[U-Boot] [PATCH v2 1/1] efi_loader: initalize EFI object list only once
If several EFI applications are executed in sequence we want to keep the content of the EFI object list.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2 Rebase based on efi-next 8787b02e32dc --- cmd/bootefi.c | 61 ++++++++++++++++++++++++++++++++++------------------------- 1 file changed, 35 insertions(+), 26 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index e9f14d54af..cf717564c4 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -20,6 +20,8 @@
DECLARE_GLOBAL_DATA_PTR;
+static uint8_t efi_obj_list_initalized; + /* * When booting using the "bootefi" command, we don't know which * physical device the file came from. So we create a pseudo-device @@ -104,6 +106,37 @@ static struct efi_object bootefi_device_obj = { }, };
+/* Initialize and populate EFI object list */ +static void efi_init_obj_list(void) +{ + efi_obj_list_initalized = 1; + list_add_tail(&loaded_image_info_obj.link, &efi_obj_list); + list_add_tail(&bootefi_device_obj.link, &efi_obj_list); + efi_console_register(); +#ifdef CONFIG_PARTITIONS + efi_disk_register(); +#endif +#ifdef CONFIG_LCD + efi_gop_register(); +#endif +#ifdef CONFIG_NET + void *nethandle = loaded_image_info.device_handle; + efi_net_register(&nethandle); + + if (!memcmp(bootefi_device_path[0].str, "N\0e\0t", 6)) + loaded_image_info.device_handle = nethandle; + else + loaded_image_info.device_handle = bootefi_device_path; +#endif +#ifdef CONFIG_GENERATE_SMBIOS_TABLE + efi_smbios_register(); +#endif + + /* Initialize EFI runtime services */ + efi_reset_system_init(); + efi_get_time_init(); +} + static void *copy_fdt(void *fdt) { u64 fdt_size = fdt_totalsize(fdt); @@ -223,32 +256,8 @@ static unsigned long do_bootefi_exec(void *efi, void *fdt) return -ENOENT;
/* Initialize and populate EFI object list */ - INIT_LIST_HEAD(&efi_obj_list); - list_add_tail(&loaded_image_info_obj.link, &efi_obj_list); - list_add_tail(&bootefi_device_obj.link, &efi_obj_list); - efi_console_register(); -#ifdef CONFIG_PARTITIONS - efi_disk_register(); -#endif -#ifdef CONFIG_LCD - efi_gop_register(); -#endif -#ifdef CONFIG_NET - void *nethandle = loaded_image_info.device_handle; - efi_net_register(&nethandle); - - if (!memcmp(bootefi_device_path[0].str, "N\0e\0t", 6)) - loaded_image_info.device_handle = nethandle; - else - loaded_image_info.device_handle = bootefi_device_path; -#endif -#ifdef CONFIG_GENERATE_SMBIOS_TABLE - efi_smbios_register(); -#endif - - /* Initialize EFI runtime services */ - efi_reset_system_init(); - efi_get_time_init(); + if (!efi_obj_list_initalized) + efi_init_obj_list();
/* Call our payload! */ debug("%s:%d Jumping to 0x%lx\n", __func__, __LINE__, (long)entry);
Heinrich@lists.denx.de
