[U-Boot] [PATCH] powerpc/mpc85xx: support application without resetvec segment in the linker script
For SD/SPI 2-stage bootloader, the On-Chip Rom code loads the SPL into L2 SRAM, then jump to it to begin execution. After that, the SPL loads the final uboot image into DDR, then jump to it to begin execution. The segment .resetvec in the SPL and in final U-boot is useless.
So, add new symbols CONFIG_SYS_MPC85XX_NO_RESETVEC for this application. If CONFIG_SYS_MPC85XX_NO_RESETVEC is set, the segment .resetvec is excluded and the segment .bootpg is placed in the previous 4K of the segment .text.
Signed-off-by: Ying Zhang b40530@freescale.com --- README | 5 +++++ arch/powerpc/cpu/mpc85xx/u-boot-spl.lds | 15 +++++++++++++++ arch/powerpc/cpu/mpc85xx/u-boot.lds | 8 ++++++++ 3 files changed, 28 insertions(+), 0 deletions(-)
diff --git a/README b/README index 0d37d56..d8a1198 100644 --- a/README +++ b/README @@ -3972,6 +3972,11 @@ Low Level (hardware related) configuration options: that is executed before the actual U-Boot. E.g. when compiling a NAND SPL.
+- CONFIG_SYS_MPC85XX_NO_RESETVEC + Only for 85xx systems. If this variable is specified, the section + .resetvec is not kept and the section .bootpg is placed in the + previous 4k of the .text section. + - CONFIG_ARCH_MAP_SYSMEM Generally U-Boot (and in particular the md command) uses effective address. It is therefore not necessary to regard diff --git a/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds b/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds index f2b7bff..dff2398 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds @@ -26,6 +26,13 @@ #include "config.h" /* CONFIG_BOARDDIR */
OUTPUT_ARCH(powerpc) +#ifdef CONFIG_SYS_MPC85XX_NO_RESETVEC +PHDRS +{ + text PT_LOAD; + bss PT_LOAD; +} +#endif SECTIONS { . = CONFIG_SPL_TEXT_BASE; @@ -68,9 +75,17 @@ SECTIONS #else #error unknown NAND controller #endif + +#ifdef CONFIG_SYS_MPC85XX_NO_RESETVEC + .bootpg ADDR(.text) - 0x1000 : + { + KEEP(*(.bootpg)) + } :text = 0xffff +#else .resetvec ADDR(.text) + RESET_VECTOR_OFFSET : { KEEP(*(.resetvec)) } = 0xffff +#endif
/* * Make sure that the bss segment isn't linked at 0x0, otherwise its diff --git a/arch/powerpc/cpu/mpc85xx/u-boot.lds b/arch/powerpc/cpu/mpc85xx/u-boot.lds index 0503dce..2643563 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot.lds @@ -95,6 +95,13 @@ SECTIONS . = ALIGN(256); __init_end = .;
+#ifdef CONFIG_SYS_MPC85XX_NO_RESETVEC + .bootpg ADDR(.text) - 0x1000 : + { + KEEP(arch/powerpc/cpu/mpc85xx/start.o (.bootpg)) + } :text = 0xffff + . = ADDR(.text) + 0x80000; +#else .bootpg RESET_VECTOR_ADDRESS - 0xffc : { arch/powerpc/cpu/mpc85xx/start.o (.bootpg) @@ -117,6 +124,7 @@ SECTIONS #if (RESET_VECTOR_ADDRESS == 0xfffffffc) . |= 0x10; #endif +#endif
__bss_start = .; .bss (NOLOAD) :
ying.zhang@freescale.com
