[U-Boot] Kernel hang when replace older uboot with uboot master
Hi all, This log show the bootlog that when I replace older uboot with uboot master on my machine. Any hints will be appreciated!!!
## Current stack ends at 0x87f5db80 * kernel: cmdline image address = 0x9f060000 ## Booting kernel from Legacy Image at 9f060000 ... Image Name: MIPS OpenWrt Linux-4.14.101 Image Type: MIPS Linux Kernel Image (lzma compressed) Data Size: 1615030 Bytes = 1.5 MiB Load Address: 80060000 Entry Point: 80060000 Verifying Checksum ... OK kernel data at 0x9f060040, len = 0x0018a4b6 (1615030) ## No init Ramdisk ramdisk start = 0x00000000, ramdisk end = 0x00000000 ## No Flattened Device Tree Continuing to boot without FDT Initial value for argc=3 Final value for argc=3 Uncompressing Kernel Image ... LZMA: Image address............... 0x9f060040 LZMA: Properties address.......... 0x9f060040 LZMA: Uncompressed size address... 0x9f060045 LZMA: Compressed data address..... 0x9f06004d LZMA: Destination address......... 0x80060000 LZMA: Uncompresed size............ 0x4e4f49 LZMA: Compresed size.............. 0x18a4b1 LZMA: Uncompressed ............... 0x4e4f49 OK kernel loaded at 0x80060000, end = 0x80544f49 ## initrd_high = 0x88000000, copy_to_ram = 1 ramdisk load start = 0x00000000, ramdisk load end = 0x00000000 Initial value for argc=3 Final value for argc=3 Initial value for argc=3 Final value for argc=3 ## initrd_high = 0x88000000, copy_to_ram = 1 ramdisk load start = 0x00000000, ramdisk load end = 0x00000000 ## cmdline argv at 0xa7f70e40, argp at 0xa7f7127d arg 001: console=ttyS0,115200 arg 002: root=/dev/mtdblock5 arg 003: rootfstype=squashfs ## Giving linux memsize in MB, 128 ## Transferring control to Linux (at address 80060000) ... [ 0.000000] Linux version 4.14.101 (xxx@xxx-PC) (gcc version 7.4.0 (OpenWrt GCC 7.4.0 r8997-488af51f81)) #0 Mon Feb 18 15:11:32 2019 [ 0.000000] bootconsole [early0] enabled [ 0.000000] CPU0 revision is: 00019750 (MIPS 74Kc) [ 0.000000] MIPS: machine is ROSINSON WR818 [ 0.000000] SoC: Qualcomm Atheros QCA956X ver 1 rev 0 [ 0.000000] Determined physical RAM map: [ 0.000000] memory: 08000000 @ 00000000 (usable) [ 0.000000] Initrd not found or empty - disabling initrd [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes. [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff] [ 0.000000] random: get_random_bytes called from start_kernel+0x8c/0x474 with crng_init=0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512 [ 0.000000] Kernel command line: console=ttyS0,115200n8 rootfstype=squashfs,jffs2 [ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes) [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) [ 0.000000] Writing ErrCtl register=00000000 [ 0.000000] Readback ErrCtl register=00000000 [ 0.000000] Memory: 123184K/131072K available (3777K kernel code, 150K rwdata, 912K rodata, 1232K init, 204K bss, 7888K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] NR_IRQS: 51 [ 0.000000] CPU clock: 775.000 MHz [ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 4932285024 ns [ 0.000007] sched_clock: 32 bits at 387MHz, resolution 2ns, wraps every 5541893118ns [ 0.008841] Calibrating delay loop... 385.84 BogoMIPS (lpj=1929216) [ 0.075897] pid_max: default: 32768 minimum: 301 [ 0.081291] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.088805] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.100199] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.111385] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.118371] pinctrl core: initialized pinctrl subsystem [ 0.125118] NET: Registered protocol family 16 [ 0.152756] clocksource: Switched to clocksource MIPS [ 0.159367] NET: Registered protocol family 2 [ 0.164968] TCP established hash table entries: 1024 (order: 0, 4096 bytes) [ 0.172929] TCP bind hash table entries: 1024 (order: 0, 4096 bytes) [ 0.180151] TCP: Hash tables configured (established 1024 bind 1024) [ 0.187497] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.194172] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.201498] NET: Registered protocol family 1 [ 0.209200] Crashlog allocated RAM at address 0x3f00000 [ 0.216285] workingset: timestamp_bits=30 max_order=15 bucket_order=0 [ 0.227594] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.234248] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc. [ 0.253131] io scheduler noop registered [ 0.257584] io scheduler deadline registered (default) [ 0.263708] ar7200-usb-phy usb-phy: phy reset is missing [ 0.271233] pinctrl-single 1804002c.pinmux: 544 pins at pa b804002c size 68 [ 0.280104] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled [ 0.287943] console [ttyS0] disabled [ 0.292032] 18020000.uart: ttyS0 at MMIO 0x18020000 (irq = 8, base_baud = 1562500) is a 16550A [ 0.301853] console [ttyS0] enabled [ 0.301853] console [ttyS0] enabled [ 0.309411] bootconsole [early0] disabled [ 0.309411] bootconsole [early0] disabled [ 0.332426] m25p80 spi0.0: w25q128 (16384 Kbytes) [ 0.337373] 5 fixed-partitions partitions found on MTD device spi0.0 [ 0.343943] Creating 5 MTD partitions on "spi0.0": [ 0.348898] 0x000000000000-0x000000040000 : "u-boot" [ 0.354737] 0x000000040000-0x000000050000 : "u-boot-env" [ 0.360856] 0x000000050000-0x000000060000 : "factory" [ 0.366741] 0x000000060000-0x000000fe0000 : "firmware" [ 0.374897] 2 uimage-fw partitions found on MTD device firmware [ 0.381019] Creating 2 MTD partitions on "firmware": [ 0.386186] 0x000000000000-0x000000190000 : "kernel" [ 0.391956] 0x000000190000-0x000000f80000 : "rootfs" [ 0.397706] mtd: device 5 (rootfs) set to be root filesystem [ 0.403623] 1 squashfs-split partitions found on MTD device rootfs [ 0.410014] 0x000000440000-0x000000f80000 : "rootfs_data" [ 0.416213] 0x000000ff0000-0x000001000000 : "art" [ 0.422610] libphy: Fixed MDIO Bus: probed [ 0.763118] libphy: ag71xx_mdio: probed [ 0.770064] switch0: Atheros AR8337 rev. 2 switch registered on mdio-bus.0 [ 1.424562] ag71xx 19000000.eth: invalid MAC address, using random address [ 1.763918] ag71xx 19000000.eth: connected to PHY at mdio-bus.0:00 [uid=004dd036, driver=Atheros AR8216/AR8236/AR8316] [ 1.775514] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:SGMII [ 1.783553] NET: Registered protocol family 10 [ 1.791482] Segment Routing with IPv6 [ 1.795402] NET: Registered protocol family 17 [ 1.800029] 8021q: 802.1Q VLAN Support v1.8 [ 1.809949] SQUASHFS error: xz decompression failed, data probably corrupt [ 1.817103] SQUASHFS error: squashfs_read_data failed to read block 0x29f61c [ 1.824387] SQUASHFS error: Unable to read metadata cache entry [29f61c] [ 1.831302] SQUASHFS error: Unable to read inode 0x2146084e [ 1.837412] VFS: Cannot open root device "(null)" or unknown-block(31,5): error -5 [ 1.845254] Please append a correct "root=" boot option; here are the available partitions: [ 1.853888] 1f00 256 mtdblock0 [ 1.853892] (driver?) [ 1.860640] 1f01 64 mtdblock1 [ 1.860643] (driver?) [ 1.867396] 1f02 64 mtdblock2 [ 1.867399] (driver?) [ 1.874149] 1f03 15872 mtdblock3 [ 1.874153] (driver?) [ 1.880897] 1f04 1600 mtdblock4 [ 1.880900] (driver?) [ 1.887654] 1f05 14272 mtdblock5 [ 1.887657] (driver?) [ 1.894407] 1f06 11520 mtdblock6 [ 1.894410] (driver?) [ 1.901156] 1f07 64 mtdblock7 [ 1.901159] (driver?) [ 1.907912] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,5) [ 1.917125] Rebooting in 1 seconds..
rosysong@rosinson.com
