Provide a man-page for the imxtract command.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- doc/usage/cmd/imxtract.rst | 81 ++++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 2 files changed, 82 insertions(+) create mode 100644 doc/usage/cmd/imxtract.rst
diff --git a/doc/usage/cmd/imxtract.rst b/doc/usage/cmd/imxtract.rst new file mode 100644 index 0000000000..eb64b1cefa --- /dev/null +++ b/doc/usage/cmd/imxtract.rst @@ -0,0 +1,81 @@ +.. SPDX-License-Identifier: GPL-2.0+: + +imxtract command +================ + +Synopsis +-------- + +:: + + imxtract addr part [dest] + imxtract addr uname [dest] + +Description +----------- + +The imxtract command is used to extract a part of a multi-image file. + +Two different file formats are supported: + +* FIT images +* legacy U-Boot images + +addr + Address of the multi-image file from which a part shall be extracted + +part + Index (hexadecimal) of the part of a legacy U-Boot image to be extracted + +uname + Name of the part of a FIT image to be extracted + +dest + Destination address (defaults to 0x0) + +The value of environment variable *verify* controls if the hashes and +signatures of FIT images or the check sums of legacy U-Boot images are checked. +To enable checking set *verify* to one of the values *1*, *yes*, *true*. +(Actually only the first letter is checked disregarding the case.) + +To list the parts of an image the *iminfo* command can be used. + +Examples +-------- + +With verify=no incorrect hashes, signatures, or check sums don't stop the +extraction. But correct hashes are still indicated in the output +(here: md5, sha1). + +.. code-block:: console + + => setenv verify no + => imxtract $loadaddr kernel-1 $kernel_addr_r + ## Copying 'kernel-1' subimage from FIT image at 40200000 ... + md5+ sha1+ Loading part 0 ... OK + => + +With verify=yes incorrect hashes, signatures, or check sums stop the extraction. + +.. code-block:: console + + => setenv verify yes + => imxtract $loadaddr kernel-1 $kernel_addr_r + ## Copying 'kernel-1' subimage from FIT image at 40200000 ... + md5 error! + Bad hash value for 'hash-1' hash node in 'kernel-1' image node + Bad Data Hash + => + +Configuration +------------- + +The imxtract command is only available if CONFIG_CMD_XIMG=y. Support for FIT +images requires CONFIG_FIT=y. Support for legacy U-Boot images requires +CONFIG_LEGACY_IMAGE_FORMAT=y. + +Return value +------------ + +On success the return value $? of the command is 0 (true). On failure the +return value is 1 (false). diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 84ef8a9a42..54ef89edb2 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -62,6 +62,7 @@ Shell commands cmd/fwu_mdata cmd/gpio cmd/host + cmd/imxtract cmd/load cmd/loadb cmd/loadm
