[U-Boot] [PATCH] treewide: Replace CONFIG_DM_SPI_FLASH with CONFIG_IS_ENABLED(DM_SPI_FLASH)
Perform the replacement to allow platforms use non-DM SPI flash access in SPL/TPL. This is thus far needed on platforms with size constraints.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Jagan Teki jagan@openedev.com Cc: Vignesh R vigneshr@ti.com --- cmd/sf.c | 4 ++-- drivers/mtd/spi/sf_probe.c | 2 +- drivers/net/fm/fm.c | 4 ++-- env/sf.c | 2 +- include/spi_flash.h | 2 +- 5 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/cmd/sf.c b/cmd/sf.c index 738ef0e46d..7e92a43b2c 100644 --- a/cmd/sf.c +++ b/cmd/sf.c @@ -84,7 +84,7 @@ static int do_spi_flash_probe(int argc, char * const argv[]) unsigned int speed = CONFIG_SF_DEFAULT_SPEED; unsigned int mode = CONFIG_SF_DEFAULT_MODE; char *endp; -#ifdef CONFIG_DM_SPI_FLASH +#if CONFIG_IS_ENABLED(DM_SPI_FLASH) struct udevice *new, *bus_dev; int ret; /* In DM mode defaults will be taken from DT */ @@ -119,7 +119,7 @@ static int do_spi_flash_probe(int argc, char * const argv[]) return -1; }
-#ifdef CONFIG_DM_SPI_FLASH +#if CONFIG_IS_ENABLED(DM_SPI_FLASH) /* Remove the old device, otherwise probe will just be a nop */ ret = spi_find_bus_and_cs(bus, cs, &bus_dev, &new); if (!ret) { diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 7f1378f494..4282d48f26 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -53,7 +53,7 @@ err_read_id: return ret; }
-#ifndef CONFIG_DM_SPI_FLASH +#if !CONFIG_IS_ENABLED(DM_SPI_FLASH) struct spi_flash *spi_flash_probe(unsigned int busnum, unsigned int cs, unsigned int max_hz, unsigned int spi_mode) { diff --git a/drivers/net/fm/fm.c b/drivers/net/fm/fm.c index e19d7777dc..6a5c9bbc9d 100644 --- a/drivers/net/fm/fm.c +++ b/drivers/net/fm/fm.c @@ -377,7 +377,7 @@ int fm_init_common(int index, struct ccsr_fman *reg) addr = malloc(CONFIG_SYS_QE_FMAN_FW_LENGTH); int ret = 0;
-#ifdef CONFIG_DM_SPI_FLASH +#if CONFIG_IS_ENABLED(DM_SPI_FLASH) struct udevice *new;
/* speed and mode will be read from DT */ @@ -464,7 +464,7 @@ int fm_init_common(int index, struct ccsr_fman *reg) void *addr = malloc(CONFIG_SYS_QE_FMAN_FW_LENGTH); int ret = 0;
/* speed and mode will be read from DT */ diff --git a/env/sf.c b/env/sf.c index b3dec82c35..ee639b90fc 100644 --- a/env/sf.c +++ b/env/sf.c @@ -52,7 +52,7 @@ static struct spi_flash *env_flash;
static int setup_flash_device(void) { -#ifdef CONFIG_DM_SPI_FLASH +#if CONFIG_IS_ENABLED(DM_SPI_FLASH) struct udevice *new; int ret;
diff --git a/include/spi_flash.h b/include/spi_flash.h index 7f691e8559..09f3896fb9 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -51,7 +51,7 @@ struct dm_spi_flash_ops { /* Access the serial operations for a device */ #define sf_get_ops(dev) ((struct dm_spi_flash_ops *)(dev)->driver->ops)
-#ifdef CONFIG_DM_SPI_FLASH +#if CONFIG_IS_ENABLED(DM_SPI_FLASH) /** * spi_flash_read_dm() - Read data from SPI flash *
I have a similar patch, but you beat me to it :)
Reviewed-by: Vignesh R vigneshr@ti.com
Regards Vignesh
- spi_flash_read_dm() - Read data from SPI flash
Except this one breaks a few platforms, so feel free to drop this one and send yours , or merge them into one.
I stumbled upon this issue when trying to build a non-DM SPL for imx with SPI flash access. This fixes the build.
Reviewed-by: Frieder Schrempf frieder.schrempf@kontron.de Tested-by: Frieder Schrempf frieder.schrempf@kontron.de
This patch breaks x86 at least, so NAK.
It seems, that there's still no solution for this upstream. I tried to build Marek's patch with a fixup on current master [1], but still the build breaks for some configurations [2].
Can someone have a look, how to fix the failing boards?
Thanks, Frieder
[1] https://github.com/fschrempf/u-boot/commits/non_dm_spi_flash_in_spl [2] https://travis-ci.org/fschrempf/u-boot/builds/551244482
Schrempf Frieder
Vignesh R
