[PATCH] Remove CROSS_COMPILE default from arch/*/config.mk
In order to support the compiler providing information used within Kconfig itself we cannot have the compiler be determined by arch/*/config.mk as we will not be able to evaluate that yet. Given that most documentation tells people to specify CROSS_COMPILE, remove these references.
Cc: Huan Wang alison.wang@nxp.com Cc: Angelo Dureghello angelo@sysam.it Cc: Michal Simek monstr@monstr.eu Cc: Rick Chen rick@andestech.com Cc: Thomas Chou thomas@wytron.com.tw Cc: Wolfgang Denk wd@denx.de Cc: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Max Filippov jcmvbkbc@gmail.com Signed-off-by: Tom Rini trini@konsulko.com --- arch/m68k/config.mk | 4 ---- arch/microblaze/config.mk | 4 ---- arch/nds32/config.mk | 4 ---- arch/nios2/config.mk | 4 ---- arch/powerpc/config.mk | 4 ---- arch/sh/config.mk | 4 ---- arch/x86/cpu/config.mk | 2 -- arch/xtensa/config.mk | 1 - 8 files changed, 27 deletions(-)
diff --git a/arch/m68k/config.mk b/arch/m68k/config.mk index 88b1a409f260..ed592334af2e 100644 --- a/arch/m68k/config.mk +++ b/arch/m68k/config.mk @@ -3,10 +3,6 @@ # (C) Copyright 2000-2002 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifeq ($(CROSS_COMPILE),) -CROSS_COMPILE := m68k-elf- -endif - CONFIG_STANDALONE_LOAD_ADDR ?= 0x20000
PLATFORM_CPPFLAGS += -D__M68K__ diff --git a/arch/microblaze/config.mk b/arch/microblaze/config.mk index 3c5866a29528..96c39b1278b1 100644 --- a/arch/microblaze/config.mk +++ b/arch/microblaze/config.mk @@ -6,10 +6,6 @@ # (C) Copyright 2004 Atmark Techno, Inc. # Yasushi SHOJI yashi@atmark-techno.com
-ifeq ($(CROSS_COMPILE),) -CROSS_COMPILE := mb- -endif - CONFIG_STANDALONE_LOAD_ADDR ?= 0x80F00000
PLATFORM_CPPFLAGS += -ffixed-r31 -D__microblaze__ diff --git a/arch/nds32/config.mk b/arch/nds32/config.mk index a1c3371ddcfd..c82dd69c6c30 100644 --- a/arch/nds32/config.mk +++ b/arch/nds32/config.mk @@ -8,10 +8,6 @@ # Macpaul Lin, Andes Technology Corporation macpaul@andestech.com #
-ifeq ($(CROSS_COMPILE),) -CROSS_COMPILE := nds32le-linux- -endif - CONFIG_STANDALONE_LOAD_ADDR = 0x300000 LDFLAGS_STANDALONE += -T $(srctree)/examples/standalone/nds32.lds
diff --git a/arch/nios2/config.mk b/arch/nios2/config.mk index c63d170eaee6..44260b1431cb 100644 --- a/arch/nios2/config.mk +++ b/arch/nios2/config.mk @@ -4,10 +4,6 @@ # Psyent Corporation <www.psyent.com> # Scott McNutt smcnutt@psyent.com
-ifeq ($(CROSS_COMPILE),) -CROSS_COMPILE := nios2-elf- -endif - CONFIG_STANDALONE_LOAD_ADDR ?= 0x02000000
PLATFORM_CPPFLAGS += -D__NIOS2__ diff --git a/arch/powerpc/config.mk b/arch/powerpc/config.mk index 88e2c58cb44a..307ca65745c8 100644 --- a/arch/powerpc/config.mk +++ b/arch/powerpc/config.mk @@ -3,10 +3,6 @@ # (C) Copyright 2000-2010 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifeq ($(CROSS_COMPILE),) -CROSS_COMPILE := ppc_8xx- -endif - CONFIG_STANDALONE_LOAD_ADDR ?= 0x40000 LDFLAGS_FINAL += --gc-sections LDFLAGS_FINAL += --bss-plt diff --git a/arch/sh/config.mk b/arch/sh/config.mk index 6ef44638abd0..4cdde807245f 100644 --- a/arch/sh/config.mk +++ b/arch/sh/config.mk @@ -3,10 +3,6 @@ # (C) Copyright 2000-2002 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifeq ($(CROSS_COMPILE),) -CROSS_COMPILE := sh4-linux- -endif - CONFIG_STANDALONE_LOAD_ADDR ?= 0x8C000000 ifeq ($(CPU),sh2) LDFLAGS_STANDALONE += -EB diff --git a/arch/x86/cpu/config.mk b/arch/x86/cpu/config.mk index 8f9814c0ae7d..d3033b416034 100644 --- a/arch/x86/cpu/config.mk +++ b/arch/x86/cpu/config.mk @@ -3,8 +3,6 @@ # (C) Copyright 2002 # Daniel Engström, Omicron Ceti AB, daniel@omicron.se.
-CROSS_COMPILE ?= i386-linux- - # DO NOT MODIFY THE FOLLOWING UNLESS YOU REALLY KNOW WHAT YOU ARE DOING! LDPPFLAGS += -DRESET_SEG_START=$(CONFIG_RESET_SEG_START) LDPPFLAGS += -DRESET_VEC_LOC=$(CONFIG_RESET_VEC_LOC) diff --git a/arch/xtensa/config.mk b/arch/xtensa/config.mk index ec3710786290..b0809999e403 100644 --- a/arch/xtensa/config.mk +++ b/arch/xtensa/config.mk @@ -3,7 +3,6 @@ # (C) Copyright 2007 - 2013 Tensilica, Inc. # (C) Copyright 2014 - 2016 Cadence Design Systems Inc.
-CROSS_COMPILE ?= xtensa-linux- PLATFORM_CPPFLAGS += -D__XTENSA__ -mlongcalls -mforce-no-pic \ -ffunction-sections -fdata-sections
none is really using it anyway.
Acked-by: Michal Simek michal.simek@xilinx.com
Thanks, Michal
Cc: Huan Wang alison.wang@nxp.com Cc: Angelo Dureghello angelo@sysam.it Cc: Michal Simek monstr@monstr.eu Cc: Rick Chen rick@andestech.com Cc: Thomas Chou thomas@wytron.com.tw Cc: Wolfgang Denk wd@denx.de Cc: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Max Filippov jcmvbkbc@gmail.com Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org Acked-by: Michal Simek michal.simek@xilinx.com
Michal Simek
