Serial console via USB on U-boot error
Hi U-boot team,
We have realized that, on NXP i.MX93-EVK, when switching the console to usb:
u-boot=> setenv stdin usbacm; setenv stdout usbacm; setenv stderr usbacm
On a Linux host the gadget is detected-
Bus 003 Device 101: ID 1fc9:0134 NXP Semiconductors USB download gadget
However, Linux dmesg host shows an error.
[1138006.159559] usb 3-1: new high-speed USB device number 101 using xhci_hcd [1138006.309162] usb 3-1: config 1 interface 1 altsetting 0 has a duplicate endpoint with address 0x81, skipping [1138006.310989] usb 3-1: New USB device found, idVendor=1fc9, idProduct=0134, bcdDevice= 2.21 [1138006.311004] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [1138006.311011] usb 3-1: Product: USB download gadget [1138006.311029] usb 3-1: Manufacturer: FSL [1138006.311033] usb 3-1: SerialNumber: e6a3c0352fb31ff6 [1138006.314521] cdc_acm: probe of 3-1:1.0 failed with error -22
I checked that endpoints are misconfigured. For a CDC device, configuration 1 has one IN interrupt endpoint, and configuraton 2 has two bulk endpoints (IN/OUT). Although they are set on that way, for U-boot implementation was using EP1_IN for both configurations. This issue is also present on iMX8MM-EVK as well since it uses the Chipidea (CI) USB IP (same as iMX93).
Attached is a patch containing the fix for this issue which adds a specific case for CI USB in the usb_ep_autoconfig function so that the endpoint's name of the USB IP matches with the corresponding USB endpoint descriptor.
CONFIG_CI_UDC needs to be set to 'y' for this fix to work, as it makes use of the gadget_is_ci macro to identify the USB IP.
We are sending this email since the epautoconf.c file is part of the uboot code.
Is there are additional specific requirements to request integrating this patch into U-Boot code?
Thanks in advance and best regards!
/Carlos
Hi Carlos,
On Fri, Sep 20, 2024 at 11:39 PM Chema Casillas Mora carlos.mora@nxp.com wrote:
Please follow the guidelines below and submit a formal patch:
https://docs.u-boot.org/en/latest/develop/sending_patches.html
Chema Casillas Mora
Fabio Estevam
