[U-Boot] [PATCH v2] common/Makefile: Add new symbol CONFIG_SPL_ENV_SUPPORT to replace CONFIG_SPL_NET_SUPPORT
There will need the environment in SPL for reasons other than network support (in particular, hwconfig contains info for how to set up DDR).
Add a new symbol CONFIG_SPL_ENV_SUPPORT to replace CONFIG_SPL_NET_SUPPORT in common/Makefile.
Signed-off-by: Ying Zhang b40530@freescale.com --- README | 3 +++ common/Makefile | 16 ++++++---------- include/configs/am335x_evm.h | 1 + include/configs/pcm051.h | 1 + 4 files changed, 11 insertions(+), 10 deletions(-)
diff --git a/README b/README index d8a1198..f38f375 100644 --- a/README +++ b/README @@ -2984,6 +2984,9 @@ FIT uImage format: CONFIG_SPL_LIBGENERIC_SUPPORT Support for lib/libgeneric.o in SPL binary
+ CONFIG_SPL_ENV_SUPPORT + Support for the environment operating in SPL binary + CONFIG_SPL_PAD_TO Image offset to which the SPL should be padded before appending the SPL payload. By default, this is defined as diff --git a/common/Makefile b/common/Makefile index 0e0fff1..1adae03 100644 --- a/common/Makefile +++ b/common/Makefile @@ -44,7 +44,6 @@ COBJS-$(CONFIG_SYS_GENERIC_BOARD) += board_r.o COBJS-y += cmd_boot.o COBJS-$(CONFIG_CMD_BOOTM) += cmd_bootm.o COBJS-y += cmd_help.o -COBJS-y += cmd_nvedit.o COBJS-y += cmd_version.o
# environment @@ -67,7 +66,6 @@ COBJS-$(CONFIG_ENV_IS_IN_ONENAND) += env_onenand.o COBJS-$(CONFIG_ENV_IS_IN_SPI_FLASH) += env_sf.o COBJS-$(CONFIG_ENV_IS_IN_REMOTE) += env_remote.o COBJS-$(CONFIG_ENV_IS_IN_UBI) += env_ubi.o -COBJS-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o
# command COBJS-$(CONFIG_CMD_AMBAPP) += cmd_ambapp.o @@ -214,18 +212,16 @@ COBJS-$(CONFIG_CMD_GPT) += cmd_gpt.o endif
ifdef CONFIG_SPL_BUILD -COBJS-y += cmd_nvedit.o -COBJS-y += env_common.o COBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o COBJS-$(CONFIG_SPL_YMODEM_SUPPORT) += xyzModem.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += cmd_nvedit.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_attr.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_callback.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_common.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_flags.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_nowhere.o COBJS-$(CONFIG_SPL_NET_SUPPORT) += miiphyutil.o +COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_common.o +COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_attr.o +COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_flags.o +COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_callback.o endif +COBJS-y += cmd_nvedit.o +COBJS-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o COBJS-$(CONFIG_BOUNCE_BUFFER) += bouncebuf.o COBJS-y += console.o COBJS-y += dlmalloc.o diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index ef00306..f47d3d1 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -325,6 +325,7 @@ #define CONFIG_SPL_GPIO_SUPPORT #define CONFIG_SPL_YMODEM_SUPPORT #define CONFIG_SPL_NET_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT #define CONFIG_SPL_NET_VCI_STRING "AM335x U-Boot SPL" #define CONFIG_SPL_ETH_SUPPORT #define CONFIG_SPL_SPI_SUPPORT diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index d0ea74e..926842f 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -224,6 +224,7 @@ #define CONFIG_SPL_GPIO_SUPPORT #define CONFIG_SPL_YMODEM_SUPPORT #define CONFIG_SPL_NET_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT #define CONFIG_SPL_NET_VCI_STRING "pcm051 U-Boot SPL" #define CONFIG_SPL_ETH_SUPPORT #define CONFIG_SPL_SPI_SUPPORT
[snip]
Just move the whole CONFIG_ENV_IS_IN.. section down to where we always build objects, and update the comments in the Makefile in both spots.
And a3m071 needs to be updated for CONFIG_SPL_ENV_SUPPORT too. Thanks!
-----Original Message----- From: Tom Rini [mailto:tom.rini@gmail.com] On Behalf Of Tom Rini Sent: Tuesday, May 14, 2013 6:13 AM To: Zhang Ying-B40530 Cc: u-boot@lists.denx.de; Wood Scott-B07421; Xie Xiaobo-R63061; Zhang Ying-B40530 Subject: Re: [U-Boot] [PATCH v2] common/Makefile: Add new symbol CONFIG_SPL_ENV_SUPPORT to replace CONFIG_SPL_NET_SUPPORT
[snip]
Just move the whole CONFIG_ENV_IS_IN.. section down to where we always build objects, and update the comments in the Makefile in both spots. [Zhang Ying] For common lines(for example: cmd_nvedit.o) that shared by the SPL and non-SPL, can we move it to public area? So, we can avoid excessive SPL symbols.
And a3m071 needs to be updated for CONFIG_SPL_ENV_SUPPORT too. Thanks! [Zhang Ying] In include/configs/a3m071.h, there was no CONFIG_SPL_NET_SUPPORT to be defined. Are you sure to add CONFIG_SPL_ENV_SUPPORT for it?
[snip]
Right. Re-order things so we're duplicating as little as possible. There's already a bit of needless duplication going on here.
Yes, it uses the environment as part of CONFIG_SPL_OS support rather than CONFIG_SPL_NET_SUPPORT.
endif
Right. Re-order things so we're duplicating as little as possible. There's already a bit of needless duplication going on here. [Zhang Ying] Ok, we had moved CONFIG_ENV_IS_IN.. section to public area in another patch just submitted :"move the common makefile line out of the CONFIG_SPL_BUILD ifdef". Please review.
Zhang Ying-B40530
