[U-Boot] [PATCH] net/phy: Add support for realtek RTL8211F
RTL8211F has different registers from RTL8211E. This patch adds support for RTL8211F PHY which can be found on Freescale's T1023 RDB board.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- drivers/net/phy/realtek.c | 84 +++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 84 insertions(+)
diff --git a/drivers/net/phy/realtek.c b/drivers/net/phy/realtek.c index a3ace68..fbb46f9 100644 --- a/drivers/net/phy/realtek.c +++ b/drivers/net/phy/realtek.c @@ -21,6 +21,17 @@ #define MIIM_RTL8211x_PHYSTAT_SPDDONE 0x0800 #define MIIM_RTL8211x_PHYSTAT_LINK 0x0400
+/* RTL8211F PHY Status Register */ +#define MIIM_RTL8211F_PHY_STATUS 0x1a +#define MIIM_RTL8211F_AUTONEG_ENABLE 0x1000 +#define MIIM_RTL8211F_PHYSTAT_SPEED 0x0030 +#define MIIM_RTL8211F_PHYSTAT_GBIT 0x0020 +#define MIIM_RTL8211F_PHYSTAT_100 0x0010 +#define MIIM_RTL8211F_PHYSTAT_DUPLEX 0x0008 +#define MIIM_RTL8211F_PHYSTAT_SPDDONE 0x0800 +#define MIIM_RTL8211F_PHYSTAT_LINK 0x0004 + +#define MIIM_RTL8211F_PAGE_SELECT 0x1f
/* RealTek RTL8211x */ static int rtl8211x_config(struct phy_device *phydev) @@ -89,6 +100,58 @@ static int rtl8211x_parse_status(struct phy_device *phydev) return 0; }
+static int rtl8211f_parse_status(struct phy_device *phydev) +{ + unsigned int speed; + unsigned int mii_reg; + int i = 0; + + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_RTL8211F_PAGE_SELECT, 0xa43); + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_RTL8211F_PHY_STATUS); + + phydev->link = 1; + while (!(mii_reg & MIIM_RTL8211F_PHYSTAT_LINK)) { + if (i > PHY_AUTONEGOTIATE_TIMEOUT) { + puts(" TIMEOUT !\n"); + phydev->link = 0; + break; + } + + if ((i++ % 1000) == 0) + putc('.'); + udelay(1000); + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, + MIIM_RTL8211F_PHY_STATUS); + } + + if (mii_reg & MIIM_RTL8211F_PHYSTAT_DUPLEX) + phydev->duplex = DUPLEX_FULL; + else + phydev->duplex = DUPLEX_HALF; + + speed = (mii_reg & MIIM_RTL8211F_PHYSTAT_SPEED); + + switch (speed) { + case MIIM_RTL8211F_PHYSTAT_GBIT: + phydev->speed = SPEED_1000; + break; + case MIIM_RTL8211F_PHYSTAT_100: + phydev->speed = SPEED_100; + break; + default: + phydev->speed = SPEED_10; + } + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII) { + /* enable TXDLY */ + phy_write(phydev, MDIO_DEVAD_NONE, + MIIM_RTL8211F_PAGE_SELECT, 0xd08); + phy_write(phydev, MDIO_DEVAD_NONE, 0x11, 0x109); + } + + return 0; +} + static int rtl8211x_startup(struct phy_device *phydev) { /* Read the Status (2x to make sure link is right) */ @@ -98,6 +161,15 @@ static int rtl8211x_startup(struct phy_device *phydev) return 0; }
+static int rtl8211f_startup(struct phy_device *phydev) +{ + /* Read the Status (2x to make sure link is right) */ + genphy_update_link(phydev); + rtl8211f_parse_status(phydev); + + return 0; +} + /* Support for RTL8211B PHY */ static struct phy_driver RTL8211B_driver = { .name = "RealTek RTL8211B", @@ -131,10 +203,22 @@ static struct phy_driver RTL8211DN_driver = { .shutdown = &genphy_shutdown, };
+/* Support for RTL8211F PHY */ +static struct phy_driver RTL8211F_driver = { + .name = "RealTek RTL8211F", + .uid = 0x1cc916, + .mask = 0xffffff, + .features = PHY_GBIT_FEATURES, + .config = &rtl8211x_config, + .startup = &rtl8211f_startup, + .shutdown = &genphy_shutdown, +}; + int phy_realtek_init(void) { phy_register(&RTL8211B_driver); phy_register(&RTL8211E_driver); + phy_register(&RTL8211F_driver); phy_register(&RTL8211DN_driver);
Hi Shengzhou Liu,
On Thu, Mar 12, 2015 at 5:54 AM, Shengzhou Liu Shengzhou.Liu@freescale.com wrote:
Please Cc me in the future.
Applied to u-boot-net/next, thanks! -Joe
Joe Hershberger
Shengzhou Liu
