[U-Boot] [RFC] export genphy_parse_link()
I'm porting a phy driver from Linux to u-boot and was able to use genphy_parse_link() without a problem. As mentioned in comment to genphy_parse_link(), the routine itself was taken from Linux kernel and many phy drivers are using this generic function.
Why wasn't it exported? Are there any issues?
Regards, Yegor
From c20576e3ddbf92e68837238a2aef9c6c83c6fea2 Mon Sep 17 00:00:00 2001
From: Yegor Yefremov yegorslists@googlemail.com Date: Mon, 26 Nov 2012 15:25:55 +0100 Subject: [PATCH] phy: export genphy_parse_link()
Signed-off-by: Yegor Yefremov yegorslists@googlemail.com --- drivers/net/phy/phy.c | 2 +- include/phy.h | 1 + 2 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index 1ffa791..c28ea70 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -279,7 +279,7 @@ int genphy_update_link(struct phy_device *phydev) * * Stolen from Linux's mii.c and phy_device.c */ -static int genphy_parse_link(struct phy_device *phydev) +int genphy_parse_link(struct phy_device *phydev) { int mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMSR);
diff --git a/include/phy.h b/include/phy.h index 3c30f11..1342ef7 100644 --- a/include/phy.h +++ b/include/phy.h @@ -209,6 +209,7 @@ int phy_register(struct phy_driver *drv); int genphy_config_aneg(struct phy_device *phydev); int genphy_restart_aneg(struct phy_device *phydev); int genphy_update_link(struct phy_device *phydev); +int genphy_parse_link(struct phy_device *phydev); int genphy_config(struct phy_device *phydev); int genphy_startup(struct phy_device *phydev); int genphy_shutdown(struct phy_device *phydev); -- 1.7.7
Dear Yegor Yefremov,
Ccing Joe ... do you have any consumer for this now exported function?
Best regards, Marek Vasut
Yes, I'm about to submit a phy driver for ICPlus phy and need this export. I tested it with both 100mbit and 1Gbit switches. In both cases phy reported the correct speed.
Yegor
On Tue, Nov 27, 2012 at 7:55 AM, Yegor Yefremov yegorslists@googlemail.com wrote:
I've sent a patch series: first patch is exporting the genphy_parse_link() the second is adding ICPlus driver.
Yegor
Yegor Yefremov
