[U-Boot] [PATCH] mxs: Reset the EMI block on mx23
The real reason for memory instability was the fact that the EMI block was gated and not reset throughout the boards' operation. This patch resets the EMI block properly while also reverts the memory voltage bump. The memory stability issues were caused by the EMI not being reset properly and thus there is no longer need to run the memory at higher voltage than it ought to run at.
This partly reverts 8303ed128a55519f19c5f11087032d4bc4e0537a .
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
NOTE: Please apply _SEVERE_ testing!
diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c b/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c index f8392f6..20833f5 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c @@ -229,7 +229,7 @@ static void mx23_mem_setup_vddmem(void) struct mxs_power_regs *power_regs = (struct mxs_power_regs *)MXS_POWER_BASE;
- writel((0x12 << POWER_VDDMEMCTRL_TRG_OFFSET) | + writel((0x10 << POWER_VDDMEMCTRL_TRG_OFFSET) | POWER_VDDMEMCTRL_ENABLE_ILIMIT | POWER_VDDMEMCTRL_ENABLE_LINREG | POWER_VDDMEMCTRL_PULLDOWN_ACTIVE, @@ -237,13 +237,20 @@ static void mx23_mem_setup_vddmem(void)
early_delay(10000);
- writel((0x12 << POWER_VDDMEMCTRL_TRG_OFFSET) | + writel((0x10 << POWER_VDDMEMCTRL_TRG_OFFSET) | POWER_VDDMEMCTRL_ENABLE_LINREG, &power_regs->hw_power_vddmemctrl); }
static void mx23_mem_init(void) { + /* + * Reset/ungate the EMI block. This is essential, otherwise the system + * suffers from memory instability. This thing is mx23 specific and is + * no longer present on mx28. + */ + mxs_reset_block(MXS_EMI_BASE); + mx23_mem_setup_vddmem();
I did a test with and without the patch. *Without* this patch I see an error in memony but it takes some time to it to error out. With the patch, the error is mostly instantaneous:
=> mtest Pattern FFFFFFDD Writing... Reading... Mem error @ 0x40087F6C: found BFFDE002, expected FFFDE002
So it seems to make it worse; but I am not sure if something else is missing too.
-- Otavio Salvador O.S. Systems E-mail: otavio@ossystems.com.br http://www.ossystems.com.br Mobile: +55 53 9981-7854 http://projetos.ossystems.com.br
Otavio Salvador
