17 +212,9 @@ /* Boot FreeBSD/vxWorks from an ELF image */ #define CONFIG_SYS_MMC_MAX_DEVICE 1
-/* MMC support */ -#ifdef CONFIG_MMC_SDHCI_ZYNQ -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" -#endif - /* Address in RAM where the parameters must be copied by SPL. */ #define CONFIG_SYS_SPL_ARGS_ADDR 0x10000000
-#define CONFIG_SPL_FS_LOAD_ARGS_NAME "system.dtb" -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" - /* Not using MMC raw mode - just for compilation purpose */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0 #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index d777c0ffa838..7bfb44365b68 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -573,7 +573,6 @@ CONFIG_SPL_CMT_DEBUG CONFIG_SPL_COMMON_INIT_DDR CONFIG_SPL_FS_LOAD_ARGS_NAME CONFIG_SPL_FS_LOAD_KERNEL_NAME -CONFIG_SPL_FS_LOAD_PAYLOAD_NAME CONFIG_SPL_GD_ADDR CONFIG_SPL_MAX_FOOTPRINT CONFIG_SPL_MAX_SIZE
This converts the following to Kconfig: CONFIG_SPL_PAD_TO CONFIG_SPL_MAX_SIZE CONFIG_TPL_PAD_TO CONFIG_TPL_MAX_SIZE
Note that we need to make TPL_MAX_SIZE be hex, and so move and convert the existing places.
Signed-off-by: Tom Rini trini@konsulko.com --- README | 24 --------- arch/arm/mach-rockchip/px30/Kconfig | 3 -- arch/arm/mach-rockchip/rk322x/Kconfig | 3 -- arch/arm/mach-rockchip/rk3288/Kconfig | 3 -- arch/arm/mach-rockchip/rk3328/Kconfig | 3 -- arch/arm/mach-rockchip/rk3368/Kconfig | 3 -- arch/arm/mach-rockchip/rk3399/Kconfig | 3 -- common/spl/Kconfig | 50 +++++++++++++++++-- configs/P1010RDB-PA_36BIT_NAND_defconfig | 2 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 2 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 2 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 2 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 2 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 2 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 2 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 2 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 2 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 2 + configs/T1024RDB_SDCARD_defconfig | 2 + configs/T1024RDB_SPIFLASH_defconfig | 2 + configs/T1042D4RDB_NAND_defconfig | 2 + configs/T1042D4RDB_SDCARD_defconfig | 2 + configs/T1042D4RDB_SPIFLASH_defconfig | 2 + configs/T2080QDS_NAND_defconfig | 2 + configs/T2080QDS_SDCARD_defconfig | 2 + configs/T2080QDS_SPIFLASH_defconfig | 2 + configs/T2080RDB_NAND_defconfig | 2 + configs/T2080RDB_SDCARD_defconfig | 2 + configs/T2080RDB_SPIFLASH_defconfig | 2 + configs/T2080RDB_revD_NAND_defconfig | 2 + configs/T2080RDB_revD_SDCARD_defconfig | 2 + configs/T2080RDB_revD_SPIFLASH_defconfig | 2 + configs/T4240RDB_SDCARD_defconfig | 2 + configs/ae350_rv32_spl_defconfig | 1 + configs/ae350_rv32_spl_xip_defconfig | 1 + configs/ae350_rv64_spl_defconfig | 1 + configs/ae350_rv64_spl_xip_defconfig | 1 + configs/alt_defconfig | 1 + configs/am335x_hs_evm_defconfig | 1 + configs/am335x_hs_evm_uart_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_rtconly_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/am57xx_hs_evm_usb_defconfig | 1 + configs/am64x_evm_a53_defconfig | 1 + configs/am64x_evm_r5_defconfig | 1 + configs/am65x_evm_a53_defconfig | 1 + configs/am65x_evm_r5_defconfig | 1 + configs/am65x_evm_r5_usbdfu_defconfig | 1 + configs/am65x_evm_r5_usbmsc_defconfig | 1 + configs/am65x_hs_evm_a53_defconfig | 1 + configs/am65x_hs_evm_r5_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + ...edev_cc_v1_0_ultrazedev_som_v1_0_defconfig | 1 + configs/axm_defconfig | 2 + configs/bitmain_antminer_s9_defconfig | 1 + configs/cgtqmx8_defconfig | 1 + configs/chromebit_mickey_defconfig | 1 + configs/chromebook_bob_defconfig | 2 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_kevin_defconfig | 2 + configs/chromebook_minnie_defconfig | 1 + configs/chromebook_speedy_defconfig | 1 + configs/ci20_mmc_defconfig | 1 + configs/cl-som-imx7_defconfig | 1 + configs/clearfog_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/controlcenterdc_defconfig | 1 + configs/corvus_defconfig | 2 + configs/da850evm_defconfig | 1 + configs/da850evm_nand_defconfig | 1 + configs/db-88f6720_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-88f6820-gp_defconfig | 1 + configs/db-mv784mp-gp_defconfig | 1 + configs/deneb_defconfig | 1 + configs/devkit3250_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/dra7xx_evm_defconfig | 1 + configs/dra7xx_hs_evm_defconfig | 1 + configs/dra7xx_hs_evm_usb_defconfig | 1 + configs/ds414_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/elgin-rv1108_defconfig | 1 + configs/evb-px30_defconfig | 3 ++ configs/evb-px5_defconfig | 3 ++ configs/evb-rk3036_defconfig | 1 + configs/evb-rk3128_defconfig | 1 + configs/evb-rk3229_defconfig | 3 ++ configs/evb-rk3288_defconfig | 1 + configs/evb-rk3308_defconfig | 2 + configs/evb-rk3328_defconfig | 3 ++ configs/evb-rk3399_defconfig | 2 + configs/evb-rk3568_defconfig | 2 + configs/evb-rv1108_defconfig | 1 + configs/ficus-rk3399_defconfig | 2 + configs/firefly-px30_defconfig | 3 ++ configs/firefly-rk3288_defconfig | 1 + configs/firefly-rk3399_defconfig | 2 + .../gardena-smart-gateway-at91sam_defconfig | 2 + .../gardena-smart-gateway-mt7688_defconfig | 1 + configs/geekbox_defconfig | 2 + configs/giedi_defconfig | 1 + configs/gose_defconfig | 1 + configs/helios4_defconfig | 1 + configs/igep00x0_defconfig | 1 + configs/imx7_cm_defconfig | 1 + configs/imx8mm-cl-iot-gate-optee_defconfig | 1 + configs/imx8mm-cl-iot-gate_defconfig | 1 + configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 1 + configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 1 + configs/imx8mm-mx8menlo_defconfig | 1 + configs/imx8mm_beacon_defconfig | 1 + configs/imx8mm_data_modul_edm_sbc_defconfig | 1 + configs/imx8mm_evk_defconfig | 1 + configs/imx8mm_venice_defconfig | 1 + configs/imx8mn_beacon_2g_defconfig | 1 + configs/imx8mn_beacon_defconfig | 1 + configs/imx8mn_bsh_smm_s2_defconfig | 1 + configs/imx8mn_bsh_smm_s2pro_defconfig | 1 + configs/imx8mn_ddr4_evk_defconfig | 1 + configs/imx8mn_evk_defconfig | 1 + configs/imx8mn_var_som_defconfig | 1 + configs/imx8mn_venice_defconfig | 1 + configs/imx8mp_evk_defconfig | 1 + configs/imx8mp_rsb3720a1_4G_defconfig | 1 + configs/imx8mp_rsb3720a1_6G_defconfig | 1 + configs/imx8mp_venice_defconfig | 1 + configs/imx8mq_cm_defconfig | 1 + configs/imx8mq_evk_defconfig | 1 + configs/imx8mq_phanbell_defconfig | 1 + configs/imx8qm_mek_defconfig | 1 + configs/imx8qm_rom7720_a1_4G_defconfig | 1 + configs/imx8qxp_mek_defconfig | 1 + configs/imx8ulp_evk_defconfig | 1 + configs/iot2050_defconfig | 1 + configs/j7200_evm_a72_defconfig | 1 + configs/j7200_evm_r5_defconfig | 1 + configs/j721e_evm_a72_defconfig | 1 + configs/j721e_evm_r5_defconfig | 1 + configs/j721e_hs_evm_a72_defconfig | 1 + configs/j721e_hs_evm_r5_defconfig | 1 + configs/j721s2_evm_a72_defconfig | 1 + configs/j721s2_evm_r5_defconfig | 1 + configs/k2e_evm_defconfig | 1 + configs/k2e_hs_evm_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2g_hs_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/k2l_hs_evm_defconfig | 1 + configs/khadas-edge-captain-rk3399_defconfig | 2 + configs/khadas-edge-rk3399_defconfig | 2 + configs/khadas-edge-v-rk3399_defconfig | 2 + configs/koelsch_defconfig | 1 + configs/kontron-sl-mx8mm_defconfig | 1 + configs/kontron_pitx_imx8m_defconfig | 1 + configs/kontron_sl28_defconfig | 1 + configs/kylin-rk3036_defconfig | 1 + configs/lager_defconfig | 1 + configs/leez-rk3399_defconfig | 2 + configs/linkit-smart-7688_defconfig | 1 + configs/lion-rk3368_defconfig | 3 ++ configs/ls1021aiot_sdcard_defconfig | 2 + configs/ls1021aqds_nand_defconfig | 2 + configs/ls1021aqds_sdcard_ifc_defconfig | 2 + configs/ls1021aqds_sdcard_qspi_defconfig | 2 + configs/ls1021atsn_sdcard_defconfig | 2 + ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 2 + configs/ls1021atwr_sdcard_ifc_defconfig | 2 + configs/ls1021atwr_sdcard_qspi_defconfig | 2 + configs/ls1043aqds_nand_defconfig | 2 + configs/ls1043aqds_sdcard_ifc_defconfig | 2 + configs/ls1043aqds_sdcard_qspi_defconfig | 2 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 2 + configs/ls1043ardb_nand_defconfig | 2 + .../ls1043ardb_sdcard_SECURE_BOOT_defconfig | 2 + configs/ls1043ardb_sdcard_defconfig | 2 + configs/ls1046aqds_nand_defconfig | 2 + configs/ls1046aqds_sdcard_ifc_defconfig | 2 + configs/ls1046aqds_sdcard_qspi_defconfig | 2 + configs/ls1046ardb_emmc_defconfig | 2 + configs/ls1046ardb_qspi_spl_defconfig | 2 + .../ls1046ardb_sdcard_SECURE_BOOT_defconfig | 2 + configs/ls1046ardb_sdcard_defconfig | 2 + configs/ls1088aqds_sdcard_ifc_defconfig | 1 + configs/ls1088aqds_sdcard_qspi_defconfig | 1 + ...1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_sdcard_qspi_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 2 + configs/ls2080aqds_qspi_defconfig | 1 + configs/ls2080aqds_sdcard_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 2 + configs/ls2081ardb_defconfig | 1 + configs/ls2088aqds_tfa_defconfig | 1 + configs/ls2088ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_qspi_defconfig | 1 + configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 1 + configs/m53menlo_defconfig | 1 + configs/maxbcm_defconfig | 1 + configs/miqi-rk3288_defconfig | 1 + configs/mk808_defconfig | 4 +- configs/mt7620_mt7530_rfb_defconfig | 1 + configs/mt7620_rfb_defconfig | 1 + configs/mt7628_rfb_defconfig | 1 + configs/mt7629_rfb_defconfig | 1 + configs/nanopc-t4-rk3399_defconfig | 2 + configs/nanopi-m4-2gb-rk3399_defconfig | 2 + configs/nanopi-m4-rk3399_defconfig | 2 + configs/nanopi-m4b-rk3399_defconfig | 2 + configs/nanopi-neo4-rk3399_defconfig | 2 + configs/nanopi-r2s-rk3328_defconfig | 3 ++ configs/nanopi-r4s-rk3399_defconfig | 2 + configs/odroid-go2_defconfig | 3 ++ configs/omap35_logic_defconfig | 1 + configs/omap35_logic_somlv_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_logic_somlv_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/omap4_sdp4430_defconfig | 1 + configs/omap5_uevm_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/openpiton_riscv64_spl_defconfig | 1 + configs/orangepi-rk3399_defconfig | 2 + configs/orangepi_zero2_defconfig | 1 + configs/phycore-imx8mm_defconfig | 1 + configs/phycore-imx8mp_defconfig | 1 + configs/phycore-rk3288_defconfig | 1 + configs/pico-dwarf-imx7d_defconfig | 1 + configs/pico-hobbit-imx7d_defconfig | 1 + configs/pico-imx7d_bl33_defconfig | 1 + configs/pico-imx7d_defconfig | 1 + configs/pico-imx8mq_defconfig | 1 + configs/pico-nymph-imx7d_defconfig | 1 + configs/pico-pi-imx7d_defconfig | 1 + configs/pinebook-pro-rk3399_defconfig | 2 + configs/pm9g45_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/porter_defconfig | 1 + configs/puma-rk3399_defconfig | 2 + configs/px30-core-ctouch2-of10-px30_defconfig | 3 ++ configs/px30-core-ctouch2-px30_defconfig | 3 ++ configs/px30-core-edimm2.2-px30_defconfig | 3 ++ configs/qemu-riscv32_spl_defconfig | 1 + configs/qemu-riscv64_spl_defconfig | 1 + configs/roc-cc-rk3308_defconfig | 2 + configs/roc-cc-rk3328_defconfig | 3 ++ configs/roc-pc-mezzanine-rk3399_defconfig | 2 + configs/roc-pc-rk3399_defconfig | 2 + configs/rock-pi-4-rk3399_defconfig | 2 + configs/rock-pi-4c-rk3399_defconfig | 2 + configs/rock-pi-e-rk3328_defconfig | 3 ++ configs/rock-pi-n10-rk3399pro_defconfig | 2 + configs/rock-pi-n8-rk3288_defconfig | 1 + configs/rock2_defconfig | 1 + configs/rock64-rk3328_defconfig | 3 ++ configs/rock960-rk3399_defconfig | 2 + configs/rock_defconfig | 2 + configs/rockpro64-rk3399_defconfig | 2 + configs/sama5d27_giantboard_defconfig | 1 + configs/sama5d27_som1_ek_mmc1_defconfig | 1 + configs/sama5d27_som1_ek_mmc_defconfig | 1 + configs/sama5d27_som1_ek_qspiflash_defconfig | 1 + configs/sama5d27_wlsom1_ek_mmc_defconfig | 1 + .../sama5d27_wlsom1_ek_qspiflash_defconfig | 1 + configs/sama5d2_icp_mmc_defconfig | 1 + configs/sama5d2_icp_qspiflash_defconfig | 1 + configs/sama5d2_xplained_emmc_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_qspiflash_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d36ek_cmp_mmc_defconfig | 1 + configs/sama5d36ek_cmp_nandflash_defconfig | 1 + configs/sama5d36ek_cmp_spiflash_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sheep-rk3368_defconfig | 2 + configs/sifive_unleashed_defconfig | 1 + configs/sifive_unmatched_defconfig | 1 + configs/silk_defconfig | 1 + configs/smartweb_defconfig | 2 + configs/sniper_defconfig | 1 + configs/socfpga_agilex_atf_defconfig | 1 + configs/socfpga_agilex_defconfig | 1 + configs/socfpga_agilex_vab_defconfig | 1 + configs/socfpga_arria10_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_dbm_soc1_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_de10_nano_defconfig | 1 + configs/socfpga_de1_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_n5x_atf_defconfig | 1 + configs/socfpga_n5x_defconfig | 1 + configs/socfpga_n5x_vab_defconfig | 1 + configs/socfpga_secu1_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_stratix10_atf_defconfig | 1 + configs/socfpga_stratix10_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/stm32746g-eval_defconfig | 1 + configs/stm32746g-eval_spl_defconfig | 1 + configs/stm32f746-disco_defconfig | 1 + configs/stm32f746-disco_spl_defconfig | 1 + configs/stm32f769-disco_defconfig | 1 + configs/stm32f769-disco_spl_defconfig | 1 + configs/stout_defconfig | 1 + configs/syzygy_hub_defconfig | 1 + configs/taurus_defconfig | 2 + configs/theadorable_debug_defconfig | 1 + configs/ti816x_evm_defconfig | 1 + configs/tinker-rk3288_defconfig | 1 + configs/tinker-s-rk3288_defconfig | 3 +- configs/topic_miami_defconfig | 1 + configs/topic_miamilite_defconfig | 1 + configs/topic_miamiplus_defconfig | 1 + configs/turris_omnia_defconfig | 1 + configs/uniphier_ld4_sld8_defconfig | 2 + configs/uniphier_v7_defconfig | 2 + configs/uniphier_v8_defconfig | 2 + configs/verdin-imx8mm_defconfig | 1 + configs/verdin-imx8mp_defconfig | 1 + configs/vocore2_defconfig | 1 + configs/vyasa-rk3288_defconfig | 1 + configs/work_92105_defconfig | 1 + configs/x530_defconfig | 1 + configs/xilinx_zynq_virt_defconfig | 1 + configs/xilinx_zynqmp_mini_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc0_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc1_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_defconfig | 1 + .../xilinx_zynqmp_mini_nand_single_defconfig | 1 + configs/xilinx_zynqmp_mini_qspi_defconfig | 1 + configs/xilinx_zynqmp_virt_defconfig | 1 + configs/zynq_cse_nand_defconfig | 1 + configs/zynq_cse_nor_defconfig | 1 + configs/zynq_cse_qspi_defconfig | 1 + include/config_fallbacks.h | 8 --- include/configs/P1010RDB.h | 9 ---- include/configs/T102xRDB.h | 2 - include/configs/T104xRDB.h | 2 - include/configs/T208xQDS.h | 2 - include/configs/T208xRDB.h | 2 - include/configs/T4240RDB.h | 2 - include/configs/alt.h | 1 - include/configs/am64x_evm.h | 1 - include/configs/am65x_evm.h | 2 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/ax25-ae350.h | 1 - include/configs/bur_am335x_common.h | 2 - include/configs/capricorn-common.h | 1 - include/configs/cgtqmx8.h | 1 - include/configs/ci20.h | 2 - include/configs/clearfog.h | 1 - include/configs/controlcenterdc.h | 6 --- include/configs/corvus.h | 2 - include/configs/da850evm.h | 4 -- include/configs/db-88f6720.h | 1 - include/configs/db-88f6820-amc.h | 1 - include/configs/db-88f6820-gp.h | 1 - include/configs/db-mv784mp-gp.h | 1 - include/configs/devkit3250.h | 3 -- include/configs/ds414.h | 1 - include/configs/edminiv2.h | 1 - .../configs/gardena-smart-gateway-at91sam.h | 2 - .../configs/gardena-smart-gateway-mt7688.h | 2 - include/configs/gose.h | 1 - include/configs/helios4.h | 1 - include/configs/imx6_spl.h | 4 -- include/configs/imx7_spl.h | 2 - include/configs/imx8mm-cl-iot-gate.h | 1 - include/configs/imx8mm_beacon.h | 1 - include/configs/imx8mm_data_modul_edm_sbc.h | 1 - include/configs/imx8mm_evk.h | 1 - include/configs/imx8mm_icore_mx8mm.h | 1 - include/configs/imx8mm_venice.h | 1 - include/configs/imx8mn_beacon.h | 1 - include/configs/imx8mn_bsh_smm_s2_common.h | 1 - include/configs/imx8mn_evk.h | 1 - include/configs/imx8mn_var_som.h | 1 - include/configs/imx8mn_venice.h | 1 - include/configs/imx8mp_evk.h | 1 - include/configs/imx8mp_rsb3720.h | 1 - include/configs/imx8mp_venice.h | 1 - include/configs/imx8mq_cm.h | 1 - include/configs/imx8mq_evk.h | 1 - include/configs/imx8mq_phanbell.h | 1 - include/configs/imx8qm_mek.h | 1 - include/configs/imx8qm_rom7720.h | 1 - include/configs/imx8qxp_mek.h | 1 - include/configs/imx8ulp_evk.h | 1 - include/configs/iot2050.h | 2 - include/configs/j721e_evm.h | 2 - include/configs/j721s2_evm.h | 2 - include/configs/koelsch.h | 1 - include/configs/kontron-sl-mx8mm.h | 1 - include/configs/kontron_pitx_imx8m.h | 1 - include/configs/kontron_sl28.h | 1 - include/configs/lager.h | 1 - include/configs/linkit-smart-7688.h | 2 - include/configs/ls1021aiot.h | 2 - include/configs/ls1021aqds.h | 4 -- include/configs/ls1021atsn.h | 2 - include/configs/ls1021atwr.h | 2 - include/configs/ls1043a_common.h | 3 -- include/configs/ls1043aqds.h | 1 - include/configs/ls1043ardb.h | 1 - include/configs/ls1046a_common.h | 5 -- include/configs/ls1046aqds.h | 1 - include/configs/ls1088a_common.h | 1 - include/configs/ls2080a_common.h | 1 - include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - include/configs/m53menlo.h | 1 - include/configs/maxbcm.h | 1 - include/configs/mt7620.h | 2 - include/configs/mt7628.h | 2 - include/configs/mt7629.h | 2 - include/configs/omapl138_lcdk.h | 1 - include/configs/openpiton-riscv64.h | 1 - include/configs/p1_p2_rdb_pc.h | 8 --- include/configs/phycore_imx8mm.h | 1 - include/configs/phycore_imx8mp.h | 1 - include/configs/pico-imx8mq.h | 1 - include/configs/pm9g45.h | 1 - include/configs/porter.h | 1 - include/configs/px30_common.h | 1 - include/configs/qemu-riscv.h | 1 - include/configs/rcar-gen3-common.h | 1 - include/configs/rk3066_common.h | 2 - include/configs/rk3188_common.h | 1 - include/configs/rk322x_common.h | 1 - include/configs/rk3308_common.h | 1 - include/configs/rk3328_common.h | 1 - include/configs/rk3368_common.h | 1 - include/configs/rk3399_common.h | 2 - include/configs/rk3568_common.h | 1 - include/configs/rockchip-common.h | 1 - include/configs/sama5d27_som1_ek.h | 1 - include/configs/sama5d27_wlsom1_ek.h | 1 - include/configs/sama5d2_icp.h | 1 - include/configs/sama5d2_xplained.h | 1 - include/configs/sama5d3_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 1 - include/configs/sama5d4ek.h | 1 - include/configs/siemens-am33x-common.h | 2 - include/configs/sifive-unleashed.h | 1 - include/configs/sifive-unmatched.h | 1 - include/configs/silk.h | 1 - include/configs/smartweb.h | 2 - include/configs/sniper.h | 2 - include/configs/socfpga_common.h | 5 -- include/configs/socfpga_soc64_common.h | 1 - include/configs/stm32f746-disco.h | 1 - include/configs/stout.h | 1 - include/configs/sunxi-common.h | 8 --- include/configs/taurus.h | 2 - include/configs/theadorable.h | 1 - include/configs/ti814x_evm.h | 2 - include/configs/ti816x_evm.h | 2 - include/configs/ti_armv7_common.h | 4 -- include/configs/ti_armv7_keystone2.h | 2 - include/configs/turris_omnia.h | 1 - include/configs/uniphier.h | 3 -- include/configs/verdin-imx8mm.h | 1 - include/configs/verdin-imx8mp.h | 1 - include/configs/vocore2.h | 2 - include/configs/work_92105.h | 1 - include/configs/x530.h | 1 - include/configs/xilinx_zynqmp.h | 1 - include/configs/zynq-common.h | 1 - scripts/Makefile.spl | 2 +- 535 files changed, 556 insertions(+), 277 deletions(-)
diff --git a/README b/README index f39b215d019f..074fabb4e91c 100644 --- a/README +++ b/README @@ -1665,12 +1665,6 @@ The following options need to be configured: CONFIG_SPL_MAX_FOOTPRINT and CONFIG_SPL_BSS_MAX_SIZE must not be both defined at the same time.
- CONFIG_SPL_MAX_SIZE - Maximum size of the SPL image (text, data, rodata, and - linker lists sections), BSS excluded. - When defined, the linker checks that the actual size does - not exceed it. - CONFIG_SPL_RELOC_TEXT_BASE Address to relocate to. If unspecified, this is equal to CONFIG_SPL_TEXT_BASE (i.e. no relocation is done). @@ -1760,13 +1754,6 @@ The following options need to be configured: CONFIG_SPL_RAM_DEVICE Support for running image already present in ram, in SPL binary
- CONFIG_SPL_PAD_TO - Image offset to which the SPL should be padded before appending - the SPL payload. By default, this is defined as - CONFIG_SPL_MAX_SIZE, or 0 if CONFIG_SPL_MAX_SIZE is undefined. - CONFIG_SPL_PAD_TO must be either 0, meaning to append the SPL - payload without any padding, or >= CONFIG_SPL_MAX_SIZE. - CONFIG_SPL_TARGET Final target image containing SPL and payload. Some SPLs use an arch-specific makefile fragment instead, for @@ -1778,17 +1765,6 @@ The following options need to be configured: option to re-enable it. This will affect the output of the bootm command when booting a FIT image.
-- TPL framework - CONFIG_TPL - Enable building of TPL globally. - - CONFIG_TPL_PAD_TO - Image offset to which the TPL should be padded before appending - the TPL payload. By default, this is defined as - CONFIG_SPL_MAX_SIZE, or 0 if CONFIG_SPL_MAX_SIZE is undefined. - CONFIG_SPL_PAD_TO must be either 0, meaning to append the SPL - payload without any padding, or >= CONFIG_SPL_MAX_SIZE. - - Interrupt support (PPC):
There are common interrupt_init() and timer_interrupt() diff --git a/arch/arm/mach-rockchip/px30/Kconfig b/arch/arm/mach-rockchip/px30/Kconfig index 4886fe946e3a..28639c00414c 100644 --- a/arch/arm/mach-rockchip/px30/Kconfig +++ b/arch/arm/mach-rockchip/px30/Kconfig @@ -56,9 +56,6 @@ config TPL_LDSCRIPT config TPL_TEXT_BASE default 0xff0e1000
-config TPL_MAX_SIZE - default 10240 - config TPL_STACK default 0xff0e4fff
diff --git a/arch/arm/mach-rockchip/rk322x/Kconfig b/arch/arm/mach-rockchip/rk322x/Kconfig index 058f848ddc70..9ad1f54055b3 100644 --- a/arch/arm/mach-rockchip/rk322x/Kconfig +++ b/arch/arm/mach-rockchip/rk322x/Kconfig @@ -26,9 +26,6 @@ config SPL_LIBGENERIC_SUPPORT config SPL_SERIAL default y
-config TPL_MAX_SIZE - default 28672 - config TPL_STACK default 0x10088000
diff --git a/arch/arm/mach-rockchip/rk3288/Kconfig b/arch/arm/mach-rockchip/rk3288/Kconfig index dd8c7826fc10..e8c57843a38f 100644 --- a/arch/arm/mach-rockchip/rk3288/Kconfig +++ b/arch/arm/mach-rockchip/rk3288/Kconfig @@ -172,9 +172,6 @@ config SPL_SERIAL config TPL_LDSCRIPT default "arch/arm/mach-rockchip/u-boot-tpl.lds"
-config TPL_MAX_SIZE - default 32768 - config TPL_STACK default 0xff718000
diff --git a/arch/arm/mach-rockchip/rk3328/Kconfig b/arch/arm/mach-rockchip/rk3328/Kconfig index f6f1e06a83fe..d5cb649ae6ba 100644 --- a/arch/arm/mach-rockchip/rk3328/Kconfig +++ b/arch/arm/mach-rockchip/rk3328/Kconfig @@ -36,9 +36,6 @@ config TPL_LDSCRIPT config TPL_TEXT_BASE default 0xff091000
-config TPL_MAX_SIZE - default 28672 - config TPL_STACK default 0xff098000
diff --git a/arch/arm/mach-rockchip/rk3368/Kconfig b/arch/arm/mach-rockchip/rk3368/Kconfig index 104db36737bf..25afd3cb6077 100644 --- a/arch/arm/mach-rockchip/rk3368/Kconfig +++ b/arch/arm/mach-rockchip/rk3368/Kconfig @@ -71,9 +71,6 @@ config SPL_LDSCRIPT config SPL_STACK_R_ADDR default 0x04000000
-config TPL_MAX_SIZE - default 28672 - config TPL_STACK default 0xff8cffff
diff --git a/arch/arm/mach-rockchip/rk3399/Kconfig b/arch/arm/mach-rockchip/rk3399/Kconfig index c1f251316cb2..b48feeb3466c 100644 --- a/arch/arm/mach-rockchip/rk3399/Kconfig +++ b/arch/arm/mach-rockchip/rk3399/Kconfig @@ -143,9 +143,6 @@ config SPL_LIBGENERIC_SUPPORT config TPL_LDSCRIPT default "arch/arm/mach-rockchip/u-boot-tpl-v8.lds"
-config TPL_MAX_SIZE - default 188416 - config TPL_STACK default 0xff8effff
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index df2075c7cf28..ff8690d4f6af 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -75,6 +75,36 @@ config SPL_SIZE_LIMIT_PROVIDE_STACK of SRAM available for SPL when the stack required before reolcation uses this SRAM, too.
+config SPL_MAX_SIZE + hex "Maximum size of the SPL image, excluding BSS" + default 0x30000 if ARCH_MX6 && MX6_OCRAM_256KB + default 0x1b000 if AM33XX && !TI_SECURE_DEVICE + default 0x10000 if ARCH_MX6 && !MX6_OCRAM_256KB + default 0x7fa0 if SUNXI_SRAM_ADDRESS = 0x10000 + default 0x7fa0 if SUNXI_SRAM_ADDRESS = 0x20000 && !MACH_SUN50I_H616 + default 0x7000 if RCAR_GEN3 + default 0x5fa0 if SUNXI_SRAM_ADDRESS = 0x0 + default 0x0 + help + Maximum size of the SPL image (text, data, rodata, and linker lists + sections), BSS excluded. When defined, the linker checks that the + actual size does not exceed it. + +config SPL_PAD_TO + hex "Offset to which the SPL should be padded before appending the SPL payload" + default 0x31000 if ARCH_MX6 && MX6_OCRAM_256KB + default 0x11000 if ARCH_MX7 || (ARCH_MX6 && !MX6_OCRAM_256KB) + default 0x10000 if ARCH_KEYSTONE + default 0x8000 if ARCH_SUNXI && !MACH_SUN50I_H616 + default TPL_MAX_SIZE if TPL_MAX_SIZE > SPL_MAX_SIZE + default SPL_MAX_SIZE + help + Image offset to which the SPL should be padded before appending the + SPL payload. By default, this is defined as CONFIG_SPL_MAX_SIZE, or 0 if + CONFIG_SPL_MAX_SIZE is undefined. CONFIG_SPL_PAD_TO must be either + 0, meaning to append the SPL payload without any padding, or >= + CONFIG_SPL_MAX_SIZE. + config SPL_SYS_STACK_F_CHECK_BYTE hex default 0xaa @@ -1489,12 +1519,26 @@ config TPL_TEXT_BASE The base address for the .text section of the TPL stage.
config TPL_MAX_SIZE - int "Maximum size (in bytes) for the TPL stage" - default 0 - depends on TPL + hex "Maximum size (in bytes) for the TPL stage" + default 0x2e000 if ROCKCHIP_RK3399 + default 0x8000 if ROCKCHIP_RK3288 + default 0x7000 if ROCKCHIP_RK322X || ROCKCHIP_RK3328 || ROCKCHIP_RK3368 + default 0x2800 if ROCKCHIP_PX30 + default 0x0 help The maximum size (in bytes) of the TPL stage.
+config TPL_PAD_TO + hex "Offset to which the TPL should be padded before appending the TPL payload" + depends on !TPL_FRAMEWORK && PPC + default TPL_MAX_SIZE + help + Image offset to which the TPL should be padded before appending the + TPL payload. By default, this is defined as CONFIG_TPL_MAX_SIZE, or 0 if + CONFIG_TPL_MAX_SIZE is undefined. CONFIG_TPL_PAD_TO must be either + 0, meaning to append the TPL payload without any padding, or >= + CONFIG_TPL_MAX_SIZE. + config TPL_STACK hex "Address of the initial stack-pointer for the TPL stage" depends on TPL_NEEDS_SEPARATE_STACK diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 79de9b41dcc0..ed9ee1136959 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -28,11 +28,13 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x2000 CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_INIT_MINIMAL=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y +CONFIG_TPL_MAX_SIZE=0x20000 CONFIG_TPL_DRIVERS_MISC=y CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 0c1cd2f19692..1a78db709c4b 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -20,6 +20,7 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudra CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 6f6d6445dd74..6845645d47b2 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index bef258411633..961d3eafffa0 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index a3e6120b948e..ee416a581a3d 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -27,11 +27,13 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x2000 CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_INIT_MINIMAL=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y +CONFIG_TPL_MAX_SIZE=0x20000 CONFIG_TPL_DRIVERS_MISC=y CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 349c6477a40c..d1d08fd818bc 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudra CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index bb34c0499ed2..4298c6d80c14 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -25,6 +25,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index f42ba10be9ae..766eb1d5dac8 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index b807eb1ee358..10275a313b5a 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -29,11 +29,13 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x2000 CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_INIT_MINIMAL=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y +CONFIG_TPL_MAX_SIZE=0x20000 CONFIG_TPL_DRIVERS_MISC=y CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 9186e6fafe8a..693de45423e9 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 3b1912d282fb..8c6ff1cd704f 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 8ec1e93426e5..74ae1643342d 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index eb0e48289d79..d103e9bc02c1 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -28,11 +28,13 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x2000 CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_INIT_MINIMAL=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y +CONFIG_TPL_MAX_SIZE=0x20000 CONFIG_TPL_DRIVERS_MISC=y CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index b2a3587171d6..5d47b6c805e1 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 0b547456a1a7..83d4ee205f50 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -26,6 +26,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index c92036e9d952..60513725bc51 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -29,6 +29,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index f5892e98bf72..d6de87f9af30 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -29,11 +29,13 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x1000 CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_INIT_MINIMAL=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y +CONFIG_TPL_MAX_SIZE=0x20000 CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C=y CONFIG_TPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index deaeb0a4e1b9..6b381204068d 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 4dffe7e5b34c..1424742f3ca4 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -31,6 +31,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index f127d8c92dce..086fab47d291 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -22,6 +22,7 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$con CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index ff27fd2a7bfb..832a1f3fda5f 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -28,11 +28,13 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x1000 CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_INIT_MINIMAL=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y +CONFIG_TPL_MAX_SIZE=0x20000 CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C=y CONFIG_TPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index a2d16e31a7a5..f3e57082e0ad 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 7cd087e01ce5..3f965697b262 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 069a35f3df81..36472f75fd88 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -21,6 +21,7 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$con CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 9b8793298edd..a42baf4ffd22 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -28,11 +28,13 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x1000 CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_INIT_MINIMAL=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y +CONFIG_TPL_MAX_SIZE=0x20000 CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C=y CONFIG_TPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index f7acd3996ce0..6443fb0bccea 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index daed834c0fc0..a59ec504a9d6 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index ccb1e30b4ec1..0a69b4393402 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -21,6 +21,7 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$con CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index d6f3fb242223..b337b2c5af6a 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -29,11 +29,13 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x1000 CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_INIT_MINIMAL=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y +CONFIG_TPL_MAX_SIZE=0x20000 CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C=y CONFIG_TPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 50bf852203c1..bb8ce4f3715c 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index a99f46a88011..7e9c54b0475e 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -31,6 +31,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index cbae767fceb6..d550be2e5da5 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -22,6 +22,7 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$con CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 1031ebe4628f..37b8edf8e716 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -28,11 +28,13 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x1000 CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_INIT_MINIMAL=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y +CONFIG_TPL_MAX_SIZE=0x20000 CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C=y CONFIG_TPL_MPC8XXX_INIT_DDR=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 6c757c2a69e4..a10522873c05 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 91ca330b119f..75316881fd87 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FLUSH_IMAGE=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index f33b69d97d7e..48451fdded90 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -21,6 +21,7 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$con CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_FLUSH_IMAGE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 218985606d1d..f328cfde20d1 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -32,6 +32,8 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index d0b7f7174e02..bdfc14e23aee 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -33,6 +33,8 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index fce2aac36b2c..5da728572152 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -36,6 +36,8 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_ID_EEPROM=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 7c0e35b67b49..d5dadf0e6753 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -28,6 +28,8 @@ CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index bd9d1aefc607..9ee4d2bc4033 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -29,6 +29,8 @@ CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 21a7c18a29bf..cde17d28795f 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -32,6 +32,8 @@ CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 5b17526766aa..56e9817f8a9f 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -33,6 +33,8 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudra CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index a3ec6bc5bc90..640288e6d6ad 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -34,6 +34,8 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudra CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 956835167bd4..b3fdedb61bd4 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -37,6 +37,8 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudra CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 8a6e6899c80f..e6249d70e865 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -31,6 +31,8 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudra CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index beb714a7027d..84bc23ba8c48 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -32,6 +32,8 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudra CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 14fa9f6efde0..29be13224886 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -35,6 +35,8 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudra CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T2080RDB_revD_NAND_defconfig b/configs/T2080RDB_revD_NAND_defconfig index 3ba54841f2af..5e799cf3fde8 100644 --- a/configs/T2080RDB_revD_NAND_defconfig +++ b/configs/T2080RDB_revD_NAND_defconfig @@ -32,6 +32,8 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudra CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T2080RDB_revD_SDCARD_defconfig b/configs/T2080RDB_revD_SDCARD_defconfig index 9afa79b0f714..5ab3becef4ea 100644 --- a/configs/T2080RDB_revD_SDCARD_defconfig +++ b/configs/T2080RDB_revD_SDCARD_defconfig @@ -33,6 +33,8 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudra CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T2080RDB_revD_SPIFLASH_defconfig b/configs/T2080RDB_revD_SPIFLASH_defconfig index f86de3a6852c..ae28d8da0631 100644 --- a/configs/T2080RDB_revD_SPIFLASH_defconfig +++ b/configs/T2080RDB_revD_SPIFLASH_defconfig @@ -36,6 +36,8 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudra CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index fe5481ec7fc0..b6edf0f787ec 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -30,6 +30,8 @@ CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudra CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_MAX_SIZE=0x28000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_FLUSH_IMAGE=y diff --git a/configs/ae350_rv32_spl_defconfig b/configs/ae350_rv32_spl_defconfig index cd9cc613cb50..ea0163c7ab22 100644 --- a/configs/ae350_rv32_spl_defconfig +++ b/configs/ae350_rv32_spl_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x00200000 CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SYS_PROMPT="RISC-V # " CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_IMLS=y diff --git a/configs/ae350_rv32_spl_xip_defconfig b/configs/ae350_rv32_spl_xip_defconfig index 8f47e178636d..f34c894c51f0 100644 --- a/configs/ae350_rv32_spl_xip_defconfig +++ b/configs/ae350_rv32_spl_xip_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x80010000 CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SYS_PROMPT="RISC-V # " CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_IMLS=y diff --git a/configs/ae350_rv64_spl_defconfig b/configs/ae350_rv64_spl_defconfig index 33476f3fb1d2..15cecb1255ce 100644 --- a/configs/ae350_rv64_spl_defconfig +++ b/configs/ae350_rv64_spl_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x00200000 CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SYS_PROMPT="RISC-V # " CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_IMLS=y diff --git a/configs/ae350_rv64_spl_xip_defconfig b/configs/ae350_rv64_spl_xip_defconfig index e6ed0efa5535..55310f40c7b7 100644 --- a/configs/ae350_rv64_spl_xip_defconfig +++ b/configs/ae350_rv64_spl_xip_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x80010000 CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SYS_PROMPT="RISC-V # " CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_IMLS=y diff --git a/configs/alt_defconfig b/configs/alt_defconfig index 5a75381bb3f1..8a7fe556925d 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_ENV_ADDR=0xC0000 CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SPL_MAX_SIZE=0x4000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index 7123a167eb3f..36ebff3d3976 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run init_console; run finduuid; run distro_boot CONFIG_LOGLEVEL=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y +CONFIG_SPL_MAX_SIZE=0xb0b0 CONFIG_SPL_FIT_IMAGE_TINY=y # CONFIG_SPL_ENV_SUPPORT is not set # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 120f3ad9c4d6..cd1f7e3722c0 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -20,6 +20,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run init_console; run finduuid; run distro_boot CONFIG_LOGLEVEL=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y +CONFIG_SPL_MAX_SIZE=0x9ab0 CONFIG_SPL_FIT_IMAGE_TINY=y # CONFIG_SPL_ENV_SUPPORT is not set # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 26468ca2a9c3..1ae12cb6fbd8 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -16,6 +16,7 @@ CONFIG_LTO=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=10 CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device $mmcdev; if run loadbootenv; then run importbootenv; fi; echo Checking if uenvcmd is set ...; if test -n $uenvcmd; then echo Running uenvcmd ...; run uenvcmd; fi; echo Running default loadimage ...; setenv bootfile zImage; if run loadimage; then run loadfdt; run mmcboot; fi; else run nandboot; fi" +CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 24ecf1fbe026..282fcf6e0f66 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_MAX_SIZE=0x439e0 CONFIG_SPL_ETH=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 6c9a62c40df4..b28b3a133f00 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_MAX_SIZE=0x439e0 CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 2bd98cf4f7e2..14a34501c939 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_MAX_SIZE=0x37690 CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 33b008f5a902..6b08ebe98944 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -22,6 +22,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_MAX_SIZE=0x36100 CONFIG_SPL_ETH=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 2769d3518c68..400a1ae5c82a 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -26,6 +26,7 @@ CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_MISC_INIT_R is not set CONFIG_AVB_VERIFY=y CONFIG_ANDROID_AB=y +CONFIG_SPL_MAX_SIZE=0x7bc00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_DMA=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 2d23db26c6ba..7131b1c9c00b 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -29,6 +29,7 @@ CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_MISC_INIT_R is not set CONFIG_AVB_VERIFY=y CONFIG_ANDROID_AB=y +CONFIG_SPL_MAX_SIZE=0x7a8b0 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_DMA=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index b218b1b50d02..bf3934729c48 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -32,6 +32,7 @@ CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_MISC_INIT_R is not set CONFIG_AVB_VERIFY=y CONFIG_ANDROID_AB=y +CONFIG_SPL_MAX_SIZE=0x74eb0 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_DMA=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index ed603a19f5b7..9e251c1ed90a 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -30,6 +30,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_kern_${boot}; run get_fdt_${boot}; run run_kern" CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x180000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y diff --git a/configs/am64x_evm_r5_defconfig b/configs/am64x_evm_r5_defconfig index 0f76a0a8824a..6ad98a430325 100644 --- a/configs/am64x_evm_r5_defconfig +++ b/configs/am64x_evm_r5_defconfig @@ -31,6 +31,7 @@ CONFIG_BOOTCOMMAND="run distro_bootcmd" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y +CONFIG_SPL_MAX_SIZE=0x180000 CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index 236e32f21a37..3915c3bb5b47 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -33,6 +33,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" CONFIG_LOGLEVEL=7 CONFIG_CONSOLE_MUX=y +CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index f5d4e32ddf63..cea8231c1066 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -31,6 +31,7 @@ CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y +CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y diff --git a/configs/am65x_evm_r5_usbdfu_defconfig b/configs/am65x_evm_r5_usbdfu_defconfig index d6b3bb5521c4..ea237914af33 100644 --- a/configs/am65x_evm_r5_usbdfu_defconfig +++ b/configs/am65x_evm_r5_usbdfu_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_EARLY_BSS=y diff --git a/configs/am65x_evm_r5_usbmsc_defconfig b/configs/am65x_evm_r5_usbmsc_defconfig index 3d8b6deb2217..41fabd44f6fe 100644 --- a/configs/am65x_evm_r5_usbmsc_defconfig +++ b/configs/am65x_evm_r5_usbmsc_defconfig @@ -22,6 +22,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_LOAD_FIT=y CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_EARLY_BSS=y diff --git a/configs/am65x_hs_evm_a53_defconfig b/configs/am65x_hs_evm_a53_defconfig index 99c78d3b425c..0dc421019017 100644 --- a/configs/am65x_hs_evm_a53_defconfig +++ b/configs/am65x_hs_evm_a53_defconfig @@ -33,6 +33,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_fit_${boot}; run get_overlaystring; run run_fit" CONFIG_LOGLEVEL=7 CONFIG_CONSOLE_MUX=y +CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/am65x_hs_evm_r5_defconfig b/configs/am65x_hs_evm_r5_defconfig index 8826be3fc87d..214349dab175 100644 --- a/configs/am65x_hs_evm_r5_defconfig +++ b/configs/am65x_hs_evm_r5_defconfig @@ -28,6 +28,7 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_EARLY_BSS=y diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index b6cc3754298f..72b747f77873 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -23,6 +23,7 @@ CONFIG_BOOTCOMMAND="fatload mmc 0:1 0x71000000 dtb; fatload mmc 0:1 0x72000000 z CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_SYS_CBSIZE=256 diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index 2937de432988..724fda01e8ea 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -23,6 +23,7 @@ CONFIG_BOOTCOMMAND="nand read 0x70000000 0x200000 0x300000;bootm 0x70000000" CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_SYS_CBSIZE=256 diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index 06ea24bbb509..986aaec25f2d 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs ${console} ${mtdparts} ${bootargs_mmc};fatload mmc 0:1 0x21000000 dtb;fatload mmc 0:1 0x22000000 uImage;bootm 0x22000000 - 0x21000000" CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x6000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_SYS_CBSIZE=256 diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 0b33ce79347b..3a5a3f1aa14a 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs ${console} ${mtdparts} ${bootargs_nand};nand read 0x21000000 0x180000 0x080000;nand read 0x22000000 0x200000 0x400000;bootm 0x22000000 - 0x21000000" CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x6000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_SYS_CBSIZE=256 diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index b2d9eb31127a..f54265081296 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -20,6 +20,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs ${console} ${mtdparts} ${bootargs_nand};sf probe 0; sf read 0x22000000 0x100000 0x300000; bootm 0x22000000" CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x6000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_SYS_CBSIZE=256 diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index 75528ad15e6a..671a01b15a7d 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -25,6 +25,7 @@ CONFIG_BOOTCOMMAND="sf probe 0; sf read 0x22000000 0x84000 0x294000; bootm 0x220 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x6000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_SYS_CBSIZE=256 diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 0e3014397045..13ccaecd9a41 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -22,6 +22,7 @@ CONFIG_BOOTARGS="mem=128M console=ttyS0,115200 mtdparts=atmel_nand:8M(bootstrap/ # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x6000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_SYS_CBSIZE=256 diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index 125dc19abf0a..cdc12d42a5cb 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -24,6 +24,7 @@ CONFIG_BOOTCOMMAND="nand read 0x22000000 0x200000 0x600000; nand read 0x21000000 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x6000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_SYS_CBSIZE=256 diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 96ab238461cc..2fd143c16a53 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -26,6 +26,7 @@ CONFIG_BOOTCOMMAND="sf probe 0; sf read 0x22000000 0x100000 0x300000; bootm 0x22 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x6000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_SYS_CBSIZE=256 diff --git a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig index 90ca33b8244b..2903c491f5a9 100644 --- a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig +++ b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x10000000 CONFIG_BOOTDELAY=0 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" CONFIG_SPL_OS_BOOT=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index ebda5a49fe99..23ad604f4b35 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -35,6 +35,8 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run flash_self" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x3e00 +CONFIG_SPL_PAD_TO=0x20000 # CONFIG_SPL_LEGACY_IMAGE_FORMAT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_CRC32=y diff --git a/configs/bitmain_antminer_s9_defconfig b/configs/bitmain_antminer_s9_defconfig index 6e88048e0a4a..f26776de6df1 100644 --- a/configs/bitmain_antminer_s9_defconfig +++ b/configs/bitmain_antminer_s9_defconfig @@ -27,6 +27,7 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x30000 CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="antminer> " diff --git a/configs/cgtqmx8_defconfig b/configs/cgtqmx8_defconfig index 9ad055353087..446e0d568454 100644 --- a/configs/cgtqmx8_defconfig +++ b/configs/cgtqmx8_defconfig @@ -28,6 +28,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" CONFIG_LOG=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x1f000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index 81662915d248..6ccce21dafbc 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -23,6 +23,7 @@ CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-mickey.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index 1b2db5d0a8fb..53b043548296 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -26,6 +26,8 @@ CONFIG_MISC_INIT_R=y CONFIG_BLOBLIST=y CONFIG_BLOBLIST_ADDR=0x100000 CONFIG_BLOBLIST_SIZE=0x1000 +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_HANDOFF=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index d3d9f8fc0ba0..9d88c664b9d1 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -24,6 +24,7 @@ CONFIG_LOG=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 diff --git a/configs/chromebook_kevin_defconfig b/configs/chromebook_kevin_defconfig index ad6cbca198b8..6a3f3cf0cbb8 100644 --- a/configs/chromebook_kevin_defconfig +++ b/configs/chromebook_kevin_defconfig @@ -27,6 +27,8 @@ CONFIG_MISC_INIT_R=y CONFIG_BLOBLIST=y CONFIG_BLOBLIST_ADDR=0x100000 CONFIG_BLOBLIST_SIZE=0x1000 +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_HANDOFF=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index 63899f37aaa7..fac8a900dc76 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -24,6 +24,7 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 diff --git a/configs/chromebook_speedy_defconfig b/configs/chromebook_speedy_defconfig index 9343263be5ec..7fd4d5739532 100644 --- a/configs/chromebook_speedy_defconfig +++ b/configs/chromebook_speedy_defconfig @@ -24,6 +24,7 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 diff --git a/configs/ci20_mmc_defconfig b/configs/ci20_mmc_defconfig index 4d963c3eb35e..2337ac6a8beb 100644 --- a/configs/ci20_mmc_defconfig +++ b/configs/ci20_mmc_defconfig @@ -23,6 +23,7 @@ CONFIG_DISPLAY_CPUINFO=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_MISC_INIT_R=y CONFIG_SYS_MALLOC_BOOTPARAMS=y +CONFIG_SPL_MAX_SIZE=0x2e00 # CONFIG_SPL_BANNER_PRINT is not set CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1c diff --git a/configs/cl-som-imx7_defconfig b/configs/cl-som-imx7_defconfig index b42e5c25aec5..7e872fa2155b 100644 --- a/configs/cl-som-imx7_defconfig +++ b/configs/cl-som-imx7_defconfig @@ -25,6 +25,7 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="echo SD boot attempt ...; run sdbootscript; run sdboot; echo eMMC boot attempt ...; run emmcbootscript; run emmcboot; echo USB boot attempt ...; run usbbootscript; " CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x80 CONFIG_SPL_I2C=y diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index 5ee39911a288..726c80bf011a 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -24,6 +24,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x22fd0 CONFIG_SPL_I2C=y CONFIG_SYS_MAXARGS=32 CONFIG_CMD_TLV_EEPROM=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index c3ddc5e0a927..1507131d07f4 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -27,6 +27,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_MAX_SIZE=0x37690 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x480 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index 574d931493fe..7e07a1526907 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -32,6 +32,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_LATE_INIT=y CONFIG_LAST_STAGE_INIT=y +CONFIG_SPL_MAX_SIZE=0x27fd0 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_I2C=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 9b55d9e87db0..1c7bc9e05466 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -30,6 +30,8 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="nand read 0x70000000 0x200000 0x300000;bootm 0x70000000" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x3000 +CONFIG_SPL_PAD_TO=0x20000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_RAW_ONLY=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index a692e1456c15..40da37f1b411 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -33,6 +33,7 @@ CONFIG_DEFAULT_FDT_FILE="da850-evm.dtb" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CLOCKS=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_PAD_TO=0x8000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_DM_SPI_FLASH=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index c382c38050eb..3f27999673a8 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -30,6 +30,7 @@ CONFIG_DEFAULT_FDT_FILE="da850-evm.dtb" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CLOCKS=y +CONFIG_SPL_PAD_TO=0x8000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig index f92f2c49c92d..da17225b490f 100644 --- a/configs/db-88f6720_defconfig +++ b/configs/db-88f6720_defconfig @@ -23,6 +23,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x1ffd0 CONFIG_SPL_I2C=y CONFIG_SYS_MAXARGS=32 CONFIG_CMD_I2C=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 03a38c6e1e5b..48bd7bcc4a8d 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -24,6 +24,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x22fd0 CONFIG_SPL_I2C=y CONFIG_SYS_MAXARGS=96 # CONFIG_CMD_FLASH is not set diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index 61f9169bc463..2e2ce2a204a2 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -23,6 +23,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x22fd0 CONFIG_SPL_I2C=y CONFIG_SYS_MAXARGS=32 CONFIG_CMD_I2C=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index 4fd9c6011b6f..48e0a7be9d93 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -23,6 +23,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x1bfd0 CONFIG_SPL_I2C=y CONFIG_SYS_MAXARGS=32 # CONFIG_CMD_FLASH is not set diff --git a/configs/deneb_defconfig b/configs/deneb_defconfig index f02b10bcfad0..c1fb57b98847 100644 --- a/configs/deneb_defconfig +++ b/configs/deneb_defconfig @@ -34,6 +34,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="if usrbutton; then run flash_self_test; reset; fi;run flash_self;reset;" CONFIG_LOG=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x1f000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index 5b25463df969..ba9ee13534a7 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -23,6 +23,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="dhcp; tftp ${loadaddr} ${serverip}:${tftpdir}/${bootfile}; tftp ${dtbaddr} ${serverip}:${tftpdir}/devkit3250.dtb; setenv nfsargs ip=dhcp root=/dev/nfs nfsroot=${serverip}:${nfsroot},tcp; setenv bootargs ${bootargs} ${nfsargs} ${userargs}; bootm ${loadaddr} - ${dtbaddr}" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 0db8b83f3eba..2db73e165a35 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run autoboot" CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y CONFIG_SPL_NAND_SIMPLE=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index f04a2fbca6fa..ded2e6cefd42 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -26,6 +26,7 @@ CONFIG_BOOTCOMMAND="if test ${dofastboot} -eq 1; then echo Boot fastboot request CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_MAX_SIZE=0x7bc00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_DMA=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 6bb5c3c2ad00..b9d3f665dcf5 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -29,6 +29,7 @@ CONFIG_BOOTCOMMAND="if test ${dofastboot} -eq 1; then echo Boot fastboot request CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_MAX_SIZE=0x7a8b0 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_DMA=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index 652d9924bb88..739c48b461a3 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -31,6 +31,7 @@ CONFIG_BOOTCOMMAND="if test ${dofastboot} -eq 1; then echo Boot fastboot request CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_MAX_SIZE=0x74eb0 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_DMA=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index cc8f29b761b9..5c3c7d64e6e8 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -31,6 +31,7 @@ CONFIG_BOOTCOMMAND="sf probe; sf read ${loadaddr} 0xd0000 0x2d0000; sf read ${ra # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x1bfd0 CONFIG_SPL_I2C=y CONFIG_SYS_MAXARGS=32 # CONFIG_CMD_FLASH is not set diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index c3293e202469..f18e483f6a7f 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -20,6 +20,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0xfff0 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/elgin-rv1108_defconfig b/configs/elgin-rv1108_defconfig index 113b7c8cfe06..8a57c15ff089 100644 --- a/configs/elgin-rv1108_defconfig +++ b/configs/elgin-rv1108_defconfig @@ -19,6 +19,7 @@ CONFIG_DEFAULT_FDT_FILE="rv1108-elgin-r1.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_CMD_GPIO=y CONFIG_RANDOM_UUID=y CONFIG_CMD_MMC=y diff --git a/configs/evb-px30_defconfig b/configs/evb-px30_defconfig index 36eaf4e6b954..f7fa65e69fb9 100644 --- a/configs/evb-px30_defconfig +++ b/configs/evb-px30_defconfig @@ -28,12 +28,15 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/px30-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y # CONFIG_TPL_BANNER_PRINT is not set CONFIG_SPL_ATF=y # CONFIG_TPL_FRAMEWORK is not set +CONFIG_TPL_MAX_SIZE=0x20000 # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMI is not set diff --git a/configs/evb-px5_defconfig b/configs/evb-px5_defconfig index 1e2b0f03087c..10586a538473 100644 --- a/configs/evb-px5_defconfig +++ b/configs/evb-px5_defconfig @@ -32,6 +32,8 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3368-px5-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_TPL_SYS_MALLOC_SIMPLE=y @@ -39,6 +41,7 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_ATF=y CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y CONFIG_TPL=y +CONFIG_TPL_MAX_SIZE=0x40000 CONFIG_CMD_MMC=y CONFIG_CMD_CACHE=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/evb-rk3036_defconfig b/configs/evb-rk3036_defconfig index dcc70cb0bc7f..ea4427ed4952 100644 --- a/configs/evb-rk3036_defconfig +++ b/configs/evb-rk3036_defconfig @@ -23,6 +23,7 @@ CONFIG_DEFAULT_FDT_FILE="rk3036-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y diff --git a/configs/evb-rk3128_defconfig b/configs/evb-rk3128_defconfig index d232d78d6e57..4424cc866b12 100644 --- a/configs/evb-rk3128_defconfig +++ b/configs/evb-rk3128_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT=y CONFIG_DEFAULT_FDT_FILE="rk3128-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index 8eda765fb373..abca41de13ae 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -26,10 +26,13 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3229-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x100000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_SPL_OPTEE_IMAGE=y +CONFIG_TPL_MAX_SIZE=0x100000 CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_USB_MASS_STORAGE=y diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 14a1d4cf3322..0a5ee20709ff 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -24,6 +24,7 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3288-evb-rk808.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_SPL_OPTEE_IMAGE=y diff --git a/configs/evb-rk3308_defconfig b/configs/evb-rk3308_defconfig index b4ce8a1a3962..694256e3e84c 100644 --- a/configs/evb-rk3308_defconfig +++ b/configs/evb-rk3308_defconfig @@ -22,6 +22,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=0 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 7e0c4c50a617..f5c9f7b88bd0 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -25,12 +25,15 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_TPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_SPL_ATF=y CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_TPL_MAX_SIZE=0x40000 CONFIG_TPL_DRIVERS_MISC=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index a9afb63fdd9b..baf3a1151561 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -14,6 +14,8 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-evb.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/evb-rk3568_defconfig b/configs/evb-rk3568_defconfig index 1d61c1519436..a45fac0c2f7a 100644 --- a/configs/evb-rk3568_defconfig +++ b/configs/evb-rk3568_defconfig @@ -24,6 +24,8 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_ATF=y diff --git a/configs/evb-rv1108_defconfig b/configs/evb-rv1108_defconfig index fcdef1d35492..013fabfb2f29 100644 --- a/configs/evb-rv1108_defconfig +++ b/configs/evb-rv1108_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_FDT_FILE="rv1108-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_RANDOM_UUID=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/ficus-rk3399_defconfig b/configs/ficus-rk3399_defconfig index 1ee3cb225bf1..68b830dcb81d 100644 --- a/configs/ficus-rk3399_defconfig +++ b/configs/ficus-rk3399_defconfig @@ -14,6 +14,8 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 diff --git a/configs/firefly-px30_defconfig b/configs/firefly-px30_defconfig index 01858a65b4cc..57ac37fc6426 100644 --- a/configs/firefly-px30_defconfig +++ b/configs/firefly-px30_defconfig @@ -29,12 +29,15 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/px30-firefly.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y # CONFIG_TPL_BANNER_PRINT is not set CONFIG_SPL_ATF=y # CONFIG_TPL_FRAMEWORK is not set +CONFIG_TPL_MAX_SIZE=0x20000 # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMI is not set diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index c0dbd8470a78..629272a94bce 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -20,6 +20,7 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3288-firefly.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 3803e42f380a..4ed54ea4d393 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -15,6 +15,8 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-firefly.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index 2ee716365341..2dd0aa2acfc2 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -32,6 +32,8 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256k(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs rw" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_MAX_SIZE=0x7000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index b07e7c78d06f..11ad133c7339 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -37,6 +37,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_MALLOC_BOOTPARAMS=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/geekbox_defconfig b/configs/geekbox_defconfig index 8287600e0ba3..b4705ecbea68 100644 --- a/configs/geekbox_defconfig +++ b/configs/geekbox_defconfig @@ -15,6 +15,8 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3368-geekbox.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/giedi_defconfig b/configs/giedi_defconfig index 2be2e767ca2b..6fd6e56fe54c 100644 --- a/configs/giedi_defconfig +++ b/configs/giedi_defconfig @@ -34,6 +34,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="if usrbutton; then run flash_self_test; reset; fi;run flash_self;reset;" CONFIG_LOG=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x1f000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/gose_defconfig b/configs/gose_defconfig index 57bf892f055f..6efa4a544073 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_ENV_ADDR=0xC0000 CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SPL_MAX_SIZE=0x4000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/helios4_defconfig b/configs/helios4_defconfig index 56470c042d4b..240e3878bfb4 100644 --- a/configs/helios4_defconfig +++ b/configs/helios4_defconfig @@ -24,6 +24,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x22fd0 CONFIG_SPL_I2C=y CONFIG_SYS_MAXARGS=32 CONFIG_CMD_TLV_EEPROM=y diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 24d6502c0667..2e1811228e59 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -15,6 +15,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/imx7_cm_defconfig b/configs/imx7_cm_defconfig index e6b146615790..912b3a6fd7af 100644 --- a/configs/imx7_cm_defconfig +++ b/configs/imx7_cm_defconfig @@ -24,6 +24,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run boot${boot-mode}" CONFIG_DEFAULT_FDT_FILE="ask" # CONFIG_BOARD_EARLY_INIT_F is not set +CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_I2C=y CONFIG_SPL_USB_HOST=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/imx8mm-cl-iot-gate-optee_defconfig b/configs/imx8mm-cl-iot-gate-optee_defconfig index 20b5e29f973b..e0041312352b 100644 --- a/configs/imx8mm-cl-iot-gate-optee_defconfig +++ b/configs/imx8mm-cl-iot-gate-optee_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/imx8mm-cl-iot-gate_defconfig b/configs/imx8mm-cl-iot-gate_defconfig index eb3982b52435..d076ae3a4a7b 100644 --- a/configs/imx8mm-cl-iot-gate_defconfig +++ b/configs/imx8mm-cl-iot-gate_defconfig @@ -27,6 +27,7 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig index 1787b5082a14..fce998d3bb30 100644 --- a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig +++ b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mm-icore-mx8mm-ctouch2.dtb" +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig index 9096bab638db..03e33f395b43 100644 --- a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig +++ b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mm-icore-mx8mm-edimm2.2.dtb" +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/imx8mm-mx8menlo_defconfig b/configs/imx8mm-mx8menlo_defconfig index 109d01f11640..5f39dd2ca79f 100644 --- a/configs/imx8mm-mx8menlo_defconfig +++ b/configs/imx8mm-mx8menlo_defconfig @@ -34,6 +34,7 @@ CONFIG_LOG=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/imx8mm_beacon_defconfig b/configs/imx8mm_beacon_defconfig index 494f469fe117..bcf18b3613c5 100644 --- a/configs/imx8mm_beacon_defconfig +++ b/configs/imx8mm_beacon_defconfig @@ -25,6 +25,7 @@ CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; fi;" CONFIG_DEFAULT_FDT_FILE="imx8mm-beacon-kit.dtb" +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/imx8mm_data_modul_edm_sbc_defconfig b/configs/imx8mm_data_modul_edm_sbc_defconfig index 3bb2f45c1b12..574016ac7058 100644 --- a/configs/imx8mm_data_modul_edm_sbc_defconfig +++ b/configs/imx8mm_data_modul_edm_sbc_defconfig @@ -41,6 +41,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK=y diff --git a/configs/imx8mm_evk_defconfig b/configs/imx8mm_evk_defconfig index 5f7e5f7b4a36..86f24a0d2dd6 100644 --- a/configs/imx8mm_evk_defconfig +++ b/configs/imx8mm_evk_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index 0c266d20a5cb..9223c0a3dfb1 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -31,6 +31,7 @@ CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="gsc wd-disable" CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_beacon_2g_defconfig b/configs/imx8mn_beacon_2g_defconfig index 6a2f0dcac3fb..aec7ddd72e0f 100644 --- a/configs/imx8mn_beacon_2g_defconfig +++ b/configs/imx8mn_beacon_2g_defconfig @@ -32,6 +32,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" CONFIG_DEFAULT_FDT_FILE="imx8mn-beacon-kit.dtb" CONFIG_ARCH_MISC_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/imx8mn_beacon_defconfig b/configs/imx8mn_beacon_defconfig index d2d182d342dd..865b06b038c0 100644 --- a/configs/imx8mn_beacon_defconfig +++ b/configs/imx8mn_beacon_defconfig @@ -31,6 +31,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" CONFIG_DEFAULT_FDT_FILE="imx8mn-beacon-kit.dtb" CONFIG_ARCH_MISC_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/imx8mn_bsh_smm_s2_defconfig b/configs/imx8mn_bsh_smm_s2_defconfig index 69ba13797a3f..1a4db3360904 100644 --- a/configs/imx8mn_bsh_smm_s2_defconfig +++ b/configs/imx8mn_bsh_smm_s2_defconfig @@ -26,6 +26,7 @@ CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="freescale/imx8mn-bsh-smm-s2.dtb" CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/imx8mn_bsh_smm_s2pro_defconfig b/configs/imx8mn_bsh_smm_s2pro_defconfig index 655dfbe6c488..69dde3f25a3c 100644 --- a/configs/imx8mn_bsh_smm_s2pro_defconfig +++ b/configs/imx8mn_bsh_smm_s2pro_defconfig @@ -27,6 +27,7 @@ CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="freescale/imx8mn-bsh-smm-s2pro.dtb" CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/imx8mn_ddr4_evk_defconfig b/configs/imx8mn_ddr4_evk_defconfig index 09d3c1b3c08c..d08ace7d68c9 100644 --- a/configs/imx8mn_ddr4_evk_defconfig +++ b/configs/imx8mn_ddr4_evk_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mn-ddr4-evk.dtb" CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/imx8mn_evk_defconfig b/configs/imx8mn_evk_defconfig index 9c879cd6d1c5..2aef70be67eb 100644 --- a/configs/imx8mn_evk_defconfig +++ b/configs/imx8mn_evk_defconfig @@ -26,6 +26,7 @@ CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mn-evk.dtb" CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set diff --git a/configs/imx8mn_var_som_defconfig b/configs/imx8mn_var_som_defconfig index 161f2752a1c0..7fdaa2c3a6c0 100644 --- a/configs/imx8mn_var_som_defconfig +++ b/configs/imx8mn_var_som_defconfig @@ -27,6 +27,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="freescale/imx8mn-var-som-symphony.dtb" CONFIG_ARCH_MISC_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig index e6a630e3b325..c7509987f8fe 100644 --- a/configs/imx8mn_venice_defconfig +++ b/configs/imx8mn_venice_defconfig @@ -32,6 +32,7 @@ CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="gsc wd-disable" CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index f9e1b605820e..90973aa25e84 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -29,6 +29,7 @@ CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mp-evk.dtb" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x26000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/imx8mp_rsb3720a1_4G_defconfig b/configs/imx8mp_rsb3720a1_4G_defconfig index d500e5c9487d..4ad5e1ef8fb3 100644 --- a/configs/imx8mp_rsb3720a1_4G_defconfig +++ b/configs/imx8mp_rsb3720a1_4G_defconfig @@ -36,6 +36,7 @@ CONFIG_DEFAULT_FDT_FILE="imx8mp-rsb3720-a1.dtb" CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x26000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/imx8mp_rsb3720a1_6G_defconfig b/configs/imx8mp_rsb3720a1_6G_defconfig index 7ea850deb675..6b21ad017cf6 100644 --- a/configs/imx8mp_rsb3720a1_6G_defconfig +++ b/configs/imx8mp_rsb3720a1_6G_defconfig @@ -36,6 +36,7 @@ CONFIG_DEFAULT_FDT_FILE="imx8mp-rsb3720-a1.dtb" CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x26000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/imx8mp_venice_defconfig b/configs/imx8mp_venice_defconfig index b370203ebe55..c8b6f21e2846 100644 --- a/configs/imx8mp_venice_defconfig +++ b/configs/imx8mp_venice_defconfig @@ -32,6 +32,7 @@ CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="gsc wd-disable" CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x26000 CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/imx8mq_cm_defconfig b/configs/imx8mq_cm_defconfig index 7caa19c1555c..4d34a5c4b59d 100644 --- a/configs/imx8mq_cm_defconfig +++ b/configs/imx8mq_cm_defconfig @@ -27,6 +27,7 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x1f000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index 637211c653a1..a1c15de0276d 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -29,6 +29,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x1f000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/imx8mq_phanbell_defconfig b/configs/imx8mq_phanbell_defconfig index 167251fb3b2f..8f01718bc3bf 100644 --- a/configs/imx8mq_phanbell_defconfig +++ b/configs/imx8mq_phanbell_defconfig @@ -31,6 +31,7 @@ CONFIG_SD_BOOT=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x2b000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/imx8qm_mek_defconfig b/configs/imx8qm_mek_defconfig index 1bc0a9d1b27d..9f68877125e8 100644 --- a/configs/imx8qm_mek_defconfig +++ b/configs/imx8qm_mek_defconfig @@ -28,6 +28,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if test ${sec_boot} = yes; then if run loadcntr; then run mmcboot; else run netboot; fi; else if run loadimage; then run mmcboot; else run netboot; fi; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" CONFIG_LOG=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x1f000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/imx8qm_rom7720_a1_4G_defconfig b/configs/imx8qm_rom7720_a1_4G_defconfig index 6ed2882aaab6..da9b1ab194ca 100644 --- a/configs/imx8qm_rom7720_a1_4G_defconfig +++ b/configs/imx8qm_rom7720_a1_4G_defconfig @@ -25,6 +25,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" CONFIG_LOG=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x1f000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_POWER_DOMAIN=y CONFIG_SPL_WATCHDOG=y diff --git a/configs/imx8qxp_mek_defconfig b/configs/imx8qxp_mek_defconfig index bd4ab56ad594..d0f42842fcae 100644 --- a/configs/imx8qxp_mek_defconfig +++ b/configs/imx8qxp_mek_defconfig @@ -28,6 +28,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if test ${sec_boot} = yes; then if run loadcntr; then run mmcboot; else run netboot; fi; else if run loadimage; then run mmcboot; else run netboot; fi; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" CONFIG_LOG=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x1f000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/imx8ulp_evk_defconfig b/configs/imx8ulp_evk_defconfig index 88ba690fc488..3d09aaa865d4 100644 --- a/configs/imx8ulp_evk_defconfig +++ b/configs/imx8ulp_evk_defconfig @@ -27,6 +27,7 @@ CONFIG_BOOTCOMMAND="run distro_bootcmd;run bsp_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx8ulp-evk" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/iot2050_defconfig b/configs/iot2050_defconfig index 01ef500d82bd..6cabc10925b1 100644 --- a/configs/iot2050_defconfig +++ b/configs/iot2050_defconfig @@ -31,6 +31,7 @@ CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_SPL_SHOW_BOOT_PROGRESS=y CONFIG_CONSOLE_MUX=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index ac5152a164ce..e633f2243aa3 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -32,6 +32,7 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" CONFIG_LOGLEVEL=7 +CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index 4883e8a18993..451f25cf3db6 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -28,6 +28,7 @@ CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index b507f23e8df3..c0f55d8f8357 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -29,6 +29,7 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd; run init_${boot}; run main_cpsw0_qsgmii_phyinit; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" CONFIG_LOGLEVEL=7 +CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index c7899fcddd1a..45bebbe66b0a 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -28,6 +28,7 @@ CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y diff --git a/configs/j721e_hs_evm_a72_defconfig b/configs/j721e_hs_evm_a72_defconfig index a07204dd98ed..34bd47608dab 100644 --- a/configs/j721e_hs_evm_a72_defconfig +++ b/configs/j721e_hs_evm_a72_defconfig @@ -30,6 +30,7 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run main_cpsw0_qsgmii_phyinit; run boot_rprocs; run get_fit_${boot}; run get_overlaystring; run run_fit" CONFIG_LOGLEVEL=7 +CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y diff --git a/configs/j721e_hs_evm_r5_defconfig b/configs/j721e_hs_evm_r5_defconfig index 7a5867bb7d24..42ccbe28c7af 100644 --- a/configs/j721e_hs_evm_r5_defconfig +++ b/configs/j721e_hs_evm_r5_defconfig @@ -29,6 +29,7 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_EARLY_BSS=y diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index 90b941157beb..503b8fb512f7 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -32,6 +32,7 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run main_cpsw0_qsgmii_phyinit; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" CONFIG_LOGLEVEL=7 +CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 57f6c7bdfea0..7f1d2b05048b 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -32,6 +32,7 @@ CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y +CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 5de27f06bad9..89726c96799b 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -27,6 +27,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run init_${boot}; run get_mon_${boot} run_mon; run get_kern_${boot}; run init_fw_rd_${boot}; run get_fdt_${boot}; run run_kern" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0xfff8 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index 25f229371578..b1cfa34d0f01 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -20,6 +20,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run run_mon_hs; run init_${boot}; run get_fit_${boot}; bootm ${addr_fit}#${name_fdt}" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0xfff8 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index fc33225bac71..e98e9533546a 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -26,6 +26,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_mon_${boot} run_mon; run set_name_pmmc get_pmmc_${boot} run_pmmc; run get_kern_${boot}; run init_fw_rd_${boot}; run get_fdt_${boot}; run run_kern" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0xfff8 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 2767cd82db07..11717af65946 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -19,6 +19,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run run_mon_hs; run init_${boot}; run get_fit_${boot}; bootm ${addr_fit}#${name_fdt}" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0xfff8 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 206bccdbbd6b..93a29fb31e9e 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -27,6 +27,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run init_${boot}; run get_mon_${boot} run_mon; run get_kern_${boot}; run init_fw_rd_${boot}; run get_fdt_${boot}; run run_kern" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0xfff8 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index af56223f6622..fae63da58bc9 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -20,6 +20,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run run_mon_hs; run init_${boot}; run get_fit_${boot}; bootm ${addr_fit}#${name_fdt}" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0xfff8 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 3fcca0100d10..852d2d8467b5 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -27,6 +27,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run init_${boot}; run get_mon_${boot} run_mon; run get_kern_${boot}; run init_fw_rd_${boot}; run get_fdt_${boot}; run run_kern" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0xfff8 CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index 2e46eac3d777..8879710162c4 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -20,6 +20,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run run_mon_hs; run init_${boot}; run get_fit_${boot}; bootm ${addr_fit}#${name_fdt}" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0xfff8 CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=64 CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 diff --git a/configs/khadas-edge-captain-rk3399_defconfig b/configs/khadas-edge-captain-rk3399_defconfig index 44ec22f2a37d..91e01705168e 100644 --- a/configs/khadas-edge-captain-rk3399_defconfig +++ b/configs/khadas-edge-captain-rk3399_defconfig @@ -14,6 +14,8 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-khadas-edge-captain.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/khadas-edge-rk3399_defconfig b/configs/khadas-edge-rk3399_defconfig index a2f27407aa78..6eb1c35e86b6 100644 --- a/configs/khadas-edge-rk3399_defconfig +++ b/configs/khadas-edge-rk3399_defconfig @@ -14,6 +14,8 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-khadas-edge.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/khadas-edge-v-rk3399_defconfig b/configs/khadas-edge-v-rk3399_defconfig index 949fb333bc0c..8529b4c28444 100644 --- a/configs/khadas-edge-v-rk3399_defconfig +++ b/configs/khadas-edge-v-rk3399_defconfig @@ -14,6 +14,8 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-khadas-edge-v.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index ff71d1463b28..58239a78d813 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_ENV_ADDR=0xC0000 CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SPL_MAX_SIZE=0x4000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/kontron-sl-mx8mm_defconfig b/configs/kontron-sl-mx8mm_defconfig index 235ef7023224..88c8adefd12e 100644 --- a/configs/kontron-sl-mx8mm_defconfig +++ b/configs/kontron-sl-mx8mm_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOARD_TYPES=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/kontron_pitx_imx8m_defconfig b/configs/kontron_pitx_imx8m_defconfig index ae94ed1f12a8..7b0d6b91d01b 100644 --- a/configs/kontron_pitx_imx8m_defconfig +++ b/configs/kontron_pitx_imx8m_defconfig @@ -30,6 +30,7 @@ CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x1f000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/kontron_sl28_defconfig b/configs/kontron_sl28_defconfig index 1bae47092109..fcc6dd394d91 100644 --- a/configs/kontron_sl28_defconfig +++ b/configs/kontron_sl28_defconfig @@ -35,6 +35,7 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOARD_LATE_INIT=y CONFIG_PCI_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_MPC8XXX_INIT_DDR=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index 0111f30e14d7..876a7e5a95d6 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -25,6 +25,7 @@ CONFIG_DEFAULT_FDT_FILE="rk3036-kylin.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index a58c23a524f7..a2cfcb061faf 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_ENV_ADDR=0xC0000 CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SPL_MAX_SIZE=0x4000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/leez-rk3399_defconfig b/configs/leez-rk3399_defconfig index 2fa8d563ebe2..9bd3e20c3ef3 100644 --- a/configs/leez-rk3399_defconfig +++ b/configs/leez-rk3399_defconfig @@ -14,6 +14,8 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-leez-p710.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_TPL=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index d50c77d8b63d..ed23c13061b2 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -29,6 +29,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_MALLOC_BOOTPARAMS=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/lion-rk3368_defconfig b/configs/lion-rk3368_defconfig index 426913816bf3..7dc518758a81 100644 --- a/configs/lion-rk3368_defconfig +++ b/configs/lion-rk3368_defconfig @@ -30,6 +30,8 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3368-lion-haikou.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_TPL_SYS_MALLOC_SIMPLE=y @@ -38,6 +40,7 @@ CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 CONFIG_SPL_ATF=y CONFIG_TPL=y +CONFIG_TPL_MAX_SIZE=0x40000 CONFIG_TPL_DRIVERS_MISC=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index b554b616228a..14406bc9fb3c 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -31,6 +31,8 @@ CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_MISC_INIT_R=y CONFIG_ID_EEPROM=y +CONFIG_SPL_MAX_SIZE=0x1a000 +CONFIG_SPL_PAD_TO=0x1c000 CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index bdb66d0e837a..dc8b03ee02a2 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -41,6 +41,8 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y CONFIG_ID_EEPROM=y +CONFIG_SPL_MAX_SIZE=0x1a000 +CONFIG_SPL_PAD_TO=0x1c000 CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index c936c0051afb..b7d46ad6db15 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -40,6 +40,8 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y CONFIG_ID_EEPROM=y +CONFIG_SPL_MAX_SIZE=0x1a000 +CONFIG_SPL_PAD_TO=0x1c000 CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index 230f1470afec..ad03479f8b00 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -39,6 +39,8 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y CONFIG_ID_EEPROM=y +CONFIG_SPL_MAX_SIZE=0x1a000 +CONFIG_SPL_PAD_TO=0x1c000 CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 diff --git a/configs/ls1021atsn_sdcard_defconfig b/configs/ls1021atsn_sdcard_defconfig index 4754a37f0d43..e76e3df75ec9 100644 --- a/configs/ls1021atsn_sdcard_defconfig +++ b/configs/ls1021atsn_sdcard_defconfig @@ -33,6 +33,8 @@ CONFIG_SILENT_CONSOLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y CONFIG_ID_EEPROM=y +CONFIG_SPL_MAX_SIZE=0x1a000 +CONFIG_SPL_PAD_TO=0x1c000 CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 69df4623ddb4..5348ade5e14d 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -40,6 +40,8 @@ CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y CONFIG_ID_EEPROM=y +CONFIG_SPL_MAX_SIZE=0x1a000 +CONFIG_SPL_PAD_TO=0x1c000 CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 637cc96928ba..c9537ed4ac3f 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -41,6 +41,8 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y CONFIG_ID_EEPROM=y +CONFIG_SPL_MAX_SIZE=0x1a000 +CONFIG_SPL_PAD_TO=0x1c000 CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 9050bba7011d..82030f8f3cd2 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -42,6 +42,8 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y CONFIG_ID_EEPROM=y +CONFIG_SPL_MAX_SIZE=0x1a000 +CONFIG_SPL_PAD_TO=0x1c000 CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 04e341334652..079cbb3f1fcf 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -45,6 +45,8 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x1a000 +CONFIG_SPL_PAD_TO=0x20000 CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index a508885be91e..71ecfccb48dd 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -46,6 +46,8 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x17000 +CONFIG_SPL_PAD_TO=0x1d000 CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index bed7b45770cc..d51cc08ef6c9 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -46,6 +46,8 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x17000 +CONFIG_SPL_PAD_TO=0x1d000 CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index 29558ea737d3..9d566d3def95 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -29,6 +29,8 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x1a000 +CONFIG_SPL_PAD_TO=0x20000 CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index cb6344e66245..cc60fa65d154 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -34,6 +34,8 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x1a000 +CONFIG_SPL_PAD_TO=0x20000 CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index b6987a5dfd91..1a7fc26ee385 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -30,6 +30,8 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" CONFIG_BOOTCOMMAND="run distro_bootcmd; run sd_bootcmd; env exists secureboot && esbc_halt;" CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x17000 +CONFIG_SPL_PAD_TO=0x1d000 CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index d118e0578fb7..74a426cdc6c2 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -35,6 +35,8 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_BOOTCOMMAND="run distro_bootcmd; run sd_bootcmd; env exists secureboot && esbc_halt;" CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x17000 +CONFIG_SPL_PAD_TO=0x1d000 CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 56fa46945fd4..f56f078d12e2 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -45,6 +45,8 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_BOOTCOMMAND="run distro_bootcmd; run nand_bootcmd; env exists secureboot && esbc_halt;;" CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x17000 +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index d36bedde32f9..be7903b0a0f3 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -46,6 +46,8 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_BOOTCOMMAND="run distro_bootcmd; run sd_bootcmd; env exists secureboot && esbc_halt;;" CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x1f000 +CONFIG_SPL_PAD_TO=0x21000 CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index 2abc2b1ccdc3..3fc281fe8ec9 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -46,6 +46,8 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_BOOTCOMMAND="run distro_bootcmd; run sd_bootcmd; env exists secureboot && esbc_halt;;" CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x1f000 +CONFIG_SPL_PAD_TO=0x21000 CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index cfd2208ff736..b9219b52010d 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -36,6 +36,8 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x1f000 +CONFIG_SPL_PAD_TO=0x21000 CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index cf7d46e08812..50b26b3ff81b 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -40,6 +40,8 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_BOOTCOMMAND="run distro_bootcmd; run qspi_bootcmd; env exists secureboot && esbc_halt;;" CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x1f000 +CONFIG_SPL_PAD_TO=0x20000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index f385d289f222..6a5c8997c9ca 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -34,6 +34,8 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.spi-0:1m(rcw),15m(u-boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel),448m(nand_free)" CONFIG_BOOTCOMMAND="run distro_bootcmd;run sd_bootcmd; env exists secureboot && esbc_halt;" CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x1f000 +CONFIG_SPL_PAD_TO=0x21000 CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index 95b79b9572a2..f573a679f2ba 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -36,6 +36,8 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_BOOTCOMMAND="run distro_bootcmd;run sd_bootcmd; env exists secureboot && esbc_halt;" CONFIG_ARCH_MISC_INIT=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x1f000 +CONFIG_SPL_PAD_TO=0x21000 CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index 811a97cf9f95..de3c11382ae2 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -39,6 +39,7 @@ CONFIG_BOOTCOMMAND="mmcinfo;mmc read 0x80001000 0x6800 0x800; fsl_mc lazyapply d # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index 09e00445f9e0..a30640901524 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -40,6 +40,7 @@ CONFIG_BOOTCOMMAND="mmcinfo;mmc read 0x80001000 0x6800 0x800; fsl_mc lazyapply d # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig index 3cf4180b9779..a727b5c358aa 100644 --- a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig @@ -40,6 +40,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index 51db7a64a4a8..d2db36cecc30 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -41,6 +41,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index e78b226ccc58..3a0e29009eaa 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -25,6 +25,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" CONFIG_BOOTCOMMAND="fsl_mc apply dpl 0x580d00000 && cp.b $kernel_start $kernel_load $kernel_size && bootm $kernel_load" CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_IMLS=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index c4ba0d45faea..28f796e6c2f5 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -26,6 +26,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" CONFIG_BOOTCOMMAND="fsl_mc apply dpl 0x580d00000 && cp.b $kernel_start $kernel_load $kernel_size && bootm $kernel_load" CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_IMLS=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 240ce113c1cc..547fe5c12346 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -31,6 +31,8 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" CONFIG_BOOTCOMMAND="fsl_mc apply dpl 0x580d00000 && cp.b $kernel_start $kernel_load $kernel_size && bootm $kernel_load" CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 +CONFIG_SPL_PAD_TO=0x20000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 88ba55124e2a..6359a7320599 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -26,6 +26,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" CONFIG_BOOTCOMMAND="fsl_mc apply dpl 0x580d00000 && cp.b $kernel_start $kernel_load $kernel_size && bootm $kernel_load" CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_GREPENV=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index 9dae1c74512f..f724c0e05241 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -32,6 +32,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" CONFIG_BOOTCOMMAND="mmc read 0x80200000 0x6800 0x800; fsl_mc apply dpl 0x80200000 && mmc read $kernel_load $kernel_start $kernel_size && bootm $kernel_load" CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index b799f349a573..715eb8c6d274 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -30,6 +30,7 @@ CONFIG_BOOTARGS="console=ttyS1,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_BOOTCOMMAND="env exists mcinitcmd && env exists secureboot && esbc_validate 0x5806C0000; env exists mcinitcmd && fsl_mc lazyapply dpl 0x580d00000;run distro_bootcmd;run nor_bootcmd; env exists secureboot && esbc_halt;" CONFIG_MISC_INIT_R=y CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_IMLS=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index 6bb10b817a0e..2efcfd1d8abf 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -31,6 +31,7 @@ CONFIG_BOOTARGS="console=ttyS1,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_BOOTCOMMAND="env exists mcinitcmd && env exists secureboot && esbc_validate 0x5806C0000; env exists mcinitcmd && fsl_mc lazyapply dpl 0x580d00000;run distro_bootcmd;run nor_bootcmd; env exists secureboot && esbc_halt;" CONFIG_MISC_INIT_R=y CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_IMLS=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 60eeb79d3aaf..6c499b8fbaf1 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -37,6 +37,8 @@ CONFIG_BOOTARGS="console=ttyS1,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_BOOTCOMMAND="env exists mcinitcmd && env exists secureboot && esbc_validate 0x5806C0000; env exists mcinitcmd && fsl_mc lazyapply dpl 0x580d00000;run distro_bootcmd;run nor_bootcmd; env exists secureboot && esbc_halt;" CONFIG_MISC_INIT_R=y CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 +CONFIG_SPL_PAD_TO=0x80000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/ls2081ardb_defconfig b/configs/ls2081ardb_defconfig index 3fa37ddf18de..c4e4be1ef7aa 100644 --- a/configs/ls2081ardb_defconfig +++ b/configs/ls2081ardb_defconfig @@ -32,6 +32,7 @@ CONFIG_BOOTARGS="console=ttyS1,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_BOOTCOMMAND="sf probe 0:0; sf read 0x806c0000 0x6c0000 0x40000; env exists mcinitcmd && env exists secureboot && esbc_validate 0x806C0000; sf read 0x80d00000 0xd00000 0x100000; env exists mcinitcmd && fsl_mc lazyapply dpl 0x80d00000; run distro_bootcmd;run qspi_bootcmd; env exists secureboot && esbc_halt;" CONFIG_MISC_INIT_R=y CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_GREPENV=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index c46e506213c9..3948edb77aa5 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -29,6 +29,7 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_IMLS=y diff --git a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig index 39540c74be2e..5fa0785f642a 100644 --- a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig @@ -29,6 +29,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOOTCOMMAND="sf probe 0:0; sf read 0x806c0000 0x6c0000 0x40000; env exists mcinitcmd && env exists secureboot && esbc_validate 0x806C0000; sf read 0x80d00000 0xd00000 0x100000; env exists mcinitcmd && fsl_mc lazyapply dpl 0x80d00000; run distro_bootcmd;run qspi_bootcmd; env exists secureboot && esbc_halt;" CONFIG_MISC_INIT_R=y CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_GREPENV=y diff --git a/configs/ls2088ardb_qspi_defconfig b/configs/ls2088ardb_qspi_defconfig index f702a3923587..5014eb4a46b4 100644 --- a/configs/ls2088ardb_qspi_defconfig +++ b/configs/ls2088ardb_qspi_defconfig @@ -33,6 +33,7 @@ CONFIG_BOOTARGS="console=ttyS1,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_BOOTCOMMAND="sf probe 0:0; sf read 0x806c0000 0x6c0000 0x40000; env exists mcinitcmd && env exists secureboot && esbc_validate 0x806C0000; sf read 0x80d00000 0xd00000 0x100000; env exists mcinitcmd && fsl_mc lazyapply dpl 0x80d00000; run distro_bootcmd;run qspi_bootcmd; env exists secureboot && esbc_halt;" CONFIG_MISC_INIT_R=y CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_GREPENV=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index 2f0ece68eb9e..b33754882f3b 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -33,6 +33,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS1,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0600 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" CONFIG_MISC_INIT_R=y CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_IMLS=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index 37d327527888..0d912219fa8a 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -35,6 +35,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS1,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0600 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" CONFIG_MISC_INIT_R=y CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x16000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=532 CONFIG_CMD_IMLS=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 3b9f5ca62b1d..deb765fc6b3c 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -34,6 +34,7 @@ CONFIG_BOOTCOMMAND="run mmc_mmc" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="run try_bootscript" CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_PAD_TO=0x8000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/maxbcm_defconfig b/configs/maxbcm_defconfig index 61d392550e9b..3105fa857e11 100644 --- a/configs/maxbcm_defconfig +++ b/configs/maxbcm_defconfig @@ -22,6 +22,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x1bfd0 CONFIG_SPL_I2C=y CONFIG_SYS_MAXARGS=32 CONFIG_CMD_I2C=y diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index c5af739fa488..8d3bd5d2be9c 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -20,6 +20,7 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3288-miqi.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/mk808_defconfig b/configs/mk808_defconfig index 7923fadf3369..9d5f09327361 100644 --- a/configs/mk808_defconfig +++ b/configs/mk808_defconfig @@ -16,7 +16,6 @@ CONFIG_SPL_TEXT_BASE=0x60000000 CONFIG_ROCKCHIP_RK3066=y # CONFIG_ROCKCHIP_STIMER is not set CONFIG_TPL_TEXT_BASE=0x10080C04 -CONFIG_TPL_MAX_SIZE=32764 CONFIG_TPL_STACK=0x1008FFFF CONFIG_TARGET_MK808=y CONFIG_SPL_STACK_R_ADDR=0x70000000 @@ -32,12 +31,15 @@ CONFIG_DEFAULT_FDT_FILE="rk3066a-mk808.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x32000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_FS_EXT4=y CONFIG_SYS_MMCSD_FS_BOOT_PARTITION=2 CONFIG_TPL_NEEDS_SEPARATE_STACK=y +CONFIG_TPL_MAX_SIZE=0x7ffc CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 # CONFIG_BOOTM_PLAN9 is not set diff --git a/configs/mt7620_mt7530_rfb_defconfig b/configs/mt7620_mt7530_rfb_defconfig index 5bf12729050a..9622d821c13c 100644 --- a/configs/mt7620_mt7530_rfb_defconfig +++ b/configs/mt7620_mt7530_rfb_defconfig @@ -24,6 +24,7 @@ CONFIG_DEBUG_UART=y CONFIG_FIT=y # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_SYS_MALLOC_BOOTPARAMS=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NOR_SUPPORT=y # CONFIG_CMD_ELF is not set diff --git a/configs/mt7620_rfb_defconfig b/configs/mt7620_rfb_defconfig index 8a4124e95cab..048a83c0052a 100644 --- a/configs/mt7620_rfb_defconfig +++ b/configs/mt7620_rfb_defconfig @@ -23,6 +23,7 @@ CONFIG_DEBUG_UART=y CONFIG_FIT=y # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_SYS_MALLOC_BOOTPARAMS=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NOR_SUPPORT=y # CONFIG_CMD_ELF is not set diff --git a/configs/mt7628_rfb_defconfig b/configs/mt7628_rfb_defconfig index 3ca36cdede31..fedc217a9cf8 100644 --- a/configs/mt7628_rfb_defconfig +++ b/configs/mt7628_rfb_defconfig @@ -23,6 +23,7 @@ CONFIG_FIT=y # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SYS_MALLOC_BOOTPARAMS=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NOR_SUPPORT=y # CONFIG_CMD_ELF is not set diff --git a/configs/mt7629_rfb_defconfig b/configs/mt7629_rfb_defconfig index 80e530836d51..b1f528bbdded 100644 --- a/configs/mt7629_rfb_defconfig +++ b/configs/mt7629_rfb_defconfig @@ -22,6 +22,7 @@ CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="mt7629-rfb" CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_NOR_SUPPORT=y diff --git a/configs/nanopc-t4-rk3399_defconfig b/configs/nanopc-t4-rk3399_defconfig index 31de4bd1a946..81d474ed2359 100644 --- a/configs/nanopc-t4-rk3399_defconfig +++ b/configs/nanopc-t4-rk3399_defconfig @@ -14,6 +14,8 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopc-t4.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/nanopi-m4-2gb-rk3399_defconfig b/configs/nanopi-m4-2gb-rk3399_defconfig index 7c8eff869b63..608ef3824f0e 100644 --- a/configs/nanopi-m4-2gb-rk3399_defconfig +++ b/configs/nanopi-m4-2gb-rk3399_defconfig @@ -14,6 +14,8 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-m4-2gb.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/nanopi-m4-rk3399_defconfig b/configs/nanopi-m4-rk3399_defconfig index d500ebe58dc4..c504a6d17558 100644 --- a/configs/nanopi-m4-rk3399_defconfig +++ b/configs/nanopi-m4-rk3399_defconfig @@ -14,6 +14,8 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-m4.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/nanopi-m4b-rk3399_defconfig b/configs/nanopi-m4b-rk3399_defconfig index 16e39035e5e5..de950c36933a 100644 --- a/configs/nanopi-m4b-rk3399_defconfig +++ b/configs/nanopi-m4b-rk3399_defconfig @@ -14,6 +14,8 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-m4b.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/nanopi-neo4-rk3399_defconfig b/configs/nanopi-neo4-rk3399_defconfig index 753ba92d0ed1..b3dfafa971dd 100644 --- a/configs/nanopi-neo4-rk3399_defconfig +++ b/configs/nanopi-neo4-rk3399_defconfig @@ -14,6 +14,8 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-neo4.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/nanopi-r2s-rk3328_defconfig b/configs/nanopi-r2s-rk3328_defconfig index 453e54295de1..54ccecb33e1d 100644 --- a/configs/nanopi-r2s-rk3328_defconfig +++ b/configs/nanopi-r2s-rk3328_defconfig @@ -26,6 +26,8 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-nanopi-r2s.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_TPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y @@ -33,6 +35,7 @@ CONFIG_SPL_I2C=y CONFIG_SPL_POWER=y CONFIG_SPL_ATF=y CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_TPL_MAX_SIZE=0x40000 CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y diff --git a/configs/nanopi-r4s-rk3399_defconfig b/configs/nanopi-r4s-rk3399_defconfig index 46ba07f4d555..f5e24e8814fb 100644 --- a/configs/nanopi-r4s-rk3399_defconfig +++ b/configs/nanopi-r4s-rk3399_defconfig @@ -14,6 +14,8 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-r4s.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/odroid-go2_defconfig b/configs/odroid-go2_defconfig index 8ff71fd28cda..4e57a2b52ead 100644 --- a/configs/odroid-go2_defconfig +++ b/configs/odroid-go2_defconfig @@ -32,6 +32,8 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3326-odroid-go2.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y @@ -40,6 +42,7 @@ CONFIG_SPL_I2C=y CONFIG_SPL_POWER=y CONFIG_SPL_ATF=y # CONFIG_TPL_FRAMEWORK is not set +CONFIG_TPL_MAX_SIZE=0x20000 # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMI is not set diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index 72b83b424261..d205cc308cc1 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -20,6 +20,7 @@ CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="setenv preboot;saveenv;" CONFIG_DEFAULT_FDT_FILE="logicpd-torpedo-35xx-devkit.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index ffb0e28569ae..b0832a09fde6 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="setenv preboot;saveenv;" CONFIG_DEFAULT_FDT_FILE="logicpd-som-lv-35xx-devkit.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 8a542763c1ef..1518d1e5e3ed 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -14,6 +14,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="omap3-beagle.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index a4bcb43926d1..914b1ea10965 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -14,6 +14,7 @@ CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run e CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="omap3-evm.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index dfd9c3073397..4d3cafc7ae18 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTCOMMAND="run autoboot" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="setenv preboot;saveenv;" CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index b49734666d77..4afc37bec64e 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="setenv preboot;saveenv;" CONFIG_DEFAULT_FDT_FILE="logicpd-som-lv-37xx-devkit.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index 6b8ce982aaa7..a815b9ab5739 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run f CONFIG_DEFAULT_FDT_FILE="omap4-panda.dtb" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_MAX_SIZE=0xbc00 # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C is not set # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index 6185421708ec..7a435930f87c 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -15,6 +15,7 @@ CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run f CONFIG_DEFAULT_FDT_FILE="omap4-sdp.dtb" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_MAX_SIZE=0xbc00 # CONFIG_SPL_I2C is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SYS_MAXARGS=64 diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index 748b0125276d..beccc82aa69e 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -14,6 +14,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="if test ${dofastboot} -eq 1; then echo Boot fastboot requested, resetting dofastboot ...;setenv dofastboot 0; saveenv;echo Booting into fastboot ...; fastboot 1;fi;if test ${boot_fit} -eq 1; then run update_to_fit;fi;run findfdt; run finduuid; run distro_bootcmd;run emmc_android_boot; " CONFIG_DEFAULT_FDT_FILE="omap5-uevm.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_MAX_SIZE=0x1dc00 # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_OS_BOOT=y CONFIG_SPL_FALCON_BOOT_MMCSD=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 799dc4075713..0ae02d923d31 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -31,6 +31,7 @@ CONFIG_LOGLEVEL=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CLOCKS=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_PAD_TO=0x8000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xb5 CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/openpiton_riscv64_spl_defconfig b/configs/openpiton_riscv64_spl_defconfig index 6e4e4549419d..fdb34d9d06ea 100644 --- a/configs/openpiton_riscv64_spl_defconfig +++ b/configs/openpiton_riscv64_spl_defconfig @@ -20,6 +20,7 @@ CONFIG_ENV_VARS_UBOOT_CONFIG=y # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="fdt addr ${fdtcontroladdr}; fdt move ${fdtcontroladdr} ${fdt_addr_r}; load mmc ${mmcdev}:${mmcpart} ${kernel_addr_r} ${image}; booti ${kernel_addr_r} - ${fdt_addr_r}; " +CONFIG_SPL_MAX_SIZE=0x100000 # CONFIG_SPL_LEGACY_IMAGE_FORMAT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_BANNER_PRINT is not set diff --git a/configs/orangepi-rk3399_defconfig b/configs/orangepi-rk3399_defconfig index 461300fd1060..b090e928dfd1 100644 --- a/configs/orangepi-rk3399_defconfig +++ b/configs/orangepi-rk3399_defconfig @@ -14,6 +14,8 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-orangepi.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/orangepi_zero2_defconfig b/configs/orangepi_zero2_defconfig index 4788102e975a..d9c89c88a97d 100644 --- a/configs/orangepi_zero2_defconfig +++ b/configs/orangepi_zero2_defconfig @@ -10,6 +10,7 @@ CONFIG_MACH_SUN50I_H616=y CONFIG_MMC0_CD_PIN="PF6" CONFIG_R_I2C_ENABLE=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_MAX_SIZE=0xbfa0 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SPL_SYS_I2C_LEGACY=y diff --git a/configs/phycore-imx8mm_defconfig b/configs/phycore-imx8mm_defconfig index 5f6455b70c3c..13b1b75b4a27 100644 --- a/configs/phycore-imx8mm_defconfig +++ b/configs/phycore-imx8mm_defconfig @@ -26,6 +26,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadimage; then run mmcboot; else run netboot; fi; fi;" CONFIG_DEFAULT_FDT_FILE="oftree" CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/phycore-imx8mp_defconfig b/configs/phycore-imx8mp_defconfig index 300216846dc2..7ec698bc6d3a 100644 --- a/configs/phycore-imx8mp_defconfig +++ b/configs/phycore-imx8mp_defconfig @@ -27,6 +27,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadimage; then run mmcboot; else run netboot; fi; fi;" CONFIG_DEFAULT_FDT_FILE="oftree" CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x26000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index 644464922213..5b67b96254e5 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -21,6 +21,7 @@ CONFIG_DEFAULT_FDT_FILE="rk3288-phycore-rdk.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/pico-dwarf-imx7d_defconfig b/configs/pico-dwarf-imx7d_defconfig index 9d6a9168aeef..d030af10951b 100644 --- a/configs/pico-dwarf-imx7d_defconfig +++ b/configs/pico-dwarf-imx7d_defconfig @@ -25,6 +25,7 @@ CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=715776 CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx7d-pico-dwarf.dtb" +CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_I2C=y CONFIG_SPL_USB_HOST=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index 464fdccc97b3..568623b55565 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -25,6 +25,7 @@ CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=715776 CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx7d-pico-hobbit.dtb" +CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_I2C=y CONFIG_SPL_USB_HOST=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/pico-imx7d_bl33_defconfig b/configs/pico-imx7d_bl33_defconfig index 18fa0026b67c..d814a42a9f3b 100644 --- a/configs/pico-imx7d_bl33_defconfig +++ b/configs/pico-imx7d_bl33_defconfig @@ -26,6 +26,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" +CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_I2C=y CONFIG_SPL_USB_HOST=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index 9750f97ef16b..cea2df659c7b 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -25,6 +25,7 @@ CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=715776 CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="ask" +CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_I2C=y CONFIG_SPL_USB_HOST=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/pico-imx8mq_defconfig b/configs/pico-imx8mq_defconfig index ac714536d5e8..2320c1557a9c 100644 --- a/configs/pico-imx8mq_defconfig +++ b/configs/pico-imx8mq_defconfig @@ -30,6 +30,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x1f000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/pico-nymph-imx7d_defconfig b/configs/pico-nymph-imx7d_defconfig index 9d6a9168aeef..d030af10951b 100644 --- a/configs/pico-nymph-imx7d_defconfig +++ b/configs/pico-nymph-imx7d_defconfig @@ -25,6 +25,7 @@ CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=715776 CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx7d-pico-dwarf.dtb" +CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_I2C=y CONFIG_SPL_USB_HOST=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index 9a91ace6fe12..822f61def6fa 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -25,6 +25,7 @@ CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=715776 CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx7d-pico-pi.dtb" +CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_I2C=y CONFIG_SPL_USB_HOST=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/pinebook-pro-rk3399_defconfig b/configs/pinebook-pro-rk3399_defconfig index 8ca1d0708f9a..825d8602e6bf 100644 --- a/configs/pinebook-pro-rk3399_defconfig +++ b/configs/pinebook-pro-rk3399_defconfig @@ -19,6 +19,8 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-pinebook-pro.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index 364ea8300854..34bf3d7e93af 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -22,6 +22,7 @@ CONFIG_BOOTCOMMAND="nand read 0x70000000 0x200000 0x300000;bootm 0x70000000" CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_RESET_PHY_R=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_SYS_CBSIZE=256 diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index cb463a9b69aa..8acd84a060e6 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -21,6 +21,7 @@ CONFIG_DEFAULT_FDT_FILE="rk3288-popmetal.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index 7b78c68fd413..528dd9e6d4e2 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_ENV_ADDR=0xC0000 CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SPL_MAX_SIZE=0x4000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 7ce2dc07192d..a29018501f4f 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -20,6 +20,8 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-puma-haikou.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 diff --git a/configs/px30-core-ctouch2-of10-px30_defconfig b/configs/px30-core-ctouch2-of10-px30_defconfig index 213d01fe7a8c..005abd968b8e 100644 --- a/configs/px30-core-ctouch2-of10-px30_defconfig +++ b/configs/px30-core-ctouch2-of10-px30_defconfig @@ -29,12 +29,15 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/px30-engicam-px30-core-ctouch2-of10.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y # CONFIG_TPL_BANNER_PRINT is not set CONFIG_SPL_ATF=y # CONFIG_TPL_FRAMEWORK is not set +CONFIG_TPL_MAX_SIZE=0x20000 # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMI is not set diff --git a/configs/px30-core-ctouch2-px30_defconfig b/configs/px30-core-ctouch2-px30_defconfig index 875d7aa7de33..16503ae794f7 100644 --- a/configs/px30-core-ctouch2-px30_defconfig +++ b/configs/px30-core-ctouch2-px30_defconfig @@ -29,12 +29,15 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/px30-engicam-px30-core-ctouch2.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y # CONFIG_TPL_BANNER_PRINT is not set CONFIG_SPL_ATF=y # CONFIG_TPL_FRAMEWORK is not set +CONFIG_TPL_MAX_SIZE=0x20000 # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMI is not set diff --git a/configs/px30-core-edimm2.2-px30_defconfig b/configs/px30-core-edimm2.2-px30_defconfig index 4e2fa8cf7dc8..ab7c0692b4fb 100644 --- a/configs/px30-core-edimm2.2-px30_defconfig +++ b/configs/px30-core-edimm2.2-px30_defconfig @@ -29,12 +29,15 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/px30-engicam-px30-core-edimm2.2.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y # CONFIG_TPL_BANNER_PRINT is not set CONFIG_SPL_ATF=y # CONFIG_TPL_FRAMEWORK is not set +CONFIG_TPL_MAX_SIZE=0x20000 # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMI is not set diff --git a/configs/qemu-riscv32_spl_defconfig b/configs/qemu-riscv32_spl_defconfig index f9bdf68fd801..efd38f52b78f 100644 --- a/configs/qemu-riscv32_spl_defconfig +++ b/configs/qemu-riscv32_spl_defconfig @@ -13,6 +13,7 @@ CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80200000 CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y +CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 # CONFIG_CMD_MII is not set diff --git a/configs/qemu-riscv64_spl_defconfig b/configs/qemu-riscv64_spl_defconfig index 5cd22450714f..de82869525fc 100644 --- a/configs/qemu-riscv64_spl_defconfig +++ b/configs/qemu-riscv64_spl_defconfig @@ -13,6 +13,7 @@ CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80200000 CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y +CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 # CONFIG_CMD_MII is not set diff --git a/configs/roc-cc-rk3308_defconfig b/configs/roc-cc-rk3308_defconfig index 0ae45ca8a197..f90c36332b23 100644 --- a/configs/roc-cc-rk3308_defconfig +++ b/configs/roc-cc-rk3308_defconfig @@ -22,6 +22,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=0 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/roc-cc-rk3328_defconfig b/configs/roc-cc-rk3328_defconfig index 5fc4dd779434..e9907debfbe0 100644 --- a/configs/roc-cc-rk3328_defconfig +++ b/configs/roc-cc-rk3328_defconfig @@ -26,6 +26,8 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-roc-cc.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_TPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y @@ -33,6 +35,7 @@ CONFIG_SPL_I2C=y CONFIG_SPL_POWER=y CONFIG_SPL_ATF=y CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_TPL_MAX_SIZE=0x40000 CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index fd857ed0ffd3..135679b872ff 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -20,6 +20,8 @@ CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-roc-pc-mezzanine.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x20000 diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index 4684fa6e7471..c98fd0303c67 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -20,6 +20,8 @@ CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-roc-pc.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x20000 diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 80d1e63b59c8..ebc318405ad1 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -16,6 +16,8 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-pi-4b.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/rock-pi-4c-rk3399_defconfig b/configs/rock-pi-4c-rk3399_defconfig index bda4b70dbf9b..23381540987a 100644 --- a/configs/rock-pi-4c-rk3399_defconfig +++ b/configs/rock-pi-4c-rk3399_defconfig @@ -16,6 +16,8 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-pi-4c.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/rock-pi-e-rk3328_defconfig b/configs/rock-pi-e-rk3328_defconfig index 36038d905309..26f9c91b6d8b 100644 --- a/configs/rock-pi-e-rk3328_defconfig +++ b/configs/rock-pi-e-rk3328_defconfig @@ -27,6 +27,8 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-rock-pi-e.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_TPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y @@ -35,6 +37,7 @@ CONFIG_SPL_I2C=y CONFIG_SPL_POWER=y CONFIG_SPL_ATF=y CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_TPL_MAX_SIZE=0x40000 CONFIG_TPL_DRIVERS_MISC=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig index 7151da4c1910..c31a5ed531ea 100644 --- a/configs/rock-pi-n10-rk3399pro_defconfig +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -18,6 +18,8 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399pro-rock-pi-n10.dtb" # CONFIG_CONSOLE_MUX is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/rock-pi-n8-rk3288_defconfig b/configs/rock-pi-n8-rk3288_defconfig index 6d13e351ee6e..19c3f54d80b8 100644 --- a/configs/rock-pi-n8-rk3288_defconfig +++ b/configs/rock-pi-n8-rk3288_defconfig @@ -20,6 +20,7 @@ CONFIG_DEBUG_UART=y CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_SPL=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index e8d183cd9b6f..fbaf82df13ae 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -21,6 +21,7 @@ CONFIG_DEFAULT_FDT_FILE="rk3288-rock2-square.dtb" CONFIG_SILENT_CONSOLE=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index ea61fe738f2f..2524ad94498b 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -26,6 +26,8 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-rock64.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_TPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y @@ -33,6 +35,7 @@ CONFIG_SPL_I2C=y CONFIG_SPL_POWER=y CONFIG_SPL_ATF=y CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_TPL_MAX_SIZE=0x40000 CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index ce37b578e26d..b581a900c7ac 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -15,6 +15,8 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock960.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/rock_defconfig b/configs/rock_defconfig index 4aa4608f9042..9ec2c4b92315 100644 --- a/configs/rock_defconfig +++ b/configs/rock_defconfig @@ -22,6 +22,8 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3188-radxarock.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x7800 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_RANDOM_UUID=y diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index e6f7a8469a31..a4f3d3d68a91 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -19,6 +19,8 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rockpro64.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 diff --git a/configs/sama5d27_giantboard_defconfig b/configs/sama5d27_giantboard_defconfig index 610f85a302d3..050d9bf1d481 100644 --- a/configs/sama5d27_giantboard_defconfig +++ b/configs/sama5d27_giantboard_defconfig @@ -36,6 +36,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="fatload mmc 0 0x22000000 at91-sama5d27_giantboard.dtb; fatload mmc 0 0x23000000 zImage; bootz 0x23000000 - 0x22000000" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index b4c8863e9bfb..4a72c7e6cf63 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -32,6 +32,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="fatload mmc 1 0x22000000 at91-sama5d27_som1_ek.dtb; fatload mmc 1 0x23000000 zImage; bootz 0x23000000 - 0x22000000" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index 2ec2f094eee5..82a6803ab3c5 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -33,6 +33,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="fatload mmc 0 0x22000000 at91-sama5d27_som1_ek.dtb; fatload mmc 0 0x23000000 zImage; bootz 0x23000000 - 0x22000000" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d27_som1_ek_qspiflash_defconfig b/configs/sama5d27_som1_ek_qspiflash_defconfig index 55155c7861ae..e590643e741b 100644 --- a/configs/sama5d27_som1_ek_qspiflash_defconfig +++ b/configs/sama5d27_som1_ek_qspiflash_defconfig @@ -31,6 +31,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d27_wlsom1_ek_mmc_defconfig b/configs/sama5d27_wlsom1_ek_mmc_defconfig index 5413652fad54..607272f07265 100644 --- a/configs/sama5d27_wlsom1_ek_mmc_defconfig +++ b/configs/sama5d27_wlsom1_ek_mmc_defconfig @@ -32,6 +32,7 @@ CONFIG_BOOTCOMMAND="if test ! -n ${dtb_name}; then setenv dtb_name at91-${board_ # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_SPL_DISPLAY_PRINT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_AT91_MCK_BYPASS=y diff --git a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig index 3bc9558aea1e..08fc34ef59e3 100644 --- a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig +++ b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig @@ -32,6 +32,7 @@ CONFIG_BOOTCOMMAND="sf probe 0; sf read 0x21000000 0x60000 0xc000; sf read 0x220 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_SPL_DISPLAY_PRINT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_DM_SPI_FLASH=y diff --git a/configs/sama5d2_icp_mmc_defconfig b/configs/sama5d2_icp_mmc_defconfig index 69d8eedb8722..ee2817b4d66b 100644 --- a/configs/sama5d2_icp_mmc_defconfig +++ b/configs/sama5d2_icp_mmc_defconfig @@ -31,6 +31,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="fatload mmc 0:1 0x21000000 at91-sama5d2_icp.dtb; fatload mmc 0:1 0x22000000 zImage; bootz 0x22000000 - 0x21000000" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_SPL_DISPLAY_PRINT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/sama5d2_icp_qspiflash_defconfig b/configs/sama5d2_icp_qspiflash_defconfig index ca5787b1bec0..9678b72f7711 100644 --- a/configs/sama5d2_icp_qspiflash_defconfig +++ b/configs/sama5d2_icp_qspiflash_defconfig @@ -26,6 +26,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="fatload mmc 0:1 0x21000000 at91-sama5d2_icp.dtb; fatload mmc 0:1 0x22000000 zImage; bootz 0x22000000 - 0x21000000" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index 3af514530d98..12ad0a443f81 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -31,6 +31,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwai CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="fatload mmc 0:1 0x22000000 at91-sama5d2_xplained.dtb; fatload mmc 0:1 0x23000000 zImage; bootz 0x23000000 - 0x22000000" # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index b852b4e3a003..18d866c0f8ee 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -33,6 +33,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="fatload mmc 1:1 0x22000000 at91-sama5d2_xplained.dtb; fatload mmc 1:1 0x23000000 zImage; bootz 0x23000000 - 0x22000000" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d2_xplained_qspiflash_defconfig b/configs/sama5d2_xplained_qspiflash_defconfig index c41c6e134c31..d3b9c4fcb390 100644 --- a/configs/sama5d2_xplained_qspiflash_defconfig +++ b/configs/sama5d2_xplained_qspiflash_defconfig @@ -34,6 +34,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="sf probe 1:0; sf read 0x22000000 0x180000 0x80000; sf read 0x23000000 0x200000 0x600000; bootz 0x23000000 - 0x22000000" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index 4981a8a55ecc..e494893c051f 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -35,6 +35,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="ext4load mmc 0:1 0x22000000 /boot/at91-sama5d2_xplained.dtb; ext4load mmc 0:1 0x23000000 /boot/zImage; bootz 0x23000000 - 0x22000000" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 diff --git a/configs/sama5d36ek_cmp_mmc_defconfig b/configs/sama5d36ek_cmp_mmc_defconfig index a20b60093d00..72d0958873a7 100644 --- a/configs/sama5d36ek_cmp_mmc_defconfig +++ b/configs/sama5d36ek_cmp_mmc_defconfig @@ -24,6 +24,7 @@ CONFIG_BOOTCOMMAND="if test ! -n ${dtb_name}; then setenv dtb_name at91-${board_ # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d36ek_cmp_nandflash_defconfig b/configs/sama5d36ek_cmp_nandflash_defconfig index 214472638227..4e1e012cd979 100644 --- a/configs/sama5d36ek_cmp_nandflash_defconfig +++ b/configs/sama5d36ek_cmp_nandflash_defconfig @@ -24,6 +24,7 @@ CONFIG_BOOTCOMMAND="nand read 0x21000000 0x180000 0x80000;nand read 0x22000000 0 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d36ek_cmp_spiflash_defconfig b/configs/sama5d36ek_cmp_spiflash_defconfig index 2190edd55f2b..1bf6e66d67a0 100644 --- a/configs/sama5d36ek_cmp_spiflash_defconfig +++ b/configs/sama5d36ek_cmp_spiflash_defconfig @@ -26,6 +26,7 @@ CONFIG_BOOTCOMMAND="sf probe 0; sf read 0x21000000 0x60000 0xc000; sf read 0x220 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index 86724e4df375..d39974e3575b 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -32,6 +32,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwai CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="if test ! -n ${dtb_name}; then setenv dtb_name at91-${board_name}.dtb; fi; fatload mmc 0:1 0x21000000 ${dtb_name}; fatload mmc 0:1 0x22000000 zImage; bootz 0x22000000 - 0x21000000" # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 7a870ac38b3a..878eca9cd98f 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -29,6 +29,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(boots CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="nand read 0x21000000 0x180000 0x80000;nand read 0x22000000 0x200000 0x600000;bootz 0x22000000 - 0x21000000" # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_BASE=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 742830562f8d..5074d0151253 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -34,6 +34,7 @@ CONFIG_BOOTCOMMAND="if test ! -n ${dtb_name}; then setenv dtb_name at91-${board_ # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 55b9e9570ef5..ef88b51dacf5 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -31,6 +31,7 @@ CONFIG_BOOTCOMMAND="nand read 0x21000000 0x180000 0x80000;nand read 0x22000000 0 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_BASE=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 20ea57ff4aa6..04d68d33a03e 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -34,6 +34,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(boots CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="sf probe 0; sf read 0x21000000 0x60000 0xc000; sf read 0x22000000 0x6c000 0x394000; bootz 0x22000000 - 0x21000000" # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index 1b17400267bd..04358d19120a 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -33,6 +33,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="if test ! -n ${dtb_name}; then setenv dtb_name at91-${board_name}.dtb; fi; fatload mmc 0:1 0x21000000 ${dtb_name}; fatload mmc 0:1 0x22000000 zImage; bootz 0x22000000 - 0x21000000" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index 49e3c778dc46..77851be9bdbf 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -30,6 +30,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="nand read 0x21000000 0x180000 0x80000;nand read 0x22000000 0x200000 0x600000;bootz 0x22000000 - 0x21000000" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_BASE=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index 5df91abc6ff8..979186b44747 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -35,6 +35,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="sf probe 0; sf read 0x21000000 0x60000 0xc000; sf read 0x22000000 0x6c000 0x394000; bootz 0x22000000 - 0x21000000" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 4c200304a468..98819d9ddb7c 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -34,6 +34,7 @@ CONFIG_BOOTCOMMAND="if test ! -n ${dtb_name}; then setenv dtb_name at91-${board_ # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index 4f016bc82438..a402d693b3a6 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -31,6 +31,7 @@ CONFIG_BOOTCOMMAND="nand read 0x21000000 0x180000 0x80000;nand read 0x22000000 0 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_BASE=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index 469040627c2e..364e949cb996 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -34,6 +34,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(boots CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="sf probe 0; sf read 0x21000000 0x60000 0xc000; sf read 0x22000000 0x6c000 0x394000; bootz 0x22000000 - 0x21000000" # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_MAX_SIZE=0x18000 CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 diff --git a/configs/sheep-rk3368_defconfig b/configs/sheep-rk3368_defconfig index 80f599d3a395..5b8046850124 100644 --- a/configs/sheep-rk3368_defconfig +++ b/configs/sheep-rk3368_defconfig @@ -15,6 +15,8 @@ CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3368-sheep.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_CMD_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_REGMAP=y diff --git a/configs/sifive_unleashed_defconfig b/configs/sifive_unleashed_defconfig index 196035927486..f219bd21b487 100644 --- a/configs/sifive_unleashed_defconfig +++ b/configs/sifive_unleashed_defconfig @@ -22,6 +22,7 @@ CONFIG_DEFAULT_FDT_FILE="sifive/hifive-unleashed-a00.dtb" CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_DM_RESET=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/sifive_unmatched_defconfig b/configs/sifive_unmatched_defconfig index 41224d038147..40aa38fe5246 100644 --- a/configs/sifive_unmatched_defconfig +++ b/configs/sifive_unmatched_defconfig @@ -26,6 +26,7 @@ CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_ID_EEPROM=y +CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_DM_RESET=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/silk_defconfig b/configs/silk_defconfig index 065241279ed5..6cbe5aaa865a 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_ENV_ADDR=0xC0000 CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SPL_MAX_SIZE=0x4000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index b3c6d23e717b..38ddb142b174 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -32,6 +32,8 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run flashboot" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x1000 +CONFIG_SPL_PAD_TO=0x20000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_RAW_ONLY=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index 483b3713186d..ef2f49f627e8 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="setenv boot_mmc_part ${kernel_mmc_part}; if test reboot-${reboot-mode} = reboot-r; then echo recovery; setenv boot_mmc_part ${recovery_mmc_part}; fi; if test reboot-${reboot-mode} = reboot-b; then echo fastboot; fastboot 0; fi; part start mmc ${boot_mmc_dev} ${boot_mmc_part} boot_mmc_start; part size mmc ${boot_mmc_dev} ${boot_mmc_part} boot_mmc_size; mmc dev ${boot_mmc_dev}; mmc read ${kernel_addr_r} ${boot_mmc_start} ${boot_mmc_size} && bootm ${kernel_addr_r};" CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SPL_MAX_SIZE=0xec00 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=2 diff --git a/configs/socfpga_agilex_atf_defconfig b/configs/socfpga_agilex_atf_defconfig index 9fd631bf0dd1..f84f258e1cf5 100644 --- a/configs/socfpga_agilex_atf_defconfig +++ b/configs/socfpga_agilex_atf_defconfig @@ -25,6 +25,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fatscript; run mmcfitload; run mmcfitboot" +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_CRC32=y CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/socfpga_agilex_defconfig b/configs/socfpga_agilex_defconfig index f356466d54c6..bc8e7811ee8d 100644 --- a/configs/socfpga_agilex_defconfig +++ b/configs/socfpga_agilex_defconfig @@ -22,6 +22,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fatscript; run mmcload; run linux_qspi_enable; run mmcboot" +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x3c00000 diff --git a/configs/socfpga_agilex_vab_defconfig b/configs/socfpga_agilex_vab_defconfig index 1ec6d7b1aa63..7bb0df2c4487 100644 --- a/configs/socfpga_agilex_vab_defconfig +++ b/configs/socfpga_agilex_vab_defconfig @@ -26,6 +26,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fatscript; run mmcfitload; run mmcfitboot" +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_CRC32=y CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index 903d885334dd..c3cd442d3744 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -24,6 +24,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CLOCKS=y +CONFIG_SPL_PAD_TO=0x40000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FPGA=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 37a401eafc6b..ee0585ca323c 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CLOCKS=y +CONFIG_SPL_PAD_TO=0x10000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SYS_MAXARGS=32 diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index a9dfeef74131..3ab2a7d4573d 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CLOCKS=y +CONFIG_SPL_PAD_TO=0x10000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SYS_MAXARGS=32 diff --git a/configs/socfpga_dbm_soc1_defconfig b/configs/socfpga_dbm_soc1_defconfig index bb06c408c8e0..cccee6f777ad 100644 --- a/configs/socfpga_dbm_soc1_defconfig +++ b/configs/socfpga_dbm_soc1_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CLOCKS=y +CONFIG_SPL_PAD_TO=0x10000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_HUSH_PARSER=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index e45e3dbaa700..74b1c803f5a7 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CLOCKS=y +CONFIG_SPL_PAD_TO=0x10000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 diff --git a/configs/socfpga_de10_nano_defconfig b/configs/socfpga_de10_nano_defconfig index 7a022992cbbe..9ae804f5f658 100644 --- a/configs/socfpga_de10_nano_defconfig +++ b/configs/socfpga_de10_nano_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CLOCKS=y +CONFIG_SPL_PAD_TO=0x10000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SYS_MAXARGS=32 diff --git a/configs/socfpga_de1_soc_defconfig b/configs/socfpga_de1_soc_defconfig index c2fac57d55c1..cf48d443e4b8 100644 --- a/configs/socfpga_de1_soc_defconfig +++ b/configs/socfpga_de1_soc_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CLOCKS=y +CONFIG_SPL_PAD_TO=0x10000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 770347c0407c..c289f1b8bfa9 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CLOCKS=y +CONFIG_SPL_PAD_TO=0x10000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SYS_MAXARGS=32 diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 936402ba8199..97977d33bd4e 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CLOCKS=y +CONFIG_SPL_PAD_TO=0x10000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SYS_MAXARGS=32 diff --git a/configs/socfpga_n5x_atf_defconfig b/configs/socfpga_n5x_atf_defconfig index 5e213d0a0e46..dc4734b8969b 100644 --- a/configs/socfpga_n5x_atf_defconfig +++ b/configs/socfpga_n5x_atf_defconfig @@ -24,6 +24,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon panic=-1 earlyprintk=ttyS0,115200" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fatscript; run mmcfitload; run mmcfitboot" +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_CRC32=y CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/socfpga_n5x_defconfig b/configs/socfpga_n5x_defconfig index 1fd4131108bd..3a17ace0fda4 100644 --- a/configs/socfpga_n5x_defconfig +++ b/configs/socfpga_n5x_defconfig @@ -19,6 +19,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon panic=-1 earlyprintk=ttyS0,115200" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fatscript; run mmcload; run linux_qspi_enable; run mmcboot" +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x3c00000 diff --git a/configs/socfpga_n5x_vab_defconfig b/configs/socfpga_n5x_vab_defconfig index 89a9025ae718..e1e61753b903 100644 --- a/configs/socfpga_n5x_vab_defconfig +++ b/configs/socfpga_n5x_vab_defconfig @@ -25,6 +25,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon panic=-1 earlyprintk=ttyS0,115200" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fatscript; run mmcfitload; run mmcfitboot" +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_CRC32=y CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/socfpga_secu1_defconfig b/configs/socfpga_secu1_defconfig index 2fea52b6effd..c55ed87f210b 100644 --- a/configs/socfpga_secu1_defconfig +++ b/configs/socfpga_secu1_defconfig @@ -31,6 +31,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CLOCKS=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_PAD_TO=0x10000 CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=0x1 diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index fba917ac3e34..db8dd0b2f20d 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CLOCKS=y +CONFIG_SPL_PAD_TO=0x10000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SYS_MAXARGS=32 diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 99f82e7f1c25..2602839e9d57 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CLOCKS=y +CONFIG_SPL_PAD_TO=0x10000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SYS_MAXARGS=32 diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index cdc48b1455d6..d939d0cce4af 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -25,6 +25,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CLOCKS=y +CONFIG_SPL_PAD_TO=0x10000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SYS_MAXARGS=32 diff --git a/configs/socfpga_stratix10_atf_defconfig b/configs/socfpga_stratix10_atf_defconfig index db486958013e..87c188fa9d72 100644 --- a/configs/socfpga_stratix10_atf_defconfig +++ b/configs/socfpga_stratix10_atf_defconfig @@ -25,6 +25,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fatscript; run mmcfitload; run mmcfitboot" +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_CRC32=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x02000000 diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index 2d5315cf7435..9db555a846ac 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -24,6 +24,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fatscript; run mmcload; run linux_qspi_enable; run mmcboot" +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x3C00000 CONFIG_HUSH_PARSER=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 202121511c14..154f8197b5d4 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -25,6 +25,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CLOCKS=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_PAD_TO=0x10000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_CMDLINE_PS_SUPPORT=y diff --git a/configs/stm32746g-eval_defconfig b/configs/stm32746g-eval_defconfig index b90492685ac4..92bd206b32c7 100644 --- a/configs/stm32746g-eval_defconfig +++ b/configs/stm32746g-eval_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_PAD_TO=0x8000 CONFIG_SYS_PROMPT="U-Boot > " CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_GPT=y diff --git a/configs/stm32746g-eval_spl_defconfig b/configs/stm32746g-eval_spl_defconfig index 7522a0e0b549..c8e30525a583 100644 --- a/configs/stm32746g-eval_spl_defconfig +++ b/configs/stm32746g-eval_spl_defconfig @@ -26,6 +26,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_PAD_TO=0x8000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index 0473ed6e609b..76023a5dab39 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_PAD_TO=0x8000 CONFIG_SYS_PROMPT="U-Boot > " CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_GPT=y diff --git a/configs/stm32f746-disco_spl_defconfig b/configs/stm32f746-disco_spl_defconfig index 440022d75234..1eeae3a4ac32 100644 --- a/configs/stm32f746-disco_spl_defconfig +++ b/configs/stm32f746-disco_spl_defconfig @@ -26,6 +26,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_PAD_TO=0x8000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/stm32f769-disco_defconfig b/configs/stm32f769-disco_defconfig index 180112a5a06d..7894594b01e9 100644 --- a/configs/stm32f769-disco_defconfig +++ b/configs/stm32f769-disco_defconfig @@ -17,6 +17,7 @@ CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_PAD_TO=0x8000 CONFIG_SYS_PROMPT="U-Boot > " CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_GPT=y diff --git a/configs/stm32f769-disco_spl_defconfig b/configs/stm32f769-disco_spl_defconfig index 7594eff47c60..570f69fe1d23 100644 --- a/configs/stm32f769-disco_spl_defconfig +++ b/configs/stm32f769-disco_spl_defconfig @@ -25,6 +25,7 @@ CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_PAD_TO=0x8000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/stout_defconfig b/configs/stout_defconfig index 46b2549ca4ee..4fa827765456 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_ENV_ADDR=0xC0000 CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SPL_MAX_SIZE=0x4000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/syzygy_hub_defconfig b/configs/syzygy_hub_defconfig index b1990841987e..279da693229e 100644 --- a/configs/syzygy_hub_defconfig +++ b/configs/syzygy_hub_defconfig @@ -25,6 +25,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_USE_PREBOOT=y CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x30000 CONFIG_SPL_STACK_R=y CONFIG_SPL_FS_LOAD_ARGS_NAME="system.dtb" CONFIG_SPL_OS_BOOT=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 8bc5afdc2e51..15687143358c 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -39,6 +39,8 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="nand read 0x22000000 0x200000 0x300000; bootm" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_MAX_SIZE=0x3e00 +CONFIG_SPL_PAD_TO=0x20000 # CONFIG_SPL_LEGACY_IMAGE_FORMAT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_CRC32=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index d0cb511ca920..839599292288 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -27,6 +27,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x1bfd0 CONFIG_SPL_I2C=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 85d7d2677a91..8134ccec9a15 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -27,6 +27,7 @@ CONFIG_BOOTCOMMAND="mmc rescan;fatload mmc 0 ${loadaddr} uImage;bootm ${loadaddr CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set # CONFIG_MISC_INIT_R is not set +CONFIG_SPL_MAX_SIZE=0xfff1b400 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index 5c2366098b7b..019fe4b26e4a 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3288-tinker.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_SPL_I2C=y diff --git a/configs/tinker-s-rk3288_defconfig b/configs/tinker-s-rk3288_defconfig index 4b6ae64988af..27d2e5c4028a 100644 --- a/configs/tinker-s-rk3288_defconfig +++ b/configs/tinker-s-rk3288_defconfig @@ -11,7 +11,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3288-tinker-s" CONFIG_ROCKCHIP_RK3288=y CONFIG_TARGET_TINKER_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x800000 -CONFIG_SPL_SIZE_LIMIT=0x4B000 +CONFIG_SPL_SIZE_LIMIT=0x4b000 CONFIG_DEBUG_UART_BASE=0xff690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SYS_LOAD_ADDR=0x800800 @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3288-tinker-s.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x300000 CONFIG_SPL_I2C=y diff --git a/configs/topic_miami_defconfig b/configs/topic_miami_defconfig index e62b7dc85878..4e8f5fe078b5 100644 --- a/configs/topic_miami_defconfig +++ b/configs/topic_miami_defconfig @@ -25,6 +25,7 @@ CONFIG_BOOTDELAY=0 CONFIG_BOOTCOMMAND="if mmcinfo; then if fatload mmc 0 0x1900000 ${bootscript}; then source 0x1900000; fi; fi; run $modeboot" CONFIG_USE_PREBOOT=y CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x30000 CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig index 5acf1dec1085..1e64b06e0590 100644 --- a/configs/topic_miamilite_defconfig +++ b/configs/topic_miamilite_defconfig @@ -25,6 +25,7 @@ CONFIG_BOOTDELAY=0 CONFIG_BOOTCOMMAND="if mmcinfo; then if fatload mmc 0 0x1900000 ${bootscript}; then source 0x1900000; fi; fi; run $modeboot" CONFIG_USE_PREBOOT=y CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x30000 CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index 7a51c5c7c4b0..bd70cb7015c8 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -25,6 +25,7 @@ CONFIG_BOOTDELAY=0 CONFIG_BOOTCOMMAND="if mmcinfo; then if fatload mmc 0 0x1900000 ${bootscript}; then source 0x1900000; fi; fi; run $modeboot" CONFIG_USE_PREBOOT=y CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x30000 CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index 224d6f01b35a..dae24ba0da08 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -36,6 +36,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x22fd0 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index 03e4f1fb0360..c0e4f15af547 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -16,6 +16,8 @@ CONFIG_BOOTCOMMAND="run ${bootdev}script; run ${bootdev}boot" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="env exist ${bootdev}preboot && run ${bootdev}preboot" CONFIG_LOGLEVEL=6 +CONFIG_SPL_MAX_SIZE=0x10000 +CONFIG_SPL_PAD_TO=0x20000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_CMD_CONFIG=y diff --git a/configs/uniphier_v7_defconfig b/configs/uniphier_v7_defconfig index b69b2b265706..13e208c1a032 100644 --- a/configs/uniphier_v7_defconfig +++ b/configs/uniphier_v7_defconfig @@ -16,6 +16,8 @@ CONFIG_BOOTCOMMAND="run ${bootdev}script; run ${bootdev}boot" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="env exist ${bootdev}preboot && run ${bootdev}preboot" CONFIG_LOGLEVEL=6 +CONFIG_SPL_MAX_SIZE=0x10000 +CONFIG_SPL_PAD_TO=0x20000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_CMD_CONFIG=y diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index db986cf13b84..c0cdc121f0ae 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -15,6 +15,8 @@ CONFIG_BOOTCOMMAND="run ${bootdev}script; run ${bootdev}boot" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="env exist ${bootdev}preboot && run ${bootdev}preboot" CONFIG_LOGLEVEL=6 +CONFIG_SPL_MAX_SIZE=0x10000 +CONFIG_SPL_PAD_TO=0x20000 CONFIG_CMD_CONFIG=y # CONFIG_CMD_XIMG is not set CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=10 diff --git a/configs/verdin-imx8mm_defconfig b/configs/verdin-imx8mm_defconfig index ec47a0f10bde..e2e6cfb9623e 100644 --- a/configs/verdin-imx8mm_defconfig +++ b/configs/verdin-imx8mm_defconfig @@ -32,6 +32,7 @@ CONFIG_LOG=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x25000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/verdin-imx8mp_defconfig b/configs/verdin-imx8mp_defconfig index 10d88ff79f19..0ec44aab4bef 100644 --- a/configs/verdin-imx8mp_defconfig +++ b/configs/verdin-imx8mp_defconfig @@ -40,6 +40,7 @@ CONFIG_LOG=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x26000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/vocore2_defconfig b/configs/vocore2_defconfig index 33d27ad4b62d..42031be6270a 100644 --- a/configs/vocore2_defconfig +++ b/configs/vocore2_defconfig @@ -31,6 +31,7 @@ CONFIG_LOGLEVEL=8 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SYS_MALLOC_BOOTPARAMS=y +CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/vyasa-rk3288_defconfig b/configs/vyasa-rk3288_defconfig index ecba1a76c389..dedf62771954 100644 --- a/configs/vyasa-rk3288_defconfig +++ b/configs/vyasa-rk3288_defconfig @@ -20,6 +20,7 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3288-vyasa.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_SPL_OS_BOOT=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index 4c5008fedef3..e3409ad305ee 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -26,6 +26,7 @@ CONFIG_BOOTARGS="console=ttyS2,115200n8" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_PAD_TO=0x20000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/x530_defconfig b/configs/x530_defconfig index 4106b475b925..2be6e2cc69fd 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -26,6 +26,7 @@ CONFIG_SILENT_U_BOOT_ONLY=y CONFIG_SILENT_CONSOLE_UPDATE_ON_RELOC=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x22fd0 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_WATCHDOG=y CONFIG_SYS_CBSIZE=256 diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index 5e724f063f9d..c01a9189d448 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -28,6 +28,7 @@ CONFIG_LEGACY_IMAGE_FORMAT=y # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_PREBOOT=y CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x30000 CONFIG_SPL_STACK_R=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_FS_LOAD_ARGS_NAME="system.dtb" diff --git a/configs/xilinx_zynqmp_mini_defconfig b/configs/xilinx_zynqmp_mini_defconfig index 50f87ba60288..cb714d78622a 100644 --- a/configs/xilinx_zynqmp_mini_defconfig +++ b/configs/xilinx_zynqmp_mini_defconfig @@ -18,6 +18,7 @@ CONFIG_REMAKE_ELF=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_BOARD_LATE_INIT is not set CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x40000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set diff --git a/configs/xilinx_zynqmp_mini_emmc0_defconfig b/configs/xilinx_zynqmp_mini_emmc0_defconfig index 0e0adefe34a6..f64600a0d371 100644 --- a/configs/xilinx_zynqmp_mini_emmc0_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc0_defconfig @@ -22,6 +22,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_BOARD_LATE_INIT is not set CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x40000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_MAXARGS=64 diff --git a/configs/xilinx_zynqmp_mini_emmc1_defconfig b/configs/xilinx_zynqmp_mini_emmc1_defconfig index 64118cb6ccc1..b3b193ca5c93 100644 --- a/configs/xilinx_zynqmp_mini_emmc1_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc1_defconfig @@ -22,6 +22,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_BOARD_LATE_INIT is not set CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x40000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_MAXARGS=64 diff --git a/configs/xilinx_zynqmp_mini_nand_defconfig b/configs/xilinx_zynqmp_mini_nand_defconfig index dd5a36c92e93..fbace07a9b54 100644 --- a/configs/xilinx_zynqmp_mini_nand_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_defconfig @@ -19,6 +19,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_BOARD_LATE_INIT is not set CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x40000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set diff --git a/configs/xilinx_zynqmp_mini_nand_single_defconfig b/configs/xilinx_zynqmp_mini_nand_single_defconfig index b1bc70c4eaee..dccd5fc47883 100644 --- a/configs/xilinx_zynqmp_mini_nand_single_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_single_defconfig @@ -19,6 +19,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_BOARD_LATE_INIT is not set CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x40000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index f8425dc4d230..d5ca194ca7ce 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -21,6 +21,7 @@ CONFIG_REMAKE_ELF=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_BOARD_LATE_INIT is not set CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x40000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 35625a4c1fa4..91c65c9279ab 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -31,6 +31,7 @@ CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="run scsi_init;usb start" CONFIG_BOARD_EARLY_INIT_R=y CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_STACK_R=y CONFIG_SPL_FS_LOAD_KERNEL_NAME="atf-uboot.ub" CONFIG_SPL_FS_LOAD_ARGS_NAME="u-boot.bin" diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index d21ca5550a3a..38002882eadb 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_BOARD_LATE_INIT is not set CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x30000 CONFIG_SPL_STACK_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig index 12a704be206e..41c870499cc7 100644 --- a/configs/zynq_cse_nor_defconfig +++ b/configs/zynq_cse_nor_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_BOARD_LATE_INIT is not set CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x30000 CONFIG_SPL_STACK_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/zynq_cse_qspi_defconfig b/configs/zynq_cse_qspi_defconfig index 392235088fb6..b057ee7169dd 100644 --- a/configs/zynq_cse_qspi_defconfig +++ b/configs/zynq_cse_qspi_defconfig @@ -28,6 +28,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_ARCH_EARLY_INIT_R is not set # CONFIG_BOARD_LATE_INIT is not set CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x30000 CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index 4fb74e7568bf..17c76bcf3dbc 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -9,20 +9,12 @@ #ifndef __CONFIG_FALLBACKS_H #define __CONFIG_FALLBACKS_H
-#ifdef CONFIG_SPL #ifdef CONFIG_SPL_PAD_TO #ifdef CONFIG_SPL_MAX_SIZE #if CONFIG_SPL_PAD_TO && CONFIG_SPL_PAD_TO < CONFIG_SPL_MAX_SIZE #error CONFIG_SPL_PAD_TO < CONFIG_SPL_MAX_SIZE #endif #endif -#else -#ifdef CONFIG_SPL_MAX_SIZE -#define CONFIG_SPL_PAD_TO CONFIG_SPL_MAX_SIZE -#else -#define CONFIG_SPL_PAD_TO 0 -#endif -#endif #endif
#ifndef CONFIG_SYS_BAUDRATE_TABLE diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 8667941a0ab3..3b7a49251293 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -17,8 +17,6 @@
#ifdef CONFIG_SDCARD #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_PAD_TO 0x18000 -#define CONFIG_SPL_MAX_SIZE (96 * 1024) #define CONFIG_SYS_MMC_U_BOOT_SIZE (512 << 10) #define CONFIG_SYS_MMC_U_BOOT_DST (0x11000000) #define CONFIG_SYS_MMC_U_BOOT_START (0x11000000) @@ -36,8 +34,6 @@ #else #define CONFIG_SPL_SPI_FLASH_MINIMAL #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_PAD_TO 0x18000 -#define CONFIG_SPL_MAX_SIZE (96 * 1024) #define CONFIG_SYS_SPI_FLASH_U_BOOT_SIZE (512 << 10) #define CONFIG_SYS_SPI_FLASH_U_BOOT_DST (0x11000000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_START (0x11000000) @@ -53,7 +49,6 @@ #ifdef CONFIG_NXP_ESBC #define CONFIG_SPL_TARGET "u-boot-with-spl.bin"
-#define CONFIG_SPL_MAX_SIZE 8192 #define CONFIG_SPL_RELOC_TEXT_BASE 0x00100000 #define CONFIG_SPL_RELOC_STACK 0x00100000 #define CONFIG_SYS_NAND_U_BOOT_SIZE ((768 << 10) - 0x2000) @@ -63,13 +58,11 @@ #ifdef CONFIG_TPL_BUILD #define CONFIG_SPL_NAND_INIT #define CONFIG_SPL_COMMON_INIT_DDR -#define CONFIG_SPL_MAX_SIZE (128 << 10) #define CONFIG_SYS_MPC85XX_NO_RESETVEC #define CONFIG_SYS_NAND_U_BOOT_SIZE (576 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST (0x11000000) #define CONFIG_SYS_NAND_U_BOOT_START (0x11000000) #elif defined(CONFIG_SPL_BUILD) -#define CONFIG_SPL_MAX_SIZE 8192 #define CONFIG_SYS_NAND_U_BOOT_SIZE (128 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0xD0000000 #define CONFIG_SYS_NAND_U_BOOT_START 0xD0000000 @@ -78,8 +71,6 @@ #define CONFIG_SYS_MPC85XX_NO_RESETVEC #endif #endif -#define CONFIG_SPL_PAD_TO 0x20000 -#define CONFIG_TPL_PAD_TO 0x20000 #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #endif #endif diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 30570ad51198..c912062ce4ea 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -21,8 +21,6 @@ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS
#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_SPL_PAD_TO 0x40000 -#define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC #define BOOT_PAGE_OFFSET 0x27000 #ifdef CONFIG_SPL_BUILD diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 2d9c8fcd175e..81b820ee6cbb 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -15,8 +15,6 @@ #include <asm/config_mpc85xx.h>
#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_SPL_PAD_TO 0x40000 -#define CONFIG_SPL_MAX_SIZE 0x28000 #ifdef CONFIG_SPL_BUILD #define CONFIG_SPL_COMMON_INIT_DDR #define CONFIG_SYS_CCSR_DO_NOT_RELOCATE diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 1f546f4407c8..a18f44caa388 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -29,8 +29,6 @@ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS
#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_SPL_PAD_TO 0x40000 -#define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC #define BOOT_PAGE_OFFSET 0x27000 #ifdef CONFIG_SPL_BUILD diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 1bd4b36eb8bf..96a8ad102bda 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -24,8 +24,6 @@ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS
#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_SPL_PAD_TO 0x40000 -#define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC #define BOOT_PAGE_OFFSET 0x27000 #ifdef CONFIG_SPL_BUILD diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 934f98ca3730..6dd43340d655 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -22,8 +22,6 @@ #define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #else -#define CONFIG_SPL_PAD_TO 0x40000 -#define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC #define BOOT_PAGE_OFFSET 0x27000
diff --git a/include/configs/alt.h b/include/configs/alt.h index 090bee7d2d66..eb71c6d1de5c 100644 --- a/include/configs/alt.h +++ b/include/configs/alt.h @@ -40,6 +40,5 @@
/* SPL support */ #define CONFIG_SPL_STACK 0xe6340000 -#define CONFIG_SPL_MAX_SIZE 0x4000
#endif /* __ALT_H */ diff --git a/include/configs/am64x_evm.h b/include/configs/am64x_evm.h index 0abaddcae6d2..98f2ecae202e 100644 --- a/include/configs/am64x_evm.h +++ b/include/configs/am64x_evm.h @@ -18,7 +18,6 @@ /* DDR Configuration */ #define CONFIG_SYS_SDRAM_BASE1 0x880000000
-#define CONFIG_SPL_MAX_SIZE CONFIG_SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE #if defined(CONFIG_TARGET_AM642_A53_EVM) #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SPL_TEXT_BASE + SZ_4M) #else diff --git a/include/configs/am65x_evm.h b/include/configs/am65x_evm.h index ba50c759c00f..0093f077ed35 100644 --- a/include/configs/am65x_evm.h +++ b/include/configs/am65x_evm.h @@ -44,8 +44,6 @@ #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_16M #endif
-#define CONFIG_SPL_MAX_SIZE CONFIG_SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE - #define CONFIG_SYS_BOOTM_LEN SZ_64M
#define PARTS_DEFAULT \ diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 20753e00de74..7cdd682894e0 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -41,7 +41,6 @@ #endif
/* Defines for SPL */ -#define CONFIG_SPL_MAX_SIZE 0x010000 #define CONFIG_SPL_STACK 0x310000
#define CONFIG_SYS_MONITOR_LEN 0x80000 diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 7bc8a36481db..94f1096f4028 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -60,7 +60,6 @@ #endif
/* SPL */ -#define CONFIG_SPL_MAX_SIZE 0x6000 #define CONFIG_SPL_STACK 0x308000
#define CONFIG_SPL_BSS_START_ADDR 0x20000000 diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index cab44d2645a2..a0f0916ab784 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -55,7 +55,6 @@ #endif
#define CONFIG_SPL_BSS_START_ADDR 0x20000000 diff --git a/include/configs/ax25-ae350.h b/include/configs/ax25-ae350.h index 242b73f8f2f0..be420bf154f5 100644 --- a/include/configs/ax25-ae350.h +++ b/include/configs/ax25-ae350.h @@ -8,7 +8,6 @@ #define __CONFIG_H
#ifdef CONFIG_SPL -#define CONFIG_SPL_MAX_SIZE 0x00100000 #define CONFIG_SPL_BSS_START_ADDR 0x04000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 #endif diff --git a/include/configs/bur_am335x_common.h b/include/configs/bur_am335x_common.h index 1c3c86eb59f7..157d51e02f3d 100644 --- a/include/configs/bur_am335x_common.h +++ b/include/configs/bur_am335x_common.h @@ -36,8 +36,6 @@ * Y-MODEM to load u-boot.img, when booted over UART. We must also include * the scratch space that U-Boot uses in SRAM. */ -#define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ - CONFIG_SPL_TEXT_BASE)
/* * Since SPL did pll and ddr initialization for us, diff --git a/include/configs/capricorn-common.h b/include/configs/capricorn-common.h index 63d02c5b44fb..92b26e735baa 100644 --- a/include/configs/capricorn-common.h +++ b/include/configs/capricorn-common.h @@ -15,7 +15,6 @@ /* SPL config */ #ifdef CONFIG_SPL_BUILD
-#define CONFIG_SPL_MAX_SIZE (124 * 1024) #define CONFIG_SYS_MONITOR_LEN (1024 * 1024)
#define CONFIG_SPL_STACK 0x013E000 diff --git a/include/configs/cgtqmx8.h b/include/configs/cgtqmx8.h index 6da0483ef09a..6dff69c2f671 100644 --- a/include/configs/cgtqmx8.h +++ b/include/configs/cgtqmx8.h @@ -12,7 +12,6 @@ #include <asm/arch/imx-regs.h>
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_MAX_SIZE (124 * 1024) #define CONFIG_SYS_MONITOR_LEN (1024 * 1024)
#define CONFIG_SPL_STACK 0x013E000 diff --git a/include/configs/ci20.h b/include/configs/ci20.h index d2cb2f4b6f2d..af9e4a347461 100644 --- a/include/configs/ci20.h +++ b/include/configs/ci20.h @@ -33,8 +33,6 @@ /* SPL */ #define CONFIG_SPL_STACK 0xf4008000 /* only max. 2KB spare! */
-#define CONFIG_SPL_MAX_SIZE ((14 * 1024) - 0xa00) - #define CONFIG_SPL_BSS_START_ADDR 0xf4004000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00002000 /* 512KB, arbitrary */
diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index 871e87c26d01..b8af7187c170 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -44,7 +44,6 @@
/* Defines for SPL */ #define CONFIG_SPL_SIZE (140 << 10) -#define CONFIG_SPL_MAX_SIZE (CONFIG_SPL_SIZE - (CONFIG_SPL_TEXT_BASE - 0x40000000))
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) #define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index b499d7085fd4..94f61f99687d 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -37,12 +37,6 @@ /* Defines for SPL */ #define CONFIG_SPL_SIZE (160 << 10)
-#if defined(CONFIG_SECURED_MODE_IMAGE) -#define CONFIG_SPL_MAX_SIZE (CONFIG_SPL_SIZE - 0x2614) -#else -#define CONFIG_SPL_MAX_SIZE (CONFIG_SPL_SIZE - 0x30) -#endif - #define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) #define CONFIG_SPL_BSS_MAX_SIZE (16 << 10)
diff --git a/include/configs/corvus.h b/include/configs/corvus.h index b4fef73121af..95ea75ced1d9 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -57,7 +57,6 @@ /* bootstrap + u-boot + env in nandflash */
/* Defines for SPL */ -#define CONFIG_SPL_MAX_SIZE (12 * SZ_1K) #define CONFIG_SPL_STACK (SZ_16K)
#define CONFIG_SPL_BSS_START_ADDR CONFIG_SPL_MAX_SIZE @@ -79,7 +78,6 @@ #define CONFIG_SYS_MCKR 0x1301 #define CONFIG_SYS_MCKR_CSS 0x1302
-#define CONFIG_SPL_PAD_TO CONFIG_SYS_NAND_U_BOOT_OFFS #define CONFIG_SYS_SPL_LEN CONFIG_SPL_PAD_TO
#endif diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 12f5bbf51278..5e3925e5fd58 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -178,10 +178,6 @@ #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15
-#ifndef CONFIG_MTD_NOR_FLASH -#define CONFIG_SPL_PAD_TO 32768 -#endif - #ifdef CONFIG_SPL_BUILD /* defines for SPL */ #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_TEXT_BASE - \ diff --git a/include/configs/db-88f6720.h b/include/configs/db-88f6720.h index 16c83a88dace..dd5a8389eba1 100644 --- a/include/configs/db-88f6720.h +++ b/include/configs/db-88f6720.h @@ -34,7 +34,6 @@
/* SPL */ /* Defines for SPL */ -#define CONFIG_SPL_MAX_SIZE ((128 << 10) - (CONFIG_SPL_TEXT_BASE - 0x40000000))
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + (128 << 10)) #define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 9ad9173f7d48..e0e9c7ce6d5a 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -41,7 +41,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) #define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index 8dc73e8b1cc9..11f522a25aba 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -41,7 +41,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) #define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index d6850bd32e72..98ce65f5da3a 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -53,7 +53,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + (128 << 10)) #define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index d2a760e9b1f6..c944910584f4 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -97,9 +97,6 @@
/* SPL will use serial */
-#define CONFIG_SPL_MAX_SIZE 0x20000 -#define CONFIG_SPL_PAD_TO CONFIG_SPL_MAX_SIZE - /* U-Boot will be 0x60000 bytes, loaded and run at CONFIG_SYS_TEXT_BASE */ #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x60000
diff --git a/include/configs/ds414.h b/include/configs/ds414.h index dbccd46bbdb1..2c07a9e34038 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -45,7 +45,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + (128 << 10)) #define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index 685eb7d0251e..c3acaef238f5 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -15,7 +15,6 @@ * SPL */
-#define CONFIG_SPL_MAX_SIZE 0x0000fff0 #define CONFIG_SPL_STACK 0x00020000 #define CONFIG_SPL_BSS_START_ADDR 0x00020000 #define CONFIG_SPL_BSS_MAX_SIZE 0x0001ffff diff --git a/include/configs/gardena-smart-gateway-at91sam.h b/include/configs/gardena-smart-gateway-at91sam.h index 3e99d2cfb04d..ae1fc8266122 100644 --- a/include/configs/gardena-smart-gateway-at91sam.h +++ b/include/configs/gardena-smart-gateway-at91sam.h @@ -36,7 +36,6 @@ #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PD5
/* SPL */ -#define CONFIG_SPL_MAX_SIZE 0x7000 #define CONFIG_SPL_STACK 0x308000
#define CONFIG_SPL_BSS_START_ADDR 0x20000000 @@ -55,7 +54,6 @@ #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE
#endif diff --git a/include/configs/gardena-smart-gateway-mt7688.h b/include/configs/gardena-smart-gateway-mt7688.h index 3fe37eae8bfa..efb053023441 100644 --- a/include/configs/gardena-smart-gateway-mt7688.h +++ b/include/configs/gardena-smart-gateway-mt7688.h @@ -19,8 +19,6 @@ #define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SPL_BSS_START_ADDR 0x80010000 #define CONFIG_SPL_BSS_MAX_SIZE 0x10000 -#define CONFIG_SPL_MAX_SIZE 0x10000 -#define CONFIG_SPL_PAD_TO 0
/* Dummy value */ #define CONFIG_SYS_UBOOT_BASE 0 diff --git a/include/configs/gose.h b/include/configs/gose.h index 4ffa5bea8f83..70c4e91eee1b 100644 --- a/include/configs/gose.h +++ b/include/configs/gose.h @@ -35,6 +35,5 @@
#endif /* __GOSE_H */ diff --git a/include/configs/helios4.h b/include/configs/helios4.h index 151ab66f4c3f..d405d4b3f6a4 100644 --- a/include/configs/helios4.h +++ b/include/configs/helios4.h @@ -44,7 +44,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) #define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) diff --git a/include/configs/imx6_spl.h b/include/configs/imx6_spl.h index 38aec9436e46..5b8d7590312c 100644 --- a/include/configs/imx6_spl.h +++ b/include/configs/imx6_spl.h @@ -21,14 +21,12 @@ * and some padding thus 'our' max size is really 0x00908000 - 0x00938000 * or 192KB */ -#define CONFIG_SPL_MAX_SIZE 0x30000 #define CONFIG_SPL_STACK 0x0093FFB8 /* * Pad SPL to 196KB (4KB header + 192KB max size). This allows to write the * SPL/U-Boot combination generated with u-boot-with-spl.imx directly to a * boot media (given that boot media specific offset is configured properly). */ -#define CONFIG_SPL_PAD_TO 0x31000 #else /* * see Figure 8-3 in IMX6SDL Reference manuals: @@ -42,14 +40,12 @@ * and some padding thus 'our' max size is really 0x00908000 - 0x00918000 * or 64KB */ -#define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_STACK 0x0091FFB8 /* * Pad SPL to 68KB (4KB header + 64KB max size). This allows to write the * SPL/U-Boot combination generated with u-boot-with-spl.imx directly to a * boot media (given that boot media specific offset is configured properly). */ -#define CONFIG_SPL_PAD_TO 0x11000
#endif
diff --git a/include/configs/imx7_spl.h b/include/configs/imx7_spl.h index 39136ea49a8e..135727bab9ae 100644 --- a/include/configs/imx7_spl.h +++ b/include/configs/imx7_spl.h @@ -26,7 +26,6 @@ * CONFIG_SPL_TEXT_BASE could be moved to 0x00911000 to gain 4KB of space * for the SPL, but 56KB should be more than enough for the SPL. */ -#define CONFIG_SPL_MAX_SIZE 0xE000 #define CONFIG_SPL_STACK 0x00946BB8 /* * Pad SPL to 68KB (4KB header + 56KB max size + 8KB extra padding) @@ -36,7 +35,6 @@ * u-boot-with-spl.imx directly to a boot media (given that boot media specific * offset is configured properly). */ -#define CONFIG_SPL_PAD_TO 0x11000
/* MMC support */ #if defined(CONFIG_SPL_MMC) diff --git a/include/configs/imx8mm-cl-iot-gate.h b/include/configs/imx8mm-cl-iot-gate.h index bb29bdce03e0..ff7f51b01c02 100644 --- a/include/configs/imx8mm-cl-iot-gate.h +++ b/include/configs/imx8mm-cl-iot-gate.h @@ -12,7 +12,6 @@ #include <config_distro_bootcmd.h>
#define CONFIG_SYS_BOOTM_LEN (32 * SZ_1M) -#define CONFIG_SPL_MAX_SIZE (148 * 1024) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index 155ad57f9e1a..f411675f2726 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -9,7 +9,6 @@ #include <linux/sizes.h> #include <asm/arch/imx-regs.h>
-#define CONFIG_SPL_MAX_SIZE (148 * 1024) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/imx8mm_data_modul_edm_sbc.h b/include/configs/imx8mm_data_modul_edm_sbc.h index 8105f33be723..7a471c19362e 100644 --- a/include/configs/imx8mm_data_modul_edm_sbc.h +++ b/include/configs/imx8mm_data_modul_edm_sbc.h @@ -12,7 +12,6 @@
#define CONFIG_SYS_BOOTM_LEN SZ_128M
-#define CONFIG_SPL_MAX_SIZE (148 * 1024) #define CONFIG_SYS_MONITOR_LEN SZ_1M
#define CONFIG_SPL_STACK 0x920000 diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index e086e979dd9c..9425d2ededea 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -11,7 +11,6 @@ #include <asm/arch/imx-regs.h>
#define CONFIG_SYS_BOOTM_LEN (64 * SZ_1M) -#define CONFIG_SPL_MAX_SIZE (148 * 1024) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/imx8mm_icore_mx8mm.h b/include/configs/imx8mm_icore_mx8mm.h index f034f6f7049a..90f1da60dc5f 100644 --- a/include/configs/imx8mm_icore_mx8mm.h +++ b/include/configs/imx8mm_icore_mx8mm.h @@ -10,7 +10,6 @@ #include <linux/sizes.h> #include <asm/arch/imx-regs.h>
-#define CONFIG_SPL_MAX_SIZE (148 * 1024) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/imx8mm_venice.h b/include/configs/imx8mm_venice.h index 0fda754dcca8..fc0c23892aed 100644 --- a/include/configs/imx8mm_venice.h +++ b/include/configs/imx8mm_venice.h @@ -9,7 +9,6 @@ #include <asm/arch/imx-regs.h> #include <linux/sizes.h>
-#define CONFIG_SPL_MAX_SIZE (148 * 1024) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/imx8mn_beacon.h b/include/configs/imx8mn_beacon.h index 77e4dd810460..966b27ef22b5 100644 --- a/include/configs/imx8mn_beacon.h +++ b/include/configs/imx8mn_beacon.h @@ -9,7 +9,6 @@ #include <linux/sizes.h> #include <asm/arch/imx-regs.h>
-#define CONFIG_SPL_MAX_SIZE (148 * SZ_1K) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/imx8mn_bsh_smm_s2_common.h b/include/configs/imx8mn_bsh_smm_s2_common.h index 367b9ee06072..f1351edf8f11 100644 --- a/include/configs/imx8mn_bsh_smm_s2_common.h +++ b/include/configs/imx8mn_bsh_smm_s2_common.h @@ -12,7 +12,6 @@
-#define CONFIG_SPL_MAX_SIZE (148 * SZ_1K) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index 395b8b078028..21601ac56b5d 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -12,7 +12,6 @@
-#define CONFIG_SPL_MAX_SIZE (148 * 1024) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/imx8mn_var_som.h b/include/configs/imx8mn_var_som.h index 03e7341398c7..350af54a0fae 100644 --- a/include/configs/imx8mn_var_som.h +++ b/include/configs/imx8mn_var_som.h @@ -12,7 +12,6 @@
-#define CONFIG_SPL_MAX_SIZE (148 * SZ_1K) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/imx8mn_venice.h b/include/configs/imx8mn_venice.h index 687801e5c22d..e902ab0c6a41 100644 --- a/include/configs/imx8mn_venice.h +++ b/include/configs/imx8mn_venice.h @@ -9,7 +9,6 @@ #include <asm/arch/imx-regs.h> #include <linux/sizes.h>
-#define CONFIG_SPL_MAX_SIZE (148 * 1024) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index cbea3d5625e1..163e2e72e978 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -12,7 +12,6 @@
-#define CONFIG_SPL_MAX_SIZE (152 * 1024) #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_UBOOT_BASE (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
diff --git a/include/configs/imx8mp_rsb3720.h b/include/configs/imx8mp_rsb3720.h index 4e45ed7b4985..fddd7553f0c0 100644 --- a/include/configs/imx8mp_rsb3720.h +++ b/include/configs/imx8mp_rsb3720.h @@ -14,7 +14,6 @@
diff --git a/include/configs/imx8mp_venice.h b/include/configs/imx8mp_venice.h index 68313856f04b..ff3ddc2061db 100644 --- a/include/configs/imx8mp_venice.h +++ b/include/configs/imx8mp_venice.h @@ -9,7 +9,6 @@ #include <asm/arch/imx-regs.h> #include <linux/sizes.h>
-#define CONFIG_SPL_MAX_SIZE (152 * 1024) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/imx8mq_cm.h b/include/configs/imx8mq_cm.h index 31a8274d578a..c0b98dfd9e85 100644 --- a/include/configs/imx8mq_cm.h +++ b/include/configs/imx8mq_cm.h @@ -12,7 +12,6 @@
-#define CONFIG_SPL_MAX_SIZE (124 * 1024) #define CONFIG_SYS_MONITOR_LEN (512 * 1024)
#ifdef CONFIG_SPL_BUILD diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index b31d7534bd0d..8ab543ba64e4 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -12,7 +12,6 @@
#ifdef CONFIG_SPL_BUILD diff --git a/include/configs/imx8mq_phanbell.h b/include/configs/imx8mq_phanbell.h index 1950de567eab..cbc0afe4e9eb 100644 --- a/include/configs/imx8mq_phanbell.h +++ b/include/configs/imx8mq_phanbell.h @@ -9,7 +9,6 @@ #include <linux/sizes.h> #include <asm/arch/imx-regs.h>
-#define CONFIG_SPL_MAX_SIZE (172 * 1024) #define CONFIG_SYS_MONITOR_LEN (512 * 1024)
#ifdef CONFIG_SPL_BUILD diff --git a/include/configs/imx8qm_mek.h b/include/configs/imx8qm_mek.h index 61d56e269ac4..9a5160d8d07f 100644 --- a/include/configs/imx8qm_mek.h +++ b/include/configs/imx8qm_mek.h @@ -13,7 +13,6 @@ #define CONFIG_SYS_BOOTM_LEN (64 * SZ_1M)
#define CONFIG_SPL_STACK 0x013E000 diff --git a/include/configs/imx8qm_rom7720.h b/include/configs/imx8qm_rom7720.h index 81ab5d8caa57..43c4c3cc4e32 100644 --- a/include/configs/imx8qm_rom7720.h +++ b/include/configs/imx8qm_rom7720.h @@ -10,7 +10,6 @@ #include <linux/stringify.h> #include <asm/arch/imx-regs.h>
-#define CONFIG_SPL_MAX_SIZE (124 * 1024) #define CONFIG_SPL_BSS_START_ADDR 0x00128000 #define CONFIG_SPL_BSS_MAX_SIZE 0x1000 /* 4 KB */
diff --git a/include/configs/imx8qxp_mek.h b/include/configs/imx8qxp_mek.h index 8eb6ab8552b8..abbcf9992569 100644 --- a/include/configs/imx8qxp_mek.h +++ b/include/configs/imx8qxp_mek.h @@ -11,7 +11,6 @@ #include <asm/arch/imx-regs.h>
#define CONFIG_SPL_STACK 0x013E000 diff --git a/include/configs/imx8ulp_evk.h b/include/configs/imx8ulp_evk.h index 66bf816ecf0e..92615dff4a72 100644 --- a/include/configs/imx8ulp_evk.h +++ b/include/configs/imx8ulp_evk.h @@ -10,7 +10,6 @@ #include <asm/arch/imx-regs.h>
#define CONFIG_SYS_BOOTM_LEN (SZ_64M) -#define CONFIG_SPL_MAX_SIZE (148 * 1024) #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_UBOOT_BASE (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
diff --git a/include/configs/iot2050.h b/include/configs/iot2050.h index 91ed76bb40b6..a5c1c36de358 100644 --- a/include/configs/iot2050.h +++ b/include/configs/iot2050.h @@ -17,8 +17,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SPL_TEXT_BASE + \ CONFIG_SYS_K3_NON_SECURE_MSRAM_SIZE)
/* U-Boot general configuration */ diff --git a/include/configs/j721e_evm.h b/include/configs/j721e_evm.h index 5538fee9460f..3ddd72e281fb 100644 --- a/include/configs/j721e_evm.h +++ b/include/configs/j721e_evm.h @@ -49,8 +49,6 @@ /* Image load address in RAM for DFU boot*/ #endif
/* HyperFlash related configuration */ diff --git a/include/configs/j721s2_evm.h b/include/configs/j721s2_evm.h index d0a78fd7cc89..32af9de30b65 100644 --- a/include/configs/j721s2_evm.h +++ b/include/configs/j721s2_evm.h @@ -50,8 +50,6 @@ /* Image load address in RAM for DFU boot*/ #endif
/* U-Boot general configuration */ diff --git a/include/configs/koelsch.h b/include/configs/koelsch.h index c0997aa3ddd5..8ab93ae353f2 100644 --- a/include/configs/koelsch.h +++ b/include/configs/koelsch.h @@ -35,6 +35,5 @@
#endif /* __KOELSCH_H */ diff --git a/include/configs/kontron-sl-mx8mm.h b/include/configs/kontron-sl-mx8mm.h index 1b429f7dbe22..795b8b62db5d 100644 --- a/include/configs/kontron-sl-mx8mm.h +++ b/include/configs/kontron-sl-mx8mm.h @@ -58,7 +58,6 @@ #endif
#define CONFIG_SYS_BOOTM_LEN SZ_64M -#define CONFIG_SPL_MAX_SIZE (148 * SZ_1K)
#ifdef CONFIG_SPL_BUILD #define CONFIG_SPL_STACK 0x91fff0 diff --git a/include/configs/kontron_pitx_imx8m.h b/include/configs/kontron_pitx_imx8m.h index e8e92920dcbc..2c17ea55a2a4 100644 --- a/include/configs/kontron_pitx_imx8m.h +++ b/include/configs/kontron_pitx_imx8m.h @@ -9,7 +9,6 @@
-#define CONFIG_SPL_MAX_SIZE (124 * SZ_1K) #define CONFIG_SYS_MONITOR_LEN (512 * SZ_1K)
/* GUID for capsule updatable firmware image */ diff --git a/include/configs/kontron_sl28.h b/include/configs/kontron_sl28.h index c47b5940fb29..25cb8f6f84f5 100644 --- a/include/configs/kontron_sl28.h +++ b/include/configs/kontron_sl28.h @@ -44,7 +44,6 @@ /* SPL */ #define CONFIG_SPL_BSS_START_ADDR 0x80100000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 -#define CONFIG_SPL_MAX_SIZE 0x20000 #define CONFIG_SPL_STACK (CONFIG_SYS_FSL_OCRAM_BASE + 0x9ff0)
#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00100000 diff --git a/include/configs/lager.h b/include/configs/lager.h index a5abbaaeab1f..ee37b2a6b338 100644 --- a/include/configs/lager.h +++ b/include/configs/lager.h @@ -36,6 +36,5 @@
#endif /* __LAGER_H */ diff --git a/include/configs/linkit-smart-7688.h b/include/configs/linkit-smart-7688.h index b0d77d1c6245..c0bc23ef2118 100644 --- a/include/configs/linkit-smart-7688.h +++ b/include/configs/linkit-smart-7688.h @@ -19,8 +19,6 @@ #define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SPL_BSS_START_ADDR 0x80010000 #define CONFIG_SPL_BSS_MAX_SIZE 0x10000 -#define CONFIG_SPL_MAX_SIZE 0x10000 -#define CONFIG_SPL_PAD_TO 0
/* Dummy value */ #define CONFIG_SYS_UBOOT_BASE 0 diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 82ae3492a2f2..f1e42a593f0a 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -42,9 +42,7 @@ #define SDRAM_CFG_BI 0x00000001
#ifdef CONFIG_SD_BOOT -#define CONFIG_SPL_MAX_SIZE 0x1a000 #define CONFIG_SPL_STACK 0x1001d000 -#define CONFIG_SPL_PAD_TO 0x1c000
#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_TEXT_BASE + \ CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 7b79e0841a5a..b655b7ea46cf 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -11,9 +11,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE OCRAM_SIZE
#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_TEXT_BASE + \ CONFIG_SYS_MONITOR_LEN) @@ -24,9 +22,7 @@ #endif
#ifdef CONFIG_NAND_BOOT -#define CONFIG_SPL_MAX_SIZE 0x1a000 #define CONFIG_SPL_STACK 0x1001d000 -#define CONFIG_SPL_PAD_TO 0x1c000
#define CONFIG_SYS_NAND_U_BOOT_SIZE (400 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ls1021atsn.h b/include/configs/ls1021atsn.h index 577ba6dfc046..d60701bcb987 100644 --- a/include/configs/ls1021atsn.h +++ b/include/configs/ls1021atsn.h @@ -44,9 +44,7 @@ #define CONFIG_U_BOOT_HDR_SIZE (16 << 10) #endif /* ifdef CONFIG_NXP_ESBC */
#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_TEXT_BASE + \ CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index b36c8dccf172..c573adf85dab 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -46,9 +46,7 @@ #define CONFIG_U_BOOT_HDR_SIZE (16 << 10) #endif /* ifdef CONFIG_NXP_ESBC */
#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_TEXT_BASE + \ CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 0b54c52b4f2e..a87494363acb 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -52,9 +52,7 @@ /* SD boot SPL */ #ifdef CONFIG_SD_BOOT
-#define CONFIG_SPL_MAX_SIZE 0x17000 #define CONFIG_SPL_STACK 0x1001e000 -#define CONFIG_SPL_PAD_TO 0x1d000
#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ CONFIG_SPL_BSS_MAX_SIZE) @@ -78,7 +76,6 @@
/* NAND SPL */ #ifdef CONFIG_NAND_BOOT -#define CONFIG_SPL_MAX_SIZE 0x1a000 #define CONFIG_SPL_STACK 0x1001d000 #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index b4329c2e89ef..8fd1af76f942 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -128,7 +128,6 @@ #endif
#ifdef CONFIG_NAND_BOOT -#define CONFIG_SPL_PAD_TO 0x20000 /* block aligned */ #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 << 10) #endif
diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 3ac4cb7643db..16815f4fb00a 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -101,7 +101,6 @@ #define CONFIG_MTD_NAND_VERIFY_WRITE
#ifdef CONFIG_NAND_BOOT -#define CONFIG_SPL_PAD_TO 0x20000 /* block aligned */ #define CONFIG_SYS_NAND_U_BOOT_SIZE (1024 << 10) #endif
diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 21830c0bda9e..ed43c12f4107 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -51,9 +51,7 @@
/* SD boot SPL */ #ifdef CONFIG_SD_BOOT -#define CONFIG_SPL_MAX_SIZE 0x1f000 /* 124 KiB */ #define CONFIG_SPL_STACK 0x10020000 -#define CONFIG_SPL_PAD_TO 0x21000 /* 132 KiB */ #define CONFIG_SPL_BSS_START_ADDR 0x8f000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ @@ -76,9 +74,7 @@
#if defined(CONFIG_QSPI_BOOT) && defined(CONFIG_SPL) #define CONFIG_SPL_TARGET "spl/u-boot-spl.pbl" -#define CONFIG_SPL_MAX_SIZE 0x1f000 #define CONFIG_SPL_STACK 0x10020000 -#define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SPL_BSS_START_ADDR 0x8f000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ @@ -89,7 +85,6 @@
/* NAND SPL */ #ifdef CONFIG_NAND_BOOT -#define CONFIG_SPL_MAX_SIZE 0x17000 /* 90 KiB */ #define CONFIG_SPL_STACK 0x1001f000 #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 05aeedc41073..124f279c48e2 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -145,7 +145,6 @@ #endif
#ifdef CONFIG_NAND_BOOT -#define CONFIG_SPL_PAD_TO 0x40000 /* block aligned */ #define CONFIG_SYS_NAND_U_BOOT_SIZE (768 << 10) #endif
diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 78d3d57eec3a..f03513279236 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -151,7 +151,6 @@ unsigned long long get_qixis_addr(void); #ifdef CONFIG_SPL #define CONFIG_SPL_BSS_START_ADDR 0x80100000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 -#define CONFIG_SPL_MAX_SIZE 0x16000 #define CONFIG_SPL_STACK (CONFIG_SYS_FSL_OCRAM_BASE + 0x9ff0) #define CONFIG_SPL_TARGET "u-boot-with-spl.bin"
diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 974e98ab1d07..e225c0721c37 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -144,7 +144,6 @@ unsigned long long get_qixis_addr(void);
diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 4975fb782b31..9ce48a09602e 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -191,7 +191,6 @@ #define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3
-#define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 * 1024) #endif #else diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 52a48bd4b891..cdfc9fd82e84 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -174,7 +174,6 @@ #define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3
-#define CONFIG_SPL_PAD_TO 0x80000 #define CONFIG_SYS_NAND_U_BOOT_SIZE (512 * 1024) #else #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 0e89dae7701c..d547dba322d5 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -114,7 +114,6 @@ * NAND SPL */ #define CONFIG_SPL_TARGET "u-boot-with-nand-spl.imx" -#define CONFIG_SPL_PAD_TO 0x8000 #define CONFIG_SPL_STACK 0x70004000
#define CONFIG_SYS_NAND_SIZE (256 * 1024 * 1024) diff --git a/include/configs/maxbcm.h b/include/configs/maxbcm.h index e4df9d8dfff3..86d7fc8feaa2 100644 --- a/include/configs/maxbcm.h +++ b/include/configs/maxbcm.h @@ -48,7 +48,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + (128 << 10)) #define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) diff --git a/include/configs/mt7620.h b/include/configs/mt7620.h index bcbc70b0945c..eae4d391e9d1 100644 --- a/include/configs/mt7620.h +++ b/include/configs/mt7620.h @@ -21,8 +21,6 @@ #define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SPL_BSS_START_ADDR 0x80010000 #define CONFIG_SPL_BSS_MAX_SIZE 0x10000 -#define CONFIG_SPL_MAX_SIZE 0x10000 -#define CONFIG_SPL_PAD_TO 0
/* Dummy value */ #define CONFIG_SYS_UBOOT_BASE 0 diff --git a/include/configs/mt7628.h b/include/configs/mt7628.h index efda683b4a79..c53b987ed194 100644 --- a/include/configs/mt7628.h +++ b/include/configs/mt7628.h @@ -33,8 +33,6 @@ #define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SPL_BSS_START_ADDR 0x80010000 #define CONFIG_SPL_BSS_MAX_SIZE 0x10000 -#define CONFIG_SPL_MAX_SIZE 0x10000 -#define CONFIG_SPL_PAD_TO 0
/* Dummy value */ #define CONFIG_SYS_UBOOT_BASE 0 diff --git a/include/configs/mt7629.h b/include/configs/mt7629.h index 24890b6f940b..e3ec2b90c09f 100644 --- a/include/configs/mt7629.h +++ b/include/configs/mt7629.h @@ -21,9 +21,7 @@
/* Defines for SPL */ #define CONFIG_SPL_STACK 0x106000 -#define CONFIG_SPL_MAX_SIZE SZ_64K #define CONFIG_SPL_MAX_FOOTPRINT SZ_64K -#define CONFIG_SPL_PAD_TO 0x10000
#define CONFIG_SPI_ADDR 0x30000000 #define CONFIG_SYS_UBOOT_BASE (CONFIG_SPI_ADDR + CONFIG_SPL_PAD_TO) diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index b7698c86454c..60f4302d82fe 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -177,7 +177,6 @@ #define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN #define CONFIG_SPL_STACK 0x8001ff00 #define CONFIG_SPL_MAX_FOOTPRINT 32768 -#define CONFIG_SPL_PAD_TO 32768
/* additions for new relocation code, must added to all boards */ #define CONFIG_SYS_SDRAM_BASE 0xc0000000 diff --git a/include/configs/openpiton-riscv64.h b/include/configs/openpiton-riscv64.h index f909aa862fdb..4901a00cdf65 100644 --- a/include/configs/openpiton-riscv64.h +++ b/include/configs/openpiton-riscv64.h @@ -19,7 +19,6 @@ #define CONFIG_SYS_BOOTM_LEN SZ_256M
#ifdef CONFIG_SPL -#define CONFIG_SPL_MAX_SIZE 0x00100000 #define CONFIG_SPL_BSS_START_ADDR 0x82000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index d2c8d23c31c0..755775f5568b 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -78,8 +78,6 @@
#ifdef CONFIG_SDCARD #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_PAD_TO 0x20000 -#define CONFIG_SPL_MAX_SIZE (128 * 1024) #define CONFIG_SYS_MMC_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_MMC_U_BOOT_DST (0x11000000) #define CONFIG_SYS_MMC_U_BOOT_START (0x11000000) @@ -91,8 +89,6 @@ #elif defined(CONFIG_SPIFLASH) #define CONFIG_SPL_SPI_FLASH_MINIMAL #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_PAD_TO 0x20000 -#define CONFIG_SPL_MAX_SIZE (128 * 1024) #define CONFIG_SYS_SPI_FLASH_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_SPI_FLASH_U_BOOT_DST (0x11000000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_START (0x11000000) @@ -105,14 +101,12 @@ #ifdef CONFIG_TPL_BUILD #define CONFIG_SPL_NAND_INIT #define CONFIG_SPL_COMMON_INIT_DDR -#define CONFIG_SPL_MAX_SIZE (128 << 10) #define CONFIG_SYS_MPC85XX_NO_RESETVEC #define CONFIG_SYS_NAND_U_BOOT_SIZE (832 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST (0x11000000) #define CONFIG_SYS_NAND_U_BOOT_START (0x11000000) #elif defined(CONFIG_SPL_BUILD) #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_MAX_SIZE 4096 #define CONFIG_SYS_NAND_U_BOOT_SIZE (128 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0xf8f80000 #define CONFIG_SYS_NAND_U_BOOT_START 0xf8f80000 @@ -122,8 +116,6 @@ #endif #endif /* not CONFIG_TPL_BUILD */
diff --git a/include/configs/phycore_imx8mm.h b/include/configs/phycore_imx8mm.h index 170d000827e8..94e0bec24b5b 100644 --- a/include/configs/phycore_imx8mm.h +++ b/include/configs/phycore_imx8mm.h @@ -12,7 +12,6 @@ #include <asm/arch/imx-regs.h>
#define CONFIG_SYS_BOOTM_LEN SZ_64M -#define CONFIG_SPL_MAX_SIZE (148 * SZ_1K) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/phycore_imx8mp.h b/include/configs/phycore_imx8mp.h index 545845f73380..1a7ac2ba972b 100644 --- a/include/configs/phycore_imx8mp.h +++ b/include/configs/phycore_imx8mp.h @@ -12,7 +12,6 @@
-#define CONFIG_SPL_MAX_SIZE (152 * SZ_1K) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/pico-imx8mq.h b/include/configs/pico-imx8mq.h index 11bb1ad28aca..12420abe09e6 100644 --- a/include/configs/pico-imx8mq.h +++ b/include/configs/pico-imx8mq.h @@ -9,7 +9,6 @@ #include <linux/sizes.h> #include <asm/arch/imx-regs.h>
#ifdef CONFIG_SPL_BUILD diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 0bcc2f35f5c3..6c9a68eec935 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -46,7 +46,6 @@ #endif
#define CONFIG_SYS_MONITOR_LEN 0x80000 diff --git a/include/configs/porter.h b/include/configs/porter.h index bf380ddf05b0..89fd0f2c6438 100644 --- a/include/configs/porter.h +++ b/include/configs/porter.h @@ -40,6 +40,5 @@
#endif /* __PORTER_H */ diff --git a/include/configs/px30_common.h b/include/configs/px30_common.h index eaaf8cad01c9..9b967b8d90f1 100644 --- a/include/configs/px30_common.h +++ b/include/configs/px30_common.h @@ -15,7 +15,6 @@
#define CONFIG_SYS_INIT_SP_ADDR 0x00400000 #define CONFIG_SPL_STACK 0x00400000 -#define CONFIG_SPL_MAX_SIZE 0x20000 #define CONFIG_SPL_BSS_START_ADDR 0x4000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x4000 #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */ diff --git a/include/configs/qemu-riscv.h b/include/configs/qemu-riscv.h index 618c3b63d41e..6bf8b70efd6d 100644 --- a/include/configs/qemu-riscv.h +++ b/include/configs/qemu-riscv.h @@ -10,7 +10,6 @@
#ifdef CONFIG_SPL
-#define CONFIG_SPL_MAX_SIZE 0x00100000 #define CONFIG_SPL_BSS_START_ADDR 0x84000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 #define CONFIG_SYS_SPL_MALLOC_START 0x84100000 diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index a0ba0c2ea78e..9aaefb8cd1b0 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -53,6 +53,5 @@ #define CONFIG_SPL_BSS_MAX_SIZE 0x1000 #endif #define CONFIG_SPL_STACK 0xe6304000 -#define CONFIG_SPL_MAX_SIZE 0x7000
#endif /* __RCAR_GEN3_COMMON_H */ diff --git a/include/configs/rk3066_common.h b/include/configs/rk3066_common.h index 30f037766dc7..e838f379d7e5 100644 --- a/include/configs/rk3066_common.h +++ b/include/configs/rk3066_common.h @@ -13,8 +13,6 @@
#define CONFIG_IRAM_BASE 0x10080000
-#define CONFIG_SPL_MAX_SIZE 0x32000 - #define CONFIG_SPL_STACK 0x1008FFFF
#define CONFIG_SYS_SDRAM_BASE 0x60000000 diff --git a/include/configs/rk3188_common.h b/include/configs/rk3188_common.h index 47f70f1aad43..77b23f1e2245 100644 --- a/include/configs/rk3188_common.h +++ b/include/configs/rk3188_common.h @@ -19,7 +19,6 @@ #define CONFIG_IRAM_BASE 0x10080000
/* spl size 32kb sram - 2kb bootrom */ -#define CONFIG_SPL_MAX_SIZE (0x8000 - 0x800)
#define CONFIG_SPL_STACK 0x10087fff
diff --git a/include/configs/rk322x_common.h b/include/configs/rk322x_common.h index c32e2236265a..f4668f08aec4 100644 --- a/include/configs/rk322x_common.h +++ b/include/configs/rk322x_common.h @@ -13,7 +13,6 @@ #define CONFIG_SYS_HZ_CLOCK 24000000
#define CONFIG_SYS_INIT_SP_ADDR 0x61100000 -#define CONFIG_SPL_MAX_SIZE 0x100000
#define CONFIG_ROCKCHIP_MAX_INIT_SIZE (28 << 10) #define CONFIG_ROCKCHIP_CHIP_TAG "RK32" diff --git a/include/configs/rk3308_common.h b/include/configs/rk3308_common.h index 3268181611f0..65a5d1da1f32 100644 --- a/include/configs/rk3308_common.h +++ b/include/configs/rk3308_common.h @@ -8,7 +8,6 @@
#include "rockchip-common.h"
-#define CONFIG_SPL_MAX_SIZE 0x20000 #define CONFIG_SPL_BSS_START_ADDR 0x00400000 #define CONFIG_SPL_BSS_MAX_SIZE 0x2000
diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index 283b644e4742..5ba34e8cd722 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -12,7 +12,6 @@
#define CONFIG_SYS_INIT_SP_ADDR 0x00300000 #define CONFIG_SPL_STACK 0x00400000 -#define CONFIG_SPL_MAX_SIZE 0x40000 #define CONFIG_SPL_BSS_START_ADDR 0x2000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x2000
diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index cd81caf98533..0561c2c1835d 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -18,7 +18,6 @@
-#define CONFIG_SPL_MAX_SIZE 0x40000 #define CONFIG_SPL_BSS_START_ADDR 0x400000 #define CONFIG_SPL_BSS_MAX_SIZE 0x20000 #define CONFIG_SPL_STACK 0x00188000 diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index d2f286521b50..32529cede10a 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -14,12 +14,10 @@
#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_TPL_BOOTROM_SUPPORT) #define CONFIG_SPL_STACK 0x00400000 -#define CONFIG_SPL_MAX_SIZE 0x40000 #define CONFIG_SPL_BSS_START_ADDR 0x00400000 #define CONFIG_SPL_BSS_MAX_SIZE 0x2000 #else #define CONFIG_SPL_STACK 0xff8effff -#define CONFIG_SPL_MAX_SIZE 0x30000 - 0x2000 /* BSS setup */ #define CONFIG_SPL_BSS_START_ADDR 0xff8e0000 #define CONFIG_SPL_BSS_MAX_SIZE 0x10000 diff --git a/include/configs/rk3568_common.h b/include/configs/rk3568_common.h index 0563d9025fcf..245e3039fd5b 100644 --- a/include/configs/rk3568_common.h +++ b/include/configs/rk3568_common.h @@ -13,7 +13,6 @@ #define CONFIG_SYS_INIT_SP_ADDR 0x00c00000
diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index 0c08776ae268..4c964cc37708 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -10,7 +10,6 @@ #define CONFIG_SYS_NS16550_MEM32
/* ((CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR - 64) * 512) */ -#define CONFIG_SPL_PAD_TO 8355840
#ifndef CONFIG_SPL_BUILD
diff --git a/include/configs/sama5d27_som1_ek.h b/include/configs/sama5d27_som1_ek.h index 1ac4f66a91c4..33435d2050cb 100644 --- a/include/configs/sama5d27_som1_ek.h +++ b/include/configs/sama5d27_som1_ek.h @@ -22,7 +22,6 @@ #endif
/* SPL */ -#define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 #define CONFIG_SYS_SPL_MALLOC_START 0x20080000 diff --git a/include/configs/sama5d27_wlsom1_ek.h b/include/configs/sama5d27_wlsom1_ek.h index a1c0e6a1eb63..e7a792ffe2ce 100644 --- a/include/configs/sama5d27_wlsom1_ek.h +++ b/include/configs/sama5d27_wlsom1_ek.h @@ -27,7 +27,6 @@ #endif
/* SPL */ -#define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 #define CONFIG_SYS_SPL_MALLOC_START 0x20080000 diff --git a/include/configs/sama5d2_icp.h b/include/configs/sama5d2_icp.h index 8cb80efe8e5b..5b7db47dc172 100644 --- a/include/configs/sama5d2_icp.h +++ b/include/configs/sama5d2_icp.h @@ -34,7 +34,6 @@ #endif
/* SPL */ -#define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 #define CONFIG_SYS_SPL_MALLOC_START 0x20080000 diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index c2fe118b5bcd..1b02fc14921d 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -19,7 +19,6 @@ #endif
/* SPL */ -#define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 #define CONFIG_SYS_SPL_MALLOC_START 0x20080000 diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index 1617ebc643da..6d25bd6012b5 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -56,7 +56,6 @@ #endif
/* SPL */ -#define CONFIG_SPL_MAX_SIZE 0x18000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 #define CONFIG_SYS_SPL_MALLOC_START 0x20080000 diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 94f4ae6a1f05..9fca00333078 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -68,7 +68,6 @@ #endif
/* SPL */ -#define CONFIG_SPL_MAX_SIZE 0x18000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 #define CONFIG_SYS_SPL_MALLOC_START 0x20080000 diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index 42a7ac402d22..5bc8744c1547 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -33,7 +33,6 @@ #endif
/* SPL */ -#define CONFIG_SPL_MAX_SIZE 0x18000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 #define CONFIG_SYS_SPL_MALLOC_START 0x20080000 diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index 6519956e09cf..08f042d6a263 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -33,7 +33,6 @@ #endif
/* SPL */ -#define CONFIG_SPL_MAX_SIZE 0x18000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 #define CONFIG_SYS_SPL_MALLOC_START 0x20080000 diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 22c6015e28a9..94596a8e4f43 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -53,8 +53,6 @@ /* I2C Configuration */
/* Defines for SPL */ -#define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ - CONFIG_SPL_TEXT_BASE)
#define CONFIG_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ diff --git a/include/configs/sifive-unleashed.h b/include/configs/sifive-unleashed.h index 920f3140f64f..71df8c405200 100644 --- a/include/configs/sifive-unleashed.h +++ b/include/configs/sifive-unleashed.h @@ -13,7 +13,6 @@
#ifdef CONFIG_SPL
-#define CONFIG_SPL_MAX_SIZE 0x00100000 #define CONFIG_SPL_BSS_START_ADDR 0x85000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ diff --git a/include/configs/sifive-unmatched.h b/include/configs/sifive-unmatched.h index 087764666bf6..f0530c7d9fc4 100644 --- a/include/configs/sifive-unmatched.h +++ b/include/configs/sifive-unmatched.h @@ -13,7 +13,6 @@
#ifdef CONFIG_SPL
-#define CONFIG_SPL_MAX_SIZE 0x00100000 #define CONFIG_SPL_BSS_START_ADDR 0x85000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ diff --git a/include/configs/silk.h b/include/configs/silk.h index 574ba228d8a1..a273f21b64c9 100644 --- a/include/configs/silk.h +++ b/include/configs/silk.h @@ -40,6 +40,5 @@
#endif /* __SILK_H */ diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index d58d76d10914..ffd2b214d7e0 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -117,7 +117,6 @@ #endif
/* Defines for SPL */ -#define CONFIG_SPL_MAX_SIZE (SZ_4K)
#define CONFIG_SPL_BSS_START_ADDR CONFIG_SYS_SDRAM_BASE #define CONFIG_SPL_BSS_MAX_SIZE (SZ_16K) @@ -144,7 +143,6 @@ #define CONFIG_SYS_MCKR_CSS (0x02 | CONFIG_SYS_MCKR) #define CONFIG_SYS_AT91_PLLB 0x10483f0e
#endif /* __CONFIG_H */ diff --git a/include/configs/sniper.h b/include/configs/sniper.h index e8a57faac528..631eefd3979e 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -50,8 +50,6 @@ * SPL */
-#define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ - CONFIG_SPL_TEXT_BASE) #define CONFIG_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SPL_BSS_MAX_SIZE (512 * 1024) #define CONFIG_SYS_SPL_MALLOC_START 0x80208000 diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 23467773ce34..6943dc04de23 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -14,10 +14,8 @@ #if defined(CONFIG_TARGET_SOCFPGA_GEN5) #define CONFIG_SYS_INIT_RAM_ADDR 0xFFFF0000 #define CONFIG_SYS_INIT_RAM_SIZE SOCFPGA_PHYS_OCRAM_SIZE -#define CONFIG_SPL_PAD_TO 0x10000 #elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) #define CONFIG_SYS_INIT_RAM_ADDR 0xFFE00000 -#define CONFIG_SPL_PAD_TO 0x40000 /* SPL memory allocation configuration, this is for FAT implementation */ #ifndef CONFIG_SYS_SPL_MALLOC_SIZE #define CONFIG_SYS_SPL_MALLOC_SIZE 0x10000 @@ -158,9 +156,6 @@ * 0xFFEz_zzzz ...... Malloc area (grows up to top) * 0xFFE3_FFFF ...... End of SRAM (top) */ -#ifndef CONFIG_SPL_TEXT_BASE -#define CONFIG_SPL_MAX_SIZE CONFIG_SYS_INIT_RAM_SIZE -#endif
/* SPL QSPI boot support */
diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index 750cc00f849f..ebbd9fc492e8 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -153,7 +153,6 @@ unsigned int cm_get_l4_sys_free_clk_hz(void); * */ #define CONFIG_SPL_TARGET "spl/u-boot-spl-dtb.hex" -#define CONFIG_SPL_MAX_SIZE CONFIG_SYS_INIT_RAM_SIZE #define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR #define CONFIG_SPL_BSS_MAX_SIZE 0x100000 /* 1 MB */ #define CONFIG_SPL_BSS_START_ADDR (PHYS_SDRAM_1 + PHYS_SDRAM_1_SIZE \ diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index 375f2a7e0ba5..261e4c8b5ad1 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -47,7 +47,6 @@ #define CONFIG_SYS_UBOOT_START 0x080083FD #define CONFIG_SYS_UBOOT_BASE (CONFIG_SYS_FLASH_BASE + \ CONFIG_SYS_SPL_LEN) -#define CONFIG_SPL_PAD_TO 0x8000
/* DT blob (fdt) address */ #define CONFIG_SYS_FDT_BASE (CONFIG_SYS_FLASH_BASE + \ diff --git a/include/configs/stout.h b/include/configs/stout.h index bcc6fcd36b30..d709c2109f15 100644 --- a/include/configs/stout.h +++ b/include/configs/stout.h @@ -44,6 +44,5 @@
#endif /* __STOUT_H */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index c47f4752fc42..c92427a4cc9a 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -115,7 +115,6 @@ * autoconf.mk. */ #if CONFIG_SUNXI_SRAM_ADDRESS == 0x10000 -#define CONFIG_SPL_MAX_SIZE 0x7fa0 /* 32 KiB */ #ifdef CONFIG_ARM64 /* end of SRAM A2 for now, as SRAM A1 is pretty tight for an ARM64 build */ #define LOW_LEVEL_SRAM_STACK 0x00054000 @@ -124,24 +123,17 @@ #endif /* !CONFIG_ARM64 */ #elif CONFIG_SUNXI_SRAM_ADDRESS == 0x20000 #ifdef CONFIG_MACH_SUN50I_H616 -#define CONFIG_SPL_MAX_SIZE 0xbfa0 /* 48 KiB */ #define LOW_LEVEL_SRAM_STACK 0x58000 #else -#define CONFIG_SPL_MAX_SIZE 0x7fa0 /* 32 KiB */ /* end of SRAM A2 on H6 for now */ #define LOW_LEVEL_SRAM_STACK 0x00118000 #endif #else -#define CONFIG_SPL_MAX_SIZE 0x5fa0 /* 24KB on sun4i/sun7i */ #define LOW_LEVEL_SRAM_STACK 0x00008000 /* End of sram */ #endif
#define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK
-#ifndef CONFIG_MACH_SUN50I_H616 -#define CONFIG_SPL_PAD_TO 32768 /* decimal for 'dd' */ -#endif - /* Ethernet support */
#ifdef CONFIG_USB_EHCI_HCD diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 768bfc6cc6c3..4e5f373cf9e5 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -142,7 +142,6 @@ #endif /* #ifndef CONFIG_SPL_BUILD */
/* Defines for SPL */ -#define CONFIG_SPL_MAX_SIZE (31 * SZ_512) #define CONFIG_SPL_STACK (ATMEL_BASE_SRAM1 + SZ_16K) #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_TEXT_BASE - \ CONFIG_SYS_MALLOC_LEN) @@ -170,7 +169,6 @@ #define CONFIG_SYS_MCKR_CSS (0x02 | CONFIG_SYS_MCKR) #define CONFIG_SYS_AT91_PLLB 0x10193F05
#endif diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index fdf048b27b3c..3add6fa5570e 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -73,7 +73,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + (128 << 10)) #define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 299eec75bdfe..a513d662e6a9 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -87,8 +87,6 @@ /* CPU */
#define CONFIG_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index ba3bc43aa0e7..fa5d91099e1a 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -64,7 +64,5 @@
/* SPL */ /* Defines for SPL */ -#define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ - CONFIG_SPL_TEXT_BASE)
#endif diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index a4fdc2de8b21..782b53f8c0cf 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -127,10 +127,6 @@ CONFIG_SPL_BSS_MAX_SIZE) #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_8M #endif -#ifndef CONFIG_SPL_MAX_SIZE -#define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ - CONFIG_SPL_TEXT_BASE) -#endif
#ifdef CONFIG_SPL_OS_BOOT /* FAT */ diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 57f013cbf846..564af6dc2dcf 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -27,8 +27,6 @@ #endif
/* SPL SPI Loader Configuration */ -#define CONFIG_SPL_PAD_TO 65536 -#define CONFIG_SPL_MAX_SIZE (CONFIG_SPL_PAD_TO - 8) #define CONFIG_SPL_BSS_START_ADDR (CONFIG_ISW_ENTRY_ADDR + \ CONFIG_SPL_MAX_SIZE) #define CONFIG_SPL_BSS_MAX_SIZE (32 * 1024) diff --git a/include/configs/turris_omnia.h b/include/configs/turris_omnia.h index 8119340b112f..b293ed41f549 100644 --- a/include/configs/turris_omnia.h +++ b/include/configs/turris_omnia.h @@ -28,7 +28,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) #define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index cbdb2d91bdad..99c8a0a7ac25 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -183,9 +183,6 @@
#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_MAX_FOOTPRINT 0x10000 -#define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_BSS_MAX_SIZE 0x2000
-#define CONFIG_SPL_PAD_TO 0x20000 - #endif /* __CONFIG_UNIPHIER_H__ */ diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index ccb7124371e8..927e46d7ccdd 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -9,7 +9,6 @@ #include <asm/arch/imx-regs.h> #include <linux/sizes.h>
-#define CONFIG_SPL_MAX_SIZE (148 * 1024) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/verdin-imx8mp.h b/include/configs/verdin-imx8mp.h index f2b49d03a9a6..6da86e9a3f7f 100644 --- a/include/configs/verdin-imx8mp.h +++ b/include/configs/verdin-imx8mp.h @@ -9,7 +9,6 @@ #include <asm/arch/imx-regs.h> #include <linux/sizes.h>
-#define CONFIG_SPL_MAX_SIZE (152 * 1024) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) diff --git a/include/configs/vocore2.h b/include/configs/vocore2.h index af792c78ee2c..45528503b01c 100644 --- a/include/configs/vocore2.h +++ b/include/configs/vocore2.h @@ -19,8 +19,6 @@ #define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SPL_BSS_START_ADDR 0x80010000 #define CONFIG_SPL_BSS_MAX_SIZE 0x10000 -#define CONFIG_SPL_MAX_SIZE 0x10000 -#define CONFIG_SPL_PAD_TO 0
/* Dummy value */ #define CONFIG_SYS_UBOOT_BASE 0 diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index 4d46ce024f16..d1515d98cd1c 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -67,7 +67,6 @@ /* Use the framework and generic lib */ /* SPL will use serial */ /* SPL will load U-Boot from NAND offset 0x40000 */ -#define CONFIG_SPL_PAD_TO 0x20000 /* U-Boot will be 0x40000 bytes, loaded and run at CONFIG_SYS_TEXT_BASE */ #define CONFIG_SYS_MONITOR_LEN 0x40000 /* actually, MAX size */ #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE diff --git a/include/configs/x530.h b/include/configs/x530.h index 67ff01db9041..d23b7b4d9245 100644 --- a/include/configs/x530.h +++ b/include/configs/x530.h @@ -68,7 +68,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) #define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 9fc7c44dbaad..7e60b16b7497 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -202,7 +202,6 @@ #endif
#define CONFIG_SPL_STACK 0xfffffffc -#define CONFIG_SPL_MAX_SIZE 0x40000
/* Just random location in OCM */ #define CONFIG_SPL_BSS_START_ADDR 0x0 diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index a93dbfb10295..d904dbd8d467 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -230,7 +230,6 @@ /* SP location before relocation, must use scratch RAM */
/* 3 * 64kB blocks of OCM - one is on the top because of bootrom */ -#define CONFIG_SPL_MAX_SIZE 0x30000
/* On the top of OCM space */ #define CONFIG_SYS_SPL_MALLOC_START CONFIG_SPL_STACK_R_ADDR diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index f047d4e09415..c1d32f587911 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -194,7 +194,7 @@ LDPPFLAGS += \
# Turn various CONFIG symbols into IMAGE symbols for easy reuse of # the scripts between SPL, TPL and VPL. -ifneq ($(CONFIG_$(SPL_TPL_)MAX_SIZE),) +ifneq ($(CONFIG_$(SPL_TPL_)MAX_SIZE),0x0) LDPPFLAGS += -DIMAGE_MAX_SIZE=$(CONFIG_$(SPL_TPL_)MAX_SIZE) endif ifneq ($(CONFIG_$(SPL_TPL_)TEXT_BASE),)
On Wed, May 18, 2022 at 07:47:44PM -0400, Tom Rini wrote:
This symbol is not used anywhere, remove it.
Signed-off-by: Tom Rini trini@konsulko.com
For the series, applied to u-boot/next, thanks!
