[U-Boot] [PATCH] config: ls1012aqds: Add USB EHCI support for ls1012aqds
Add USB EHCI support for ls1012aqds platform
Signed-off-by: Rajat Srivastava rajat.srivastava@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: yinbo.zhu yinbo.zhu@nxp.com --- arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h | 1 + include/configs/ls1012aqds.h | 2 ++ include/usb/ehci-ci.h | 2 +- 3 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 8ad199f..4afc338 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -35,6 +35,7 @@ #define CONFIG_SYS_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x01f00000) #define CONFIG_SYS_XHCI_USB2_ADDR (CONFIG_SYS_IMMR + 0x02000000) #define CONFIG_SYS_XHCI_USB3_ADDR (CONFIG_SYS_IMMR + 0x02100000) +#define CONFIG_SYS_EHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x07600000) #define CONFIG_SYS_PCIE1_ADDR (CONFIG_SYS_IMMR + 0x2400000) #define CONFIG_SYS_PCIE2_ADDR (CONFIG_SYS_IMMR + 0x2500000) #define CONFIG_SYS_PCIE3_ADDR (CONFIG_SYS_IMMR + 0x2600000) diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index 5b8500b..55f2578 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -115,6 +115,8 @@
#ifdef CONFIG_HAS_FSL_DR_USB #define CONFIG_USB_EHCI_FSL +#define CONFIG_USB_ULPI +#define CONFIG_USB_ULPI_VIEWPORT #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #endif
diff --git a/include/usb/ehci-ci.h b/include/usb/ehci-ci.h index 847b698..cd3eb47 100644 --- a/include/usb/ehci-ci.h +++ b/include/usb/ehci-ci.h @@ -156,7 +156,7 @@ #elif defined(CONFIG_MPC85xx) #define CONFIG_SYS_FSL_USB1_ADDR CONFIG_SYS_MPC85xx_USB1_ADDR #define CONFIG_SYS_FSL_USB2_ADDR CONFIG_SYS_MPC85xx_USB2_ADDR -#elif defined(CONFIG_ARCH_LS1021A) +#elif defined(CONFIG_LS102XA) || defined(CONFIG_ARCH_LS1012A) #define CONFIG_SYS_FSL_USB1_ADDR CONFIG_SYS_EHCI_USB1_ADDR #define CONFIG_SYS_FSL_USB2_ADDR 0 #endif
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of yinbo.zhu@nxp.com Sent: Thursday, July 27, 2017 3:19 PM To: u-boot@lists.denx.de Cc: open list:OPEN FIRMWARE AND FLATTENED DEVICE TREE BINDINGS devicetree@vger.kernel.org; Mihai Emilian Bantea mihai.bantea@nxp.com; Horia Geantă horia.geanta@nxp.com; Marc Zyngier marc.zyngier@arm.com; Gang Liu gang.liu@nxp.com; open list <linux- kernel@vger.kernel.org>; Scott Wood oss@buserror.net; Rajat Srivastava rajat.srivastava@nxp.com; Yinbo Zhu yinbo.zhu@nxp.com; moderated list:ARM64 PORT (AARCH64 ARCHITECTURE) <linux-arm- kernel@lists.infradead.org> Subject: [U-Boot] [PATCH] config: ls1012aqds: Add USB EHCI support for ls1012aqds
Why CONFIG_ARCH_LS1021A has been replaced by CONFIG_LS102XA?
-prabhakar
Removed commit message (a copy of subject). Applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Please use CONFIG_ARCH_LS1021A, not CONFIG_LS102XA.
York
<snip>
Never mind. This is merged. I will send a patch to fix it.
York
Prabhakar Kushwaha
yinbo.zhu@nxp.com
York Sun
