[U-Boot] patch to make u-boot work on jornada 720 flashrom - feedback wanted
Greetings,
I currently have blob working nicely on the flashboard in question, Ive been trying to create a patchset to get it working on u-boot. I basicly want feedback if this is enough or what else is needed. The code is heavily copied from assabet since they are similiar.
diff --git a/board/jornada/Makefile b/board/jornada/Makefile new file mode 100644 index 0000000..1b4e192 --- /dev/null +++ b/board/jornada/Makefile @@ -0,0 +1,53 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# 2004 (c) MontaVista Software, Inc. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := jornada.o +SOBJS := setup.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/jornada/config.mk b/board/jornada/config.mk new file mode 100644 index 0000000..c9d9109 --- /dev/null +++ b/board/jornada/config.mk @@ -0,0 +1,7 @@ +# +# SA-1110 based HP Jornada board +# +# The Intel Jornada 1 bank of 32 MiB SDRAM +# + +TEXT_BASE = 0xc1f00000 diff --git a/board/jornada/jornada.c b/board/jornada/jornada.c new file mode 100644 index 0000000..9c761e1 --- /dev/null +++ b/board/jornada/jornada.c @@ -0,0 +1,66 @@ +/* + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * 2004 (c) MontaVista Software, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <SA-1100.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ + +static inline u8 +readb(volatile u8 * p) +{ + return *p; +} + +static inline void +writeb(u8 v, volatile u8 * p) +{ + *p = v; +} + +static void jornada_init(void) +{ +} + +int board_init(void) +{ + gd->bd->bi_arch_number = MACH_TYPE_JORNADA; + gd->bd->bi_boot_params = 0xc0000100; + + jornada_init(); + + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return (0); +} diff --git a/board/jornada/setup.S b/board/jornada/setup.S new file mode 100644 index 0000000..598c83b --- /dev/null +++ b/board/jornada/setup.S @@ -0,0 +1,137 @@ +/* + * Memory Setup stuff - taken from blob memsetup.S + * + * Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) and + * Jan-Derk Bakker (J.D.Bakker@its.tudelft.nl) + * 2004 (c) MontaVista Software, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + + +#include "config.h" +#include "version.h" + + +/*----------------------------------------------------------------------- + * Board defines: + */ + +#define MDCNFG 0x00 +#define MDCAS00 0x04 +#define MDCAS01 0x08 +#define MDCAS02 0x0C +#define MSC0 0x10 +#define MSC1 0x14 +#define MECR 0x18 +#define MDREFR 0x1C +#define MDCAS20 0x20 +#define MDCAS21 0x24 +#define MDCAS22 0x28 +#define MSC2 0x2C +#define SMCNFG 0x30 + +#define JORNADA_BCR (0x12000000) +#define JORNADA_BCR_DB1110 (0x00a07490 | (0<<16) | (0<<17)) +#define JORNADA_SCR_nNEPONSET (1 << 9) +#define JORNADA_LEDS (0x10000010) + + +/*----------------------------------------------------------------------- + * Setup parameters for the board: + */ + + +MEM_BASE: .long 0xa0000000 +MEM_START: .long 0xc0000000 + +/* calculated from old blob bootloader */ +mdcnfg: .long 0x00007265 +mdcas00: .long 0x5555557f +mdcas01: .long 0x55555555 +mdcas02: .long 0x55555555 +msc0: .long 0xfff04f78 +msc1: .long 0xfff8fff0 +mecr: .long 0x98c698c6 +mdrefr: .long 0x04340327 +mdcas20: .long 0xd1284142 +mdcas21: .long 0x72249529 +mdcas22: .long 0x78414351 +msc2: .long 0x201d2959 +smcnfg: .long 0x00000000 + +BCR: .long ASSABET_BCR +BCR_DB1110: .long ASSABET_BCR_DB1110 +LEDS: .long NEPONSET_LEDS + + + .globl lowlevel_init +lowlevel_init: + + /* Setting up the memory and stuff */ + + ldr r0, MEM_BASE + ldr r1, mdcas00 + str r1, [r0, #MDCAS00] + ldr r1, mdcas01 + str r1, [r0, #MDCAS01] + ldr r1, mdcas02 + str r1, [r0, #MDCAS02] + ldr r1, mdcas20 + str r1, [r0, #MDCAS20] + ldr r1, mdcas21 + str r1, [r0, #MDCAS21] + ldr r1, mdcas22 + str r1, [r0, #MDCAS22] + ldr r1, mdrefr + str r1, [r0, #MDREFR] + ldr r1, mecr + str r1, [r0, #MECR] + ldr r1, msc0 + str r1, [r0, #MSC0] + ldr r1, msc1 + str r1, [r0, #MSC1] + ldr r1, msc2 + str r1, [r0, #MSC2] + ldr r1, smcnfg + str r1, [r0, #SMCNFG] + + ldr r1, mdcnfg + str r1, [r0, #MDCNFG] + + /* Load something to activate bank */ + ldr r2, MEM_START +.rept 8 + ldr r3, [r2] +.endr + + /* Enable SDRAM */ + orr r1, r1, #0x00000001 + str r1, [r0, #MDCNFG] + + ldr r1, BCR + ldr r2, BCR_DB1110 + str r2, [r1] + + ldr r1, LEDS + mov r0, #0x3 + str r0, [r1] + + /* All done... */ + mov pc, lr diff --git a/board/jornada/u-boot.lds b/board/jornada/u-boot.lds new file mode 100644 index 0000000..bd97436 --- /dev/null +++ b/board/jornada/u-boot.lds @@ -0,0 +1,58 @@ +/* + * (C) Copyright 2000-2004 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * 2004 (c) MontaVista Software, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/sa1100/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) . = ALIGN(4); } + _end = .; +} diff --git a/include/configs/jornada.h b/include/configs/jornada.h new file mode 100644 index 0000000..0a0766d --- /dev/null +++ b/include/configs/jornada.h @@ -0,0 +1,166 @@ +/* + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * 2004 (c) MontaVista Software, Inc. + * + * Configuation settings for the Intel Assabet board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + * (easy to change) + */ +#define CONFIG_SA1110 1 /* This is an SA1100 CPU */ +#define CONFIG_JORNADA700 1 /* on an HP Jornada 700 */ + +#undef CONFIG_USE_IRQ +/* we will never enable dcache, because we have to setup MMU first */ +#define CONFIG_SYS_NO_DCACHE + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size rsrvd for initial data */ + +/* + * select serial console configuration + */ +#define CONFIG_SA1100_SERIAL +#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on HP Jornada */ + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_BAUDRATE 59600 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP + + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_SUBNETMASK +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME +#define CONFIG_BOOTP_BOOTPATH + + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "console=ttySA0,115200n8 root=/dev/nfs ip=bootp" +#define CONFIG_BOOTCOMMAND "bootp;tftp;bootm" +#define CONFIG_SYS_AUTOLOAD "n" /* No autoload */ + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 59600 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "HP Jornada # " /* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_SYS_MEMTEST_START 0xc0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xc0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR 0xc0000000 /* default load address */ + +#define CONFIG_SYS_HZ 3686400 /* incrementer freq: 3.6864 MHz */ +#define CONFIG_SYS_CPUSPEED 0x0a /* set core clock to 206MHz */ + + /* valid baudrates */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of SDRAM */ +#define PHYS_SDRAM_1 0xc0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ + +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x02000000 /* 32 MB */ +#define PHYS_FLASH_BANK_SIZE 0x01000000 /* 16 MB Banks */ +#define PHYS_FLASH_SECT_SIZE 0x00040000 /* 256 KB sectors (x2) */ + +#define CONFIG_SYS_MONITOR_BASE TEXT_BASE +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 KB for Monitor */ + +#if CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_RAMSTART +#endif + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ + +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 +#define CONFIG_SYS_FLASH_SIZE PHYS_FLASH_SIZE +#define CONFIG_SYS_FLASH_CFI 1 /* flash is CFI conformant */ +#define CONFIG_FLASH_CFI_DRIVER 1 /* use common cfi driver */ +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max # of memory banks */ +#define CONFIG_SYS_FLASH_INCREMENT 0 /* there is only one bank */ +#define CONFIG_SYS_MAX_FLASH_SECT 128 /* max # of sectors on one chip */ +#undef CONFIG_SYS_FLASH_PROTECTION +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } + +#define CONFIG_ENV_IS_IN_FLASH 1 + +#if defined(CONFIG_ENV_IS_IN_FLASH) +#define CONFIG_ENV_IN_OWN_SECTOR 1 +#define CONFIG_ENV_ADDR (PHYS_FLASH_1 + PHYS_FLASH_SECT_SIZE) +#define CONFIG_ENV_SIZE PHYS_FLASH_SECT_SIZE +#define CONFIG_ENV_SECT_SIZE PHYS_FLASH_SECT_SIZE +#endif + +#endif /* __CONFIG_H */
Kristoffer Ericson
