[U-Boot] [PULL] u-boot-socfpga/master
This was rotting in for too long, might as well push it upstream ...
The following changes since commit 3c476d841daa491f87c8f07851038afbdf4d90a8:
Merge git://git.denx.de/u-boot-fsl-qoriq (2017-04-18 11:36:06 -0400)
git://git.denx.de/u-boot-socfpga.git master
for you to fetch changes up to 6bd041f00d5d80761852eae1ecb7879a27f3c289:
arm: socfpga: add cyclone5 based de10-nano board (2017-04-25 12:46:44 +0200)
---------------------------------------------------------------- Dalon Westergreen (1): arm: socfpga: add cyclone5 based de10-nano board
arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_cyclone5_de10_nano.dts | 68 ++++++++++ arch/arm/mach-socfpga/Kconfig | 7 + board/terasic/de10-nano/MAINTAINERS | 5 + board/terasic/de10-nano/Makefile | 9 ++ board/terasic/de10-nano/qts/iocsr_config.h | 660 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/terasic/de10-nano/qts/pinmux_config.h | 219 +++++++++++++++++++++++++++++++ board/terasic/de10-nano/qts/pll_config.h | 85 ++++++++++++ board/terasic/de10-nano/qts/sdram_config.h | 344 ++++++++++++++++++++++++++++++++++++++++++++++++ board/terasic/de10-nano/socfpga.c | 6 + configs/socfpga_de10_nano_defconfig | 59 +++++++++ include/configs/socfpga_de10_nano.h | 33 +++++ 12 files changed, 1496 insertions(+) create mode 100644 arch/arm/dts/socfpga_cyclone5_de10_nano.dts create mode 100644 board/terasic/de10-nano/MAINTAINERS create mode 100644 board/terasic/de10-nano/Makefile create mode 100644 board/terasic/de10-nano/qts/iocsr_config.h create mode 100644 board/terasic/de10-nano/qts/pinmux_config.h create mode 100644 board/terasic/de10-nano/qts/pll_config.h create mode 100644 board/terasic/de10-nano/qts/sdram_config.h create mode 100644 board/terasic/de10-nano/socfpga.c create mode 100644 configs/socfpga_de10_nano_defconfig create mode 100644 include/configs/socfpga_de10_nano.h
