[PATCH v1 7/9] rockchip: RK356x: Enable display cpuinfo support on all boards
Imply DISPLAY_CPUINFO Kconfig options to support on all RK3566 and RK3568 boards, Its used to determine the reset cause of the board.
Cc: Jagan Teki jagan@edgeble.ai Signed-off-by: Anand Moon anand@edgeble.ai --- arch/arm/mach-rockchip/Kconfig | 1 + configs/anbernic-rgxx3-rk3566_defconfig | 1 - configs/bpi-r2-pro-rk3568_defconfig | 1 - configs/evb-rk3568_defconfig | 1 - configs/generic-rk3568_defconfig | 1 - configs/lubancat-2-rk3568_defconfig | 1 - configs/nanopi-r5c-rk3568_defconfig | 1 - configs/nanopi-r5s-rk3568_defconfig | 1 - configs/odroid-m1-rk3568_defconfig | 1 - configs/pinetab2-rk3566_defconfig | 1 - configs/quartz64-a-rk3566_defconfig | 1 - configs/quartz64-b-rk3566_defconfig | 1 - configs/radxa-cm3-io-rk3566_defconfig | 1 - configs/radxa-e25-rk3568_defconfig | 1 - configs/rock-3a-rk3568_defconfig | 1 - configs/soquartz-blade-rk3566_defconfig | 1 - configs/soquartz-cm4-rk3566_defconfig | 1 - configs/soquartz-model-a-rk3566_defconfig | 1 - 18 files changed, 1 insertion(+), 17 deletions(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 1fd482e43b..2e9c71138e 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -331,6 +331,7 @@ config ROCKCHIP_RK3568 imply ROCKCHIP_OTP imply SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF imply SPL_MMC_HS200_SUPPORT if SPL_MMC && MMC_HS200_SUPPORT + imply DISPLAY_CPUINFO help The Rockchip RK3568 is a ARM-based SoC with quad-core Cortex-A55, including NEON and GPU, 512K L3 cache, Mali-G52 based graphics, diff --git a/configs/anbernic-rgxx3-rk3566_defconfig b/configs/anbernic-rgxx3-rk3566_defconfig index a03509bf46..95f7cf0739 100644 --- a/configs/anbernic-rgxx3-rk3566_defconfig +++ b/configs/anbernic-rgxx3-rk3566_defconfig @@ -21,7 +21,6 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-anbernic-rgxx3.dtb" # CONFIG_CONSOLE_MUX is not set -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_RNG_SEED=y CONFIG_SPL_MAX_SIZE=0x40000 diff --git a/configs/bpi-r2-pro-rk3568_defconfig b/configs/bpi-r2-pro-rk3568_defconfig index eccc15a0ae..4955fd907c 100644 --- a/configs/bpi-r2-pro-rk3568_defconfig +++ b/configs/bpi-r2-pro-rk3568_defconfig @@ -16,7 +16,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-bpi-r2-pro.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/evb-rk3568_defconfig b/configs/evb-rk3568_defconfig index 2076f55122..e6da8fd246 100644 --- a/configs/evb-rk3568_defconfig +++ b/configs/evb-rk3568_defconfig @@ -15,7 +15,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-evb1-v10.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/generic-rk3568_defconfig b/configs/generic-rk3568_defconfig index 66a33afbba..ba2d995cdc 100644 --- a/configs/generic-rk3568_defconfig +++ b/configs/generic-rk3568_defconfig @@ -20,7 +20,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_BOOTMETH_VBE is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-generic.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/lubancat-2-rk3568_defconfig b/configs/lubancat-2-rk3568_defconfig index 88593bfa70..384d0ecfc5 100644 --- a/configs/lubancat-2-rk3568_defconfig +++ b/configs/lubancat-2-rk3568_defconfig @@ -15,7 +15,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-lubancat-2.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/nanopi-r5c-rk3568_defconfig b/configs/nanopi-r5c-rk3568_defconfig index 4a6c320faf..b83796083d 100644 --- a/configs/nanopi-r5c-rk3568_defconfig +++ b/configs/nanopi-r5c-rk3568_defconfig @@ -17,7 +17,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-nanopi-r5c.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/nanopi-r5s-rk3568_defconfig b/configs/nanopi-r5s-rk3568_defconfig index 7ab12e619a..5d500963a2 100644 --- a/configs/nanopi-r5s-rk3568_defconfig +++ b/configs/nanopi-r5s-rk3568_defconfig @@ -17,7 +17,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-nanopi-r5s.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/odroid-m1-rk3568_defconfig b/configs/odroid-m1-rk3568_defconfig index b5263caff6..7bea6e6851 100644 --- a/configs/odroid-m1-rk3568_defconfig +++ b/configs/odroid-m1-rk3568_defconfig @@ -23,7 +23,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-odroid-m1.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/pinetab2-rk3566_defconfig b/configs/pinetab2-rk3566_defconfig index e46acf3a3b..1441feb796 100644 --- a/configs/pinetab2-rk3566_defconfig +++ b/configs/pinetab2-rk3566_defconfig @@ -23,7 +23,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-pinetab2-v2.0.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/quartz64-a-rk3566_defconfig b/configs/quartz64-a-rk3566_defconfig index 1ea8e0f40c..458d6d6e81 100644 --- a/configs/quartz64-a-rk3566_defconfig +++ b/configs/quartz64-a-rk3566_defconfig @@ -24,7 +24,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-quartz64-a.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/quartz64-b-rk3566_defconfig b/configs/quartz64-b-rk3566_defconfig index f61b2c181a..029c184177 100644 --- a/configs/quartz64-b-rk3566_defconfig +++ b/configs/quartz64-b-rk3566_defconfig @@ -23,7 +23,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-quartz64-b.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/radxa-cm3-io-rk3566_defconfig b/configs/radxa-cm3-io-rk3566_defconfig index 48c8fcf5a6..8d6990c403 100644 --- a/configs/radxa-cm3-io-rk3566_defconfig +++ b/configs/radxa-cm3-io-rk3566_defconfig @@ -15,7 +15,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-radxa-cm3-io.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/radxa-e25-rk3568_defconfig b/configs/radxa-e25-rk3568_defconfig index 496fee0e0a..2cfa34956d 100644 --- a/configs/radxa-e25-rk3568_defconfig +++ b/configs/radxa-e25-rk3568_defconfig @@ -18,7 +18,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-radxa-e25.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/rock-3a-rk3568_defconfig b/configs/rock-3a-rk3568_defconfig index 66ac2f6d7a..9ac9ef8827 100644 --- a/configs/rock-3a-rk3568_defconfig +++ b/configs/rock-3a-rk3568_defconfig @@ -22,7 +22,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-rock-3a.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/soquartz-blade-rk3566_defconfig b/configs/soquartz-blade-rk3566_defconfig index 82910daf7c..3d5344e43a 100644 --- a/configs/soquartz-blade-rk3566_defconfig +++ b/configs/soquartz-blade-rk3566_defconfig @@ -18,7 +18,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-soquartz-blade.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/soquartz-cm4-rk3566_defconfig b/configs/soquartz-cm4-rk3566_defconfig index 5744f1baa8..99e5dbe4fc 100644 --- a/configs/soquartz-cm4-rk3566_defconfig +++ b/configs/soquartz-cm4-rk3566_defconfig @@ -18,7 +18,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-soquartz-cm4.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/soquartz-model-a-rk3566_defconfig b/configs/soquartz-model-a-rk3566_defconfig index 920df9b622..656e0ef178 100644 --- a/configs/soquartz-model-a-rk3566_defconfig +++ b/configs/soquartz-model-a-rk3566_defconfig @@ -18,7 +18,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-soquartz-model-a.dtb" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000
Anand Moon
