[U-Boot-Users] broken changes @ MPC83xx
Kim,
after being back from holiday and pulling the lates u-boot today (v1.3.3) my MPC8343 based board (mvBL-M7) doesn't work any longer. Not a single character is put out on serial - yet build is not complaining about anything and System.map looks quite normal.
Any ideas what commit can cause this ?
Am I missing any #defines introduced lately ?
regards, Andre
MATRIX VISION GmbH, Talstraße 16, DE-71570 Oppenweiler - Registergericht: Amtsgericht Stuttgart, HRB 271090 Geschäftsführer: Gerhard Thullner, Werner Armingeon, Uwe Furtner
Hi Andre,
I had a similar problem a while back.
Adding the new define:
#define CONFIG_HIGH_BATS 1 /* High BATs supported */
To my config solved the problem.
/Tor
On 6/23/2008, "Andre Schwarz" andre.schwarz@matrix-vision.de wrote:
Kim,
regards, Andre
Check out the new SourceForge.net Marketplace. It's the best place to buy or sell services for just about anything Open Source. http://sourceforge.net/services/buy/index.php _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
gotcha - that's it !
It's _really_ hard to keep things working these days ...
many thanks, Andre
Tor Krill schrieb:
Hi Andre,
/Tor
Kim,
regards, Andre
MATRIX VISION GmbH, Talstra�e 16, DE-71570 Oppenweiler - Registergericht: Amtsgericht Stuttgart, HRB 271090 Gesch�ftsf�hrer: Gerhard Thullner, Werner Armingeon, Uwe Furtner
Add missing #define CONFIG_HIGH_BATS in mvBL-M7 board config file. Add default MAC to enable netboot during production.
Signed-off-by: Andre Schwarz andre.schwarz@matrix-vision.de ---
include/configs/MVBLM7.h | 5 ++++- 1 files changed, 4 insertions(+), 1 deletions(-)
diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index 349ca14..8c0e8b6 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -27,7 +27,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define MV_VERSION "v1.0.1" +#define MV_VERSION "v1.0.2"
/* * High Level Configuration Options @@ -215,6 +215,7 @@ #define CONFIG_TSEC2
#define CONFIG_HAS_ETH0 +#define CONFIG_ETHADDR b6:b4:45:eb:fb:c0 #define CONFIG_TSEC1_NAME "TSEC0" #define CONFIG_FEC1_PHY_NORXERR #define CFG_TSEC1_OFFSET 0x24000 @@ -224,6 +225,7 @@ #define TSEC1_FLAGS (TSEC_GIGABIT|TSEC_REDUCED)
#define CONFIG_HAS_ETH1 +#define CONFIG_ETH1ADDR b6:b4:45:eb:fb:c2 #define CONFIG_TSEC2_NAME "TSEC1" #define CONFIG_FEC2_PHY_NORXERR #define CFG_TSEC2_OFFSET 0x25000 @@ -336,6 +338,7 @@ #define CFG_HID0_FINAL CFG_HID0_INIT
#define CFG_HID2 HID2_HBE +#define CONFIG_HIGH_BATS 1
/* DDR */ #define CFG_IBAT0L (CFG_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE)
On Mon, 23 Jun 2008 13:25:34 +0200 Andre Schwarz andre.schwarz@matrix-vision.de wrote:
Hello Andre,
instead of incrementing this for each patch, can we just use U_BOOT_VERSION instead?
I had removed this from your original board port because this goes against recommended practice; see:
http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/41178
this line applied.
Kim
Kim,
thanks - ok.
Switching to U_BOOT_VERSION should be no problem.
regards, André
Hello Andre,
this line applied.
Kim
Andre Schwarz
André Schwarz
Kim Phillips
Tor Krill
