Re: [U-Boot] [PATCH] pinctrl: imx: fix memory leak
-----Original Message----- From: Lothar Waßmann [mailto:LW@KARO-electronics.de] Sent: Thursday, May 11, 2017 5:13 PM To: Peng Fan peng.fan@nxp.com Cc: sjg@chromium.org; u-boot@lists.denx.de; Stefan Agner stefan.agner@toradex.com Subject: Re: [U-Boot] [PATCH] pinctrl: imx: fix memory leak
On Thu, 11 May 2017 10:43:02 +0800 Peng Fan wrote:
Each time set_state is called, a new piece memory will be allocated for pin_data, but not freed, this will incur memory leak.
When error, the devm API could not free memory automatically. So need call devm_kfree when error.
Issue reported by Coverity
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Stefan Agner stefan.agner@toradex.com Cc: Stefano Babic sbabic@denx.de
drivers/pinctrl/nxp/pinctrl-imx.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/pinctrl/nxp/pinctrl-imx.c b/drivers/pinctrl/nxp/pinctrl-imx.c index f0321c4..31a28e1 100644 --- a/drivers/pinctrl/nxp/pinctrl-imx.c +++ b/drivers/pinctrl/nxp/pinctrl-imx.c @@ -53,6 +53,7 @@ static int imx_pinctrl_set_state(struct udevice *dev,
struct udevice *config)
if (fdtdec_get_int_array(gd->fdt_blob, node, "fsl,pins", pin_data, size >> 2)) { dev_err(dev, "Error reading pin data.\n");
return -EINVAL; }devm_kfree(pin_data);
@@ -78,6 +79,7 @@ static int imx_pinctrl_set_state(struct udevice *dev, struct udevice *config)
if ((mux_reg == -1) || (conf_reg == -1)) { dev_err(dev, "Error mux_reg or conf_reg\n");
}devm_kfree(pin_data); return -EINVAL;
@@ -166,6 +168,8 @@ static int imx_pinctrl_set_state(struct udevice *dev,
- devm_kfree(pin_data);
IMO 'devm'_kzalloc() doesn't make any sense here. It would make sense for allocations that have the same lifetime as the 'struct udevice', but not for a temporary buffer that is used within on function.
Size is different for different fsl,pins group. So need to use devm_kzalloc.
Thanks, Peng.
Lothar Waßmann
Peng Fan
