[U-Boot-Users] at91rm9200 - silent console
Dear List
I have a at91rm9200ek based board on which I am trying to get u boot 1.2.0 running, without success.
I have also tried to compile and run u-boot for the ek directly from the source, all be it with unmodified at91rm9200dk_config. This does not work either. When I load the uboot.bin into flash (with a J-Link ICE) at 0x10000000 and reboot I get nothing on the DBGU console. Is this what you would expect for an ek board with un-patched 1.2.0 source? I have seen references to patches from Ulf for an EK board in the list - is there something I am missing? Is the at91rm92000 support broken in the latest version? Not sure if the recent thread [ARM cleanup - was: [GIT PULL] [ARM] Please pull fromgit://denx.de/git/u-boot-arm.git] suggested it was...
Just to put my mind at rest I have also tried to compile and run u-boot with CONFIG_SKIP_LOWLWEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT defined. I thought this may then allow loading and running uboot using the loader.bin programme provided by Atmel. However, I got as far as a report that u-boot was downloaded successfully and then silence....is this what you would expect?
Also, I'm a bit confused by the following snippet from at91rm9200dk.h:
#ifdef CFG_ENV_IS_IN_DATAFLASH #define CFG_ENV_OFFSET 0x20000 #define CFG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS0 + CFG_ENV_OFFSET) #define CFG_ENV_SIZE 0x2000 /* 0x8000 */ #else #define CFG_ENV_IS_IN_FLASH 1 #ifdef CONFIG_SKIP_LOWLEVEL_INIT #define CFG_ENV_ADDR (PHYS_FLASH_1 + 0x60000) /* after u-boot.bin */ #define CFG_ENV_SIZE 0x10000 /* sectors are 64K here */ #else #define CFG_ENV_ADDR (PHYS_FLASH_1 + 0xe000) /* between boot.bin and u-boot.bin.gz */ #define CFG_ENV_SIZE 0x2000 /* 0x8000 */ #endif /* CONFIG_SKIP_LOWLEVEL_INIT */ #endif /* CFG_ENV_IS_IN_DATAFLASH */
Does the above say (or imply through comments) that if we are booting from flash and skipping low level init then the format of uboot is an umcompressed binary and boot.bin is not used? Is this backwards or am I?
On our new board there is a different flash chip to the, now obsolete, one on the ek board. I have altered flash.h and board/at91rm9200xxx/flash.c along the lines of the patch by Nicolas Lacressonniere (24 Jun 2004) to 1.1.1 to take this into account. We are now using the AT49BV642D. I believe it is compatible in all respects, aside from CFI ID, with the previous chip (AT49BV6416). If anyone knows this to be incorrect then please let me know!
Many thanks for you help and I hope I have not asked anything too obviously daft!
Best regards, Craig Robinson.
Circuitree Ltd W: www.cctree.co.uk
No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.5.485 / Virus Database: 269.13.13/998 - Release Date: 10/09/2007 08:48
----- Original Message ----- From: "Craig Robinson" craig.robinson@cctree.co.uk To: u-boot-users@lists.sourceforge.net Sent: Monday, September 10, 2007 5:45 PM Subject: [U-Boot-Users] at91rm9200 - silent console
Dear List
You may want to get the u-boot-1.2.0-atmel.tar.bz2 from
ftp://at91dist:distrib@81.80.104.162/ -> AT91 Third Party -> Linux Host -> Source
This supports the AT91RM9200 booting from dataflash.
It also contains a number of other things which really simplifies the experience of booting linux, which unfortunately is rejected for inclusion into mainstream u-boot.
This version is not an official Atmel release, but I have included all patches from the Atmel 1.1.5 version.
An easy way to get this done is to download the buildroot script from the www.at91.com Linux Forum. (The buildroot project in www.at91.com is too old) This will build a cross compiler, linux, u-boot and dataflashboot.
Best Regards Ulf Samuelsson ulf@atmel.com Atmel Nordic AB Mail: Box 2033, 174 02 Sundbyberg, Sweden Visit: Kavallerivägen 24, 174 58 Sundbyberg, Sweden Phone +46 (8) 441 54 22 Fax +46 (8) 441 54 29 GSM +46 (706) 22 44 57
Technical support when I am not available: AT90 AVR Applications Group: mailto:avr@atmel.com AT91 ARM Applications Group: mailto:at91support@atmel.com AVR32 Applications Group mailto:avr32@atmel.com http://www.avrfreaks.net/; http://avr32linux.org/ http://www.at91.com/ ; ftp://at91dist:distrib@81.80.104.162/
Hi, Ulf: ___________________________________________________________________ On Monday, September 10, 2007 3:10 PM Ulf Samuelsson wrote:
Can you please provide a link on latest (not obsolete) at91rm9200 buildroot?
Thanks,
Leonid.
tis 2007-09-11 klockan 15:58 -0700 skrev Leonid:
Download the buildroot tarball with the latest date from
ftp://at91supp:support@81.80.104.162/ -> AT91 Third Party support ... -> Linux_Host -> Source
IIRC it is 2007-06-07.
You can also go to www.at91.com Linux Forum and look for buildroot. There should be a script which downloads the stuff above. It is no longer maintained, since I got write access to the main buildroot svn.
Someone just broke the AT91 support though, so todays tarball wont work.
I will try to fix this immediately.
Thanks,
Leonid.
Than you, Ulf. Tarball doesn't work indeed. I could create workable filesystem from January buildroot, but if you can suggest better/newer sources, I'd appreciate that.
Thanks,
Leonid.
-----Original Message----- From: Ulf Samuelsson [mailto:ulf@atmel.com] Sent: Tuesday, September 11, 2007 7:34 PM To: Leonid Cc: Craig Robinson; u-boot-users@lists.sourceforge.net Subject: RE: [U-Boot-Users] at91rm9200 - silent console
Thanks,
Leonid.
-- Best Regards, Ulf Samuelsson mail: ulf@atmel.com Atmel Nordic AB Box 2033, 174 52 Sundbyberg Kavallerivägen 24, 174 58 Sundbyberg Sweden Tel: +46 8 441 54 22 GSM: +46 706 224457
Unlike more "traditional" PPC versions of u-boot, at91... U-boot is not the first code running on the board. The first one is normally some small bootstrap, running from dataflash or flash itself - it depends on jumper settings and also u-bbot configuration must be right.
Search this list's archives - this question has been discussed many times in different forms.
Leonid.
-----Original Message----- From: u-boot-users-bounces@lists.sourceforge.net [mailto:u-boot-users-bounces@lists.sourceforge.net] On Behalf Of Craig Robinson Sent: Monday, September 10, 2007 8:46 AM To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] at91rm9200 - silent console
Dear List
------------------------------------------------------------------------ - This SF.net email is sponsored by: Microsoft Defy all challenges. Microsoft(R) Visual Studio 2005. http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Hi Leonid & Ulf
Thank-you for the pointers to the atmel patched code and buildroot scripts.
Can I confirm with you that the correct way to set up u-boot for an at91rm9200 is to use two boot loaders. Can I also confirm that, to boot from parallel flash, the first stage boot loader is boot.bin and that this will load a gzipped version of u-boot. The fact that the atmel source from Ulf's ftp generates a gzipped binary when built suggests to me that this is so. I've seen different opinions on the newsgroup, including some pretty emphatic ones from Wolfgang that u-boot will just work on its own, and frankly am a bit confused!
If u-boot should be started by boot.bin are there any specific CONFIG settings to go along with this? Eg. do we need LOWLEVEL_INIT or not? Also I'd be grateful if you could point me at the CONFIG (if any) needed to boot from parallel flash and not dataflash. I think this used to have something to do with CONFIG_BOOTBINFUNC but now that's been replaced...?
Many thanks Craig
-----Original Message----- From: Leonid [mailto:Leonid@a-k-a.net] Sent: 10 September 2007 23:20 To: Craig Robinson; u-boot-users@lists.sourceforge.net Subject: RE: [U-Boot-Users] at91rm9200 - silent console
Leonid.
Dear List
No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.5.485 / Virus Database: 269.13.14/999 - Release Date: 10/09/2007 17:43
Hi, Craig:
I am using two stage boot loader for Atmel reference board. While there are indeed different opinions whether this is correct way to go, but such concept certainly works.
If your first stage boot, u-boot and u-boot environment are on NOR flash (on the very begiining of it you must program boot.bin) you should undef both DATAFLASH config and lovel init flags in <board>.h include file.
#define CONFIG_SKIP_LOWLEVEL_INIT 1
#undef CFG_ENV_IS_IN_DATAFLASH
at91rm9200dk.h which is in u-boot tree already is a good start point.
Regards,
Leonid.
-----Original Message----- From: Craig Robinson [mailto:craig.robinson@cctree.co.uk] Sent: Wednesday, September 12, 2007 2:20 AM To: Leonid; u-boot-users@lists.sourceforge.net; ulf@atmel.com Subject: RE: [U-Boot-Users] at91rm9200 - silent console
Hi Leonid & Ulf
Many thanks Craig
Leonid.
Dear List
Craig Robinson
Leonid
Ulf Samuelsson
