[U-Boot] [PATCH] ARM: atmel: at91sam9m10g45ek: enable SPL
Supports boot up from NAND flash with software ECC eanbled. And supports boot up from SD/MMC card with FAT file system.
As the boot from SD/MMC card with FAT file system, the BSS segment is too big to fit into SRAM, so, use the lds to put it into SDRAM. So, we need to initialize the SDRAM as soon as possible. Borrow the low level init code from <arm/arm/cpu/armv7/lowlevel_init.S> for this purpose.
As there is a little change, which need lowlevel init, so also change taurus board based on at91sam9260, corvus board based on at91sam9g45. (CONFIG_SPL_STACK is replaced by CONFIG_SYS_INIT_SP_ADDR)
Signed-off-by: Bo Shen voice.shen@atmel.com ---
arch/arm/Kconfig | 1 + arch/arm/cpu/arm926ejs/at91/Makefile | 4 ++ arch/arm/cpu/arm926ejs/at91/spl_lowlevel_init.S | 37 ++++++++++++ arch/arm/cpu/at91-common/spl_at91.c | 7 +-- arch/arm/cpu/at91-common/u-boot-spl-arm9.lds | 48 +++++++++++++++ board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 80 +++++++++++++++++++++++++ configs/at91sam9m10g45ek_mmc_defconfig | 5 +- configs/at91sam9m10g45ek_nandflash_defconfig | 5 +- include/configs/at91sam9m10g45ek.h | 65 ++++++++++++++++++++ include/configs/corvus.h | 7 ++- include/configs/taurus.h | 7 ++- 11 files changed, 256 insertions(+), 10 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/at91/spl_lowlevel_init.S create mode 100644 arch/arm/cpu/at91-common/u-boot-spl-arm9.lds
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 5eb1d03..f4788c6 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -141,6 +141,7 @@ config TARGET_AT91SAM9263EK config TARGET_AT91SAM9M10G45EK bool "Support at91sam9m10g45ek" select CPU_ARM926EJS + select SUPPORT_SPL
config TARGET_AT91SAM9N12EK bool "Support at91sam9n12ek" diff --git a/arch/arm/cpu/arm926ejs/at91/Makefile b/arch/arm/cpu/arm926ejs/at91/Makefile index 698a28d..238434b 100644 --- a/arch/arm/cpu/arm926ejs/at91/Makefile +++ b/arch/arm/cpu/arm926ejs/at91/Makefile @@ -25,5 +25,9 @@ obj-y += reset.o obj-y += timer.o
ifndef CONFIG_SKIP_LOWLEVEL_INIT +ifdef CONFIG_SPL_BUILD +obj-y += spl_lowlevel_init.o +else obj-y += lowlevel_init.o endif +endif diff --git a/arch/arm/cpu/arm926ejs/at91/spl_lowlevel_init.S b/arch/arm/cpu/arm926ejs/at91/spl_lowlevel_init.S new file mode 100644 index 0000000..f1b2ec9 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/at91/spl_lowlevel_init.S @@ -0,0 +1,37 @@ +/* + * A lowlevel_init function that sets up the stack to call a C function to + * perform further init. + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Author : + * Aneesh V aneesh@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm-offsets.h> +#include <config.h> +#include <linux/linkage.h> + +ENTRY(lowlevel_init) + /* + * Setup a temporary stack + */ + ldr sp, =CONFIG_SYS_INIT_SP_ADDR + bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ + + ldr r9, =gdata + + /* + * Save the old lr(passed in ip) and the current lr to stack + */ + push {ip, lr} + + /* + * go setup pll, mux, memory + */ + bl s_init + pop {ip, pc} +ENDPROC(lowlevel_init) diff --git a/arch/arm/cpu/at91-common/spl_at91.c b/arch/arm/cpu/at91-common/spl_at91.c index 89f588b..04abc29 100644 --- a/arch/arm/cpu/at91-common/spl_at91.c +++ b/arch/arm/cpu/at91-common/spl_at91.c @@ -67,11 +67,12 @@ void __weak matrix_init(void) { }
-void __weak at91_spl_board_init(void) +void spl_board_init(void) { + at91_spl_board_init(); }
-void spl_board_init(void) +void s_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
@@ -119,6 +120,4 @@ void spl_board_init(void) preloader_console_init();
mem_init(); - - at91_spl_board_init(); } diff --git a/arch/arm/cpu/at91-common/u-boot-spl-arm9.lds b/arch/arm/cpu/at91-common/u-boot-spl-arm9.lds new file mode 100644 index 0000000..6f350a9 --- /dev/null +++ b/arch/arm/cpu/at91-common/u-boot-spl-arm9.lds @@ -0,0 +1,48 @@ +/* + * Copyright (C) 2014 Atmel Corporation + * Bo Shen voice.shen@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +MEMORY { .sram : ORIGIN = CONFIG_SPL_TEXT_BASE, \ + LENGTH = CONFIG_SPL_MAX_SIZE } +MEMORY { .sdram : ORIGIN = CONFIG_SPL_BSS_START_ADDR, \ + LENGTH = CONFIG_SPL_BSS_MAX_SIZE } + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + .text : + { + __start = .; + *(.vectors) + arch/arm/cpu/arm926ejs/start.o (.text*) + *(.text*) + } >.sram + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(.rodata*)) } >.sram + + . = ALIGN(4); + .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram + + . = ALIGN(4); + __image_copy_end = .; + + .end : + { + *(.__end) + } >.sram + + .bss : + { + . = ALIGN(4); + __bss_start = .; + *(.bss*) + . = ALIGN(4); + __bss_end = .; + } >.sdram +} diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index b807ef9..4289179 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -8,6 +8,7 @@
#include <common.h> #include <asm/io.h> +#include <asm/arch/clk.h> #include <asm/arch/at91sam9g45_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> @@ -15,6 +16,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/clk.h> #include <lcd.h> +#include <linux/mtd/nand.h> #include <atmel_lcdc.h> #include <atmel_mci.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) @@ -71,6 +73,84 @@ void at91sam9m10g45ek_nand_hw_init(void) } #endif
+#if defined(CONFIG_SPL_BUILD) +#include <spl.h> +#include <nand.h> + +void at91_spl_board_init(void) +{ + /* + * On the at91sam9m10g45ek board, the chip wm9711 stays in the + * test mode, so it needs do some action to exit test mode. + */ + at91_periph_clk_enable(ATMEL_ID_PIODE); + at91_set_gpio_output(AT91_PIN_PD7, 0); + at91_set_gpio_output(AT91_PIN_PD8, 0); + at91_set_pio_pullup(AT91_PIO_PORTD, 7, 1); + at91_set_pio_pullup(AT91_PIO_PORTD, 8, 1); + +#ifdef CONFIG_SYS_USE_MMC + at91_mci_hw_init(); +#elif CONFIG_SYS_USE_NANDFLASH + at91sam9m10g45ek_nand_hw_init(); +#endif +} + +#include <asm/arch/atmel_mpddrc.h> +static void ddr2_conf(struct atmel_mpddr *ddr2) +{ + ddr2->md = (ATMEL_MPDDRC_MD_DBW_16_BITS | ATMEL_MPDDRC_MD_DDR2_SDRAM); + + ddr2->cr = (ATMEL_MPDDRC_CR_NC_COL_10 | + ATMEL_MPDDRC_CR_NR_ROW_14 | + ATMEL_MPDDRC_CR_DQMS_SHARED | + ATMEL_MPDDRC_CR_CAS_DDR_CAS3); + + ddr2->rtr = 0x24b; + + ddr2->tpr0 = (6 << ATMEL_MPDDRC_TPR0_TRAS_OFFSET |/* 6*7.5 = 45 ns */ + 2 << ATMEL_MPDDRC_TPR0_TRCD_OFFSET |/* 2*7.5 = 15 ns */ + 2 << ATMEL_MPDDRC_TPR0_TWR_OFFSET | /* 2*7.5 = 15 ns */ + 8 << ATMEL_MPDDRC_TPR0_TRC_OFFSET | /* 8*7.5 = 60 ns */ + 2 << ATMEL_MPDDRC_TPR0_TRP_OFFSET | /* 2*7.5 = 15 ns */ + 1 << ATMEL_MPDDRC_TPR0_TRRD_OFFSET | /* 1*7.5= 7.5 ns*/ + 1 << ATMEL_MPDDRC_TPR0_TWTR_OFFSET | /* 1 clk cycle */ + 2 << ATMEL_MPDDRC_TPR0_TMRD_OFFSET); /* 2 clk cycles */ + + ddr2->tpr1 = (2 << ATMEL_MPDDRC_TPR1_TXP_OFFSET | /* 2*7.5 = 15 ns */ + 200 << ATMEL_MPDDRC_TPR1_TXSRD_OFFSET | + 16 << ATMEL_MPDDRC_TPR1_TXSNR_OFFSET | + 14 << ATMEL_MPDDRC_TPR1_TRFC_OFFSET); + + ddr2->tpr2 = (1 << ATMEL_MPDDRC_TPR2_TRTP_OFFSET | + 0 << ATMEL_MPDDRC_TPR2_TRPA_OFFSET | + 7 << ATMEL_MPDDRC_TPR2_TXARDS_OFFSET | + 2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); +} + +void mem_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct at91_matrix *mat = (struct at91_matrix *)ATMEL_BASE_MATRIX; + struct atmel_mpddr ddr2; + unsigned long csa; + + ddr2_conf(&ddr2); + + /* enable DDR2 clock */ + writel(0x4, &pmc->scer); + + /* Chip select 1 is for DDR2/SDRAM */ + csa = readl(&mat->ebicsa); + csa |= AT91_MATRIX_EBI_CS1A_SDRAMC; + csa &= ~AT91_MATRIX_EBI_VDDIOMSEL_3_3V; + writel(csa, &mat->ebicsa); + + /* DDRAM2 Controller initialize */ + ddr2_init(ATMEL_BASE_CS6, &ddr2); +} +#endif + #ifdef CONFIG_CMD_USB static void at91sam9m10g45ek_usb_hw_init(void) { diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index 1681bc8..30d632d 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -1,3 +1,4 @@ +CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_MMC" -CONFIG_ARM=y -CONFIG_TARGET_AT91SAM9M10G45EK=y ++S:CONFIG_ARM=y ++S:CONFIG_TARGET_AT91SAM9M10G45EK=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index 61ae56e..b3de8a1 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -1,3 +1,4 @@ +CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_NANDFLASH" -CONFIG_ARM=y -CONFIG_TARGET_AT91SAM9M10G45EK=y ++S:CONFIG_ARM=y ++S:CONFIG_TARGET_AT91SAM9M10G45EK=y diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index db5d5ea..77379f5 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -26,7 +26,9 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG +#ifndef CONFIG_SPL_BUILD #define CONFIG_SKIP_LOWLEVEL_INIT +#endif #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DISPLAY_CPUINFO
@@ -98,8 +100,12 @@ #define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS6 #define CONFIG_SYS_SDRAM_SIZE 0x08000000
+#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_INIT_SP_ADDR 0x310000 +#else #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE) +#endif
/* NAND flash */ #ifdef CONFIG_CMD_NAND @@ -203,4 +209,63 @@ */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000)
+/* Defines for SPL */ +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x300000 +#define CONFIG_SPL_MAX_SIZE 0x010000 + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_GPIO_SUPPORT + +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SYS_MONITOR_LEN 0x80000 + +#ifdef CONFIG_SYS_USE_MMC + +#define CONFIG_SPL_BSS_START_ADDR 0x70000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x00080000 +#define CONFIG_SYS_SPL_MALLOC_START 0x70080000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00080000 + +#define CONFIG_SPL_LDSCRIPT arch/arm/cpu/at91-common/u-boot-spl-arm9.lds +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x400 +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x200 +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT + +#elif CONFIG_SYS_USE_NANDFLASH +#define CONFIG_SYS_NAND_ENABLE_PIN_SPL (2 * 32 + 14) +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_ECC +#define CONFIG_SPL_NAND_SOFTECC +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 +#define CONFIG_SYS_NAND_5_ADDR_CYCLE + +#define CONFIG_SYS_NAND_PAGE_SIZE 0x800 +#define CONFIG_SYS_NAND_BLOCK_SIZE 0x20000 +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCSIZE 256 +#define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ + 48, 49, 50, 51, 52, 53, 54, 55, \ + 56, 57, 58, 59, 60, 61, 62, 63, } +#endif + +#define CONFIG_SPL_ATMEL_SIZE +#define CONFIG_SYS_MASTER_CLOCK 132096000 +#define CONFIG_SYS_AT91_PLLA 0x20c73f03 +#define CONFIG_SYS_MCKR 0x1301 +#define CONFIG_SYS_MCKR_CSS 0x1302 + +#define ATMEL_BASE_MPDDRC ATMEL_BASE_DDRSDRC0 #endif diff --git a/include/configs/corvus.h b/include/configs/corvus.h index 5b50c1d..d6ef69a 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -37,7 +37,9 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG +#ifndef CONFIG_SPL_BUILD #define CONFIG_SKIP_LOWLEVEL_INIT +#endif #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DISPLAY_CPUINFO
@@ -89,8 +91,12 @@ #define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS6 #define CONFIG_SYS_SDRAM_SIZE 0x08000000
/* No NOR flash */ #define CONFIG_SYS_NO_FLASH @@ -160,7 +166,6 @@ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_TEXT_BASE 0x300000 #define CONFIG_SPL_MAX_SIZE (12 * 1024) -#define CONFIG_SPL_STACK (16 * 1024)
#define CONFIG_SPL_BSS_START_ADDR CONFIG_SPL_MAX_SIZE #define CONFIG_SPL_BSS_MAX_SIZE (2 * 1024) diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 20194ae..060544a 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -45,7 +45,9 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG +#ifndef CONFIG_SPL_BUILD #define CONFIG_SKIP_LOWLEVEL_INIT +#endif #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DISPLAY_CPUINFO
@@ -93,8 +95,12 @@ * leaving the correct space for initial global data structure above * that address while providing maximum stack area below. */ +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_INIT_SP_ADDR (16 * 1024) +#else # define CONFIG_SYS_INIT_SP_ADDR \ (ATMEL_BASE_SRAM1 + 0x1000 - GENERATED_GBL_DATA_SIZE) +#endif
/* NAND flash */ #ifdef CONFIG_CMD_NAND @@ -172,7 +178,6 @@ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_TEXT_BASE 0x0 #define CONFIG_SPL_MAX_SIZE (11 * 1024) -#define CONFIG_SPL_STACK (16 * 1024)
#define CONFIG_SPL_BSS_START_ADDR CONFIG_SPL_MAX_SIZE #define CONFIG_SPL_BSS_MAX_SIZE (3 * 1024)
Hi Bo,
just a short review, more will follow this weekend.
- select SUPPORT_SPL
I'm fine with having two variants of lowlevel_init for a time, but we should consolidate this and use C-style initialisation of SDRAM and stuff for the other armv5 at91 devices in future. AFAIK the a/a/c/arm926ejs/at91/lowlevel_init.S is mainly used for NOR Flash boots, so using the SPL code (but not necessarily the two binary mechanism) for the NOR Flash boots in future is appreciated.
- A lowlevel_init function that sets up the stack to call a C function to
- perform further init.
- (C) Copyright 2010
- Texas Instruments, <www.ti.com>
- Author :
- Aneesh V aneesh@ti.com
- ldr sp, =CONFIG_SYS_INIT_SP_ADDR
- bic sp, sp, #7 /* 8-byte alignment for ABI compliance */
- ldr r9, =gdata
I remember some patches removing the SPL gdata stuff, is that true?
- push {ip, lr}
- bl s_init
- pop {ip, pc}
Rest of this patch will be reviewed later.
Best regards
Andreas Bießmann
Hi Andreas,
On 01/16/2015 05:10 PM, Andreas Bießmann wrote:
Hi Bo,
select SUPPORT_SPL
OK, when all the arm9 at91 related board has SPL support, then I will do this.
- Author :
- ldr r9, =gdata
Thanks.
Yes, just search for it, the following patch do this. http://patchwork.ozlabs.org/patch/423789/ (arm: Reduce the scope of lowlevel_init())
- push {ip, lr}
- bl s_init
- pop {ip, pc}
Thanks.
Best regards
Andreas Bießmann
Best Regards, Bo Shen
Hi Bo,
Can we achieve this in this MW?
- ldr r9, =gdata
Thanks.
I think we should use the function provided there. What do you think?
Best regards
Andreas Bießmann
Hi Andreas,
On 01/16/2015 06:16 PM, Andreas Bießmann wrote:
Hi Bo,
I will try, but not sure. As I don't have this kind of board :( I need to check whether we still have this kind of board.
- ldr r9, =gdata
Thanks.
OK. I will do it in next version. Thanks.
Best regards
Andreas Bießmann
Hello Bo,
added Simon to cc ...
Am 19.01.2015 02:41, schrieb Bo Shen:
Hi Andreas,
Hi Bo,
- ldr r9, =gdata
Thanks.
Hmm... looking into this patch [1] ... it says:
+ * Call the very early init function. This should do only the + * absolute bare minimum to get started. It should not: + * + * - set up DRAM + * - use global_data + * - clear BSS + * - try to start a console
but if we have small init ram for SPL (like on the sam9260 with 4k sram) we should init here SDRAM, so we could set bss and stack into RAM in board_init_f, which is called after this function.
So we should rework the comment here ... or?
bye, Heiko [1] http://patchwork.ozlabs.org/patch/423789/
Hi Heiko,
On 18 January 2015 at 23:15, Heiko Schocher hs@denx.de wrote:
Hello Bo,
Hi Andreas,
Hi Bo,
- ldr r9, =gdata
Please don't use 'gdata', we are trying to get rid of it throughout U-Boot in the next week or so. The global_data pointer is managed by crt0.S. You cannot use it in lowlevel_init.
Thanks.
* - set up DRAM
* - use global_data
* - clear BSS
I don't see any need to init DRAM before board_init_f(). What is needed here?
Also I believe board_init_f() should not touch BSS in SPL (as with U-Boot proper).
Hello Bo
Am 16.01.2015 03:53, schrieb Bo Shen:
Acked-by: Heiko Schocher hs@denx.de
but it does not boot on the corvus board ... please add this fix to your patch:
diff --git a/include/configs/corvus.h b/include/configs/corvus.h index efc8ce5..dc25d95 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -90,7 +90,7 @@ #define CONFIG_SYS_SDRAM_SIZE 0x08000000
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SYS_INIT_SP_ADDR 0x310000 +#define CONFIG_SYS_INIT_SP_ADDR (16 * 1024) #else #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE)
Tested your patch also on the taurus board, there it boots fine!
so, after you fixed the corvus board, you can add my: Tested-by: Heiko Schocher hs@denx.de
Thanks! And one question ...
- Author :
Could we use here a new define (saying CONFIG_SYS_INIT_SP_LOWLEVEL)?
Benefit would be, we can setup first the stack in sram, and after RAM init, which is done with your patch very early, we can set the stack with CONFIG_SYS_INIT_SP_ADDR into RAM!
With using CONFIG_SYS_INIT_SP_ADDR here, the stack gets set twice to CONFIG_SYS_INIT_SP_ADDR ... I just try to get SPL on an atsam9260 based board working with only 4k sram ... so it would be nice to have stack also optionally in RAM ... but we have problems with the debugger adapter on the board ... so I have to wait some more days to try this part ...
bye, Heiko
Hi Heiko,
On 01/16/2015 07:35 PM, Heiko Schocher wrote:
Hello Bo
Thanks.
Thanks, I will add this fix into next version.
function to
- Author :
This just for the at91sam9260 based boards, not for others. Or else, we also need to add this definition for other boards. Can you do the following check?
#ifdef CONFIG_SYS_INIT_SP_LOWLEVEL ldr sp, =CONFIG_SYS_INIT_SP_LOWLEVEL #else ldr sp, =CONFIG_SYS_INIT_SP_ADDR #endif
If it is acceptable, can you add through your patches, as I my patch nowhere will use it.
bye, Heiko
Hello Bo,
Am 19.01.2015 02:38, schrieb Bo Shen:
Hi Heiko,
Hello Bo
Thanks.
Thanks!
function to
- Author :
Or we check if "CONFIG_SYS_INIT_SP_LOWLEVEL" is defined, if not we set default to: #define CONFIG_SYS_INIT_SP_LOWLEVEL CONFIG_SYS_INIT_SP_ADDR
so, something like:
diff --git a/arch/arm/cpu/arm926ejs/at91/spl_lowlevel_init.S b/arch/arm/cpu/arm926ejs/at91/spl_lowlevel_init.S index f1b2ec9..ed9adc7 100644 --- a/arch/arm/cpu/arm926ejs/at91/spl_lowlevel_init.S +++ b/arch/arm/cpu/arm926ejs/at91/spl_lowlevel_init.S @@ -15,11 +15,15 @@ #include <config.h> #include <linux/linkage.h>
+#ifndef CONFIG_SYS_INIT_SP_ADDR_LOWLEVEL +#define CONFIG_SYS_INIT_SP_ADDR_LOWLEVEL CONFIG_SYS_INIT_SP_ADDR +#endif + ENTRY(lowlevel_init) /* * Setup a temporary stack */ - ldr sp, =CONFIG_SYS_INIT_SP_ADDR + ldr sp, =CONFIG_SYS_INIT_SP_ADDR_LOWLEVEL bic sp, sp, #7 /* 8-byte alignment for ABI compliance */
ldr r9, =gdata
so we do not need to adapt existing boards, just add an entry in README, that we have such a possibility now for at91 boards ...
bye, Heiko
Andreas Bießmann
Bo Shen
Heiko Schocher
