[PATCH v2] cmd: sf/nand: Print and return failure when 0 length is passed
For sf commands, when '0' length is passed for erase, update, write or read, there might be undesired results. Ideally '0' length means nothing to do.
So print 'ERROR: Invalid size 0' and return cmd failure when length '0' is passed to sf commands. Same thing applies for nand commands also.
Example:
ZynqMP> sf erase 0 0 ERROR: Invalid size 0 ZynqMP> sf write 10000 0 0 ERROR: Invalid size 0 ZynqMP> sf read 10000 0 0 ERROR: Invalid size 0 ZynqMP> sf update 1000 10000 0 ERROR: Invalid size 0 ZynqMP>
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@amd.com ---
Changes in v2: - Changed print from 'size is 0' to Invalid size 0 without quites. - Modified description to be imperative - Fixed typo in description from "samething" to "same thing"
cmd/legacy-mtd-utils.c | 5 +++++ cmd/sf.c | 5 +++++ 2 files changed, 10 insertions(+)
diff --git a/cmd/legacy-mtd-utils.c b/cmd/legacy-mtd-utils.c index ac7139f84d..61987918a4 100644 --- a/cmd/legacy-mtd-utils.c +++ b/cmd/legacy-mtd-utils.c @@ -88,6 +88,11 @@ int mtd_arg_off_size(int argc, char *const argv[], int *idx, loff_t *off, return -1; }
+ if (*size == 0) { + printf("ERROR: Invalid size 0\n"); + return -1; + } + print: printf("device %d ", *idx); if (*size == chipsize) diff --git a/cmd/sf.c b/cmd/sf.c index 11b9c25896..a6aadc2b00 100644 --- a/cmd/sf.c +++ b/cmd/sf.c @@ -353,6 +353,11 @@ static int do_spi_flash_erase(int argc, char *const argv[]) if (ret != 1) return CMD_RET_USAGE;
+ if (size == 0) { + printf("ERROR: Invalid size 0\n"); + return CMD_RET_FAILURE; + } + /* Consistency checking */ if (offset + size > flash->size) { printf("ERROR: attempting %s past flash size (%#x)\n",
Example:
Changes in v2:
- if (*size == 0) {
return -1;
- print: printf("device %d ", *idx); if (*size == chipsize)
- if (size == 0) {
- /* Consistency checking */ if (offset + size > flash->size) { printf("ERROR: attempting %s past flash size (%#x)\n",
Acked-by: Michal Simek michal.simek@amd.com
Thanks, Michal
On Wed, Apr 12, 2023 at 1:22 PM Ashok Reddy Soma ashok.reddy.soma@amd.com wrote:
Example:
Changes in v2:
if (*size == 0) {
return -1;
if (size == 0) {
I feel it is too verbose and if erase happened it shows the log otherwise it shows nothing, and that is enough.
Jagan.
Ashok Reddy Soma
Jagan Teki
Michal Simek
