[U-Boot] [PATCH] SMDKV310: Fix host compilation of mkv310_image
Fix compilation of mkv310_image host tool
tools/mkv310_image.c: In function 'main': tools/mkv310_image.c:67: error: 'S_IRUSR' undeclared (first use in this function) tools/mkv310_image.c:67: error: (Each undeclared identifier is reported only once tools/mkv310_image.c:67: error: for each function it appears in.) tools/mkv310_image.c:67: error: 'S_IWUSR' undeclared (first use in this function) tools/mkv310_image.c:67: error: 'S_IRGRP' undeclared (first use in this function) tools/mkv310_image.c:67: error: 'S_IWGRP' undeclared (first use in this function) tools/mkv310_image.c:67: error: 'S_IROTH' undeclared (first use in this function) tools/mkv310_image.c:67: error: 'S_IWOTH' undeclared (first use in this function)
resulting from a 'make smdkv310_config'.
Signed-off-by: Dirk Behme dirk.behme@googlemail.com
--- Note: mkv310_image is compiled for the host by the host's gcc:
cd mmc_spl/board/samsung/smdkv310 gcc tools/mkv310_image.c -o tools/mkv310_mmc_spl_exec
At my system S_IRUSR & friends are defined in linux/stat.h and are wrapped by a #if defined(__KERNEL__). On other hosts this might be different (?)
mmc_spl/board/samsung/smdkv310/tools/mkv310_image.c | 2 ++ 1 file changed, 2 insertions(+)
Index: u-boot.git/mmc_spl/board/samsung/smdkv310/tools/mkv310_image.c =================================================================== --- u-boot.git.orig/mmc_spl/board/samsung/smdkv310/tools/mkv310_image.c +++ u-boot.git/mmc_spl/board/samsung/smdkv310/tools/mkv310_image.c @@ -26,6 +26,8 @@ #include <fcntl.h> #include <errno.h> #include <string.h> +#define __KERNEL__ +#include <linux/stat.h>
#define CHECKSUM_OFFSET (14*1024-4) #define BUFSIZE (16*1024)
yikes, no. use standard sys/stat.h. -mike
Dirk Behme
Mike Frysinger
