[PATCH 01/20] sh: Remove unused code in arch/sh/lib/bootm.c
There are no callers of the hexdump function that is guarded by CONFIG_SYS_DEBUG, so remove the section.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/sh/lib/bootm.c | 15 --------------- 1 file changed, 15 deletions(-)
diff --git a/arch/sh/lib/bootm.c b/arch/sh/lib/bootm.c index 9b71424dfe60..7ea04442b876 100644 --- a/arch/sh/lib/bootm.c +++ b/arch/sh/lib/bootm.c @@ -17,21 +17,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#ifdef CONFIG_SYS_DEBUG -static void hexdump(unsigned char *buf, int len) -{ - int i; - - for (i = 0; i < len; i++) { - if ((i % 16) == 0) - printf("%s%08x: ", i ? "\n" : "", - (unsigned int)&buf[i]); - printf("%02x ", buf[i]); - } - printf("\n"); -} -#endif - #ifdef CONFIG_SH_SDRAM_OFFSET #define GET_INITRD_START(initrd, linux) (initrd - linux + CONFIG_SH_SDRAM_OFFSET) #else
No platforms enable the functionality to tftp directly to NOR flash, and this is discouraged by the documentation. Remove this code. Further, this highlights an oddity of the code. Un-indent the start of this function.
Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com Signed-off-by: Tom Rini trini@konsulko.com --- README | 13 ----------- include/configs/kzm9g.h | 2 -- net/tftp.c | 52 +++++++++++------------------------------ 3 files changed, 13 insertions(+), 54 deletions(-)
diff --git a/README b/README index ff0df3797d21..74e37aa95cc4 100644 --- a/README +++ b/README @@ -1775,19 +1775,6 @@ Configuration Settings: If defined, hardware flash sectors protection is used instead of U-Boot software protection.
-- CONFIG_SYS_DIRECT_FLASH_TFTP: - - Enable TFTP transfers directly to flash memory; - without this option such a download has to be - performed in two steps: (1) download to RAM, and (2) - copy from RAM to flash. - - The two-step approach is usually more reliable, since - you can check if the download worked before you erase - the flash, but in some situations (when system RAM is - too limited to allow for a temporary copy of the - downloaded image) this option may be very useful. - - CONFIG_SYS_FLASH_CFI: Define if the flash driver uses extra elements in the common flash structure for storing flash geometry. diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index e084f87d14dd..f94cb54c7050 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -53,8 +53,6 @@ /* Timeout for Flash clear lock bit operations (in ms) */ #define CONFIG_SYS_FLASH_UNLOCK_TOUT (3 * 1000)
-#undef CONFIG_SYS_DIRECT_FLASH_TFTP - /* GPIO / PFC */ #define CONFIG_SH_GPIO_PFC
diff --git a/net/tftp.c b/net/tftp.c index bfc4c9bde9cb..451d73529f2a 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -17,9 +17,6 @@ #include <asm/global_data.h> #include <net/tftp.h> #include "bootp.h" -#ifdef CONFIG_SYS_DIRECT_FLASH_TFTP -#include <flash.h> -#endif
@@ -158,47 +155,24 @@ static inline int store_block(int block, uchar *src, unsigned int len) tftp_block_size; ulong newsize = offset + len; ulong store_addr = tftp_load_addr + offset; -#ifdef CONFIG_SYS_DIRECT_FLASH_TFTP - int i, rc = 0; - - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { - /* start address in flash? */ - if (flash_info[i].flash_id == FLASH_UNKNOWN) - continue; - if (store_addr >= flash_info[i].start[0]) { - rc = 1; - break; - } - } - - if (rc) { /* Flash is destination for this packet */ - rc = flash_write((char *)src, store_addr, len); - if (rc) { - flash_perror(rc); - return rc; - } - } else -#endif /* CONFIG_SYS_DIRECT_FLASH_TFTP */ - { - void *ptr; + void *ptr;
#ifdef CONFIG_LMB - ulong end_addr = tftp_load_addr + tftp_load_size; + ulong end_addr = tftp_load_addr + tftp_load_size;
- if (!end_addr) - end_addr = ULONG_MAX; + if (!end_addr) + end_addr = ULONG_MAX;
- if (store_addr < tftp_load_addr || - store_addr + len > end_addr) { - puts("\nTFTP error: "); - puts("trying to overwrite reserved memory...\n"); - return -1; - } -#endif - ptr = map_sysmem(store_addr, len); - memcpy(ptr, src, len); - unmap_sysmem(ptr); + if (store_addr < tftp_load_addr || + store_addr + len > end_addr) { + puts("\nTFTP error: "); + puts("trying to overwrite reserved memory...\n"); + return -1; } +#endif + ptr = map_sysmem(store_addr, len); + memcpy(ptr, src, len); + unmap_sysmem(ptr);
if (net_boot_file_size < newsize) net_boot_file_size = newsize;
int i, rc = 0;
continue;
rc = 1;
break;
if (rc) {
flash_perror(rc);
return rc;
} else
void *ptr;
void *ptr;
#ifdef CONFIG_LMB
if (!end_addr)
if (!end_addr)
return -1;
-#endif
unmap_sysmem(ptr);
return -1; }
unmap_sysmem(ptr); if (net_boot_file_size < newsize) net_boot_file_size = newsize;
-- 2.25.1
Acked-by: Ramon Fried rfried.dev@gmail.com
This converts the following to Kconfig: CONFIG_SYS_FLASH_EMPTY_INFO
Signed-off-by: Tom Rini trini@konsulko.com --- configs/MPC837XERDB_defconfig | 1 + configs/MPC8548CDS_36BIT_defconfig | 1 + configs/MPC8548CDS_defconfig | 1 + configs/MPC8548CDS_legacy_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/P2041RDB_NAND_defconfig | 1 + configs/P2041RDB_SDCARD_defconfig | 1 + configs/P2041RDB_SPIFLASH_defconfig | 1 + configs/P2041RDB_defconfig | 1 + configs/P3041DS_NAND_defconfig | 1 + configs/P3041DS_SDCARD_defconfig | 1 + configs/P3041DS_SPIFLASH_defconfig | 1 + configs/P3041DS_defconfig | 1 + configs/P4080DS_SDCARD_defconfig | 1 + configs/P4080DS_SPIFLASH_defconfig | 1 + configs/P4080DS_defconfig | 1 + configs/P5040DS_NAND_defconfig | 1 + configs/P5040DS_SDCARD_defconfig | 1 + configs/P5040DS_SPIFLASH_defconfig | 1 + configs/P5040DS_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 1 + configs/T2080QDS_SDCARD_defconfig | 1 + configs/T2080QDS_SECURE_BOOT_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 1 + configs/T2080QDS_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2080RDB_defconfig | 1 + configs/T2080RDB_revD_NAND_defconfig | 1 + configs/T2080RDB_revD_SDCARD_defconfig | 1 + configs/T2080RDB_revD_SPIFLASH_defconfig | 1 + configs/T2080RDB_revD_defconfig | 1 + configs/T4240RDB_SDCARD_defconfig | 1 + configs/T4240RDB_defconfig | 1 + configs/comtrend_ct5361_ram_defconfig | 1 + configs/comtrend_wap5813n_ram_defconfig | 1 + configs/huawei_hg556a_ram_defconfig | 1 + configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + configs/integratorcp_cm1136_defconfig | 1 + configs/integratorcp_cm920t_defconfig | 1 + configs/integratorcp_cm926ejs_defconfig | 1 + configs/integratorcp_cm946es_defconfig | 1 + configs/kmcent2_defconfig | 1 + configs/kzm9g_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043aqds_tfa_defconfig | 1 + configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_defconfig | 1 + configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 1 + configs/ls1046aqds_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_defconfig | 1 + configs/ls1046aqds_lpuart_defconfig | 1 + configs/ls1046aqds_nand_defconfig | 1 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/ls1088aqds_defconfig | 1 + configs/ls1088aqds_sdcard_ifc_defconfig | 1 + configs/ls1088aqds_tfa_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + configs/ls2088aqds_tfa_defconfig | 1 + configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 1 + configs/mccmon6_nor_defconfig | 1 + configs/mccmon6_sd_defconfig | 1 + configs/microblaze-generic_defconfig | 1 + configs/octeon_ebb7304_defconfig | 1 + configs/pg_wcom_expu1_defconfig | 1 + configs/pg_wcom_expu1_update_defconfig | 1 + configs/pg_wcom_seli8_defconfig | 1 + configs/pg_wcom_seli8_update_defconfig | 1 + configs/sfr_nb4-ser_ram_defconfig | 1 + configs/total_compute_defconfig | 1 + configs/vexpress_aemv8a_juno_defconfig | 1 + configs/vexpress_aemv8a_semi_defconfig | 1 + configs/vexpress_ca9x4_defconfig | 1 + configs/xtfpga_defconfig | 1 + drivers/mtd/Kconfig | 4 ++++ include/configs/MPC837XERDB.h | 2 -- include/configs/MPC8548CDS.h | 2 -- include/configs/P1010RDB.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/bmips_bcm6338.h | 1 - include/configs/bmips_bcm6348.h | 1 - include/configs/bmips_bcm6358.h | 1 - include/configs/bmips_bcm6368.h | 1 - include/configs/corenet_ds.h | 1 - include/configs/integrator-common.h | 1 - include/configs/km/pg-wcom-ls102xa.h | 1 - include/configs/kmcent2.h | 1 - include/configs/kzm9g.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043aqds.h | 1 - include/configs/ls1043ardb.h | 1 - include/configs/ls1046aqds.h | 1 - include/configs/ls1088aqds.h | 1 - include/configs/ls1088ardb.h | 1 - include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - include/configs/mccmon6.h | 1 - include/configs/microblaze-generic.h | 1 - include/configs/mx6sabreauto.h | 1 - include/configs/octeon_ebb7304.h | 1 - include/configs/p1_p2_rdb_pc.h | 2 -- include/configs/total_compute.h | 1 - include/configs/vexpress_aemv8.h | 1 - include/configs/vexpress_common.h | 1 - include/configs/xtfpga.h | 1 - include/configs/zynq-common.h | 1 - 188 files changed, 154 insertions(+), 40 deletions(-)
diff --git a/configs/MPC837XERDB_defconfig b/configs/MPC837XERDB_defconfig index efdddf7c2b3d..1004d3c80507 100644 --- a/configs/MPC837XERDB_defconfig +++ b/configs/MPC837XERDB_defconfig @@ -194,6 +194,7 @@ CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index 6fa89aad36a7..838a29a1ba8b 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -61,6 +61,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_PHY_ATHEROS=y diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index 82776497a592..2912b4446c68 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -60,6 +60,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_PHY_ATHEROS=y diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index c21ed57dc375..0f5b166f9987 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -60,6 +60,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_PHY_ATHEROS=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 7a50cd7f90d0..a4cf3ba22023 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -99,6 +99,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 5030afd098e7..0de8d87f1192 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -67,6 +67,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index dd04cff4a448..60b86d3a5e29 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -88,6 +88,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index 46613cce3b59..515c05053d2f 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -90,6 +90,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 49acfd2d38e5..9e303f378aab 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -98,6 +98,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 89fccd6fc324..982da33427fe 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -66,6 +66,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index a2786616c8de..71c1bb861e97 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -87,6 +87,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index 17daecd2ece9..69e3165c0b9e 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -89,6 +89,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 6b73bf43413e..e17bef8016ec 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -101,6 +101,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 7a5e057a2c22..d1a3edd16048 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -69,6 +69,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index ef85d48719c8..b8851f45a05b 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -90,6 +90,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index bda32ccbf342..893f2f84cdcf 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -92,6 +92,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 50667e56f6af..48687a91bc54 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -100,6 +100,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index c13369efe708..586630ae632b 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -68,6 +68,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 691d6e33dac4..08421403c6ae 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -89,6 +89,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index a630e961ee24..7915c8f6a2d9 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -91,6 +91,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 8288e858ed02..69d6493b1ed8 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -110,6 +110,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index b581cb109b16..e974b80420e0 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -97,6 +97,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index e8543c6461a1..016ae79d6938 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -99,6 +99,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 2b9fcb034c9c..9dd76803f6f2 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -77,6 +77,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index fdb163f49c2a..792a2fe7036f 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -109,6 +109,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 7489ad3459f4..47ff7ebf3715 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -96,6 +96,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 728592f6c3c8..ad3eda7cbfd2 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -98,6 +98,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index ada7e2d59a74..2b744decbbe4 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -76,6 +76,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 08392863371f..5d6ef2d173fa 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -112,6 +112,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index ddd9e335e642..7b8fe82de04b 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -99,6 +99,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 88365bff62b9..718f2ae2d200 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -101,6 +101,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index ef31e0970ace..3080e7add614 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index 99f1d26446e0..2df97ba559ad 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -114,6 +114,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 856a78fdd137..a4e684a99c1b 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -101,6 +101,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index b03c17c7e7b8..822f5f603d72 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -103,6 +103,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index c1a5ef9d30c5..0d697dbf8bdf 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -81,6 +81,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 2558596b161a..4c754560a958 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -113,6 +113,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 29cc14700aeb..595aa70f73f4 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -100,6 +100,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 3ee43f8da617..d6967754b17b 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -102,6 +102,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index 7af0244078ac..c9f43191516e 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -80,6 +80,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 30bf78be1e6e..fc4eab55b175 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -74,6 +74,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index d5ad60981a2a..cdb44a0c05b9 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -71,6 +71,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index 97b01b498bf1..eedaf8a748e0 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -73,6 +73,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index c1eb08053299..9379de07c193 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -68,6 +68,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index 1df522a7449a..92ba8bf63e2f 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index 2380cfc7710c..201991885732 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -76,6 +76,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index 8a2464df91dd..41afa473dcd2 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -78,6 +78,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index 0abf6e1631da..881c8f748101 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -73,6 +73,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index 66769e03c77d..27f75844bb5d 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -73,6 +73,7 @@ CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index 8b5b81448a5d..e3bb46a14342 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -75,6 +75,7 @@ CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index a0b12d049ef3..727c9b5fb71d 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -70,6 +70,7 @@ CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index f48b0f92f72d..dbb760eb9ac2 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index bf7287417e96..48e3ffa4eb3d 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -75,6 +75,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index c3a5f630a974..2f3801d2a257 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -77,6 +77,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index 9dac9e94c64b..9685180545ec 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -72,6 +72,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index de2b09c18fe9..577ea9300f30 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -102,6 +102,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 3a3cff873b2d..75225ba20dbf 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -101,6 +101,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 9499f585f1a6..8c6617aa02d3 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -104,6 +104,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index da28ef143f84..92d8365addd4 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -76,6 +76,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index e51e363cfdd7..fb4923d94344 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -98,6 +98,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index e86f0fa99a66..ab5cf3fa4f4c 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -97,6 +97,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index c8d8857ccbc9..aeb371d806ce 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -100,6 +100,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 1f3d6f6985fd..0a1331fef150 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -72,6 +72,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index f9475619603c..54f5896c63d7 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -105,6 +105,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index d83d36542376..54cae76d9b5a 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -104,6 +104,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index a18ea5651665..3b36349a7f71 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -78,6 +78,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 160e697159fb..fc447ab4ebbb 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -107,6 +107,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index e7775dac0b80..3f15ffc2d6b8 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 472e5779af64..82d6ded46ce0 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -107,6 +107,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 6882baf164af..8c640c5c5d0b 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -106,6 +106,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 5b1824ddb9bd..9a7c395fab21 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -109,6 +109,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index 6c6835eee316..d140c26cd383 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -81,6 +81,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080RDB_revD_NAND_defconfig b/configs/T2080RDB_revD_NAND_defconfig index a34c7caec7ea..43e595d33aae 100644 --- a/configs/T2080RDB_revD_NAND_defconfig +++ b/configs/T2080RDB_revD_NAND_defconfig @@ -108,6 +108,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/T2080RDB_revD_SDCARD_defconfig b/configs/T2080RDB_revD_SDCARD_defconfig index 0f503a889cc1..ea0f40f66703 100644 --- a/configs/T2080RDB_revD_SDCARD_defconfig +++ b/configs/T2080RDB_revD_SDCARD_defconfig @@ -107,6 +107,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080RDB_revD_SPIFLASH_defconfig b/configs/T2080RDB_revD_SPIFLASH_defconfig index d5845febd8d8..af65e4378970 100644 --- a/configs/T2080RDB_revD_SPIFLASH_defconfig +++ b/configs/T2080RDB_revD_SPIFLASH_defconfig @@ -110,6 +110,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080RDB_revD_defconfig b/configs/T2080RDB_revD_defconfig index e599c4e640e8..b6ca9f1ec1f8 100644 --- a/configs/T2080RDB_revD_defconfig +++ b/configs/T2080RDB_revD_defconfig @@ -82,6 +82,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index bd467ac7cfb5..739978463d78 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -93,6 +93,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 5b7849ea6ba8..7956ba11cc32 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -68,6 +68,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/comtrend_ct5361_ram_defconfig b/configs/comtrend_ct5361_ram_defconfig index cb2caf454350..4ad1d56cab4f 100644 --- a/configs/comtrend_ct5361_ram_defconfig +++ b/configs/comtrend_ct5361_ram_defconfig @@ -51,6 +51,7 @@ CONFIG_LED_GPIO=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y diff --git a/configs/comtrend_wap5813n_ram_defconfig b/configs/comtrend_wap5813n_ram_defconfig index b7174ff5ee34..dc0f7cee4efc 100644 --- a/configs/comtrend_wap5813n_ram_defconfig +++ b/configs/comtrend_wap5813n_ram_defconfig @@ -51,6 +51,7 @@ CONFIG_LED_GPIO=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y diff --git a/configs/huawei_hg556a_ram_defconfig b/configs/huawei_hg556a_ram_defconfig index 2b5a58714102..daa6ba0f865e 100644 --- a/configs/huawei_hg556a_ram_defconfig +++ b/configs/huawei_hg556a_ram_defconfig @@ -51,6 +51,7 @@ CONFIG_LED_GPIO=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y diff --git a/configs/integratorap_cm720t_defconfig b/configs/integratorap_cm720t_defconfig index 5f4ec5ff8f0e..71f645009792 100644 --- a/configs/integratorap_cm720t_defconfig +++ b/configs/integratorap_cm720t_defconfig @@ -30,6 +30,7 @@ CONFIG_SYS_RX_ETH_BUFFER=8 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_BAUDRATE=38400 diff --git a/configs/integratorap_cm920t_defconfig b/configs/integratorap_cm920t_defconfig index fb86b7cf2996..1c3b8a024e96 100644 --- a/configs/integratorap_cm920t_defconfig +++ b/configs/integratorap_cm920t_defconfig @@ -30,6 +30,7 @@ CONFIG_SYS_RX_ETH_BUFFER=8 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_BAUDRATE=38400 diff --git a/configs/integratorap_cm926ejs_defconfig b/configs/integratorap_cm926ejs_defconfig index 6bf08cd13aef..8dc7b0c06372 100644 --- a/configs/integratorap_cm926ejs_defconfig +++ b/configs/integratorap_cm926ejs_defconfig @@ -30,6 +30,7 @@ CONFIG_SYS_RX_ETH_BUFFER=8 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_BAUDRATE=38400 diff --git a/configs/integratorap_cm946es_defconfig b/configs/integratorap_cm946es_defconfig index 97c44f369554..c80a2b6a3a34 100644 --- a/configs/integratorap_cm946es_defconfig +++ b/configs/integratorap_cm946es_defconfig @@ -30,6 +30,7 @@ CONFIG_SYS_RX_ETH_BUFFER=8 # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_BAUDRATE=38400 diff --git a/configs/integratorcp_cm1136_defconfig b/configs/integratorcp_cm1136_defconfig index 89cfa9b9a6f7..05d5bf015307 100644 --- a/configs/integratorcp_cm1136_defconfig +++ b/configs/integratorcp_cm1136_defconfig @@ -33,6 +33,7 @@ CONFIG_BOOTFILE="uImage" # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_BAUDRATE=38400 diff --git a/configs/integratorcp_cm920t_defconfig b/configs/integratorcp_cm920t_defconfig index d895ba462920..eb9d1b765903 100644 --- a/configs/integratorcp_cm920t_defconfig +++ b/configs/integratorcp_cm920t_defconfig @@ -33,6 +33,7 @@ CONFIG_BOOTFILE="uImage" # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_BAUDRATE=38400 diff --git a/configs/integratorcp_cm926ejs_defconfig b/configs/integratorcp_cm926ejs_defconfig index 9cf449cb4c81..501c19c19277 100644 --- a/configs/integratorcp_cm926ejs_defconfig +++ b/configs/integratorcp_cm926ejs_defconfig @@ -33,6 +33,7 @@ CONFIG_BOOTFILE="uImage" # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_BAUDRATE=38400 diff --git a/configs/integratorcp_cm946es_defconfig b/configs/integratorcp_cm946es_defconfig index bcbcde211285..3264475fb438 100644 --- a/configs/integratorcp_cm946es_defconfig +++ b/configs/integratorcp_cm946es_defconfig @@ -33,6 +33,7 @@ CONFIG_BOOTFILE="uImage" # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_BAUDRATE=38400 diff --git a/configs/kmcent2_defconfig b/configs/kmcent2_defconfig index a0c92441cea0..de58944b761e 100644 --- a/configs/kmcent2_defconfig +++ b/configs/kmcent2_defconfig @@ -73,6 +73,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/kzm9g_defconfig b/configs/kzm9g_defconfig index 9a944cad39c2..58191c114c54 100644 --- a/configs/kzm9g_defconfig +++ b/configs/kzm9g_defconfig @@ -37,6 +37,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x10000000 diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 92fa4f000ed3..81459aa39fa8 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index fcbaf9b685e0..760f528f3c3f 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 19a21f4a0475..d1264fd318ae 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -111,6 +111,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index 727475f62264..b6d20424d9ce 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -78,6 +78,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 82c6a1bdc3bc..96b668718150 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -81,6 +81,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 438a8ecf0ae6..1b7aae5e898e 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -81,6 +81,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index cbb7c55944f9..2964bb7465a4 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -109,6 +109,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index b86a60fd3264..ad815b6832f7 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -65,6 +65,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index 0410249b316b..4ee9fe1b40c2 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -68,6 +68,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 82e3b39a522e..99271e79820e 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -68,6 +68,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index d247d114f393..11e1c8451cc4 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -96,6 +96,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 855657ca37a0..cdd7f8e38d15 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -96,6 +96,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index 364a34751fcf..6f767f749fd5 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index 7b083b32fba1..6d4b5912bce9 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 7446f01272e0..7311b1c558d8 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -108,6 +108,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 6dd797c652b9..78e39c46dc68 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -80,6 +80,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index 53f19a376ee8..b8e4a7bc6ef3 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -106,6 +106,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index 1ebe893b43d4..c4946f94e9f1 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -76,6 +76,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index d04d1d918b72..31d6173fdb5e 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -85,6 +85,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 787c8f96bd56..8105fc1030b0 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -62,6 +62,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 341fb0f92698..4b33e56be504 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -65,6 +65,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index 305734d74822..f30a7055d981 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -85,6 +85,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 56cdef82216d..41a3eb7f4ca9 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -92,6 +92,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index bf2805db9e94..8df1a4910b39 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -86,6 +86,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index f1370b5104b6..ae04bd4be08f 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -90,6 +90,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig index 12ccb78b9210..990254b57494 100644 --- a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig @@ -61,6 +61,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index db5229487216..d9b51553ac23 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -67,6 +67,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index fdeedca47678..fd996cd0ac52 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -76,6 +76,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index a66099c815dd..5bdfe7e42587 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index 835159deefbb..3c0b3563b731 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 2a70d660ed66..91a0ae4d7ee7 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -106,6 +106,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index 11554a831d5a..6e70fe553491 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -107,6 +107,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig index 7fd24122f041..0fc632d0cbaa 100644 --- a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig @@ -76,6 +76,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index 52d3d302d942..a8a2b8e5374e 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -85,6 +85,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index 64d87ae9b4f3..2db19f1cc758 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -75,6 +75,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index d3b068483968..99051b378178 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -95,6 +95,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index af5ecadec9d3..8965617becec 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -83,6 +83,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index 91cb2df6ee1a..f02e9aba3f77 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -64,6 +64,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index 8aef83af820f..49f3fd5dc1ea 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -67,6 +67,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 4fab4fb3b150..55b93ca2f165 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -67,6 +67,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index c3327cd0b7cc..973c657137d4 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -70,6 +70,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 6c7b49b71c2c..f6a6a1150756 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -90,6 +90,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index dc0f6f886bdf..63e54012b58e 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -78,6 +78,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index 8d970cce429d..9aac8bfdcf54 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -72,6 +72,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index d70d3cbf90b3..754f8b0980c6 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index 80b59cbb053b..1fae517ea04e 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -64,6 +64,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index 6984256a1c2d..111c0f07c7c0 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -61,6 +61,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index ad61859b897e..a7892c6e33fd 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -66,6 +66,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/octeon_ebb7304_defconfig b/configs/octeon_ebb7304_defconfig index ee83cd40c1ee..71df8cdabcb4 100644 --- a/configs/octeon_ebb7304_defconfig +++ b/configs/octeon_ebb7304_defconfig @@ -52,6 +52,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/pg_wcom_expu1_defconfig b/configs/pg_wcom_expu1_defconfig index bc58a631bed3..549a86cabcf8 100644 --- a/configs/pg_wcom_expu1_defconfig +++ b/configs/pg_wcom_expu1_defconfig @@ -81,6 +81,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/pg_wcom_expu1_update_defconfig b/configs/pg_wcom_expu1_update_defconfig index 5d70160bd3b9..f1bfc40b5756 100644 --- a/configs/pg_wcom_expu1_update_defconfig +++ b/configs/pg_wcom_expu1_update_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/pg_wcom_seli8_defconfig b/configs/pg_wcom_seli8_defconfig index a604d3248f2c..ae679966baab 100644 --- a/configs/pg_wcom_seli8_defconfig +++ b/configs/pg_wcom_seli8_defconfig @@ -81,6 +81,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/pg_wcom_seli8_update_defconfig b/configs/pg_wcom_seli8_update_defconfig index dfd6d627e1c1..1c74b6b8c51e 100644 --- a/configs/pg_wcom_seli8_update_defconfig +++ b/configs/pg_wcom_seli8_update_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/sfr_nb4-ser_ram_defconfig b/configs/sfr_nb4-ser_ram_defconfig index df008b797f86..4334182c7f85 100644 --- a/configs/sfr_nb4-ser_ram_defconfig +++ b/configs/sfr_nb4-ser_ram_defconfig @@ -53,6 +53,7 @@ CONFIG_LED_GPIO=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y diff --git a/configs/total_compute_defconfig b/configs/total_compute_defconfig index 2cb17f5040bf..43db639c273c 100644 --- a/configs/total_compute_defconfig +++ b/configs/total_compute_defconfig @@ -53,6 +53,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_32BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_LIBAVB=y diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index 792bcf1eb5d4..977e3270453b 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_UBI=y CONFIG_MTD=y CONFIG_SYS_FLASH_CFI_WIDTH_32BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index 0ae8ae10a310..71b3caa9224f 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_UBI=y CONFIG_MTD=y CONFIG_SYS_FLASH_CFI_WIDTH_32BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_VIRTIO_MMIO=y diff --git a/configs/vexpress_ca9x4_defconfig b/configs/vexpress_ca9x4_defconfig index f2084890edec..fbb6448480f0 100644 --- a/configs/vexpress_ca9x4_defconfig +++ b/configs/vexpress_ca9x4_defconfig @@ -45,6 +45,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_BANKS=2 diff --git a/configs/xtfpga_defconfig b/configs/xtfpga_defconfig index eab40fc0d133..c3c634e263ce 100644 --- a/configs/xtfpga_defconfig +++ b/configs/xtfpga_defconfig @@ -39,6 +39,7 @@ CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y +CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHYLIB=y diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index 3d1f6e43fd52..8c6719378ca7 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -106,6 +106,10 @@ config SYS_FLASH_USE_BUFFER_WRITE help Use buffered writes to flash.
+config SYS_FLASH_EMPTY_INFO + bool "Enable displaying empty sectors in flash info" + depends on FLASH_CFI_DRIVER + config FLASH_CFI_MTD bool "Enable CFI MTD driver" depends on FLASH_CFI_DRIVER diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index d56d60306abf..67a6cfd1ed05 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -141,8 +141,6 @@ #define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ #define CONFIG_SYS_FLASH_SIZE 8 /* max FLASH size is 32M */
-#define CONFIG_SYS_FLASH_EMPTY_INFO /* display empty sectors */ -
#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */
diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index c3c68071f2f2..4c33188c5000 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -129,8 +129,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#define CONFIG_SYS_FLASH_EMPTY_INFO - #define CONFIG_HWCONFIG /* enable hwconfig */
/* diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 12a78eac17c9..fbba1f053185 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -208,7 +208,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
/* CFI for NOR Flash */ -#define CONFIG_SYS_FLASH_EMPTY_INFO
/* NAND Flash on IFC */ #define CONFIG_SYS_NAND_BASE 0xff800000 diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 2d552835b776..3a3f1d306126 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -155,7 +155,6 @@ | OR_FCM_EHTR) #endif /* CONFIG_NAND_FSL_ELBC */
-#define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000}
#define CONFIG_HWCONFIG diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index c90ffe048c6f..6e7f0bcd52ec 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -172,7 +172,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS}
#ifdef CONFIG_TARGET_T1024RDB diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 56486cf5c934..140b3074784e 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -134,7 +134,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
/* CPLD on IFC */ diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 710254a8fb47..53f62837c66d 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -137,7 +137,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS \ + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS}
diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 8ade2e3c8292..8a0b00555995 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -126,7 +126,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ -#define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS }
/* CPLD on IFC */ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 653483cc99f0..d2f5cebfc07e 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -208,7 +208,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
diff --git a/include/configs/bmips_bcm6338.h b/include/configs/bmips_bcm6338.h index ddaa54051395..b8a962dfa2fb 100644 --- a/include/configs/bmips_bcm6338.h +++ b/include/configs/bmips_bcm6338.h @@ -21,6 +21,5 @@ #endif
#define CONFIG_SYS_FLASH_BASE 0xbfc00000 -#define CONFIG_SYS_FLASH_EMPTY_INFO
#endif /* __CONFIG_BMIPS_BCM6338_H */ diff --git a/include/configs/bmips_bcm6348.h b/include/configs/bmips_bcm6348.h index f704fe26ca0d..b23ab6a13cc9 100644 --- a/include/configs/bmips_bcm6348.h +++ b/include/configs/bmips_bcm6348.h @@ -21,6 +21,5 @@ #endif
#endif /* __CONFIG_BMIPS_BCM6348_H */ diff --git a/include/configs/bmips_bcm6358.h b/include/configs/bmips_bcm6358.h index 9aaa694cad91..106af2d27727 100644 --- a/include/configs/bmips_bcm6358.h +++ b/include/configs/bmips_bcm6358.h @@ -21,6 +21,5 @@ #endif
#define CONFIG_SYS_FLASH_BASE 0xbe000000 -#define CONFIG_SYS_FLASH_EMPTY_INFO
#endif /* __CONFIG_BMIPS_BCM6358_H */ diff --git a/include/configs/bmips_bcm6368.h b/include/configs/bmips_bcm6368.h index 0319124a0edd..fb1d760a8f3a 100644 --- a/include/configs/bmips_bcm6368.h +++ b/include/configs/bmips_bcm6368.h @@ -21,6 +21,5 @@ #endif
#define CONFIG_SYS_FLASH_BASE 0xb8000000 -#define CONFIG_SYS_FLASH_EMPTY_INFO
#endif /* __CONFIG_BMIPS_BCM6368_H */ diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 4eeca47c2534..7d666e553b0b 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -145,7 +145,6 @@ | OR_FCM_EHTR) #endif /* CONFIG_NAND_FSL_ELBC */
-#define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS}
#define CONFIG_HWCONFIG diff --git a/include/configs/integrator-common.h b/include/configs/integrator-common.h index 34eec5a33d25..4408fd0c2374 100644 --- a/include/configs/integrator-common.h +++ b/include/configs/integrator-common.h @@ -46,4 +46,3 @@ /* Timeout values in ticks */ #define CONFIG_SYS_FLASH_ERASE_TOUT (2 * CONFIG_SYS_HZ) /* Erase Timeout */ #define CONFIG_SYS_FLASH_WRITE_TOUT (2 * CONFIG_SYS_HZ) /* Write Timeout */ -#define CONFIG_SYS_FLASH_EMPTY_INFO /* flinfo indicates empty blocks */ diff --git a/include/configs/km/pg-wcom-ls102xa.h b/include/configs/km/pg-wcom-ls102xa.h index f83739013507..1477483db5bf 100644 --- a/include/configs/km/pg-wcom-ls102xa.h +++ b/include/configs/km/pg-wcom-ls102xa.h @@ -68,7 +68,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE_PHYS }
#define CONFIG_SYS_WRITE_SWAPPED_DATA diff --git a/include/configs/kmcent2.h b/include/configs/kmcent2.h index b389229b7546..dc369d431893 100644 --- a/include/configs/kmcent2.h +++ b/include/configs/kmcent2.h @@ -236,7 +236,6 @@
#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */
/* NAND Flash on IFC CS1*/ diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index f94cb54c7050..83c676803bba 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -41,7 +41,6 @@
/* FLASH */ #undef CONFIG_SYS_FLASH_QUIET_TEST -#define CONFIG_SYS_FLASH_EMPTY_INFO #define FLASH_SECTOR_SIZE (256 * 1024) /* 256 KB sectors */
/* Timeout for Flash erase operations (in ms) */ diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 517ade383bee..73f1797b4761 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -73,7 +73,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS, \ CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000}
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 1aa29e541ec5..732869ac14a7 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -102,7 +102,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
#define CONFIG_SYS_WRITE_SWAPPED_DATA diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 15c3ff53fe8e..f11d3e976bb2 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -78,7 +78,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 6c33847b27b6..45b2359dda23 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -46,7 +46,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
#define CONFIG_SYS_WRITE_SWAPPED_DATA diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 36c64db8f5d1..713946301690 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -95,7 +95,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index debb60d25cef..004de7cfb734 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -69,7 +69,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE,\ CONFIG_SYS_FLASH_BASE + 0x40000000} #endif diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h index c0567c3fe580..14b2c9793bbd 100644 --- a/include/configs/ls1088ardb.h +++ b/include/configs/ls1088ardb.h @@ -54,7 +54,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } #endif #endif diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 9ba7258572fc..ff1c192c6b38 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -71,7 +71,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE,\ CONFIG_SYS_FLASH_BASE + 0x40000000} #endif diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index a504a0ea462a..b2dd6c65893a 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -68,7 +68,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE,\ CONFIG_SYS_FLASH_BASE + 0x40000000} #endif diff --git a/include/configs/mccmon6.h b/include/configs/mccmon6.h index 02a22351874b..17986a0e348a 100644 --- a/include/configs/mccmon6.h +++ b/include/configs/mccmon6.h @@ -27,7 +27,6 @@
/* NOR 16-bit mode */ #define CONFIG_SYS_FLASH_BASE WEIM_ARB_BASE_ADDR -#define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_FLASH_VERIFY
/* NOR Flash MTD */ diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 73f849222880..9f34d2aea7ef 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -18,7 +18,6 @@
#ifdef CONFIG_CFI_FLASH /* ?empty sector */ -# define CONFIG_SYS_FLASH_EMPTY_INFO 1 /* max number of memory banks */ /* max number of sectors on one chip */ # define CONFIG_SYS_MAX_FLASH_SECT 2048 diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index bc4aa52f5bf1..5fc3acded305 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -33,7 +33,6 @@ #define CONFIG_SYS_FLASH_BASE WEIM_ARB_BASE_ADDR #define CONFIG_SYS_FLASH_SECT_SIZE (128 * 1024) #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ -#define CONFIG_SYS_FLASH_EMPTY_INFO #endif
#define CONFIG_SYS_FSL_USDHC_NUM 2 diff --git a/include/configs/octeon_ebb7304.h b/include/configs/octeon_ebb7304.h index 7035e6313420..5df1a2a755f3 100644 --- a/include/configs/octeon_ebb7304.h +++ b/include/configs/octeon_ebb7304.h @@ -13,7 +13,6 @@ * CFI flash */ #define CONFIG_SYS_MAX_FLASH_SECT 256 -#define CONFIG_SYS_FLASH_EMPTY_INFO /* flinfo indicates empty blocks */
#define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index a0d583040cde..137114fcbc76 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -202,8 +202,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#define CONFIG_SYS_FLASH_EMPTY_INFO - /* Nand Flash */ #ifdef CONFIG_NAND_FSL_ELBC #define CONFIG_SYS_NAND_BASE 0xff800000 diff --git a/include/configs/total_compute.h b/include/configs/total_compute.h index 4fb3d731c67a..5a1eed3f2170 100644 --- a/include/configs/total_compute.h +++ b/include/configs/total_compute.h @@ -47,7 +47,6 @@ /* 256 x 256KiB sectors */ #define CONFIG_SYS_MAX_FLASH_SECT 256
-#define CONFIG_SYS_FLASH_EMPTY_INFO /* flinfo indicates empty blocks */ #define FLASH_MAX_SECTOR_SIZE 0x00040000
#endif /* __TOTAL_COMPUTE_H */ diff --git a/include/configs/vexpress_aemv8.h b/include/configs/vexpress_aemv8.h index 3705313aec06..6b65fcf37ec9 100644 --- a/include/configs/vexpress_aemv8.h +++ b/include/configs/vexpress_aemv8.h @@ -272,7 +272,6 @@ /* Store environment at top of flash */ #endif
#endif /* __VEXPRESS_AEMV8_H */ diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index ff7307f09044..91ce2fe0ca40 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -189,7 +189,6 @@ */
/* Store environment at top of flash */ -#define CONFIG_SYS_FLASH_EMPTY_INFO /* flinfo indicates empty blocks */ #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE0, \ CONFIG_SYS_FLASH_BASE1 }
diff --git a/include/configs/xtfpga.h b/include/configs/xtfpga.h index f1ea47654671..67ba8af71f85 100644 --- a/include/configs/xtfpga.h +++ b/include/configs/xtfpga.h @@ -190,6 +190,5 @@ */
/* print 'E' for empty sector on flinfo */ -#define CONFIG_SYS_FLASH_EMPTY_INFO
#endif /* __CONFIG_H */ diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 1fdde90654f2..c9d8d09f194d 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -42,7 +42,6 @@ # define CONFIG_SYS_FLASH_ERASE_TOUT 1000 # define CONFIG_SYS_FLASH_WRITE_TOUT 5000 # define CONFIG_FLASH_SHOW_PROGRESS 10 -# undef CONFIG_SYS_FLASH_EMPTY_INFO # define CONFIG_SYS_FLASH_QUIET_TEST #endif
We have a number of CONFIG_SYS_xxx_SIZE options to describe the amount main memory available. Rework CONFIG_SYS_DDR_SIZE, which described a size in number of MiB to use CONFIG_SYS_SDRAM_SIZE which is most often used as a number of bytes. Use shifts of this option when required.
Signed-off-by: Tom Rini trini@konsulko.com --- board/freescale/mpc837xerdb/mpc837xerdb.c | 4 ++-- board/gdsys/mpc8308/sdram.c | 2 +- board/ids/ids8313/ids8313.c | 4 ++-- board/keymile/km83xx/km83xx.c | 5 ++--- include/configs/MPC837XERDB.h | 2 +- include/configs/ids8313.h | 2 +- include/configs/km/km-mpc83xx.h | 2 +- 7 files changed, 10 insertions(+), 11 deletions(-)
diff --git a/board/freescale/mpc837xerdb/mpc837xerdb.c b/board/freescale/mpc837xerdb/mpc837xerdb.c index 84671f63c60b..2650d300e384 100644 --- a/board/freescale/mpc837xerdb/mpc837xerdb.c +++ b/board/freescale/mpc837xerdb/mpc837xerdb.c @@ -97,7 +97,7 @@ int dram_init(void) int fixed_sdram(void) { immap_t *im = (immap_t *) CONFIG_SYS_IMMR; - u32 msize = CONFIG_SYS_DDR_SIZE * 1024 * 1024; + u32 msize = CONFIG_SYS_SDRAM_SIZE; u32 msize_log2 = __ilog2(msize);
im->sysconf.ddrlaw[0].bar = CONFIG_SYS_SDRAM_BASE & 0xfffff000; @@ -127,7 +127,7 @@ int fixed_sdram(void)
im->ddr.sdram_cfg |= SDRAM_CFG_MEM_EN; udelay(2000); - return CONFIG_SYS_DDR_SIZE; + return CONFIG_SYS_SDRAM_SIZE >> 20; } #endif /*!CONFIG_SYS_SPD_EEPROM */
diff --git a/board/gdsys/mpc8308/sdram.c b/board/gdsys/mpc8308/sdram.c index bfd55f54e4e1..47b880435210 100644 --- a/board/gdsys/mpc8308/sdram.c +++ b/board/gdsys/mpc8308/sdram.c @@ -34,7 +34,7 @@ DECLARE_GLOBAL_DATA_PTR; static long fixed_sdram(void) { immap_t *im = (immap_t *)CONFIG_SYS_IMMR; - u32 msize = CONFIG_SYS_DDR_SIZE * 1024 * 1024; + u32 msize = CONFIG_SYS_SDRAM_SIZE; u32 msize_log2 = __ilog2(msize);
out_be32(&im->sysconf.ddrlaw[0].bar, diff --git a/board/ids/ids8313/ids8313.c b/board/ids/ids8313/ids8313.c index 45c77a249a9b..48aea71be637 100644 --- a/board/ids/ids8313/ids8313.c +++ b/board/ids/ids8313/ids8313.c @@ -56,7 +56,7 @@ int checkboard(void) int fixed_sdram(unsigned long config) { immap_t *im = (immap_t *)CONFIG_SYS_IMMR; - u32 msize = CONFIG_SYS_DDR_SIZE << 20; + u32 msize = CONFIG_SYS_SDRAM_SIZE;
#ifndef CONFIG_SYS_RAMBOOT u32 msize_log2 = __ilog2(msize); @@ -109,7 +109,7 @@ int fixed_sdram(unsigned long config)
static int setup_sdram(void) { - u32 msize = CONFIG_SYS_DDR_SIZE << 20; + u32 msize = CONFIG_SYS_SDRAM_SIZE; long int size_01, size_02;
size_01 = fixed_sdram(CONFIG_SYS_DDR_CONFIG); diff --git a/board/keymile/km83xx/km83xx.c b/board/keymile/km83xx/km83xx.c index 8a0b17585663..6a7b84816145 100644 --- a/board/keymile/km83xx/km83xx.c +++ b/board/keymile/km83xx/km83xx.c @@ -141,12 +141,11 @@ static int fixed_sdram(void) udelay(200); setbits_be32(&im->ddr.sdram_cfg, SDRAM_CFG_MEM_EN);
- msize = CONFIG_SYS_DDR_SIZE << 20; disable_addr_trans(); - msize = get_ram_size(CONFIG_SYS_SDRAM_BASE, msize); + msize = get_ram_size(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE); enable_addr_trans(); msize /= (1024 * 1024); - if (CONFIG_SYS_DDR_SIZE != msize) { + if (CONFIG_SYS_SDRAM_SIZE >> 20 != msize) { for (ddr_size = msize << 20, ddr_size_log2 = 0; (ddr_size > 1); ddr_size = ddr_size >> 1, ddr_size_log2++) diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 67a6cfd1ed05..8fffb0c5cc00 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -69,7 +69,7 @@ /* * Manually set up DDR parameters */ -#define CONFIG_SYS_DDR_SIZE 256 /* MB */ +#define CONFIG_SYS_SDRAM_SIZE 0x10000000 /* 256 MiB */ #define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ | CSCONFIG_ODT_WR_ONLY_CURRENT \ diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index a8bb2090ec4a..26f0741be3f1 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -41,7 +41,7 @@ * Manually set up DDR parameters, * as this board has not the SPD connected to I2C. */ -#define CONFIG_SYS_DDR_SIZE 256 /* MB */ +#define CONFIG_SYS_SDRAM_SIZE 0x10000000 /* 256 MiB */ #define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN |\ 0x00010000 |\ CSCONFIG_ROW_BIT_13 |\ diff --git a/include/configs/km/km-mpc83xx.h b/include/configs/km/km-mpc83xx.h index 9f76f48a5c6b..3c23715a7721 100644 --- a/include/configs/km/km-mpc83xx.h +++ b/include/configs/km/km-mpc83xx.h @@ -18,7 +18,7 @@ /* * Manually set up DDR parameters */ -#define CONFIG_SYS_DDR_SIZE 2048 /* MB */ +#define CONFIG_SYS_SDRAM_SIZE 0x80000000 /* 2048 MiB */
/* * The reserved memory
This is the only platform defining and using CONFIG_SYS_MEM_SIZE, switch to using CONFIG_SYS_SDRAM_SIZE for consistency.
Cc: Paul Burton paul.burton@mips.com Signed-off-by: Tom Rini trini@konsulko.com --- board/imgtec/malta/lowlevel_init.S | 4 ++-- board/imgtec/malta/malta.c | 2 +- include/configs/malta.h | 2 +- 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/imgtec/malta/lowlevel_init.S b/board/imgtec/malta/lowlevel_init.S index ecb4424fd92a..bed24972f7a8 100644 --- a/board/imgtec/malta/lowlevel_init.S +++ b/board/imgtec/malta/lowlevel_init.S @@ -118,7 +118,7 @@ _msc01: /* setup basic address decode */ PTR_LI t0, CKSEG1ADDR(MALTA_MSC01_BIU_BASE) li t1, 0x0 - li t2, -CONFIG_SYS_MEM_SIZE + li t2, -CONFIG_SYS_SDRAM_SIZE sw t1, MSC01_BIU_MCBAS1L_OFS(t0) sw t2, MSC01_BIU_MCMSK1L_OFS(t0) sw t1, MSC01_BIU_MCBAS2L_OFS(t0) @@ -168,7 +168,7 @@ _msc01: sw t3, MSC01_PCI_SC2PIOMAPL_OFS(t0)
/* setup PCI_BAR0 memory window */ - li t1, -CONFIG_SYS_MEM_SIZE + li t1, -CONFIG_SYS_SDRAM_SIZE sw t1, MSC01_PCI_BAR0_OFS(t0)
/* setup PCI to SysCon/CPU translation */ diff --git a/board/imgtec/malta/malta.c b/board/imgtec/malta/malta.c index d2e2e4ae2093..9853a0ba82f6 100644 --- a/board/imgtec/malta/malta.c +++ b/board/imgtec/malta/malta.c @@ -94,7 +94,7 @@ static enum sys_con malta_sys_con(void)
int dram_init(void) { - gd->ram_size = CONFIG_SYS_MEM_SIZE; + gd->ram_size = CONFIG_SYS_SDRAM_SIZE;
return 0; } diff --git a/include/configs/malta.h b/include/configs/malta.h index c8b230ab21e9..98ea860655ea 100644 --- a/include/configs/malta.h +++ b/include/configs/malta.h @@ -30,7 +30,7 @@ #else # define CONFIG_SYS_SDRAM_BASE 0x80000000 #endif -#define CONFIG_SYS_MEM_SIZE (256 * 1024 * 1024) +#define CONFIG_SYS_SDRAM_SIZE 0x10000000 /* 256 MiB */
#define CONFIG_SYS_INIT_SP_OFFSET 0x400000
All platforms today define CONFIG_SYS_DDR_RAW_TIMING, so drop the code for this option being unset.
Cc: Qiang Zhao qiang.zhao@nxp.com Signed-off-by: Tom Rini trini@konsulko.com --- board/freescale/p1010rdb/ddr.c | 138 --------------------------------- include/configs/P1010RDB.h | 37 --------- 2 files changed, 175 deletions(-)
diff --git a/board/freescale/p1010rdb/ddr.c b/board/freescale/p1010rdb/ddr.c index 2625195f81b1..b423ec8e218a 100644 --- a/board/freescale/p1010rdb/ddr.c +++ b/board/freescale/p1010rdb/ddr.c @@ -16,142 +16,6 @@
-#ifndef CONFIG_SYS_DDR_RAW_TIMING -#define CONFIG_SYS_DRAM_SIZE 1024 - -fsl_ddr_cfg_regs_t ddr_cfg_regs_800 = { - .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, - .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, - .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, - .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_800, - .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_800, - .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_800, - .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_800, - .ddr_sdram_cfg = CONFIG_SYS_DDR_CONTROL, - .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_CONTROL_2, - .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1_800, - .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_800, - .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, - .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL_800, - .ddr_data_init = CONFIG_MEM_INIT_VALUE, - .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_800, - .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, - .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, - .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, - .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, - .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CONTROL, - .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CONTROL_800, - .ddr_sr_cntr = CONFIG_SYS_DDR_SR_CNTR, - .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, - .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 -}; - -fsl_ddr_cfg_regs_t ddr_cfg_regs_667 = { - .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, - .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, - .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, - .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_667, - .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_667, - .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_667, - .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_667, - .ddr_sdram_cfg = CONFIG_SYS_DDR_CONTROL, - .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_CONTROL_2, - .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1_667, - .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_667, - .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, - .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL_667, - .ddr_data_init = CONFIG_MEM_INIT_VALUE, - .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_667, - .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, - .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, - .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, - .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, - .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CONTROL, - .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CONTROL_667, - .ddr_sr_cntr = CONFIG_SYS_DDR_SR_CNTR, - .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, - .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 -}; - -fixed_ddr_parm_t fixed_ddr_parm_0[] = { - {750, 850, &ddr_cfg_regs_800}, - {607, 749, &ddr_cfg_regs_667}, - {0, 0, NULL} -}; - -unsigned long get_sdram_size(void) -{ - struct cpu_type *cpu; - phys_size_t ddr_size; - - cpu = gd->arch.cpu; - /* P1014 and it's derivatives support max 16it DDR width */ - if (cpu->soc_ver == SVR_P1014) - ddr_size = (CONFIG_SYS_DRAM_SIZE / 2); - else - ddr_size = CONFIG_SYS_DRAM_SIZE; - - return ddr_size; -} - -/* - * Fixed sdram init -- doesn't use serial presence detect. - */ -phys_size_t fixed_sdram(void) -{ - int i; - char buf[32]; - fsl_ddr_cfg_regs_t ddr_cfg_regs; - phys_size_t ddr_size; - ulong ddr_freq, ddr_freq_mhz; - struct cpu_type *cpu; - -#if defined(CONFIG_SYS_RAMBOOT) - return CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; -#endif - - ddr_freq = get_ddr_freq(0); - ddr_freq_mhz = ddr_freq / 1000000; - - printf("Configuring DDR for %s MT/s data rate\n", - strmhz(buf, ddr_freq)); - - for (i = 0; fixed_ddr_parm_0[i].max_freq > 0; i++) { - if ((ddr_freq_mhz > fixed_ddr_parm_0[i].min_freq) && - (ddr_freq_mhz <= fixed_ddr_parm_0[i].max_freq)) { - memcpy(&ddr_cfg_regs, fixed_ddr_parm_0[i].ddr_settings, - sizeof(ddr_cfg_regs)); - break; - } - } - - if (fixed_ddr_parm_0[i].max_freq == 0) - panic("Unsupported DDR data rate %s MT/s data rate\n", - strmhz(buf, ddr_freq)); - - cpu = gd->arch.cpu; - /* P1014 and it's derivatives support max 16bit DDR width */ - if (cpu->soc_ver == SVR_P1014) { - ddr_cfg_regs.ddr_sdram_cfg &= ~SDRAM_CFG_DBW_MASK; - ddr_cfg_regs.ddr_sdram_cfg |= SDRAM_CFG_16_BE; - /* divide SA and EA by two and then mask the rest so we don't - * write to reserved fields */ - ddr_cfg_regs.cs[0].bnds = (CONFIG_SYS_DDR_CS0_BNDS >> 1) & 0x0fff0fff; - } - - ddr_size = (phys_size_t) CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; - fsl_ddr_set_memctl_regs(&ddr_cfg_regs, 0, 0); - - if (set_ddr_laws(CONFIG_SYS_DDR_SDRAM_BASE, ddr_size, - LAW_TRGT_IF_DDR_1) < 0) { - printf("ERROR setting Local Access Windows for DDR\n"); - return 0; - } - - return ddr_size; -} - -#else /* CONFIG_SYS_DDR_RAW_TIMING */ /* * Samsung K4B2G0846C-HCF8 * The following timing are for "downshift" @@ -232,5 +96,3 @@ void fsl_ddr_board_options(memctl_options_t *popts, popts->cs_local_opts[i].odt_wr_cfg = FSL_DDR_ODT_CS; } } - -#endif /* CONFIG_SYS_DDR_RAW_TIMING */ diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index fbba1f053185..def21e55a611 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -114,43 +114,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE
-/* DDR3 Controller Settings */ -#define CONFIG_SYS_DDR_CS0_BNDS 0x0000003f -#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014302 -#define CONFIG_SYS_DDR_CS0_CONFIG_2 0x00000000 -#define CONFIG_SYS_DDR_INIT_ADDR 0x00000000 -#define CONFIG_SYS_DDR_INIT_EXT_ADDR 0x00000000 -#define CONFIG_SYS_DDR_MODE_CONTROL 0x00000000 -#define CONFIG_SYS_DDR_ZQ_CONTROL 0x89080600 -#define CONFIG_SYS_DDR_SR_CNTR 0x00000000 -#define CONFIG_SYS_DDR_RCW_1 0x00000000 -#define CONFIG_SYS_DDR_RCW_2 0x00000000 -#define CONFIG_SYS_DDR_CONTROL 0xc70c0008 /* Type = DDR3 */ -#define CONFIG_SYS_DDR_CONTROL_2 0x24401000 -#define CONFIG_SYS_DDR_TIMING_4 0x00000001 -#define CONFIG_SYS_DDR_TIMING_5 0x03402400 - -#define CONFIG_SYS_DDR_TIMING_3_800 0x00030000 -#define CONFIG_SYS_DDR_TIMING_0_800 0x00110104 -#define CONFIG_SYS_DDR_TIMING_1_800 0x6f6b8644 -#define CONFIG_SYS_DDR_TIMING_2_800 0x0FA888CF -#define CONFIG_SYS_DDR_CLK_CTRL_800 0x03000000 -#define CONFIG_SYS_DDR_MODE_1_800 0x00441420 -#define CONFIG_SYS_DDR_MODE_2_800 0x00000000 -#define CONFIG_SYS_DDR_INTERVAL_800 0x0C300100 -#define CONFIG_SYS_DDR_WRLVL_CONTROL_800 0x8675f608 - -/* settings for DDR3 at 667MT/s */ -#define CONFIG_SYS_DDR_TIMING_3_667 0x00010000 -#define CONFIG_SYS_DDR_TIMING_0_667 0x00110004 -#define CONFIG_SYS_DDR_TIMING_1_667 0x5d59e544 -#define CONFIG_SYS_DDR_TIMING_2_667 0x0FA890CD -#define CONFIG_SYS_DDR_CLK_CTRL_667 0x03000000 -#define CONFIG_SYS_DDR_MODE_1_667 0x00441210 -#define CONFIG_SYS_DDR_MODE_2_667 0x00000000 -#define CONFIG_SYS_DDR_INTERVAL_667 0x0a280000 -#define CONFIG_SYS_DDR_WRLVL_CONTROL_667 0x8675F608 - #define CONFIG_SYS_CCSRBAR 0xffe00000 #define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR
This converts the following to Kconfig: CONFIG_SYS_FLASH_CHECKSUM
Signed-off-by: Tom Rini trini@konsulko.com --- configs/M5249EVB_defconfig | 1 + configs/M5282EVB_defconfig | 1 + drivers/mtd/Kconfig | 7 +++++++ include/configs/M5249EVB.h | 1 - include/configs/M5282EVB.h | 1 - include/configs/MPC837XERDB.h | 1 - include/configs/MPC8548CDS.h | 1 - include/configs/P1010RDB.h | 1 - include/configs/p1_p2_rdb_pc.h | 1 - include/configs/socrates.h | 1 - 10 files changed, 9 insertions(+), 7 deletions(-)
diff --git a/configs/M5249EVB_defconfig b/configs/M5249EVB_defconfig index f99375b535ed..74301045c8e4 100644 --- a/configs/M5249EVB_defconfig +++ b/configs/M5249EVB_defconfig @@ -28,4 +28,5 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_CHECKSUM=y CONFIG_MCFUART=y diff --git a/configs/M5282EVB_defconfig b/configs/M5282EVB_defconfig index 42940e1000a4..aeb7738ebe77 100644 --- a/configs/M5282EVB_defconfig +++ b/configs/M5282EVB_defconfig @@ -33,6 +33,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_CHECKSUM=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index 8c6719378ca7..985cc01e425d 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -132,6 +132,13 @@ config SYS_FLASH_CFI Define if the flash driver uses extra elements in the common flash structure for storing flash geometry.
+config SYS_FLASH_CHECKSUM + bool "Compute and print flash CRC if 'flashchecksum' is set in the environment" + depends on MTD_NOR_FLASH + help + If the variable flashchecksum is set in the environment, perform a CRC + of the flash and print the value to console. + config ALTERA_QSPI bool "Altera Generic Quad SPI Controller" depends on DM_MTD diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index 1889a235a2a1..39bffc29ff22 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -78,7 +78,6 @@
# define CONFIG_SYS_FLASH_SIZE 0x1000000 /* Max size that the board might have */ # define CONFIG_SYS_MAX_FLASH_SECT 137 /* max number of sectors on one chip */ -# define CONFIG_SYS_FLASH_CHECKSUM # define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } #endif
diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index 9f06f41ce11b..c476b0c4475a 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -96,7 +96,6 @@
diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 8fffb0c5cc00..87ae9530852f 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -144,7 +144,6 @@
-#undef CONFIG_SYS_FLASH_CHECKSUM #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 4c33188c5000..febe8c2476f2 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -125,7 +125,6 @@ #define CONFIG_SYS_FLASH_BANKS_LIST \ {CONFIG_SYS_FLASH_BASE_PHYS + 0x800000, CONFIG_SYS_FLASH_BASE_PHYS} #define CONFIG_SYS_MAX_FLASH_SECT 128 /* sectors per device */ -#undef CONFIG_SYS_FLASH_CHECKSUM #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index def21e55a611..9f680f21b8a6 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -166,7 +166,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 137114fcbc76..95c438f6e970 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -198,7 +198,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 5dc8d8559882..c3b1be969879 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -89,7 +89,6 @@ #define CONFIG_SYS_FLASH_BASE CONFIG_SYS_LBC_FLASH_BASE /* start of FLASH */
#define CONFIG_SYS_MAX_FLASH_SECT 256 /* sectors per device */ -#undef CONFIG_SYS_FLASH_CHECKSUM #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
This converts the following to Kconfig: CONFIG_SYS_FLASH_ERASE_TOUT CONFIG_SYS_FLASH_LOCK_TOUT CONFIG_SYS_FLASH_UNLOCK_TOUT CONFIG_SYS_FLASH_WRITE_TOUT
In practice, for two m68k platforms we move to hard-coding with a comment the timeout values, rather than try and make convoluted Kconfig logic. We add options for the write and erase options to the pic32 flash driver, as this driver does make use of them. Everywhere else these are unreferenced values.
Signed-off-by: Tom Rini trini@konsulko.com --- README | 12 ------------ board/cobra5272/flash.c | 8 ++++---- board/freescale/m5253demo/flash.c | 10 ++++++---- drivers/mtd/Kconfig | 12 ++++++++++++ include/configs/M5253DEMO.h | 2 -- include/configs/M5275EVB.h | 1 - include/configs/MCR3000.h | 2 -- include/configs/MPC837XERDB.h | 3 --- include/configs/MPC8548CDS.h | 2 -- include/configs/P1010RDB.h | 3 --- include/configs/P2041RDB.h | 2 -- include/configs/T102xRDB.h | 2 -- include/configs/T104xRDB.h | 2 -- include/configs/T208xQDS.h | 2 -- include/configs/T208xRDB.h | 2 -- include/configs/T4240RDB.h | 2 -- include/configs/amcore.h | 1 - include/configs/armadillo-800eva.h | 5 ----- include/configs/astro_mcf5373l.h | 1 - include/configs/ax25-ae350.h | 3 --- include/configs/blanche.h | 5 ----- include/configs/cobra5272.h | 1 - include/configs/corenet_ds.h | 2 -- include/configs/eb_cpu5282.h | 1 - include/configs/ids8313.h | 3 --- include/configs/integrator-common.h | 2 -- include/configs/km/pg-wcom-ls102xa.h | 2 -- include/configs/kzm9g.h | 4 ---- include/configs/ls1021aqds.h | 2 -- include/configs/ls1021atwr.h | 2 -- include/configs/ls1043aqds.h | 2 -- include/configs/ls1043ardb.h | 2 -- include/configs/ls1046aqds.h | 2 -- include/configs/ls1088aqds.h | 2 -- include/configs/ls1088ardb.h | 2 -- include/configs/ls2080aqds.h | 2 -- include/configs/ls2080ardb.h | 2 -- include/configs/p1_p2_rdb_pc.h | 3 --- include/configs/socrates.h | 2 -- include/configs/vexpress_common.h | 2 -- include/configs/zynq-common.h | 2 -- 41 files changed, 22 insertions(+), 102 deletions(-)
diff --git a/README b/README index 74e37aa95cc4..157612d00412 100644 --- a/README +++ b/README @@ -1759,18 +1759,6 @@ Configuration Settings: - CONFIG_SYS_MAX_FLASH_SECT: Max number of sectors on a Flash chip
-- CONFIG_SYS_FLASH_ERASE_TOUT: - Timeout for Flash erase operations (in ms) - -- CONFIG_SYS_FLASH_WRITE_TOUT: - Timeout for Flash write operations (in ms) - -- CONFIG_SYS_FLASH_LOCK_TOUT - Timeout for Flash set sector lock bit operation (in ms) - -- CONFIG_SYS_FLASH_UNLOCK_TOUT - Timeout for Flash clear lock bits operation (in ms) - - CONFIG_SYS_FLASH_PROTECTION If defined, hardware flash sectors protection is used instead of U-Boot software protection. diff --git a/board/cobra5272/flash.c b/board/cobra5272/flash.c index 4337f4879de7..5d15ed4e691d 100644 --- a/board/cobra5272/flash.c +++ b/board/cobra5272/flash.c @@ -200,8 +200,8 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) do { result = *addr;
- /* check timeout */ - if (get_timer(start) > CONFIG_SYS_FLASH_ERASE_TOUT) { + /* check timeout, 1000ms */ + if (get_timer(start) > 1000) { MEM_FLASH_ADDR1 = CMD_READ_ARRAY; chip1 = TMO; break; @@ -289,8 +289,8 @@ static int write_word(flash_info_t *info, ulong dest, ulong data) do { result = *addr;
- /* check timeout */ - if (get_timer(start) > CONFIG_SYS_FLASH_ERASE_TOUT) { + /* check timeout, 1000ms */ + if (get_timer(start) > 1000) { chip1 = ERR | TMO; break; } diff --git a/board/freescale/m5253demo/flash.c b/board/freescale/m5253demo/flash.c index 319742178168..bff1ac5fb113 100644 --- a/board/freescale/m5253demo/flash.c +++ b/board/freescale/m5253demo/flash.c @@ -242,7 +242,8 @@ int flash_erase(flash_info_t * info, int s_first, int s_last) count = 0; }
- if (get_timer(start) > CONFIG_SYS_FLASH_ERASE_TOUT) { + /* check timeout, 1000ms */ + if (get_timer(start) > 1000) { printf("Timeout\n"); *addr = 0x00F0; /* reset to read mode */
@@ -294,8 +295,8 @@ int flash_erase(flash_info_t * info, int s_first, int s_last) enable_interrupts();
while ((*addr & 0x0080) != 0x0080) { - if (get_timer(start) > - CONFIG_SYS_FLASH_ERASE_TOUT) { + /* check timeout, 1000ms */ + if (get_timer(start) > 1000) { printf("Timeout\n"); *addr = 0x00F0; /* reset to read mode */
@@ -430,7 +431,8 @@ int write_word(flash_info_t * info, FPWV * dest, u16 data) /* data polling for D7 */ while (res == 0 && (*dest & (u8) 0x00800080) != (data & (u8) 0x00800080)) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { + /* check timeout, 500ms */ + if (get_timer(start) > 500) { *dest = (u8) 0x00F000F0; /* reset bank */ res = 1; } diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index 985cc01e425d..e28ff049550b 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -157,6 +157,18 @@ config FLASH_PIC32 This enables access to Microchip PIC32 internal non-CFI flash chips through PIC32 Non-Volatile-Memory Controller.
+config SYS_FLASH_ERASE_TOUT + int "Timeout in ms for performing an erase operation on the flash" + depends on FLASH_PIC32 + help + Timeout for Flash erase operations (in ms) + +config SYS_FLASH_WRITE_TOUT + int "Timeout in ms for performing a write operation on the flash" + depends on FLASH_PIC32 + help + Timeout for Flash write operations (in ms) + config RENESAS_RPC_HF bool "Renesas RCar Gen3 RPC HyperFlash driver" depends on RCAR_GEN3 && DM_MTD diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index cac9b24ead8e..88c2bbbf25f2 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -94,7 +94,6 @@ /* FLASH organization */ #define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CS0_BASE) #define CONFIG_SYS_MAX_FLASH_SECT 2048 /* max number of sectors on one chip */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 1000
#define FLASH_SST6401B 0x200 #define SST_ID_xF6401B 0x236D236D @@ -110,7 +109,6 @@ #else # define CONFIG_SYS_SST_SECT 2048 # define CONFIG_SYS_SST_SECTSZ 0x1000 -# define CONFIG_SYS_FLASH_WRITE_TOUT 500 #endif
/* Cache Configuration */ diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index 292578fc15b9..80d079a48995 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -92,7 +92,6 @@ * FLASH organization */ #define CONFIG_SYS_MAX_FLASH_SECT 11 /* max number of sectors on one chip */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 1000
#define CONFIG_SYS_FLASH_SIZE 0x200000
diff --git a/include/configs/MCR3000.h b/include/configs/MCR3000.h index 41ab86085083..f6854cb8c985 100644 --- a/include/configs/MCR3000.h +++ b/include/configs/MCR3000.h @@ -70,8 +70,6 @@ /* FLASH organization */ #define CONFIG_SYS_FLASH_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_MAX_FLASH_SECT 35 -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 -#define CONFIG_SYS_FLASH_WRITE_TOUT 500
/* * For booting Linux, the board info and command line data diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 87ae9530852f..a25bf7464514 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -144,9 +144,6 @@
-#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ - /* * NAND Flash on the Local Bus */ diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index febe8c2476f2..d4a2b0184f64 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -125,8 +125,6 @@ #define CONFIG_SYS_FLASH_BANKS_LIST \ {CONFIG_SYS_FLASH_BASE_PHYS + 0x800000, CONFIG_SYS_FLASH_BASE_PHYS} #define CONFIG_SYS_MAX_FLASH_SECT 128 /* sectors per device */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 9f680f21b8a6..a057d59177e5 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -166,9 +166,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ - /* CFI for NOR Flash */
/* NAND Flash on IFC */ diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 3a3f1d306126..b4a7b4688113 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -124,8 +124,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Write Timeout (ms) */
/* Nand Flash */ #ifdef CONFIG_NAND_FSL_ELBC diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 6e7f0bcd52ec..7c5fbbba5926 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -169,8 +169,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 140b3074784e..39b04b204e58 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -131,8 +131,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 53f62837c66d..0cb8d394d11c 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -134,8 +134,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS \ + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS} diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 8a0b00555995..bccc3385cb21 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -124,8 +124,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS }
/* CPLD on IFC */ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index d2f5cebfc07e..181b5fe2a44b 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -205,8 +205,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS \ + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS} diff --git a/include/configs/amcore.h b/include/configs/amcore.h index 3c9267b14ec9..89b94b29306f 100644 --- a/include/configs/amcore.h +++ b/include/configs/amcore.h @@ -37,7 +37,6 @@ #define CONFIG_SYS_SDRAM_SIZE 0x1000000 #define CONFIG_SYS_FLASH_BASE 0xffc00000 #define CONFIG_SYS_MAX_FLASH_SECT 1024 -#define CONFIG_SYS_FLASH_ERASE_TOUT 1000
/* amcore design has flash data bytes wired swapped */ #define CONFIG_SYS_WRITE_SWAPPED_DATA diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index 1c7494183a4d..d54cadd41eeb 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -50,11 +50,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 512 #define CONFIG_SYS_FLASH_BANKS_LIST { (CONFIG_SYS_FLASH_BASE) }
-#define CONFIG_SYS_FLASH_ERASE_TOUT 3000 -#define CONFIG_SYS_FLASH_WRITE_TOUT 3000 -#define CONFIG_SYS_FLASH_LOCK_TOUT 3000 -#define CONFIG_SYS_FLASH_UNLOCK_TOUT 3000 - /* ENV setting */
/* SH Ether */ diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index a8265e961a26..f48f7902a002 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -208,7 +208,6 @@
/* FLASH organization */ #define CONFIG_SYS_MAX_FLASH_SECT 259 -#define CONFIG_SYS_FLASH_ERASE_TOUT 1000
#define CONFIG_SYS_FLASH_SIZE 0x2000000 #define CONFIG_SYS_FLASH_CFI_NONBLOCK 1 diff --git a/include/configs/ax25-ae350.h b/include/configs/ax25-ae350.h index daa5cdf5b26b..653acdc9aff1 100644 --- a/include/configs/ax25-ae350.h +++ b/include/configs/ax25-ae350.h @@ -46,9 +46,6 @@ #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 #define CONFIG_SYS_FLASH_BANKS_LIST { PHYS_FLASH_1, }
-#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* TO for Flash Erase (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* TO for Flash Write (ms) */ - /* max number of memory banks */ /* * There are 4 banks supported for this Controller, diff --git a/include/configs/blanche.h b/include/configs/blanche.h index 25b6e7005e7a..76271ebe2e68 100644 --- a/include/configs/blanche.h +++ b/include/configs/blanche.h @@ -33,11 +33,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 1024 #define CONFIG_SYS_FLASH_BANKS_LIST { (CONFIG_SYS_FLASH_BASE) } #define CONFIG_SYS_FLASH_BANKS_SIZES { (CONFIG_SYS_FLASH_SIZE) } - -#define CONFIG_SYS_FLASH_ERASE_TOUT 3000 -#define CONFIG_SYS_FLASH_WRITE_TOUT 3000 -#define CONFIG_SYS_FLASH_LOCK_TOUT 3000 -#define CONFIG_SYS_FLASH_UNLOCK_TOUT 3000 #endif
/* Board Clock */ diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index dd7b6c08730c..5e364b4990a8 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -190,7 +190,6 @@ enter a valid image address in flash */ * FLASH organization */ #define CONFIG_SYS_MAX_FLASH_SECT 11 /* max number of sectors on one chip */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 1000 /* flash timeout */
/*----------------------------------------------------------------------- * Cache Configuration diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 7d666e553b0b..c12cdd413291 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -114,8 +114,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
/* Nand Flash */ #ifdef CONFIG_NAND_FSL_ELBC diff --git a/include/configs/eb_cpu5282.h b/include/configs/eb_cpu5282.h index 6e444c478922..1a05914c1b88 100644 --- a/include/configs/eb_cpu5282.h +++ b/include/configs/eb_cpu5282.h @@ -95,7 +95,6 @@ #define CONFIG_SYS_INT_FLASH_ENABLE 0x21
#define CONFIG_SYS_MAX_FLASH_SECT 128 -#define CONFIG_SYS_FLASH_ERASE_TOUT 10000000
#define CONFIG_SYS_FLASH_SIZE 16*1024*1024
diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index 26f0741be3f1..3dbd141a7699 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -112,9 +112,6 @@
-#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 - /* * NAND FLASH setup */ diff --git a/include/configs/integrator-common.h b/include/configs/integrator-common.h index 4408fd0c2374..512e0e61aa78 100644 --- a/include/configs/integrator-common.h +++ b/include/configs/integrator-common.h @@ -44,5 +44,3 @@ #define CONFIG_SYS_FLASH_BASE 0x24000000
/* Timeout values in ticks */ -#define CONFIG_SYS_FLASH_ERASE_TOUT (2 * CONFIG_SYS_HZ) /* Erase Timeout */ -#define CONFIG_SYS_FLASH_WRITE_TOUT (2 * CONFIG_SYS_HZ) /* Write Timeout */ diff --git a/include/configs/km/pg-wcom-ls102xa.h b/include/configs/km/pg-wcom-ls102xa.h index 1477483db5bf..1d9e0b6551e6 100644 --- a/include/configs/km/pg-wcom-ls102xa.h +++ b/include/configs/km/pg-wcom-ls102xa.h @@ -65,8 +65,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 83c676803bba..9147a726e592 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -44,13 +44,9 @@ #define FLASH_SECTOR_SIZE (256 * 1024) /* 256 KB sectors */
/* Timeout for Flash erase operations (in ms) */ -#define CONFIG_SYS_FLASH_ERASE_TOUT (3 * 1000) /* Timeout for Flash write operations (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT (3 * 1000) /* Timeout for Flash set sector lock bit operations (in ms) */ -#define CONFIG_SYS_FLASH_LOCK_TOUT (3 * 1000) /* Timeout for Flash clear lock bit operations (in ms) */ -#define CONFIG_SYS_FLASH_UNLOCK_TOUT (3 * 1000)
/* GPIO / PFC */ #define CONFIG_SH_GPIO_PFC diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 73f1797b4761..f3e694c3c8cd 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -70,8 +70,6 @@ #define CONFIG_SYS_WRITE_SWAPPED_DATA
#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS, \ CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000} diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 732869ac14a7..8681417eb038 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -99,8 +99,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index f11d3e976bb2..e265b1a48eaf 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -75,8 +75,6 @@ #define CONFIG_SYS_NOR_FTIM3 0
#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS, \ CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000} diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 45b2359dda23..352b7dbdd8d2 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -43,8 +43,6 @@ #define CONFIG_SYS_IFC_CCR 0x01000000
diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 713946301690..261646fe703e 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -92,8 +92,6 @@ #define CONFIG_SYS_NOR_FTIM3 0
#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS, \ CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000} diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index 004de7cfb734..c02acfb85806 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -66,8 +66,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE,\ CONFIG_SYS_FLASH_BASE + 0x40000000} diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h index 14b2c9793bbd..61df2a4253ca 100644 --- a/include/configs/ls1088ardb.h +++ b/include/configs/ls1088ardb.h @@ -51,8 +51,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } #endif diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index ff1c192c6b38..c7146314dfee 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -68,8 +68,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE,\ CONFIG_SYS_FLASH_BASE + 0x40000000} diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index b2dd6c65893a..d20eaec7527f 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -65,8 +65,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE,\ CONFIG_SYS_FLASH_BASE + 0x40000000} diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 95c438f6e970..1c5ef78fc927 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -198,9 +198,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ - /* Nand Flash */ #ifdef CONFIG_NAND_FSL_ELBC #define CONFIG_SYS_NAND_BASE 0xff800000 diff --git a/include/configs/socrates.h b/include/configs/socrates.h index c3b1be969879..185da975fc2f 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -89,8 +89,6 @@ #define CONFIG_SYS_FLASH_BASE CONFIG_SYS_LBC_FLASH_BASE /* start of FLASH */
#define CONFIG_SYS_MAX_FLASH_SECT 256 /* sectors per device */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
#define CONFIG_SYS_LBC_LCRR 0x00030004 /* LB clock ratio reg */ #define CONFIG_SYS_LBC_LBCR 0x00000000 /* LB config reg */ diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index 91ce2fe0ca40..572a5171fc5c 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -173,8 +173,6 @@ #define CONFIG_SYS_FLASH_BASE1 V2M_NOR1
/* 255 0x40000 sectors + first or last sector may have 4 erase regions = 259 */ #define CONFIG_SYS_MAX_FLASH_SECT 259 /* Max sectors */ diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index c9d8d09f194d..cb4f4209728d 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -39,8 +39,6 @@ /* NOR */ #ifdef CONFIG_MTD_NOR_FLASH # define CONFIG_SYS_MAX_FLASH_SECT 512 -# define CONFIG_SYS_FLASH_ERASE_TOUT 1000 -# define CONFIG_SYS_FLASH_WRITE_TOUT 5000 # define CONFIG_FLASH_SHOW_PROGRESS 10 # define CONFIG_SYS_FLASH_QUIET_TEST #endif
As the only pic32 platform does not enable flash, this is dead code. Remove it.
Cc: Purna Chandra Mandal purna.mandal@microchip.com Signed-off-by: Tom Rini trini@konsulko.com --- As an alternative, enabling the driver would be appreciated. --- boot/Kconfig | 2 +- drivers/mtd/Kconfig | 20 -- drivers/mtd/Makefile | 1 - drivers/mtd/pic32_flash.c | 448 -------------------------------------- 4 files changed, 1 insertion(+), 470 deletions(-) delete mode 100644 drivers/mtd/pic32_flash.c
diff --git a/boot/Kconfig b/boot/Kconfig index 17438b566d5c..e62b7834f2e8 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -486,7 +486,7 @@ config SYS_TEXT_BASE config HAVE_SYS_MONITOR_BASE bool depends on ARC || MIPS || M68K || NIOS2 || PPC || XTENSA || X86 \ - || FLASH_PIC32 || ENV_IS_IN_FLASH || MTD_NOR_FLASH + || ENV_IS_IN_FLASH || MTD_NOR_FLASH depends on !EFI_APP default y
diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index e28ff049550b..431168d12ee5 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -149,26 +149,6 @@ config ALTERA_QSPI NOR flash to parallel flash interface. Please find details on the "Embedded Peripherals IP User Guide" of Altera.
-config FLASH_PIC32 - bool "Microchip PIC32 Flash driver" - depends on MACH_PIC32 && DM_MTD - select USE_SYS_MAX_FLASH_BANKS - help - This enables access to Microchip PIC32 internal non-CFI flash - chips through PIC32 Non-Volatile-Memory Controller. - -config SYS_FLASH_ERASE_TOUT - int "Timeout in ms for performing an erase operation on the flash" - depends on FLASH_PIC32 - help - Timeout for Flash erase operations (in ms) - -config SYS_FLASH_WRITE_TOUT - int "Timeout in ms for performing a write operation on the flash" - depends on FLASH_PIC32 - help - Timeout for Flash write operations (in ms) - config RENESAS_RPC_HF bool "Renesas RCar Gen3 RPC HyperFlash driver" depends on RCAR_GEN3 && DM_MTD diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index ce0451108eb5..3a78590aaaa1 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -11,7 +11,6 @@ mtd-$(CONFIG_ALTERA_QSPI) += altera_qspi.o mtd-$(CONFIG_FLASH_CFI_DRIVER) += cfi_flash.o mtd-$(CONFIG_FLASH_CFI_MTD) += cfi_mtd.o mtd-$(CONFIG_FLASH_CFI_LEGACY) += jedec_flash.o -mtd-$(CONFIG_FLASH_PIC32) += pic32_flash.o mtd-$(CONFIG_STM32_FLASH) += stm32_flash.o mtd-$(CONFIG_RENESAS_RPC_HF) += renesas_rpc_hf.o mtd-$(CONFIG_HBMC_AM654) += hbmc-am654.o diff --git a/drivers/mtd/pic32_flash.c b/drivers/mtd/pic32_flash.c deleted file mode 100644 index ea0dbe9eeee5..000000000000 --- a/drivers/mtd/pic32_flash.c +++ /dev/null @@ -1,448 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2015 - * Cristian Birsan cristian.birsan@microchip.com - * Purna Chandra Mandal purna.mandal@microchip.com - */ - -#include <common.h> -#include <cpu_func.h> -#include <dm.h> -#include <fdt_support.h> -#include <flash.h> -#include <init.h> -#include <irq_func.h> -#include <asm/global_data.h> -#include <linux/bitops.h> -#include <mach/pic32.h> -#include <wait_bit.h> - -DECLARE_GLOBAL_DATA_PTR; - -/* NVM Controller registers */ -struct pic32_reg_nvm { - struct pic32_reg_atomic ctrl; - struct pic32_reg_atomic key; - struct pic32_reg_atomic addr; - struct pic32_reg_atomic data; -}; - -/* NVM operations */ -#define NVMOP_NOP 0 -#define NVMOP_WORD_WRITE 1 -#define NVMOP_PAGE_ERASE 4 - -/* NVM control bits */ -#define NVM_WR BIT(15) -#define NVM_WREN BIT(14) -#define NVM_WRERR BIT(13) -#define NVM_LVDERR BIT(12) - -/* NVM programming unlock register */ -#define LOCK_KEY 0x0 -#define UNLOCK_KEY1 0xaa996655 -#define UNLOCK_KEY2 0x556699aa - -/* - * PIC32 flash banks consist of number of pages, each page - * into number of rows and rows into number of words. - * Here we will maintain page information instead of sector. - */ -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; -static struct pic32_reg_nvm *nvm_regs_p; - -static inline void flash_initiate_operation(u32 nvmop) -{ - /* set operation */ - writel(nvmop, &nvm_regs_p->ctrl.raw); - - /* enable flash write */ - writel(NVM_WREN, &nvm_regs_p->ctrl.set); - - /* unlock sequence */ - writel(LOCK_KEY, &nvm_regs_p->key.raw); - writel(UNLOCK_KEY1, &nvm_regs_p->key.raw); - writel(UNLOCK_KEY2, &nvm_regs_p->key.raw); - - /* initiate operation */ - writel(NVM_WR, &nvm_regs_p->ctrl.set); -} - -static int flash_wait_till_busy(const char *func, ulong timeout) -{ - int ret = wait_for_bit_le32(&nvm_regs_p->ctrl.raw, - NVM_WR, false, timeout, false); - - return ret ? ERR_TIMEOUT : ERR_OK; -} - -static inline int flash_complete_operation(void) -{ - u32 tmp; - - tmp = readl(&nvm_regs_p->ctrl.raw); - if (tmp & NVM_WRERR) { - printf("Error in Block Erase - Lock Bit may be set!\n"); - flash_initiate_operation(NVMOP_NOP); - return ERR_PROTECTED; - } - - if (tmp & NVM_LVDERR) { - printf("Error in Block Erase - low-vol detected!\n"); - flash_initiate_operation(NVMOP_NOP); - return ERR_NOT_ERASED; - } - - /* disable flash write or erase operation */ - writel(NVM_WREN, &nvm_regs_p->ctrl.clr); - - return ERR_OK; -} - -/* - * Erase flash sectors, returns: - * ERR_OK - OK - * ERR_INVAL - invalid sector arguments - * ERR_TIMEOUT - write timeout - * ERR_NOT_ERASED - Flash not erased - * ERR_UNKNOWN_FLASH_VENDOR - incorrect flash - */ -int flash_erase(flash_info_t *info, int s_first, int s_last) -{ - ulong sect_start, sect_end, flags; - int prot, sect; - int rc; - - if ((info->flash_id & FLASH_VENDMASK) != FLASH_MAN_MCHP) { - printf("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return ERR_UNKNOWN_FLASH_VENDOR; - } - - if ((s_first < 0) || (s_first > s_last)) { - printf("- no sectors to erase\n"); - return ERR_INVAL; - } - - prot = 0; - for (sect = s_first; sect <= s_last; ++sect) { - if (info->protect[sect]) - prot++; - } - - if (prot) - printf("- Warning: %d protected sectors will not be erased!\n", - prot); - else - printf("\n"); - - /* erase on unprotected sectors */ - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect]) - continue; - - /* disable interrupts */ - flags = disable_interrupts(); - - /* write destination page address (physical) */ - sect_start = CPHYSADDR(info->start[sect]); - writel(sect_start, &nvm_regs_p->addr.raw); - - /* page erase */ - flash_initiate_operation(NVMOP_PAGE_ERASE); - - /* wait */ - rc = flash_wait_till_busy(__func__, - CONFIG_SYS_FLASH_ERASE_TOUT); - - /* re-enable interrupts if necessary */ - if (flags) - enable_interrupts(); - - if (rc != ERR_OK) - return rc; - - rc = flash_complete_operation(); - if (rc != ERR_OK) - return rc; - - /* - * flash content is updated but cache might contain stale - * data, so invalidate dcache. - */ - sect_end = info->start[sect] + info->size / info->sector_count; - invalidate_dcache_range(info->start[sect], sect_end); - } - - printf(" done\n"); - return ERR_OK; -} - -int page_erase(flash_info_t *info, int sect) -{ - return 0; -} - -/* Write a word to flash */ -static int write_word(flash_info_t *info, ulong dest, ulong word) -{ - ulong flags; - int rc; - - /* read flash to check if it is sufficiently erased */ - if ((readl((void __iomem *)dest) & word) != word) { - printf("Error, Flash not erased!\n"); - return ERR_NOT_ERASED; - } - - /* disable interrupts */ - flags = disable_interrupts(); - - /* update destination page address (physical) */ - writel(CPHYSADDR(dest), &nvm_regs_p->addr.raw); - writel(word, &nvm_regs_p->data.raw); - - /* word write */ - flash_initiate_operation(NVMOP_WORD_WRITE); - - /* wait for operation to complete */ - rc = flash_wait_till_busy(__func__, CONFIG_SYS_FLASH_WRITE_TOUT); - - /* re-enable interrupts if necessary */ - if (flags) - enable_interrupts(); - - if (rc != ERR_OK) - return rc; - - return flash_complete_operation(); -} - -/* - * Copy memory to flash, returns: - * ERR_OK - OK - * ERR_TIMEOUT - write timeout - * ERR_NOT_ERASED - Flash not erased - */ -int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong dst, tmp_le, len = cnt; - int i, l, rc; - uchar *cp; - - /* get lower word aligned address */ - dst = (addr & ~3); - - /* handle unaligned start bytes */ - l = addr - dst; - if (l != 0) { - tmp_le = 0; - for (i = 0, cp = (uchar *)dst; i < l; ++i, ++cp) - tmp_le |= *cp << (i * 8); - - for (; (i < 4) && (cnt > 0); ++i, ++src, --cnt, ++cp) - tmp_le |= *src << (i * 8); - - for (; (cnt == 0) && (i < 4); ++i, ++cp) - tmp_le |= *cp << (i * 8); - - rc = write_word(info, dst, tmp_le); - if (rc) - goto out; - - dst += 4; - } - - /* handle word aligned part */ - while (cnt >= 4) { - tmp_le = src[0] | src[1] << 8 | src[2] << 16 | src[3] << 24; - rc = write_word(info, dst, tmp_le); - if (rc) - goto out; - src += 4; - dst += 4; - cnt -= 4; - } - - if (cnt == 0) { - rc = ERR_OK; - goto out; - } - - /* handle unaligned tail bytes */ - tmp_le = 0; - for (i = 0, cp = (uchar *)dst; (i < 4) && (cnt > 0); ++i, ++cp) { - tmp_le |= *src++ << (i * 8); - --cnt; - } - - for (; i < 4; ++i, ++cp) - tmp_le |= *cp << (i * 8); - - rc = write_word(info, dst, tmp_le); -out: - /* - * flash content updated by nvm controller but CPU cache might - * have stale data, so invalidate dcache. - */ - invalidate_dcache_range(addr, addr + len); - - printf(" done\n"); - return rc; -} - -void flash_print_info(flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_MCHP: - printf("Microchip Technology "); - break; - default: - printf("Unknown Vendor "); - break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_MCHP100T: - printf("Internal (8 Mbit, 64 x 16k)\n"); - break; - default: - printf("Unknown Chip Type\n"); - break; - } - - printf(" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf(" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; ++i) { - if ((i % 5) == 0) - printf("\n "); - - printf(" %08lX%s", info->start[i], - info->protect[i] ? " (RO)" : " "); - } - printf("\n"); -} - -unsigned long flash_init(void) -{ - unsigned long size = 0; - struct udevice *dev; - int bank; - - /* probe every MTD device */ - for (uclass_first_device(UCLASS_MTD, &dev); dev; - uclass_next_device(&dev)) { - /* nop */ - } - - /* calc total flash size */ - for (bank = 0; bank < CONFIG_SYS_MAX_FLASH_BANKS; ++bank) - size += flash_info[bank].size; - - return size; -} - -static void pic32_flash_bank_init(flash_info_t *info, - ulong base, ulong size) -{ - ulong sect_size; - int sect; - - /* device & manufacturer code */ - info->flash_id = FLASH_MAN_MCHP | FLASH_MCHP100T; - info->sector_count = CONFIG_SYS_MAX_FLASH_SECT; - info->size = size; - - /* update sector (i.e page) info */ - sect_size = info->size / info->sector_count; - for (sect = 0; sect < info->sector_count; sect++) { - info->start[sect] = base; - /* protect each sector by default */ - info->protect[sect] = 1; - base += sect_size; - } -} - -static int pic32_flash_probe(struct udevice *dev) -{ - void *blob = (void *)gd->fdt_blob; - int node = dev_of_offset(dev); - const char *list, *end; - const fdt32_t *cell; - unsigned long addr, size; - int parent, addrc, sizec; - flash_info_t *info; - int len, idx; - - /* - * decode regs. there are multiple reg tuples, and they need to - * match with reg-names. - */ - parent = fdt_parent_offset(blob, node); - fdt_support_default_count_cells(blob, parent, &addrc, &sizec); - list = fdt_getprop(blob, node, "reg-names", &len); - if (!list) - return -ENOENT; - - end = list + len; - cell = fdt_getprop(blob, node, "reg", &len); - if (!cell) - return -ENOENT; - - for (idx = 0, info = &flash_info[0]; list < end;) { - addr = fdt_translate_address((void *)blob, node, cell + idx); - size = fdt_addr_to_cpu(cell[idx + addrc]); - len = strlen(list); - if (!strncmp(list, "nvm", len)) { - /* NVM controller */ - nvm_regs_p = ioremap(addr, size); - } else if (!strncmp(list, "bank", 4)) { - /* Flash bank: use kseg0 cached address */ - pic32_flash_bank_init(info, CKSEG0ADDR(addr), size); - info++; - } - idx += addrc + sizec; - list += len + 1; - } - - /* disable flash write/erase operations */ - writel(NVM_WREN, &nvm_regs_p->ctrl.clr); - -#if (CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE) - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE - 1, - &flash_info[0]); -#endif - return 0; -} - -static const struct udevice_id pic32_flash_ids[] = { - { .compatible = "microchip,pic32mzda-flash" }, - {} -}; - -U_BOOT_DRIVER(pic32_flash) = { - .name = "pic32_flash", - .id = UCLASS_MTD, - .of_match = pic32_flash_ids, - .probe = pic32_flash_probe, -};
This converts the following to Kconfig: CONFIG_FLASH_CFI_LEGACY
Signed-off-by: Tom Rini trini@konsulko.com --- board/freescale/m5253demo/Kconfig | 4 ++++ include/configs/M5253DEMO.h | 1 - 2 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/board/freescale/m5253demo/Kconfig b/board/freescale/m5253demo/Kconfig index 303d29bc23a2..0ecce875d149 100644 --- a/board/freescale/m5253demo/Kconfig +++ b/board/freescale/m5253demo/Kconfig @@ -1,5 +1,9 @@ if TARGET_M5253DEMO
+config FLASH_CFI_LEGACY + depends on SYS_FLASH_CFI + def_bool y + config SYS_CPU default "mcf52x2"
diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index 88c2bbbf25f2..b88280c90cdf 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -105,7 +105,6 @@ * 0x30 is block erase in SST */ # define CONFIG_SYS_FLASH_SIZE 0x800000 -# define CONFIG_FLASH_CFI_LEGACY #else # define CONFIG_SYS_SST_SECT 2048 # define CONFIG_SYS_SST_SECTSZ 0x1000
A large number of files include <flash.h> as it used to be how various SPI flash related functions were found, or for other reasons entirely. In order to migrate some further CONFIG symbols to Kconfig we need to not include flash.h in cases where we don't have a NOR flash of some sort enabled. Furthermore, in cases where we are in common code and it doesn't make sense to try and further refactor the code itself in to new files we need to guard this inclusion.
Signed-off-by: Tom Rini trini@konsulko.com --- board/atmel/at91sam9263ek/at91sam9263ek.c | 3 +-- board/buffalo/lsxl/lsxl.c | 1 - board/freescale/common/fsl_validate.c | 3 ++- board/gardena/smart-gateway-mt7688/board.c | 1 - board/logicpd/omap3som/omap3logic.c | 1 - board/siemens/taurus/taurus.c | 1 - board/socrates/socrates.c | 2 -- board/toradex/common/tdx-cfg-block.c | 2 ++ cmd/bootm.c | 1 - cmd/cramfs.c | 2 +- cmd/cros_ec.c | 1 - cmd/flash.c | 1 - cmd/jffs2.c | 5 ++--- cmd/load.c | 2 ++ cmd/mem.c | 2 ++ cmd/mvebu/bubt.c | 1 - cmd/sf.c | 1 - common/board_r.c | 2 ++ common/flash.c | 2 -- common/update.c | 5 ++--- drivers/dfu/dfu_sf.c | 1 - drivers/fastboot/fb_command.c | 1 - drivers/fastboot/fb_mmc.c | 1 - drivers/fastboot/fb_nand.c | 1 - drivers/misc/cros_ec.c | 1 - drivers/mtd/spi/sf_dataflash.c | 1 - drivers/mtd/spi/sf_mtd.c | 1 - drivers/mtd/spi/spi-nor-core.c | 1 - env/flash.c | 2 +- env/sf.c | 1 - fs/cramfs/cramfs.c | 3 +-- fs/jffs2/jffs2_1pass.c | 4 ++-- include/flash.h | 5 +---- include/mtd/cfi_flash.h | 1 - net/nfs.c | 2 ++ post/drivers/flash.c | 4 +--- 36 files changed, 24 insertions(+), 45 deletions(-)
diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c index c3e1734dda0c..86b4050c4c17 100644 --- a/board/atmel/at91sam9263ek/at91sam9263ek.c +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -7,7 +7,6 @@
#include <common.h> #include <debug_uart.h> -#include <flash.h> #include <init.h> #include <net.h> #include <vsprintf.h> @@ -140,7 +139,7 @@ static void at91sam9263ek_lcd_hw_init(void) #include <version.h>
#ifdef CONFIG_MTD_NOR_FLASH -extern flash_info_t flash_info[]; +#include <flash.h> #endif
void lcd_show_board_info(void) diff --git a/board/buffalo/lsxl/lsxl.c b/board/buffalo/lsxl/lsxl.c index 738b6bc25cea..31d532b75294 100644 --- a/board/buffalo/lsxl/lsxl.c +++ b/board/buffalo/lsxl/lsxl.c @@ -12,7 +12,6 @@ #include <command.h> #include <env.h> #include <env_internal.h> -#include <flash.h> #include <init.h> #include <net.h> #include <malloc.h> diff --git a/board/freescale/common/fsl_validate.c b/board/freescale/common/fsl_validate.c index f1a0b0cfc34c..f56e4e857af1 100644 --- a/board/freescale/common/fsl_validate.c +++ b/board/freescale/common/fsl_validate.c @@ -6,7 +6,6 @@
#include <common.h> #include <dm.h> -#include <flash.h> #include <fsl_validate.h> #include <fsl_secboot_err.h> #include <fsl_sfp.h> @@ -79,6 +78,8 @@ static u32 check_ie(struct fsl_secboot_img_priv *img) * address */ #if defined(CONFIG_MPC85xx) +#include <flash.h> + int get_csf_base_addr(u32 *csf_addr, u32 *flash_base_addr) { struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); diff --git a/board/gardena/smart-gateway-mt7688/board.c b/board/gardena/smart-gateway-mt7688/board.c index aa833a030fd9..0cfde91c94c6 100644 --- a/board/gardena/smart-gateway-mt7688/board.c +++ b/board/gardena/smart-gateway-mt7688/board.c @@ -7,7 +7,6 @@ #include <command.h> #include <env.h> #include <env_internal.h> -#include <flash.h> #include <init.h> #include <led.h> #include <log.h> diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index 2379b521904a..559192e9001e 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -15,7 +15,6 @@ #include <init.h> #include <net.h> #include <ns16550.h> -#include <flash.h> #include <nand.h> #include <i2c.h> #include <serial.h> diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index dae064d4654a..6c44afb44875 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -15,7 +15,6 @@ #include <common.h> #include <dm.h> #include <env.h> -#include <flash.h> #include <init.h> #include <asm/global_data.h> #include <asm/io.h> diff --git a/board/socrates/socrates.c b/board/socrates/socrates.c index 27aad4eaae3a..f9e1bc631648 100644 --- a/board/socrates/socrates.c +++ b/board/socrates/socrates.c @@ -30,8 +30,6 @@
-extern flash_info_t flash_info[]; /* FLASH chips info */ - void local_bus_init (void); ulong flash_get_size (ulong base, int banknum);
diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index 9305709a3c0d..5c4657e5ea92 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -25,7 +25,9 @@ #include <cli.h> #include <console.h> #include <env.h> +#ifdef CONFIG_TDX_CFG_BLOCK_IS_IN_NOR #include <flash.h> +#endif #include <malloc.h> #include <mmc.h> #include <nand.h> diff --git a/cmd/bootm.c b/cmd/bootm.c index 1f70ee9e911b..9fe8ce4a27cf 100644 --- a/cmd/bootm.c +++ b/cmd/bootm.c @@ -31,7 +31,6 @@ static int image_info(unsigned long addr); #if defined(CONFIG_CMD_IMLS) #include <flash.h> #include <mtd/cfi_flash.h> -extern flash_info_t flash_info[]; /* info for FLASH chips */ #endif
#if defined(CONFIG_CMD_IMLS) || defined(CONFIG_CMD_IMLS_NAND) diff --git a/cmd/cramfs.c b/cmd/cramfs.c index 2aad50c6724c..57e2afa2472b 100644 --- a/cmd/cramfs.c +++ b/cmd/cramfs.c @@ -33,11 +33,11 @@ # define DEBUGF(fmt, args...) #endif
-#include <flash.h>
#ifndef CONFIG_MTD_NOR_FLASH # define OFFSET_ADJUSTMENT 0 #else +#include <flash.h> # define OFFSET_ADJUSTMENT (flash_info[id.num].start[0]) #endif
diff --git a/cmd/cros_ec.c b/cmd/cros_ec.c index ad49905d67bb..90921cecf602 100644 --- a/cmd/cros_ec.c +++ b/cmd/cros_ec.c @@ -10,7 +10,6 @@ #include <command.h> #include <cros_ec.h> #include <dm.h> -#include <flash.h> #include <log.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> diff --git a/cmd/flash.c b/cmd/flash.c index db4bb2529c6a..f4f85ecc7a8e 100644 --- a/cmd/flash.c +++ b/cmd/flash.c @@ -25,7 +25,6 @@ int find_dev_and_part(const char *id, struct mtd_device **dev, #ifdef CONFIG_MTD_NOR_FLASH #include <flash.h> #include <mtd/cfi_flash.h> -extern flash_info_t flash_info[]; /* info for FLASH chips */
/* * The user interface starts numbering for Flash banks with 1 diff --git a/cmd/jffs2.c b/cmd/jffs2.c index 914a7beeed95..e00fcc202266 100644 --- a/cmd/jffs2.c +++ b/cmd/jffs2.c @@ -73,7 +73,9 @@ #include <common.h> #include <command.h> #include <env.h> +#if defined(CONFIG_CMD_FLASH) #include <flash.h> +#endif #include <image.h> #include <malloc.h> #include <jffs2/jffs2.h> @@ -156,7 +158,6 @@ static int mtd_device_validate(u8 type, u8 num, u32 *size) if (type == MTD_DEV_TYPE_NOR) { #if defined(CONFIG_CMD_FLASH) if (num < CONFIG_SYS_MAX_FLASH_BANKS) { - extern flash_info_t flash_info[]; *size = flash_info[num].size;
return 0; @@ -260,8 +261,6 @@ static inline u32 get_part_sector_size_nand(struct mtdids *id) static inline u32 get_part_sector_size_nor(struct mtdids *id, struct part_info *part) { #if defined(CONFIG_CMD_FLASH) - extern flash_info_t flash_info[]; - u32 end_phys, start_phys, sector_size = 0, size = 0; int i; flash_info_t *flash; diff --git a/cmd/load.c b/cmd/load.c index 1224a7f85bb3..e44ae0d56b75 100644 --- a/cmd/load.c +++ b/cmd/load.c @@ -14,7 +14,9 @@ #include <efi_loader.h> #include <env.h> #include <exports.h> +#ifdef CONFIG_MTD_NOR_FLASH #include <flash.h> +#endif #include <image.h> #include <lmb.h> #include <mapmem.h> diff --git a/cmd/mem.c b/cmd/mem.c index b7511382d3ac..1f4e3fcdede1 100644 --- a/cmd/mem.c +++ b/cmd/mem.c @@ -16,7 +16,9 @@ #include <cli.h> #include <command.h> #include <console.h> +#ifdef CONFIG_MTD_NOR_FLASH #include <flash.h> +#endif #include <hash.h> #include <log.h> #include <mapmem.h> diff --git a/cmd/mvebu/bubt.c b/cmd/mvebu/bubt.c index 1362c03bcee5..92101cfc8058 100644 --- a/cmd/mvebu/bubt.c +++ b/cmd/mvebu/bubt.c @@ -8,7 +8,6 @@ #include <common.h> #include <command.h> #include <env.h> -#include <flash.h> #include <image.h> #include <net.h> #include <vsprintf.h> diff --git a/cmd/sf.c b/cmd/sf.c index cd50b38081c2..058635cb2f83 100644 --- a/cmd/sf.c +++ b/cmd/sf.c @@ -9,7 +9,6 @@ #include <command.h> #include <div64.h> #include <dm.h> -#include <flash.h> #include <log.h> #include <malloc.h> #include <mapmem.h> diff --git a/common/board_r.c b/common/board_r.c index ed29069d2de6..e702f0234ee7 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -14,7 +14,9 @@ #include <bootstage.h> #include <cpu_func.h> #include <exports.h> +#ifdef CONFIG_MTD_NOR_FLASH #include <flash.h> +#endif #include <hang.h> #include <image.h> #include <irq_func.h> diff --git a/common/flash.c b/common/flash.c index f939c2f9e954..848f44e59dfd 100644 --- a/common/flash.c +++ b/common/flash.c @@ -13,8 +13,6 @@
-extern flash_info_t flash_info[]; /* info for FLASH chips */ - /*----------------------------------------------------------------------- * Functions */ diff --git a/common/update.c b/common/update.c index b9ad475d9d44..80f16af65358 100644 --- a/common/update.c +++ b/common/update.c @@ -20,14 +20,12 @@
#include <command.h> #include <env.h> -#include <flash.h> #include <net.h> #include <net/tftp.h> #include <malloc.h> #include <mapmem.h> #include <dfu.h> #include <errno.h> -#include <mtd/cfi_flash.h>
#if defined(CONFIG_DFU_TFTP) || defined(CONFIG_UPDATE_TFTP) /* env variable holding the location of the update file */ @@ -49,7 +47,8 @@ extern ulong tftp_timeout_ms; extern int tftp_timeout_count_max; #ifdef CONFIG_MTD_NOR_FLASH -extern flash_info_t flash_info[]; +#include <flash.h> +#include <mtd/cfi_flash.h> static uchar *saved_prot_info; #endif static int update_load(char *filename, ulong msec_max, int cnt_max, ulong addr) diff --git a/drivers/dfu/dfu_sf.c b/drivers/dfu/dfu_sf.c index 25a9c8185037..2dae15937064 100644 --- a/drivers/dfu/dfu_sf.c +++ b/drivers/dfu/dfu_sf.c @@ -4,7 +4,6 @@ */
#include <common.h> -#include <flash.h> #include <malloc.h> #include <errno.h> #include <div64.h> diff --git a/drivers/fastboot/fb_command.c b/drivers/fastboot/fb_command.c index 98eccc34556b..bdfdf262c8a3 100644 --- a/drivers/fastboot/fb_command.c +++ b/drivers/fastboot/fb_command.c @@ -10,7 +10,6 @@ #include <fastboot-internal.h> #include <fb_mmc.h> #include <fb_nand.h> -#include <flash.h> #include <part.h> #include <stdlib.h>
diff --git a/drivers/fastboot/fb_mmc.c b/drivers/fastboot/fb_mmc.c index c62e414306c3..033c510bc096 100644 --- a/drivers/fastboot/fb_mmc.c +++ b/drivers/fastboot/fb_mmc.c @@ -10,7 +10,6 @@ #include <fastboot.h> #include <fastboot-internal.h> #include <fb_mmc.h> -#include <flash.h> #include <image-sparse.h> #include <image.h> #include <log.h> diff --git a/drivers/fastboot/fb_nand.c b/drivers/fastboot/fb_nand.c index eb8a36f29222..6d3a900c7728 100644 --- a/drivers/fastboot/fb_nand.c +++ b/drivers/fastboot/fb_nand.c @@ -7,7 +7,6 @@ #include <config.h> #include <common.h> #include <blk.h> -#include <flash.h>
#include <fastboot.h> #include <image-sparse.h> diff --git a/drivers/misc/cros_ec.c b/drivers/misc/cros_ec.c index e131eccd281f..621d1752176a 100644 --- a/drivers/misc/cros_ec.c +++ b/drivers/misc/cros_ec.c @@ -18,7 +18,6 @@ #include <common.h> #include <command.h> #include <dm.h> -#include <flash.h> #include <i2c.h> #include <cros_ec.h> #include <fdtdec.h> diff --git a/drivers/mtd/spi/sf_dataflash.c b/drivers/mtd/spi/sf_dataflash.c index 85867817c786..e19e34244d1f 100644 --- a/drivers/mtd/spi/sf_dataflash.c +++ b/drivers/mtd/spi/sf_dataflash.c @@ -10,7 +10,6 @@ #include <dm.h> #include <errno.h> #include <fdtdec.h> -#include <flash.h> #include <log.h> #include <spi.h> #include <spi_flash.h> diff --git a/drivers/mtd/spi/sf_mtd.c b/drivers/mtd/spi/sf_mtd.c index 0aed28a52b78..071b25ac67f2 100644 --- a/drivers/mtd/spi/sf_mtd.c +++ b/drivers/mtd/spi/sf_mtd.c @@ -4,7 +4,6 @@ */
#include <common.h> -#include <flash.h> #include <malloc.h> #include <linux/errno.h> #include <linux/mtd/mtd.h> diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 8a226a7af553..26a356baf841 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -10,7 +10,6 @@ */
#include <common.h> -#include <flash.h> #include <log.h> #include <watchdog.h> #include <dm.h> diff --git a/env/flash.c b/env/flash.c index 9c8abfa016c4..1e75f8c004ee 100644 --- a/env/flash.c +++ b/env/flash.c @@ -13,7 +13,6 @@ #include <command.h> #include <env.h> #include <env_internal.h> -#include <flash.h> #include <log.h> #include <asm/global_data.h> #include <linux/stddef.h> @@ -26,6 +25,7 @@ DECLARE_GLOBAL_DATA_PTR;
#ifndef CONFIG_SPL_BUILD # if defined(CONFIG_CMD_SAVEENV) && defined(CONFIG_CMD_FLASH) +# include <flash.h> # define CMD_SAVEENV # elif defined(CONFIG_ENV_ADDR_REDUND) # error CONFIG_ENV_ADDR_REDUND must have CONFIG_CMD_SAVEENV & CONFIG_CMD_FLASH diff --git a/env/sf.c b/env/sf.c index 4b768542c14c..a425ecc11c8e 100644 --- a/env/sf.c +++ b/env/sf.c @@ -12,7 +12,6 @@ #include <dm.h> #include <env.h> #include <env_internal.h> -#include <flash.h> #include <malloc.h> #include <spi.h> #include <spi_flash.h> diff --git a/fs/cramfs/cramfs.c b/fs/cramfs/cramfs.c index 7ef48bbc064c..6c017cebc50f 100644 --- a/fs/cramfs/cramfs.c +++ b/fs/cramfs/cramfs.c @@ -25,7 +25,6 @@ */
#include <common.h> -#include <flash.h> #include <malloc.h> #include <asm/byteorder.h> #include <linux/stat.h> @@ -43,7 +42,7 @@ struct cramfs_super super; /* CPU address space offset calculation macro, struct part_info offset is * device address space offset, so we need to shift it by a device start address. */ #if defined(CONFIG_MTD_NOR_FLASH) -extern flash_info_t flash_info[]; +#include <flash.h> #define PART_OFFSET(x) ((ulong)x->offset + \ flash_info[x->dev->id->num].start[0]) #else diff --git a/fs/jffs2/jffs2_1pass.c b/fs/jffs2/jffs2_1pass.c index 1818e8121569..ef7b302725ca 100644 --- a/fs/jffs2/jffs2_1pass.c +++ b/fs/jffs2/jffs2_1pass.c @@ -113,7 +113,6 @@
#include <common.h> #include <config.h> -#include <flash.h> #include <malloc.h> #include <div64.h> #include <linux/compiler.h> @@ -381,6 +380,8 @@ static void put_fl_mem_onenand(void *buf)
#if defined(CONFIG_CMD_FLASH) +#include <flash.h> + /* * Support for jffs2 on top of NOR-flash * @@ -392,7 +393,6 @@ static inline void *get_fl_mem_nor(u32 off, u32 size, void *ext_buf) u32 addr = off; struct mtdids *id = current_part->dev->id;
- extern flash_info_t flash_info[]; flash_info_t *flash = &flash_info[id->num];
addr += flash->start[0]; diff --git a/include/flash.h b/include/flash.h index f3959f501202..95992fa689bb 100644 --- a/include/flash.h +++ b/include/flash.h @@ -7,10 +7,6 @@ #ifndef _FLASH_H_ #define _FLASH_H_
-#ifndef CONFIG_SYS_MAX_FLASH_SECT -#define CONFIG_SYS_MAX_FLASH_SECT 512 -#endif - /*----------------------------------------------------------------------- * FLASH Info: contains chip specific data, per FLASH bank */ @@ -91,6 +87,7 @@ int flash_sect_erase(ulong addr_first, ulong addr_last); int flash_sect_protect(int flag, ulong addr_first, ulong addr_last); int flash_sect_roundb(ulong *addr); unsigned long flash_sector_size(flash_info_t *info, flash_sect_t sect); +void flash_cmd_reset(flash_info_t *info); void flash_set_verbose(uint v);
/* common/flash.c */ diff --git a/include/mtd/cfi_flash.h b/include/mtd/cfi_flash.h index d4aeea7e464b..1321da191028 100644 --- a/include/mtd/cfi_flash.h +++ b/include/mtd/cfi_flash.h @@ -176,7 +176,6 @@ extern int cfi_flash_num_flash_banks;
phys_addr_t cfi_flash_bank_addr(int i); unsigned long cfi_flash_bank_size(int i); -void flash_cmd_reset(flash_info_t *info);
#ifdef CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS void flash_write8(u8 value, void *addr); diff --git a/net/nfs.c b/net/nfs.c index 9152ab742ef1..9f65cfb20dc9 100644 --- a/net/nfs.c +++ b/net/nfs.c @@ -28,7 +28,9 @@
#include <common.h> #include <command.h> +#ifdef CONFIG_SYS_DIRECT_FLASH_NFS #include <flash.h> +#endif #include <image.h> #include <log.h> #include <net.h> diff --git a/post/drivers/flash.c b/post/drivers/flash.c index 07eab332d21b..7d65f46d9fea 100644 --- a/post/drivers/flash.c +++ b/post/drivers/flash.c @@ -6,12 +6,12 @@ * Licensed under the GPL-2 or later. */
+#if CONFIG_POST & CONFIG_SYS_POST_FLASH #include <common.h> #include <malloc.h> #include <post.h> #include <flash.h>
-#if CONFIG_POST & CONFIG_SYS_POST_FLASH
/* * This code will walk over the declared sectors erasing them, @@ -30,8 +30,6 @@ # error "invalid flash block start/end" #endif
-extern flash_info_t flash_info[]; - static void *seed_src_data(void *ptr, ulong *old_len, ulong new_len) { unsigned char *p;
This converts the following to Kconfig: CONFIG_SYS_MAX_FLASH_SECT
Signed-off-by: Tom Rini trini@konsulko.com --- README | 3 --- configs/10m50_defconfig | 1 + configs/M5208EVBE_defconfig | 1 + configs/M5235EVB_Flash32_defconfig | 1 + configs/M5235EVB_defconfig | 1 + configs/M5249EVB_defconfig | 1 + configs/M5253DEMO_defconfig | 1 + configs/M5272C3_defconfig | 1 + configs/M5275EVB_defconfig | 1 + configs/M5282EVB_defconfig | 1 + configs/M53017EVB_defconfig | 1 + configs/M5329AFEE_defconfig | 1 + configs/M5329BFEE_defconfig | 1 + configs/M5373EVB_defconfig | 1 + configs/MCR3000_defconfig | 1 + configs/MPC837XERDB_defconfig | 1 + configs/MPC8548CDS_36BIT_defconfig | 1 + configs/MPC8548CDS_defconfig | 1 + configs/MPC8548CDS_legacy_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/P2041RDB_NAND_defconfig | 1 + configs/P2041RDB_SDCARD_defconfig | 1 + configs/P2041RDB_SPIFLASH_defconfig | 1 + configs/P2041RDB_defconfig | 1 + configs/P3041DS_NAND_defconfig | 1 + configs/P3041DS_SDCARD_defconfig | 1 + configs/P3041DS_SPIFLASH_defconfig | 1 + configs/P3041DS_defconfig | 1 + configs/P4080DS_SDCARD_defconfig | 1 + configs/P4080DS_SPIFLASH_defconfig | 1 + configs/P4080DS_defconfig | 1 + configs/P5040DS_NAND_defconfig | 1 + configs/P5040DS_SDCARD_defconfig | 1 + configs/P5040DS_SPIFLASH_defconfig | 1 + configs/P5040DS_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 1 + configs/T2080QDS_SDCARD_defconfig | 1 + configs/T2080QDS_SECURE_BOOT_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 1 + configs/T2080QDS_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2080RDB_defconfig | 1 + configs/T2080RDB_revD_NAND_defconfig | 1 + configs/T2080RDB_revD_SDCARD_defconfig | 1 + configs/T2080RDB_revD_SPIFLASH_defconfig | 1 + configs/T2080RDB_revD_defconfig | 1 + configs/T4240RDB_SDCARD_defconfig | 1 + configs/T4240RDB_defconfig | 1 + configs/amcore_defconfig | 1 + configs/astro_mcf5373l_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/blanche_defconfig | 1 + configs/boston32r2_defconfig | 1 + configs/boston32r2el_defconfig | 1 + configs/boston32r6_defconfig | 1 + configs/boston32r6el_defconfig | 1 + configs/boston64r2_defconfig | 1 + configs/boston64r2el_defconfig | 1 + configs/boston64r6_defconfig | 1 + configs/boston64r6el_defconfig | 1 + configs/cobra5272_defconfig | 1 + configs/da850evm_direct_nor_defconfig | 1 + configs/devkit3250_defconfig | 1 + configs/eb_cpu5282_defconfig | 1 + configs/eb_cpu5282_internal_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/ethernut5_defconfig | 1 + configs/gazerbeam_defconfig | 1 + configs/ids8313_defconfig | 1 + configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + configs/integratorcp_cm1136_defconfig | 1 + configs/integratorcp_cm920t_defconfig | 1 + configs/integratorcp_cm926ejs_defconfig | 1 + configs/integratorcp_cm946es_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043aqds_tfa_defconfig | 1 + configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_defconfig | 1 + configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 1 + configs/ls1046aqds_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_defconfig | 1 + configs/ls1046aqds_lpuart_defconfig | 1 + configs/ls1046aqds_nand_defconfig | 1 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/ls1088aqds_defconfig | 1 + configs/ls1088aqds_sdcard_ifc_defconfig | 1 + configs/ls1088aqds_tfa_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + configs/ls2088aqds_tfa_defconfig | 1 + configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 1 + configs/malta64_defconfig | 1 + configs/malta64el_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + configs/microblaze-generic_defconfig | 1 + configs/octeon_ebb7304_defconfig | 1 + configs/omap35_logic_somlv_defconfig | 1 + configs/omap3_logic_somlv_defconfig | 1 + configs/pm9261_defconfig | 1 + configs/pm9263_defconfig | 1 + configs/qemu_arm64_defconfig | 1 + configs/qemu_arm_defconfig | 1 + configs/r2dplus_defconfig | 1 + configs/r8a77990_ebisu_defconfig | 1 + configs/r8a77995_draak_defconfig | 1 + configs/rcar3_salvator-x_defconfig | 1 + configs/rcar3_ulcb_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/socrates_defconfig | 1 + configs/stm32746g-eval_defconfig | 1 + configs/stm32746g-eval_spl_defconfig | 1 + configs/stm32f429-discovery_defconfig | 1 + configs/stm32f429-evaluation_defconfig | 1 + configs/stm32f469-discovery_defconfig | 1 + configs/stm32f746-disco_defconfig | 1 + configs/stm32f746-disco_spl_defconfig | 1 + configs/stm32f769-disco_defconfig | 1 + configs/stm32f769-disco_spl_defconfig | 1 + configs/total_compute_defconfig | 1 + configs/vexpress_aemv8a_juno_defconfig | 1 + configs/vexpress_aemv8a_semi_defconfig | 1 + configs/vexpress_ca9x4_defconfig | 1 + configs/xtfpga_defconfig | 1 + drivers/mtd/Kconfig | 5 +++++ include/configs/10m50_devboard.h | 1 - include/configs/3c120_devboard.h | 1 - include/configs/M5208EVBE.h | 1 - include/configs/M5235EVB.h | 1 - include/configs/M5249EVB.h | 1 - include/configs/M5253DEMO.h | 1 - include/configs/M5272C3.h | 1 - include/configs/M5275EVB.h | 1 - include/configs/M5282EVB.h | 1 - include/configs/M53017EVB.h | 1 - include/configs/M5329EVB.h | 1 - include/configs/M5373EVB.h | 1 - include/configs/MCR3000.h | 1 - include/configs/MPC837XERDB.h | 3 --- include/configs/MPC8548CDS.h | 1 - include/configs/P1010RDB.h | 1 - include/configs/P2041RDB.h | 2 -- include/configs/T102xRDB.h | 2 -- include/configs/T104xRDB.h | 2 -- include/configs/T208xQDS.h | 2 -- include/configs/T208xRDB.h | 1 - include/configs/T4240RDB.h | 2 -- include/configs/am335x_evm.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/amcore.h | 1 - include/configs/armadillo-800eva.h | 1 - include/configs/astro_mcf5373l.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/ax25-ae350.h | 1 - include/configs/blanche.h | 1 - include/configs/boston.h | 6 ------ include/configs/cobra5272.h | 5 ----- include/configs/corenet_ds.h | 2 -- include/configs/da850evm.h | 2 -- include/configs/devkit3250.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/draak.h | 1 - include/configs/eb_cpu5282.h | 2 -- include/configs/ebisu.h | 1 - include/configs/edminiv2.h | 1 - include/configs/ethernut5.h | 1 - include/configs/gazerbeam.h | 2 -- include/configs/ids8313.h | 3 --- include/configs/imx27lite-common.h | 2 -- include/configs/integratorap.h | 1 - include/configs/integratorcp.h | 1 - include/configs/km/km-mpc83xx.h | 1 - include/configs/km/pg-wcom-ls102xa.h | 2 -- include/configs/kmcent2.h | 2 -- include/configs/kzm9g.h | 1 - include/configs/ls1021aqds.h | 2 -- include/configs/ls1021atwr.h | 2 -- include/configs/ls1043aqds.h | 2 -- include/configs/ls1043ardb.h | 2 -- include/configs/ls1046aqds.h | 2 -- include/configs/ls1088aqds.h | 2 -- include/configs/ls1088ardb.h | 2 -- include/configs/ls2080aqds.h | 2 -- include/configs/ls2080ardb.h | 2 -- include/configs/lsxl.h | 3 --- include/configs/malta.h | 1 - include/configs/microblaze-generic.h | 7 ------- include/configs/mx6sabreauto.h | 1 - include/configs/octeon_ebb7304.h | 5 ----- include/configs/omap3_logic.h | 1 - include/configs/p1_p2_rdb_pc.h | 2 -- include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/qemu-arm.h | 2 -- include/configs/r2dplus.h | 1 - include/configs/salvator-x.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/socrates.h | 2 -- include/configs/stm32f429-discovery.h | 2 -- include/configs/stm32f429-evaluation.h | 2 -- include/configs/stm32f469-discovery.h | 2 -- include/configs/stm32f746-disco.h | 2 -- include/configs/total_compute.h | 4 ---- include/configs/ulcb.h | 1 - include/configs/vexpress_aemv8.h | 9 --------- include/configs/vexpress_common.h | 4 ---- include/configs/xtfpga.h | 3 --- include/configs/zynq-common.h | 1 - 283 files changed, 203 insertions(+), 155 deletions(-)
diff --git a/README b/README index 157612d00412..d88c350cb914 100644 --- a/README +++ b/README @@ -1756,9 +1756,6 @@ Configuration Settings: Enables allocating and saving a kernel copy of the bd_info in space between "bootm_low" and "bootm_low" + BOOTMAPSZ.
-- CONFIG_SYS_MAX_FLASH_SECT: - Max number of sectors on a Flash chip - - CONFIG_SYS_FLASH_PROTECTION If defined, hardware flash sectors protection is used instead of U-Boot software protection. diff --git a/configs/10m50_defconfig b/configs/10m50_defconfig index 6c56cdc3286d..5083545a069c 100644 --- a/configs/10m50_defconfig +++ b/configs/10m50_defconfig @@ -40,6 +40,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_ALTERA_QSPI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_PHY_MARVELL=y CONFIG_DM_ETH=y CONFIG_PHY_GIGE=y diff --git a/configs/M5208EVBE_defconfig b/configs/M5208EVBE_defconfig index 858fc5bbfd2e..e294d1315cbc 100644 --- a/configs/M5208EVBE_defconfig +++ b/configs/M5208EVBE_defconfig @@ -38,6 +38,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=254 CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y diff --git a/configs/M5235EVB_Flash32_defconfig b/configs/M5235EVB_Flash32_defconfig index c7fd5a07a7c5..571b653b718a 100644 --- a/configs/M5235EVB_Flash32_defconfig +++ b/configs/M5235EVB_Flash32_defconfig @@ -45,6 +45,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_32BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=137 CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y diff --git a/configs/M5235EVB_defconfig b/configs/M5235EVB_defconfig index a14bf427ad0a..7f7d92ba019f 100644 --- a/configs/M5235EVB_defconfig +++ b/configs/M5235EVB_defconfig @@ -45,6 +45,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=137 CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y diff --git a/configs/M5249EVB_defconfig b/configs/M5249EVB_defconfig index 74301045c8e4..e4fb7ab96a83 100644 --- a/configs/M5249EVB_defconfig +++ b/configs/M5249EVB_defconfig @@ -29,4 +29,5 @@ CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_FLASH_CHECKSUM=y +CONFIG_SYS_MAX_FLASH_SECT=137 CONFIG_MCFUART=y diff --git a/configs/M5253DEMO_defconfig b/configs/M5253DEMO_defconfig index 3ed703a7a793..79382eb0fe43 100644 --- a/configs/M5253DEMO_defconfig +++ b/configs/M5253DEMO_defconfig @@ -39,6 +39,7 @@ CONFIG_SYS_FSL_I2C_OFFSET=0x280 CONFIG_SYS_I2C_SLAVE=0x7F CONFIG_SYS_I2C_SPEED=80000 CONFIG_MTD_NOR_FLASH=y +CONFIG_SYS_MAX_FLASH_SECT=2048 CONFIG_USE_SYS_MAX_FLASH_BANKS=y CONFIG_DRIVER_DM9000=y CONFIG_MCFUART=y diff --git a/configs/M5272C3_defconfig b/configs/M5272C3_defconfig index e3f736bf6308..7dc87a2b2736 100644 --- a/configs/M5272C3_defconfig +++ b/configs/M5272C3_defconfig @@ -57,6 +57,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=137 CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y diff --git a/configs/M5275EVB_defconfig b/configs/M5275EVB_defconfig index fe6ffca43c9f..9e2cc332505a 100644 --- a/configs/M5275EVB_defconfig +++ b/configs/M5275EVB_defconfig @@ -41,6 +41,7 @@ CONFIG_SYS_I2C_SPEED=80000 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=11 CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y diff --git a/configs/M5282EVB_defconfig b/configs/M5282EVB_defconfig index aeb7738ebe77..751d80500255 100644 --- a/configs/M5282EVB_defconfig +++ b/configs/M5282EVB_defconfig @@ -34,6 +34,7 @@ CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_FLASH_CHECKSUM=y +CONFIG_SYS_MAX_FLASH_SECT=137 CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y diff --git a/configs/M53017EVB_defconfig b/configs/M53017EVB_defconfig index 28d51eaa9deb..103289193613 100644 --- a/configs/M53017EVB_defconfig +++ b/configs/M53017EVB_defconfig @@ -41,6 +41,7 @@ CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=137 CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_SYS_UNIFY_CACHE=y diff --git a/configs/M5329AFEE_defconfig b/configs/M5329AFEE_defconfig index c59359b820c7..152a0be28ead 100644 --- a/configs/M5329AFEE_defconfig +++ b/configs/M5329AFEE_defconfig @@ -40,6 +40,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=137 CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_SYS_UNIFY_CACHE=y diff --git a/configs/M5329BFEE_defconfig b/configs/M5329BFEE_defconfig index ae4add504b1c..0bb86c158fa0 100644 --- a/configs/M5329BFEE_defconfig +++ b/configs/M5329BFEE_defconfig @@ -41,6 +41,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=137 CONFIG_MTD_RAW_NAND=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y diff --git a/configs/M5373EVB_defconfig b/configs/M5373EVB_defconfig index aead0f45bd30..27f72562d7a3 100644 --- a/configs/M5373EVB_defconfig +++ b/configs/M5373EVB_defconfig @@ -41,6 +41,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=137 CONFIG_MTD_RAW_NAND=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y diff --git a/configs/MCR3000_defconfig b/configs/MCR3000_defconfig index 6adba431ef09..086507e60165 100644 --- a/configs/MCR3000_defconfig +++ b/configs/MCR3000_defconfig @@ -83,6 +83,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=35 CONFIG_MTD_RAW_NAND=y CONFIG_MPC8XX_FEC=y # CONFIG_PCI is not set diff --git a/configs/MPC837XERDB_defconfig b/configs/MPC837XERDB_defconfig index 1004d3c80507..9a421096e7a8 100644 --- a/configs/MPC837XERDB_defconfig +++ b/configs/MPC837XERDB_defconfig @@ -197,6 +197,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_DM_ETH_PHY=y diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index 838a29a1ba8b..def5d6fdf44b 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -63,6 +63,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index 2912b4446c68..881fca912b9b 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -62,6 +62,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index 0f5b166f9987..99a63300af90 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -62,6 +62,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index a4cf3ba22023..3c5e62d10b4a 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -101,6 +101,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 0de8d87f1192..e5deb252ebad 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -69,6 +69,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 60b86d3a5e29..5bf9893fef9d 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -90,6 +90,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index 515c05053d2f..e3cea01cc654 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -92,6 +92,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 9e303f378aab..466747483c12 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -100,6 +100,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 982da33427fe..8a2bb55f6141 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -68,6 +68,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index 71c1bb861e97..320eb691deea 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -89,6 +89,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index 69e3165c0b9e..cad5fbb3823a 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -91,6 +91,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index e17bef8016ec..7535d9f81273 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -103,6 +103,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index d1a3edd16048..1811c5cc4b11 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -71,6 +71,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index b8851f45a05b..405365e63dcf 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -92,6 +92,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 893f2f84cdcf..afbb38c63946 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -94,6 +94,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 48687a91bc54..9ab0bb5e094d 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -102,6 +102,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index 586630ae632b..9196895842da 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -70,6 +70,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 08421403c6ae..bac9d01ae780 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -91,6 +91,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index 7915c8f6a2d9..33f28402a7e7 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -93,6 +93,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 69d6493b1ed8..cc3efdc96e43 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -112,6 +112,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index e974b80420e0..4956eb299402 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -99,6 +99,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 016ae79d6938..6f8beca99e20 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -101,6 +101,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 9dd76803f6f2..a38943d8ee6c 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -79,6 +79,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 792a2fe7036f..2476352d6ab0 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -111,6 +111,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 47ff7ebf3715..ed77af051cca 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -98,6 +98,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index ad3eda7cbfd2..55794e683386 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -100,6 +100,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 2b744decbbe4..57d5958125a7 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -78,6 +78,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index 2df97ba559ad..04540ae8ed0c 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -117,6 +117,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index a4e684a99c1b..3af641f6a0ca 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -104,6 +104,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 822f5f603d72..22937dd9dbed 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -106,6 +106,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index 0d697dbf8bdf..caa546a376f9 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -84,6 +84,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 4c754560a958..852ef4419a05 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -116,6 +116,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 595aa70f73f4..aeaa538700dd 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -103,6 +103,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index d6967754b17b..4a3ad3179e04 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -105,6 +105,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index c9f43191516e..101377b565b5 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -83,6 +83,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index fc4eab55b175..10f4d712d4bb 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -76,6 +76,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index cdb44a0c05b9..a130983a2681 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -73,6 +73,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index eedaf8a748e0..5c2a0c1a1ef0 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -75,6 +75,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index 9379de07c193..e1cf145a64ad 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -70,6 +70,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index 92ba8bf63e2f..61b9c016976d 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -81,6 +81,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index 201991885732..410a98bbfcb6 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -78,6 +78,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index 41afa473dcd2..700eab5e3078 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -80,6 +80,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index 881c8f748101..ef402f0ddb10 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -75,6 +75,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index 27f75844bb5d..f77ea226ea60 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -75,6 +75,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index e3bb46a14342..b94a2be38209 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -77,6 +77,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index 727c9b5fb71d..f0d67766126c 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -72,6 +72,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index dbb760eb9ac2..48b868a548d9 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -81,6 +81,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index 48e3ffa4eb3d..2eecbd98ee21 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -77,6 +77,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index 2f3801d2a257..759bcf56ed86 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -79,6 +79,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index 9685180545ec..d839a265e5d0 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -74,6 +74,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 577ea9300f30..ddfb9c08e3e9 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -105,6 +105,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 75225ba20dbf..8efd45f9220e 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -104,6 +104,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 8c6617aa02d3..ccb3fa416bda 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -107,6 +107,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index 92d8365addd4..ab6486bd21c7 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -79,6 +79,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index fb4923d94344..8e4dc127f730 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -101,6 +101,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index ab5cf3fa4f4c..9b7ae6207578 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -100,6 +100,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index aeb371d806ce..2995350135f1 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -103,6 +103,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 0a1331fef150..105b4c75a349 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -75,6 +75,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 54f5896c63d7..280354b4ff5e 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -108,6 +108,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 54cae76d9b5a..6cb8882bd276 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -107,6 +107,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index 3b36349a7f71..ee45ea34b2ac 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -81,6 +81,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index fc447ab4ebbb..277761308d71 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -110,6 +110,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index 3f15ffc2d6b8..b576840ea376 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -82,6 +82,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 82d6ded46ce0..344ca5755e4f 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -110,6 +110,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 8c640c5c5d0b..a3d44ab6e665 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -109,6 +109,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 9a7c395fab21..94be0a010b7d 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -112,6 +112,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index d140c26cd383..c875d22617a2 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -84,6 +84,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080RDB_revD_NAND_defconfig b/configs/T2080RDB_revD_NAND_defconfig index 43e595d33aae..02ce36e02244 100644 --- a/configs/T2080RDB_revD_NAND_defconfig +++ b/configs/T2080RDB_revD_NAND_defconfig @@ -111,6 +111,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/T2080RDB_revD_SDCARD_defconfig b/configs/T2080RDB_revD_SDCARD_defconfig index ea0f40f66703..b99acbd94d96 100644 --- a/configs/T2080RDB_revD_SDCARD_defconfig +++ b/configs/T2080RDB_revD_SDCARD_defconfig @@ -110,6 +110,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080RDB_revD_SPIFLASH_defconfig b/configs/T2080RDB_revD_SPIFLASH_defconfig index af65e4378970..109511432f43 100644 --- a/configs/T2080RDB_revD_SPIFLASH_defconfig +++ b/configs/T2080RDB_revD_SPIFLASH_defconfig @@ -113,6 +113,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080RDB_revD_defconfig b/configs/T2080RDB_revD_defconfig index b6ca9f1ec1f8..8a6bc95c27d0 100644 --- a/configs/T2080RDB_revD_defconfig +++ b/configs/T2080RDB_revD_defconfig @@ -85,6 +85,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index 739978463d78..1e10166f1d3a 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -95,6 +95,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 7956ba11cc32..e47521a4b1d6 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -70,6 +70,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/amcore_defconfig b/configs/amcore_defconfig index ad549c02c152..71ee97969d99 100644 --- a/configs/amcore_defconfig +++ b/configs/amcore_defconfig @@ -35,4 +35,5 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MCFUART=y diff --git a/configs/astro_mcf5373l_defconfig b/configs/astro_mcf5373l_defconfig index 3a44c7e8ec9d..db99c975ee91 100644 --- a/configs/astro_mcf5373l_defconfig +++ b/configs/astro_mcf5373l_defconfig @@ -43,6 +43,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=259 CONFIG_MCFRTC=y CONFIG_SYS_MCFRTC_BASE=0xFC0A8000 CONFIG_MCFUART=y diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index 7b975813928c..bd74eeae74ab 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -51,6 +51,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index 2c354f3b5b51..c33fedb54972 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -52,6 +52,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/blanche_defconfig b/configs/blanche_defconfig index 42f3dc4b6f47..8167dd17aad1 100644 --- a/configs/blanche_defconfig +++ b/configs/blanche_defconfig @@ -60,6 +60,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SMC911X=y diff --git a/configs/boston32r2_defconfig b/configs/boston32r2_defconfig index 2be57d2d1ed9..16c7a401dbc1 100644 --- a/configs/boston32r2_defconfig +++ b/configs/boston32r2_defconfig @@ -45,6 +45,7 @@ CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y diff --git a/configs/boston32r2el_defconfig b/configs/boston32r2el_defconfig index 524564355f44..cc73d3b156fe 100644 --- a/configs/boston32r2el_defconfig +++ b/configs/boston32r2el_defconfig @@ -46,6 +46,7 @@ CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y diff --git a/configs/boston32r6_defconfig b/configs/boston32r6_defconfig index 7bb4e692d6b7..dab4a9f3af59 100644 --- a/configs/boston32r6_defconfig +++ b/configs/boston32r6_defconfig @@ -46,6 +46,7 @@ CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y diff --git a/configs/boston32r6el_defconfig b/configs/boston32r6el_defconfig index 8ae2f235b1a7..0ded7cfcdf9a 100644 --- a/configs/boston32r6el_defconfig +++ b/configs/boston32r6el_defconfig @@ -47,6 +47,7 @@ CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y diff --git a/configs/boston64r2_defconfig b/configs/boston64r2_defconfig index 4a41e6b5cc64..e5c370699dbc 100644 --- a/configs/boston64r2_defconfig +++ b/configs/boston64r2_defconfig @@ -46,6 +46,7 @@ CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y diff --git a/configs/boston64r2el_defconfig b/configs/boston64r2el_defconfig index 0670ffabbbb2..4c141f45fb58 100644 --- a/configs/boston64r2el_defconfig +++ b/configs/boston64r2el_defconfig @@ -47,6 +47,7 @@ CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y diff --git a/configs/boston64r6_defconfig b/configs/boston64r6_defconfig index bf7f709524b9..7b8b9b82df3b 100644 --- a/configs/boston64r6_defconfig +++ b/configs/boston64r6_defconfig @@ -46,6 +46,7 @@ CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y diff --git a/configs/boston64r6el_defconfig b/configs/boston64r6el_defconfig index e1d46d30606a..f657cb872b39 100644 --- a/configs/boston64r6el_defconfig +++ b/configs/boston64r6el_defconfig @@ -47,6 +47,7 @@ CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y diff --git a/configs/cobra5272_defconfig b/configs/cobra5272_defconfig index 42f6087d83c9..e8301c6301a5 100644 --- a/configs/cobra5272_defconfig +++ b/configs/cobra5272_defconfig @@ -50,6 +50,7 @@ CONFIG_SYS_BR7_PRELIM_BOOL=y CONFIG_SYS_BR7_PRELIM=0x701 CONFIG_SYS_OR7_PRELIM=0xFF00007C CONFIG_MTD_NOR_FLASH=y +CONFIG_SYS_MAX_FLASH_SECT=11 CONFIG_USE_SYS_MAX_FLASH_BANKS=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 8f6b8b9702f4..00ba7d7687ac 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -69,6 +69,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=67 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index eae073d76ea6..744ffbd94333 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -66,6 +66,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=71 CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_LPC32XX_SLC=y diff --git a/configs/eb_cpu5282_defconfig b/configs/eb_cpu5282_defconfig index 4cf03abc61e4..378de4bd8c29 100644 --- a/configs/eb_cpu5282_defconfig +++ b/configs/eb_cpu5282_defconfig @@ -48,6 +48,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y diff --git a/configs/eb_cpu5282_internal_defconfig b/configs/eb_cpu5282_internal_defconfig index 117851584693..ef0512c8f708 100644 --- a/configs/eb_cpu5282_internal_defconfig +++ b/configs/eb_cpu5282_internal_defconfig @@ -46,6 +46,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index 6b7cdbe4b119..1cd0ac020b2a 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -65,6 +65,7 @@ CONFIG_SYS_I2C_SLAVE=0x0 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=11 CONFIG_MVGBE=y CONFIG_MII=y CONFIG_SYS_NS16550=y diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index 796b71793a7f..6725e3aa6813 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -71,6 +71,7 @@ CONFIG_SYS_I2C_SOFT_SLAVE=0 CONFIG_GENERIC_ATMEL_MCI=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_SYS_MAX_FLASH_SECT=32 CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/gazerbeam_defconfig b/configs/gazerbeam_defconfig index a81aa00f2dba..cabe2897707a 100644 --- a/configs/gazerbeam_defconfig +++ b/configs/gazerbeam_defconfig @@ -191,6 +191,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=135 CONFIG_PHYLIB_10G=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index 74dfc6680420..1f0a86469702 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -194,6 +194,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y CONFIG_PHY_ATHEROS=y diff --git a/configs/integratorap_cm720t_defconfig b/configs/integratorap_cm720t_defconfig index 71f645009792..644876e0b244 100644 --- a/configs/integratorap_cm720t_defconfig +++ b/configs/integratorap_cm720t_defconfig @@ -33,5 +33,6 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm920t_defconfig b/configs/integratorap_cm920t_defconfig index 1c3b8a024e96..9cc8070faaa8 100644 --- a/configs/integratorap_cm920t_defconfig +++ b/configs/integratorap_cm920t_defconfig @@ -33,5 +33,6 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm926ejs_defconfig b/configs/integratorap_cm926ejs_defconfig index 8dc7b0c06372..9f7371f17e6d 100644 --- a/configs/integratorap_cm926ejs_defconfig +++ b/configs/integratorap_cm926ejs_defconfig @@ -33,5 +33,6 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm946es_defconfig b/configs/integratorap_cm946es_defconfig index c80a2b6a3a34..3f7f3e49882f 100644 --- a/configs/integratorap_cm946es_defconfig +++ b/configs/integratorap_cm946es_defconfig @@ -33,5 +33,6 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm1136_defconfig b/configs/integratorcp_cm1136_defconfig index 05d5bf015307..95d82b578dba 100644 --- a/configs/integratorcp_cm1136_defconfig +++ b/configs/integratorcp_cm1136_defconfig @@ -36,5 +36,6 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=64 CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm920t_defconfig b/configs/integratorcp_cm920t_defconfig index eb9d1b765903..61191e2b53be 100644 --- a/configs/integratorcp_cm920t_defconfig +++ b/configs/integratorcp_cm920t_defconfig @@ -36,5 +36,6 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=64 CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm926ejs_defconfig b/configs/integratorcp_cm926ejs_defconfig index 501c19c19277..b8b27da23b8a 100644 --- a/configs/integratorcp_cm926ejs_defconfig +++ b/configs/integratorcp_cm926ejs_defconfig @@ -36,5 +36,6 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=64 CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm946es_defconfig b/configs/integratorcp_cm946es_defconfig index 3264475fb438..60e0979ee42a 100644 --- a/configs/integratorcp_cm946es_defconfig +++ b/configs/integratorcp_cm946es_defconfig @@ -36,5 +36,6 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=64 CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 81459aa39fa8..7a540e7c5539 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -81,6 +81,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 760f528f3c3f..bd22e6721b49 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -81,6 +81,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index d1264fd318ae..bdef2ac84739 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -113,6 +113,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index b6d20424d9ce..681cb68c863b 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -80,6 +80,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 96b668718150..e9fda69663fc 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -83,6 +83,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 1b7aae5e898e..06f51d5ab88a 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -83,6 +83,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 2964bb7465a4..13237c65a048 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -111,6 +111,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index ad815b6832f7..fe047007bc0a 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -67,6 +67,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index 4ee9fe1b40c2..7571d7c8b5e2 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -70,6 +70,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 99271e79820e..96284e316c78 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -70,6 +70,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 11e1c8451cc4..01863abb9aaf 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -98,6 +98,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index cdd7f8e38d15..a981def7504d 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -98,6 +98,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index 6f767f749fd5..e0642c77a945 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -81,6 +81,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index 6d4b5912bce9..b50b278748ec 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -81,6 +81,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 7311b1c558d8..5afeea763b7d 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -110,6 +110,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 78e39c46dc68..373923b4d999 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -82,6 +82,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index b8e4a7bc6ef3..607df6dd9d85 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -108,6 +108,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index c4946f94e9f1..6e5f8fb9c673 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -78,6 +78,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index 31d6173fdb5e..c47eb92b25ca 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -87,6 +87,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 8105fc1030b0..48b96e18d87c 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -64,6 +64,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 4b33e56be504..555b4173b060 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -67,6 +67,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index f30a7055d981..eea1aea18dee 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -87,6 +87,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 41a3eb7f4ca9..d0e5c37357f6 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -94,6 +94,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index 8df1a4910b39..4f125358c0fc 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -88,6 +88,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index ae04bd4be08f..6cfbc5960d10 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -92,6 +92,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig index 990254b57494..da31529064a8 100644 --- a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig @@ -63,6 +63,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index d9b51553ac23..76a2b2608e45 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -69,6 +69,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index fd996cd0ac52..10f808cefa86 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -78,6 +78,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index 5bdfe7e42587..28fd339803d1 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -81,6 +81,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index 3c0b3563b731..7cbc58458925 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -81,6 +81,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 91a0ae4d7ee7..084d26462aaa 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -108,6 +108,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index 6e70fe553491..1db39e64c604 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -109,6 +109,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig index 0fc632d0cbaa..5047baec8a48 100644 --- a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig @@ -78,6 +78,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index a8a2b8e5374e..7ebb5def6455 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -87,6 +87,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index 2db19f1cc758..63ea991b6ce3 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -77,6 +77,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index 99051b378178..bc626e3f772d 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -97,6 +97,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index 8965617becec..0da726c32aeb 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -85,6 +85,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index f02e9aba3f77..b00b3fc3b1c3 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -66,6 +66,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index 49f3fd5dc1ea..8002570d4a29 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -69,6 +69,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 55b93ca2f165..f27df9df7e9a 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -69,6 +69,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index 973c657137d4..eec426e67671 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -72,6 +72,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index f6a6a1150756..8ec4e6a7ff2d 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -92,6 +92,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index 63e54012b58e..4ad644d78c7d 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -80,6 +80,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index 9aac8bfdcf54..5cd18a17e13a 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -74,6 +74,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index 754f8b0980c6..1611bb50f44b 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -81,6 +81,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/malta64_defconfig b/configs/malta64_defconfig index e55b4a491455..60a8815194bb 100644 --- a/configs/malta64_defconfig +++ b/configs/malta64_defconfig @@ -38,6 +38,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_PCNET=y CONFIG_PCI_GT64120=y CONFIG_PCI_MSC01=y diff --git a/configs/malta64el_defconfig b/configs/malta64el_defconfig index 6c6492d3febc..b4b0320fc0a0 100644 --- a/configs/malta64el_defconfig +++ b/configs/malta64el_defconfig @@ -40,6 +40,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_PCNET=y CONFIG_PCI_GT64120=y CONFIG_PCI_MSC01=y diff --git a/configs/malta_defconfig b/configs/malta_defconfig index 3aff68b0188f..ade98e623658 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -37,6 +37,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_PCNET=y CONFIG_PCI_GT64120=y CONFIG_PCI_MSC01=y diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index e268fb63743f..ef31afe86aa0 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -39,6 +39,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_PCNET=y CONFIG_PCI_GT64120=y CONFIG_PCI_MSC01=y diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index a7892c6e33fd..192bf9873a48 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -70,6 +70,7 @@ CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=2048 CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/octeon_ebb7304_defconfig b/configs/octeon_ebb7304_defconfig index 71df8cdabcb4..cf251abb9585 100644 --- a/configs/octeon_ebb7304_defconfig +++ b/configs/octeon_ebb7304_defconfig @@ -56,6 +56,7 @@ CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index ab5dfad28fcc..6702df0b22d7 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -77,6 +77,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_OMAP_ECCSCHEME_BCH8_CODE_HW_DETECTION_SW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 8c5bc19f10bf..b161fe2369ec 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -78,6 +78,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_OMAP_ECCSCHEME_BCH8_CODE_HW_DETECTION_SW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index 6922380b0093..a5256b7a1811 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -48,6 +48,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index 2b4a844d804b..b7a8124e3055 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -52,6 +52,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/qemu_arm64_defconfig b/configs/qemu_arm64_defconfig index f7c93ba2af54..8d7bc19b7ae2 100644 --- a/configs/qemu_arm64_defconfig +++ b/configs/qemu_arm64_defconfig @@ -50,6 +50,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_ETH=y diff --git a/configs/qemu_arm_defconfig b/configs/qemu_arm_defconfig index 50945472315a..b2bc149e460c 100644 --- a/configs/qemu_arm_defconfig +++ b/configs/qemu_arm_defconfig @@ -52,6 +52,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_ETH=y diff --git a/configs/r2dplus_defconfig b/configs/r2dplus_defconfig index 2beda3a2fe0a..3af338c90bc3 100644 --- a/configs/r2dplus_defconfig +++ b/configs/r2dplus_defconfig @@ -45,6 +45,7 @@ CONFIG_CLK=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_EEPRO100=y diff --git a/configs/r8a77990_ebisu_defconfig b/configs/r8a77990_ebisu_defconfig index e667d23d7eea..d13e3ea15bea 100644 --- a/configs/r8a77990_ebisu_defconfig +++ b/configs/r8a77990_ebisu_defconfig @@ -84,6 +84,7 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_RENESAS_RPC_HF=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index afccf86461df..de25e525f921 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -77,6 +77,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_RENESAS_RPC_HF=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/rcar3_salvator-x_defconfig b/configs/rcar3_salvator-x_defconfig index d423ad7b8261..bb2101ef688e 100644 --- a/configs/rcar3_salvator-x_defconfig +++ b/configs/rcar3_salvator-x_defconfig @@ -87,6 +87,7 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_RENESAS_RPC_HF=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/rcar3_ulcb_defconfig b/configs/rcar3_ulcb_defconfig index 341abe4f6dda..8eb703a54329 100644 --- a/configs/rcar3_ulcb_defconfig +++ b/configs/rcar3_ulcb_defconfig @@ -86,6 +86,7 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_RENESAS_RPC_HF=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 40a8c028c2dc..0f06d4309069 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -83,6 +83,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=131 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 772511543dbf..f29a1b7727d7 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -82,6 +82,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=131 CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=4 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 4e85807432e5..cfd6ae1b4c0b 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -84,6 +84,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=131 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 60a38abc8e3a..75195b36addf 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -73,6 +73,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y CONFIG_PHY_ATHEROS=y diff --git a/configs/stm32746g-eval_defconfig b/configs/stm32746g-eval_defconfig index 64610658c7bd..aa4e98acc584 100644 --- a/configs/stm32746g-eval_defconfig +++ b/configs/stm32746g-eval_defconfig @@ -42,6 +42,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_STM32_FLASH=y +CONFIG_SYS_MAX_FLASH_SECT=8 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/stm32746g-eval_spl_defconfig b/configs/stm32746g-eval_spl_defconfig index 753a4b80cbbc..feba98516880 100644 --- a/configs/stm32746g-eval_spl_defconfig +++ b/configs/stm32746g-eval_spl_defconfig @@ -63,6 +63,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_STM32_FLASH=y +CONFIG_SYS_MAX_FLASH_SECT=8 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/stm32f429-discovery_defconfig b/configs/stm32f429-discovery_defconfig index fde427ae692f..b347347e253c 100644 --- a/configs/stm32f429-discovery_defconfig +++ b/configs/stm32f429-discovery_defconfig @@ -32,4 +32,5 @@ CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_STM32_FLASH=y +CONFIG_SYS_MAX_FLASH_SECT=12 CONFIG_SYS_MAX_FLASH_BANKS=2 diff --git a/configs/stm32f429-evaluation_defconfig b/configs/stm32f429-evaluation_defconfig index e2c41b0844e8..98c0507b535f 100644 --- a/configs/stm32f429-evaluation_defconfig +++ b/configs/stm32f429-evaluation_defconfig @@ -31,4 +31,5 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARM_PL180_MMCI=y CONFIG_MTD_NOR_FLASH=y CONFIG_STM32_FLASH=y +CONFIG_SYS_MAX_FLASH_SECT=12 CONFIG_SYS_MAX_FLASH_BANKS=2 diff --git a/configs/stm32f469-discovery_defconfig b/configs/stm32f469-discovery_defconfig index c7dbc69fa889..c27f760af4f5 100644 --- a/configs/stm32f469-discovery_defconfig +++ b/configs/stm32f469-discovery_defconfig @@ -33,6 +33,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_STM32_FLASH=y +CONFIG_SYS_MAX_FLASH_SECT=12 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index e3f80ab8e206..61d6daa75762 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -42,6 +42,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_STM32_FLASH=y +CONFIG_SYS_MAX_FLASH_SECT=8 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/stm32f746-disco_spl_defconfig b/configs/stm32f746-disco_spl_defconfig index 927d28dd9733..0368ece6390f 100644 --- a/configs/stm32f746-disco_spl_defconfig +++ b/configs/stm32f746-disco_spl_defconfig @@ -63,6 +63,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_STM32_FLASH=y +CONFIG_SYS_MAX_FLASH_SECT=8 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/stm32f769-disco_defconfig b/configs/stm32f769-disco_defconfig index b7e9ee92a7e1..c177bd8c733f 100644 --- a/configs/stm32f769-disco_defconfig +++ b/configs/stm32f769-disco_defconfig @@ -41,6 +41,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_STM32_FLASH=y +CONFIG_SYS_MAX_FLASH_SECT=8 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/stm32f769-disco_spl_defconfig b/configs/stm32f769-disco_spl_defconfig index bae28b4ec132..7515574dfbc1 100644 --- a/configs/stm32f769-disco_spl_defconfig +++ b/configs/stm32f769-disco_spl_defconfig @@ -62,6 +62,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_STM32_FLASH=y +CONFIG_SYS_MAX_FLASH_SECT=8 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/total_compute_defconfig b/configs/total_compute_defconfig index 43db639c273c..ab13ac82ee77 100644 --- a/configs/total_compute_defconfig +++ b/configs/total_compute_defconfig @@ -56,5 +56,6 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_LIBAVB=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index 977e3270453b..cf3ffc773182 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -33,6 +33,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=259 CONFIG_DM_ETH=y CONFIG_PCI=y CONFIG_USB=y diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index 71b3caa9224f..39d96fe35990 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -30,4 +30,5 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_VIRTIO_MMIO=y diff --git a/configs/vexpress_ca9x4_defconfig b/configs/vexpress_ca9x4_defconfig index fbb6448480f0..8817c4e46f59 100644 --- a/configs/vexpress_ca9x4_defconfig +++ b/configs/vexpress_ca9x4_defconfig @@ -48,6 +48,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=259 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_ETH=y CONFIG_SMC911X=y diff --git a/configs/xtfpga_defconfig b/configs/xtfpga_defconfig index c3c634e263ce..966b0eb6538c 100644 --- a/configs/xtfpga_defconfig +++ b/configs/xtfpga_defconfig @@ -42,6 +42,7 @@ CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=1027 CONFIG_PHYLIB=y CONFIG_DM_ETH=y CONFIG_ETHOC=y diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index 431168d12ee5..828ec9758207 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -171,6 +171,11 @@ config STM32_FLASH This is the driver of embedded flash for some STMicroelectronics STM32 MCU.
+config SYS_MAX_FLASH_SECT + int "Maximumm number of sectors on a flash chip" + depends on MTD_NOR_FLASH || FLASH_CFI_DRIVER + default 512 + config SAMSUNG_ONENAND bool "Samsung OneNAND driver support"
diff --git a/include/configs/10m50_devboard.h b/include/configs/10m50_devboard.h index 9b4f5fcf1b8e..35560ab68351 100644 --- a/include/configs/10m50_devboard.h +++ b/include/configs/10m50_devboard.h @@ -20,7 +20,6 @@ /* * Flash */ -#define CONFIG_SYS_MAX_FLASH_SECT 1024
/* * BOOTP options diff --git a/include/configs/3c120_devboard.h b/include/configs/3c120_devboard.h index 2d52dc6f6608..69fa1c1b7681 100644 --- a/include/configs/3c120_devboard.h +++ b/include/configs/3c120_devboard.h @@ -19,7 +19,6 @@ /* * CFI Flash */ -#define CONFIG_SYS_MAX_FLASH_SECT 512
/* * MEMORY ORGANIZATION diff --git a/include/configs/M5208EVBE.h b/include/configs/M5208EVBE.h index c773164c869b..6c6469b0d4b8 100644 --- a/include/configs/M5208EVBE.h +++ b/include/configs/M5208EVBE.h @@ -82,7 +82,6 @@ /* FLASH organization */ #ifdef CONFIG_SYS_FLASH_CFI # define CONFIG_SYS_FLASH_SIZE 0x800000 /* Max size that the board might have */ -# define CONFIG_SYS_MAX_FLASH_SECT 254 /* max number of sectors on one chip */ #endif
#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index 79448cf44048..54116413230b 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -90,7 +90,6 @@ */ #ifdef CONFIG_SYS_FLASH_CFI # define CONFIG_SYS_FLASH_SIZE 0x800000 /* Max size that the board might have */ -# define CONFIG_SYS_MAX_FLASH_SECT 137 /* max number of sectors on one chip */ #endif
#define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CS0_BASE) diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index 39bffc29ff22..42c62b4d684a 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -77,7 +77,6 @@ #ifdef CONFIG_SYS_FLASH_CFI
# define CONFIG_SYS_FLASH_SIZE 0x1000000 /* Max size that the board might have */ -# define CONFIG_SYS_MAX_FLASH_SECT 137 /* max number of sectors on one chip */ # define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } #endif
diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index b88280c90cdf..9f648342ea33 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -93,7 +93,6 @@
/* FLASH organization */ #define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CS0_BASE) -#define CONFIG_SYS_MAX_FLASH_SECT 2048 /* max number of sectors on one chip */
#define FLASH_SST6401B 0x200 #define SST_ID_xF6401B 0x236D236D diff --git a/include/configs/M5272C3.h b/include/configs/M5272C3.h index 2fa1e4356e3e..356ad3e9da1e 100644 --- a/include/configs/M5272C3.h +++ b/include/configs/M5272C3.h @@ -91,7 +91,6 @@ */ #ifdef CONFIG_SYS_FLASH_CFI # define CONFIG_SYS_FLASH_SIZE 0x800000 /* Max size that the board might have */ -# define CONFIG_SYS_MAX_FLASH_SECT 137 /* max number of sectors on one chip */ #endif
/*----------------------------------------------------------------------- diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index 80d079a48995..1fd51212d637 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -91,7 +91,6 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CONFIG_SYS_MAX_FLASH_SECT 11 /* max number of sectors on one chip */
#define CONFIG_SYS_FLASH_SIZE 0x200000
diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index c476b0c4475a..900b0b53434b 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -95,7 +95,6 @@ #ifdef CONFIG_SYS_FLASH_CFI
diff --git a/include/configs/M53017EVB.h b/include/configs/M53017EVB.h index 4d8f752777d0..4f82389cedfa 100644 --- a/include/configs/M53017EVB.h +++ b/include/configs/M53017EVB.h @@ -99,7 +99,6 @@ #ifdef CONFIG_SYS_FLASH_CFI # define CONFIG_FLASH_SPANSION_S29WS_N 1 # define CONFIG_SYS_FLASH_SIZE 0x1000000 /* Max size that the board might have */ -# define CONFIG_SYS_MAX_FLASH_SECT 137 /* max number of sectors on one chip */ #endif
#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE diff --git a/include/configs/M5329EVB.h b/include/configs/M5329EVB.h index 87d3e8fb153b..a6c953f1a46c 100644 --- a/include/configs/M5329EVB.h +++ b/include/configs/M5329EVB.h @@ -92,7 +92,6 @@ */ #ifdef CONFIG_SYS_FLASH_CFI # define CONFIG_SYS_FLASH_SIZE 0x800000 /* Max size that the board might have */ -# define CONFIG_SYS_MAX_FLASH_SECT 137 /* max number of sectors on one chip */ #endif
#ifdef CONFIG_CMD_NAND diff --git a/include/configs/M5373EVB.h b/include/configs/M5373EVB.h index d920587c3790..f519bef24744 100644 --- a/include/configs/M5373EVB.h +++ b/include/configs/M5373EVB.h @@ -94,7 +94,6 @@ */ #ifdef CONFIG_SYS_FLASH_CFI # define CONFIG_SYS_FLASH_SIZE 0x800000 /* Max size that the board might have */ -# define CONFIG_SYS_MAX_FLASH_SECT 137 /* max number of sectors on one chip */ #endif
# define CONFIG_SYS_MAX_NAND_DEVICE 1 diff --git a/include/configs/MCR3000.h b/include/configs/MCR3000.h index f6854cb8c985..9d0683829ecb 100644 --- a/include/configs/MCR3000.h +++ b/include/configs/MCR3000.h @@ -69,7 +69,6 @@
/* FLASH organization */ #define CONFIG_SYS_FLASH_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MAX_FLASH_SECT 35
/* * For booting Linux, the board info and command line data diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index a25bf7464514..c2f4f2bee2c0 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -141,9 +141,6 @@ #define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ #define CONFIG_SYS_FLASH_SIZE 8 /* max FLASH size is 32M */
- -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ - /* * NAND Flash on the Local Bus */ diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index d4a2b0184f64..0c710ef8865c 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -124,7 +124,6 @@
#define CONFIG_SYS_FLASH_BANKS_LIST \ {CONFIG_SYS_FLASH_BASE_PHYS + 0x800000, CONFIG_SYS_FLASH_BASE_PHYS} -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* sectors per device */
#define CONFIG_HWCONFIG /* enable hwconfig */
diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index a057d59177e5..9a7f7d5464bf 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -137,7 +137,6 @@ extern unsigned long get_sdram_size(void); /* NOR Flash on IFC */
#define CONFIG_SYS_FLASH_BASE 0xee000000 -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* 32M */
#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE) diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index b4a7b4688113..45ce78a5e73c 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -123,8 +123,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ - /* Nand Flash */ #ifdef CONFIG_NAND_FSL_ELBC #define CONFIG_SYS_NAND_BASE 0xffa00000 diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 7c5fbbba5926..2bdb54522316 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -168,8 +168,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ - #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS}
#ifdef CONFIG_TARGET_T1024RDB diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 39b04b204e58..96a84706f7cc 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -130,8 +130,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
/* CPLD on IFC */ diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 0cb8d394d11c..321c306a04e9 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -133,8 +133,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ - #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS \ + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS}
diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index bccc3385cb21..677cc80d146d 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -123,7 +123,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS }
/* CPLD on IFC */ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 181b5fe2a44b..28755203ebfe 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -204,8 +204,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 4b59759f818e..bd7e2f1bf503 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -223,7 +223,6 @@ * 0x4C0000 - 0xFFFFFF : Userland (11 MiB + 256 KiB) */ #if defined(CONFIG_NOR) -#define CONFIG_SYS_MAX_FLASH_SECT 128 #define CONFIG_SYS_FLASH_BASE (0x08000000) #define CONFIG_SYS_FLASH_SIZE 0x01000000 #endif /* NOR support */ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 93beed4ad736..02a5e94c4f48 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -88,7 +88,6 @@ /* FLASH and environment organization */
/* **** PISMO SUPPORT *** */ -#define CONFIG_SYS_MAX_FLASH_SECT 520 /* max number of sectors */ /* on one chip */ #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
diff --git a/include/configs/amcore.h b/include/configs/amcore.h index 89b94b29306f..3f3b399ed7d9 100644 --- a/include/configs/amcore.h +++ b/include/configs/amcore.h @@ -36,7 +36,6 @@ #define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_SDRAM_SIZE 0x1000000 #define CONFIG_SYS_FLASH_BASE 0xffc00000 -#define CONFIG_SYS_MAX_FLASH_SECT 1024
/* amcore design has flash data bytes wired swapped */ #define CONFIG_SYS_WRITE_SWAPPED_DATA diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index d54cadd41eeb..da02a96889bc 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -47,7 +47,6 @@
/* FLASH */ #define CONFIG_SYS_FLASH_BASE 0x00000000 -#define CONFIG_SYS_MAX_FLASH_SECT 512 #define CONFIG_SYS_FLASH_BANKS_LIST { (CONFIG_SYS_FLASH_BASE) }
/* ENV setting */ diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index f48f7902a002..dde30eab5ed9 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -207,7 +207,6 @@ (CONFIG_SYS_SDRAM_SIZE << 20))
/* FLASH organization */ -#define CONFIG_SYS_MAX_FLASH_SECT 259
#define CONFIG_SYS_FLASH_SIZE 0x2000000 #define CONFIG_SYS_FLASH_CFI_NONBLOCK 1 diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 9497f055035d..8c6d1cd1d9d4 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -40,7 +40,6 @@ #ifdef CONFIG_SYS_USE_NORFLASH #define PHYS_FLASH_1 0x10000000 #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 -#define CONFIG_SYS_MAX_FLASH_SECT 256
#define CONFIG_SYS_MONITOR_SEC 1:0-3 #define CONFIG_SYS_MONITOR_LEN (256 << 10) diff --git a/include/configs/ax25-ae350.h b/include/configs/ax25-ae350.h index 653acdc9aff1..cf5125fdfa63 100644 --- a/include/configs/ax25-ae350.h +++ b/include/configs/ax25-ae350.h @@ -55,7 +55,6 @@
/* max number of sectors on one chip */ #define CONFIG_FLASH_SECTOR_SIZE (0x10000*2) -#define CONFIG_SYS_MAX_FLASH_SECT 512
/* environments */
diff --git a/include/configs/blanche.h b/include/configs/blanche.h index 76271ebe2e68..959c521b6c91 100644 --- a/include/configs/blanche.h +++ b/include/configs/blanche.h @@ -30,7 +30,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 #define CONFIG_SYS_FLASH_BASE 0x00000000 #define CONFIG_SYS_FLASH_SIZE 0x04000000 /* 64 MB */ -#define CONFIG_SYS_MAX_FLASH_SECT 1024 #define CONFIG_SYS_FLASH_BANKS_LIST { (CONFIG_SYS_FLASH_BASE) } #define CONFIG_SYS_FLASH_BANKS_SIZES { (CONFIG_SYS_FLASH_SIZE) } #endif diff --git a/include/configs/boston.h b/include/configs/boston.h index 8b04492753a8..5d6da772059d 100644 --- a/include/configs/boston.h +++ b/include/configs/boston.h @@ -34,12 +34,6 @@ * Console */
-/* - * Flash - */ - -#define CONFIG_SYS_MAX_FLASH_SECT 1024 - /* * Environment */ diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index 5e364b4990a8..c29abd15b39e 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -186,11 +186,6 @@ enter a valid image address in flash */ */ #define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */
-/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_SECT 11 /* max number of sectors on one chip */ - /*----------------------------------------------------------------------- * Cache Configuration */ diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index c12cdd413291..84712d16d0f7 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -113,8 +113,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ - /* Nand Flash */ #ifdef CONFIG_NAND_FSL_ELBC #define CONFIG_SYS_NAND_BASE 0xffa00000 diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 3db97205dab8..f699cb107800 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -137,8 +137,6 @@ #define CONFIG_SYS_FLASH_SECT_SZ (128 << 10) /* 128KB */ #define CONFIG_SYS_FLASH_BASE DAVINCI_ASYNC_EMIF_DATA_CE2_BASE #define PHYS_FLASH_SIZE (8 << 20) /* Flash size 8MB */ -#define CONFIG_SYS_MAX_FLASH_SECT ((PHYS_FLASH_SIZE/CONFIG_SYS_FLASH_SECT_SZ)\ - + 3) #endif
/* diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index 328e4958f86a..7916ca8a6cd4 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -29,7 +29,6 @@ /* * NOR Flash */ -#define CONFIG_SYS_MAX_FLASH_SECT 71 #define CONFIG_SYS_FLASH_BASE EMC_CS0_BASE #define CONFIG_SYS_FLASH_SIZE SZ_4M
diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 9247720f8b6d..6cf716e293d6 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -89,7 +89,6 @@ /* Parallel NOR Support */ #if defined(CONFIG_NOR) /* NOR: device related configs */ -#define CONFIG_SYS_MAX_FLASH_SECT 512 #define CONFIG_SYS_FLASH_SIZE (64 * 1024 * 1024) /* 64 MB */ #define CONFIG_SYS_FLASH_BASE (0x08000000) /* Reduce SPL size by removing unlikey targets */ diff --git a/include/configs/draak.h b/include/configs/draak.h index a38e48634835..8bfba78dc8e4 100644 --- a/include/configs/draak.h +++ b/include/configs/draak.h @@ -15,7 +15,6 @@
#define CONFIG_FLASH_SHOW_PROGRESS 45 #define CONFIG_SYS_FLASH_BANKS_LIST { 0x08000000 } -#define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_WRITE_SWAPPED_DATA
#endif /* __DRAAK_H */ diff --git a/include/configs/eb_cpu5282.h b/include/configs/eb_cpu5282.h index 1a05914c1b88..249da66237b5 100644 --- a/include/configs/eb_cpu5282.h +++ b/include/configs/eb_cpu5282.h @@ -94,8 +94,6 @@ #define CONFIG_SYS_INT_FLASH_BASE 0xF0000000 #define CONFIG_SYS_INT_FLASH_ENABLE 0x21
-#define CONFIG_SYS_MAX_FLASH_SECT 128 - #define CONFIG_SYS_FLASH_SIZE 16*1024*1024
#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } diff --git a/include/configs/ebisu.h b/include/configs/ebisu.h index 3dc111f5248d..5e2dc04e253d 100644 --- a/include/configs/ebisu.h +++ b/include/configs/ebisu.h @@ -18,7 +18,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_SYS_FLASH_BANKS_LIST { 0x08000000 } -#define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_WRITE_SWAPPED_DATA
#endif /* __EBISU_H */ diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index 86257016824f..d2f1cd5d5c8c 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -79,7 +79,6 @@ * FLASH configuration */
-#define CONFIG_SYS_MAX_FLASH_SECT 11 /* max num of sects on one chip */ #define CONFIG_SYS_FLASH_BASE 0xfff80000
/* auto boot */ diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index 88a702f1af27..7a3c800dca9c 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -31,7 +31,6 @@
/* 512kB on-chip NOR flash */ # define CONFIG_SYS_FLASH_BASE 0x00200000 /* AT91SAM9XE_FLASH_BASE */ -# define CONFIG_SYS_MAX_FLASH_SECT 32
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ diff --git a/include/configs/gazerbeam.h b/include/configs/gazerbeam.h index 25095e192f0b..e592dc44e4d7 100644 --- a/include/configs/gazerbeam.h +++ b/include/configs/gazerbeam.h @@ -40,8 +40,6 @@ #define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ #define CONFIG_SYS_FLASH_SIZE 8 /* FLASH size is up to 8M */
-#define CONFIG_SYS_MAX_FLASH_SECT 135 - #define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200}
diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index 3dbd141a7699..1b97e54be7f6 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -109,9 +109,6 @@ #define CONFIG_SYS_FLASH_BASE 0xFF800000 #define CONFIG_SYS_FLASH_SIZE 8
- -#define CONFIG_SYS_MAX_FLASH_SECT 128 - /* * NAND FLASH setup */ diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index 17430f15d139..6ebdc3d6f976 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -81,8 +81,6 @@ #define PHYS_FLASH_1 0xc0000000 /* Flash Base for U-Boot */ #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 -#define CONFIG_SYS_MAX_FLASH_SECT (PHYS_FLASH_SIZE / \ - CONFIG_SYS_FLASH_SECT_SZ) #define CONFIG_SYS_MONITOR_LEN 0x40000 /* Reserve 256KiB */ /* Address and size of Redundant Environment Sector */
diff --git a/include/configs/integratorap.h b/include/configs/integratorap.h index 49f07e997d83..c8457d97161a 100644 --- a/include/configs/integratorap.h +++ b/include/configs/integratorap.h @@ -21,7 +21,6 @@
/* Flash settings */ #define CONFIG_SYS_FLASH_SIZE 0x02000000 /* 32 MiB */ -#define CONFIG_SYS_MAX_FLASH_SECT 128
/*----------------------------------------------------------------------- * PCI definitions diff --git a/include/configs/integratorcp.h b/include/configs/integratorcp.h index 288014c5b82e..2752152f68ee 100644 --- a/include/configs/integratorcp.h +++ b/include/configs/integratorcp.h @@ -34,7 +34,6 @@ * Miscellaneous configurable options */ #define PHYS_FLASH_SIZE 0x01000000 /* 16MB */ -#define CONFIG_SYS_MAX_FLASH_SECT 64 #define CONFIG_SYS_MONITOR_LEN 0x00100000
#endif /* __CONFIG_H */ diff --git a/include/configs/km/km-mpc83xx.h b/include/configs/km/km-mpc83xx.h index 3c23715a7721..04192d86b700 100644 --- a/include/configs/km/km-mpc83xx.h +++ b/include/configs/km/km-mpc83xx.h @@ -49,7 +49,6 @@ */ #define CONFIG_SYS_FLASH_SIZE 256 /* max FLASH size is 256M */
-#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max num of sects on one chip */ #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE }
/* I2C */ diff --git a/include/configs/km/pg-wcom-ls102xa.h b/include/configs/km/pg-wcom-ls102xa.h index 1d9e0b6551e6..0cc90070c244 100644 --- a/include/configs/km/pg-wcom-ls102xa.h +++ b/include/configs/km/pg-wcom-ls102xa.h @@ -64,8 +64,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ - #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE_PHYS }
#define CONFIG_SYS_WRITE_SWAPPED_DATA diff --git a/include/configs/kmcent2.h b/include/configs/kmcent2.h index dc369d431893..375c6e2bfccf 100644 --- a/include/configs/kmcent2.h +++ b/include/configs/kmcent2.h @@ -234,8 +234,6 @@ /* More NOR Flash params */ #define CONFIG_SYS_FLASH_QUIET_TEST
-#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ - #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS}
/* NAND Flash on IFC CS1*/ diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 9147a726e592..203381b0e7bd 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -19,7 +19,6 @@ /* NOR Flash */ #define KZM_FLASH_BASE (0x00000000) #define CONFIG_SYS_FLASH_BASE (KZM_FLASH_BASE) -#define CONFIG_SYS_MAX_FLASH_SECT (512)
/* prompt */ #define CONFIG_SYS_BAUDRATE_TABLE { 115200 } diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index f3e694c3c8cd..7df99cad6aa9 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -69,8 +69,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 #define CONFIG_SYS_WRITE_SWAPPED_DATA
-#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ - #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS, \ CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000}
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 8681417eb038..72acc9ab62c9 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -98,8 +98,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ - #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE_PHYS }
#define CONFIG_SYS_WRITE_SWAPPED_DATA diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index e265b1a48eaf..49f6cd6be11b 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -74,8 +74,6 @@ FTIM2_NOR_TWP(0x1c)) #define CONFIG_SYS_NOR_FTIM3 0
diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 352b7dbdd8d2..d36b2c7e557b 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -42,8 +42,6 @@ #define CONFIG_SYS_NOR_FTIM3 0 #define CONFIG_SYS_IFC_CCR 0x01000000
#define CONFIG_SYS_WRITE_SWAPPED_DATA diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 261646fe703e..c2bbc5fec313 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -91,8 +91,6 @@ FTIM2_NOR_TWP(0x1c)) #define CONFIG_SYS_NOR_FTIM3 0
diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index c02acfb85806..0106456284c2 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -65,8 +65,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ - #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE,\ CONFIG_SYS_FLASH_BASE + 0x40000000} #endif diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h index 61df2a4253ca..36abd0868135 100644 --- a/include/configs/ls1088ardb.h +++ b/include/configs/ls1088ardb.h @@ -50,8 +50,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ - #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } #endif #endif diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index c7146314dfee..a8f876c54a5d 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -67,8 +67,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ - #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE,\ CONFIG_SYS_FLASH_BASE + 0x40000000} #endif diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index d20eaec7527f..cd34698e5613 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -64,8 +64,6 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ - #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE,\ CONFIG_SYS_FLASH_BASE + 0x40000000} #endif diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 81c93375e2ef..e1108619f21b 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -18,9 +18,6 @@ /* * Environment variables configurations */ -#ifdef CONFIG_SPI_FLASH -#define CONFIG_SYS_MAX_FLASH_SECT 8 -#endif
/* * Default environment variables diff --git a/include/configs/malta.h b/include/configs/malta.h index 98ea860655ea..5a42ceef2121 100644 --- a/include/configs/malta.h +++ b/include/configs/malta.h @@ -47,7 +47,6 @@ #else # define CONFIG_SYS_FLASH_BASE 0xbe000000 #endif -#define CONFIG_SYS_MAX_FLASH_SECT 128
/* * Environment diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 9f34d2aea7ef..8eaac4f8bc22 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -16,13 +16,6 @@ # define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400}
-#ifdef CONFIG_CFI_FLASH -/* ?empty sector */ -/* max number of memory banks */ -/* max number of sectors on one chip */ -# define CONFIG_SYS_MAX_FLASH_SECT 2048 -#endif - #define CONFIG_HOSTNAME "microblaze-generic"
/* architecture dependent code */ diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index 5fc3acded305..7bfc04ff18f7 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -32,7 +32,6 @@ #ifdef CONFIG_MTD_NOR_FLASH #define CONFIG_SYS_FLASH_BASE WEIM_ARB_BASE_ADDR #define CONFIG_SYS_FLASH_SECT_SIZE (128 * 1024) -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ #endif
#define CONFIG_SYS_FSL_USDHC_NUM 2 diff --git a/include/configs/octeon_ebb7304.h b/include/configs/octeon_ebb7304.h index 5df1a2a755f3..5479bdedee5d 100644 --- a/include/configs/octeon_ebb7304.h +++ b/include/configs/octeon_ebb7304.h @@ -9,11 +9,6 @@
#include "octeon_common.h"
-/* - * CFI flash - */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 - #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
#endif /* __CONFIG_H__ */ diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 38dc7ea88f7b..81c1692055d9 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -150,7 +150,6 @@ #define CONFIG_SYS_FLASH_BASE 0x10000000 #endif
-#define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_FLASH_SIZE 0x4000000
#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 1c5ef78fc927..5071959278d6 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -176,10 +176,8 @@ * Local Bus Definitions */ #if defined(CONFIG_TARGET_P1020RDB_PD) -#define CONFIG_SYS_MAX_FLASH_SECT 512 /* 64M */ #define CONFIG_SYS_FLASH_BASE 0xec000000 #else -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* 16M */ #define CONFIG_SYS_FLASH_BASE 0xef000000 #endif
diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index 7374514698f9..797e44f844de 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -149,7 +149,6 @@ /* NOR flash */ #define PHYS_FLASH_1 0x10000000 #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 -#define CONFIG_SYS_MAX_FLASH_SECT 256
/* USB */ #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 7a6d817926c7..bb5bd8b60646 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -149,7 +149,6 @@ /* NOR flash, if populated */ #define PHYS_FLASH_1 0x10000000 #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 -#define CONFIG_SYS_MAX_FLASH_SECT 256
/* NAND flash */ #ifdef CONFIG_CMD_NAND diff --git a/include/configs/qemu-arm.h b/include/configs/qemu-arm.h index e9f756b13edb..dd2faebbbb26 100644 --- a/include/configs/qemu-arm.h +++ b/include/configs/qemu-arm.h @@ -74,6 +74,4 @@ "ramdisk_addr_r=0x44000000\0" \ BOOTENV
-#define CONFIG_SYS_MAX_FLASH_SECT 256 /* Sector: 256K, Bank: 64M */ - #endif /* __CONFIG_H */ diff --git a/include/configs/r2dplus.h b/include/configs/r2dplus.h index 409d5af0241d..f0dfba3fd49f 100644 --- a/include/configs/r2dplus.h +++ b/include/configs/r2dplus.h @@ -17,7 +17,6 @@ * NOR Flash ( Spantion S29GL256P ) */ #define CONFIG_SYS_FLASH_BASE (0xA0000000) -#define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE }
/* diff --git a/include/configs/salvator-x.h b/include/configs/salvator-x.h index 4b0f20e89b7c..fd68761ce8f4 100644 --- a/include/configs/salvator-x.h +++ b/include/configs/salvator-x.h @@ -16,7 +16,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_SYS_FLASH_BANKS_LIST { 0x08000000 } -#define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_WRITE_SWAPPED_DATA
#endif /* __SALVATOR_X_H */ diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 7bc3f91e77a8..b48e40bee440 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -31,7 +31,6 @@ /* NOR flash */ #ifdef CONFIG_MTD_NOR_FLASH #define CONFIG_SYS_FLASH_BASE 0x10000000 -#define CONFIG_SYS_MAX_FLASH_SECT 131 #endif
/* SDRAM */ diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 185da975fc2f..0d9a336b4e2c 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -88,8 +88,6 @@ #define CONFIG_SYS_LBC_FLASH_BASE CONFIG_SYS_FLASH1 /* Localbus flash start */ #define CONFIG_SYS_FLASH_BASE CONFIG_SYS_LBC_FLASH_BASE /* start of FLASH */
-#define CONFIG_SYS_MAX_FLASH_SECT 256 /* sectors per device */ - #define CONFIG_SYS_LBC_LCRR 0x00030004 /* LB clock ratio reg */ #define CONFIG_SYS_LBC_LBCR 0x00000000 /* LB config reg */ #define CONFIG_SYS_LBC_LSRT 0x20000000 /* LB sdram refresh timer */ diff --git a/include/configs/stm32f429-discovery.h b/include/configs/stm32f429-discovery.h index 18c9e5bfb6eb..51f69010b179 100644 --- a/include/configs/stm32f429-discovery.h +++ b/include/configs/stm32f429-discovery.h @@ -13,8 +13,6 @@ * Configuration of the external SDRAM memory */
-#define CONFIG_SYS_MAX_FLASH_SECT 12 - #define CONFIG_SYS_HZ_CLOCK 1000000 /* Timer is clocked at 1MHz */
#define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/stm32f429-evaluation.h b/include/configs/stm32f429-evaluation.h index 6849477beafb..221b7abe1ad7 100644 --- a/include/configs/stm32f429-evaluation.h +++ b/include/configs/stm32f429-evaluation.h @@ -18,8 +18,6 @@ * Configuration of the external SDRAM memory */
#define BOOT_TARGET_DEVICES(func) \ diff --git a/include/configs/stm32f469-discovery.h b/include/configs/stm32f469-discovery.h index 2d8b2d27c925..55e70ce92508 100644 --- a/include/configs/stm32f469-discovery.h +++ b/include/configs/stm32f469-discovery.h @@ -18,8 +18,6 @@ * Configuration of the external SDRAM memory */
#define BOOT_TARGET_DEVICES(func) \ diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index df05ee4892a5..64c1bc7d43ff 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -18,8 +18,6 @@ * Configuration of the external SDRAM memory */
-#define CONFIG_SYS_MAX_FLASH_SECT 8 - #define CONFIG_SYS_HZ_CLOCK 1000000 /* Timer is clocked at 1MHz */
#define BOOT_TARGET_DEVICES(func) \ diff --git a/include/configs/total_compute.h b/include/configs/total_compute.h index 5a1eed3f2170..7c77a8d53690 100644 --- a/include/configs/total_compute.h +++ b/include/configs/total_compute.h @@ -44,9 +44,5 @@ */
#define CONFIG_SYS_FLASH_BASE 0x0C000000 -/* 256 x 256KiB sectors */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 - -#define FLASH_MAX_SECTOR_SIZE 0x00040000
#endif /* __TOTAL_COMPUTE_H */ diff --git a/include/configs/ulcb.h b/include/configs/ulcb.h index 578873295fb9..f2e787cad89d 100644 --- a/include/configs/ulcb.h +++ b/include/configs/ulcb.h @@ -16,7 +16,6 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_SYS_FLASH_BANKS_LIST { 0x08000000 } -#define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_WRITE_SWAPPED_DATA
#endif /* __ULCB_H */ diff --git a/include/configs/vexpress_aemv8.h b/include/configs/vexpress_aemv8.h index 6b65fcf37ec9..077428f50040 100644 --- a/include/configs/vexpress_aemv8.h +++ b/include/configs/vexpress_aemv8.h @@ -261,17 +261,8 @@
#ifdef CONFIG_TARGET_VEXPRESS64_JUNO #define CONFIG_SYS_FLASH_BASE 0x08000000 -/* 255 x 256KiB sectors + 4 x 64KiB sectors at the end = 259 */ -#define CONFIG_SYS_MAX_FLASH_SECT 259 -/* Store environment at top of flash in the same location as blank.img */ -/* in the Juno firmware. */ #else #define CONFIG_SYS_FLASH_BASE (V2M_PA_BASE + 0x0C000000) -/* 256 x 256KiB sectors */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 -/* Store environment at top of flash */ #endif
-#define FLASH_MAX_SECTOR_SIZE 0x00040000 - #endif /* __VEXPRESS_AEMV8_H */ diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index 572a5171fc5c..d3eb01bae624 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -174,10 +174,6 @@
/* Timeout values in ticks */
-/* 255 0x40000 sectors + first or last sector may have 4 erase regions = 259 */ -#define CONFIG_SYS_MAX_FLASH_SECT 259 /* Max sectors */ -#define FLASH_MAX_SECTOR_SIZE 0x00040000 /* 256 KB sectors */ - /* Room required on the stack for the environment data */
/* diff --git a/include/configs/xtfpga.h b/include/configs/xtfpga.h index 67ba8af71f85..526165cf1028 100644 --- a/include/configs/xtfpga.h +++ b/include/configs/xtfpga.h @@ -180,9 +180,6 @@ # define CONFIG_SYS_FLASH_PARMSECT_SZ 0x8000 /* param size 32KB */ # define CONFIG_SYS_FLASH_BASE IOADDR(0x08000000) #endif -#define CONFIG_SYS_MAX_FLASH_SECT \ - (CONFIG_SYS_FLASH_SECT_SZ/CONFIG_SYS_FLASH_PARMSECT_SZ + \ - CONFIG_SYS_FLASH_SIZE/CONFIG_SYS_FLASH_SECT_SZ - 1)
/* * Put environment in top block (64kB) diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index cb4f4209728d..f6abacf2fac7 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -38,7 +38,6 @@
/* NOR */ #ifdef CONFIG_MTD_NOR_FLASH -# define CONFIG_SYS_MAX_FLASH_SECT 512 # define CONFIG_FLASH_SHOW_PROGRESS 10 # define CONFIG_SYS_FLASH_QUIET_TEST #endif
This converts the following to Kconfig: CONFIG_SYS_FLASH_QUIET_TEST
Signed-off-by: Tom Rini trini@konsulko.com --- README | 6 ------ configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/P2041RDB_NAND_defconfig | 1 + configs/P2041RDB_SDCARD_defconfig | 1 + configs/P2041RDB_SPIFLASH_defconfig | 1 + configs/P2041RDB_defconfig | 1 + configs/P3041DS_NAND_defconfig | 1 + configs/P3041DS_SDCARD_defconfig | 1 + configs/P3041DS_SPIFLASH_defconfig | 1 + configs/P3041DS_defconfig | 1 + configs/P4080DS_SDCARD_defconfig | 1 + configs/P4080DS_SPIFLASH_defconfig | 1 + configs/P4080DS_defconfig | 1 + configs/P5040DS_NAND_defconfig | 1 + configs/P5040DS_SDCARD_defconfig | 1 + configs/P5040DS_SPIFLASH_defconfig | 1 + configs/P5040DS_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 1 + configs/T2080QDS_SDCARD_defconfig | 1 + configs/T2080QDS_SECURE_BOOT_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 1 + configs/T2080QDS_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2080RDB_defconfig | 1 + configs/T2080RDB_revD_NAND_defconfig | 1 + configs/T2080RDB_revD_SDCARD_defconfig | 1 + configs/T2080RDB_revD_SPIFLASH_defconfig | 1 + configs/T2080RDB_revD_defconfig | 1 + configs/T4240RDB_SDCARD_defconfig | 1 + configs/T4240RDB_defconfig | 1 + configs/kmcent2_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043aqds_tfa_defconfig | 1 + configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_defconfig | 1 + configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 1 + configs/ls1046aqds_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_defconfig | 1 + configs/ls1046aqds_lpuart_defconfig | 1 + configs/ls1046aqds_nand_defconfig | 1 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/ls1088aqds_defconfig | 1 + configs/ls1088aqds_sdcard_ifc_defconfig | 1 + configs/ls1088aqds_tfa_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + configs/ls2088aqds_tfa_defconfig | 1 + configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 1 + configs/pg_wcom_expu1_defconfig | 1 + configs/pg_wcom_expu1_update_defconfig | 1 + configs/pg_wcom_seli8_defconfig | 1 + configs/pg_wcom_seli8_update_defconfig | 1 + configs/r8a77990_ebisu_defconfig | 1 + configs/rcar3_salvator-x_defconfig | 1 + configs/rcar3_ulcb_defconfig | 1 + configs/socrates_defconfig | 1 + configs/xilinx_zynq_virt_defconfig | 1 + configs/zynq_cse_nor_defconfig | 1 + drivers/mtd/Kconfig | 8 ++++++++ include/configs/P1010RDB.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/corenet_ds.h | 1 - include/configs/ebisu.h | 1 - include/configs/km/pg-wcom-ls102xa.h | 1 - include/configs/kmcent2.h | 1 - include/configs/kzm9g.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043a_common.h | 1 - include/configs/ls1046aqds.h | 1 - include/configs/ls1088aqds.h | 1 - include/configs/ls1088ardb.h | 1 - include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - include/configs/p1_p2_rdb_pc.h | 1 - include/configs/salvator-x.h | 1 - include/configs/socrates.h | 1 - include/configs/ulcb.h | 1 - include/configs/zynq-common.h | 1 - 157 files changed, 138 insertions(+), 31 deletions(-)
diff --git a/README b/README index d88c350cb914..20bfe4f17d08 100644 --- a/README +++ b/README @@ -1780,12 +1780,6 @@ Configuration Settings: s29ws-n MirrorBit flash has non-standard addresses for buffered write commands.
-- CONFIG_SYS_FLASH_QUIET_TEST - If this option is defined, the common CFI flash doesn't - print it's warning upon not recognized FLASH banks. This - is useful, if some of the configured banks are only - optionally available. - - CONFIG_FLASH_SHOW_PROGRESS If defined (must be an integer), print out countdown digits and dots. Recommended value: 45 (9..1) for 80 diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 3c5e62d10b4a..b9a9e39e86b1 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -101,6 +101,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index e5deb252ebad..a3df3ddb360f 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -69,6 +69,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 5bf9893fef9d..955e9d8cb459 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -90,6 +90,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index e3cea01cc654..25f6c81d9ae1 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -92,6 +92,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 466747483c12..c515ce53fa5b 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -100,6 +100,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 8a2bb55f6141..4015e3e324ef 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -68,6 +68,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index 320eb691deea..9d67ed1b26b8 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -89,6 +89,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index cad5fbb3823a..82317319588c 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -91,6 +91,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 7535d9f81273..d04ebbaa7dde 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -103,6 +103,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 1811c5cc4b11..c74d22a230ff 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -71,6 +71,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 405365e63dcf..885f720a6120 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -92,6 +92,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index afbb38c63946..ef37991be7d1 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -94,6 +94,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 9ab0bb5e094d..72bdbe3e93b1 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -102,6 +102,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index 9196895842da..52ec404f07d2 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -70,6 +70,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index bac9d01ae780..2461f53b1c00 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -91,6 +91,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index 33f28402a7e7..151720c18938 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -93,6 +93,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index cc3efdc96e43..b5f56341d663 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -112,6 +112,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 4956eb299402..28f0758f122e 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -99,6 +99,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 6f8beca99e20..1786b9496b24 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -101,6 +101,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index a38943d8ee6c..ce3f88dac43d 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -79,6 +79,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 2476352d6ab0..88eb80ff614a 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -111,6 +111,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index ed77af051cca..4298eac8460c 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -98,6 +98,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 55794e683386..ae5724678b6b 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -100,6 +100,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 57d5958125a7..c5988e78d820 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -78,6 +78,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 5d6ef2d173fa..32874fc8beff 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -115,6 +115,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index 7b8fe82de04b..43ab26d185bd 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -102,6 +102,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 718f2ae2d200..60a62e532c4e 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -104,6 +104,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index 3080e7add614..4e73f079d632 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -82,6 +82,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index 04540ae8ed0c..b9d0e125f302 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -117,6 +117,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 3af641f6a0ca..e046b76f11c0 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -104,6 +104,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 22937dd9dbed..f001a1be4924 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -106,6 +106,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index caa546a376f9..4c9ca9e63b96 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -84,6 +84,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 852ef4419a05..466e1aae3126 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -116,6 +116,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index aeaa538700dd..f0f5f482653d 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -103,6 +103,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 4a3ad3179e04..e845058deab4 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -105,6 +105,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index 101377b565b5..cf106dc43e8f 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -83,6 +83,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=128 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 10f4d712d4bb..1540e90a1ff3 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -76,6 +76,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_ELBC=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index a130983a2681..c1c249ddc17b 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -73,6 +73,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index 5c2a0c1a1ef0..32761cd8990d 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -75,6 +75,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index e1cf145a64ad..312396c8eacb 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -70,6 +70,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index 61b9c016976d..ea76795c38fb 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -81,6 +81,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index 410a98bbfcb6..fa49232d341b 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -78,6 +78,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index 700eab5e3078..145f3260a905 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -80,6 +80,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index ef402f0ddb10..679887bd4e43 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -75,6 +75,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index f77ea226ea60..c9313ede668e 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -75,6 +75,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index b94a2be38209..ca85b0c45583 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -77,6 +77,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index f0d67766126c..4f51df3645d5 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -72,6 +72,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index 48b868a548d9..0bc8fd995e9c 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -81,6 +81,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index 2eecbd98ee21..412fcb22cba8 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -77,6 +77,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index 759bcf56ed86..7a1a72fb5d8d 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -79,6 +79,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index d839a265e5d0..f808516fdb07 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -74,6 +74,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index ddfb9c08e3e9..683a114551f2 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -105,6 +105,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 8efd45f9220e..d954574574b2 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -104,6 +104,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index ccb3fa416bda..769de718508a 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -107,6 +107,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index ab6486bd21c7..aaadb88ebdf4 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -79,6 +79,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 8e4dc127f730..8f227294fd51 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -101,6 +101,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 9b7ae6207578..7b502a9bc4e1 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -100,6 +100,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 2995350135f1..42659cd1287d 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -103,6 +103,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 105b4c75a349..48a734d0bac9 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -75,6 +75,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 280354b4ff5e..dca3b3eb87ec 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -108,6 +108,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 6cb8882bd276..192f7b729de4 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -107,6 +107,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index ee45ea34b2ac..0023ffc2af4f 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -81,6 +81,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 277761308d71..81c8e3fc8796 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -110,6 +110,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index b576840ea376..b106f0c1d334 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -82,6 +82,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 344ca5755e4f..143b23015ebf 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -110,6 +110,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index a3d44ab6e665..488b7d28c924 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -109,6 +109,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 94be0a010b7d..3c11b130f5e4 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -112,6 +112,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index c875d22617a2..b4ddc46cf860 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -84,6 +84,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080RDB_revD_NAND_defconfig b/configs/T2080RDB_revD_NAND_defconfig index 02ce36e02244..1f32cf4284aa 100644 --- a/configs/T2080RDB_revD_NAND_defconfig +++ b/configs/T2080RDB_revD_NAND_defconfig @@ -111,6 +111,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/T2080RDB_revD_SDCARD_defconfig b/configs/T2080RDB_revD_SDCARD_defconfig index b99acbd94d96..3aa70a24eaa5 100644 --- a/configs/T2080RDB_revD_SDCARD_defconfig +++ b/configs/T2080RDB_revD_SDCARD_defconfig @@ -110,6 +110,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080RDB_revD_SPIFLASH_defconfig b/configs/T2080RDB_revD_SPIFLASH_defconfig index 109511432f43..8f3f1f1c51d5 100644 --- a/configs/T2080RDB_revD_SPIFLASH_defconfig +++ b/configs/T2080RDB_revD_SPIFLASH_defconfig @@ -113,6 +113,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080RDB_revD_defconfig b/configs/T2080RDB_revD_defconfig index 8a6bc95c27d0..25f001e77b85 100644 --- a/configs/T2080RDB_revD_defconfig +++ b/configs/T2080RDB_revD_defconfig @@ -85,6 +85,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index 1e10166f1d3a..f0d426866ae1 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -95,6 +95,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index e47521a4b1d6..9c7a4b2c7c99 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -70,6 +70,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_DM_SPI_FLASH=y diff --git a/configs/kmcent2_defconfig b/configs/kmcent2_defconfig index de58944b761e..08b174dd323e 100644 --- a/configs/kmcent2_defconfig +++ b/configs/kmcent2_defconfig @@ -76,6 +76,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 7a540e7c5539..778f22ac911a 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -81,6 +81,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index bd22e6721b49..bf6ddb6cf012 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -81,6 +81,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index bdef2ac84739..da92ac13a102 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -113,6 +113,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index 681cb68c863b..ee2c6b82edce 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -80,6 +80,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index e9fda69663fc..484ff026ba75 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -83,6 +83,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 06f51d5ab88a..c19fd26dd6dc 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -83,6 +83,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 13237c65a048..66cee0b3d6eb 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -111,6 +111,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index fe047007bc0a..7356b3d6e147 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -67,6 +67,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index 7571d7c8b5e2..fdf66f662bf1 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -70,6 +70,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 96284e316c78..55b30d39003e 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -70,6 +70,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 01863abb9aaf..118a085ec3f2 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -98,6 +98,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index a981def7504d..c87581d18efe 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -98,6 +98,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index e0642c77a945..d7ff7e2970fb 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -81,6 +81,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index b50b278748ec..462fad1cd48f 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -81,6 +81,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 5afeea763b7d..63287ca533b3 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -110,6 +110,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 373923b4d999..fc72f4cdaf64 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -82,6 +82,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index 607df6dd9d85..172ab723c61b 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -108,6 +108,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index 6e5f8fb9c673..b414d400e6a1 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -78,6 +78,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index c47eb92b25ca..9bac24a27b30 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -87,6 +87,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 48b96e18d87c..0a40bf0f9f99 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -64,6 +64,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 555b4173b060..f27eadf39211 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -67,6 +67,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index eea1aea18dee..da23382940f8 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -87,6 +87,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index d0e5c37357f6..2be08bbb7b35 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -94,6 +94,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index 4f125358c0fc..d9b841df1a4e 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -88,6 +88,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 6cfbc5960d10..79feb55dfb15 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -92,6 +92,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig index da31529064a8..3aafd103df38 100644 --- a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig @@ -63,6 +63,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index 76a2b2608e45..f9cb304ba1cc 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -69,6 +69,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index 10f808cefa86..3a71185b865a 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -78,6 +78,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index 28fd339803d1..35abfb323f65 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -81,6 +81,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index 7cbc58458925..5316c80c83d2 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -81,6 +81,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 084d26462aaa..8550190d2295 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -108,6 +108,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index 1db39e64c604..6cdc78da3f0f 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -109,6 +109,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig index 5047baec8a48..7efa5cbebd07 100644 --- a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig @@ -78,6 +78,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index 7ebb5def6455..3846b95e71d5 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -87,6 +87,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index 63ea991b6ce3..bd34f8dff40b 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -77,6 +77,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index bc626e3f772d..3aa20d35af03 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -97,6 +97,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index 0da726c32aeb..91899d2ed88b 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -85,6 +85,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index b00b3fc3b1c3..965863dbd391 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -66,6 +66,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index 8002570d4a29..3e0da6884515 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -69,6 +69,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index f27df9df7e9a..16367fc45384 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -69,6 +69,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index eec426e67671..82ad9b27b06e 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -72,6 +72,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 8ec4e6a7ff2d..189a4e0683cf 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -92,6 +92,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index 4ad644d78c7d..2eba6b69a7be 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -80,6 +80,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index 5cd18a17e13a..0c58a6dd935c 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -74,6 +74,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index 1611bb50f44b..a7c703683773 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -81,6 +81,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=1024 CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y diff --git a/configs/pg_wcom_expu1_defconfig b/configs/pg_wcom_expu1_defconfig index 549a86cabcf8..e1cbc0c39c5b 100644 --- a/configs/pg_wcom_expu1_defconfig +++ b/configs/pg_wcom_expu1_defconfig @@ -84,6 +84,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/pg_wcom_expu1_update_defconfig b/configs/pg_wcom_expu1_update_defconfig index f1bfc40b5756..a381c8f41293 100644 --- a/configs/pg_wcom_expu1_update_defconfig +++ b/configs/pg_wcom_expu1_update_defconfig @@ -82,6 +82,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/pg_wcom_seli8_defconfig b/configs/pg_wcom_seli8_defconfig index ae679966baab..39c43ec3987e 100644 --- a/configs/pg_wcom_seli8_defconfig +++ b/configs/pg_wcom_seli8_defconfig @@ -84,6 +84,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/pg_wcom_seli8_update_defconfig b/configs/pg_wcom_seli8_update_defconfig index 1c74b6b8c51e..3e057591cacc 100644 --- a/configs/pg_wcom_seli8_update_defconfig +++ b/configs/pg_wcom_seli8_update_defconfig @@ -82,6 +82,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_EMPTY_INFO=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/r8a77990_ebisu_defconfig b/configs/r8a77990_ebisu_defconfig index d13e3ea15bea..04ad54eb1f1c 100644 --- a/configs/r8a77990_ebisu_defconfig +++ b/configs/r8a77990_ebisu_defconfig @@ -83,6 +83,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_RENESAS_RPC_HF=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y diff --git a/configs/rcar3_salvator-x_defconfig b/configs/rcar3_salvator-x_defconfig index bb2101ef688e..9491b78ea368 100644 --- a/configs/rcar3_salvator-x_defconfig +++ b/configs/rcar3_salvator-x_defconfig @@ -86,6 +86,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_RENESAS_RPC_HF=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y diff --git a/configs/rcar3_ulcb_defconfig b/configs/rcar3_ulcb_defconfig index 8eb703a54329..a7e375978c53 100644 --- a/configs/rcar3_ulcb_defconfig +++ b/configs/rcar3_ulcb_defconfig @@ -85,6 +85,7 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_RENESAS_RPC_HF=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 75195b36addf..251586178ec2 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -73,6 +73,7 @@ CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS=2 CONFIG_MTD_RAW_NAND=y diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index b3834b4952ff..7beb5915fcec 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -111,6 +111,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ZYNQ=y CONFIG_SYS_NAND_ONFI_DETECTION=y diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig index ecdbf8182e68..59cd19ef2d40 100644 --- a/configs/zynq_cse_nor_defconfig +++ b/configs/zynq_cse_nor_defconfig @@ -78,5 +78,6 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_ARM_DCC=y # CONFIG_GZIP is not set diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index 828ec9758207..fcdb450f77aa 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -132,6 +132,14 @@ config SYS_FLASH_CFI Define if the flash driver uses extra elements in the common flash structure for storing flash geometry.
+config SYS_FLASH_QUIET_TEST + bool "Disable printing a warning about not recognizing some flash banks" + depends on FLASH_CFI_DRIVER + help + If this option is enabled, the common CFI flash doesn't print it's + warning upon not recognized FLASH banks. This is useful, if some of + the configured banks are only optionally available. + config SYS_FLASH_CHECKSUM bool "Compute and print flash CRC if 'flashchecksum' is set in the environment" depends on MTD_NOR_FLASH diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 9a7f7d5464bf..7f5eaf88aa4c 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -162,7 +162,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_NOR_FTIM3 0x0
#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} -#define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
/* CFI for NOR Flash */ diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 45ce78a5e73c..69a5df61b141 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -120,7 +120,6 @@ #define PIXIS_LBMAP_SHIFT 4 #define PIXIS_LBMAP_ALTBANK 0x40
/* Nand Flash */ diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 2bdb54522316..f5e07a929fc5 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -165,7 +165,6 @@ FTIM2_NOR_TWP(0x1c)) #define CONFIG_SYS_NOR_FTIM3 0x0
#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 96a84706f7cc..7983a71953d4 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -127,7 +127,6 @@ FTIM2_NOR_TWP(0x1c)) #define CONFIG_SYS_NOR_FTIM3 0x0
#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 321c306a04e9..3da9831a028e 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -130,7 +130,6 @@ FTIM2_NOR_TWP(0x1c)) #define CONFIG_SYS_NOR_FTIM3 0x0
#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS \ diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 677cc80d146d..813d8fae9c8c 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -120,7 +120,6 @@ FTIM2_NOR_TWP(0x1c)) #define CONFIG_SYS_NOR_FTIM3 0x0
#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS } diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 28755203ebfe..332f34e1ff22 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -201,7 +201,6 @@ FTIM2_NOR_TWP(0x1c)) #define CONFIG_SYS_NOR_FTIM3 0x0
#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS \ diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 84712d16d0f7..7615696f1608 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -110,7 +110,6 @@ #define PIXIS_LBMAP_SHIFT 4 #define PIXIS_LBMAP_ALTBANK 0x40
/* Nand Flash */ diff --git a/include/configs/ebisu.h b/include/configs/ebisu.h index 5e2dc04e253d..597efd6745cd 100644 --- a/include/configs/ebisu.h +++ b/include/configs/ebisu.h @@ -16,7 +16,6 @@ /* Environment in eMMC, at the end of 2nd "boot sector" */
#define CONFIG_FLASH_SHOW_PROGRESS 45 -#define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_SYS_FLASH_BANKS_LIST { 0x08000000 } #define CONFIG_SYS_WRITE_SWAPPED_DATA
diff --git a/include/configs/km/pg-wcom-ls102xa.h b/include/configs/km/pg-wcom-ls102xa.h index 0cc90070c244..43471e08d604 100644 --- a/include/configs/km/pg-wcom-ls102xa.h +++ b/include/configs/km/pg-wcom-ls102xa.h @@ -61,7 +61,6 @@ FTIM2_NOR_TWP(0xb)) #define CONFIG_SYS_NOR_FTIM3 0
#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE_PHYS } diff --git a/include/configs/kmcent2.h b/include/configs/kmcent2.h index 375c6e2bfccf..348133c2c70d 100644 --- a/include/configs/kmcent2.h +++ b/include/configs/kmcent2.h @@ -232,7 +232,6 @@ #define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3
/* More NOR Flash params */ -#define CONFIG_SYS_FLASH_QUIET_TEST
diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 203381b0e7bd..602c1c539190 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -39,7 +39,6 @@ #define CONFIG_STANDALONE_LOAD_ADDR 0x41000000
/* FLASH */ -#undef CONFIG_SYS_FLASH_QUIET_TEST #define FLASH_SECTOR_SIZE (256 * 1024) /* 256 KB sectors */
/* Timeout for Flash erase operations (in ms) */ diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 7df99cad6aa9..d9a973c13fba 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -65,7 +65,6 @@ FTIM2_NOR_TWP(0x1c)) #define CONFIG_SYS_NOR_FTIM3 0
-#define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 #define CONFIG_SYS_WRITE_SWAPPED_DATA
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 72acc9ab62c9..5f3e8d5b7128 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -95,7 +95,6 @@ FTIM2_NOR_TWPH(0x0e)) #define CONFIG_SYS_NOR_FTIM3 0
#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE_PHYS } diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 95cbcb036eb8..43f30fd70f71 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -100,7 +100,6 @@ #define CONFIG_SYS_FLASH_BASE_PHYS_EARLY 0x00000000
#ifdef CONFIG_MTD_NOR_FLASH -#define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ #endif #endif diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index c2bbc5fec313..869bbd763461 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -43,7 +43,6 @@ #define CONFIG_SYS_FLASH_BASE_PHYS_EARLY 0x00000000
#ifdef CONFIG_MTD_NOR_FLASH -#define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ #endif #endif diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index 0106456284c2..6db0ba5f5ae2 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -62,7 +62,6 @@ #define CONFIG_SYS_IFC_CCR 0x01000000
#ifndef SYS_NO_FLASH -#define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE,\ diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h index 36abd0868135..c3e87ed24db9 100644 --- a/include/configs/ls1088ardb.h +++ b/include/configs/ls1088ardb.h @@ -47,7 +47,6 @@ #define CONFIG_SYS_IFC_CCR 0x01000000
#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index a8f876c54a5d..c2ad2afb5eb5 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -64,7 +64,6 @@ #define CONFIG_SYS_IFC_CCR 0x01000000
#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE,\ diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index cd34698e5613..23ddae1dc3d8 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -61,7 +61,6 @@ #define CONFIG_SYS_IFC_CCR 0x01000000
#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE,\ diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 5071959278d6..4fe5aebea4ab 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -193,7 +193,6 @@ #define CONFIG_FLASH_OR_PRELIM 0xfc000ff7
/* Nand Flash */ diff --git a/include/configs/salvator-x.h b/include/configs/salvator-x.h index fd68761ce8f4..41e52546ed32 100644 --- a/include/configs/salvator-x.h +++ b/include/configs/salvator-x.h @@ -14,7 +14,6 @@ /* Environment in eMMC, at the end of 2nd "boot sector" */
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 0d9a336b4e2c..498deb4e3fc7 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -80,7 +80,6 @@ */ #define CONFIG_SYS_LBC_CACHE_BASE 0xf0000000 /* Localbus cacheable */
-#define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_SYS_FLASH0 0xFE000000 #define CONFIG_SYS_FLASH1 0xFC000000 #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH1, CONFIG_SYS_FLASH0 } diff --git a/include/configs/ulcb.h b/include/configs/ulcb.h index f2e787cad89d..a977271c1e6e 100644 --- a/include/configs/ulcb.h +++ b/include/configs/ulcb.h @@ -14,7 +14,6 @@ /* Environment in eMMC, at the end of 2nd "boot sector" */
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index f6abacf2fac7..75ae68766fa1 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -39,7 +39,6 @@ /* NOR */ #ifdef CONFIG_MTD_NOR_FLASH # define CONFIG_FLASH_SHOW_PROGRESS 10 -# define CONFIG_SYS_FLASH_QUIET_TEST #endif
#ifdef CONFIG_NAND_ZYNQ
This converts the following to Kconfig: CONFIG_SYS_FMAN_V3
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/arch-fsl-layerscape/config.h | 2 -- arch/powerpc/include/asm/config_mpc85xx.h | 5 ----- drivers/net/Kconfig | 8 ++++++++ 3 files changed, 8 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index cd795d6919ac..9aee971b7260 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -264,7 +264,6 @@
/* SoC related */ #ifdef CONFIG_ARCH_LS1043A -#define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FSL_QMAN_V3 #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 7 @@ -317,7 +316,6 @@ #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
#elif defined(CONFIG_ARCH_LS1046A) -#define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FSL_QMAN_V3 #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 8 diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index a43e6e5e538b..1dcbe0670b62 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -183,7 +183,6 @@ #define CONFIG_SYS_NUM_FMAN 2 #define CONFIG_SYS_PME_CLK 0 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 -#define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FM1_CLK 3 #define CONFIG_SYS_FM2_CLK 3 #define CONFIG_SYS_FM_MURAM_SIZE 0x60000 @@ -205,7 +204,6 @@ #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_FM1_CLK 0 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 -#define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FM_MURAM_SIZE 0x60000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.4" @@ -244,7 +242,6 @@ #define CONFIG_PME_PLAT_CLK_DIV 2 #define CONFIG_SYS_PME_CLK CONFIG_PME_PLAT_CLK_DIV #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 -#define CONFIG_SYS_FMAN_V3 #define CONFIG_FM_PLAT_CLK_DIV 1 #define CONFIG_SYS_FM1_CLK CONFIG_FM_PLAT_CLK_DIV #define CONFIG_SYS_FM_MURAM_SIZE 0x30000 @@ -262,7 +259,6 @@ #define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_CORES_PER_CLUSTER 1 #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ -#define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FSL_NUM_CC_PLL 2 #define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1, 1, 1 } #define CONFIG_SYS_FSL_SRDS_1 @@ -305,7 +301,6 @@ #define CONFIG_SYS_PME_CLK CONFIG_PME_PLAT_CLK_DIV #define CONFIG_SYS_FM1_CLK 0 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 -#define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v3.0" diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index b671e72580e2..637aca4d7e99 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -357,6 +357,9 @@ config FEC_MXC config FMAN_ENET bool "Freescale FMan ethernet support" depends on ARM || PPC + select SYS_FMAN_V3 if ARCH_B4420 || ARCH_B4860 || ARCH_LS1043A || \ + ARCH_LS1046A || ARCH_T1024 || ARCH_T1040 || ARCH_T1042 || \ + ARCH_T2080 || ARCH_T4240 help This driver support the Freescale FMan Ethernet controller
@@ -370,6 +373,11 @@ config SYS_QE_FMAN_FW_LENGTH depends on FMAN_ENET || QE || U_QE default 0x10000
+config SYS_FMAN_V3 + bool + help + SoC has FMan v3 with mEMAC + config FTMAC100 bool "Ftmac100 Ethernet Support" help
There are a large number of options under CONFIG_SYS (but some of these are elsewhere, spotted while cleaning CONFIG_SYS) that are never referenced, or only used slightly later in the config file. Remove or restructure these.
Signed-off-by: Tom Rini trini@konsulko.com --- doc/arch/m68k.rst | 2 -- include/configs/M5253DEMO.h | 3 --- include/configs/M5275EVB.h | 5 ----- include/configs/P2041RDB.h | 7 ------- include/configs/am3517_evm.h | 2 -- include/configs/astro_mcf5373l.h | 4 ---- include/configs/brppt1.h | 4 ---- include/configs/chiliboard.h | 6 ------ include/configs/cm_t335.h | 2 -- include/configs/cobra5272.h | 7 ------- include/configs/corenet_ds.h | 6 ------ include/configs/da850evm.h | 1 - include/configs/etamin.h | 1 - include/configs/ids8313.h | 7 ------- include/configs/km/km-powerpc.h | 3 --- include/configs/km/km_arm.h | 3 --- include/configs/ls1012aqds.h | 22 ---------------------- include/configs/ls2080aqds.h | 4 ---- include/configs/ls2080ardb.h | 4 ---- include/configs/mx6sabreauto.h | 1 - include/configs/omap3_beagle.h | 1 - include/configs/omap3_evm.h | 1 - include/configs/omap3_logic.h | 2 -- include/configs/qemu-ppce500.h | 2 -- include/configs/s5p4418_nanopi2.h | 3 +-- include/configs/siemens-am33x-common.h | 3 --- include/configs/vexpress_common.h | 6 +----- include/configs/xtfpga.h | 24 ++++-------------------- 28 files changed, 6 insertions(+), 130 deletions(-)
diff --git a/doc/arch/m68k.rst b/doc/arch/m68k.rst index 698e288c4487..87a51e5b7db9 100644 --- a/doc/arch/m68k.rst +++ b/doc/arch/m68k.rst @@ -114,8 +114,6 @@ apply to one or more cpu for the ColdFire family:
CONFIG_SYS_MBAR: defines the base address of the MCF5272 configuration registers -CONFIG_SYS_ENET_BD_BASE: - defines the base address of the FEC buffer descriptors CONFIG_SYS_SCR: defines the contents of the System Configuration Register CONFIG_SYS_SPR: diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index 9f648342ea33..75278f4dab71 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -125,9 +125,6 @@ #define CONFIG_SYS_CACHE_ICACR (CF_CACR_CENB | CF_CACR_CEIB | \ CF_CACR_DBWE)
-/* Port configuration */ -#define CONFIG_SYS_FECI2C 0xF0 - #define CONFIG_SYS_CS0_BASE 0xFF800000 #define CONFIG_SYS_CS0_MASK 0x007F0021 #define CONFIG_SYS_CS0_CTRL 0x00001D80 diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index 1fd51212d637..35ff267371c2 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -122,9 +122,4 @@ #define CONFIG_SYS_CS1_CTRL 0x00001900 #define CONFIG_SYS_CS1_MASK 0x00070001
-/*----------------------------------------------------------------------- - * Port configuration - */ -#define CONFIG_SYS_FECI2C 0x0FA0 - #endif /* _M5275EVB_H */ diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 69a5df61b141..de5f42b10117 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -100,13 +100,6 @@ #define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE #endif
-#define CONFIG_SYS_FLASH_BR_PRELIM \ - (BR_PHYS_ADDR((CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000)) | \ - BR_PS_16 | BR_V) -#define CONFIG_SYS_FLASH_OR_PRELIM \ - ((0xf8000ff7 & ~OR_GPCM_SCY & ~OR_GPCM_EHTR) \ - | OR_GPCM_SCY_8 | OR_GPCM_EHTR_CLEAR) - #define CONFIG_FSL_CPLD #define CPLD_BASE 0xffdf0000 /* CPLD registers */ #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 02a5e94c4f48..2dc6bd2f2cdd 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -95,6 +95,4 @@ #define CONFIG_SYS_FLASH_BASE NAND_BASE #endif
-#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ - #endif /* __CONFIG_H */ diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index dde30eab5ed9..cd2114541d7c 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -62,9 +62,6 @@ #define CONFIG_SYS_CPU_CLK (CONFIG_SYS_CLK * 3) #define CONFIG_SYS_SDRAM_SIZE 32 /* SDRAM size in MB */
-#define CONFIG_SYS_CORE_SRAM_SIZE 0x8000 -#define CONFIG_SYS_CORE_SRAM 0x80000000 - /* * Define baudrate for UART1 (console output, tftp, ...) * default value of CONFIG_BAUDRATE for Sentec board: 19200 baud @@ -209,7 +206,6 @@ /* FLASH organization */
#define CONFIG_SYS_FLASH_SIZE 0x2000000 -#define CONFIG_SYS_FLASH_CFI_NONBLOCK 1
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 789e6a4c9d59..6cb1a1060022 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -143,8 +143,4 @@ NANDTGTS \ #define CONFIG_NAND_OMAP_GPMC_WSCFG 1 #endif /* CONFIG_MTD_RAW_NAND */
-#if defined(CONFIG_ENV_IS_IN_NAND) -#define CONFIG_SYS_ENV_SECT_SIZE CONFIG_ENV_SIZE -#endif - #endif /* ! __CONFIG_BRPPT1_H__ */ diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index 965eba58b311..fdbcbf5d96e2 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -119,10 +119,4 @@ #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14
-#if defined(CONFIG_ENV_IS_IN_NAND) -#define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#endif - -/* Network. */ - #endif /* ! __CONFIG_CHILIBOARD_H */ diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index 4baf7f7e24ae..84b4271c36fa 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -79,8 +79,6 @@
#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE
-#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ - /* GPIO pin + bank to pin ID mapping */ #define GPIO_PIN(_bank, _pin) ((_bank << 5) + _pin)
diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index c29abd15b39e..ba0662f1f40e 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -143,13 +143,6 @@ enter a valid image address in flash */ #define CONFIG_SYS_SCR 0x0003 #define CONFIG_SYS_SPR 0xffff
-/* --- - * Ethernet settings - * --- - */ - -#define CONFIG_SYS_ENET_BD_BASE 0x780000 - /*----------------------------------------------------------------------- * Definitions for initial stack pointer and data area (in internal SRAM) */ diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 7615696f1608..a4fb2b53dc9f 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -92,12 +92,6 @@ #define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE #endif
-#define CONFIG_SYS_FLASH_BR_PRELIM \ - (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000) \ - | BR_PS_16 | BR_V) -#define CONFIG_SYS_FLASH_OR_PRELIM ((0xf8000ff7 & ~OR_GPCM_SCY & ~OR_GPCM_EHTR) \ - | OR_GPCM_SCY_8 | OR_GPCM_EHTR_CLEAR) - #define PIXIS_BASE 0xffdf0000 /* PIXIS registers */ #ifdef CONFIG_PHYS_64BIT #define PIXIS_BASE_PHYS 0xfffdf0000ull diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index f699cb107800..58c902431d13 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -134,7 +134,6 @@ #endif
#ifdef CONFIG_MTD_NOR_FLASH -#define CONFIG_SYS_FLASH_SECT_SZ (128 << 10) /* 128KB */ #define CONFIG_SYS_FLASH_BASE DAVINCI_ASYNC_EMIF_DATA_CE2_BASE #define PHYS_FLASH_SIZE (8 << 20) /* Flash size 8MB */ #endif diff --git a/include/configs/etamin.h b/include/configs/etamin.h index 3acc62d9e178..7923fbb599d1 100644 --- a/include/configs/etamin.h +++ b/include/configs/etamin.h @@ -15,7 +15,6 @@ #include "siemens-am33x-common.h" /* NAND specific changes for etamin due to different page size */ #undef CONFIG_SYS_NAND_ECCPOS -#undef CONFIG_SYS_ENV_SECT_SIZE
#define CONFIG_SYS_ENV_SECT_SIZE (512 << 10) /* 512 KiB */ #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index 1b97e54be7f6..e89b800b7eeb 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -123,17 +123,10 @@ #define CONFIG_SYS_MRAM_BASE 0xE2000000 #define CONFIG_SYS_MRAM_SIZE 0x20000 /* 128 Kb */
-#define CONFIG_SYS_OR_TIMING_MRAM - - /* * CPLD setup */ #define CONFIG_SYS_CPLD_BASE 0xE3000000 -#define CONFIG_SYS_CPLD_SIZE 0x8000 - -#define CONFIG_SYS_OR_TIMING_MRAM -
/* * HW-Watchdog diff --git a/include/configs/km/km-powerpc.h b/include/configs/km/km-powerpc.h index 6becd7cd31a8..20a36fbe115e 100644 --- a/include/configs/km/km-powerpc.h +++ b/include/configs/km/km-powerpc.h @@ -9,9 +9,6 @@
/* Do boardspecific init for all boards */
-/* EEprom support 24C08, 24C16, 24C64 */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_ENABLE - /* Increase max size of compressed kernel */
/****************************************************************************** diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index eee71db37c2b..a91e5e8f8654 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -97,9 +97,6 @@ extern void __set_direction(unsigned pin, int high); #define I2C_DELAY udelay(1) #define I2C_SOFT_DECLARATIONS
-/* EEprom support 24C128, 24C256 valid for environment eeprom */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_ENABLE - /* * Environment variables configurations */ diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index b124ce52620c..48fe8288aa18 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -60,28 +60,6 @@ #define I2C_VOL_MONITOR_BUS_V_OVF 0x1 #define I2C_VOL_MONITOR_BUS_V_SHIFT 3
-/* DSPI */ -#define CONFIG_FSL_DSPI1 - -#define MMAP_DSPI DSPI1_BASE_ADDR - -#define CONFIG_SYS_DSPI_CTAR0 1 - -#define CONFIG_SYS_DSPI_CTAR1 (DSPI_CTAR_TRSZ(7) | DSPI_CTAR_PCSSCK_1CLK |\ - DSPI_CTAR_PASC(0) | DSPI_CTAR_PDT(0) | \ - DSPI_CTAR_CSSCK(2) | DSPI_CTAR_ASC(0) | \ - DSPI_CTAR_DT(0)) - -#define CONFIG_SYS_DSPI_CTAR2 (DSPI_CTAR_TRSZ(7) | DSPI_CTAR_PCSSCK_1CLK |\ - DSPI_CTAR_PASC(0) | DSPI_CTAR_PDT(0) | \ - DSPI_CTAR_CSSCK(0) | DSPI_CTAR_ASC(0) | \ - DSPI_CTAR_DT(0)) - -#define CONFIG_SYS_DSPI_CTAR3 (DSPI_CTAR_TRSZ(7) | DSPI_CTAR_PCSSCK_1CLK |\ - DSPI_CTAR_PASC(0) | DSPI_CTAR_PDT(0) | \ - DSPI_CTAR_CSSCK(2) | DSPI_CTAR_ASC(0) | \ - DSPI_CTAR_DT(0)) - #undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ "verify=no\0" \ diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index c2ad2afb5eb5..f6efda258c0e 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -208,10 +208,6 @@ #define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 #endif
-/* Debug Server firmware */ -#define CONFIG_SYS_DEBUG_SERVER_FW_IN_NOR -#define CONFIG_SYS_DEBUG_SERVER_FW_ADDR 0x580D00000ULL - #define CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS 5000
/* diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 23ddae1dc3d8..c6b601de227a 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -179,10 +179,6 @@ #define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 #endif - -/* Debug Server firmware */ -#define CONFIG_SYS_DEBUG_SERVER_FW_IN_NOR -#define CONFIG_SYS_DEBUG_SERVER_FW_ADDR 0x580D00000ULL #endif #define CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS 5000
diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index 7bfc04ff18f7..c76e7ea1605a 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -31,7 +31,6 @@
#ifdef CONFIG_MTD_NOR_FLASH #define CONFIG_SYS_FLASH_BASE WEIM_ARB_BASE_ADDR -#define CONFIG_SYS_FLASH_SECT_SIZE (128 * 1024) #endif
#define CONFIG_SYS_FSL_USDHC_NUM 2 diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 2cd42e5a1dc4..ad3dbbcac52f 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -26,7 +26,6 @@ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_SYS_ENV_SECT_SIZE SZ_128K /* NAND: SPL falcon mode configs */ #endif /* CONFIG_MTD_RAW_NAND */
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 2683d4c7ea45..c47d5573c46a 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -31,7 +31,6 @@ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_SYS_ENV_SECT_SIZE SZ_128K #endif /* CONFIG_MTD_RAW_NAND */
#define BOOTENV_DEV_LEGACY_MMC(devtypeu, devtypel, instance) \ diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 81c1692055d9..1af87b271c4f 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -152,6 +152,4 @@
#define CONFIG_SYS_FLASH_SIZE 0x4000000
-#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ - #endif /* __CONFIG_H */ diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index 31e94df84df7..5181792b7b73 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -33,8 +33,6 @@ extern unsigned long long get_phys_ccsrbar_addr_early(void); #define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE
-#define CONFIG_SYS_BOOT_BLOCK 0x00000000 /* boot TLB */ - #define CONFIG_HWCONFIG
#define CONFIG_SYS_INIT_RAM_ADDR 0x00100000 diff --git a/include/configs/s5p4418_nanopi2.h b/include/configs/s5p4418_nanopi2.h index 43593572d963..ae94f0ecc56a 100644 --- a/include/configs/s5p4418_nanopi2.h +++ b/include/configs/s5p4418_nanopi2.h @@ -18,11 +18,10 @@ /*----------------------------------------------------------------------- * System memory Configuration */ -#define CONFIG_SYS_MEM_SIZE 0x40000000 #define CONFIG_SYS_SDRAM_BASE 0x71000000
/* - * "(CONFIG_SYS_MEM_SIZE - CONFIG_SYS_RESERVE_MEM_SIZE)" has been used in + * "(0x40000000 - CONFIG_SYS_RESERVE_MEM_SIZE)" has been used in * u-boot nanopi2-v2016.01. * This is not working anymore because boot_fdt_add_mem_rsv_regions() in * common/image-fdt.c has been extended: diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index d2d4296eed62..fcb0fd5cec3b 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -370,9 +370,6 @@ /* CS0 */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ -#if !defined(CONFIG_SPI_BOOT) -#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ -#endif #endif
#endif /* ! __CONFIG_SIEMENS_AM33X_COMMON_H */ diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index d3eb01bae624..7c0856ae325a 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -167,10 +167,7 @@ "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0"
/* FLASH and environment organization */ -#define PHYS_FLASH_SIZE 0x04000000 /* 64MB */ #define CONFIG_SYS_FLASH_SIZE 0x04000000 -#define CONFIG_SYS_FLASH_BASE0 V2M_NOR0 -#define CONFIG_SYS_FLASH_BASE1 V2M_NOR1
/* Timeout values in ticks */
@@ -183,7 +180,6 @@ */
/* Store environment at top of flash */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE0, \ - CONFIG_SYS_FLASH_BASE1 } +#define CONFIG_SYS_FLASH_BANKS_LIST { V2M_NOR0, V2M_NOR1 }
#endif /* VEXPRESS_COMMON_H */ diff --git a/include/configs/xtfpga.h b/include/configs/xtfpga.h index 526165cf1028..ad8ea6538c20 100644 --- a/include/configs/xtfpga.h +++ b/include/configs/xtfpga.h @@ -76,13 +76,12 @@
#if defined(CONFIG_MAX_MEM_MAPPED) && \ CONFIG_MAX_MEM_MAPPED < CONFIG_SYS_SDRAM_SIZE -#define CONFIG_SYS_MEMORY_SIZE CONFIG_MAX_MEM_MAPPED +#define XTENSA_SYS_TEXT_ADDR \ + (MEMADDR(CONFIG_MAX_MEM_MAPPED) - CONFIG_SYS_MONITOR_LEN) #else -#define CONFIG_SYS_MEMORY_SIZE CONFIG_SYS_SDRAM_SIZE -#endif - #define XTENSA_SYS_TEXT_ADDR \ - (MEMADDR(CONFIG_SYS_MEMORY_SIZE) - CONFIG_SYS_MONITOR_LEN) + (MEMADDR(CONFIG_SYS_SDRAM_SIZE) - CONFIG_SYS_MONITOR_LEN) +#endif
/*==============================*/ /* U-Boot general configuration */ @@ -105,18 +104,6 @@ * SHIFT left amount and field WIDTH (bits), and also by a bitMASK. */
-/* Date of FPGA bitstream build in binary coded decimal (BCD) */ -#define CONFIG_SYS_FPGAREG_DATE IOADDR(0x0D020000) -#define FPGAREG_MTH_SHIFT 24 /* BCD month 1..12 */ -#define FPGAREG_MTH_WIDTH 8 -#define FPGAREG_MTH_MASK 0xFF000000 -#define FPGAREG_DAY_SHIFT 16 /* BCD day 1..31 */ -#define FPGAREG_DAY_WIDTH 8 -#define FPGAREG_DAY_MASK 0x00FF0000 -#define FPGAREG_YEAR_SHIFT 0 /* BCD year 2001..9999*/ -#define FPGAREG_YEAR_WIDTH 16 -#define FPGAREG_YEAR_MASK 0x0000FFFF - /* FPGA core clock frequency in Hz (also input to UART) */ #define CONFIG_SYS_FPGAREG_FREQ IOADDR(0x0D020004) /* CPU clock frequency*/
@@ -166,17 +153,14 @@
#ifdef CONFIG_XTFPGA_LX60 # define CONFIG_SYS_FLASH_SIZE 0x0040000 /* 4MB */ -# define CONFIG_SYS_FLASH_SECT_SZ 0x10000 /* block size 64KB */ # define CONFIG_SYS_FLASH_PARMSECT_SZ 0x2000 /* param size 8KB */ # define CONFIG_SYS_FLASH_BASE IOADDR(0x08000000) #elif defined(CONFIG_XTFPGA_KC705) # define CONFIG_SYS_FLASH_SIZE 0x8000000 /* 128MB */ -# define CONFIG_SYS_FLASH_SECT_SZ 0x20000 /* block size 128KB */ # define CONFIG_SYS_FLASH_PARMSECT_SZ 0x8000 /* param size 32KB */ # define CONFIG_SYS_FLASH_BASE IOADDR(0x00000000) #else # define CONFIG_SYS_FLASH_SIZE 0x1000000 /* 16MB */ -# define CONFIG_SYS_FLASH_SECT_SZ 0x20000 /* block size 128KB */ # define CONFIG_SYS_FLASH_PARMSECT_SZ 0x8000 /* param size 32KB */ # define CONFIG_SYS_FLASH_BASE IOADDR(0x08000000) #endif
This converts the following to Kconfig: CONFIG_FSL_CORENET
Signed-off-by: Tom Rini trini@konsulko.com --- arch/powerpc/cpu/mpc85xx/Kconfig | 18 +++++++++++++++++- arch/powerpc/include/asm/config_mpc85xx.h | 9 --------- configs/P2041RDB_NAND_defconfig | 1 - configs/P2041RDB_SDCARD_defconfig | 1 - configs/P2041RDB_SPIFLASH_defconfig | 1 - configs/P2041RDB_defconfig | 1 - configs/P3041DS_NAND_defconfig | 1 - configs/P3041DS_SDCARD_defconfig | 1 - configs/P3041DS_SPIFLASH_defconfig | 1 - configs/P3041DS_defconfig | 1 - configs/P4080DS_SDCARD_defconfig | 1 - configs/P4080DS_SPIFLASH_defconfig | 1 - configs/P4080DS_defconfig | 1 - configs/P5040DS_NAND_defconfig | 1 - configs/P5040DS_SDCARD_defconfig | 1 - configs/P5040DS_SPIFLASH_defconfig | 1 - configs/P5040DS_defconfig | 1 - configs/T1024RDB_NAND_defconfig | 1 - configs/T1024RDB_SDCARD_defconfig | 1 - configs/T1024RDB_SPIFLASH_defconfig | 1 - configs/T1024RDB_defconfig | 1 - configs/T1042D4RDB_NAND_defconfig | 1 - configs/T1042D4RDB_SDCARD_defconfig | 1 - configs/T1042D4RDB_SPIFLASH_defconfig | 1 - configs/T1042D4RDB_defconfig | 1 - configs/T2080QDS_NAND_defconfig | 1 - configs/T2080QDS_SDCARD_defconfig | 1 - configs/T2080QDS_SECURE_BOOT_defconfig | 1 - configs/T2080QDS_SPIFLASH_defconfig | 1 - configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 1 - configs/T2080QDS_defconfig | 1 - configs/T2080RDB_NAND_defconfig | 1 - configs/T2080RDB_SDCARD_defconfig | 1 - configs/T2080RDB_SPIFLASH_defconfig | 1 - configs/T2080RDB_defconfig | 1 - configs/T2080RDB_revD_NAND_defconfig | 1 - configs/T2080RDB_revD_SDCARD_defconfig | 1 - configs/T2080RDB_revD_SPIFLASH_defconfig | 1 - configs/T2080RDB_revD_defconfig | 1 - configs/T4240RDB_SDCARD_defconfig | 1 - configs/T4240RDB_defconfig | 1 - configs/kmcent2_defconfig | 1 - include/configs/kmcent2.h | 1 - 43 files changed, 17 insertions(+), 51 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index b6881bf1ff39..df7525d843c2 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -101,6 +101,7 @@ config TARGET_P2041RDB bool "Support P2041RDB" select ARCH_P2041 select BOARD_LATE_INIT if CHAIN_OF_TRUST + select FSL_CORENET select PHYS_64BIT imply CMD_SATA imply FSL_SATA @@ -180,6 +181,7 @@ config TARGET_KMP204X config TARGET_KMCENT2 bool "Support kmcent2" select VENDOR_KM + select FSL_CORENET
endchoice
@@ -187,6 +189,7 @@ config ARCH_B4420 bool select E500MC select E6500 + select FSL_CORENET select FSL_LAW select HETROGENOUS_CLUSTERS select SYS_FSL_DDR_VER_47 @@ -215,6 +218,7 @@ config ARCH_B4860 bool select E500MC select E6500 + select FSL_CORENET select FSL_LAW select HETROGENOUS_CLUSTERS select SYS_FSL_DDR_VER_47 @@ -554,6 +558,7 @@ config ARCH_P3041 bool select BACKSIDE_L2_CACHE select E500MC + select FSL_CORENET select FSL_LAW select SYS_CACHE_SHIFT_6 select SYS_FSL_DDR_VER_44 @@ -585,6 +590,7 @@ config ARCH_P4080 bool select BACKSIDE_L2_CACHE select E500MC + select FSL_CORENET select FSL_LAW select SYS_CACHE_SHIFT_6 select SYS_FSL_DDR_VER_44 @@ -625,6 +631,7 @@ config ARCH_P5040 bool select BACKSIDE_L2_CACHE select E500MC + select FSL_CORENET select FSL_LAW select SYS_CACHE_SHIFT_6 select SYS_FSL_DDR_VER_44 @@ -657,6 +664,7 @@ config ARCH_T1024 select BACKSIDE_L2_CACHE select E500MC select E5500 + select FSL_CORENET select FSL_LAW select SYS_CACHE_SHIFT_6 select SYS_FSL_DDR_VER_50 @@ -682,6 +690,7 @@ config ARCH_T1040 select BACKSIDE_L2_CACHE select E500MC select E5500 + select FSL_CORENET select FSL_LAW select SYS_CACHE_SHIFT_6 select SYS_FSL_DDR_VER_50 @@ -707,6 +716,7 @@ config ARCH_T1042 select BACKSIDE_L2_CACHE select E500MC select E5500 + select FSL_CORENET select FSL_LAW select SYS_CACHE_SHIFT_6 select SYS_FSL_DDR_VER_50 @@ -731,6 +741,7 @@ config ARCH_T2080 bool select E500MC select E6500 + select FSL_CORENET select FSL_LAW select SYS_CACHE_SHIFT_6 select SYS_FSL_DDR_VER_47 @@ -761,6 +772,7 @@ config ARCH_T4240 bool select E500MC select E6500 + select FSL_CORENET select FSL_LAW select SYS_CACHE_SHIFT_6 select SYS_FSL_DDR_VER_47 @@ -1221,6 +1233,10 @@ config SYS_BOOK3E_HV bool "Category E.HV is supported" depends on BOOKE
+config FSL_CORENET + bool + select SYS_FSL_CPC + config SYS_CPC_REINIT_F bool help @@ -1228,7 +1244,7 @@ config SYS_CPC_REINIT_F required to be re-initialized.
config SYS_FSL_CPC - bool "Corenet Platform Cache support" + bool
config SYS_CACHE_STASHING bool "Enable cache stashing" diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 1dcbe0670b62..169c91ca9e4f 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -74,7 +74,6 @@ #define CONFIG_SYS_FSL_SRIO_MSG_UNIT_NUM 2
#elif defined(CONFIG_ARCH_P2041) /* also supports P2040 */ -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_NUM_CC_PLLS 2 #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 5 @@ -91,7 +90,6 @@ #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xf0000000
#elif defined(CONFIG_ARCH_P3041) -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_NUM_CC_PLLS 2 #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 5 @@ -108,7 +106,6 @@ #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xf0000000
#elif defined(CONFIG_ARCH_P4080) /* also supports P4040 */ -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_NUM_CC_PLLS 4 #define CONFIG_SYS_NUM_FMAN 2 #define CONFIG_SYS_NUM_FM1_DTSEC 4 @@ -126,7 +123,6 @@ #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xff000000
#elif defined(CONFIG_ARCH_P5040) -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_NUM_CC_PLLS 3 #define CONFIG_SYS_NUM_FMAN 2 #define CONFIG_SYS_NUM_FM1_DTSEC 5 @@ -160,7 +156,6 @@ #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2"
#elif defined(CONFIG_ARCH_T4240) -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_CORES_PER_CLUSTER 4 #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ #ifdef CONFIG_ARCH_T4240 @@ -196,7 +191,6 @@ #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY
#elif defined(CONFIG_ARCH_B4860) || defined(CONFIG_ARCH_B4420) -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ #define CONFIG_SYS_FSL_SRDS_1 #define CONFIG_SYS_FSL_SRDS_2 @@ -231,7 +225,6 @@ #endif
#elif defined(CONFIG_ARCH_T1040) || defined(CONFIG_ARCH_T1042) -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_CORES_PER_CLUSTER 1 #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ #define CONFIG_SYS_FSL_NUM_CC_PLLS 2 @@ -256,7 +249,6 @@ #define QE_NUM_OF_SNUM 28
#elif defined(CONFIG_ARCH_T1024) -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_CORES_PER_CLUSTER 1 #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ #define CONFIG_SYS_FSL_NUM_CC_PLL 2 @@ -281,7 +273,6 @@ #define QE_NUM_OF_SNUM 28
#elif defined(CONFIG_ARCH_T2080) -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_CORES_PER_CLUSTER 4 #define CONFIG_SYS_FSL_NUM_CC_PLLS 2 #define CONFIG_SYS_FSL_QMAN_V3 diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 1540e90a1ff3..da15a1cdb56e 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -9,7 +9,6 @@ CONFIG_TARGET_P2041RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index c1c249ddc17b..96be038967d8 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -9,7 +9,6 @@ CONFIG_TARGET_P2041RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index 32761cd8990d..91f0ac56981b 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -10,7 +10,6 @@ CONFIG_TARGET_P2041RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index 312396c8eacb..78398207e5ba 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -10,7 +10,6 @@ CONFIG_TARGET_P2041RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index ea76795c38fb..dd399466728a 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -9,7 +9,6 @@ CONFIG_TARGET_P3041DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index fa49232d341b..bff11680216a 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -9,7 +9,6 @@ CONFIG_TARGET_P3041DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index 145f3260a905..a0b55b0bb95d 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -10,7 +10,6 @@ CONFIG_TARGET_P3041DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index 679887bd4e43..2eb1f7f951b3 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -10,7 +10,6 @@ CONFIG_TARGET_P3041DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index c9313ede668e..35945812a7c8 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -9,7 +9,6 @@ CONFIG_TARGET_P4080DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index ca85b0c45583..0d27e49c8ddb 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -10,7 +10,6 @@ CONFIG_TARGET_P4080DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index 4f51df3645d5..ef75108eb977 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -10,7 +10,6 @@ CONFIG_TARGET_P4080DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index 0bc8fd995e9c..cf2d5de9547c 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -9,7 +9,6 @@ CONFIG_TARGET_P5040DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index 412fcb22cba8..81f04aecf22a 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -9,7 +9,6 @@ CONFIG_TARGET_P5040DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index 7a1a72fb5d8d..fd28f3d8c775 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -10,7 +10,6 @@ CONFIG_TARGET_P5040DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index f808516fdb07..5933485c65b1 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -10,7 +10,6 @@ CONFIG_TARGET_P5040DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 683a114551f2..1140bc0aecbf 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -14,7 +14,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T1024RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index d954574574b2..05c43311b1d8 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -15,7 +15,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T1024RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PCIE1=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 769de718508a..8c82ee8afa22 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -17,7 +17,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T1024RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PCIE1=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index aaadb88ebdf4..700bbd98af99 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -10,7 +10,6 @@ CONFIG_TARGET_T1024RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 8f227294fd51..200536a7fb0d 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -13,7 +13,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T1042D4RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 7b502a9bc4e1..281cc7169b9c 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -14,7 +14,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T1042D4RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PCIE1=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 42659cd1287d..c7b337a66813 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -16,7 +16,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T1042D4RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PCIE1=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 48a734d0bac9..4983a5223183 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -9,7 +9,6 @@ CONFIG_TARGET_T1042D4RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index dca3b3eb87ec..30669d88e84c 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -13,7 +13,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 192f7b729de4..17629f13498b 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -14,7 +14,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PCIE1=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index 0023ffc2af4f..4c62d9316d21 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -7,7 +7,6 @@ CONFIG_TARGET_T2080QDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_NXP_ESBC=y CONFIG_BOOTSCRIPT_HDR_ADDR=0xee020000 diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 81c8e3fc8796..f68c87411e7b 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -16,7 +16,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PCIE1=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index 16563ea8afce..ef29f474c94f 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -8,7 +8,6 @@ CONFIG_TARGET_T2080QDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SRIO_PCIE_BOOT_SLAVE=y CONFIG_PCIE1=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index b106f0c1d334..62263b2fd4da 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -9,7 +9,6 @@ CONFIG_TARGET_T2080QDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 143b23015ebf..a1db4a4bf8fa 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -13,7 +13,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 488b7d28c924..6e9c70822221 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -14,7 +14,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PCIE1=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 3c11b130f5e4..719f022e8b07 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -16,7 +16,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PCIE1=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index b4ddc46cf860..1117c015eeac 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -9,7 +9,6 @@ CONFIG_TARGET_T2080RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/T2080RDB_revD_NAND_defconfig b/configs/T2080RDB_revD_NAND_defconfig index 1f32cf4284aa..10991e196469 100644 --- a/configs/T2080RDB_revD_NAND_defconfig +++ b/configs/T2080RDB_revD_NAND_defconfig @@ -13,7 +13,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y diff --git a/configs/T2080RDB_revD_SDCARD_defconfig b/configs/T2080RDB_revD_SDCARD_defconfig index 3aa70a24eaa5..0aa715dcac36 100644 --- a/configs/T2080RDB_revD_SDCARD_defconfig +++ b/configs/T2080RDB_revD_SDCARD_defconfig @@ -14,7 +14,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_T2080RDB_REV_D=y diff --git a/configs/T2080RDB_revD_SPIFLASH_defconfig b/configs/T2080RDB_revD_SPIFLASH_defconfig index 8f3f1f1c51d5..07114a07c20b 100644 --- a/configs/T2080RDB_revD_SPIFLASH_defconfig +++ b/configs/T2080RDB_revD_SPIFLASH_defconfig @@ -16,7 +16,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_T2080RDB_REV_D=y diff --git a/configs/T2080RDB_revD_defconfig b/configs/T2080RDB_revD_defconfig index 25f001e77b85..99b9c7931772 100644 --- a/configs/T2080RDB_revD_defconfig +++ b/configs/T2080RDB_revD_defconfig @@ -9,7 +9,6 @@ CONFIG_TARGET_T2080RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_T2080RDB_REV_D=y CONFIG_PCIE1=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index f0d426866ae1..df3b5f3bc6fb 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -14,7 +14,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T4240RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PCIE1=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 9c7a4b2c7c99..dc73dcdc1df6 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -9,7 +9,6 @@ CONFIG_TARGET_T4240RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y CONFIG_PCIE1=y CONFIG_PCIE2=y diff --git a/configs/kmcent2_defconfig b/configs/kmcent2_defconfig index 08b174dd323e..dcc0b2987d1b 100644 --- a/configs/kmcent2_defconfig +++ b/configs/kmcent2_defconfig @@ -12,7 +12,6 @@ CONFIG_TARGET_KMCENT2=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_BOOK3E_HV=y -CONFIG_SYS_FSL_CPC=y CONFIG_SYS_CACHE_STASHING=y # CONFIG_DEEP_SLEEP is not set CONFIG_PCIE1=y diff --git a/include/configs/kmcent2.h b/include/configs/kmcent2.h index 348133c2c70d..589ba615dd6d 100644 --- a/include/configs/kmcent2.h +++ b/include/configs/kmcent2.h @@ -133,7 +133,6 @@ #define KM_I2C_DEBLOCK_SDA 21
/* High Level Configuration Options */ -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */
#define CONFIG_RESET_VECTOR_ADDRESS 0xebfffffc
This converts the following to Kconfig: CONFIG_SYS_FSL_CCSR_GUR_BE CONFIG_SYS_FSL_CCSR_SCFG_BE CONFIG_SYS_FSL_ESDHC_BE CONFIG_SYS_FSL_IFC_BE CONFIG_SYS_FSL_PEX_LUT_BE CONFIG_SYS_FSL_CCSR_GUR_LE CONFIG_SYS_FSL_CCSR_SCFG_LE CONFIG_SYS_FSL_ESDHC_LE CONFIG_SYS_FSL_IFC_LE CONFIG_SYS_FSL_PEX_LUT_LE
Signed-off-by: Tom Rini trini@konsulko.com --- README | 6 ---- arch/Kconfig.nxp | 6 ++++ arch/arm/cpu/armv7/ls102xa/Kconfig | 2 ++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 34 +++++++++++++++++++ .../include/asm/arch-fsl-layerscape/config.h | 34 ------------------- arch/arm/include/asm/arch-ls102xa/config.h | 2 -- arch/powerpc/Kconfig | 1 + arch/powerpc/include/asm/config_mpc85xx.h | 3 -- 8 files changed, 43 insertions(+), 45 deletions(-)
diff --git a/README b/README index 20bfe4f17d08..3fe6d02d1ffd 100644 --- a/README +++ b/README @@ -417,12 +417,6 @@ The following options need to be configured: Board config to use DDR3L. It can be enabled for SoCs with DDR3L controllers.
- CONFIG_SYS_FSL_IFC_BE - Defines the IFC controller register space as Big Endian - - CONFIG_SYS_FSL_IFC_LE - Defines the IFC controller register space as Little Endian - CONFIG_SYS_FSL_IFC_CLK_DIV Defines divider of platform clock(clock input to IFC controller).
diff --git a/arch/Kconfig.nxp b/arch/Kconfig.nxp index d3ebbff43be1..a96245c37230 100644 --- a/arch/Kconfig.nxp +++ b/arch/Kconfig.nxp @@ -227,6 +227,12 @@ config VOL_MONITOR_ISL68233_SET
endif
+config SYS_FSL_ESDHC_BE + bool + +config SYS_FSL_IFC_BE + bool + config FSL_QIXIS bool "Enable QIXIS support" depends on PPC || ARCH_LS1021A || FSL_LSCH2 || FSL_LSCH3 diff --git a/arch/arm/cpu/armv7/ls102xa/Kconfig b/arch/arm/cpu/armv7/ls102xa/Kconfig index a901360fa7d8..e75a895e0086 100644 --- a/arch/arm/cpu/armv7/ls102xa/Kconfig +++ b/arch/arm/cpu/armv7/ls102xa/Kconfig @@ -3,6 +3,7 @@ config ARCH_LS1021A select FSL_IFC if !QSPI_BOOT && !SD_BOOT_QSPI select SYS_FSL_DDR_BE if SYS_FSL_DDR select SYS_FSL_DDR_VER_50 if SYS_FSL_DDR + select SYS_FSL_IFC_BE select SYS_FSL_ERRATUM_A008378 select SYS_FSL_ERRATUM_A008407 select SYS_FSL_ERRATUM_A008850 if SYS_FSL_DDR @@ -12,6 +13,7 @@ config ARCH_LS1021A select SYS_FSL_ERRATUM_A009798 if USB select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010315 + select SYS_FSL_ESDHC_BE select SYS_FSL_HAS_CCI400 select SYS_FSL_HAS_DDR3 if SYS_FSL_DDR select SYS_FSL_HAS_DDR4 if SYS_FSL_DDR diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 602b624dca52..1f86070b8a2c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -323,6 +323,11 @@ config ARCH_LX2160A config FSL_LSCH2 bool select SKIP_LOWLEVEL_INIT + select SYS_FSL_CCSR_GUR_BE + select SYS_FSL_CCSR_SCFG_BE + select SYS_FSL_ESDHC_BE + select SYS_FSL_IFC_BE + select SYS_FSL_PEX_LUT_BE select SYS_FSL_HAS_CCI400 select SYS_FSL_HAS_SEC select SYS_FSL_SEC_COMPAT_5 @@ -330,11 +335,40 @@ config FSL_LSCH2
config FSL_LSCH3 select ARCH_MISC_INIT + select SYS_FSL_CCSR_GUR_LE + select SYS_FSL_CCSR_SCFG_LE + select SYS_FSL_ESDHC_LE + select SYS_FSL_IFC_LE + select SYS_FSL_PEX_LUT_LE bool
config NXP_LSCH3_2 bool
+config SYS_FSL_CCSR_GUR_BE + bool + +config SYS_FSL_CCSR_SCFG_BE + bool + +config SYS_FSL_PEX_LUT_BE + bool + +config SYS_FSL_CCSR_GUR_LE + bool + +config SYS_FSL_CCSR_SCFG_LE + bool + +config SYS_FSL_ESDHC_LE + bool + +config SYS_FSL_IFC_LE + bool + +config SYS_FSL_PEX_LUT_LE + bool + menu "Layerscape architecture" depends on FSL_LSCH2 || FSL_LSCH3
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 9aee971b7260..f6710d0b0e1e 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -40,12 +40,6 @@ #define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
-#define CONFIG_SYS_FSL_CCSR_GUR_LE -#define CONFIG_SYS_FSL_CCSR_SCFG_LE -#define CONFIG_SYS_FSL_ESDHC_LE -#define CONFIG_SYS_FSL_IFC_LE -#define CONFIG_SYS_FSL_PEX_LUT_LE - #define CONFIG_SYS_MEMAC_LITTLE_ENDIAN
/* Generic Interrupt Controller Definitions */ @@ -56,7 +50,6 @@ #define SMMU_BASE 0x05000000 /* GR0 Base */
/* DCFG - GUR */ -#define CONFIG_SYS_FSL_CCSR_GUR_LE
/* Cache Coherent Interconnect */ #define CCI_MN_BASE 0x04000000 @@ -141,16 +134,9 @@ #define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
/* DCFG - GUR */ -#define CONFIG_SYS_FSL_CCSR_GUR_LE #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 #define CONFIG_SYS_FSL_OCRAM_BASE 0x18000000 /* initial RAM */ #define SYS_FSL_OCRAM_SPACE_SIZE 0x00200000 /* 2M space */ @@ -179,11 +165,6 @@ #define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
-#define CONFIG_SYS_FSL_CCSR_GUR_LE -#define CONFIG_SYS_FSL_CCSR_SCFG_LE -#define CONFIG_SYS_FSL_ESDHC_LE -#define CONFIG_SYS_FSL_PEX_LUT_LE - #define CONFIG_SYS_MEMAC_LITTLE_ENDIAN
/* Generic Interrupt Controller Definitions */ @@ -194,7 +175,6 @@ #define SMMU_BASE 0x05000000 /* GR0 Base */
@@ -234,18 +214,12 @@ #define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
/* SEC */ #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1
#elif defined(CONFIG_FSL_LSCH2) #define CONFIG_SYS_FSL_OCRAM_BASE 0x10000000 /* initial RAM */ @@ -255,12 +229,8 @@ #define DCSR_DCFG_SBEESR2 0x20140534 #define DCSR_DCFG_MBEESR2 0x20140544
-#define CONFIG_SYS_FSL_CCSR_SCFG_BE -#define CONFIG_SYS_FSL_ESDHC_BE #define CONFIG_SYS_FSL_WDOG_BE #define CONFIG_SYS_FSL_DSPI_BE -#define CONFIG_SYS_FSL_CCSR_GUR_BE -#define CONFIG_SYS_FSL_PEX_LUT_BE
/* SoC related */ #ifdef CONFIG_ARCH_LS1043A @@ -275,8 +245,6 @@ #define MAX_QE_RISC 1 #define QE_NUM_OF_SNUM 28
-#define CONFIG_SYS_FSL_IFC_BE - /* SMMU Defintions */ #define SMMU_BASE 0x09000000
@@ -323,8 +291,6 @@ #define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index e5f61ea4a6ee..868456f1f139 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -79,8 +79,6 @@ #define CONFIG_MAX_MEM_MAPPED ((phys_size_t)2 << 30) #endif
-#define CONFIG_SYS_FSL_IFC_BE -#define CONFIG_SYS_FSL_ESDHC_BE #define CONFIG_SYS_FSL_WDOG_BE #define CONFIG_SYS_FSL_DSPI_BE
diff --git a/arch/powerpc/Kconfig b/arch/powerpc/Kconfig index 737bdd8edb41..2cb5dae73657 100644 --- a/arch/powerpc/Kconfig +++ b/arch/powerpc/Kconfig @@ -20,6 +20,7 @@ config MPC85xx select CREATE_ARCH_SYMLINK select SYS_FSL_DDR select SYS_FSL_DDR_BE + select SYS_FSL_IFC_BE select BINMAN if OF_SEPARATE imply CMD_HASH imply CMD_IRQ diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 169c91ca9e4f..d9909f560bca 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -16,9 +16,6 @@
#include <fsl_ddrc_version.h>
-/* IP endianness */ -#define CONFIG_SYS_FSL_IFC_BE - #if defined(CONFIG_ARCH_MPC8548) #define CONFIG_SYS_FSL_SRIO_MAX_PORTS 1 #define CONFIG_SYS_FSL_SRIO_OB_WIN_NUM 9
This converts the following to Kconfig: CONFIG_FSL_MEMAC CONFIG_SYS_MEMAC_LITTLE_ENDIAN
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/arch-fsl-layerscape/config.h | 10 ---------- configs/ls1088aqds_defconfig | 2 ++ configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 2 ++ configs/ls1088aqds_qspi_defconfig | 2 ++ configs/ls1088aqds_sdcard_ifc_defconfig | 2 ++ configs/ls1088aqds_sdcard_qspi_defconfig | 2 ++ configs/ls1088aqds_tfa_defconfig | 2 ++ configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 2 ++ configs/ls1088ardb_qspi_defconfig | 2 ++ configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 2 ++ configs/ls1088ardb_sdcard_qspi_defconfig | 2 ++ configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 2 ++ configs/ls1088ardb_tfa_defconfig | 2 ++ configs/ls2080aqds_SECURE_BOOT_defconfig | 2 ++ configs/ls2080aqds_defconfig | 2 ++ configs/ls2080aqds_nand_defconfig | 2 ++ configs/ls2080aqds_qspi_defconfig | 2 ++ configs/ls2080aqds_sdcard_defconfig | 2 ++ configs/ls2080ardb_SECURE_BOOT_defconfig | 2 ++ configs/ls2080ardb_defconfig | 2 ++ configs/ls2080ardb_nand_defconfig | 2 ++ configs/ls2081ardb_defconfig | 2 ++ configs/ls2088aqds_tfa_defconfig | 2 ++ configs/ls2088ardb_qspi_SECURE_BOOT_defconfig | 2 ++ configs/ls2088ardb_qspi_defconfig | 2 ++ configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 2 ++ configs/ls2088ardb_tfa_defconfig | 2 ++ configs/lx2160aqds_tfa_SECURE_BOOT_defconfig | 2 ++ configs/lx2160aqds_tfa_defconfig | 2 ++ configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 2 ++ configs/lx2160ardb_tfa_defconfig | 2 ++ configs/lx2160ardb_tfa_stmm_defconfig | 2 ++ configs/lx2162aqds_tfa_SECURE_BOOT_defconfig | 2 ++ configs/lx2162aqds_tfa_defconfig | 2 ++ configs/lx2162aqds_tfa_verified_boot_defconfig | 2 ++ configs/ten64_tfa_defconfig | 1 + drivers/net/Kconfig | 1 + drivers/net/fm/Makefile | 1 - drivers/net/phy/Kconfig | 7 +++++++ include/configs/ls1088aqds.h | 3 --- include/configs/ls1088ardb.h | 2 -- include/configs/ls2080aqds.h | 3 --- include/configs/ls2080ardb.h | 2 -- include/configs/lx2160a_common.h | 2 -- 44 files changed, 77 insertions(+), 23 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index f6710d0b0e1e..76e07f385b3d 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -40,8 +40,6 @@ #define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
-#define CONFIG_SYS_MEMAC_LITTLE_ENDIAN - /* Generic Interrupt Controller Definitions */ #define GICD_BASE 0x06000000 #define GICR_BASE 0x06100000 @@ -49,8 +47,6 @@ /* SMMU Defintions */ #define SMMU_BASE 0x05000000 /* GR0 Base */
-/* DCFG - GUR */ - /* Cache Coherent Interconnect */ #define CCI_MN_BASE 0x04000000 #define CCI_MN_RNF_NODEID_LIST 0x180 @@ -134,8 +130,6 @@ #define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
-#define CONFIG_SYS_MEMAC_LITTLE_ENDIAN - /* DCFG - GUR */ #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 #define CONFIG_SYS_FSL_OCRAM_BASE 0x18000000 /* initial RAM */ @@ -165,8 +159,6 @@ #define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
-#define CONFIG_SYS_MEMAC_LITTLE_ENDIAN - /* Generic Interrupt Controller Definitions */ #define GICD_BASE 0x06000000 #define GICR_BASE 0x06200000 @@ -214,8 +206,6 @@ #define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
-#define CONFIG_SYS_MEMAC_LITTLE_ENDIAN - /* SEC */ #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1
diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index bd34f8dff40b..aca271aa9f5f 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -89,6 +89,8 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_REALTEK=y CONFIG_PHY_TERANETICS=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig index 3af10a0e0627..9bed029a349f 100644 --- a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig @@ -81,6 +81,8 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_REALTEK=y CONFIG_PHY_TERANETICS=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index 55a5389272a4..4a56e43e2bf5 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -84,6 +84,8 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_REALTEK=y CONFIG_PHY_TERANETICS=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index 3aa20d35af03..d203fb9b13d1 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -108,6 +108,8 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_REALTEK=y CONFIG_PHY_TERANETICS=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index fa1f71d77c1f..1bd83af10189 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -103,6 +103,8 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_REALTEK=y CONFIG_PHY_TERANETICS=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index 91899d2ed88b..c59de47ab63c 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -103,6 +103,8 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_REALTEK=y CONFIG_PHY_TERANETICS=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_DM_MDIO_MUX=y diff --git a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig index b4cae480e175..aa9bc8a46c36 100644 --- a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig @@ -78,6 +78,8 @@ CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index 452ee839b87b..2459212c36f5 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -81,6 +81,8 @@ CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y diff --git a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig index e36512e62d55..fc222b5dd2c3 100644 --- a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig @@ -100,6 +100,8 @@ CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index 2f81a1343c17..eba206dd7bba 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -100,6 +100,8 @@ CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y diff --git a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig index b5f556dc2035..347cc604105d 100644 --- a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig @@ -77,6 +77,8 @@ CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y diff --git a/configs/ls1088ardb_tfa_defconfig b/configs/ls1088ardb_tfa_defconfig index 3af7828887cd..362b4bea2b53 100644 --- a/configs/ls1088ardb_tfa_defconfig +++ b/configs/ls1088ardb_tfa_defconfig @@ -83,6 +83,8 @@ CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index 965863dbd391..a4143871cb24 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -81,6 +81,8 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_REALTEK=y CONFIG_PHY_TERANETICS=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index 3e0da6884515..91b52265851a 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -84,6 +84,8 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_REALTEK=y CONFIG_PHY_TERANETICS=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 1d841af6b0c6..7d3cce0751b0 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -97,6 +97,8 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_REALTEK=y CONFIG_PHY_TERANETICS=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 302de3239888..6bb37819c17e 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -77,6 +77,8 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_REALTEK=y CONFIG_PHY_TERANETICS=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index e97284222dcd..e2710b8ec788 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -91,6 +91,8 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_REALTEK=y CONFIG_PHY_TERANETICS=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 16367fc45384..1d0aea08b4a8 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -80,6 +80,8 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y CONFIG_CORTINA_FW_ADDR=0x580980000 +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME_PCI=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index 82ad9b27b06e..ec6869cf5477 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -83,6 +83,8 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y CONFIG_CORTINA_FW_ADDR=0x580980000 +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME_PCI=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 189a4e0683cf..fa929ac4dab0 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -102,6 +102,8 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y CONFIG_CORTINA_FW_ADDR=0x980000 +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME_PCI=y diff --git a/configs/ls2081ardb_defconfig b/configs/ls2081ardb_defconfig index fb7faa46d2cb..e6e6fe6efc68 100644 --- a/configs/ls2081ardb_defconfig +++ b/configs/ls2081ardb_defconfig @@ -72,6 +72,8 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y CONFIG_CORTINA_FW_ADDR=0x980000 +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME_PCI=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index 2eba6b69a7be..2a7cbd3a1bbe 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -95,6 +95,8 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_REALTEK=y CONFIG_PHY_TERANETICS=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_DM_MDIO_MUX=y diff --git a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig index b86f8164f0b8..5d9c48b13979 100644 --- a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig @@ -71,6 +71,8 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y CONFIG_CORTINA_FW_ADDR=0x980000 +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_E1000=y diff --git a/configs/ls2088ardb_qspi_defconfig b/configs/ls2088ardb_qspi_defconfig index 9e08552fb375..0628cc274d7a 100644 --- a/configs/ls2088ardb_qspi_defconfig +++ b/configs/ls2088ardb_qspi_defconfig @@ -78,6 +78,8 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y CONFIG_CORTINA_FW_ADDR=0x980000 +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_E1000=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index 0c58a6dd935c..5fb13460549a 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -86,6 +86,8 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_E1000=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index a7c703683773..bf9a016c7e6a 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -94,6 +94,8 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_E1000=y diff --git a/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig index b2bc71afa8ef..21c60524f4d6 100644 --- a/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig @@ -82,6 +82,8 @@ CONFIG_PHY_CORTINA=y CONFIG_SYS_CORTINA_NO_FW_UPLOAD=y CONFIG_PHY_REALTEK=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_DM_MDIO_MUX=y diff --git a/configs/lx2160aqds_tfa_defconfig b/configs/lx2160aqds_tfa_defconfig index 32e47c326e8f..62b214bc0b18 100644 --- a/configs/lx2160aqds_tfa_defconfig +++ b/configs/lx2160aqds_tfa_defconfig @@ -89,6 +89,8 @@ CONFIG_PHY_CORTINA=y CONFIG_SYS_CORTINA_NO_FW_UPLOAD=y CONFIG_PHY_REALTEK=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_DM_MDIO_MUX=y diff --git a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig index a758a4dca229..65e43bf74699 100644 --- a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig @@ -75,6 +75,8 @@ CONFIG_PHY_AQUANTIA=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_CORTINA=y CONFIG_SYS_CORTINA_NO_FW_UPLOAD=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_E1000=y diff --git a/configs/lx2160ardb_tfa_defconfig b/configs/lx2160ardb_tfa_defconfig index e6e794006cf6..8cdebc808e0e 100644 --- a/configs/lx2160ardb_tfa_defconfig +++ b/configs/lx2160ardb_tfa_defconfig @@ -84,6 +84,8 @@ CONFIG_PHY_AQUANTIA=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_CORTINA=y CONFIG_SYS_CORTINA_NO_FW_UPLOAD=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_E1000=y diff --git a/configs/lx2160ardb_tfa_stmm_defconfig b/configs/lx2160ardb_tfa_stmm_defconfig index bbdcb895d8e4..c7e9afe0a2dd 100644 --- a/configs/lx2160ardb_tfa_stmm_defconfig +++ b/configs/lx2160ardb_tfa_stmm_defconfig @@ -84,6 +84,8 @@ CONFIG_PHY_AQUANTIA=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_CORTINA=y CONFIG_SYS_CORTINA_NO_FW_UPLOAD=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_E1000=y diff --git a/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig index bb81e56fed81..ca70f8b5cca1 100644 --- a/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig @@ -84,6 +84,8 @@ CONFIG_PHY_CORTINA=y CONFIG_SYS_CORTINA_NO_FW_UPLOAD=y CONFIG_PHY_REALTEK=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_DM_MDIO_MUX=y diff --git a/configs/lx2162aqds_tfa_defconfig b/configs/lx2162aqds_tfa_defconfig index 216ac8007420..68cdefb52e4e 100644 --- a/configs/lx2162aqds_tfa_defconfig +++ b/configs/lx2162aqds_tfa_defconfig @@ -92,6 +92,8 @@ CONFIG_PHY_CORTINA=y CONFIG_SYS_CORTINA_NO_FW_UPLOAD=y CONFIG_PHY_REALTEK=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_DM_MDIO_MUX=y diff --git a/configs/lx2162aqds_tfa_verified_boot_defconfig b/configs/lx2162aqds_tfa_verified_boot_defconfig index b7a4238e92ea..ee3134e80c90 100644 --- a/configs/lx2162aqds_tfa_verified_boot_defconfig +++ b/configs/lx2162aqds_tfa_verified_boot_defconfig @@ -93,6 +93,8 @@ CONFIG_PHY_CORTINA=y CONFIG_SYS_CORTINA_NO_FW_UPLOAD=y CONFIG_PHY_REALTEK=y CONFIG_PHY_VITESSE=y +CONFIG_FSL_MEMAC=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_DM_MDIO_MUX=y diff --git a/configs/ten64_tfa_defconfig b/configs/ten64_tfa_defconfig index 4bbee30b0642..dad6c2d9318d 100644 --- a/configs/ten64_tfa_defconfig +++ b/configs/ten64_tfa_defconfig @@ -71,6 +71,7 @@ CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_MTD=y CONFIG_PHYLIB=y CONFIG_PHY_VITESSE=y +CONFIG_SYS_MEMAC_LITTLE_ENDIAN=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_E1000=y diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 637aca4d7e99..4f2f192f19c2 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -375,6 +375,7 @@ config SYS_QE_FMAN_FW_LENGTH
config SYS_FMAN_V3 bool + select FSL_MEMAC help SoC has FMan v3 with mEMAC
diff --git a/drivers/net/fm/Makefile b/drivers/net/fm/Makefile index ae3841217663..5a7d3037af40 100644 --- a/drivers/net/fm/Makefile +++ b/drivers/net/fm/Makefile @@ -11,7 +11,6 @@ obj-y += tgec.o obj-y += tgec_phy.o
# Soc have FMAN v3 with mEMAC -obj-$(CONFIG_SYS_FMAN_V3) += memac_phy.o obj-$(CONFIG_SYS_FMAN_V3) += memac.o
# SoC specific SERDES support diff --git a/drivers/net/phy/Kconfig b/drivers/net/phy/Kconfig index 33a4b6f30db0..52ce08b3b384 100644 --- a/drivers/net/phy/Kconfig +++ b/drivers/net/phy/Kconfig @@ -345,6 +345,13 @@ config PHY_NCSI
endif #PHYLIB
+config FSL_MEMAC + bool "NXP mEMAC PHY support" + +config SYS_MEMAC_LITTLE_ENDIAN + bool "mEMAC is access in little endian mode" + depends on FSL_MEMAC || FSL_LS_MDIO + config PHY_RESET_DELAY int "Extra delay after reset before MII register access" default 0 diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index 6db0ba5f5ae2..747ee9d4428a 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -297,8 +297,6 @@ #endif #endif
-#define CONFIG_FSL_MEMAC - #define COMMON_ENV \ "kernelheader_addr_r=0x80200000\0" \ "fdtheader_addr_r=0x80100000\0" \ @@ -467,7 +465,6 @@ #endif
#ifdef CONFIG_FSL_MC_ENET -#define CONFIG_FSL_MEMAC #define RGMII_PHY1_ADDR 0x1 #define RGMII_PHY2_ADDR 0x2 #define SGMII_CARD_PORT1_PHY_ADDR 0x1C diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h index c3e87ed24db9..3e829ea8659a 100644 --- a/include/configs/ls1088ardb.h +++ b/include/configs/ls1088ardb.h @@ -202,8 +202,6 @@ #define CONFIG_SYS_I2C_EEPROM_NXID #define CONFIG_SYS_EEPROM_BUS_NUM 0
-#define CONFIG_FSL_MEMAC - #ifndef SPL_NO_ENV /* Initial environment variables */ #ifdef CONFIG_TFABOOT diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index f6efda258c0e..6487397f6528 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -239,8 +239,6 @@ #define CONFIG_SYS_I2C_EEPROM_NXID #define CONFIG_SYS_EEPROM_BUS_NUM 0
-#define CONFIG_FSL_MEMAC - /* Initial environment variables */ #undef CONFIG_EXTRA_ENV_SETTINGS #ifdef CONFIG_NXP_ESBC @@ -385,7 +383,6 @@ #endif
#if defined(CONFIG_FSL_MC_ENET) -#define CONFIG_FSL_MEMAC #define SGMII_CARD_PORT1_PHY_ADDR 0x1C #define SGMII_CARD_PORT2_PHY_ADDR 0x1d #define SGMII_CARD_PORT3_PHY_ADDR 0x1E diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index c6b601de227a..87d07b765c6c 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -226,8 +226,6 @@ #define CONFIG_SYS_I2C_EEPROM_NXID #define CONFIG_SYS_EEPROM_BUS_NUM 0
-#define CONFIG_FSL_MEMAC - #define BOOT_TARGET_DEVICES(func) \ func(USB, usb, 0) \ func(MMC, mmc, 0) \ diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index b7543731691f..0f5b0444e70f 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -10,8 +10,6 @@ #include <asm/arch/config.h> #include <asm/arch/soc.h>
-#define CONFIG_FSL_MEMAC - #define CONFIG_SYS_FLASH_BASE 0x20000000
/* DDR */
This converts the following to Kconfig: CONFIG_SYS_FSL_CORES_PER_CLUSTER
As part of this, correct the dependencies on SYS_FSL_THREADS_PER_CORE.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/arch-fsl-layerscape/config.h | 1 - arch/powerpc/cpu/mpc85xx/Kconfig | 8 ++++++++ arch/powerpc/include/asm/config_mpc85xx.h | 6 ------ 3 files changed, 8 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 76e07f385b3d..1791b978704d 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -145,7 +145,6 @@ #define L1_CACHE_SHIFT 6 #define L1_CACHE_BYTES BIT(L1_CACHE_SHIFT) #endif -#define CONFIG_SYS_FSL_CORES_PER_CLUSTER 2 #define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1, 1, 1, 4, 4, 4, 4 } #define CONFIG_SYS_FSL_NUM_CC_PLLS 4
diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index df7525d843c2..a1704c211564 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -1120,8 +1120,16 @@ config SYS_FSL_NUM_LAWS Number of local access windows. This is fixed per SoC. If not sure, do not change.
+config SYS_FSL_CORES_PER_CLUSTER + int + depends on SYS_FSL_QORIQ_CHASSIS2 + default 4 if ARCH_B4860 || ARCH_T2080 || ARCH_T4240 + default 2 if ARCH_B4420 + default 1 if ARCH_T1024 || ARCH_T1040 || ARCH_T1042 + config SYS_FSL_THREADS_PER_CORE int + depends on SYS_FSL_QORIQ_CHASSIS2 default 2 if E6500 default 1
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index d9909f560bca..458c0a8d3653 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -153,7 +153,6 @@ #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2"
#elif defined(CONFIG_ARCH_T4240) -#define CONFIG_SYS_FSL_CORES_PER_CLUSTER 4 #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ #ifdef CONFIG_ARCH_T4240 #define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1, 4 } @@ -201,7 +200,6 @@ #define CONFIG_SYS_FSL_USB1_PHY_ENABLE
#ifdef CONFIG_ARCH_B4860 -#define CONFIG_SYS_FSL_CORES_PER_CLUSTER 4 #define CONFIG_MAX_DSP_CPUS 12 #define CONFIG_NUM_DSP_CPUS 6 #define CONFIG_SYS_FSL_SRDS_NUM_PLLS 2 @@ -215,14 +213,12 @@ #else #define CONFIG_MAX_DSP_CPUS 2 #define CONFIG_SYS_FSL_SRDS_NUM_PLLS 1 -#define CONFIG_SYS_FSL_CORES_PER_CLUSTER 2 #define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 4 } #define CONFIG_SYS_NUM_FM1_DTSEC 4 #define CONFIG_SYS_NUM_FM1_10GEC 0 #endif
#elif defined(CONFIG_ARCH_T1040) || defined(CONFIG_ARCH_T1042) -#define CONFIG_SYS_FSL_CORES_PER_CLUSTER 1 #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ #define CONFIG_SYS_FSL_NUM_CC_PLLS 2 #define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1, 1, 1 } @@ -246,7 +242,6 @@ #define QE_NUM_OF_SNUM 28
#elif defined(CONFIG_ARCH_T1024) -#define CONFIG_SYS_FSL_CORES_PER_CLUSTER 1 #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ #define CONFIG_SYS_FSL_NUM_CC_PLL 2 #define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1, 1, 1 } @@ -270,7 +265,6 @@ #define QE_NUM_OF_SNUM 28
#elif defined(CONFIG_ARCH_T2080) -#define CONFIG_SYS_FSL_CORES_PER_CLUSTER 4 #define CONFIG_SYS_FSL_NUM_CC_PLLS 2 #define CONFIG_SYS_FSL_QMAN_V3 #define CONFIG_SYS_NUM_FMAN 1
This converts the following to Kconfig: CONFIG_SYS_FSL_DDR_INTLV_256B
Signed-off-by: Tom Rini trini@konsulko.com --- README | 5 ----- configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080aqds_qspi_defconfig | 1 + configs/ls2080aqds_sdcard_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + configs/ls2081ardb_defconfig | 1 + configs/ls2088aqds_tfa_defconfig | 1 + configs/ls2088ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_qspi_defconfig | 1 + configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 1 + configs/lx2160aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160aqds_tfa_defconfig | 1 + configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160ardb_tfa_defconfig | 1 + configs/lx2160ardb_tfa_stmm_defconfig | 1 + configs/lx2162aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2162aqds_tfa_defconfig | 1 + configs/lx2162aqds_tfa_verified_boot_defconfig | 1 + drivers/ddr/fsl/Kconfig | 7 +++++++ include/configs/ls2080a_common.h | 2 -- include/configs/lx2160a_common.h | 1 - 26 files changed, 29 insertions(+), 8 deletions(-)
diff --git a/README b/README index 3fe6d02d1ffd..aae30ef9cb61 100644 --- a/README +++ b/README @@ -434,11 +434,6 @@ The following options need to be configured: same as CONFIG_SYS_DDR_SDRAM_BASE for all Power SoCs. But it could be different for ARM SoCs.
- CONFIG_SYS_FSL_DDR_INTLV_256B - DDR controller interleaving on 256-byte. This is a special - interleaving mode, handled by Dickens for Freescale layerscape - SoCs with ARM core. - CONFIG_SYS_FSL_DDR_MAIN_NUM_CTRLS Number of controllers used as main memory.
diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index a4143871cb24..afb4e48e7e85 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -56,6 +56,7 @@ CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index 91b52265851a..15dadeb4e420 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -59,6 +59,7 @@ CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 7d3cce0751b0..9fc1801c15da 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -79,6 +79,7 @@ CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_EARLY_INIT=y CONFIG_SYS_I2C_EEPROM_ADDR=0x57 diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 6bb37819c17e..d2dd95ea792d 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -60,6 +60,7 @@ CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_EARLY_INIT=y CONFIG_SYS_I2C_EEPROM_ADDR=0x57 diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index e2710b8ec788..e2e4cfdd9364 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -74,6 +74,7 @@ CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_EARLY_INIT=y CONFIG_SYS_I2C_EEPROM_ADDR=0x57 diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 1d0aea08b4a8..5378876f11b9 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -60,6 +60,7 @@ CONFIG_DDR_CLK_FREQ=133333333 CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index ec6869cf5477..6570a466e0c5 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -63,6 +63,7 @@ CONFIG_DDR_CLK_FREQ=133333333 CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index fa929ac4dab0..7c87f890c2c2 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -83,6 +83,7 @@ CONFIG_DDR_CLK_FREQ=133333333 CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y diff --git a/configs/ls2081ardb_defconfig b/configs/ls2081ardb_defconfig index e6e6fe6efc68..a426d6d48fb1 100644 --- a/configs/ls2081ardb_defconfig +++ b/configs/ls2081ardb_defconfig @@ -61,6 +61,7 @@ CONFIG_DDR_CLK_FREQ=133333333 CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_EARLY_INIT=y CONFIG_SYS_I2C_EEPROM_ADDR=0x57 diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index 2a7cbd3a1bbe..f082fa52bcc5 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -66,6 +66,7 @@ CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_MPC8XXX_GPIO=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y diff --git a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig index 5d9c48b13979..1972fc908f54 100644 --- a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig @@ -56,6 +56,7 @@ CONFIG_DDR_CLK_FREQ=133333333 CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_MPC8XXX_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_EARLY_INIT=y diff --git a/configs/ls2088ardb_qspi_defconfig b/configs/ls2088ardb_qspi_defconfig index 0628cc274d7a..dedc191edc06 100644 --- a/configs/ls2088ardb_qspi_defconfig +++ b/configs/ls2088ardb_qspi_defconfig @@ -63,6 +63,7 @@ CONFIG_DDR_CLK_FREQ=133333333 CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_MPC8XXX_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_EARLY_INIT=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index 5fb13460549a..1674a2ce0916 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -61,6 +61,7 @@ CONFIG_DDR_CLK_FREQ=133333333 CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_MPC8XXX_GPIO=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index bf9a016c7e6a..071db6b1d2e4 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -68,6 +68,7 @@ CONFIG_DDR_CLK_FREQ=133333333 CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_MPC8XXX_GPIO=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y diff --git a/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig index 21c60524f4d6..84aea7fb17cf 100644 --- a/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig @@ -61,6 +61,7 @@ CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_MPC8XXX_GPIO=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y diff --git a/configs/lx2160aqds_tfa_defconfig b/configs/lx2160aqds_tfa_defconfig index 62b214bc0b18..7fce30b3311e 100644 --- a/configs/lx2160aqds_tfa_defconfig +++ b/configs/lx2160aqds_tfa_defconfig @@ -68,6 +68,7 @@ CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_MPC8XXX_GPIO=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y diff --git a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig index 65e43bf74699..42efefa41630 100644 --- a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig @@ -59,6 +59,7 @@ CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_MPC8XXX_GPIO=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y diff --git a/configs/lx2160ardb_tfa_defconfig b/configs/lx2160ardb_tfa_defconfig index 8cdebc808e0e..85ee4ca84589 100644 --- a/configs/lx2160ardb_tfa_defconfig +++ b/configs/lx2160ardb_tfa_defconfig @@ -67,6 +67,7 @@ CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_MPC8XXX_GPIO=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y diff --git a/configs/lx2160ardb_tfa_stmm_defconfig b/configs/lx2160ardb_tfa_stmm_defconfig index c7e9afe0a2dd..547c8682e55c 100644 --- a/configs/lx2160ardb_tfa_stmm_defconfig +++ b/configs/lx2160ardb_tfa_stmm_defconfig @@ -67,6 +67,7 @@ CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_MPC8XXX_GPIO=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y diff --git a/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig index ca70f8b5cca1..421008489bdf 100644 --- a/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig @@ -63,6 +63,7 @@ CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_MPC8XXX_GPIO=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y diff --git a/configs/lx2162aqds_tfa_defconfig b/configs/lx2162aqds_tfa_defconfig index 68cdefb52e4e..dd1c0760987d 100644 --- a/configs/lx2162aqds_tfa_defconfig +++ b/configs/lx2162aqds_tfa_defconfig @@ -70,6 +70,7 @@ CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_MPC8XXX_GPIO=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y diff --git a/configs/lx2162aqds_tfa_verified_boot_defconfig b/configs/lx2162aqds_tfa_verified_boot_defconfig index ee3134e80c90..70faef837209 100644 --- a/configs/lx2162aqds_tfa_verified_boot_defconfig +++ b/configs/lx2162aqds_tfa_verified_boot_defconfig @@ -71,6 +71,7 @@ CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y +CONFIG_SYS_FSL_DDR_INTLV_256B=y CONFIG_MPC8XXX_GPIO=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y diff --git a/drivers/ddr/fsl/Kconfig b/drivers/ddr/fsl/Kconfig index d93ed8d2feb6..22400a9b8bab 100644 --- a/drivers/ddr/fsl/Kconfig +++ b/drivers/ddr/fsl/Kconfig @@ -182,6 +182,13 @@ config SYS_DDR_RAW_TIMING timing parameters are extracted from datasheet and hard-coded into header files or board specific files.
+config SYS_FSL_DDR_INTLV_256B + bool "Enforce 256-byte interleave" + help + DDR controller interleaving on 256-byte. This is a special + interleaving mode, handled by Dickens for Freescale layerscape SoCs + with ARM core. + endif
menu "PowerPC / M68K initial memory controller definitions (FLASH, SDRAM, etc)" diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 3e86d1bff215..ba5af6c34d34 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -16,8 +16,6 @@
/* Link Definitions */
-#define CONFIG_SYS_FSL_DDR_INTLV_256B /* force 256 byte interleaving */ - #define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000UL #define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 0f5b0444e70f..61870717e8e1 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -13,7 +13,6 @@ #define CONFIG_SYS_FLASH_BASE 0x20000000
/* DDR */ -#define CONFIG_SYS_FSL_DDR_INTLV_256B /* force 256 byte interleaving */ #define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000UL #define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0
Ramon Fried
