[U-Boot] Boot rootfs from FIT Image
3 Jul
2019
3 Jul
'19
5:45 a.m.
HI,
I am using fitimage to load kernel dtb and rootfs. However the kernel and dtb files are getting loaded but the rootfs is loading from the /dev/mmcblk0p4 partition. I need to load the rootfs from FIT image and I don't know what should be the uboot command line args for this. What I have to pass to uboot so that the rootfs should be loaded from fit image? root="?" currently root=/dev/mmcblk0p4 Any help will be appreciable. Thanks in advance.
-- Sent from: http://u-boot.10912.n7.nabble.com/
2136
deepakpradhan
