[U-Boot] [PATCH] imx: nitrogen6x: fix USB host initialization
USB Host scanning has been broken since v2016.05.
This is due to all the USB changes that happened between v2016.03 and v2016.05, especially: 2ef117fe4f usb: Remove 200 ms delay in usb_hub_port_connect_change() a22a264ec3 usb: Change power-on / scanning timeout handling
So we need to increase the init delay to 2s using the usb_pgood_delay environment variable.
Signed-off-by: Gary Bisson gary.bisson@boundarydevices.com --- include/configs/nitrogen6x.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index c22fed70a4..72ff5c1eab 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -137,6 +137,7 @@ "fdt_addr=0x18000000\0" \ "boot_fdt=try\0" \ "ip_dyn=yes\0" \ + "usb_pgood_delay=2000\0" \ "mmcdevs=0 1\0" \ "mmcpart=1\0" \ "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ @@ -206,6 +207,7 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "bootdevs=" CONFIG_DRIVE_TYPES "\0" \ "umsdevs=" CONFIG_UMSDEVS "\0" \ + "usb_pgood_delay=2000\0" \ "console=ttymxc1\0" \ "clearenv=if sf probe || sf probe || sf probe 1 ; then " \ "sf erase 0xc0000 0x2000 && " \
- "usb_pgood_delay=2000\0" \ "mmcdevs=0 1\0" \ "mmcpart=1\0" \ "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \
- "usb_pgood_delay=2000\0" \ "console=ttymxc1\0" \ "clearenv=if sf probe || sf probe || sf probe 1 ; then " \ "sf erase 0xc0000 0x2000 && " \
Best regards, Stefano Babic
Gary Bisson
Stefano Babic
