[U-Boot] Merge conflict on Tegra SPI between u-boot/master and u-boot-arm/master
Hello all,
While preparing for an ARM PR, specifically a merge between commit 417c55803118eb8e350d5ab8ba6583fb39f4e2e3 (current u-boot/master ToT) and commit d53e340edf65ff253d3a7b06ebe60501045892e3 (current Tot for u-boot-arm/master), I hit the following merge conflicts:
CONFLICT (content): Merge conflict in lib/fdtdec.c CONFLICT (content): Merge conflict in include/fdtdec.h CONFLICT (content): Merge conflict in drivers/spi/tegra20_sflash.c
While the first two, related to FDT, are simple (colliding additions to the same enum from both branches) and can be manually resolved, the third one, drivers/spi/tegra20_sflash.c, is not, and can not, at least, not by me, as I am not a specialist on Tegra SPI.
Tom (Warren), can you advise on how to best solve this?
Amicalement,
Albert,
On Thu, Mar 28, 2013 at 6:38 AM, Albert ARIBAUD albert.u.boot@aribaud.netwrote:
Hello all,
Let me take a look - IIRC, Simon's use of spi_alloc_slave() was the only change to tegra20_sflash.c (replaces the normal malloc() in tegra20_spi_setup_slave()).
Here's a diff of the only change to tegra20_sflash.c (merging Allen's Tegra SPI changes and Simon's SPI changes):
--- drivers/spi/tegra20_sflash.c 2013-03-22 08:43:02.373219315 -0700 +++ /home/tom/denx/u-boot-arm/drivers/spi/tegra20_sflash.c 2013-03-28 08:04:04.899860607 -0700 @@ -127,7 +127,7 @@ return NULL; }
- spi = spi_alloc_slave(struct tegra_spi_slave, bus, cs); + spi = malloc(sizeof(struct tegra_spi_slave)); if (!spi) { printf("SPI error: malloc of SPI structure failed\n"); return NULL;
Let me know if that's not enough for you to resolve this,
Tom
Amicalement,
Albert.
Albert,
On Thu, Mar 28, 2013 at 8:08 AM, Tom Warren twarren.nvidia@gmail.comwrote:
Albert,
On Thu, Mar 28, 2013 at 6:38 AM, Albert ARIBAUD <albert.u.boot@aribaud.net
wrote:
Hello all,
- spi = malloc(sizeof(struct tegra_spi_slave)); if (!spi) { printf("SPI error: malloc of SPI structure failed\n"); return NULL;
Tom
Just confirmed - in tegra20_sflash.c, remove the <<<<< HEAD section (#ifdef CONFIG_OF_CONTROL + 2 lines), and keep the "tegra: spi remove non fdt support" section (spi->slave.bus = bus + 4 lines).
Tom
Amicalement,
Albert.
Hi Tom,
Ok, thanks a lot for confirming. I'll do the merge (and tests) accordingly on u-boot-arm and then send out my PR to The Other Tom.
Amicalement,
Albert ARIBAUD
Tom Warren
