[PATCH 1/4] ARM: rmobile: Sort R-Car Gen3 Kconfig lists
Sort the 'imply' and 'select' lists in R-Car Gen3 Kconfig options. No functional change.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- arch/arm/mach-rmobile/Kconfig | 10 +++++----- arch/arm/mach-rmobile/Kconfig.64 | 22 +++++++++++----------- 2 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/arch/arm/mach-rmobile/Kconfig b/arch/arm/mach-rmobile/Kconfig index 0e9c0fa9962..9ff45f46313 100644 --- a/arch/arm/mach-rmobile/Kconfig +++ b/arch/arm/mach-rmobile/Kconfig @@ -11,19 +11,18 @@ config RCAR_32 config RCAR_GEN3 bool "Renesas ARM SoCs R-Car Gen3 (64bit)" select ARM64 - select PHY select CMD_CACHE select OF_BOARD_SETUP - select PINCTRL + select PHY select PINCONF + select PINCTRL select PINCTRL_PFC select POSITION_INDEPENDENT select SUPPORT_SPL imply CMD_FS_UUID imply CMD_GPT - imply CMD_UUID imply CMD_MMC_SWRITE if MMC - imply SUPPORT_EMMC_RPMB if MMC + imply CMD_UUID imply SPL imply SPL_BOARD_INIT imply SPL_GZIP @@ -32,8 +31,9 @@ config RCAR_GEN3 imply SPL_SERIAL imply SPL_SYS_MALLOC_SIMPLE imply SPL_TINY_MEMSET - imply SPL_YMODEM_SUPPORT imply SPL_USE_TINY_PRINTF + imply SPL_YMODEM_SUPPORT + imply SUPPORT_EMMC_RPMB if MMC
config RZA1 prompt "Renesas ARM SoCs RZ/A1 (32bit)" diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 554130b435b..33fd776f8af 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -87,17 +87,17 @@ choice
config TARGET_BEACON_RZG2M bool "Beacon EmbeddedWorks RZ/G2 Dev Kit" + select PINCTRL_PFC_R8A774A1 + select PINCTRL_PFC_R8A774B1 + select PINCTRL_PFC_R8A774E1 select R8A774A1 select R8A774B1 select R8A774E1 select RZ_G2 - select PINCTRL_PFC_R8A774A1 - select PINCTRL_PFC_R8A774B1 - select PINCTRL_PFC_R8A774E1 + imply CLK_CCF + imply CLK_VERSACLOCK imply MULTI_DTB_FIT imply MULTI_DTB_FIT_USER_DEFINED_AREA - imply CLK_VERSACLOCK - imply CLK_CCF
config TARGET_CONDOR bool "Condor board" @@ -131,13 +131,13 @@ config TARGET_FALCON
config TARGET_HIHOPE_RZG2 bool "HiHope RZ/G2 board" + imply MULTI_DTB_FIT + imply MULTI_DTB_FIT_USER_DEFINED_AREA imply R8A774A1 imply R8A774B1 imply R8A774E1 imply RZ_G2 imply SYS_MALLOC_F - imply MULTI_DTB_FIT - imply MULTI_DTB_FIT_USER_DEFINED_AREA help Support for RZG2 HiHope platform
@@ -150,23 +150,23 @@ config TARGET_SILINUX_EK874
config TARGET_SALVATOR_X bool "Salvator-X board" + imply MULTI_DTB_FIT + imply MULTI_DTB_FIT_USER_DEFINED_AREA imply R8A7795 imply R8A7796 imply R8A77965 imply SYS_MALLOC_F - imply MULTI_DTB_FIT - imply MULTI_DTB_FIT_USER_DEFINED_AREA help Support for Renesas R-Car Gen3 platform
config TARGET_ULCB bool "ULCB board" + imply MULTI_DTB_FIT + imply MULTI_DTB_FIT_USER_DEFINED_AREA imply R8A7795 imply R8A7796 imply R8A77965 imply SYS_MALLOC_F - imply MULTI_DTB_FIT - imply MULTI_DTB_FIT_USER_DEFINED_AREA help Support for Renesas R-Car Gen3 ULCB platform
Pull the SYS_SOC Kconfig option to avoid duplication of this option in Kconfig.{32,64,rza1} . The default value is the same, so just set it in one location.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- arch/arm/mach-rmobile/Kconfig | 3 +++ arch/arm/mach-rmobile/Kconfig.32 | 3 --- arch/arm/mach-rmobile/Kconfig.64 | 3 --- arch/arm/mach-rmobile/Kconfig.rza1 | 3 --- 4 files changed, 3 insertions(+), 9 deletions(-)
diff --git a/arch/arm/mach-rmobile/Kconfig b/arch/arm/mach-rmobile/Kconfig index 9ff45f46313..b69ccaee0a0 100644 --- a/arch/arm/mach-rmobile/Kconfig +++ b/arch/arm/mach-rmobile/Kconfig @@ -41,6 +41,9 @@ config RZA1
endchoice
+config SYS_SOC + default "rmobile" if ARCH_RMOBILE + source "arch/arm/mach-rmobile/Kconfig.32" source "arch/arm/mach-rmobile/Kconfig.64" source "arch/arm/mach-rmobile/Kconfig.rza1" diff --git a/arch/arm/mach-rmobile/Kconfig.32 b/arch/arm/mach-rmobile/Kconfig.32 index 31badc5a47d..1ac31c29d82 100644 --- a/arch/arm/mach-rmobile/Kconfig.32 +++ b/arch/arm/mach-rmobile/Kconfig.32 @@ -125,9 +125,6 @@ endchoice config TMU_TIMER bool
-config SYS_SOC - default "rmobile" - config RMOBILE_EXTRAM_BOOT bool "Enable boot from RAM" depends on TARGET_ALT || TARGET_BLANCHE || TARGET_KOELSCH || TARGET_LAGER || TARGET_PORTER || TARGET_SILK || TARGET_STOUT diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 33fd776f8af..3ed5099c36e 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -172,9 +172,6 @@ config TARGET_ULCB
endchoice
-config SYS_SOC - default "rmobile" - source "board/renesas/condor/Kconfig" source "board/renesas/draak/Kconfig" source "board/renesas/eagle/Kconfig" diff --git a/arch/arm/mach-rmobile/Kconfig.rza1 b/arch/arm/mach-rmobile/Kconfig.rza1 index 8cf033fb13c..e88f9a2eedb 100644 --- a/arch/arm/mach-rmobile/Kconfig.rza1 +++ b/arch/arm/mach-rmobile/Kconfig.rza1 @@ -19,9 +19,6 @@ config TARGET_GRPEACH
endchoice
-config SYS_SOC - default "rmobile" - # Renesas Supported Boards source "board/renesas/grpeach/Kconfig"
Introduce common Kconfig symbol for 64bit R-Car platforms and move common configuration options into it. This is preparatory patch to prevent duplication of Kconfig lists later on, when Gen4 is added.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- arch/arm/mach-rmobile/Kconfig | 29 +++++++++++++++++------------ 1 file changed, 17 insertions(+), 12 deletions(-)
diff --git a/arch/arm/mach-rmobile/Kconfig b/arch/arm/mach-rmobile/Kconfig index b69ccaee0a0..921153a8d9e 100644 --- a/arch/arm/mach-rmobile/Kconfig +++ b/arch/arm/mach-rmobile/Kconfig @@ -1,15 +1,8 @@ if ARCH_RMOBILE
-choice - prompt "Target Renesas SoC select" - default RCAR_32 - -config RCAR_32 - bool "Renesas ARM SoCs R-Car Gen1/Gen2 (32bit)" - select CPU_V7A - -config RCAR_GEN3 - bool "Renesas ARM SoCs R-Car Gen3 (64bit)" +# Renesas ARM SoCs R-Car Gen3/Gen4 (64bit) +config RCAR_64 + bool select ARM64 select CMD_CACHE select OF_BOARD_SETUP @@ -18,11 +11,24 @@ config RCAR_GEN3 select PINCTRL select PINCTRL_PFC select POSITION_INDEPENDENT - select SUPPORT_SPL imply CMD_FS_UUID imply CMD_GPT imply CMD_MMC_SWRITE if MMC imply CMD_UUID + imply SUPPORT_EMMC_RPMB if MMC + +choice + prompt "Target Renesas SoC select" + default RCAR_32 + +config RCAR_32 + bool "Renesas ARM SoCs R-Car Gen1/Gen2 (32bit)" + select CPU_V7A + +config RCAR_GEN3 + bool "Renesas ARM SoCs R-Car Gen3 (64bit)" + select RCAR_64 + select SUPPORT_SPL imply SPL imply SPL_BOARD_INIT imply SPL_GZIP @@ -33,7 +39,6 @@ config RCAR_GEN3 imply SPL_TINY_MEMSET imply SPL_USE_TINY_PRINTF imply SPL_YMODEM_SUPPORT - imply SUPPORT_EMMC_RPMB if MMC
There are multiple shared Kconfig options between R-Car Gen3 and Gen4. Keep the common options in Kconfig.64 and move the R-Car Gen3 specific options into separate Kconfig.rcar3 . The Kconfig.rcar3 contains SoC and board list, which is limited to R-Car Gen3.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- arch/arm/mach-rmobile/Kconfig.64 | 206 +--------------------------- arch/arm/mach-rmobile/Kconfig.rcar3 | 201 +++++++++++++++++++++++++++ 2 files changed, 206 insertions(+), 201 deletions(-) create mode 100644 arch/arm/mach-rmobile/Kconfig.rcar3
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 3ed5099c36e..3b14721dab5 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -1,207 +1,11 @@ -if RCAR_GEN3 - -menu "Select Target SoC" - -config R8A774A1 - bool "Renesas SoC R8A774A1" - select GICV2 - imply CLK_R8A774A1 - imply PINCTRL_PFC_R8A774A1 - -config R8A774B1 - bool "Renesas SoC R8A774B1" - select GICV2 - imply CLK_R8A774B1 - imply PINCTRL_PFC_R8A774B1 - -config R8A774C0 - bool "Renesas SoC R8A774C0" - select GICV2 - imply CLK_R8A774C0 - imply PINCTRL_PFC_R8A774C0 - -config R8A774E1 - bool "Renesas SoC R8A774E1" - select GICV2 - imply CLK_R8A774E1 - imply PINCTRL_PFC_R8A774E1 - -config R8A7795 - bool "Renesas SoC R8A7795" - select GICV2 - imply CLK_R8A7795 - imply PINCTRL_PFC_R8A77951 - -config R8A7796 - bool "Renesas SoC R8A7796" - select GICV2 - imply CLK_R8A77960 - imply CLK_R8A77961 - imply PINCTRL_PFC_R8A77960 - imply PINCTRL_PFC_R8A77961 - -config R8A77965 - bool "Renesas SoC R8A77965" - select GICV2 - imply CLK_R8A77965 - imply PINCTRL_PFC_R8A77965 - -config R8A77970 - bool "Renesas SoC R8A77970" - select GICV2 - imply CLK_R8A77970 - imply PINCTRL_PFC_R8A77970 - -config R8A77980 - bool "Renesas SoC R8A77980" - select GICV2 - imply CLK_R8A77980 - imply PINCTRL_PFC_R8A77980 - -config R8A77990 - bool "Renesas SoC R8A77990" - select GICV2 - imply CLK_R8A77990 - imply PINCTRL_PFC_R8A77990 - -config R8A77995 - bool "Renesas SoC R8A77995" - select GICV2 - imply CLK_R8A77995 - imply PINCTRL_PFC_R8A77995 - -config R8A779A0 - bool "Renesas SoC R8A779A0" - select GICV3 - imply CLK_R8A779A0 - imply PINCTRL_PFC_R8A779A0 - -config RZ_G2 - bool "Renesas ARM SoCs RZ/G2 (64bit)" - -endmenu - -choice - prompt "Renesas ARM64 SoCs board select" - optional - -config TARGET_BEACON_RZG2M - bool "Beacon EmbeddedWorks RZ/G2 Dev Kit" - select PINCTRL_PFC_R8A774A1 - select PINCTRL_PFC_R8A774B1 - select PINCTRL_PFC_R8A774E1 - select R8A774A1 - select R8A774B1 - select R8A774E1 - select RZ_G2 - imply CLK_CCF - imply CLK_VERSACLOCK - imply MULTI_DTB_FIT - imply MULTI_DTB_FIT_USER_DEFINED_AREA - -config TARGET_CONDOR - bool "Condor board" - imply R8A77980 - help - Support for Renesas R-Car Gen3 Condor platform - -config TARGET_DRAAK - bool "Draak board" - imply R8A77995 - help - Support for Renesas R-Car Gen3 Draak platform - -config TARGET_EAGLE - bool "Eagle board" - imply R8A77970 - help - Support for Renesas R-Car Gen3 Eagle platform - -config TARGET_EBISU - bool "Ebisu board" - imply R8A77990 - help - Support for Renesas R-Car Gen3 Ebisu platform - -config TARGET_FALCON - bool "Falcon board" - imply R8A779A0 - help - Support for Renesas R-Car Gen3 Falcon platform - -config TARGET_HIHOPE_RZG2 - bool "HiHope RZ/G2 board" - imply MULTI_DTB_FIT - imply MULTI_DTB_FIT_USER_DEFINED_AREA - imply R8A774A1 - imply R8A774B1 - imply R8A774E1 - imply RZ_G2 - imply SYS_MALLOC_F - help - Support for RZG2 HiHope platform - -config TARGET_SILINUX_EK874 - bool "Silicon Linux EK874 board" - imply R8A774C0 - imply RZ_G2 - help - Support for Silicon Linux EK874 platform - -config TARGET_SALVATOR_X - bool "Salvator-X board" - imply MULTI_DTB_FIT - imply MULTI_DTB_FIT_USER_DEFINED_AREA - imply R8A7795 - imply R8A7796 - imply R8A77965 - imply SYS_MALLOC_F - help - Support for Renesas R-Car Gen3 platform - -config TARGET_ULCB - bool "ULCB board" - imply MULTI_DTB_FIT - imply MULTI_DTB_FIT_USER_DEFINED_AREA - imply R8A7795 - imply R8A7796 - imply R8A77965 - imply SYS_MALLOC_F - help - Support for Renesas R-Car Gen3 ULCB platform - -endchoice - -source "board/renesas/condor/Kconfig" -source "board/renesas/draak/Kconfig" -source "board/renesas/eagle/Kconfig" -source "board/renesas/ebisu/Kconfig" -source "board/renesas/falcon/Kconfig" -source "board/renesas/salvator-x/Kconfig" -source "board/renesas/ulcb/Kconfig" -source "board/beacon/beacon-rzg2m/Kconfig" -source "board/hoperun/hihope-rzg2/Kconfig" -source "board/silinux/ek874/Kconfig" - -config MULTI_DTB_FIT_UNCOMPRESS_SZ - default 0x80000 if TARGET_BEACON_RZG2M - default 0x80000 if TARGET_HIHOPE_RZG2 - default 0x80000 if TARGET_SALVATOR_X - default 0x80000 if TARGET_ULCB - -config MULTI_DTB_FIT_USER_DEF_ADDR - default 0x49000000 if TARGET_BEACON_RZG2M - default 0x49000000 if TARGET_HIHOPE_RZG2 - default 0x49000000 if TARGET_SALVATOR_X - default 0x49000000 if TARGET_ULCB +if RCAR_64
config SYS_MALLOC_F_LEN - default 0x8000 if RCAR_GEN3 - -config DM_RESET - default y if RCAR_GEN3 + default 0x8000 if RCAR_64
config OF_LIBFDT_OVERLAY - default y if RCAR_GEN3 + default y if RCAR_64 + +source "arch/arm/mach-rmobile/Kconfig.rcar3"
endif diff --git a/arch/arm/mach-rmobile/Kconfig.rcar3 b/arch/arm/mach-rmobile/Kconfig.rcar3 new file mode 100644 index 00000000000..680aa455160 --- /dev/null +++ b/arch/arm/mach-rmobile/Kconfig.rcar3 @@ -0,0 +1,201 @@ +if RCAR_GEN3 + +menu "Select Target SoC" + +config R8A774A1 + bool "Renesas SoC R8A774A1" + select GICV2 + imply CLK_R8A774A1 + imply PINCTRL_PFC_R8A774A1 + +config R8A774B1 + bool "Renesas SoC R8A774B1" + select GICV2 + imply CLK_R8A774B1 + imply PINCTRL_PFC_R8A774B1 + +config R8A774C0 + bool "Renesas SoC R8A774C0" + select GICV2 + imply CLK_R8A774C0 + imply PINCTRL_PFC_R8A774C0 + +config R8A774E1 + bool "Renesas SoC R8A774E1" + select GICV2 + imply CLK_R8A774E1 + imply PINCTRL_PFC_R8A774E1 + +config R8A7795 + bool "Renesas SoC R8A7795" + select GICV2 + imply CLK_R8A7795 + imply PINCTRL_PFC_R8A77951 + +config R8A7796 + bool "Renesas SoC R8A7796" + select GICV2 + imply CLK_R8A77960 + imply CLK_R8A77961 + imply PINCTRL_PFC_R8A77960 + imply PINCTRL_PFC_R8A77961 + +config R8A77965 + bool "Renesas SoC R8A77965" + select GICV2 + imply CLK_R8A77965 + imply PINCTRL_PFC_R8A77965 + +config R8A77970 + bool "Renesas SoC R8A77970" + select GICV2 + imply CLK_R8A77970 + imply PINCTRL_PFC_R8A77970 + +config R8A77980 + bool "Renesas SoC R8A77980" + select GICV2 + imply CLK_R8A77980 + imply PINCTRL_PFC_R8A77980 + +config R8A77990 + bool "Renesas SoC R8A77990" + select GICV2 + imply CLK_R8A77990 + imply PINCTRL_PFC_R8A77990 + +config R8A77995 + bool "Renesas SoC R8A77995" + select GICV2 + imply CLK_R8A77995 + imply PINCTRL_PFC_R8A77995 + +config R8A779A0 + bool "Renesas SoC R8A779A0" + select GICV3 + imply CLK_R8A779A0 + imply PINCTRL_PFC_R8A779A0 + +config RZ_G2 + bool "Renesas ARM SoCs RZ/G2 (64bit)" + +endmenu + +choice + prompt "Renesas ARM64 SoCs board select" + optional + +config TARGET_BEACON_RZG2M + bool "Beacon EmbeddedWorks RZ/G2 Dev Kit" + select PINCTRL_PFC_R8A774A1 + select PINCTRL_PFC_R8A774B1 + select PINCTRL_PFC_R8A774E1 + select R8A774A1 + select R8A774B1 + select R8A774E1 + select RZ_G2 + imply CLK_CCF + imply CLK_VERSACLOCK + imply MULTI_DTB_FIT + imply MULTI_DTB_FIT_USER_DEFINED_AREA + +config TARGET_CONDOR + bool "Condor board" + imply R8A77980 + help + Support for Renesas R-Car Gen3 Condor platform + +config TARGET_DRAAK + bool "Draak board" + imply R8A77995 + help + Support for Renesas R-Car Gen3 Draak platform + +config TARGET_EAGLE + bool "Eagle board" + imply R8A77970 + help + Support for Renesas R-Car Gen3 Eagle platform + +config TARGET_EBISU + bool "Ebisu board" + imply R8A77990 + help + Support for Renesas R-Car Gen3 Ebisu platform + +config TARGET_FALCON + bool "Falcon board" + imply R8A779A0 + help + Support for Renesas R-Car Gen3 Falcon platform + +config TARGET_HIHOPE_RZG2 + bool "HiHope RZ/G2 board" + imply MULTI_DTB_FIT + imply MULTI_DTB_FIT_USER_DEFINED_AREA + imply R8A774A1 + imply R8A774B1 + imply R8A774E1 + imply RZ_G2 + imply SYS_MALLOC_F + help + Support for RZG2 HiHope platform + +config TARGET_SILINUX_EK874 + bool "Silicon Linux EK874 board" + imply R8A774C0 + imply RZ_G2 + help + Support for Silicon Linux EK874 platform + +config TARGET_SALVATOR_X + bool "Salvator-X board" + imply MULTI_DTB_FIT + imply MULTI_DTB_FIT_USER_DEFINED_AREA + imply R8A7795 + imply R8A7796 + imply R8A77965 + imply SYS_MALLOC_F + help + Support for Renesas R-Car Gen3 platform + +config TARGET_ULCB + bool "ULCB board" + imply MULTI_DTB_FIT + imply MULTI_DTB_FIT_USER_DEFINED_AREA + imply R8A7795 + imply R8A7796 + imply R8A77965 + imply SYS_MALLOC_F + help + Support for Renesas R-Car Gen3 ULCB platform + +endchoice + +source "board/renesas/condor/Kconfig" +source "board/renesas/draak/Kconfig" +source "board/renesas/eagle/Kconfig" +source "board/renesas/ebisu/Kconfig" +source "board/renesas/falcon/Kconfig" +source "board/renesas/salvator-x/Kconfig" +source "board/renesas/ulcb/Kconfig" +source "board/beacon/beacon-rzg2m/Kconfig" +source "board/hoperun/hihope-rzg2/Kconfig" +source "board/silinux/ek874/Kconfig" + +config MULTI_DTB_FIT_UNCOMPRESS_SZ + default 0x80000 if TARGET_BEACON_RZG2M + default 0x80000 if TARGET_HIHOPE_RZG2 + default 0x80000 if TARGET_SALVATOR_X + default 0x80000 if TARGET_ULCB + +config MULTI_DTB_FIT_USER_DEF_ADDR + default 0x49000000 if TARGET_BEACON_RZG2M + default 0x49000000 if TARGET_HIHOPE_RZG2 + default 0x49000000 if TARGET_SALVATOR_X + default 0x49000000 if TARGET_ULCB + +config DM_RESET + default y if RCAR_GEN3 + +endif
