[PATCH v2 2/3] riscv: Add ZERO_MEM_BEFORE_USE implementation
Add the actual support code for ZERO_MEM_BEFORE_USE and remove existing Starfive JH7110's L2 LIM clean code, since existing code has following issues: 1. Each hart (in the middle of a function call) overwriting its own stack and other harts' stacks. (data-race and data-corruption) 2. Lottery winner hart can be doing "board_init_f_init_reserve", while other harts are in the middle of zeroing L2 LIM. (data-race)
Signed-off-by: Bo Gan ganboing@gmail.com Signed-off-by: Shengyu Qu wiagn233@outlook.com --- arch/riscv/cpu/jh7110/spl.c | 25 ------------------------- arch/riscv/cpu/start.S | 12 ++++++++++++ common/init/board_init.c | 3 +++ 3 files changed, 15 insertions(+), 25 deletions(-)
diff --git a/arch/riscv/cpu/jh7110/spl.c b/arch/riscv/cpu/jh7110/spl.c index 72adcefa0e..4047b10efe 100644 --- a/arch/riscv/cpu/jh7110/spl.c +++ b/arch/riscv/cpu/jh7110/spl.c @@ -13,7 +13,6 @@ #include <init.h>
#define CSR_U74_FEATURE_DISABLE 0x7c1 -#define L2_LIM_MEM_END 0x81FFFFFUL
DECLARE_GLOBAL_DATA_PTR;
@@ -59,9 +58,6 @@ int spl_soc_init(void)
void harts_early_init(void) { - ulong *ptr; - u8 *tmp; - ulong len, remain; /* * Feature Disable CSR * @@ -70,25 +66,4 @@ void harts_early_init(void) */ if (CONFIG_IS_ENABLED(RISCV_MMODE)) csr_write(CSR_U74_FEATURE_DISABLE, 0); - - /* clear L2 LIM memory - * set __bss_end to 0x81FFFFF region to zero - * The L2 Cache Controller supports ECC. ECC is applied to SRAM. - * If it is not cleared, the ECC part is invalid, and an ECC error - * will be reported when reading data. - */ - ptr = (ulong *)&__bss_end; - len = L2_LIM_MEM_END - (ulong)&__bss_end; - remain = len % sizeof(ulong); - len /= sizeof(ulong); - - while (len--) - *ptr++ = 0; - - /* clear the remain bytes */ - if (remain) { - tmp = (u8 *)ptr; - while (remain--) - *tmp++ = 0; - } } diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S index 59d58a5a57..30cf674370 100644 --- a/arch/riscv/cpu/start.S +++ b/arch/riscv/cpu/start.S @@ -111,6 +111,18 @@ call_board_init_f: * It's essential before any function call, otherwise, we get data-race. */
+/* clear stack if necessary */ +#if CONFIG_IS_ENABLED(ZERO_MEM_BEFORE_USE) +clear_stack: + li t1, 1 + slli t1, t1, CONFIG_STACK_SIZE_SHIFT + sub t1, sp, t1 +clear_stack_loop: + SREG zero, 0(t1) /* t1 is always 16 byte aligned */ + addi t1, t1, REGBYTES + blt t1, sp, clear_stack_loop +#endif + call_board_init_f_0: /* find top of reserve space */ #if CONFIG_IS_ENABLED(SMP) diff --git a/common/init/board_init.c b/common/init/board_init.c index 96ffb79a98..ab8c508ad8 100644 --- a/common/init/board_init.c +++ b/common/init/board_init.c @@ -162,6 +162,9 @@ void board_init_f_init_reserve(ulong base) #if CONFIG_VAL(SYS_MALLOC_F_LEN) /* go down one 'early malloc arena' */ gd->malloc_base = base; +#if CONFIG_IS_ENABLED(ZERO_MEM_BEFORE_USE) + memset((void *)base, '\0', CONFIG_VAL(SYS_MALLOC_F_LEN)); +#endif #endif
if (CONFIG_IS_ENABLED(SYS_REPORT_STACK_F_USAGE))
Shengyu Qu
