[U-Boot] [PATCH v3 0/5] usb : musb : Add MUSB contorller driver and enable Davinci MSC support
This patch series adds Mentor Graphics USB OTG host controller driver support and MSC support for DM6446 (TI DaVinci) platform.
- [PATCH v3 1/5] usb : musb : Adding host controller driver for Mentor USB controller. - [PATCH v3 2/5] usb : musb : Adding USB VBUS enable functionality for DM6446 DVEVM. - [PATCH v3 3/5] usb : musb : Adding DM6446 (TI DaVinci) platform specific USB support. - [PATCH v3 4/5] usb : musb : Enabling DM6446 (TI DaVinci) USB module power. - [PATCH v3 5/5] usb : musb : Enabling USB MSC support for DM6446 (TI DaVinci) platform.
Note: This patch series depends on the following patch submitted by Michael Trimarchi.
- [U-Boot] [USB PATCH] USB change speed
Changes since v2:
- Addressed changes suggested by Dirk Behme - Added register overlay structure to access mentor USB module registers
Changes since v1:
- Rebased to U-Boot USB next branch - Removed high element from usb_device structure
Changes since v2:
which one no comment have been send to the ML?
Best Regards, J.
Jean,
-----Original Message----- From: Jean-Christophe PLAGNIOL-VILLARD [mailto:plagnioj@jcrosoft.com] Sent: Sunday, January 04, 2009 12:51 PM Subject: Re: [U-Boot] [PATCH v3 0/5] usb : musb : Add MUSB contorller driver and enable Davinci MSC support
<snip>
Changes since v2:
It somehow missed being posted to the mailing list.
Best Regards, J.
Thanks, Thomas.
do you have a git tree or you just using the u-boot usb next git tree ?
also, what about the feedback Bryan sent you ? i glanced at the comments he made and the source is unchanged from what i can see. -mike
Mike,
-----Original Message----- From: Mike Frysinger [mailto:vapier@gentoo.org] Sent: Sunday, January 04, 2009 11:00 PM Subject: Re: [U-Boot] [PATCH v3 0/5] usb : musb : Add MUSB contorller driver and enable Davinci MSC support
<snip>
The Davinci USB patches are against the U-Boot USB 'next' branch.
I am sorry for having missed the feedback from Bryan (did not read the emails received during vacation). I will included his comments as well.
Thanks, Thomas.
Hello Thomas,
2009/1/4 Thomas Abraham t-abraham@ti.com:
Before I loose track of all the versionnumbers of all the different series that are somehow dependant on each other, I moved this series to the 'testing' branch of u-boot-usb. I leave the door open for an update of this series when there are major comments on it.
Kind Regards,
Remy
Changes since v2:
Changes since v1:
Hi Thomas,
I'm still debugging the MUSB driver on my Blackfin board. I got a issue here: https://blackfin.uclinux.org/gf/project/u-boot/tracker/?action=TrackerItemEd...
1. when the board power on and run 'usb start', the usb function is ok for usb storage usage. 2. then I tried 'usb stop'. and run 'usb start' again. usb device cannot be found.
Is that OK on davinci or omap platform?
Thanks -Bryan
Changes since v2:
Changes since v1:
Hi Bryan,
Sorry for the delayed reply. The sequence 'usb start' -> 'usb stop' -> 'usb start' works fine on Davinci and OMAP platforms.
Thanks, Thomas.
-----Original Message----- From: cooloney.lkml@gmail.com [mailto:cooloney.lkml@gmail.com] On Behalf Of Bryan Wu Sent: Thursday, January 15, 2009 2:16 PM To: Abraham, Thomas Cc: u-boot@lists.denx.de; Gupta, Ajay Kumar; Subbrathnam, Swaminathan; B, Ravi Subject: Re: [U-Boot] [PATCH v3 0/5] usb : musb : Add MUSB contorller driver and enable Davinci MSC support
Hi Thomas,
I'm still debugging the MUSB driver on my Blackfin board. I got a issue here: https://blackfin.uclinux.org/gf/project/u-boot/tracker/?action =TrackerItemEdit&tracker_id=153&tracker_item_id=4794
- when the board power on and run 'usb start', the usb
Thanks -Bryan
controller driver
USB module power.
Changes since v2:
registers
Changes since v1:
On Sat, Jan 17, 2009 at 5:22 PM, Abraham, Thomas t-abraham@ti.com wrote:
Hi Bryan,
Thanks for the reply. And 2 more questions:
- there is no timeout control in the wait_until_xxx_ready() functions, so when there no device plugged in u-boot will hang in these endless loops. - there is no root hub control, so we cannot use 'usb info' to get device 0 root hub config info
do you have any plan to add these?
Best Regards, -Bryan
Thanks, Thomas.
Hi Thomas,
Thanks -Bryan
controller driver
USB module power.
Changes since v2:
registers
Changes since v1:
participants (6)
Abraham, Thomas
Bryan Wu
Mike Frysinger
Remy Bohmer
Thomas Abraham
