[U-Boot] [PATCH 1/2] tegra: init MMC from common board init
Signed-off-by: Lucas Stach dev@lynxeye.de CC: Stephen Warren swarren@wwwdotorg.org CC: Tom Warren TWarren@nvidia.com --- board/nvidia/common/board.c | 4 ++++ 1 Datei geändert, 4 Zeilen hinzugefügt(+)
diff --git a/board/nvidia/common/board.c b/board/nvidia/common/board.c index 7ab2040..3bd4ff1 100644 --- a/board/nvidia/common/board.c +++ b/board/nvidia/common/board.c @@ -132,6 +132,10 @@ int board_init(void) board_usb_init(gd->fdt_blob); #endif
+#ifdef CONFIG_TEGRA_MMC + board_mmc_init(gd->fdt_blob); +#endif + #ifdef CONFIG_TEGRA20_LP0 /* save Sdram params to PMC 2, 4, and 24 for WB0 */ warmboot_save_sdram_params();
Most boards don't need this fixup hook. To avoid a lot of empty implementations in board files convert it to a weak symbol.
Signed-off-by: Lucas Stach dev@lynxeye.de CC: Stephen Warren swarren@wwwdotorg.org CC: Tom Warren TWarren@nvidia.com --- board/avionic-design/common/tamonten.c | 7 ------- board/compal/paz00/paz00.c | 7 ------- board/compulab/trimslice/trimslice.c | 7 ------- board/nvidia/common/board.c | 5 +++++ board/nvidia/harmony/harmony.c | 7 ------- board/nvidia/whistler/whistler.c | 7 ------- 6 Dateien geändert, 5 Zeilen hinzugefügt(+), 35 Zeilen entfernt(-)
diff --git a/board/avionic-design/common/tamonten.c b/board/avionic-design/common/tamonten.c index a0a4d1d..f5e6f6d 100644 --- a/board/avionic-design/common/tamonten.c +++ b/board/avionic-design/common/tamonten.c @@ -41,13 +41,6 @@ #include <mmc.h> #endif
-/* - * Routine: gpio_config_uart - * Description: Does nothing on Tamonten - no conflict w/SPI. - */ -void gpio_config_uart(void) -{ -}
#ifdef CONFIG_BOARD_EARLY_INIT_F void gpio_early_init(void) diff --git a/board/compal/paz00/paz00.c b/board/compal/paz00/paz00.c index cd684f2..59cf41b 100644 --- a/board/compal/paz00/paz00.c +++ b/board/compal/paz00/paz00.c @@ -24,13 +24,6 @@ #include <mmc.h> #endif
-/* - * Routine: gpio_config_uart - * Description: Does nothing on Paz00 - no conflict w/SPI. - */ -void gpio_config_uart(void) -{ -}
#ifdef CONFIG_TEGRA_MMC /* diff --git a/board/compulab/trimslice/trimslice.c b/board/compulab/trimslice/trimslice.c index 5dae15b..f6de19e 100644 --- a/board/compulab/trimslice/trimslice.c +++ b/board/compulab/trimslice/trimslice.c @@ -34,13 +34,6 @@ #include <mmc.h> #endif
-/* - * Routine: gpio_config_uart - * Description: Does nothing on TrimSlice - no UART-related GPIOs. - */ -void gpio_config_uart(void) -{ -}
void pin_mux_spi(void) { diff --git a/board/nvidia/common/board.c b/board/nvidia/common/board.c index 3bd4ff1..c4304ac 100644 --- a/board/nvidia/common/board.c +++ b/board/nvidia/common/board.c @@ -72,6 +72,11 @@ void __pin_mux_spi(void)
void pin_mux_spi(void) __attribute__((weak, alias("__pin_mux_spi")));
+void __gpio_config_uart(void) +{ +} + +void gpio_config_uart(void) __attribute__((weak, alias("__gpio_config_uart"))); /* * Routine: power_det_init * Description: turn off power detects diff --git a/board/nvidia/harmony/harmony.c b/board/nvidia/harmony/harmony.c index 44977c7..5b75230 100644 --- a/board/nvidia/harmony/harmony.c +++ b/board/nvidia/harmony/harmony.c @@ -33,13 +33,6 @@ #include <mmc.h> #endif
-/* - * Routine: gpio_config_uart - * Description: Does nothing on Harmony - no conflict w/SPI. - */ -void gpio_config_uart(void) -{ -}
#ifdef CONFIG_TEGRA_MMC /* diff --git a/board/nvidia/whistler/whistler.c b/board/nvidia/whistler/whistler.c index c0a114d..cad7c48 100644 --- a/board/nvidia/whistler/whistler.c +++ b/board/nvidia/whistler/whistler.c @@ -34,13 +34,6 @@ #include <mmc.h> #endif
-/* - * Routine: gpio_config_uart - * Description: Does nothing on Whistler - no UART-related GPIOs. - */ -void gpio_config_uart(void) -{ -}
/* * Routine: pin_mux_mmc
This seems OK on the surface, but I think there may be more opportunity for cleanup here.
In board/nvidia/common/board.c, I see both of the following:
board_init:
#ifdef CONFIG_SPI_UART_SWITCH gpio_config_uart(); #endif
board_early_init_f:
/* Initialize periph GPIOs */ gpio_early_init(); #ifdef CONFIG_SPI_UART_SWITCH gpio_early_init_uart(); #else gpio_config_uart(); #endif
and in arch/arm/cpu/arm720t/tegra20/spl.c:
board_init_f:
It sure seems like we don't need to call those two init function all those times. Perhaps we can clarify which of the functions are actually needed at all, and when they should be called.
Hi Stephen,
Am Dienstag, den 07.08.2012, 11:09 -0600 schrieb Stephen Warren:
I looked a bit deeper into this and it seems that in fact the logic of all those calls are correct and none them could be removed.
To clarify what's going on: if we are building without CONFIG_SPI_UART_SWITCH the board file has to provide a function gpio_config_uart() to ensure correct GPIO setting and it's correct to call this in early_init.
Now, if we build with CONFIG_SPI_UART_SWITCH set, the board file stops providing the gpio_config_uart() and the UART switch provides a gpio_early_init_uart() function which does essentially the same, so we call this instead in early init.
The confusing part is that the UART switch now provides a function also named gpio_config_uart(), which redoes the GPIO setting after relocation and does some internal state setting.
Now while explaining all this in this email I see how we should make this more clear with some reasonable renaming, but we won't get around the weak symbol if we want to keep the possibility for boards to build without CONFIG_SPI_UART_SWITCH. I'll spin a new patch to untangle this mess a bit.
Thanks, Lucas
board_init:
board_early_init_f:
board_init_f:
There's no description here justifying why you want this change.
I don't think the change is correct; in arch/arm/lib/board.c, board_init_r() calls drivers/mmc/mmc.c:mmc_initialize() which calls board_mmc_init(). With this patch, won't this function get called twice?
Am Dienstag, den 07.08.2012, 11:04 -0600 schrieb Stephen Warren:
Please disregard this patch. It was only needed because of an error on my side.
Sorry for the inconvenience.
Lucas Stach
Stephen Warren
